# # ChangeLog for contrib/crossrpms/configure.ac in rtems # # Generated by Trac 1.2.1.dev0 # 05/07/24 21:30:44 Wed, 17 Mar 2010 05:08:51 GMT Ralf Corsepius [38f666c] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) rtems-4.11 fork preps. Mon, 30 Nov 2009 10:48:48 GMT Ralf Corsepius [866403c] * contrib/crossrpms/configure.ac (modified) Bump version. Mon, 30 Nov 2009 10:48:22 GMT Ralf Corsepius [7a057b1] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd7.0, freebsd7.1 Mon, 30 Nov 2009 06:04:20 GMT Ralf Corsepius [12f0aeb] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd8.0 Sun, 30 Aug 2009 08:39:50 GMT Ralf Corsepius [039a57a5] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon netbsd4.0.1 Wed, 06 May 2009 12:21:14 GMT Ralf Corsepius [b9f2ae82] * contrib/crossrpms/configure.ac (modified) Bump version. Tue, 05 May 2009 22:08:52 GMT Ralf Corsepius [72f83af4] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd7.2 Sun, 22 Feb 2009 04:54:16 GMT Ralf Corsepius [e1ae901] * contrib/crossrpms/configure.ac (modified) Add lm32. Mon, 26 Jan 2009 07:17:37 GMT Ralf Corsepius [35381baa] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.1/i586/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/gcc.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) BR: exact version of build host tools for Cdn-X builds. Sun, 18 Jan 2009 15:19:13 GMT Ralf Corsepius [3c044f1] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd7.1, freebsd6.4 Sat, 17 Jan 2009 08:34:44 GMT Ralf Corsepius [1bde0e5] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd7.1 Wed, 05 Nov 2008 16:54:08 GMT Ralf Corsepius [d2c15d6] * contrib/crossrpms/configure.ac (modified) Bump version. Fri, 03 Oct 2008 02:54:04 GMT Ralf Corsepius [b2fd3b7] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/rtems4.10/Makefile.am (modified) Add m32r, m32c. Wed, 10 Sep 2008 20:12:00 GMT Ralf Corsepius [64c5bec5] * contrib/crossrpms/configure.ac (modified) Bump RTEMS_API to 4.10. Wed, 10 Sep 2008 20:09:27 GMT Ralf Corsepius [44c2d06d] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Remove freebsd6.2, freebsd6.3, rtems4.9. Wed, 27 Aug 2008 07:42:21 GMT Ralf Corsepius [f9ad4a6] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/rtems4.9/Makefile.am (modified) Remove tic4x (Abandoned). Wed, 27 Aug 2008 07:29:31 GMT Ralf Corsepius [d0cccc9] * contrib/crossrpms/configure.ac (modified) Abandon rtems4.10/tic4x. Thu, 03 Jul 2008 16:36:20 GMT Ralf Corsepius [06a23329] * contrib/crossrpms/configure.ac (modified) Add rtems-4.10. Sat, 26 Apr 2008 05:33:04 GMT Ralf Corsepius [02c93793] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/mkspec.am (modified) Add rtems_api. Thu, 06 Mar 2008 15:34:40 GMT Ralf Corsepius [cd7b673] * contrib/crossrpms/configure.ac (modified) Bump version. Wed, 05 Mar 2008 03:03:47 GMT Ralf Corsepius [dff01852] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd6.1. Wed, 05 Mar 2008 03:01:37 GMT Ralf Corsepius [6b81c78] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add freebsd6.3, freebsd7.0 Wed, 05 Mar 2008 02:38:07 GMT Ralf Corsepius [610c400] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd6.0 Wed, 05 Mar 2008 02:35:52 GMT Ralf Corsepius [01993e1] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Abandon freebsd5.2 Wed, 27 Feb 2008 08:49:33 GMT Ralf Corsepius [ce4d33f] * contrib/crossrpms/configure.ac (modified) Require autoconf-2.61. Bump version. Fri, 28 Sep 2007 07:19:29 GMT Ralf Corsepius [1f60e1c] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) rtems-4.9. Tue, 27 Feb 2007 03:59:07 GMT Ralf Corsepius [161e2739] * contrib/crossrpms/configure.ac (modified) Add freebsd6.2 Fri, 