# # ChangeLog for contrib/crossrpms/binutils in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 03:32:23 Thu, 04 Feb 2010 16:35:56 GMT Ralf Corsepius [84da742] * contrib/crossrpms/binutils/build.add (modified) Reflect cygwin finally having upgraded binutils. Sat, 29 Aug 2009 03:33:14 GMT Ralf Corsepius [87e5173] * contrib/crossrpms/binutils/target-binutils.add (modified) Add %{_datarootdir}. Sat, 29 Aug 2009 03:33:02 GMT Ralf Corsepius [4e32450] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon binutils < 2.17. Fri, 28 Aug 2009 11:54:55 GMT Ralf Corsepius [8f9def4b] * contrib/crossrpms/binutils/base-binutils.add (modified) Mark binutils-common as noarch sub-package. Tue, 28 Oct 2008 22:09:59 GMT Ralf Corsepius [01ed848] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) Add %sysdir %{_prefix} to cater rpm5. Sun, 27 Jul 2008 06:25:12 GMT Ralf Corsepius [476c9f4] * contrib/crossrpms/binutils/install.add (modified) Don't install windmc.1 if windmc is not available. Mon, 31 Mar 2008 04:38:55 GMT Ralf Corsepius [ad476d6e] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Unconditionally BR: %{_host_rpmprefix}gcc. Wed, 26 Mar 2008 17:59:34 GMT Ralf Corsepius [db6bd68] * contrib/crossrpms/binutils/target-binutils.add (modified) Remove stray blank line. Tue, 18 Mar 2008 06:12:40 GMT Ralf Corsepius [5589eac0] * contrib/crossrpms/binutils/build.add (modified) Add %{_bindir} to PATH to cater CdnX-builds. Set CFLAGS_FOR_BUILD. Tue, 18 Mar 2008 06:11:17 GMT Ralf Corsepius [7940f96] * contrib/crossrpms/binutils/install.add (modified) Add %{_bindir} to PATH to catter CdnX-builds. Tue, 18 Mar 2008 06:09:42 GMT Ralf Corsepius [1fb6a01] * contrib/crossrpms/binutils/binutils.add (modified) BR: @rpmprefix@%{_host}-gcc for CdnX-builds. Mon, 25 Feb 2008 16:05:02 GMT Ralf Corsepius [cf04e953] * contrib/crossrpms/binutils/install.add (modified) Use make DESTDIR= ... install. Mon, 17 Dec 2007 06:11:48 GMT Ralf Corsepius [dcb8530] * contrib/crossrpms/binutils/build.add (modified) Add _smp_mflags. Mon, 17 Dec 2007 06:11:22 GMT Ralf Corsepius [bd10488] * contrib/crossrpms/binutils/binutils.add (modified) BR: texinfo for binutils > 2.18 Wed, 29 Aug 2007 02:54:39 GMT Ralf Corsepius [a380e47e] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon *-base-binutils packages. Wed, 29 Aug 2007 02:51:40 GMT Ralf Corsepius [9ce762b] * contrib/crossrpms/binutils/base-binutils.add (modified) Abandon binutils < 2.13. Tue, 24 Jul 2007 14:26:46 GMT Ralf Corsepius [e0d85b74] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into BINUTILS_RPMREL. Tue, 24 Jul 2007 03:47:09 GMT Ralf Corsepius [ee4740b] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) Add cygwin hacks. Fri, 25 May 2007 08:39:01 GMT Ralf Corsepius [d183ac2a] * contrib/crossrpms/binutils/base-binutils.add (modified) Add gprof.info handling. Thu, 01 Mar 2007 06:20:02 GMT Ralf Corsepius [1f88fa0] * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) Add support for exec_prefix. Mon, 26 Feb 2007 09:35:04 GMT Ralf Corsepius [8d182ca] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/prep.add (modified) Add BINUTILS_PKGVERS. Mon, 19 Feb 2007 06:01:11 GMT Ralf Corsepius [df22adf] * contrib/crossrpms/binutils/base-binutils.add (modified) Cosmetics Sat, 17 Feb 2007 06:48:04 GMT Ralf Corsepius [1293de07] * contrib/crossrpms/binutils/base-binutils.add (modified) Add || : to install-info. Sun, 23 Jul 2006 14:22:37 GMT Ralf Corsepius [1528803c] * contrib/crossrpms/binutils/base-binutils.add (modified) Let rpm Obsolete < %{binutils_version}-%{release} Fri, 21 Jul 2006 15:55:08 GMT Ralf Corsepius [65f75598] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) Rename rtems4.7-base-binutils into binutils-common Mon, 17 Jul 2006 15:23:04 GMT Ralf Corsepius [c10a31b] * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Require: base packages iff %build_infos Mon, 17 Jul 2006 14:30:28 GMT Ralf Corsepius [d2b94e76] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) Cosmetics. Sun, 16 Jul 2006 06:05:37 GMT Ralf Corsepius [c20efa7] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) Cosmetics. Sun, 16 Jul 2006 04:51:16 GMT Ralf Corsepius [1ac7a00] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Eliminate @osversion. Hard-code 4.7. Tue, 11 Jul 2006 03:29:26 GMT Ralf Corsepius [46a9d63] * contrib/crossrpms/binutils/binutils.add (modified) Remove %define build_infos. Tue, 20 Jun 2006 16:40:41 GMT Ralf Corsepius [e8a6236] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Replace %{build_infos} with %build_infos. Fri, 17 Mar 2006 13:13:46 GMT Ralf Corsepius [c3af37c] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-newlib.