# # ChangeLog for contrib/crossrpms/binutils/binutils.add in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 15:09:48 Sat, 18 Feb 2006 11:07:18 GMT Ralf Corsepius [00a9702b] * contrib/crossrpms/binutils/binutils.add (modified) Split out prep, build, install Thu, 16 Feb 2006 14:46:08 GMT Ralf Corsepius [5a4eb6e1] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %binutils_target Thu, 16 Feb 2006 14:05:36 GMT Ralf Corsepius [4fa25687] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/common/common.add (modified) * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-libc.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Eliminate %{rpmgroup} Tue, 14 Feb 2006 15:27:52 GMT Ralf Corsepius [2b6eb18] * contrib/crossrpms/binutils/base-binutils.add (added) * contrib/crossrpms/binutils/binutils.add (added) * contrib/crossrpms/binutils/rpm-install.add (added) * contrib/crossrpms/binutils/target-binutils.add (added) * contrib/crossrpms/common/clean.add (added) * contrib/crossrpms/freebsd6.0/.cvsignore (added) * contrib/crossrpms/freebsd6.0/Makefile.am (added) * contrib/crossrpms/freebsd6.0/binutils-sources.add (added) New.
