# # ChangeLog for contrib/crossrpms/mingw32 in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 16:51:27 Tue, 24 Jul 2007 14:26:46 GMT Ralf Corsepius [e0d85b74] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into BINUTILS_RPMREL. Tue, 24 Jul 2007 14:24:43 GMT Ralf Corsepius [b8a8bfb0] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into GCC_RPMREL. Tue, 27 Feb 2007 14:34:01 GMT Ralf Corsepius [258d7d5a] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) Add BINTUTILS_PKGVERS. Tue, 27 Feb 2007 14:33:15 GMT Ralf Corsepius [916bb726] * contrib/crossrpms/mingw32/i686/libs.add (modified) * contrib/crossrpms/mingw32/i686/w32api.add (modified) Remove _use_internal_dependency_generator 0. Remove ... Mon, 26 Feb 2007 15:54:49 GMT Ralf Corsepius [67c1bb5e] * contrib/crossrpms/cygwin/binutils.am (modified) * contrib/crossrpms/cygwin/gcc.am (modified) * contrib/crossrpms/freebsd5.2/binutils.am (modified) * contrib/crossrpms/freebsd5.2/gcc.am (modified) * contrib/crossrpms/freebsd6.0/binutils.am (modified) * contrib/crossrpms/freebsd6.0/gcc.am (modified) * contrib/crossrpms/freebsd6.1/binutils.am (modified) * contrib/crossrpms/freebsd6.1/gcc.am (modified) * contrib/crossrpms/mingw32/binutils.am (modified) * contrib/crossrpms/mingw32/gcc.am (modified) * contrib/crossrpms/mkspec.am (modified) * contrib/crossrpms/rtems4.8/binutils.am (modified) * contrib/crossrpms/rtems4.8/gcc.am (modified) * contrib/crossrpms/rtems4.8/gdb.am (modified) * contrib/crossrpms/solaris2.7/binutils.am (modified) * contrib/crossrpms/solaris2.7/gcc.am (modified) Add MKSPEC0. Mon, 26 Feb 2007 09:55:59 GMT Ralf Corsepius [a8149e7] * contrib/crossrpms/cygwin/i686/binutils-sources.add (modified) * contrib/crossrpms/freebsd5.2/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/i586/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.1/i586/binutils-sources.add (modified) * contrib/crossrpms/mingw32/i686/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (modified) Use binutils_pkgvers instead of binutils_version in Source0. Mon, 26 Feb 2007 09:26:59 GMT Ralf Corsepius [f7712468] * contrib/crossrpms/cygwin/binutils.am (modified) * contrib/crossrpms/freebsd5.2/binutils.am (modified) * contrib/crossrpms/freebsd6.0/binutils.am (modified) * contrib/crossrpms/freebsd6.1/binutils.am (modified) * contrib/crossrpms/mingw32/binutils.am (modified) * contrib/crossrpms/rtems4.8/binutils.am (modified) Add BINUTILS_PKGVERS. Fri, 23 Feb 2007 07:24:55 GMT Ralf Corsepius [b581f06] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) Set BINUTILS_RPMREL = 1 Fri, 23 Feb 2007 07:24:21 GMT Ralf Corsepius [3028ab8] * contrib/crossrpms/mingw32/i686/binutils-sources.add (modified) Use http://downloads.sourceforge.net/mingw/ as base for Source0. Fri, 23 Feb 2007 06:19:23 GMT Ralf Corsepius [15fda0f7] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) Set W32API_RPMREL = 1 Fri, 23 Feb 2007 06:18:53 GMT Ralf Corsepius [62a7c6b] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) Set MINGW32_RPMREL = 1 Fri, 23 Feb 2007 06:18:06 GMT Ralf Corsepius [6ede2df] * contrib/crossrpms/mingw32/gcc.am (modified) Add GCC_PKGVERS (PR 1220) Fri, 23 Feb 2007 06:17:01 GMT Ralf Corsepius [4442d9b4] * contrib/crossrpms/mingw32/i686/libs.add (modified) * contrib/crossrpms/mingw32/i686/w32api.add (modified) Use http://downloads.sourceforge.net/mingw/ as base for Source0. Fri, 23 Feb 2007 06:03:06 GMT Ralf Corsepius [7a345828] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) Upgrade to mingw-runtime-3.11, w32api-3.8. Disable building infos ... Fri, 12 Jan 2007 08:31:37 GMT Ralf Corsepius [72b911c] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Add