@a73220f
02/27/07 07:32:19 |
Ralf Corsepius |
Upgrade to cygwin-1.5.24-2.
Upgrade to w32api-3.8-1.
4.104.114.84.95
@37304358
02/27/07 07:30:41 |
Ralf Corsepius |
Remove _use_internal_dependency_generator 0.
Remove …
4.104.114.84.95
@67c1bb5e
02/26/07 15:54:49 |
Ralf Corsepius |
Add MKSPEC0.
4.104.114.84.95
@a8149e7
02/26/07 09:55:59 |
Ralf Corsepius |
Use binutils_pkgvers instead of binutils_version in Source0.
4.104.114.84.95
@f7712468
02/26/07 09:26:59 |
Ralf Corsepius |
Add BINUTILS_PKGVERS.
4.104.114.84.95
@99a06927
02/26/07 09:23:23 |
Ralf Corsepius |
Add GCC_PKGVERS.
4.104.114.84.95
@282197c4
01/12/07 08:33:13 |
Ralf Corsepius |
Disable binutils infos.
4.104.114.84.95
@72b911c
01/12/07 08:31:37 |
Ralf Corsepius |
Add BINUTILS_OPTS +=
4.104.114.84.95
@35db46f
01/04/07 13:43:21 |
Ralf Corsepius |
Add BINUTILS_OPTS
4.104.114.84.95
@8eb71ea4
07/25/06 16:11:49 |
Ralf Corsepius |
Remove sed -e /[@]tool_target[@]-newlib/d"
4.104.114.84.95
@eca59879
07/25/06 16:11:21 |
Ralf Corsepius |
Remove blank lines.
4.104.114.84.95
@41e4caf
07/25/06 11:47:04 |
Ralf Corsepius |
Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1
4.104.114.84.95
@aec66f3
07/23/06 05:36:19 |
Ralf Corsepius |
Elminate blank lines.
4.104.114.84.95
@7681446
07/14/06 05:19:05 |
Ralf Corsepius |
include ../gcc.am
4.104.114.84.95
@4e7fb7b
07/14/06 05:18:42 |
Ralf Corsepius |
New. Split out from i686/Makefile.am
4.104.114.84.95
@80bd514f
07/07/06 07:04:53 |
Ralf Corsepius |
Split out binutils.
4.104.114.84.95
@0f9fd94f
07/07/06 05:02:39 |
Ralf Corsepius |
New.
4.104.114.84.95
@c77cc1de
07/05/06 08:42:42 |
Ralf Corsepius |
EXTRA_DIST += ../gcc-prep.add
4.104.114.84.95
@b7e8b3e
07/05/06 07:38:53 |
Ralf Corsepius |
Reflect changes.
4.104.114.84.95
@1f193a8b
07/05/06 07:37:04 |
Ralf Corsepius |
New.
4.104.114.84.95
@478a318
07/05/06 07:32:19 |
Ralf Corsepius |
Remove.
4.104.114.84.95
@f5638da
07/05/06 07:31:07 |
Ralf Corsepius |
New.
4.104.114.84.95
@120c2980
07/05/06 07:29:55 |
Ralf Corsepius |
Moved from ..
4.104.114.84.95
@c34612ce
07/03/06 17:19:32 |
Ralf Corsepius |
Reflect new mkspec.
4.104.114.84.95
@21920c51
07/03/06 14:27:48 |
Ralf Corsepius |
Apply SPECSTRIP
4.104.114.84.95
@677c3d81
06/19/06 07:00:05 |
Ralf Corsepius |
More preps for VPATH builds.
4.104.114.84.95
@cab09c0b
03/15/06 17:41:56 |
Ralf Corsepius |
Add w32api
4.104.114.84.95
@6eba5919
03/07/06 05:26:26 |
Ralf Corsepius |
Distribute local *.add files.
4.104.114.84.95
@5c8f5f66
03/06/06 15:36:59 |
Ralf Corsepius |
Subst gcc_rpmvers for LIB packages.
4.104.114.84.95
@c04a6103
03/06/06 05:55:02 |
Ralf Corsepius |
Remove stray blank in %expand to setup rpmvers.
4.104.114.84.95
@82e0551
03/03/06 16:56:57 |
Ralf Corsepius |
Add gfortran.
Add objc.
4.104.114.84.95
@102c876
02/24/06 15:24:03 |
Ralf Corsepius |
Add gcc-prep.add
4.104.114.84.95
@ef607c60
02/24/06 15:04:25 |
Ralf Corsepius |
New.
