@fbcd7c8f
04/20/18 08:19:28 |
Sebastian Huber |
bsps: Move start files to bsps
This patch is a part of the BSP source …
5
@d7d66d7
04/19/18 04:28:01 |
Sebastian Huber |
bsps: Move console drivers to bsps
This patch is a part of the BSP …
5
@58adad4
04/20/18 07:59:43 |
Sebastian Huber |
bsps/powerpc: Move shared btimer support
This patch is a part of the …
5
@7632906
04/19/18 04:35:52 |
Sebastian Huber |
bsps: Move clock drivers to bsps
5
@5c5b021
04/19/18 04:26:42 |
Sebastian Huber |
bsps: Move bspsmpgetcurrentprocessor.c to bsps
This patch is a part …
5
@2584f5b
04/19/18 04:26:03 |
Sebastian Huber |
bsps: Move bspsmp.c to bsps
5
@bc010a8d
04/19/18 04:24:09 |
Sebastian Huber |
bsps: Move setvec.c to bsps
5
@a442939
04/19/18 04:23:59 |
Sebastian Huber |
bsps: Move sbrk.c to bsps
5
@7806d9c0
04/19/18 04:22:32 |
Sebastian Huber |
bsps: Move shared CPU counter support to bsps
This patch is a part of …
5
@79b9fe67
04/19/18 04:21:59 |
Sebastian Huber |
bsps: Move getentropy-cpucounter.c to bsps
5
@ef78454
04/19/18 04:18:55 |
Sebastian Huber |
bsps: Move gpio.c to bsps
5
@d6fb37a
04/19/18 04:17:52 |
Sebastian Huber |
bsps: Move shared btimer support to bsps
5
@4b9015c
04/19/18 04:14:56 |
Sebastian Huber |
bsps: Remove unused irq.h template file
5
@8d04f18
04/19/18 04:13:03 |
Sebastian Huber |
bsps: Remove unused rtems-stub-glue.c
5
@9ec8cfc5
04/19/18 04:10:36 |
Sebastian Huber |
bsps: Move pci_find_device.c to bsps
5
@f923901
04/19/18 04:10:18 |
Sebastian Huber |
bsps: Move pci_bus_count.c to bsps
5
@0510cd50
04/18/18 04:35:03 |
Sebastian Huber |
bsps: Move doxygen.h files to bsps
5
@c4ccf26c
04/17/18 04:57:46 |
Sebastian Huber |
bsps: Convert all bsp_predriver_hook()
Use RTEMS_SYSINIT_ITEM() …
5
@a884df3
04/17/18 07:49:49 |
Sebastian Huber |
bsp/motorola_powerpc: Move bspstart.c to bsps
This shared powerpc …
5
@5a06b187
04/17/18 04:33:51 |
Sebastian Huber |
bsps: Move bspgetworkarea.c to bsps
5
@6d21a3f2
04/17/18 04:31:30 |
Sebastian Huber |
drvmgr: Remove bsp_driver_level_hook()
5
@0b93d4f8
04/17/18 04:19:17 |
Sebastian Huber |
bsps: Move bspstart.c to bsps
5
@0736410
04/17/18 04:18:43 |
Sebastian Huber |
bsps: Move bspreset_loop.c to bsps
5
@554e39c
04/17/18 04:18:30 |
Sebastian Huber |
bsps: Move bspreset.c to bsps
5
@43bda786
04/17/18 04:18:02 |
Sebastian Huber |
bsps: Move bspclean.c to bsps
5
@4826858
04/20/18 07:19:02 |
Sebastian Huber |
motorola_powerpc: Remove headers from *_SOURCES
This was used by the …
5
@4c4dc17
04/17/18 15:05:27 |
joel |
misc arm tcfg: Add dl06, too large for memory
5
@2da4a6c
04/16/18 22:04:02 |
joel |
misc tcfg: Use disable-mrfs-tests.tcfg, do not duplicate test list
5
@2aa60e57
04/16/18 17:59:51 |
joel |
lpc2362-testsuite.tcfg: Use disable-iconv-tests.tcfg, do not duplicate …
5
@8d9aa9a
04/16/18 17:56:45 |
joel |
misc tcfg: Use disable-jffs2-tests.tcfg, do not duplicate test list
5
@d245eb0
04/12/18 15:17:35 |
joel |
generic_or1k: Disable sptls02 until or1k GCC updated from 4.9.x
5
@1b2681fe
04/12/18 15:13:48 |
joel |
Multiple BSP tcfg: Disable iconv files.
