# # ChangeLog for contrib/crossrpms/common in rtems # # Generated by Trac 1.2.1.dev0 # 04/18/24 02:22:26 Fri, 28 Mar 2008 05:45:41 GMT Ralf Corsepius [0b77003] * contrib/crossrpms/common/common.add (modified) Add _host_rpmprefix. Thu, 20 Mar 2008 08:33:07 GMT Ralf Corsepius [1187fce8] * contrib/crossrpms/common/common.add (modified) Add cygwin hacks from CVS-HEAD. Wed, 10 Jan 2007 06:31:57 GMT Ralf Corsepius [d82b3f1b] * contrib/crossrpms/common/common.add (modified) Update bugfix address Wed, 05 Jul 2006 15:29:03 GMT Ralf Corsepius [65e2634] * contrib/crossrpms/common/common.add (modified) Move %define _prefix inside of %if/%endif Fri, 17 Feb 2006 03:10:28 GMT Ralf Corsepius [e7fd334b] * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Propagate $prefix as %_prefix Thu, 16 Feb 2006 14:05:36 GMT Ralf Corsepius [4fa25687] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %{rpmgroup} Thu, 16 Feb 2006 07:59:47 GMT Ralf Corsepius [4c40577] * contrib/crossrpms/common/common.add (added) New. Tue, 14 Feb 2006 15:27:52 GMT Ralf Corsepius [2b6eb18] * contrib/crossrpms/binutils/base-binutils.add (added) * contrib/crossrpms/binutils/binutils.add (added) * contrib/crossrpms/binutils/rpm-install.add (added) * contrib/crossrpms/binutils/target-binutils.add (added) * contrib/crossrpms/common/clean.add (added) * contrib/crossrpms/freebsd6.0/.cvsignore (added) * contrib/crossrpms/freebsd6.0/Makefile.am (added) * contrib/crossrpms/freebsd6.0/binutils-sources.add (added) New.
