# # ChangeLog for contrib/crossrpms/gcc/base-gfortran.add in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 11:37:48 Fri, 16 Feb 2007 08:31:33 GMT Ralf Corsepius [64ccc152] * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) Ignore errors on install-info. Sun, 23 Jul 2006 14:17:48 GMT Ralf Corsepius [793bad2] * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) Rename *base packages into gcc*-common Sun, 16 Jul 2006 04:51:16 GMT Ralf Corsepius [1ac7a00] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Eliminate @osversion. Hard-code 4.7. Tue, 20 Jun 2006 16:40:41 GMT Ralf Corsepius [e8a6236] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Replace %{build_infos} with %build_infos. Fri, 17 Mar 2006 13:13:46 GMT Ralf Corsepius [c3af37c] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-newlib.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Use %sysdir instead of %if %_prefix ==|!= /usr Fri, 10 Mar 2006 13:44:30 GMT Ralf Corsepius [13501927] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Use %build_infos Fri, 17 Feb 2006 20:24:52 GMT Ralf Corsepius [85829b5] * contrib/crossrpms/gcc/base-gfortran.add (modified) Cosmetics Thu, 16 Feb 2006 14:05:36 GMT Ralf Corsepius [4fa25687] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %{rpmgroup} Wed, 15 Feb 2006 15:24:13 GMT Ralf Corsepius [b3a8c23b] * contrib/crossrpms/gcc/base-g77.add (added) * contrib/crossrpms/gcc/base-gcc.add (added) * contrib/crossrpms/gcc/base-gcj.add (added) * contrib/crossrpms/gcc/base-gfortran.add (added) * contrib/crossrpms/gcc/base-gnat.add (added) * contrib/crossrpms/gcc/gccnewlib.add (added) * contrib/crossrpms/gcc/install.add (added) * contrib/crossrpms/gcc/rpm-install.add (added) * contrib/crossrpms/gcc/target-c++.add (added) * contrib/crossrpms/gcc/target-g77.add (added) * contrib/crossrpms/gcc/target-gcc.add (added) * contrib/crossrpms/gcc/target-gcj.add (added) * contrib/crossrpms/gcc/target-gfortran.add (added) * contrib/crossrpms/gcc/target-gnat.add (added) * contrib/crossrpms/gcc/target-libc.add (added) * contrib/crossrpms/gcc/target-objc.add (added) New (From rtems/scripts)