5
@223e22f
04/13/18 07:15:05 |
Sebastian Huber |
bsps: Move uart-output-char.c to bsps
5
@0a09ac58
04/13/18 07:14:56 |
Sebastian Huber |
bsps: Move stackalloc.c to bsps
5
@9d44ae7
04/13/18 07:14:36 |
Sebastian Huber |
bsps: Move bsp-uboot-board-info.c to bsps
5
@1cba1de
04/13/18 07:11:58 |
Sebastian Huber |
bsps: Move bsp-fdt.c to bsps
5
@90013f59
04/13/18 06:57:30 |
Sebastian Huber |
bsps: Move tod.c to bsps and rename
5
@4ff09d5b
04/12/18 05:27:41 |
Sebastian Huber |
build: Remove subdir-objects from BSP configure.ac
The subdir-objects …
5
@ff24c90d
04/11/18 04:19:26 |
Sebastian Huber |
bsps: Remove empty gnatinstallhandler.c
5
@c5fe4431
04/11/18 04:18:32 |
Sebastian Huber |
bsps: Move bootcard.c to bsps
5
@4359c43
04/10/18 14:32:59 |
Sebastian Huber |
bsps: Simplify source file path in Makefile.am
5
@b10caf8
04/10/18 05:16:30 |
Sebastian Huber |
bsps: Remove headers from librtemsbsp_a_SOURCES
5
@b78b814
04/10/18 04:36:19 |
Sebastian Huber |
bsps: Avoid source variables in Makefile.am
5
@6c4140c
04/10/18 04:17:10 |
Sebastian Huber |
bsps: Avoid line continuation in Makefile.am
5
@1032bf9
04/07/18 17:46:01 |
Sebastian Huber |
bsp/mvme5500: Avoid RTEMS_RELLDFLAGS
5
@b46f943c
04/07/18 17:38:55 |
Sebastian Huber |
bsp/motorola_powerpc: Move polled_io.c
This file was used by this BSP …
5
@efb893f
04/07/18 17:28:42 |
Sebastian Huber |
bsp/beatnik: Avoid RTEMS_RELLDFLAGS
Avoid extra CPPFLAGS.
5
@b43ea9f
04/05/18 15:07:20 |
Sebastian Huber |
bsps: Move legacy console driver to bsps
5
@f0bcae38
04/05/18 14:45:26 |
Sebastian Huber |
bsps: Remove unused console_select_simple.c
5
@b8c59353
04/11/18 03:26:58 |
Chris Johns |
build: Fix make clean.
Update #3254.
5
@aa567bc1
04/10/18 06:06:39 |
Chris Johns |
configure: Add subdir-objects to all automake flags.
This option …
5
@7ff743d
04/10/18 00:32:25 |
Chris Johns |
Generate an error if a BSP in the --enable-rtemsbsp list is not valid
5
@cb7b4dc4
04/09/18 03:47:36 |
Chris Johns |
bsp/lpc24xx: Exclude iconv POSIX tests.
These are now built to …
5
@b606998
04/09/18 09:40:28 |
Sebastian Huber |
bsp/genmcf548x: Fix IRQ support
5
@01d34a3
04/09/18 09:37:27 |
Sebastian Huber |
bsp/csb337: Fix umon support
5
@9edb72e
04/05/18 04:56:26 |
Sebastian Huber |
build: Remove DISTCLEANFILES
A "make distclean" is not supported. So, …
5
@9b7c456
04/05/18 04:40:02 |
Sebastian Huber |
bsps: Move generic IRQ support to bsps
5
@d584269
04/04/18 14:44:52 |
Sebastian Huber |
bsps: Remove librtemsbsp.a wrapup
5
@4b28d3c
04/04/18 14:39:58 |
Sebastian Huber |
bsps: Move shmdr to bsps
5
@814eccb4
04/03/18 14:41:16 |
Sebastian Huber |
bsps: Move VME support to bsps
The VME support is only used by …
5
@671c31fc
04/03/18 14:24:31 |
Sebastian Huber |
bsp: Move umon support to bsps
The umon support is only used by the …
5
@d03ec77d
04/04/18 14:26:28 |
Sebastian Huber |
bsps/powerpc: Rename to shared-sources.am
5
@6799a78
04/04/18 14:25:21 |
Sebastian Huber |
bsps/powerpc: Rename to exceptions-sources.am
5
@0f0f249c
04/04/18 14:24:15 |
Sebastian Huber |
bsps/m68k: Rename fpsp.am to fpsp-sources.am
5
@82bc976
04/04/18 14:23:09 |
Sebastian Huber |
bsps/bfin: Rename shared.am to shared-sources.am
