# # ChangeLog for contrib/crossrpms/freebsd7.2 in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 17:37:25 Wed, 06 May 2009 12:23:13 GMT Ralf Corsepius [ac39e0f] * contrib/crossrpms/freebsd6.4/i586/.cvsignore (modified) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-binutils.spec (added) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (added) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-libs.spec (added) * contrib/crossrpms/freebsd7.0/i586/.cvsignore (modified) * contrib/crossrpms/freebsd7.0/i586/i586-pc-freebsd7.0-binutils.spec (added) * contrib/crossrpms/freebsd7.0/i586/i586-pc-freebsd7.0-gcc.spec (added) * contrib/crossrpms/freebsd7.0/i586/i586-pc-freebsd7.0-libs.spec (added) * contrib/crossrpms/freebsd7.1/i586/.cvsignore (modified) * contrib/crossrpms/freebsd7.1/i586/i586-pc-freebsd7.1-libs.spec (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-binutils.spec (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-gcc.spec (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-libs.spec (modified) Update. Wed, 06 May 2009 12:20:49 GMT Ralf Corsepius [4d0f569] * contrib/crossrpms/freebsd6.4/i586/libs.add (modified) * contrib/crossrpms/freebsd7.0/i586/libs.add (modified) * contrib/crossrpms/freebsd7.1/i586/libs.add (modified) * contrib/crossrpms/freebsd7.2/i586/libs.add (modified) Work around to centos-5 rpm bug Tue, 05 May 2009 22:07:39 GMT Ralf Corsepius [45176b8] * contrib/crossrpms/freebsd7.2/i586/.cvsignore (modified) Update. Tue, 05 May 2009 22:06:31 GMT Ralf Corsepius [307cbcb5] * contrib/crossrpms/freebsd7.2/.cvsignore (added) * contrib/crossrpms/freebsd7.2/Makefile.am (added) * contrib/crossrpms/freebsd7.2/binutils.am (added) * contrib/crossrpms/freebsd7.2/gcc-prep.add (added) * contrib/crossrpms/freebsd7.2/gcc.am (added) * contrib/crossrpms/freebsd7.2/i586/.cvsignore (added) * contrib/crossrpms/freebsd7.2/i586/Makefile.am (added) * contrib/crossrpms/freebsd7.2/i586/binutils-sources.add (added) * contrib/crossrpms/freebsd7.2/i586/gcc-sources.add (added) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-binutils.spec (added) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-gcc.spec (added) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-libs.spec (added) * contrib/crossrpms/freebsd7.2/i586/libs.add (added) * contrib/crossrpms/freebsd7.2/i586/target-libs.add (added) New.
