@f22bba3
04/26/13 09:03:59 |
eugen |
bsp/lm3s69xx: New BSP variants
Add support for LM3S3749.
4.115
@5fa0e5c5
04/24/13 12:37:50 |
Sebastian Huber |
libcsupport: Rename open_dev_console()
Rename open_dev_console() to …
4.115
@a290fbe9
04/24/13 12:30:42 |
Sebastian Huber |
libcsupport: Make LibIO helper const
Add and use rtems_libio_helper …
4.115
@62aa318
04/25/13 13:21:35 |
Sebastian Huber |
bsp/mpc55xx: Add MMU tag translate initializer
4.115
@92d8038
04/19/13 09:53:07 |
Sebastian Huber |
bsp/mpc5200: New BSP variant BRS6L
4.115
@7a44d06
04/19/13 12:17:09 |
Sebastian Huber |
bsp/mpc5200: Change SDRAM initialization
Change SDRAM initialization …
4.115
@d4a4811
04/19/13 12:01:47 |
Sebastian Huber |
bsp/mpc5200: Set SDELAY register
4.115
@dbe6aae7
04/19/13 11:51:54 |
Sebastian Huber |
bsp/mpc5200: Move CSBOOTROM_VAL definition
4.115
@e79e904
04/19/13 11:50:34 |
Sebastian Huber |
bsp/mpc5200: Move comment
4.115
@6c094da
04/19/13 11:48:48 |
Sebastian Huber |
bsp/mpc5200: Change ADREN register defines
4.115
@2793778
04/19/13 11:00:14 |
Sebastian Huber |
bsp/mpc5200: Remove Erratum 342/339 comment
4.115
@be04e62
04/19/13 10:51:57 |
Sebastian Huber |
bsp/mpc5200: Set XLB timeout values
4.115
@5e920ceb
04/19/13 10:50:10 |
Sebastian Huber |
bsp/mpc5200: Do not initialize debug registers
4.115
@740abbd
04/17/13 13:57:20 |
Sebastian Huber |
bsp/mpc5200: Add and use enable_bat_4_to_7()
4.115
@d5587f9f
04/17/13 14:03:03 |
Sebastian Huber |
bsp/mpc5200: Fix cache handling
4.115
@47fb2fe
04/11/13 15:22:02 |
Sebastian Huber |
bsp/mpc5200: Add MPC5200_BOARD prefix
4.115
@76de8a8e
04/17/13 12:54:05 |
van.freenix |
D-cache clean&&invalidate for Tiny6410
4.115
@ef8e851
04/17/13 13:45:52 |
Sebastian Huber |
bsp/mpc55xx: Typo
4.115
@db21e1d
04/03/13 10:05:49 |
Sebastian Huber |
bsp/mpc55xx: eDMA API changes
4.115
@4e3deaf7
04/05/13 13:57:19 |
Sebastian Huber |
bsp/mpc55xx: Add alternative register layout
4.115
@db0ed4c5
04/08/13 08:43:42 |
Sebastian Huber |
bsp/mpc55xx: Add PCR index enumeration
4.115
@7806a2b5
04/05/13 14:05:30 |
Sebastian Huber |
bsp/mpc55xx: New define MPC55XX_PERIPHERAL_CLOCK
4.115
@15c7657
04/05/13 14:05:03 |
Sebastian Huber |
bsp/mpc55xx: Rename BSP option
4.115
@30158371
04/03/13 10:10:25 |
Sebastian Huber |
bsp/mpc55xx: New fatal errors
4.115
@055f1f4c
04/08/13 13:21:37 |
Sebastian Huber |
bsp/mpc55xx: Include <bsp/linker-symbols.h>
4.115
@087a29b4
04/08/13 14:13:18 |
Sebastian Huber |
bsp/mpc55xx: Fix warnings
4.115
@65cd5e9
04/08/13 14:12:20 |
Sebastian Huber |
libchip/serial: Fix warnings
4.115
@ab49921
04/08/13 14:13:02 |
Sebastian Huber |
bsps: Fix warnings
4.115
@602d5ba
04/08/13 14:11:02 |
Sebastian Huber |
bsps: Fix warnings
4.115
@5ab9b13
04/08/13 07:45:45 |
Sebastian Huber |
bsps/powerpc: Use proper type
4.115
@166d78f
04/08/13 07:45:09 |
Sebastian Huber |
bsp/gen5200: Fix syntax
4.115
@39586f6
04/03/13 04:24:32 |
Sebastian Huber |
bsp/lpc24xx: Fix register address
4.115
@dea6fb6
04/02/13 14:01:05 |
Sebastian Huber |
bsp/gen5200: Typo
4.115
@0841c07
04/02/13 13:58:40 |
Sebastian Huber |
bsp/gen5200: Elaborate option help message
4.115
@fa77ad4b
04/02/13 13:50:23 |
Sebastian Huber |