16 Feb 2007 08:39:49 GMT Ralf Corsepius [1d17363] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add HOST_SUBDIRS Sat, 02 Dec 2006 06:06:55 GMT Ralf Corsepius [fcb0cd46] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/bfin/ChangeLog (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/nios2/ChangeLog (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/tools/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/ChangeLog (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/apt-conf/ChangeLog (modified) * contrib/apt-conf/configure.ac (modified) * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/repo-conf/ChangeLog (modified) * contrib/repo-conf/configure.ac (modified) * contrib/rtemsrpms/ChangeLog (modified) * contrib/rtemsrpms/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/ChangeLog (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2006-12-02 Ralf Corsépius * ... Fri, 27 Oct 2006 08:27:56 GMT Ralf Corsepius [136e234] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Remove rtems-4.7 Sun, 22 Oct 2006 04:59:15 GMT Ralf Corsepius [3b10616] * contrib/crossrpms/Makefile.am (modified) * contrib/crossrpms/configure.ac (modified) Add rtems-4.8 Mon, 16 Oct 2006 14:55:56 GMT Ralf Corsepius [a59a751b] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) 2006-10-16 Ralf Corsépius * ... Fri, 11 Aug 2006 21:37:40 GMT Joel Sherrill [6d7e836] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/patches/binutils-2.17-rtems-bfin-20060810.diff (added) * contrib/crossrpms/patches/gcc-4.1.1-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20060810a.diff (added) * contrib/crossrpms/patches/newlib-1.14.0-bfinrtems-20060810a.diff (added) * contrib/crossrpms/rtems4.7/bfin/.cvsignore (added) * contrib/crossrpms/rtems4.7/bfin/Makefile.am (added) * contrib/crossrpms/rtems4.7/bfin/binutils-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gcc-sources.add (added) * contrib/crossrpms/rtems4.7/bfin/gdb-sources.add (added) 2006-08-11 Joel Sherrill * ... Thu, 03 Aug 2006 04:29:22 GMT Ralf Corsepius [6bdebc3a] * contrib/crossrpms/configure.ac (modified) Bump version. Wed, 02 Aug 2006 03:39:00 GMT Ralf Corsepius [300dce7] * contrib/crossrpms/configure.ac (modified) Bump version. Mon, 24 Jul 2006 09:01:22 GMT Ralf Corsepius [c45ec73] * contrib/crossrpms/configure.ac (modified) Bump version. Add AC_CONFIG_FILES([autotools/Makefile]) Sun, 23 Jul 2006 14:24:25 GMT Ralf Corsepius [a61e8325] * contrib/crossrpms/configure.ac (modified) Bump version Thu, 20 Jul 2006 05:17:36 GMT Ralf Corsepius [c29d0a21] * contrib/crossrpms/configure.ac (modified) Remove $build_infos. Add SPECSTRIP_OPTS. Tue, 18 Jul 2006 07:25:19 GMT Ralf Corsepius [22f187d0] * contrib/crossrpms/configure.ac (modified) Fix setting up targets for solaris* Fri, 14 Jul 2006 06:54:23 GMT Ralf Corsepius [26bdc875] * contrib/crossrpms/configure.ac (modified) Use //Makefile.am in check for all/rtems. Thu, 13 Jul 2006 16:48:53 GMT Joel Sherrill [460d7e7] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/patches/gdb-6.5-rtems-20060713.diff (added) * contrib/crossrpms/rtems4.7/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.7/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.7/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.7/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.7/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.7/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.7/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/mipstx39/.cvsignore (added) * contrib/crossrpms/rtems4.7/mipstx39/Makefile.am (added) * contrib/crossrpms/rtems4.7/mipstx39/gdb-sources.add (added) * contrib/crossrpms/rtems4.7/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.7/sparc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.7/tic4x/gdb-sources.add (modified) 2006-07-13 Joel Sherrill * ... Fri, 07 Jul 2006 03:34:53 GMT Ralf Corsepius [748c2019] * contrib/crossrpms/configure.ac (modified) Bump version. Wed, 05 Jul 2006 09:11:23 GMT Ralf Corsepius [749361d] * contrib/crossrpms/configure.ac (modified) Bump version. Wed, 05 Jul 2006 09:10:02 GMT Ralf Corsepius [f82ddbe4] * contrib/crossrpms/configure.ac (modified) Eliminate target_os Wed, 05 Jul 2006 09:08:05 GMT Ralf Corsepius [d90e3387] * contrib/crossrpms/configure.ac (modified) Remove AC_CANONICAL_TARGET. Wed, 05 Jul 2006 09:06:24 GMT Ralf Corsepius [15fcf913] * contrib/crossrpms/configure.ac (modified) Add --enable-targets. Wed, 05 Jul 2006 08:55:51 GMT Ralf Corsepius [4fea6f06] * contrib/crossrpms/configure.ac (modified) Add new AC_CONFIG_FILES. Sun, 25 Jun 2006 04:13:33 GMT Ralf Corsepius [81e7cd80] * contrib/crossrpms/configure.ac (modified) Fix typo in previous change Sun, 25 Jun 2006 04:08:59 GMT Ralf Corsepius [ad8e65e] * contrib/crossrpms/configure.ac (modified) Bump version Tue, 20 Jun 2006 09:51:02 GMT Ralf Corsepius [c4d4e15] * contrib/crossrpms/configure.ac (modified) Add freebsd6.1 Sat, 17 Jun 2006 08:42:09 GMT Ralf Corsepius [90deee12] * contrib/crossrpms/configure.ac (modified) Bump version. Add freebsd6.1 Thu, 23 Mar 2006 13:06:28 GMT Ralf Corsepius [e39da00d] * contrib/crossrpms/configure.ac (modified) Add defaults for non-standard $prefix. Fri, 17 Mar 2006 13:14:52 GMT Ralf Corsepius [900ae6fd] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/mkspec.am (modified) Apply @sysdirpattern@ Thu, 16 Mar 2006 06:45:40 GMT Ralf Corsepius [bef3adb] * contrib/crossrpms/configure.ac (modified) Remove message erroniously checked in in previous change Thu, 16 Mar 2006 06:44:27 GMT Ralf Corsepius [77cd26d] * contrib/crossrpms/configure.ac (modified) Set defaults for ac_default_prefix Wed, 15 Mar 2006 17:42:31 GMT Ralf Corsepius [b224280] * contrib/crossrpms/configure.ac (modified) Increment version Fri, 10 Mar 2006 13:45:05 GMT Ralf Corsepius [1a64d3e] * contrib/crossrpms/configure.ac (modified) Increment version Fri, 10 Mar 2006 06:24:55 GMT Ralf Corsepius [4d3e4476] * contrib/crossrpms/configure.ac (modified) Rework rpmprefix logic. Add --enable-infos/build_infos. Tue, 07 Mar 2006 05:28:35 GMT Ralf Corsepius [9087b7c] * contrib/crossrpms/configure.ac (modified) Fix main package name. Update version. Sat, 04 Mar 2006 06:04:34 GMT Ralf Corsepius [503be14] * contrib/crossrpms/configure.ac (modified) Add osversion hack Fri, 24 Feb 2006 15:20:39 GMT Ralf Corsepius [255d476] * contrib/crossrpms/configure.ac (modified) Remove no-define foreign from AM_INIT_AUTOMAKE. Tue, 21 Feb 2006 10:23:26 GMT Ralf Corsepius [0f3d1bb] * contrib/crossrpms/configure.ac (modified) Ignore unsupported targets. Sun, 19 Feb 2006 05:06:06 GMT Ralf Corsepius [0ce942a] * contrib/crossrpms/configure.ac (modified) Add AC_CANONICAL_TARGET. Apply target magic to setup rtems. Fri, 17 Feb 2006 05:37:33 GMT Ralf Corsepius [856e9043] * contrib/crossrpms/configure.ac (modified) Remove unnecessary quotes. Fri, 17 Feb 2006 03:11:28 GMT Ralf Corsepius [0707f583] * contrib/crossrpms/configure.ac (modified) Couple rpmprefix to prefix Thu, 16 Feb 2006 14:33:16 GMT Ralf Corsepius [f05d8c9] * contrib/crossrpms/configure.ac (modified) Build host specs only if --host was given Wed, 15 Feb 2006 15:17:26 GMT Ralf Corsepius [ee8a1ec] * contrib/crossrpms/acinclude.m4 (added) * contrib/crossrpms/bootstrap (added) * contrib/crossrpms/configure.ac (added) New.