BINUTILS_OPTS += Thu, 04 Jan 2007 13:43:21 GMT Ralf Corsepius [35db46f] * contrib/crossrpms/cygwin/binutils.am (modified) * contrib/crossrpms/freebsd5.2/binutils.am (modified) * contrib/crossrpms/freebsd6.0/binutils.am (modified) * contrib/crossrpms/freebsd6.1/binutils.am (modified) * contrib/crossrpms/mingw32/binutils.am (modified) * contrib/crossrpms/rtems4.8/binutils.am (modified) * contrib/crossrpms/solaris2.7/binutils.am (modified) Add BINUTILS_OPTS Sun, 23 Jul 2006 05:36:19 GMT Ralf Corsepius [aec66f3] * contrib/crossrpms/cygwin/i686/gcc-sources.add (modified) * contrib/crossrpms/freebsd5.2/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd6.0/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd6.1/i586/gcc-sources.add (modified) * contrib/crossrpms/mingw32/i686/gcc-sources.add (modified) * contrib/crossrpms/solaris2.7/sparc/gcc-sources.add (modified) Elminate blank lines. Fri, 14 Jul 2006 06:05:04 GMT Ralf Corsepius [cb9c5a8] * contrib/crossrpms/mingw32/i686/Makefile.am (modified) include ../gcc.am Fri, 14 Jul 2006 06:04:51 GMT Ralf Corsepius [969f4d5] * contrib/crossrpms/mingw32/gcc.am (added) New. Split out from i686/Makefile.am Fri, 07 Jul 2006 07:04:53 GMT Ralf Corsepius [80bd514f] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Split out binutils. Fri, 07 Jul 2006 05:02:39 GMT Ralf Corsepius [0f9fd94f] * contrib/crossrpms/cygwin/binutils.am (added) * contrib/crossrpms/mingw32/binutils.am (added) New. Wed, 05 Jul 2006 08:42:42 GMT Ralf Corsepius [c77cc1de] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) EXTRA_DIST += ../gcc-prep.add Wed, 05 Jul 2006 07:38:53 GMT Ralf Corsepius [b7e8b3e] * contrib/crossrpms/cygwin/.cvsignore (modified) * contrib/crossrpms/freebsd5.2/.cvsignore (modified) * contrib/crossrpms/freebsd6.0/.cvsignore (modified) * contrib/crossrpms/freebsd6.1/.cvsignore (modified) * contrib/crossrpms/mingw32/.cvsignore (modified) * contrib/crossrpms/solaris2.7/.cvsignore (modified) Reflect changes. Wed, 05 Jul 2006 07:37:04 GMT Ralf Corsepius [1f193a8b] * contrib/crossrpms/cygwin/i686/.cvsignore (added) * contrib/crossrpms/freebsd5.2/i586/.cvsignore (added) * contrib/crossrpms/freebsd6.0/i586/.cvsignore (added) * contrib/crossrpms/freebsd6.1/i586/.cvsignore (added) * contrib/crossrpms/mingw32/i686/.cvsignore (added) * contrib/crossrpms/solaris2.7/sparc/.cvsignore (added) New. Wed, 05 Jul 2006 07:32:19 GMT Ralf Corsepius [478a318] * contrib/crossrpms/cygwin/binutils-sources.add (deleted) * contrib/crossrpms/cygwin/gcc-sources.add (deleted) * contrib/crossrpms/cygwin/libs.add (deleted) * contrib/crossrpms/cygwin/target-libs.add (deleted) * contrib/crossrpms/cygwin/target-w32api.add (deleted) * contrib/crossrpms/cygwin/w32api.add (deleted) * contrib/crossrpms/freebsd5.2/binutils-sources.add (deleted) * contrib/crossrpms/freebsd5.2/gcc-sources.add (deleted) * contrib/crossrpms/freebsd5.2/libs.add (deleted) * contrib/crossrpms/freebsd5.2/target-libs.add (deleted) * contrib/crossrpms/freebsd6.0/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.0/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.0/libs.add (deleted) * contrib/crossrpms/freebsd6.0/target-libs.add (deleted) * contrib/crossrpms/freebsd6.1/binutils-sources.add (deleted) * contrib/crossrpms/freebsd6.1/gcc-sources.add (deleted) * contrib/crossrpms/freebsd6.1/libs.add (deleted) * contrib/crossrpms/freebsd6.1/target-libs.add (deleted) * contrib/crossrpms/mingw32/binutils-sources.add (deleted) * contrib/crossrpms/mingw32/gcc-sources.add (deleted) * contrib/crossrpms/mingw32/libs.add (deleted) * contrib/crossrpms/mingw32/target-libs.add (deleted) * contrib/crossrpms/mingw32/target-w32api.add (deleted) * contrib/crossrpms/mingw32/w32api.add (deleted) * contrib/crossrpms/solaris2.7/binutils-sources.add (deleted) * contrib/crossrpms/solaris2.7/gcc-sources.add (deleted) * contrib/crossrpms/solaris2.7/libs.add (deleted) * contrib/crossrpms/solaris2.7/target-libs.add (deleted) Remove. Wed, 05 Jul 2006 07:31:07 GMT Ralf Corsepius [f5638da] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) New. Wed, 05 Jul 2006 07:29:55 GMT Ralf Corsepius [120c2980] * contrib/crossrpms/cygwin/i686/Makefile.am (added) * contrib/crossrpms/cygwin/i686/binutils-sources.add (added) * contrib/crossrpms/cygwin/i686/gcc-sources.add (added) * contrib/crossrpms/cygwin/i686/libs.add (added) * contrib/crossrpms/cygwin/i686/target-libs.add (added) * contrib/crossrpms/cygwin/i686/target-w32api.add (added) * contrib/crossrpms/cygwin/i686/w32api.add (added) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (added) * contrib/crossrpms/freebsd5.2/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd5.2/i586/gcc-prep.add (added) * contrib/crossrpms/freebsd5.2/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd5.2/i586/libs.add (added) * contrib/crossrpms/freebsd5.2/i586/target-libs.add (added) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (added) * contrib/crossrpms/freebsd6.0/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd6.0/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd6.0/i586/libs.add (added) * contrib/crossrpms/freebsd6.0/i586/target-libs.add (added) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (added) * contrib/crossrpms/freebsd6.1/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd6.1/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd6.1/i586/libs.add (added) * contrib/crossrpms/freebsd6.1/i586/target-libs.add (added) * contrib/crossrpms/mingw32/i686/Makefile.am (added) * contrib/crossrpms/mingw32/i686/binutils-sources.add (added) * contrib/crossrpms/mingw32/i686/gcc-sources.add (added) * contrib/crossrpms/mingw32/i686/libs.add (added) * contrib/crossrpms/mingw32/i686/target-libs.add (added) * contrib/crossrpms/mingw32/i686/target-w32api.add (added) * contrib/crossrpms/mingw32/i686/w32api.add (added) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (added) * contrib/crossrpms/solaris2.7/sparc/binutils-sources.add (added) * contrib/crossrpms/solaris2.7/sparc/gcc-sources.add (added) * contrib/crossrpms/solaris2.7/sparc/libs.add (added) * contrib/crossrpms/solaris2.7/sparc/target-libs.add (added) Moved from .. Mon, 03 Jul 2006 17:19:32 GMT Ralf Corsepius [c34612ce] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Reflect new mkspec. Mon, 03 Jul 2006 14:33:13 GMT Ralf Corsepius [9f5f501f] * contrib/crossrpms/mingw32/Makefile.am (modified) Apply SPECSTRIP. Mon, 19 Jun 2006 07:00:05 GMT Ralf Corsepius [677c3d81] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) More preps for VPATH builds. Wed, 08 Mar 2006 09:22:44 GMT Ralf Corsepius [f7c8422] * contrib/crossrpms/mingw32/gcc-sources.add (modified) Deactivate PATCH0 (not required for gcc >= 4.1.0 Tue, 07 Mar 2006 05:26:26 GMT Ralf Corsepius [6eba5919] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Distribute local *.add files. Mon, 06 Mar 2006 15:43:10 GMT Ralf Corsepius [ab163629] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) GCC_VERS = 4.1.0 Mon, 06 Mar 2006 15:36:59 GMT Ralf Corsepius [5c8f5f66] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Subst gcc_rpmvers for LIB packages. Mon, 06 Mar 2006 05:55:02 GMT Ralf Corsepius [c04a6103] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/libs.add (modified) * contrib/crossrpms/freebsd5.2/libs.add (modified) * contrib/crossrpms/freebsd6.0/libs.add (modified) * contrib/crossrpms/mingw32/libs.add (modified) * contrib/crossrpms/mingw32/w32api.add (modified) * contrib/crossrpms/solaris2.7/libs.add (modified) Remove stray blank in %expand to setup rpmvers. Fri, 03 Mar 2006 16:56:57 GMT Ralf Corsepius [82e0551] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add gfortran. Add objc. Fri, 24 Feb 2006 15:24:03 GMT Ralf Corsepius [102c876] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add gcc-prep.add Fri, 24 Feb 2006 15:04:25 GMT Ralf Corsepius [ef607c60] * contrib/crossrpms/cygwin/gcc-prep.add (added) * contrib/crossrpms/freebsd5.2/gcc-prep.add (added) * contrib/crossrpms/freebsd6.0/gcc-prep.add (added) * contrib/crossrpms/mingw32/gcc-prep.add (added) * contrib/crossrpms/rtems/gcc-prep.add (added) * contrib/crossrpms/solaris2.7/gcc-prep.add (added) New. Wed, 22 Feb 2006 13:02:32 GMT Ralf Corsepius [0d0560a1] * contrib/crossrpms/cygwin/binutils-sources.add (modified) * contrib/crossrpms/cygwin/gcc-sources.add (modified) * contrib/crossrpms/freebsd5.2/binutils-sources.add (modified) * contrib/crossrpms/freebsd5.2/gcc-sources.add (modified) * contrib/crossrpms/freebsd6.0/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/gcc-sources.add (modified) * contrib/crossrpms/mingw32/binutils-sources.add (modified) * contrib/crossrpms/mingw32/gcc-sources.add (modified) * contrib/crossrpms/rtems/binutils-sources.add (modified) * contrib/crossrpms/rtems/gcc-sources.add (modified) * contrib/crossrpms/solaris2.7/binutils-sources.add (modified) * contrib/crossrpms/solaris2.7/gcc-sources.add (modified) Cosmetics. Tue, 21 Feb 2006 10:27:25 GMT Ralf Corsepius [cb185ee] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Remove @tool_target@-gcc hacks. Tue, 21 Feb 2006 10:11:07 GMT Ralf Corsepius [3072c09] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Delete refs to *-newlib packages in *-gcc.spec.in Tue, 21 Feb 2006 08:22:43 GMT Ralf Corsepius [a310f56] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate osversion Tue, 21 Feb 2006 08:18:29 GMT Ralf Corsepius [1259c55] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate newlib_version Tue, 21 Feb 2006 08:14:06 GMT Ralf Corsepius [14179bab] * contrib/crossrpms/mingw32/Makefile.am (modified) Use $(MKSPEC) to generate *-w32api.spec. Tue, 21 Feb 2006 08:12:54 GMT Ralf Corsepius [42b1efb8] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-binutils.spec. Tue, 21 Feb 2006 08:12:10 GMT Ralf Corsepius [fe977c7] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-gcc.spec. Tue, 21 Feb 2006 08:10:46 GMT Ralf Corsepius [773ab4f] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use $(MKSPEC) to generate *-libs.spec. Tue, 21 Feb 2006 07:54:50 GMT Ralf Corsepius [f538086] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Include ../mkspec.am Mon, 20 Feb 2006 16:37:01 GMT Ralf Corsepius [dd3a261] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Mon, 20 Feb 2006 14:00:55 GMT Ralf Corsepius [b7cd78c1] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Mon, 20 Feb 2006 07:50:18 GMT Ralf Corsepius [d31a75a] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Apply @rpmprefix@ to *.spec files. Sun, 19 Feb 2006 15:17:05 GMT Ralf Corsepius [3d612dc4] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Use package version as RPMREL. Sat, 18 Feb 2006 14:42:05 GMT Ralf Corsepius [38da76ea] * contrib/crossrpms/mingw32/Makefile.am (modified) Switch off _cxx Sat, 18 Feb 2006 11:11:51 GMT Ralf Corsepius [1b8fc3e4] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Add binutils/prep.add, binutils/build.add binutils/install.add Sat, 18 Feb 2006 11:10:22 