# # ChangeLog for contrib/crossrpms/autotools in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 06:10:09 Wed, 14 Feb 2007 17:21:43 GMT Ralf Corsepius [072cbd3] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOCONF_RPMREL = 5 Wed, 14 Feb 2007 17:21:30 GMT Ralf Corsepius [0852a4f7] * contrib/crossrpms/autotools/target-autoconf.add (modified) Add ||: to install-info Wed, 14 Feb 2007 16:47:57 GMT Ralf Corsepius [9c58665b] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOCONF_RPMREL = 4 Wed, 14 Feb 2007 16:46:18 GMT Ralf Corsepius [843ee5d] * contrib/crossrpms/autotools/autoconf.add (modified) Add req/prov filters Wed, 14 Feb 2007 15:51:02 GMT Ralf Corsepius [43858659] * contrib/crossrpms/autotools/Makefile.am (modified) AUTOMAKE_RPMREL = 5 Wed, 14 Feb 2007 15:50:37 GMT Ralf Corsepius [2388d57] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/target-automake.add (modified) Make install-infos safe against --exclude-docs. Filter bogus ... Wed, 10 Jan 2007 08:02:41 GMT Ralf Corsepius [cb08aeb] * contrib/crossrpms/autotools/Makefile.am (modified) Bump releases. Wed, 10 Jan 2007 08:02:07 GMT Ralf Corsepius [1b5a5610] * contrib/crossrpms/autotools/automake.add (modified) * contrib/crossrpms/autotools/automake.am (modified) Rename automake-rtems into automake. Rename autoconf-rtems into autoconf. Wed, 10 Jan 2007 08:02:01 GMT Ralf Corsepius [727e8469] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/autoconf.am (modified) Rename autoconf-rtems into autoconf. Sun, 19 Nov 2006 03:38:30 GMT Ralf Corsepius [bd8f4d8] * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/autoconf.add (modified) 2006-11-19 Ralf Corsépius * ... Thu, 19 Oct 2006 13:30:56 GMT Ralf Corsepius [c991316e] * contrib/crossrpms/autotools/automake.add (modified) Cleanup. Mon, 16 Oct 2006 11:14:07 GMT Ralf Corsepius [e337b49] * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/autotools/Makefile.am (modified) * contrib/crossrpms/autotools/automake.add (modified) 2006-10-16 Ralf Corsépius * ... Wed, 16 Aug 2006 07:54:10 GMT Ralf Corsepius [67eede5] * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.am (modified) Pickup common.add from $(top_srcdir). Thu, 03 Aug 2006 04:28:43 GMT Ralf Corsepius [c1a25af9] * contrib/crossrpms/autotools/Makefile.am (modified) Use hard-coded %release. Wed, 02 Aug 2006 03:37:34 GMT Ralf Corsepius [d9e9a5a] * contrib/crossrpms/autotools/autoconf.am (modified) * contrib/crossrpms/autotools/automake.am (modified) Use further shared spec-fragments. Wed, 02 Aug 2006 03:36:22 GMT Ralf Corsepius [6c873da] * contrib/crossrpms/autotools/autoconf.add (modified) Split out target-autoconf.add Wed, 02 Aug 2006 03:36:11 GMT Ralf Corsepius [a5b38ea] * contrib/crossrpms/autotools/automake.add (modified) Split out target-automake.add Wed, 02 Aug 2006 03:35:10 GMT Ralf Corsepius [e5f924d] * contrib/crossrpms/autotools/target-autoconf.add (added) * contrib/crossrpms/autotools/target-automake.add (added) New. Tue, 25 Jul 2006 13:15:18 GMT Ralf Corsepius [f391f6a] * contrib/crossrpms/autotools/autoconf.add (modified) * contrib/crossrpms/autotools/automake.add (modified) Fix rpmgroup. Cosmetics. Mon, 24 Jul 2006 08:51:15 GMT Ralf Corsepius [a26364de] * contrib/crossrpms/autotools/.cvsignore (added) * contrib/crossrpms/autotools/Makefile.am (added) * contrib/crossrpms/autotools/autoconf.add (added) * contrib/crossrpms/autotools/autoconf.am (added) * contrib/crossrpms/autotools/automake.add (added) * contrib/crossrpms/autotools/automake.am (added) New.
