# # ChangeLog for configure.in in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 19:56:43 Thu, 13 Sep 2001 13:14:30 GMT Joel Sherrill [e712997] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-gcc28.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-libcdir.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (modified) * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.in (modified) 2001-07-19 Ralf Corsepius * ... Thu, 01 Mar 2001 20:46:21 GMT Joel Sherrill [48ad47cc] * ChangeLog (modified) * Makefile.am (modified) * README.cdn-X (added) * c/src/lib/libbsp/arm/armulator/bsp_specs (modified) * config.guess (modified) * config.sub (modified) * configure.in (modified) * make/custom/arm_bare_bsp.cfg (modified) * scripts/setup.def (modified) * tools/Makefile.am (modified) 2001-02-22 Ralf Corsepius * ... Fri, 02 Feb 2001 18:30:42 GMT Joel Sherrill [21d7de3a] * ChangeLog (modified) * aclocal/bsp-arg-enable.m4 (modified) * aclocal/check-bsps.m4 (modified) * configure.in (modified) 2001-02-02 Ralf Corsepius * ... Thu, 09 Nov 2000 17:01:25 GMT Joel Sherrill [5913d94] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * configure.in (modified) 2000-11-09 Ralf Corsepius * ... Tue, 31 Oct 2000 21:20:00 GMT Joel Sherrill [3174a7ed] * ChangeLog (modified) * Makefile.am (modified) * automake/compile.am (modified) * automake/lib.am (modified) * configure.in (modified) * macros/enable-rtemsbsp.m4 (modified) * macros/i386-gas-code16.m4 (modified) * macros/multilib.m4 (modified) * macros/prog-cc.m4 (modified) * macros/prog-cxx.m4 (modified) * macros/project-root.m4 (modified) * macros/rtems-top.m4 (modified) * macros/target.m4 (modified) * macros/tool-prefix.m4 (deleted) 2000-10-30 Ralf Corsepius * ... Wed, 12 Jul 2000 19:23:14 GMT Joel Sherrill [39607984] * aclocal/rtems-debug.m4 (added) * c/src/exec/configure.in (modified) * configure.in (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius [df49c60] * Makefile.am (modified) * VERSION (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/target.m4 (modified) * automake/host.am (added) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/libcsupport/src/termiosreserveresources.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/memory.h (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/if_loop.c (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/sys/un.h (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/README_RTEMS (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpc/auth.h (modified) * c/src/exec/librpc/include/rpc/auth_des.h (modified) * c/src/exec/librpc/include/rpc/auth_unix.h (modified) * c/src/exec/librpc/include/rpc/clnt.h (modified) * c/src/exec/librpc/include/rpc/des.h (modified) * c/src/exec/librpc/include/rpc/des_crypt.h (modified) * c/src/exec/librpc/include/rpc/pmap_clnt.h (modified) * c/src/exec/librpc/include/rpc/pmap_prot.h (modified) * c/src/exec/librpc/include/rpc/pmap_rmt.h (modified) * c/src/exec/librpc/include/rpc/rpc.h (modified) * c/src/exec/librpc/include/rpc/rpc_com.h (modified) * c/src/exec/librpc/include/rpc/rpc_msg.h (modified) * c/src/exec/librpc/include/rpc/svc.h (modified) * c/src/exec/librpc/include/rpc/svc_auth.h (modified) * c/src/exec/librpc/include/rpc/types.h (modified) * c/src/exec/librpc/include/rpc/xdr.h (modified) * c/src/exec/librpc/include/rpcsvc/.cvsignore (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/crypt.x (modified) * c/src/exec/librpc/include/rpcsvc/key_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/mount.x (modified) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/nis.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_db.h (modified) * c/src/exec/librpc/include/rpcsvc/nis_object.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/exec/librpc/include/rpcsvc/nislib.h (modified) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/rex.x (modified) * c/src/exec/librpc/include/rpcsvc/rnusers.x (modified) * c/src/exec/librpc/include/rpcsvc/rquota.x (modified) * c/src/exec/librpc/include/rpcsvc/rstat.x (modified) * c/src/exec/librpc/include/rpcsvc/rwall.x (modified) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/exec/librpc/include/rpcsvc/spray.x (modified) * c/src/exec/librpc/include/rpcsvc/yp.x (modified) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/DISCLAIMER (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/exec/librpc/src/rpc/README (modified) * c/src/exec/librpc/src/rpc/auth_des.c (modified) * c/src/exec/librpc/src/rpc/auth_none.c (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/auth_unix.c (modified) * c/src/exec/librpc/src/rpc/authdes_prot.c (modified) * c/src/exec/librpc/src/rpc/authunix_prot.c (modified) * c/src/exec/librpc/src/rpc/bindresvport.3 (modified) * c/src/exec/librpc/src/rpc/bindresvport.c (modified) * c/src/exec/librpc/src/rpc/clnt_generic.c (modified) * c/src/exec/librpc/src/rpc/clnt_perror.c (modified) * c/src/exec/librpc/src/rpc/clnt_raw.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/crypt_client.c (modified) * c/src/exec/librpc/src/rpc/des_crypt.3 (modified) * c/src/exec/librpc/src/rpc/des_crypt.c (modified) * c/src/exec/librpc/src/rpc/des_soft.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/getpublickey.c (modified) * c/src/exec/librpc/src/rpc/getrpcent.3 (modified) * c/src/exec/librpc/src/rpc/getrpcent.c (modified) * c/src/exec/librpc/src/rpc/getrpcport.3 (modified) * c/src/exec/librpc/src/rpc/getrpcport.c (modified) * c/src/exec/librpc/src/rpc/key_call.c (modified) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/exec/librpc/src/rpc/netname.c (modified) * c/src/exec/librpc/src/rpc/netnamer.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot2.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/publickey.3 (modified) * c/src/exec/librpc/src/rpc/publickey.5 (modified) * c/src/exec/librpc/src/rpc/rpc.3 (modified) * c/src/exec/librpc/src/rpc/rpc.5 (modified) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/exec/librpc/src/rpc/rpc_commondata.c (modified) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/exec/librpc/src/rpc/rpc_prot.c (modified) * c/src/exec/librpc/src/rpc/rpc_secure.3 (modified) * c/src/exec/librpc/src/rpc/rpcdname.c (modified) * c/src/exec/librpc/src/rpc/rstat.1 (modified) * c/src/exec/librpc/src/rpc/rstat_svc.8 (modified) * c/src/exec/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/exec/librpc/src/rpc/rtems_rpc.c (modified) * c/src/exec/librpc/src/rpc/rtime.3 (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc.c (modified) * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_des.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/exec/librpc/src/rpc/svc_raw.c (modified) * c/src/exec/librpc/src/rpc/svc_run.c (modified) * c/src/exec/librpc/src/rpc/svc_simple.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/exec/librpc/src/xdr/xdr.3 (modified) * c/src/exec/librpc/src/xdr/xdr.c (modified) * c/src/exec/librpc/src/xdr/xdr_array.c (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/exec/librpc/src/xdr/xdr_mem.c (modified) * c/src/exec/librpc/src/xdr/xdr_rec.c (modified) * c/src/exec/librpc/src/xdr/xdr_reference.c (modified) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/exec/librpc/src/xdr/xdr_stdio.c (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/pthread.h (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskvariableget.c (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/include/rtems/README (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/README (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/dotests (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libc/termiosreserveresources.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/memory.h (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/if_loop.c (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/netinet/in.h (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/balloc.c (modified) * c/src/libnetworking/rtems_webserver/ejlex.c (modified) * c/src/libnetworking/rtems_webserver/handler.c (modified) * c/src/libnetworking/rtems_webserver/uemf.