GMT Ralf Corsepius [6cc81d31] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Cosmetics. Sat, 18 Feb 2006 08:02:54 GMT Ralf Corsepius [384fa937] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Reflect having split out gcc/prep.add and gcc/build.add Sat, 18 Feb 2006 06:53:57 GMT Ralf Corsepius [9d07966e] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Misc. sed magic. Fri, 17 Feb 2006 15:49:16 GMT Ralf Corsepius [149930b1] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Let *.spec.in depend on Makefile.am Fri, 17 Feb 2006 15:45:13 GMT Ralf Corsepius [2fb29308] * contrib/crossrpms/mingw32/Makefile.am (modified) Increment release numbers Fri, 17 Feb 2006 03:10:28 GMT Ralf Corsepius [e7fd334b] * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Propagate $prefix as %_prefix Thu, 16 Feb 2006 17:22:17 GMT Ralf Corsepius [ebc03f5] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Propagate rpmprefix Thu, 16 Feb 2006 14:46:08 GMT Ralf Corsepius [5a4eb6e1] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %binutils_target Thu, 16 Feb 2006 14:45:01 GMT Ralf Corsepius [2fbb0a0] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %gcc_target Thu, 16 Feb 2006 14:38:01 GMT Ralf Corsepius [0f60691] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate deps on %{newlib_version} Thu, 16 Feb 2006 14:16:14 GMT Ralf Corsepius [0510c027] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Unify @PATCH handling. Thu, 16 Feb 2006 14:05:36 GMT Ralf Corsepius [4fa25687] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %{rpmgroup} Thu, 16 Feb 2006 10:06:03 GMT Ralf Corsepius [6bd18c2a] * contrib/crossrpms/mingw32/libs.add (modified) * contrib/crossrpms/mingw32/target-libs.add (modified) * contrib/crossrpms/mingw32/target-w32api.add (modified) * contrib/crossrpms/mingw32/w32api.add (modified) Remove *-libs. Install to sys-root/mingw. Cosmetics. Thu, 16 Feb 2006 10:04:46 GMT Ralf Corsepius [2bf76c9] * contrib/crossrpms/mingw32/gcc-sources.add (modified) Add gcc-4.0.2-mingw.diff Thu, 16 Feb 2006 08:02:11 GMT Ralf Corsepius [f2fac68] * contrib/crossrpms/mingw32/Makefile.am (modified) Backup. Wed, 15 Feb 2006 15:21:54 GMT Ralf Corsepius [d72421b] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Backup. Wed, 15 Feb 2006 15:04:03 GMT Ralf Corsepius [c0b13f0] * contrib/crossrpms/.cvsignore (added) * contrib/crossrpms/binutils/.cvsignore (added) * contrib/crossrpms/freebsd5.2/binutils-sources.add (modified) * contrib/crossrpms/freebsd5.2/gcc-sources.add (added) * contrib/crossrpms/freebsd6.0/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/gcc-sources.add (added) * contrib/crossrpms/mingw32/libs.add (added) * contrib/crossrpms/mingw32/target-libs.add (added) * contrib/crossrpms/mingw32/target-w32api.add (added) * contrib/crossrpms/mingw32/w32api.add (added) * contrib/crossrpms/rtems/.cvsignore (added) * contrib/crossrpms/rtems/Makefile.am (added) * contrib/crossrpms/rtems/binutils-sources.add (added) * contrib/crossrpms/rtems/gcc-sources.add (added) * contrib/crossrpms/solaris2.7/Makefile.am (modified) * contrib/crossrpms/solaris2.7/binutils-sources.add (modified) * contrib/crossrpms/solaris2.7/gcc-sources.add (added) New. Wed, 15 Feb 2006 14:59:48 GMT Ralf Corsepius [209696b] * contrib/crossrpms/mingw32/gcc-sources.add (added) New. Use FSF sources. Wed, 15 Feb 2006 14:57:27 GMT Ralf Corsepius [b4745775] * contrib/crossrpms/mingw32/.cvsignore (modified) Add *.spec.in Tue, 14 Feb 2006 17:16:45 GMT Ralf Corsepius [78128559] * contrib/crossrpms/mingw32/.cvsignore (added) * contrib/crossrpms/mingw32/Makefile.am (added) * contrib/crossrpms/mingw32/binutils-sources.add (added) New.
