Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/contrib/crossrpms/rtems4.10/i386
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @c2352fc   11/25/08 03:42:40 Ralf Corsepius newlib-1.16.0.cvs.20081124-rtems4.10-20081124.diff 4.104.115
(edit) @1efc075   11/25/08 03:41:52 Ralf Corsepius newlib-1.16.0.cvs.20081124. GCC_RPMREL = 13%{?dist}. 4.104.115
(edit) @9fb5c8a   11/24/08 06:21:17 Ralf Corsepius Regenerate. 4.104.115
(edit) @aebe4b6   11/24/08 06:19:54 Ralf Corsepius GCC_RPMREL = 12%{?dist}. 4.104.115
(edit) @56e3371   11/24/08 06:19:17 Ralf Corsepius newlib-1.16.0-rtems4.10-20081120.diff. 4.104.115
(edit) @8429438   11/19/08 17:07:56 Ralf Corsepius Regenerate. 4.104.115
(edit) @aedc2d5a   11/19/08 17:04:50 Ralf Corsepius Preps for newlib-cvs. Bump GCC_RPMREL. 4.104.115
(edit) @6357d742   11/19/08 17:04:21 Ralf Corsepius Update to gcc-core-4.3.2-rtems4.10-20081119.diff. Preps for newlib-cvs. 4.104.115
(edit) @f1322b47   11/10/08 10:47:51 Ralf Corsepius Regenerate. 4.104.115
(edit) @782c454   11/10/08 10:46:50 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @719a5c7   11/07/08 02:54:05 Ralf Corsepius Regenerate. 4.104.115
(edit) @181e2da   11/07/08 02:42:13 Ralf Corsepius Bump GCC_RPMREL. 4.104.115
(edit) @05c66cf   11/05/08 19:07:46 Ralf Corsepius Update. 4.104.115
(edit) @d41e18f8   10/28/08 22:12:04 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.115
(edit) @b3bfca66   10/23/08 04:34:14 Ralf Corsepius Regenerate. 4.104.115
(edit) @1cf80bf   10/23/08 04:32:35 Ralf Corsepius binutils-2.19. 4.104.115
(edit) @54726239   10/16/08 03:09:18 Ralf Corsepius Regenerate. 4.104.115
(edit) @bc23d85   10/16/08 03:08:20 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @e56584fb   10/16/08 02:49:07 Ralf Corsepius Regenerate. 4.104.115
(edit) @d596630   10/16/08 02:48:16 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.115
(edit) @945f9df9   10/10/08 02:33:18 Ralf Corsepius Regenerate. 4.104.115
(edit) @1171c46   10/10/08 02:32:36 Ralf Corsepius binutils-2.18.93-rtems4.10-20081010.diff. 4.104.115
(edit) @c81b995   10/10/08 02:30:19 Ralf Corsepius BINUTILS_VERS = 2.18.93 4.104.115
(edit) @c41d6b4   10/04/08 05:01:08 Ralf Corsepius Regenerate. 4.104.115
(edit) @e7910cd7   10/04/08 05:00:16 Ralf Corsepius Update to binutils-2.18.92. 4.104.115
(edit) @b38ae26b   10/03/08 03:41:40 Ralf Corsepius Regenerate. 4.104.115
(edit) @df339c2   10/03/08 03:40:27 Ralf Corsepius gdb-6.8-rtems4.10-20081003.diff. Abandon _without_sources. 4.104.115
(edit) @30e604d   10/03/08 03:39:44 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @3d0a3acb   10/03/08 02:59:19 Ralf Corsepius Regenerate. 4.104.115
(edit) @24d6e0b   10/03/08 02:53:26 Ralf Corsepius Bump BINUTILS_RPMREL 4.104.115
(edit) @7d28f71   10/03/08 02:52:48 Ralf Corsepius Add binutils-2.18.91-rtems4.10-20081003.diff 4.104.115
(edit) @aa2d0450   09/17/08 15:26:36 Ralf Corsepius binutils-2.18.91. 4.104.115
(edit) @9a5e29b   09/17/08 14:38:54 Ralf Corsepius Switch to gdb-6.8-rtems4.10-20080917.diff. 4.104.115
(edit) @fd92869   09/12/08 07:48:11 Ralf Corsepius Regenerate. 4.104.115
(edit) @c42b2459   09/12/08 07:47:01 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @0558e58   09/12/08 07:46:06 Ralf Corsepius Update. 4.104.115
(edit) @3e256081   09/11/08 15:57:25 Ralf Corsepius GCC_RPMREL = 3 (Rebuild against binutils-2.18.90). 4.104.115
(edit) @518adaf   09/11/08 15:56:31 Ralf Corsepius Abandon gcc-4.3.1. 4.104.115
(edit) @04e8c69   09/11/08 12:00:46 Ralf Corsepius Upgrade to binutils-2.18.90. 4.104.115
(edit) @d8a213b2   08/28/08 19:54:29 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @e90124e   08/28/08 19:53:37 Ralf Corsepius Bump GCC_RPMREL. 4.104.114.95
(edit) @183e5cf   08/28/08 14:13:55 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @68e6a18d   08/28/08 14:11:48 Ralf Corsepius Bump BINUTILS_RPMREL. 4.104.114.95
(edit) @2fb65fbf   08/28/08 14:08:37 Ralf Corsepius gcc-4.3.2 4.104.114.95
(edit) @882a12a   08/28/08 01:14:03 Ralf Corsepius Use URLs for patches. 4.104.114.95
(edit) @5c7a69ba   08/27/08 07:52:59 Ralf Corsepius Update. 4.104.114.95
(edit) @e69afe2   08/27/08 07:38:40 Ralf Corsepius Use full URLs to patches. 4.104.114.95
(edit) @dbb26e7   07/05/08 05:33:27 Ralf Corsepius Add full URL to patch. 4.104.114.95
(edit) @3f6e3fa   07/03/08 15:30:57 Ralf Corsepius New. 4.104.114.95
(edit) @5916f579   07/03/08 08:37:15 Ralf Corsepius Remove 4.3.0. 4.104.114.95
(edit) @35f8615   07/03/08 08:24:44 Ralf Corsepius Set target to rtems4.10. 4.104.114.95
(edit) @b1bd76b   07/03/08 08:20:43 Ralf Corsepius Reset *_RPMREL. 4.104.114.95
(add) @01141c5   07/03/08 08:18:22 Ralf Corsepius New. 4.104.114.95