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/un.h (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/README_RTEMS (modified) * c/src/librpc/configure.in (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpc/auth.h (modified) * c/src/librpc/include/rpc/auth_des.h (modified) * c/src/librpc/include/rpc/auth_unix.h (modified) * c/src/librpc/include/rpc/clnt.h (modified) * c/src/librpc/include/rpc/des.h (modified) * c/src/librpc/include/rpc/des_crypt.h (modified) * c/src/librpc/include/rpc/pmap_clnt.h (modified) * c/src/librpc/include/rpc/pmap_prot.h (modified) * c/src/librpc/include/rpc/pmap_rmt.h (modified) * c/src/librpc/include/rpc/rpc.h (modified) * c/src/librpc/include/rpc/rpc_com.h (modified) * c/src/librpc/include/rpc/rpc_msg.h (modified) * c/src/librpc/include/rpc/svc.h (modified) * c/src/librpc/include/rpc/svc_auth.h (modified) * c/src/librpc/include/rpc/types.h (modified) * c/src/librpc/include/rpc/xdr.h (modified) * c/src/librpc/include/rpcsvc/.cvsignore (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/librpc/include/rpcsvc/crypt.x (modified) * c/src/librpc/include/rpcsvc/key_prot.x (modified) * c/src/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/librpc/include/rpcsvc/mount.x (modified) * c/src/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/librpc/include/rpcsvc/nis.x (modified) * c/src/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/librpc/include/rpcsvc/nis_db.h (modified) * c/src/librpc/include/rpcsvc/nis_object.x (modified) * c/src/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/librpc/include/rpcsvc/nislib.h (modified) * c/src/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/librpc/include/rpcsvc/rex.x (modified) * c/src/librpc/include/rpcsvc/rnusers.x (modified) * c/src/librpc/include/rpcsvc/rquota.x (modified) * c/src/librpc/include/rpcsvc/rstat.x (modified) * c/src/librpc/include/rpcsvc/rwall.x (modified) * c/src/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/librpc/include/rpcsvc/spray.x (modified) * c/src/librpc/include/rpcsvc/yp.x (modified) * c/src/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/DISCLAIMER (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/librpc/src/rpc/README (modified) * c/src/librpc/src/rpc/auth_des.c (modified) * c/src/librpc/src/rpc/auth_none.c (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/auth_unix.c (modified) * c/src/librpc/src/rpc/authdes_prot.c (modified) * c/src/librpc/src/rpc/authunix_prot.c (modified) * c/src/librpc/src/rpc/bindresvport.3 (modified) * c/src/librpc/src/rpc/bindresvport.c (modified) * c/src/librpc/src/rpc/clnt_generic.c (modified) * c/src/librpc/src/rpc/clnt_perror.c (modified) * c/src/librpc/src/rpc/clnt_raw.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/crypt_client.c (modified) * c/src/librpc/src/rpc/des_crypt.3 (modified) * c/src/librpc/src/rpc/des_crypt.c (modified) * c/src/librpc/src/rpc/des_soft.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/getpublickey.c (modified) * c/src/librpc/src/rpc/getrpcent.3 (modified) * c/src/librpc/src/rpc/getrpcent.c (modified) * c/src/librpc/src/rpc/getrpcport.3 (modified) * c/src/librpc/src/rpc/getrpcport.c (modified) * c/src/librpc/src/rpc/key_call.c (modified) * c/src/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/librpc/src/rpc/netname.c (modified) * c/src/librpc/src/rpc/netnamer.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_prot.c (modified) * c/src/librpc/src/rpc/pmap_prot2.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/publickey.3 (modified) * c/src/librpc/src/rpc/publickey.5 (modified) * c/src/librpc/src/rpc/rpc.3 (modified) * c/src/librpc/src/rpc/rpc.5 (modified) * c/src/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/librpc/src/rpc/rpc_commondata.c (modified) * c/src/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/librpc/src/rpc/rpc_prot.c (modified) * c/src/librpc/src/rpc/rpc_secure.3 (modified) * c/src/librpc/src/rpc/rpcdname.c (modified) * c/src/librpc/src/rpc/rstat.1 (modified) * c/src/librpc/src/rpc/rstat_svc.8 (modified) * c/src/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/librpc/src/rpc/rtems_rpc.c (modified) * c/src/librpc/src/rpc/rtime.3 (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth_des.c (modified) * c/src/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/librpc/src/rpc/svc_raw.c (modified) * c/src/librpc/src/rpc/svc_run.c (modified) * c/src/librpc/src/rpc/svc_simple.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/src/rpc_callmsg.c (deleted) * c/src/librpc/src/rpc_prot.c (deleted) * c/src/librpc/src/svc.c (deleted) * c/src/librpc/src/svc_auth.c (deleted) * c/src/librpc/src/svc_udp.c (deleted) * c/src/librpc/src/xdr.c (deleted) * c/src/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/src/xdr/xdr.3 (modified) * c/src/librpc/src/xdr/xdr.c (modified) * c/src/librpc/src/xdr/xdr_array.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_mem.c (modified) * c/src/librpc/src/xdr/xdr_rec.c (modified) * c/src/librpc/src/xdr/xdr_reference.c (modified) * c/src/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/librpc/src/xdr/xdr_stdio.c (modified) * c/src/librpc/src/xdr_array.c (deleted) * c/src/librpc/src/xdr_mem.c (deleted) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/sapi/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/itronmbox01.scn (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/itrontime01.scn (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/cpuuse/cpuuse.scn (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/malloctest/malloctest.scn (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmount/main.c (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/main.c (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/system.h (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/samples/unlimited/init.c (modified) * c/src/tests/samples/unlimited/system.h (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp27/init.c (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/sp29/init.c (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/system.h (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.in (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/webs.c (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/memory.h (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/README_RTEMS (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/des.h (modified) * cpukit/librpc/include/rpc/des_crypt.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/.cvsignore (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (modified) * cpukit/librpc/include/rpcsvc/crypt.x (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/klm_prot.x (modified) * cpukit/librpc/include/rpcsvc/mount.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nis.x (modified) * cpukit/librpc/include/rpcsvc/nis_cache.x (modified) * cpukit/librpc/include/rpcsvc/nis_callback.x (modified) * cpukit/librpc/include/rpcsvc/nis_db.h (modified) * cpukit/librpc/include/rpcsvc/nis_object.x (modified) * cpukit/librpc/include/rpcsvc/nis_tags.h (modified) * cpukit/librpc/include/rpcsvc/nislib.h (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rex.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) * cpukit/librpc/include/rpcsvc/rquota.x (modified) * cpukit/librpc/include/rpcsvc/rstat.x (modified) * cpukit/librpc/include/rpcsvc/rwall.x (modified) * cpukit/librpc/include/rpcsvc/sm_inter.x (modified) * cpukit/librpc/include/rpcsvc/spray.x (modified) * cpukit/librpc/include/rpcsvc/yp.x (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (modified) * cpukit/librpc/include/rpcsvc/ypxfrd.x (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/DISCLAIMER (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * cpukit/librpc/src/rpc/README (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authdes_prot.