# # ChangeLog for contrib/crossrpms/gcc/gccnewlib.add in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 12:53:19 Sat, 18 Feb 2006 09:00:56 GMT Ralf Corsepius [82880e5] * contrib/crossrpms/gcc/gccnewlib.add (modified) Remove hard-coded default for _cxx for mingw Sat, 18 Feb 2006 08:03:36 GMT Ralf Corsepius [fd1eb5a] * contrib/crossrpms/gcc/gccnewlib.add (modified) Remove %prep, %build Fri, 17 Feb 2006 20:30:18 GMT Ralf Corsepius [e94d6430] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Cosmetics. Thu, 16 Feb 2006 14:45:01 GMT Ralf Corsepius [2fbb0a0] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %gcc_target Thu, 16 Feb 2006 14:05:36 GMT Ralf Corsepius [4fa25687] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %{rpmgroup} Thu, 16 Feb 2006 13:31:10 GMT Ralf Corsepius [5d985c4] * contrib/crossrpms/gcc/gccnewlib.add (modified) Add %{?dist} to Release. Wed, 15 Feb 2006 15:24:13 GMT Ralf Corsepius [b3a8c23b] * contrib/crossrpms/gcc/base-g77.add (added) * contrib/crossrpms/gcc/base-gcc.add (added) * contrib/crossrpms/gcc/base-gcj.add (added) * contrib/crossrpms/gcc/base-gfortran.add (added) * contrib/crossrpms/gcc/base-gnat.add (added) * contrib/crossrpms/gcc/gccnewlib.add (added) * contrib/crossrpms/gcc/install.add (added) * contrib/crossrpms/gcc/rpm-install.add (added) * contrib/crossrpms/gcc/target-c++.add (added) * contrib/crossrpms/gcc/target-g77.add (added) * contrib/crossrpms/gcc/target-gcc.add (added) * contrib/crossrpms/gcc/target-gcj.add (added) * contrib/crossrpms/gcc/target-gfortran.add (added) * contrib/crossrpms/gcc/target-gnat.add (added) * contrib/crossrpms/gcc/target-libc.add (added) * contrib/crossrpms/gcc/target-objc.add (added) New (From rtems/scripts)
