# # ChangeLog for contrib/crossrpms/autotools in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 00:05:11 Wed, 09 Dec 2009 09:29:59 GMT Ralf Corsepius [7b21633] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) Upgrade to automake-1.11.1 Mon, 23 Nov 2009 03:33:52 GMT Ralf Corsepius [64101ef] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) autoconf-2.65. Mon, 27 Jul 2009 11:55:52 GMT Ralf Corsepius [e7667a8] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) Upgrade to autoconf-2.64. Sun, 26 Jul 2009 05:00:19 GMT Ralf Corsepius [862e1ec] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) Regenerate. Sun, 26 Jul 2009 04:59:59 GMT Ralf Corsepius [bff8cf4b] * contrib/crossrpms/autotools/Makefile.am (modified) Bump AUTOCONF_RPMREL. Sun, 26 Jul 2009 04:56:06 GMT Ralf Corsepius [051e1b2] * contrib/crossrpms/autotools/Makefile.am (modified) Bump AUTOMAKE_RPMREL. Sun, 26 Jul 2009 04:55:43 GMT Ralf Corsepius [bcbfc091] * contrib/crossrpms/autotools/automake.add (modified) Require help2man for automake < 1.11 Mon, 13 Jul 2009 14:27:01 GMT Ralf Corsepius [f76ddaa] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) Regenerate. Mon, 13 Jul 2009 14:26:49 GMT Ralf Corsepius [700acb98] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/autoconf.am (modified) Move %{?dist} into autoconf.am Mon, 13 Jul 2009 14:23:48 GMT Ralf Corsepius [b08d3f3c] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/automake.add (modified) Remove Obsolete/Provides. Mon, 13 Jul 2009 14:21:39 GMT Ralf Corsepius [186049a] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) Regenerate. Mon, 13 Jul 2009 14:21:05 GMT Ralf Corsepius [afdc9d7] * contrib/crossrpms/autotools/Makefile.am (modified) Bump AUTOCONF_RPMREL. Mon, 13 Jul 2009 14:20:36 GMT Ralf Corsepius [ae1862c] * contrib/crossrpms/autotools/autoconf-sources.add (added) * contrib/crossrpms/autotools/autoconf.am (modified) Add autoconf-sources.add. Mon, 13 Jul 2009 14:19:43 GMT Ralf Corsepius [350178d0] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) Acknowledge autoconf-sources.add Mon, 18 May 2009 16:51:52 GMT Ralf Corsepius [be1d136] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) automake-1.11. Mon, 18 May 2009 07:55:51 GMT Ralf Corsepius [4890bae] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/automake-sources.add (modified) Automake-1.11. Sun, 22 Feb 2009 04:22:55 GMT Ralf Corsepius [a2b76fdf] * contrib/crossrpms/autotools/automake-sources.add (added) * contrib/crossrpms/patches/automake-1.10.2-rtems4.10-20090222.diff (added) New. Sun, 22 Feb 2009 04:22:17 GMT Ralf Corsepius [2276acc0] * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) Regenerate. Sun, 22 Feb 2009 04:21:18 GMT Ralf Corsepius [d129b56] * contrib/crossrpms/autotools/Makefile.am (modified) Bump version. Sun, 22 Feb 2009 04:20:44 GMT Ralf Corsepius [bef54816] * contrib/crossrpms/autotools/automake.add (modified) Add @SOURCES@, PATCH0. Sun, 22 Feb 2009 04:19:52 GMT Ralf Corsepius [024eb28] * contrib/crossrpms/autotools/automake.am (modified) Add automake-sources.add. Mon, 26 Jan 2009 07:17:37 GMT Ralf Corsepius [35381baa] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.1/i586/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/gcc.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) BR: exact version of build host tools for Cdn-X builds. Thu, 27 Nov 2008 16:08:09 GMT Ralf Corsepius [9d1af30] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) Update to automake-1.10.2 Thu, 16 Oct 2008 02:31:01 GMT Ralf Corsepius [6440a9c9] * contrib/crossrpms/autotools/rtems-4.10-autoconf.spec (added) * contrib/crossrpms/autotools/rtems-4.10-automake.spec (added) New. Thu, 16 Oct 2008 02:30:20 GMT Ralf Corsepius [04c9086c] * contrib/crossrpms/autotools/Makefile.am (modified) Bump RPMREL. Wed, 10 Sep 2008 20:13:03 GMT Ralf Corsepius [93e1140] * contrib/crossrpms/autotools/Makefile.am (modified) Upgrade autoconf to 2.63. Fri, 09 May 2008 12:43:57 GMT Ralf Corsepius [dc49fb9] * contrib/crossrpms/autotools/autoconf.add (modified) BuildRequire: m4 > 1.4.5 Sun, 27 Apr 2008 05:27:02 GMT Ralf Corsepius [1ef4b6c] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/automake.add (modified) Move %{?dist} to Makefile.am. Sun, 27 Apr 2008 05:26:37 GMT Ralf Corsepius [42f9ca8b] * contrib/crossrpms/autotools/autoconf.add (modified) Move %{?dist} to Makefile.am. BR: m4 > 1.4.5 for autoconf >= 2.62. Mon, 21 Apr 2008 06:01:23 GMT Ralf Corsepius [84f140c] * contrib/crossrpms/autotools/Makefile.am (modified) autoconf-2.62. Mon, 21 Apr 2008 06:01:07 GMT Ralf Corsepius [2e4550cf] * contrib/crossrpms/autotools/autoconf.add (modified) Use AUTOCONF_VERS. Mon, 21 Apr 2008 06:00:44 GMT Ralf Corsepius [2dc7132] * contrib/crossrpms/autotools/autoconf.am (modified) Add AUTOCONF_VERS. Tue, 22 Jan 2008 08:56:18 GMT Ralf Corsepius [c539ced1] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/automake.am (modified) Preps for automake-1.10.1 Tue, 22 Jan 2008 08:56:01 GMT Ralf Corsepius [980102a] * contrib/crossrpms/autotools/Makefile.am (modified) automake-1.10.1 Wed, 14 Feb 2007 17:21:43 GMT Ralf Corsepius [072cbd3] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOCONF_RPMREL = 5 Wed, 14 Feb 2007 17:21:30 GMT Ralf Corsepius [0852a4f7] * contrib/crossrpms/autotools/target-autoconf.add (modified) Add ||: to install-info Wed, 14 Feb 2007 16:47:57 GMT Ralf Corsepius [9c58665b] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOCONF_RPMREL = 4 Wed, 14 Feb 2007 16:46:18 GMT Ralf Corsepius [843ee5d] * contrib/crossrpms/autotools/autoconf.add (modified) Add req/prov filters Wed, 14 Feb 2007 15:51:02 GMT Ralf Corsepius [43858659] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOMAKE_RPMREL = 5 Wed, 14 Feb 2007 15:50:37 GMT Ralf Corsepius [2388d57] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/target-automake.add (modified) Make install-infos safe against --exclude-docs. Filter bogus ... Wed, 10 Jan 2007 08:02:41 GMT Ralf Corsepius [cb08aeb] * contrib/crossrpms/autotools/Makefile.am (modified) Bump releases. Wed, 10 Jan 2007 08:02:07 GMT Ralf Corsepius [1b5a5610] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/automake.am (modified) Rename automake-rtems into automake. Rename autoconf-rtems into autoconf. Wed, 10 Jan 2007 08:02:01 GMT Ralf Corsepius [727e8469] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/autoconf.am (modified) Rename autoconf-rtems into autoconf. Sun, 19 Nov 2006 03:38:30 GMT Ralf Corsepius [bd8f4d8] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/autoconf.add (modified) 2006-11-19 Ralf Corsépius * ... Thu, 19 Oct 2006 13:30:56 GMT Ralf Corsepius [c991316e] * contrib/crossrpms/autotools/automake.add (modified) Cleanup. Mon, 16 Oct 2006 11:14:07 GMT Ralf Corsepius [e337b49] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/automake.add (modified) 2006-10-16 Ralf Corsépius * ... Wed, 16 Aug 2006 07:54:10 GMT Ralf Corsepius [67eede5] * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.am (modified) Pickup common.add from $(top_srcdir). Thu, 03 Aug 2006 04:28:43 GMT Ralf Corsepius [c1a25af9] * contrib/crossrpms/autotools/Makefile.am (modified) Use hard-coded %release. Wed, 02 Aug 2006 03:37:34 GMT Ralf Corsepius [d9e9a5a] * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.am (modified) Use further shared spec-fragments. Wed, 02 Aug 2006 03:36:22 GMT Ralf Corsepius [6c873da] * contrib/crossrpms/autotools/autoconf.add (modified) Split out target-autoconf.add Wed, 02 Aug 2006 03:36:11 GMT Ralf Corsepius [a5b38ea] * contrib/crossrpms/autotools/automake.add (modified) Split out target-automake.add Wed, 02 Aug 2006 03:35:10 GMT Ralf Corsepius [e5f924d] * contrib/crossrpms/autotools/target-autoconf.add (added) * contrib/crossrpms/autotools/target-automake.add (added) New. Tue, 25 Jul 2006 13:15:18 GMT Ralf Corsepius [f391f6a] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/automake.add (modified) Fix rpmgroup. Cosmetics. Mon, 24 Jul 2006 08:51:15 GMT Ralf Corsepius [a26364de] * contrib/crossrpms/autotools/.cvsignore (added) * contrib/crossrpms/autotools/Makefile.am (added) * contrib/crossrpms/autotools/autoconf.add (added) * contrib/crossrpms/autotools/autoconf.am (added) * contrib/crossrpms/autotools/automake.add (added) * contrib/crossrpms/autotools/automake.am (added) New.