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.3 (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/crypt_client.c (modified) * cpukit/librpc/src/rpc/des_crypt.3 (modified) * cpukit/librpc/src/rpc/des_crypt.c (modified) * cpukit/librpc/src/rpc/des_soft.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getpublickey.c (modified) * cpukit/librpc/src/rpc/getrpcent.3 (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.3 (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/key_call.c (modified) * cpukit/librpc/src/rpc/key_prot_xdr.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/publickey.3 (modified) * cpukit/librpc/src/rpc/publickey.5 (modified) * cpukit/librpc/src/rpc/rpc.3 (modified) * cpukit/librpc/src/rpc/rpc.5 (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpc_secure.3 (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rstat.1 (modified) * cpukit/librpc/src/rpc/rstat_svc.8 (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.3 (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/src/xdr/xdr.3 (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/objectcopynamestring.c (modified) * make/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Makefile.am (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/.cvsignore (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/.cvsignore (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/.cvsignore (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkbinutilspec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup.def (modified) * scripts/Makefile.am (modified) * scripts/binutils/.cvsignore (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/.cvsignore (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/.cvsignore (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/.cvsignore (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/itronmbox01.scn (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/itrontests/itrontime01/itrontime01.scn (modified) * testsuites/itrontests/itrontime01/system.h (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/cpuuse.scn (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/psxtests/psxtimer/system.h (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/system.h (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/gensize.c (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) * tools/update/rtems-polish.sh (modified) Merged from 4.5.0-beta3a Tue, 08 Feb 2000 22:33:25 GMT Joel Sherrill [70810dc] * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * c/configure.in (modified) * c/make/Makefile.am (modified) * c/make/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/i386ex/configure.in (modified) * c/src/lib/libbsp/i386/pc386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/m68k/dmv152/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/configure.in (modified) * c/src/lib/libbsp/m68k/efi68k/configure.in (modified) * c/src/lib/libbsp/m68k/gen68302/configure.in (modified) * c/src/lib/libbsp/m68k/gen68340/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/configure.in (modified) * c/src/lib/libbsp/m68k/mvme136/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/ods68302/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips/p4000/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sh/gensh1/configure.in (modified) * c/src/lib/libbsp/sh/gensh2/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/configure.in (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libcpu/hppa1.1/configure.in (modified) * c/src/lib/libcpu/i386/configure.in (modified) * c/src/lib/libcpu/m68k/configure.in (modified) * c/src/lib/libcpu/mips/configure.in (modified) * c/src/lib/libcpu/mips64orion/configure.in (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/sh/configure.in (modified) * c/src/lib/libcpu/sparc/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/configure.in (modified) * c/src/librdbg/include/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/lib.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * configure.in (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/lib.cfg (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/cipolish (modified) * tools/update/configure.in (modified) Patches rtems-rc-20000204-0.diff from Ralf Corsepius [dd9c6e0d] * c/src/make/configure.in (modified) * c/src/tests/itrontests/itronmbox01/Makefile.in (modified) * c/src/tests/itrontests/itrontime01/Makefile.in (modified) * c/src/tests/sptests/sp27/Makefile.in (modified) * c/src/tests/sptests/sp28/Makefile.in (modified) * configure.in (modified) Patch rtems-rc-19991117-0.diff.gz from Ralf Corsepius ... Wed, 10 Nov 1999 13:48:27 GMT Joel Sherrill [eb02f47] * c/src/exec/itron/include/itronsys/types.h (modified) * c/src/exec/itron/include/rtems/itron/object.h (modified) * c/src/exec/itron/include/rtems/itron/task.h (modified) * c/src/exec/itron/inline/rtems/itron/task.inl (modified) * c/src/exec/itron/src/can_wup.c (modified) * c/src/exec/itron/src/chg_pri.c (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/exd_tsk.c (modified) * c/src/exec/itron/src/ext_tsk.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/get_tid.c (modified) * c/src/exec/itron/src/ref_tsk.c (modified) * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rot_rdq.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * c/src/exec/itron/src/slp_tsk.c (modified) * c/src/exec/itron/src/sta_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/task.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * c/src/exec/rtems/src/taskresume.c (modified) * c/src/exec/rtems/src/tasksuspend.c (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/src/threadinitialize.c (modified) * c/src/exec/score/src/threadrestart.c (modified) * c/src/exec/score/src/threadresume.c (added) * c/src/exec/score/src/threadrotatequeue.c (added) * c/src/exec/score/src/threadsuspend.c (added) * c/src/tests/itrontests/itrontask03/Makefile.in (modified) * c/src/tests/itrontests/itrontask03/spinit.c (deleted) * configure.in (modified) * cpukit/itron/include/itronsys/types.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/itron/inline/rtems/itron/task.inl (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/slp_tsk.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadresume.c (added) * cpukit/score/src/threadrotatequeue.c (added) * cpukit/score/src/threadsuspend.c (added) Committed modifications from ITRON Task and Task Dependendent ... Tue, 09 Nov 1999 22:18:43 GMT Joel Sherrill [c73b8ac2] * aclocal/check-itron.m4 (added) * aclocal/enable-itron.m4 (added) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/Makefile.inc.in (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/configure.in (modified) * c/src/make/target.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure.in (modified) * make/target.cfg.in (modified) * tools/update/cipolish (modified) This patch adds the basic framework for the ITRON 3.0 API ... Mon, 30 Aug 1999 16:25:54 GMT Joel Sherrill [f724a870] * c/configure (modified) * c/configure.in (modified) * c/src/configure (modified) * c/src/configure.in (modified) * c/src/make/Makefile.am (modified) * c/src/make/Makefile.in (modified) * c/src/make/Templates/Makefile.am (deleted) * c/src/make/Templates/Makefile.dir (deleted) * c/src/make/Templates/Makefile.in (deleted) * c/src/make/Templates/Makefile.leaf (deleted) * c/src/make/Templates/Makefile.lib (deleted) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * configure (modified) * configure.in (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) Patch from Ralf Corsepius : This patch ... Mon, 26 Jul 1999 20:00:37 GMT Joel Sherrill [6693a68] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * aclocal/tool-paths.m4 (modified) * aclocal/tool-prefix.m4 (modified) * autogen (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/rtems/sptables.h.in (added) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/README (added) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * c/src/tests/tools/generic/configure.