bsp/gen5200: Remove superfluous option definition
4.115
@aa11df6
03/28/13 08:25:07 |
Sebastian Huber |
bsp/gen5200: Use busy wait
The usage of rtems_task_wake_after() is …
4.115
@d1e1df68
03/28/13 08:24:11 |
Sebastian Huber |
bsp/gen5200: Use fatal error instead of assert
4.115
@8ac62c4
03/26/13 15:01:10 |
Sebastian Huber |
bsps/arm: Add thread-local storage (TLS) sections
4.115
@c32b1ef
03/23/13 18:13:07 |
alan.cudmore |
bsp/raspberrypi: New BSP
4.115
@7b14e8b
03/21/13 09:46:03 |
Sebastian Huber |
bsp/mpc83xx: Add MPC83XX_NET*_INTERFACE_0_PHY_ADDR
4.115
@6457fb29
03/19/13 09:12:06 |
Sebastian Huber |
bsp/psim: Use shared linkcmds.base
Several GCC tests faild due to the …
4.115
@df6818f9
03/18/13 14:24:00 |
Sebastian Huber |
bsps: Support DWARF extension
4.115
@c2015b44
03/14/13 10:54:31 |
Sebastian Huber |
bsp/edb7312: Improve output char
The output char function used by …
4.115
@df3f0226
03/14/13 10:45:44 |
Sebastian Huber |
bsp/edb7312: Fix warnings
4.115
@faad192
03/11/13 16:54:34 |
Sebastian Huber |
mpc83xx: Add and use mpc83xx_reset()
The inline version makes it …
4.115
@f88da30
03/11/13 16:50:27 |
Sebastian Huber |
mpc83xx: Use shared linkcmds.base
4.115
@b34401cc
03/11/13 16:44:51 |
Sebastian Huber |
mpc83xx: Copy nothing if necessary
4.115
@9e25621
03/11/13 16:44:19 |
Sebastian Huber |
mpc83xx: Fix local access window 1 configuration
4.115
@907b07d9
03/11/13 16:43:08 |
Sebastian Huber |
mpc83xx: Add MPC83XX_HAS_NAND_LP_FLASH_ON_CS0
4.115
@dbc983c
03/11/13 19:28:06 |
Joel Sherrill |
mvme3100/Makefile.am: Remove reference to ChangeLog?
4.115
@b1f105e1
03/11/13 19:27:50 |
Joel Sherrill |
beatnik/Makefile.am: Remove reference to ChangeLog?
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@e2b4891
03/01/13 15:29:20 |
Sebastian Huber |
libchip: Fix prototypes
4.115
@aa314cf
02/28/13 17:08:50 |
Andreas Heinig |
libchip/rtc: Fixed 19 compiler warnings
4.115
@f806289
02/27/13 13:38:57 |
Andreas Heinig |
libchip/serial: Fixed warnings
4.115
@48fc25f
02/27/13 18:13:21 |
Anthony Green |
Common file changes in support of Moxie port
Signed-off-by: Anthony …
4.115
@032e5e4
02/27/13 18:13:20 |
Anthony Green |
Add sample Moxie BSP for GDB sim
Signed-off-by: Anthony Green …
4.115
@c6902a8
02/27/13 14:57:06 |
Andreas Heinig |
libchip/network: Fixed warning
4.115
@e517714b
02/26/13 18:31:23 |
Jennifer Averett |
sparc: Remove dead code that was leftover from SMP development.
4.115
@ef921556
02/25/13 16:33:17 |
Sebastian Huber |
bsp/mpc55xx: Add register type definition
4.115
@57bcb88e
02/18/13 16:00:28 |
Sebastian Huber |
bsp/gen5200: New ATA driver
This is a replacement for the ATA task. …
4.115
@c7a5656
02/18/13 15:29:32 |
Sebastian Huber |
bsp/gen5200: Add and use mpc5200_fatal()
4.115
@ced11eb1
02/18/13 15:27:50 |
Sebastian Huber |
bsp/mpc55xx: Fix prototype
4.115
@83a2fad
02/12/13 12:58:52 |
Sebastian Huber |
make: Add default flags
4.115
@f67eee1
02/12/13 12:54:18 |
Sebastian Huber |
make: Add CPPFLAGS
4.115
@780aadc
02/12/13 12:53:39 |
Sebastian Huber |
make: Remove -Wno-unused flag for debug variant
4.115
@3e132a8
02/12/13 12:51:27 |
Sebastian Huber |
make: Remove -g flags
The -g flag is set by the BSP.
