# # ChangeLog for contrib/crossrpms/gdb in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 01:21:19 Thu, 12 Mar 2009 09:45:33 GMT Ralf Corsepius [f6a237b] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Sync w/ cvs-head. Thu, 08 May 2008 02:56:34 GMT Ralf Corsepius [ac91ec77] * contrib/crossrpms/gdb/build.add (modified) Enable --with-system-readline only for gdb >= 6.7 Tue, 29 Apr 2008 11:40:37 GMT Ralf Corsepius [9bb08af] * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/prep.add (modified) Improvements for gdb-6.6/6.7 Mon, 28 Apr 2008 13:38:47 GMT Ralf Corsepius [d9393d5] * contrib/crossrpms/gdb/gdb.add (modified) Minor restructurization. Sat, 26 Apr 2008 05:36:01 GMT Ralf Corsepius [17002619] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Use rtems_api. Mon, 31 Mar 2008 04:42:24 GMT Ralf Corsepius [cb63bf0] * contrib/crossrpms/gdb/gdb.add (modified) BR: %{_host_rpmprefix}readline-devel. BR: ... Mon, 31 Mar 2008 04:40:59 GMT Ralf Corsepius [f86abfa] * contrib/crossrpms/gdb/gdb.add (modified) BR: %{_host_rpmprefix}expat-devel. Mon, 31 Mar 2008 04:38:55 GMT Ralf Corsepius [ad476d6e] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Unconditionally BR: %{_host_rpmprefix}gcc. Mon, 31 Mar 2008 04:36:55 GMT Ralf Corsepius [23347e95] * contrib/crossrpms/gdb/prep.add (modified) Remove readline/configure to force not building the bundled readline ... Wed, 26 Mar 2008 07:35:00 GMT Ralf Corsepius [e50a0b2] * contrib/crossrpms/gdb/target-gdb.add (modified) Remove stray blank line. Wed, 26 Mar 2008 06:00:04 GMT Ralf Corsepius [dd56645] * contrib/crossrpms/gdb/build.add (modified) Add CFLAGS_FOR_BUILD. Mon, 24 Mar 2008 16:02:02 GMT Ralf Corsepius [c0141a36] * contrib/crossrpms/gdb/gdb.add (modified) Add %{_host}-gcc for CdnX Mon, 24 Mar 2008 16:00:10 GMT Ralf Corsepius [4ae739d] * contrib/crossrpms/gdb/prep.add (modified) Add patch1. Mon, 24 Mar 2008 15:52:15 GMT Ralf Corsepius [6d71a6f3] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/install.add (modified) Add _bindir to $PATH. Sun, 16 Dec 2007 08:06:08 GMT Ralf Corsepius [fe47a71] * contrib/crossrpms/gdb/build.add (modified) Add _smp_mflags. Thu, 01 Nov 2007 07:32:07 GMT Ralf Corsepius [7cb1d6ea] * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Assume gdb >= 6.4 Wed, 31 Oct 2007 15:45:45 GMT Ralf Corsepius [91a492a2] * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Cleanups for erc32. Wed, 31 Oct 2007 12:30:51 GMT Ralf Corsepius [84f86cb] * contrib/crossrpms/gdb/gdb.add (modified) Reflect suse-10.3 having expat in libexpat-devel. Wed, 31 Oct 2007 05:28:40 GMT Ralf Corsepius [49deaec] * contrib/crossrpms/gdb/build.add (modified) Force building against expat Fri, 28 Sep 2007 07:38:40 GMT Ralf Corsepius [51aac0e] * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/arm/rtems-4.9-arm-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/avr/rtems-4.9-avr-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/bfin/rtems-4.9-bfin-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/h8300/rtems-4.9-h8300-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/i386/rtems-4.9-i386-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/m68k/rtems-4.9-m68k-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/mips/rtems-4.9-mips-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/mipstx39/rtems-4.9-mipstx39-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/powerpc/rtems-4.9-powerpc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sh/rtems-4.9-sh-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gcc.spec (modified) * contrib/crossrpms/rtems4.9/sparc/rtems-4.9-sparc-rtems4.9-gdb.spec (modified) * contrib/crossrpms/rtems4.9/tic4x/rtems-4.9-tic4x-rtems4.9-gcc.spec (modified) Cleanups. Thu, 09 Aug 2007 02:55:36 GMT Ralf Corsepius [2ef64f2] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove references to base packages. Thu, 09 Aug 2007 02:54:01 GMT Ralf Corsepius [9452ee4a] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove support for gdb < 6.0. Thu, 09 Aug 2007 02:53:30 GMT Ralf Corsepius [ee19567c] * contrib/crossrpms/gdb/gdb.add (modified) Remove %{?dist} Fri, 20 Jul 2007 05:23:59 GMT Ralf Corsepius [ed332c8] * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Sync with testing. Sat, 17 Feb 2007 11:30:40 GMT Ralf Corsepius [1ee16e8] * contrib/crossrpms/gdb/gdb.add (modified) BuildRequire: expat-devel for gdb >= 6.6 Sat, 17 Feb 2007 07:03:17 GMT Ralf Corsepius [71f6a66] * contrib/crossrpms/gdb/base-gdb.add (modified) Add || : to install-info. Mon, 30 Oct 2006 03:53:00 GMT Ralf Corsepius [5cde0c4] * contrib/crossrpms/gdb/gdb.add (modified) Update sparc dep to rtems4.8 Sun, 23 Jul 2006 14:16:21 GMT Ralf Corsepius [e41b8b7] * contrib/crossrpms/gdb/base-gdb.add (modified) Let rpm Obsolete < %{gdb_version}-%{release} Sat, 22 Jul 2006 02:40:16 GMT Ralf Corsepius [385f81c] * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Rename rtems4.7-base-gdb into gdb-common Mon, 17 Jul 2006 15:23:04 GMT Ralf Corsepius [c10a31b] * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Require: base packages iff %build_infos Mon, 17 Jul 2006 14:30:28 GMT Ralf Corsepius [d2b94e76] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) Cosmetics. Sun, 16 Jul 2006 06:05:37 GMT Ralf Corsepius [c20efa7] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Cosmetics. Sun, 16 Jul 2006 06:03:36 GMT Ralf Corsepius [473fe62] * contrib/crossrpms/gdb/base-gdb.add (modified) Remove rpmlint warning on subject. Sun, 16 Jul 2006 04:51:16 GMT Ralf Corsepius [1ac7a00] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Eliminate @osversion. Hard-code 4.7. Thu, 13 Jul 2006 12:50:17 GMT Ralf Corsepius [6933a4c] * contrib/crossrpms/gdb/gdb.add (modified) BR: libtermcap-devel for sparc-rtems. Wed, 05 Jul 2006 15:30:05 GMT Ralf Corsepius [05fac2c] * contrib/crossrpms/gdb/gdb.add (modified) Remove build_infos Tue, 20 Jun 2006 16:40:41 GMT Ralf Corsepius [e8a6236] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Replace %{build_infos} with %build_infos. Fri, 17 Mar 2006 13:13:46 GMT Ralf Corsepius [c3af37c] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-newlib.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Use %sysdir instead of %if %_prefix ==|!= /usr Sat, 11 Mar 2006 09:01:52 GMT Ralf Corsepius [760e8186] * contrib/crossrpms/gdb/build.add (modified) configure --enable-sim Sat, 11 Mar 2006 09:01:09 GMT Ralf Corsepius [aa005877] * contrib/crossrpms/gdb/install.add (modified) Use DESTDIR for gdb >= 6.3. Remove bogus lib*-sim.a Fri, 10 Mar 2006 13:44:30 GMT Ralf Corsepius [13501927] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Use %build_infos Fri, 10 Mar 2006 06:03:39 GMT Ralf Corsepius [59c3dfe] * contrib/crossrpms/gdb/base-gdb.add (added) * contrib/crossrpms/gdb/build.add (added) * contrib/crossrpms/gdb/gdb.add (added) * contrib/crossrpms/gdb/install.add (added) * contrib/crossrpms/gdb/prep.add (added) * contrib/crossrpms/gdb/rpm-install.add (added) * contrib/crossrpms/gdb/target-gdb.add (added) New.