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/sapi/include/rtems/sptables.h.in (moved) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) * make/directory.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * make/target.cfg.in (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/cpu/unix/configure.in (modified) * tools/update/Makefile.am (modified) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) * tools/update/rtems-polish.sh (modified) This is part of a major patch from Ralf Corsepius [15aa5ffb] * aclocal.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-cpu.m4 (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/tools/generic/aclocal.m4 (modified) * c/src/exec/score/tools/generic/configure (modified) * c/src/exec/score/tools/hppa1.1/aclocal.m4 (modified) * c/src/exec/score/tools/hppa1.1/configure (modified) * c/src/exec/score/tools/sh/aclocal.m4 (modified) * c/src/exec/score/tools/sh/configure (modified) * c/src/exec/score/tools/unix/aclocal.m4 (modified) * c/src/exec/score/tools/unix/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/no_cpu/no_bsp/bsp_specs (added) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * configure (modified) * configure.in (modified) * make/target.cfg.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius [817466c] * aclocal.m4 (modified) * aclocal/mkdir.m4 (deleted) * c/src/make/host.cfg.in (modified) * configure (modified) * configure.in (modified) * make/host.cfg.in (modified) * make/main.cfg (modified) Patch ("FIX: MKDIR/INSTALL_VARIANT") from Ralf Corsepius ... Fri, 16 Apr 1999 18:23:48 GMT Joel Sherrill [6b7ab9bf] * README.configure (modified) * aclocal.m4 (modified) * aclocal/enable-gmake-print.m4 (deleted) * c/src/make/directory.cfg (modified) * c/update-tools/cipolish (modified) * configure (modified) * configure.in (modified) * make/Templates/Makefile.inc.in (modified) * make/directory.cfg (modified) * make/main.cfg (modified) * make/target.cfg.in (modified) * tools/update/cipolish (modified) Patch from Ralf Corsepius : FYI: I am ... Mon, 12 Apr 1999 15:41:33 GMT Joel Sherrill [8cdb582] * aclocal.m4 (modified) * aclocal/rtems-top.m4 (modified) * autogen (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/aclocal.m4 (modified) * c/build-tools/configure (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/generic/aclocal.m4 (modified) * c/src/exec/score/tools/generic/configure (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/aclocal.m4 (modified) * c/src/exec/score/tools/hppa1.1/configure (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/sh/aclocal.m4 (modified) * c/src/exec/score/tools/sh/configure (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/score/tools/unix/aclocal.m4 (modified) * c/src/exec/score/tools/unix/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * c/update-tools/Makefile.am (added) * c/update-tools/Makefile.in (modified) * c/update-tools/aclocal.m4 (added) * c/update-tools/configure.in (added) * configure (modified) * configure.in (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/update/Makefile.am (added) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (added) * tools/update/configure.in (added) Patch from Ralf Corsepius : This patch ... Thu, 01 Apr 1999 16:58:06 GMT Joel Sherrill [f72dd2a] * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * configure (modified) * configure.in (modified) * testsuites/tools/generic/Makefile.am (modified) Patch from Ralf Corsepius to address ... Tue, 30 Mar 1999 15:38:57 GMT Joel Sherrill [710389fc] * configure (modified) * configure.in (modified) Cleaned up and regenerated. Mon, 29 Mar 1999 22:24:23 GMT Joel Sherrill [e5f4e5a] * c/src/lib/librdbg/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * configure (modified) * configure.in (modified) Patch from Ralf Corsepius : ... Wed, 24 Mar 1999 22:49:17 GMT Joel Sherrill [c9b07e92] * aclocal.m4 (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libchip/network/sonic.h (modified) * c/src/libchip/network/sonic.h (modified) * configure.in (modified) * make/custom/gensh1.cfg (modified) * make/target.cfg.in (modified) Automake II patch from Ralf Corsepius : ... Tue, 23 Mar 1999 18:02:17 GMT Joel Sherrill [9b8baa1] * aclocal.m4 (modified) * aclocal/rtems-top.m4 (modified) * autogen (modified) * automake/local.am (added) * automake/subdirs.am (added) * c/build-tools/Makefile.am (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/aclocal.m4 (modified) * c/build-tools/configure (modified) * c/build-tools/configure.in (modified) * c/build-tools/os/Makefile.am (modified) * c/build-tools/scripts/Makefile.am (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.am (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/print_dump.c (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/difftest.in (added) * c/src/tests/tools/generic/sorttimes.in (moved) * c/update-tools/ampolish (added) * c/update-tools/rtems-polish.sh (added) * configure (modified) * configure.in (modified) * testsuites/tools/generic/difftest.in (moved) * testsuites/tools/generic/sorttimes.in (added) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/build/os/Makefile.am (modified) * tools/build/scripts/Makefile.am (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.am (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/ampolish (added) * tools/update/rtems-polish.sh (added) Automake II patch from Ralf Corsepius . ... Fri, 19 Mar 1999 23:11:36 GMT Joel Sherrill [04c308c] * aclocal.m4 (modified) * aclocal/canonical-host.m4 (modified) * aclocal/enable-inlines.m4 (modified) * autogen (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.am (added) * c/build-tools/Makefile.in (modified) * c/build-tools/aclocal.m4 (added) * c/build-tools/configure (added) * c/build-tools/configure.in (added) * c/build-tools/os/Makefile.am (added) * c/build-tools/scripts/Makefile.am (added) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.am (added) * c/build-tools/src/Makefile.in (modified) * c/build-tools/src/config.h.in (modified) * c/build-tools/src/stamp-h.in (added) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * tools/build/Makefile.am (added) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (added) * tools/build/configure (added) * tools/build/configure.in (added) * tools/build/os/Makefile.am (added) * tools/build/scripts/Makefile.am (added) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.am (added) * tools/build/src/Makefile.in (modified) * tools/build/src/config.h.in (modified) * tools/build/src/stamp-h.in (added) Incorporated automake I patch from Ralf Corsepius [d8ff793] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * c/update-tools/acpolish (added) * configure.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/rtems.cfg (deleted) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/acpolish (added) Towards automake XI patch from Ralf Corsepius [dfe7746e] * aclocal/canonical-target-name.m4 (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * configure.in (modified) * make/custom/p4000.cfg (modified) * make/host.cfg.in (modified) Patch from Ralf Corsepius Wed, 17 Mar 1999 15:56:03 GMT Joel Sherrill [e9e01dd6] * configure (modified) * configure.in (modified) Suggested rephrasing of inline versus macros option by Chris Johns ... Mon, 08 Mar 1999 21:38:16 GMT Joel Sherrill [16b5264d] * configure (modified) * configure.in (modified) Switched sense of tests configure flag to really be off by default. Thu, 25 Feb 1999 19:22:58 GMT Joel Sherrill [e1b77701] * configure (modified) * configure.in (modified) backed off previous change and switched to tests being disabled by ... Thu, 25 Feb 1999 17:30:24 GMT Joel Sherrill [0ce4728] * configure (modified) * configure.in (modified) Suggestion from Ralf Corsepius to clarify ... Thu, 18 Feb 1999 18:28:24 GMT Joel Sherrill [7908ba5b] * c/src/exec/score/cpu/a29k/rtems/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (added) * c/src/exec/score/cpu/a29k/rtems/score/a29ktypes.h (added) * c/src/exec/score/cpu/a29k/rtems/score/cpu.h (added) * c/src/exec/score/cpu/a29k/rtems/score/types.