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Use %sysdir instead of %if %_prefix ==|!= /usr Thu, 16 Mar 2006 06:47:34 GMT Ralf Corsepius [f906d86] * contrib/crossrpms/binutils/binutils.add (modified) Require base-binutils if building infos. Fri, 10 Mar 2006 13:44:30 GMT Ralf Corsepius [13501927] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Use %build_infos Mon, 06 Mar 2006 05:55:02 GMT Ralf Corsepius [c04a6103] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/libs.add (modified) * contrib/crossrpms/freebsd5.2/libs.add (modified) * contrib/crossrpms/freebsd6.0/libs.add (modified) * contrib/crossrpms/mingw32/libs.add (modified) * contrib/crossrpms/mingw32/w32api.add (modified) * contrib/crossrpms/solaris2.7/libs.add (modified) Remove stray blank in %expand to setup rpmvers. Tue, 28 Feb 2006 23:09:54 GMT Ralf Corsepius [87f443cc] * contrib/crossrpms/binutils/build.add (modified) Add --with-sysroot (Required by GCC-4.1.0) Sat, 25 Feb 2006 04:52:44 GMT Ralf Corsepius [2f9c5897] * contrib/crossrpms/binutils/rpm-install.add (modified) * contrib/crossrpms/gcc/rpm-install.add (modified) Fix stupid typo. Wed, 22 Feb 2006 07:45:45 GMT Ralf Corsepius [7afdf54c] * contrib/crossrpms/binutils/rpm-install.add (modified) * contrib/crossrpms/gcc/rpm-install.add (modified) Add ",g" in sed call to propagate _prefix to brp-compress. Wed, 22 Feb 2006 06:35:50 GMT Ralf Corsepius [c2dade8] * contrib/crossrpms/binutils/rpm-install.add (modified) * contrib/crossrpms/gcc/rpm-install.add (modified) Correct /-handling Mon, 20 Feb 2006 16:27:09 GMT Ralf Corsepius [f058946] * contrib/crossrpms/binutils/install.add (modified) Unconditionally remove configure.info, because cygwin still ships it:( Sat, 18 Feb 2006 11:07:18 GMT Ralf Corsepius [00a9702b] * contrib/crossrpms/binutils/binutils.add (modified) Split out prep, build, install Sat, 18 Feb 2006 11:06:56 GMT Ralf Corsepius [14653c86] * contrib/crossrpms/binutils/build.add (added) * contrib/crossrpms/binutils/install.add (added) * contrib/crossrpms/binutils/prep.add (added) New. Thu, 16 Feb 2006 14:46:08 GMT Ralf Corsepius [5a4eb6e1] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %binutils_target Thu, 16 Feb 2006 14:05:36 GMT Ralf Corsepius [4fa25687] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %{rpmgroup} Wed, 15 Feb 2006 15:04:03 GMT Ralf Corsepius [c0b13f0] * contrib/crossrpms/.cvsignore (added) * contrib/crossrpms/binutils/.cvsignore (added) * contrib/crossrpms/freebsd5.2/binutils-sources.add (modified) * contrib/crossrpms/freebsd5.2/gcc-sources.add (added) * contrib/crossrpms/freebsd6.0/binutils-sources.add (modified) * contrib/crossrpms/freebsd6.0/gcc-sources.add (added) * contrib/crossrpms/mingw32/libs.add (added) * contrib/crossrpms/mingw32/target-libs.add (added) * contrib/crossrpms/mingw32/target-w32api.add (added) * contrib/crossrpms/mingw32/w32api.add (added) * contrib/crossrpms/rtems/.cvsignore (added) * contrib/crossrpms/rtems/Makefile.am (added) * contrib/crossrpms/rtems/binutils-sources.add (added) * contrib/crossrpms/rtems/gcc-sources.add (added) * contrib/crossrpms/solaris2.7/Makefile.am (modified) * contrib/crossrpms/solaris2.7/binutils-sources.add (modified) * contrib/crossrpms/solaris2.7/gcc-sources.add (added) New. Tue, 14 Feb 2006 15:27:52 GMT Ralf Corsepius [2b6eb18] * contrib/crossrpms/binutils/base-binutils.add (added) * contrib/crossrpms/binutils/binutils.add (added) * contrib/crossrpms/binutils/rpm-install.add (added) * contrib/crossrpms/binutils/target-binutils.add (added) * contrib/crossrpms/common/clean.add (added) * contrib/crossrpms/freebsd6.0/.cvsignore (added) * contrib/crossrpms/freebsd6.0/Makefile.am (added) * contrib/crossrpms/freebsd6.0/binutils-sources.add (added) New.