4.104.114.84.95
@0d0560a1
02/22/06 13:02:32 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@cb185ee
02/21/06 10:27:25 |
Ralf Corsepius |
Remove @tool_target@-gcc hacks.
4.104.114.84.95
@fccf862
02/21/06 10:21:29 |
Ralf Corsepius |
Delete refs to *-w32api-sys-root packages in *-gcc.spec.in
4.104.114.84.95
@3072c09
02/21/06 10:11:07 |
Ralf Corsepius |
Delete refs to *-newlib packages in *-gcc.spec.in
4.104.114.84.95
@a310f56
02/21/06 08:22:43 |
Ralf Corsepius |
Eliminate osversion
4.104.114.84.95
@1259c55
02/21/06 08:18:29 |
Ralf Corsepius |
Eliminate newlib_version
4.104.114.84.95
@42b1efb8
02/21/06 08:12:54 |
Ralf Corsepius |
Use $(MKSPEC) to generate *-binutils.spec.
4.104.114.84.95
@fe977c7
02/21/06 08:12:10 |
Ralf Corsepius |
Use $(MKSPEC) to generate *-gcc.spec.
4.104.114.84.95
@773ab4f
02/21/06 08:10:46 |
Ralf Corsepius |
Use $(MKSPEC) to generate *-libs.spec.
4.104.114.84.95
@f538086
02/21/06 07:54:50 |
Ralf Corsepius |
Include ../mkspec.am
4.104.114.84.95
@dd3a261
02/20/06 16:37:01 |
Ralf Corsepius |
Backup.
4.104.114.84.95
@b7cd78c1
02/20/06 14:00:55 |
Ralf Corsepius |
Backup.
4.104.114.84.95
@d31a75a
02/20/06 07:50:18 |
Ralf Corsepius |
Apply @rpmprefix@ to *.spec files.
4.104.114.84.95
@3d612dc4
02/19/06 15:17:05 |
Ralf Corsepius |
Use package version as RPMREL.
4.104.114.84.95
@1b8fc3e4
02/18/06 11:11:51 |
Ralf Corsepius |
Add binutils/prep.add, binutils/build.add binutils/install.add
4.104.114.84.95
@6cc81d31
02/18/06 11:10:22 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@384fa937
02/18/06 08:02:54 |
Ralf Corsepius |
Reflect having split out gcc/prep.add and gcc/build.add
4.104.114.84.95
@9d07966e
02/18/06 06:53:57 |
Ralf Corsepius |
Misc. sed magic.
4.104.114.84.95
@149930b1
02/17/06 15:49:16 |
Ralf Corsepius |
Let *.spec.in depend on Makefile.am
4.104.114.84.95
@0d349d29
02/17/06 15:44:28 |
Ralf Corsepius |
Use %{tar} instead of plain tar
4.104.114.84.95
@79a3e1b
02/17/06 15:22:03 |
Ralf Corsepius |
Add libs.add target-libs.add
4.104.114.84.95
@584f2214
02/17/06 15:21:46 |
Ralf Corsepius |
Add *.spec.in
4.104.114.84.95
@7e5cb9c4
02/17/06 15:21:25 |
Ralf Corsepius |
New.
4.104.114.84.95
@e7fd334b
02/17/06 03:10:28 |
Ralf Corsepius |
Propagate $prefix as %_prefix
4.104.114.84.95
@ebc03f5
02/16/06 17:22:17 |
Ralf Corsepius |
Propagate rpmprefix
4.104.114.84.95
@5a4eb6e1
02/16/06 14:46:08 |
Ralf Corsepius |
Eliminate %binutils_target
4.104.114.84.95
@3e404ca
02/16/06 14:38:44 |
Ralf Corsepius |
New.
4.104.114.84.95
@0f60691
02/16/06 14:38:01 |
Ralf Corsepius |
Eliminate deps on %{newlib_version}
4.104.114.84.95
@0510c027
02/16/06 14:16:14 |
Ralf Corsepius |
Unify @PATCH handling.
4.104.114.84.95
@4fa25687
02/16/06 14:05:36 |
Ralf Corsepius |
Eliminate %{rpmgroup}
4.104.114.84.95
@d72421b
02/15/06 15:21:54 |
Ralf Corsepius |
Backup.
4.104.114.84.95
@67023def
02/14/06 14:42:33 |
Ralf Corsepius |
New.
4.104.114.84.95