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu_asm.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppatypes.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/types.h (added) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/cpu.h (added) * c/src/exec/score/cpu/i386/rtems/score/i386.h (added) * c/src/exec/score/cpu/i386/rtems/score/i386types.h (added) * c/src/exec/score/cpu/i386/rtems/score/types.h (added) * c/src/exec/score/cpu/i386/wrap/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (added) * c/src/exec/score/cpu/i960/rtems/score/i960.h (added) * c/src/exec/score/cpu/i960/rtems/score/i960types.h (added) * c/src/exec/score/cpu/i960/rtems/score/types.h (added) * c/src/exec/score/cpu/i960/wrap/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (added) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (added) * c/src/exec/score/cpu/m68k/rtems/score/m68ktypes.h (added) * c/src/exec/score/cpu/m68k/rtems/score/types.h (added) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (added) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (added) * c/src/exec/score/cpu/mips/rtems/score/mipstypes.h (added) * c/src/exec/score/cpu/mips/rtems/score/types.h (added) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/idtcpu.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/idtmon.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/iregdef.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/mipstypes.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/types.h (added) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cputypes.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/types.h (added) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/score/cpu.h (added) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/cpu.h (added) * c/src/exec/score/cpu/sh/rtems/score/cpu_isps.h (added) * c/src/exec/score/cpu/sh/rtems/score/iosh7030.h (added) * c/src/exec/score/cpu/sh/rtems/score/iosh7032.h (added) * c/src/exec/score/cpu/sh/rtems/score/ispsh7032.h (added) * c/src/exec/score/cpu/sh/rtems/score/sh.h (added) * c/src/exec/score/cpu/sh/rtems/score/sh_io.h (added) * c/src/exec/score/cpu/sh/rtems/score/shtypes.h (added) * c/src/exec/score/cpu/sh/rtems/score/types.h (added) * c/src/exec/score/cpu/sh/wrap/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (added) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (added) * c/src/exec/score/cpu/sparc/rtems/score/sparctypes.h (added) * c/src/exec/score/cpu/sparc/rtems/score/types.h (added) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (added) * c/src/exec/score/cpu/unix/rtems/score/types.h (added) * c/src/exec/score/cpu/unix/rtems/score/unix.h (added) * c/src/exec/score/cpu/unix/rtems/score/unixtypes.h (added) * c/src/exec/score/cpu/unix/wrap/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (added) * c/src/lib/libcpu/sh/sh7032/include/ispsh7032.h (added) * configure.in (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (added) * cpukit/score/cpu/a29k/rtems/score/cpu.h (added) * cpukit/score/cpu/a29k/rtems/score/types.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/cpu.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/types.h (added) * cpukit/score/cpu/i386/rtems/score/cpu.h (added) * cpukit/score/cpu/i386/rtems/score/i386.h (added) * cpukit/score/cpu/i386/rtems/score/types.h (added) * cpukit/score/cpu/i960/rtems/score/cpu.h (added) * cpukit/score/cpu/i960/rtems/score/i960.h (added) * cpukit/score/cpu/i960/rtems/score/types.h (added) * cpukit/score/cpu/m68k/rtems/score/cpu.h (added) * cpukit/score/cpu/m68k/rtems/score/m68k.h (added) * cpukit/score/cpu/m68k/rtems/score/types.h (added) * cpukit/score/cpu/mips/rtems/score/cpu.h (added) * cpukit/score/cpu/mips/rtems/score/types.h (added) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (added) * cpukit/score/cpu/mips64orion/rtems/score/types.h (added) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (added) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (added) * cpukit/score/cpu/no_cpu/rtems/score/types.h (added) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (added) * cpukit/score/cpu/sh/rtems/score/cpu.h (added) * cpukit/score/cpu/sh/rtems/score/sh.h (added) * cpukit/score/cpu/sh/rtems/score/sh_io.h (added) * cpukit/score/cpu/sh/rtems/score/types.h (added) * cpukit/score/cpu/sparc/rtems/score/cpu.h (added) * cpukit/score/cpu/sparc/rtems/score/sparc.h (added) * cpukit/score/cpu/sparc/rtems/score/types.h (added) * cpukit/score/cpu/unix/rtems/score/cpu.h (added) * cpukit/score/cpu/unix/rtems/score/types.h (added) * cpukit/score/cpu/unix/rtems/score/unix.h (added) Part of the automake VI patch from Ralf Corsepius [283d7285] * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (added) * c/src/exec/score/include/rtems/Makefile.in (added) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (added) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (added) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (added) * configure (modified) * configure.in (modified) Patch from Ralf Corsepius heading toward ... Thu, 10 Dec 1998 23:31:54 GMT Joel Sherrill [cca4400] * VERSION (modified) * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/sys/sockio.h (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/include/sys/sockio.h (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/sys/sockio.h (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/sys/sockio.h (modified) * configure (modified) * configure.in (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Merged Eric Norum's select patch that was based on 4.0 and resolved ... Thu, 03 Dec 1998 23:54:14 GMT Joel Sherrill [4721cf1] * c/Makefile.in (modified) * c/src/exec/librpc/include/rpc/auth.h (added) * c/src/exec/librpc/include/rpc/clnt.h (added) * c/src/exec/librpc/include/rpc/rpc.h (added) * c/src/exec/librpc/include/rpc/rpc_msg.h (added) * c/src/exec/librpc/include/rpc/svc.h (added) * c/src/exec/librpc/include/rpc/svc_auth.h (added) * c/src/exec/librpc/include/rpc/types.h (added) * c/src/exec/librpc/include/rpc/xdr.h (added) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/rdbg/i386/rdbg_f.h (added) * c/src/lib/include/rdbg/i386/reg.h (added) * c/src/lib/include/rdbg/rdbg.h (added) * c/src/lib/include/rdbg/servrpc.h (added) * c/src/lib/include/rpc/auth.h (added) * c/src/lib/include/rpc/clnt.h (added) * c/src/lib/include/rpc/rpc.h (added) * c/src/lib/include/rpc/rpc_msg.h (added) * c/src/lib/include/rpc/svc.h (added) * c/src/lib/include/rpc/svc_auth.h (added) * c/src/lib/include/rpc/types.h (added) * c/src/lib/include/rpc/xdr.h (added) * c/src/lib/librdbg/Makefile.in (added) * c/src/lib/librdbg/_servtgt.c (added) * c/src/lib/librdbg/awk.svc (added) * c/src/lib/librdbg/i386/excep.c (added) * c/src/lib/librdbg/i386/pc386/remdeb_f.x (added) * c/src/lib/librdbg/i386/rdbg_cpu_asm.s (added) * c/src/lib/librdbg/i386/rdbg_f.c (added) * c/src/lib/librdbg/ptrace.c (added) * c/src/lib/librdbg/rdbg.c (added) * c/src/lib/librdbg/remdeb.x (added) * c/src/lib/librdbg/servbkpt.c (added) * c/src/lib/librdbg/servcon.c (added) * c/src/lib/librdbg/servrpc.c (added) * c/src/lib/librdbg/servtgt.c (added) * c/src/lib/librdbg/servtsp.c (added) * c/src/lib/librdbg/servutil.c (added) * c/src/lib/librpc/Makefile.in (added) * c/src/lib/librpc/rpc_callmsg.c (added) * c/src/lib/librpc/rpc_prot.c (added) * c/src/lib/librpc/svc.c (added) * c/src/lib/librpc/svc_auth.c (added) * c/src/lib/librpc/svc_udp.c (added) * c/src/lib/librpc/xdr.c (added) * c/src/lib/librpc/xdr_array.c (added) * c/src/lib/librpc/xdr_mem.c (added) * c/src/lib/wrapup/Makefile.in (modified) * c/src/librdbg/include/rdbg/i386/rdbg_f.h (added) * c/src/librdbg/include/rdbg/i386/reg.h (added) * c/src/librdbg/include/rdbg/rdbg.h (added) * c/src/librdbg/include/rdbg/servrpc.h (added) * c/src/librdbg/src/Makefile.in (added) * c/src/librdbg/src/_servtgt.c (added) * c/src/librdbg/src/awk.svc (added) * c/src/librdbg/src/i386/any/remdeb_f.x (added) * c/src/librdbg/src/i386/excep.c (added) * c/src/librdbg/src/i386/pc386/remdeb_f.x (added) * c/src/librdbg/src/i386/rdbg_cpu_asm.s (added) * c/src/librdbg/src/i386/rdbg_f.c (added) * c/src/librdbg/src/ptrace.c (added) * c/src/librdbg/src/rdbg.c (added) * c/src/librdbg/src/remdeb.x (added) * c/src/librdbg/src/servbkpt.c (added) * c/src/librdbg/src/servcon.c (added) * c/src/librdbg/src/servrpc.c (added) * c/src/librdbg/src/servtgt.c (added) * c/src/librdbg/src/servtsp.c (added) * c/src/librdbg/src/servutil.c (added) * c/src/librpc/include/rpc/auth.h (added) * c/src/librpc/include/rpc/clnt.h (added) * c/src/librpc/include/rpc/rpc.h (added) * c/src/librpc/include/rpc/rpc_msg.h (added) * c/src/librpc/include/rpc/svc.h (added) * c/src/librpc/include/rpc/svc_auth.h (added) * c/src/librpc/include/rpc/types.h (added) * c/src/librpc/include/rpc/xdr.h (added) * c/src/librpc/src/Makefile.in (added) * c/src/librpc/src/rpc_callmsg.c (added) * c/src/librpc/src/rpc_prot.c (added) * c/src/librpc/src/svc.c (added) * c/src/librpc/src/svc_auth.c (added) * c/src/librpc/src/svc_udp.c (added) * c/src/librpc/src/xdr.c (added) * c/src/librpc/src/xdr_array.c (added) * c/src/librpc/src/xdr_mem.c (added) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/librpc/include/rpc/auth.h (added) * cpukit/librpc/include/rpc/clnt.h (added) * cpukit/librpc/include/rpc/rpc.h (added) * cpukit/librpc/include/rpc/rpc_msg.h (added) * cpukit/librpc/include/rpc/svc.h (added) * cpukit/librpc/include/rpc/svc_auth.h (added) * cpukit/librpc/include/rpc/types.h (added) * cpukit/librpc/include/rpc/xdr.h (added) * make/custom/default.cfg (modified) * make/target.cfg.in (modified) Patch from Emmanuel Raguet to add remote debug ... Mon, 23 Nov 1998 17:38:09 GMT Joel Sherrill [97e2729d] * aclocal.m4 (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/headers/cond.h (modified) * c/src/exec/posix/headers/mqueue.h (modified) * c/src/exec/posix/headers/mutex.h (modified) * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/headers/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/src/cond.c (modified) * c/src/exec/posix/src/mutex.c (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/monitor.h (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/monitor.h (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * configure (modified) * configure.in (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadq.c (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147s.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/simhppa.cfg (modified) * make/leaf.cfg (modified) * make/target.cfg.in (modified) * testsuites/sptests/spsize/size.c (modified) * tools/cpu/generic/size_rtems.in (modified) Added --disable-multiprocessing flag and modified a lot of files to ... Thu, 19 Nov 1998 20:09:01 GMT Joel Sherrill [2e26bbd] * aclocal/canonicalize-tools.m4 (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * configure.in (modified) Patch from Ralf Corsepius : Here is a ... Wed, 28 Oct 1998 19:17:16 GMT Joel Sherrill [692b9f7] * aclocal.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * c/Makefile.in (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * make/custom/psim.cfg (modified) * make/target.cfg.in (modified) Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along ... Wed, 14 Oct 1998 20:19:30 GMT Joel Sherrill [11cfb6f7] * c/build-tools/README (modified) * c/build-tools/install-if-change.in (added) * c/build-tools/lock-directory.in (added) * c/build-tools/rcs-clean.in (added) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/scripts/README (modified) * c/build-tools/scripts/install-if-change.in (added) * c/build-tools/scripts/lock-directory.in (added) * c/build-tools/scripts/rcs-clean.in (added) * c/build-tools/scripts/unlock-directory.in (added) * c/build-tools/unlock-directory.in (added) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (added) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/looptest.in (added) * c/src/lib/libbsp/unix/posix/tools/runtest.in (added) * c/src/lib/libbsp/unix/posix/tools/semdump.in (added) * c/src/lib/libbsp/unix/posix/tools/shmdump.in (added) * c/update-tools/Makefile.in (modified) * c/update-tools/update.in (added) * c/update-tools/word-replace.in (added) * configure (modified) * configure.in (modified) * make/rtems.cfg (added) * tools/build/README (modified) * tools/build/install-if-change.in (added) * tools/build/lock-directory.in (added) * tools/build/rcs-clean.in (added) * tools/build/scripts/Makefile.in (modified) * tools/build/scripts/README (modified) * tools/build/scripts/install-if-change.in (added) * tools/build/scripts/lock-directory.in (added) * tools/build/scripts/rcs-clean.in (added) * tools/build/scripts/unlock-directory.in (added) * tools/build/unlock-directory.in (added) * tools/cpu/generic/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/update.in (added) * tools/update/word-replace.in (added) Patch from Ralf Corsepius : 1. Rtems ... Wed, 14 Oct 1998 19:42:45 GMT Joel Sherrill [946b3cb] * configure (modified) * configure.in (modified) * make/compilers/gcc.cfg.in (modified) Patch from Ralf Corsepius : 2. "make ... Wed, 07 Oct 1998 14:39:58 GMT Joel Sherrill [959d752] * configure (modified) * configure.in (modified) Corrected typo pointed out by Pollak Leon . Wed, 30 Sep 1998 20:58:39 GMT Joel Sherrill [2c3840b] * aclocal.m4 (modified) * aclocal/i386-gas-code16.m4 (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/start.s (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * configure (modified) * configure.in (modified) Added new autoconf test for i386 code16/code32 support. The guts of ... Fri, 21 Aug 1998 17:43:22 GMT Joel Sherrill [cce81a7] * configure (modified) * configure.in (modified) * make/Makefile.in (modified) * make/compilers/gcc.cfg.in (added) * make/custom/default.cfg (modified) A patch from Ralf Corsepius : Here is ... Thu, 20 Aug 1998 22:04:22 GMT Joel Sherrill [28e7d7fa] * c/Makefile.in (modified) * c/src/exec/libnetworking/arpa/inet.h (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/README (modified) * c/src/lib/libbsp/bare/do-bare-bsp-build (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/arpa/inet.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libnetworking/arpa/inet.h (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * make/Templates/Makefile.inc.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) Patches from Eric Norum Thu, 20 Aug 1998 15:46:07 GMT Joel Sherrill [f205fe6d] * README.configure (modified) * configure (modified) * configure.in (modified) Updated to reflect stack transition. Thu, 20 Aug 1998 14:39:09 GMT Joel Sherrill [0280cb6] * c/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) FreeBSD stack compiles for the first time (except libc/strsep.c) Thu, 13 Aug 1998 14:47:18 GMT Joel Sherrill [579fc6a3] * c/PROBLEMS (modified) * configure (modified) * configure.in (modified) Per request from Chris Johns , I added code to detect ... Thu, 23 Jul 1998 22:02:34 GMT Joel Sherrill [67a2288] * Makefile.in (modified) * c/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (added) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (added) * c/src/lib/libbsp/i386/shared/irq/idt.