4.115
@baa60b5e
02/12/13 10:25:25 |
Sebastian Huber |
make: Remove -qrtems_debug flag usage
4.115
@7b859d59
02/12/13 10:24:40 |
Sebastian Huber |
bsps/powerpc: Remove unused files
4.115
@77ac5785
02/12/13 08:27:01 |
Sebastian Huber |
bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS
4.115
@0241ab0
02/11/13 19:18:26 |
Gedare Bloom |
sparc64: revert linkcmds to 4 MB ram size
4.115
@6a22637
02/08/13 13:23:22 |
Sebastian Huber |
bsp/lpc24xx: Move UART probes to separate files
4.115
@5455f23a
02/08/13 15:58:52 |
Sebastian Huber |
libchip/serial: Make NS16550 handler public
This allows derived …
4.115
@c8bd3cd
02/08/13 12:39:59 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@e4933743
02/08/13 12:43:47 |
Sebastian Huber |
4.115
@49f65bef
02/08/13 12:42:02 |
Sebastian Huber |
4.115
@d2a4f158
02/08/13 10:58:37 |
Sebastian Huber |
4.115
@5de9e8d
02/08/13 10:58:20 |
Sebastian Huber |
bsp/erc32: Fix warnings
4.115
@4b53f191
02/06/13 10:38:29 |
Sebastian Huber |
bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE
4.115
@dc5cd79
02/06/13 10:37:26 |
Sebastian Huber |
bsp/mpc55xx: Merge RSM6 variants into one
4.115
@c082b575
02/05/13 16:23:55 |
Sebastian Huber |
bsp/mpc55xx: Add and use BSP specific fatal codes
4.115
@39de538
02/05/13 16:00:10 |
Sebastian Huber |
bsps/powerpc: Add and use ppc_cpu_is_specific_e200
4.115
@3020614
02/05/13 15:59:36 |
Sebastian Huber |
bsps/powerpc: Fix e200 check
4.115
@93d4d06
02/05/13 15:31:30 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_mmu_apply_config()
4.115
@c934a10d
01/11/13 13:41:53 |
Sebastian Huber |
bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH
4.115
@036788d5
01/11/13 13:41:00 |
Sebastian Huber |
bsps/powerpc: Add option for write-through cache
4.115
@4dafa52
01/28/13 11:38:55 |
Sebastian Huber |
bsp/mpc55xx: Fix MMU configuration for RSM6
4.115
@967278f
01/23/13 00:16:37 |
Ric Claus |
Fixed virtex4,5 BSP compile time warnings
4.115
@7f7b09c
01/18/13 08:48:38 |
Sebastian Huber |
bsp/gen83xx: Disable caches in bsp_restart()
4.115
@f7351e4
01/14/13 07:16:04 |
Sebastian Huber |
bsp/virtex5: Fix define location
4.115
@b1d1021
01/11/13 08:27:50 |
Sebastian Huber |
bsp/lpc32xx: Bypass the IrDA modem for UART6
4.115
@f12ef239
01/09/13 15:25:37 |
Sebastian Huber |
bsps/arm: Fix LPC Ethernet driver initialization
4.115
@da80202
01/09/13 13:31:58 |
Sebastian Huber |
bsp/gen83xx: Register I2C SEMTECH SC620 driver
4.115
@fb070e05
01/09/13 13:31:20 |
Sebastian Huber |
libchip: Add I2C SEMTECH SC620 octal LED driver
4.115
@aeff597
01/09/13 12:17:18 |
Sebastian Huber |
bsps/powerpc: Add probe handler to I2C driver
4.115
@339646e
01/09/13 11:50:55 |
Sebastian Huber |
bsps/powerpc: Fix compiler warnings
4.115
@bfde536e
01/09/13 10:12:48 |
Sebastian Huber |
bsp/gen83xx: Invalidate caches only if disabled
4.115
@5828127
01/09/13 08:29:04 |
Sebastian Huber |
bsp/gen83xx: System reset after fatal conditions
4.115
@d4e2f337
01/09/13 08:28:19 |
Sebastian Huber |
bsp/gen83xx: Add bsp_restart()
4.115
@253cb8b5
01/08/13 09:37:41 |
Sebastian Huber |
bsp/gen83xx: Delete obsolete region
4.115
