# # ChangeLog for contrib/crossrpms/patches in rtems # # Generated by Trac 1.2.1.dev0 # 05/04/24 14:02:34 Fri, 12 Jan 2007 04:35:49 GMT Ralf Corsepius [652473b3] * contrib/crossrpms/patches/gcc-core-4.2-20070110-rtems4.8-20070112.diff (added) Update (bfin merged into upstream) Wed, 10 Jan 2007 06:05:01 GMT Ralf Corsepius [3d62598] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070110.diff (added) Add ECANCELED. Thu, 04 Jan 2007 08:00:32 GMT Ralf Corsepius [e0c27b1] * contrib/crossrpms/patches/gcc-core-4.2-20070102-rtems4.8-20070104.diff (added) New. Tue, 02 Jan 2007 10:44:12 GMT Ralf Corsepius [227afd10] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070102.diff (added) New. Tue, 19 Dec 2006 16:30:30 GMT Ralf Corsepius [adb07b1] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20061219.diff (added) New. Wed, 15 Nov 2006 03:48:33 GMT Ralf Corsepius [b2b99f57] * contrib/crossrpms/patches/gcc-4.1.1-bfinrtems-20060810a.diff (deleted) * contrib/crossrpms/patches/newlib-1.14.0-bfinrtems-20060810a.diff (deleted) Remove (Obsolete) Wed, 15 Nov 2006 03:43:43 GMT Ralf Corsepius [5a7f1e1] * contrib/crossrpms/patches/gcc-core-4.2-20061114-rtems4.8-20061115.diff (added) New. Tue, 14 Nov 2006 17:50:23 GMT Ralf Corsepius [f4884049] * contrib/crossrpms/patches/binutils-2.17-rtems4.8-20061021.diff (added) Add. Thu, 09 Nov 2006 11:19:05 GMT Ralf Corsepius [e315b421] * contrib/crossrpms/patches/gcc-core-4.2-20061031-rtems4.8-20061109.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-rtems4.8-20061109.diff (added) New (Merge BFIN patches). Fri, 27 Oct 2006 08:42:14 GMT Ralf Corsepius [5fcda02] * contrib/crossrpms/patches/binutils-2.17-rtems-20060711.diff (deleted) * contrib/crossrpms/patches/binutils-2.17-rtems-20060812.diff (deleted) * contrib/crossrpms/patches/binutils-2.17-rtems-20060815.diff (deleted) Remove (unused) Fri, 27 Oct 2006 08:32:40 GMT Ralf Corsepius [d94d76ad] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060909.diff (deleted) Remove (unused). Fri, 27 Oct 2006 08:32:05 GMT Ralf Corsepius [f5b9b5b] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20061026.diff (deleted) Remove (broken). Fri, 27 Oct 2006 08:31:28 GMT Ralf Corsepius [2466600] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060707.diff (deleted) Remove (obsolete). Fri, 27 Oct 2006 08:18:04 GMT Ralf Corsepius [653db3f] * contrib/crossrpms/patches/newlib-1.14.0-rtems4.8-20061027.diff (added) New. Thu, 26 Oct 2006 18:01:34 GMT Joel Sherrill [7693aec] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/patches/newlib-1.14.0-rtems-20061026.diff (added) 2006-10-26 Joel Sherrill * ... Thu, 19 Oct 2006 08:03:50 GMT Ralf Corsepius [ae4894a] * contrib/crossrpms/patches/automake-1.8.1-rtems-20040112-1.diff (deleted) Remove. Wed, 13 Sep 2006 11:50:03 GMT Ralf Corsepius [4bbd0b4] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060909.diff (added) New. Fri, 08 Sep 2006 20:33:52 GMT Joel Sherrill [9cb14887] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff (added) New file. Tue, 22 Aug 2006 11:57:03 GMT Chris Johns [e5e88aa] * contrib/crossrpms/patches/gcc-core-4.0.3-rtems-20060822.diff (added) The .exe for the versioned execuable for MinGW. Mon, 21 Aug 2006 14:38:33 GMT Joel Sherrill [a94075b] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/patches/binutils-2.17-rtems-20060815.diff (added) * contrib/crossrpms/rtems4.7/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/binutils-sources.add (modified) 2006-08-21 Joel Sherrill * ... Sat, 12 Aug 2006 06:03:27 GMT Ralf Corsepius [070cf12] * contrib/crossrpms/patches/binutils-2.17-rtems-bfin-20060810.diff (deleted) Remove (Merged into binutils-2.17-rtems-20060812.diff). Sat, 12 Aug 2006 06:02:29 GMT Ralf Corsepius [d218a83] * contrib/crossrpms/patches/binutils-2.17-rtems-20060812.diff (added) Update from binutils-2.17_branch. Merge bfin patch. Fri, 11 Aug 2006 21:37:40 GMT Joel Sherrill [6d7e836] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/patches/binutils-2.17-rtems-bfin-20060810.diff (added) * contrib/crossrpms/patches/gcc-4.1.1-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-bfinrtems-20060810a.diff (added) * contrib/crossrpms/rtems4.7/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.7/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.7/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gdb-sources.add (added) 2006-08-11 Joel Sherrill * ... Thu, 03 Aug 2006 02:50:36 GMT Ralf Corsepius [e85211e] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060626.diff (deleted) Remove (Obsolete) Thu, 03 Aug 2006 02:48:31 GMT Ralf Corsepius [52053484] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060704.diff (deleted) Remove Tue, 25 Jul 2006 14:18:12 GMT Ralf Corsepius [6cbe966] * contrib/crossrpms/patches/automake-1.8.1-rtems-20040112-1.diff (added) New. Wed, 19 Jul 2006 21:51:39 GMT Chris Johns [45def1d] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff (added) Added patch to fix GCC bug PR28400. Thu, 13 Jul 2006 16:48:53 GMT Joel Sherrill [460d7e7] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/patches/gdb-6.5-rtems-20060713.diff (added) * contrib/crossrpms/rtems4.7/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.7/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (modified) 2006-07-13 Joel Sherrill * ... Wed, 12 Jul 2006 20:48:51 GMT Joel Sherrill [d959898] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/patches/gdb-6.4-rtems-20060712.diff (added) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (modified) 2006-07-12 RTEMS * rtems4.7/arm/gdb-sources.add, ... Tue, 11 Jul 2006 11:32:10 GMT Ralf Corsepius [2dd8aa1e] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060707.diff (added) New. Remove arm/endian.h Tue, 11 Jul 2006 03:28:02 GMT Ralf Corsepius [9807f04] * contrib/crossrpms/patches/binutils-2.17-rtems-20060711.diff (added) New. m68k/cpu32 patch. Thu, 06 Jul 2006 13:19:11 GMT Ralf Corsepius [c484d2ef] * contrib/crossrpms/patches/gdb-6.4-rtems-20060311.diff (added) New. Wed, 05 Jul 2006 14:22:52 GMT Ralf Corsepius [72f8c0c6] * contrib/crossrpms/patches/binutils-2.16.1-rtems-20050708.diff (added) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060626.diff (added) New. Wed, 05 Jul 2006 13:21:52 GMT Ralf Corsepius [6caac6d] * contrib/crossrpms/patches/newlib-1.14.0-rtems-20060704.diff (added) New.