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.h (added) * c/src/lib/libbsp/i386/shared/irq/irq_asm.h (added) * c/src/lib/libbsp/i386/shared/irq/irq_asm.s (added) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (added) * c/src/lib/libcpu/i386/Makefile.in (added) * c/src/lib/libcpu/i386/cpu.c (added) * c/src/lib/libcpu/i386/cpu.h (added) * c/src/lib/libcpu/i386/cpu_asm.S (added) * c/src/lib/libcpu/i386/idt.c (added) * c/src/lib/libcpu/i386/wrapup/Makefile.in (added) * c/src/lib/wrapup/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/score/cpu/i386/cpu.c (modified) Patch from Eric VALETTE : Here is a ... Thu, 23 Jul 1998 19:39:25 GMT Joel Sherrill [613ab62] * aclocal.m4 (modified) * aclocal/sysv-ipc.m4 (added) * configure (modified) * configure.in (modified) Patch from Dario Alcocer and Ralf Corsepius ... Fri, 17 Jul 1998 15:49:12 GMT Joel Sherrill [f95d2b53] * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/update-tools/Makefile.in (modified) * configure.in (modified) * make/host.cfg.in (modified) * make/main.cfg (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Patch from Ralf Corsepius . Comments: ... Tue, 07 Jul 1998 18:35:01 GMT Joel Sherrill [57c9bc2] * configure (modified) * configure.in (modified) Removed rtems-glom as a generated file. Regenerated aclocal.m4 and ... Sat, 27 Jun 1998 17:09:47 GMT Joel Sherrill [98100d2] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/ar-s.m4 (added) * aclocal/canonicalize-tools.m4 (modified) * aclocal/cygwin.m4 (added) * aclocal/exeext.m4 (added) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * c/PROBLEMS (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/README (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/size_rtems.in (modified) Monstrous patch from Ralf Corsepius . I ... Thu, 25 Jun 1998 16:21:31 GMT Joel Sherrill [a5400c0] * configure (modified) * configure.in (modified) Bare bsp patch from Chris Johns and regenerated files. Thu, 18 Jun 1998 15:22:35 GMT Joel Sherrill [9a6994b4] * c/ACKNOWLEDGEMENTS (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/exec/score/cpu/unix/unix.h (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libc/termios.c (modified) * configure (modified) * configure.in (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) * tools/cpu/generic/size_rtems.in (modified) Added freebsd support from Dario Alcocer . Thu, 04 Jun 1998 15:15:08 GMT Joel Sherrill [1388d19] * configure (modified) * configure.in (modified) Regenerated aclocal and configure after cleaning up the check that a ... Wed, 03 Jun 1998 11:22:18 GMT Joel Sherrill [d7c9cbe4] * configure (modified) * configure.in (modified) ppc-rtems is now an alias for powerpc-rtems. Fri, 22 May 1998 12:25:52 GMT Joel Sherrill [550ca7d5] * configure (modified) * configure.in (modified) hppa1.1 -> hppa1_1 remapping crept back in somehow -- gona again. ... Thu, 21 May 1998 18:26:58 GMT Joel Sherrill [bd5e4f3b] * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (added) * c/src/lib/libbsp/bare/README (added) * c/src/lib/libbsp/bare/bsp_specs (added) * c/src/lib/libbsp/bare/include/Makefile.in (added) * c/src/lib/libbsp/bare/include/bsp.h (added) * c/src/lib/libbsp/bare/wrapup/Makefile.in (added) * configure (modified) * configure.in (modified) * make/custom/bare.cfg (added) * make/leaf.cfg (modified) * make/target.cfg.in (modified) Added bare bsp from Chris Johns . Wed, 20 May 1998 17:06:57 GMT Joel Sherrill [2efdd08] * aclocal/canonicalize-tools.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * configure.in (modified) Patch from Ralf Corseipus to fix latent configure problems suddenly ... Mon, 18 May 1998 16:36:09 GMT Joel Sherrill [0b76723] * configure (modified) * configure.in (modified) Support bsp_specs style building for linux and solaris. Improved C++ ... Mon, 27 Apr 1998 13:43:46 GMT Joel Sherrill [9829978] * configure (modified) * configure.in (modified) Fixed bug where posix tests were not being enabled. Tue, 14 Apr 1998 22:13:05 GMT Joel Sherrill [2758c9f2] * configure (modified) * configure.in (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) Ralf Corsepius suggested a way to get rid of UNIX compiler files and ... Fri, 03 Apr 1998 18:02:16 GMT Joel Sherrill [70dda0ea] * configure (modified) * configure.in (modified) Patch from Samuel Tardieu so the messages printed ... Mon, 23 Mar 1998 23:08:10 GMT Joel Sherrill [42dc81e] * c/src/exec/score/tools/generic/size_rtems.in (modified) * configure (modified) * configure.in (modified) * tools/cpu/generic/size_rtems.in (modified) Renamed hppa1_1 to hppa1.1 Mon, 23 Mar 1998 22:54:55 GMT Joel Sherrill [e4829a05] * c/src/exec/score/tools/generic/size_rtems.in (modified) * configure (modified) * configure.in (modified) * make/custom/papyrus.cfg (modified) * tools/cpu/generic/size_rtems.in (modified) renamed ppc to powerpc Thu, 19 Feb 1998 22:54:14 GMT Joel Sherrill [41f61bc] * configure (modified) * configure.in (modified) Updated so test tools are installed even when --disable-tests is ... Tue, 17 Feb 1998 19:23:47 GMT Joel Sherrill [540292a] * configure (modified) * configure.in (modified) Ralf Corsepius pushing us farther down the autconf path: "Ladies ... Tue, 17 Feb 1998 13:48:43 GMT Joel Sherrill [3771cc6e] * configure (modified) * configure.in (modified) Update from Ralf Corsepius: Yep, I have a bunch of bug-fixes and ... Wed, 11 Feb 1998 21:20:43 GMT Joel Sherrill [2bb990f] * configure (modified) * configure.in (modified) Fixed hppa1.1 configuration. Wed, 04 Feb 1998 15:54:31 GMT Joel Sherrill [7a524954] * config.sub (modified) * configure.in (modified) Change suggested by Ralf Corsepius: I am not sure if this is ... Fri, 30 Jan 1998 21:49:51 GMT Joel Sherrill [5c3511e] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/base/Makefile.in (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/sys/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/headers/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * configure (modified) * configure.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.inc.in (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/target.cfg.in (modified) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Big patch form Ralf Corsepius described in this email: Here is ... Fri, 30 Jan 1998 20:57:53 GMT Joel Sherrill [243ce5d] * configure.in (modified) correction Thu, 22 Jan 1998 22:46:55 GMT Joel Sherrill [4a7c0451] * configure (modified) * configure.in (modified) Reverted change ... Thu, 22 Jan 1998 15:20:43 GMT Joel Sherrill [ba024755] * configure (modified) * configure.in (modified) Corrected/simplified setting of RTEMS_ROOT. Wed, 21 Jan 1998 18:28:09 GMT Joel Sherrill [9ad1f13] * c/build-tools/cklength.c (modified) * c/build-tools/eolstrip.c (modified) * c/build-tools/packhex.c (modified) * c/build-tools/src/Makefile.in (modified) * c/build-tools/src/cklength.c (modified) * c/build-tools/src/eolstrip.c (modified) * c/build-tools/src/packhex.c (modified) * c/build-tools/src/unhex.c (modified) * c/build-tools/unhex.c (modified) * configure (modified) * configure.in (modified) * tools/build/cklength.c (modified) * tools/build/eolstrip.c (modified) * tools/build/packhex.c (modified) * tools/build/src/Makefile.in (modified) * tools/build/src/cklength.c (modified) * tools/build/src/eolstrip.c (modified) * tools/build/src/packhex.c (modified) * tools/build/src/unhex.c (modified) * tools/build/unhex.c (modified) Added autoconf support for strerror/sys_errlist per Ralf Corsepius' ... Tue, 20 Jan 1998 19:30:48 GMT Joel Sherrill [6d6f1b34] * configure (modified) * configure.in (modified) Fixed libhwapi to reflect eeprom to non volatile memory rename. Fri, 16 Jan 1998 16:56:48 GMT Joel Sherrill [6f9c75c3] * Makefile.in (modified) * README.configure (modified) * aclocal.m4 (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/scripts/search-id.sh (added) * c/build-tools/search-id.sh (added) * c/src/lib/libbsp/i386/i386ex/startup/README (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/clock/rtc.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/coverhd.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/startup/sbrk.