# # ChangeLog for contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 07:19:51 Tue, 03 Feb 2009 11:40:15 GMT Ralf Corsepius [2453f66] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Upgrade to binutils-2.19.1 Mon, 26 Jan 2009 07:17:37 GMT Ralf Corsepius [35381baa] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.1/i586/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/gcc.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) BR: exact version of build host tools for Cdn-X builds. Tue, 23 Dec 2008 07:00:55 GMT Ralf Corsepius [8ffd16bb] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) newlib-1.17.0 Wed, 05 Nov 2008 19:07:46 GMT Ralf Corsepius [05c66cf] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Update. Thu, 23 Oct 2008 04:34:14 GMT Ralf Corsepius [b3bfca66] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Thu, 16 Oct 2008 02:49:07 GMT Ralf Corsepius [e56584fb] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Fri, 10 Oct 2008 02:33:18 GMT Ralf Corsepius [945f9df9] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Sat, 04 Oct 2008 05:01:08 GMT Ralf Corsepius [c41d6b4] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Fri, 03 Oct 2008 02:59:19 GMT Ralf Corsepius [3d0a3acb] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) Regenerate. Wed, 17 Sep 2008 15:26:36 GMT Ralf Corsepius [aa2d0450] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) binutils-2.18.91. Thu, 11 Sep 2008 12:00:46 GMT Ralf Corsepius [04e8c69] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Upgrade to binutils-2.18.90. Thu, 28 Aug 2008 14:13:55 GMT Ralf Corsepius [183e5cf] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) Regenerate. Thu, 03 Jul 2008 15:30:57 GMT Ralf Corsepius [3f6e3fa] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/tic4x/rtems-4.10-tic4x-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/tic4x/rtems-4.10-tic4x-rtems4.10-gcc.spec (added) New.