5
@27de4e1f
04/03/18 05:20:11 |
Sebastian Huber |
bsps: Move libchip to bsps
5
@8621ed38
04/03/18 05:28:03 |
Sebastian Huber |
bsps: Move config macros to RTEMS_BSP_CONFIGURE
Provide …
5
@4f0dca3a
04/03/18 05:09:11 |
Sebastian Huber |
bsps: Move version.c and use bspopts.h
5
@ce0ea6f
04/03/18 05:08:24 |
Sebastian Huber |
bsps: Add shared-sources.am
5
@66b99a1
04/03/18 04:28:00 |
Sebastian Huber |
bsps: Add RTEMS_BSP to bspopts.h
5
@2d0bc83
03/30/18 18:42:21 |
Sebastian Huber |
build: Remove EXTRA_DIST
A "make dist" is not supported. So, it makes …
5
@0b8a6d7
03/28/18 16:17:45 |
joel |
Eliminate PowerPC libcpu/page.h
Started to eliminate warnings and …
5
@4f0dcb69
03/27/18 11:07:57 |
Sebastian Huber |
bsps/riscv: Fix warnings
5
@699fee43
03/26/18 11:33:29 |
Sebastian Huber |
bsps: Remove libcpu
5
@5d39512
03/26/18 11:25:36 |
Sebastian Huber |
bsps/m68k: Remove libcpu/m68k
5
@b54558ac
03/26/18 11:20:43 |
Sebastian Huber |
bsps/mcf5225x: Move libcpu content to bsps
5
@945095d
03/26/18 11:08:07 |
Sebastian Huber |
bsps/genmcf548x: Move libcpu content to bsps
5
@ddf3ea2
03/26/18 10:23:22 |
Sebastian Huber |
bsps/csb360: Move libcpu content to bsps
5
@2190bc6
03/26/18 10:20:45 |
Sebastian Huber |
bsps/mcf5206elite: Move libcpu content to bsps
5
@3cf2bf63
03/26/18 10:17:06 |
Sebastian Huber |
bsps/m68k: Move fpsp support to bsps
5
@fc2ec62
03/26/18 10:10:15 |
Sebastian Huber |
bsps/m68k: Move libcpu content to bsps
5
@1e23c47
03/26/18 10:01:18 |
Sebastian Huber |
bsps/m68k: Remove unused define
5
@f8e4755f
03/26/18 09:59:23 |
Sebastian Huber |
bsps/m68k: Use namespace header
5
@1048a165
03/26/18 08:36:52 |
Sebastian Huber |
bsp/tqm8xx: Use shared linker command file
Update #3339.
5
@11a8296
03/26/18 05:57:53 |
Sebastian Huber |
bsp/mvme3100: Simplify Makefile.am
5
@5f59e2a
03/26/18 05:52:57 |
Sebastian Huber |
bsps/powerpc: Move dec timer driver
5
@6882be7
03/26/18 05:47:02 |
Sebastian Huber |
bsps/powerpc: Remove libcpu/powerpc
5
@2d33672a
03/26/18 05:43:09 |
Sebastian Huber |
bsps/powerpc: Move ppc403 clock driver to bsps
5
@d7c232f
03/26/18 05:18:20 |
Sebastian Huber |
bsps/powerpc: Remove unused files
5
@4fd1ff0f
03/26/18 04:57:10 |
Sebastian Huber |
bsps/powerpc: Move AltiVec? support to bsps
5
@d813d9aa
03/26/18 04:24:55 |
Sebastian Huber |
bsps/powerpc: Move dec clock driver to bsps
5
@11fe8c59
03/26/18 04:18:51 |
Sebastian Huber |
bsps/powerpc: Move MMU support to bsps
5
@b8c468b
03/23/18 15:11:55 |
Sebastian Huber |
bsp/tqm8xx: Move libcpu content to bsps
5
@a12dcff8
03/23/18 15:04:18 |
Sebastian Huber |
bsp/mpc8260: Move libcpu content to bsps
5
@0cab067
03/23/18 14:54:12 |
Sebastian Huber |
bsps/powerpc: Move libcpu content to bsps
5
@e2bd1f6
03/21/18 15:38:43 |
Sebastian Huber |
bsp/bfin: Move libcpu content to bsps
5
@96400050
03/26/18 07:04:43 |
Sebastian Huber |
bsp/pc386: Remove unused RTEMS_CPU_MODEL
5
@b1b7390
03/26/18 06:58:42 |
Sebastian Huber |
bsp/pc386: Fix build
5
@f17df94
03/26/18 07:14:16 |
Sebastian Huber |
build: configure.ac is a file
5
@d7fd3bc
03/23/18 16:33:45 |
Gedare Bloom |
sparc64: remove header file with duplicated macros
The boot/stack.h …
5