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/pc386/times_i486dx (modified) * c/src/lib/libbsp/i386/pc386/times_p5 (modified) * c/src/lib/libbsp/i386/pc386/tools/Spec.doc (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/start332/start332.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c (modified) * c/src/lib/libbsp/mips/README (modified) * c/src/lib/libbsp/mips/p4000/README (modified) * c/src/lib/libbsp/mips/p4000/startup/ghlinkcmds (modified) * c/src/lib/libbsp/mips/p4000/times (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/README (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/README (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/ghlinkcmds (modified) * c/src/lib/libbsp/mips64orion/p4000/times (modified) * c/src/lib/libcpu/hppa1.1/milli/milli.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/README (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/fpsp.defs (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/round.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sacos.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sasin.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satanh.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scosh.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slog2.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssinh.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/tbldo.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/util.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.s (modified) * c/src/lib/libmisc/cpuuse/README (modified) * c/src/lib/libmisc/cpuuse/cpuuse.c (modified) * c/src/lib/libmisc/cpuuse/cpuuse.h (modified) * c/src/lib/libmisc/cpuuse/internal.h (modified) * c/src/libmisc/cpuuse/README (modified) * c/src/libmisc/cpuuse/cpuuse.c (modified) * c/src/libmisc/cpuuse/cpuuse.h (modified) * c/src/libmisc/cpuuse/internal.h (modified) * c/src/tests/libtests/cpuuse/init.c (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task1.c (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/task3.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/monitor/init.c (modified) * c/src/tests/libtests/rtmonuse/getall.c (modified) * c/src/tests/libtests/rtmonuse/init.c (modified) * c/src/tests/libtests/rtmonuse/task1.c (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/tools/generic/sorttimes (modified) * c/update-tools/310_to_320_list (modified) * config.guess (modified) * config.sub (modified) * configure (modified) * configure.in (modified) * cpukit/libmisc/cpuuse/README (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * install-sh (modified) * mkinstalldirs (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/termios/init.c (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/scripts/search-id.sh (added) * tools/build/search-id.sh (added) * tools/update/310_to_320_list (modified) Ralf Corsepius reported a number of missing CVS Id's: > RTEMS is ... Thu, 15 Jan 1998 21:31:37 GMT Joel Sherrill [300c8a76] * configure (modified) * configure.in (modified) Added "done" to end of list of BSPs found. Thu, 15 Jan 1998 20:29:51 GMT Joel Sherrill [566aea7d] * INSTALL (modified) * configure (modified) * configure.in (modified) Fixed code for --disable-rtems-inlines so that it would complete ... Mon, 22 Dec 1997 20:33:55 GMT Joel Sherrill [fcb114c1] * configure (modified) * configure.in (modified) Made --enable-gcc28 the default. Mon, 22 Dec 1997 17:26:19 GMT Joel Sherrill [6d5769f] * configure (modified) * configure.in (modified) Added size_rtems as a generated file. Tue, 16 Dec 1997 18:40:08 GMT Joel Sherrill [87cec48] * configure (modified) * configure.in (modified) Changed RTEMS_BSP to RTEMS_BSP_LIST. Wed, 10 Dec 1997 16:58:00 GMT Joel Sherrill [674c900] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/base/Makefile.in (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/sys/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/headers/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * configure (modified) * configure.in (modified) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Modified a lot of files to take a first cut at supporting building ... Sat, 06 Dec 1997 15:44:46 GMT Joel Sherrill [80a16ec4] * configure (modified) * configure.in (modified) Redid hwapi makefile search to remove need for -follow option to ... Thu, 04 Dec 1997 18:38:05 GMT Joel Sherrill [744df795] * configure (modified) * configure.in (modified) Added better/more correct support for Linux and Solaris simulators. Mon, 01 Dec 1997 21:27:24 GMT Joel Sherrill [ba1a2af9] * configure (modified) * configure.in (modified) Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API related ... Mon, 01 Dec 1997 17:07:52 GMT Joel Sherrill [b9ca4ba] * configure (modified) * configure.in (modified) Even more cleanup to make sure all the --enable/disable options avoid ... Sun, 30 Nov 1997 18:34:11 GMT Joel Sherrill [37717818] * Makefile.in (modified) * aclocal.m4 (modified) * configure (modified) * configure.in (modified) Serious cleanup to reduce the number of explicitly listed Makefiles, ... Sat, 29 Nov 1997 18:20:04 GMT Joel Sherrill [1670eede] * Makefile.in (modified) * aclocal.m4 (modified) * configure (modified) * configure.in (modified) Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to ... Tue, 18 Nov 1997 22:29:32 GMT Joel Sherrill [a50148a] * configure (modified) * configure.in (modified) Merged code from Ralf Corsepius to generate ... Thu, 23 Oct 1997 18:46:03 GMT Joel Sherrill [208a922c] * configure (modified) * configure.in (modified) Added TOD code for MVME162 BSP from Katsutoshi Shibuya. Thu, 23 Oct 1997 15:09:50 GMT Joel Sherrill [ee9669f] * configure (modified) * configure.in (modified) Added termios test. Sun, 21 Sep 1997 17:44:14 GMT Joel Sherrill [8cd3748] * Makefile.in (modified) * configure (modified) * configure.in (modified) Removed duplicate listing of install in MTARGETS. Add monitor test. Tue, 26 Aug 1997 19:25:20 GMT Joel Sherrill [39ffc7d] * configure (modified) * configure.in (modified) Use own pdir option was reversed. Mon, 04 Aug 1997 21:41:38 GMT Joel Sherrill [c46732c] * configure (modified) * configure.in (modified) Added ppc-rtems as alternative name. Moved files around in list of ... Fri, 01 Aug 1997 20:22:29 GMT Joel Sherrill [3f70e3c] * configure (modified) * configure.in (modified) Corrected typo where "+ " was pasted in from another window. Added ... Thu, 31 Jul 1997 22:04:17 GMT Joel Sherrill [91333c2] * Makefile.in (modified) * README.configure (modified) * c/Makefile.in (modified) * c/src/exec/score/cpu/m68k/m68302.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/cdtest/main.cc (modified) * configure (modified) * configure.in (modified) * cpukit/score/cpu/m68k/m68302.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68302.h (modified) * testsuites/samples/cdtest/main.cc (modified) Merged very large and much appreciated patch from Chris Johns ... Wed, 09 Jul 1997 23:42:09 GMT Joel Sherrill [250394f6] * configure (modified) * configure.in (modified) Added mvme162lx bsp configuration. M68040 FPSP was already part of ... Tue, 27 May 1997 23:39:29 GMT Joel Sherrill [1f0f3e35] * Makefile.in (modified) * README.configure (modified) * c/ACKNOWLEDGEMENTS (modified) * c/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/network/network.c (added) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) added ka9q stack Fri, 23 May 1997 21:44:19 GMT Joel Sherrill [f5bd03c] * Makefile.in (modified) * README.configure (modified) * c/ACKNOWLEDGEMENTS (modified) * c/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) KA9Q stack removed prior to testing for 4.0.0 public release. Thu, 22 May 1997 18:13:24 GMT Joel Sherrill [69df7da] * configure (modified) * configure.in (modified) updated to correct problem in decoding arguments provided to configure. Tue, 22 Apr 1997 12:37:11 GMT Joel Sherrill [d4cf164] * configure (modified) * configure.in (modified) Added support for Hardware API. This will be distributed as a ...
