@e17ffea
06/03/97 22:06:49 |
Joel Sherrill |
Changed to variable length messages.
4.104.114.84.95
@bc35a6ef
06/03/97 21:48:57 |
Joel Sherrill |
Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0.
4.104.114.84.95
@1338cdb
06/03/97 21:46:18 |
Joel Sherrill |
Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0.
4.104.114.84.95
@c7f646b5
06/03/97 21:43:20 |
Joel Sherrill |
Fixed all references to Semaphore_Create to have the correct
argument …
4.104.114.84.95
@9db72b4
06/03/97 21:39:35 |
Joel Sherrill |
New file.
4.104.114.84.95
@4b067069
06/03/97 21:27:16 |
Joel Sherrill |
new file
4.104.114.84.95
@b4be04e
06/03/97 20:24:11 |
Joel Sherrill |
Removed Configuration Table information.
4.104.114.84.95
@7b93a327
06/03/97 20:20:39 |
Joel Sherrill |
Corrected call to Semaphore_Create to have the proper calling sequence
4.104.114.84.95
@b67e6ec
06/03/97 20:20:23 |
Joel Sherrill |
4.104.114.84.95
@43437e97
06/03/97 20:20:10 |
Joel Sherrill |
new file
4.104.114.84.95
@f222e9d4
06/03/97 19:26:36 |
Joel Sherrill |
Removed unnecessary dependency on RTEMS_Test_Support which existed
in …
4.104.114.84.95
@a1ceec8
06/03/97 19:25:56 |
Joel Sherrill |
new file
4.104.114.84.95
@be1618a
06/03/97 19:21:25 |
Joel Sherrill |
removed reference to the Stub Device Driver
4.104.114.84.95
@d6a9988
06/03/97 19:18:15 |
Joel Sherrill |
Changed mode and priority of initialization task.
4.104.114.84.95
@5687a1e9
06/03/97 18:38:58 |
Joel Sherrill |
Changed attribute of Initialization Task to Floating_Point
4.104.114.84.95
@ac953f2
06/03/97 18:38:40 |
Joel Sherrill |
new files
4.104.114.84.95
@dc300df
06/03/97 18:37:40 |
Joel Sherrill |
new file
4.104.114.84.95
@82870ab
06/03/97 18:28:38 |
Joel Sherrill |
new file
4.104.114.84.95
@91c78ffd
06/03/97 18:28:23 |
Joel Sherrill |
Changed from RTEMS.Boolean to Standard.Boolean to avoid problems.
4.104.114.84.95
@93bd518
06/03/97 18:07:51 |
Joel Sherrill |
new files
4.104.114.84.95
@6666ea88
06/03/97 18:07:30 |
Joel Sherrill |
Added True and False constants for RTEMS.Boolean types. This …
4.104.114.84.95
@9bec37b
06/03/97 18:06:46 |
Joel Sherrill |
Switched to proper types for booleans and increased the stack space …
4.104.114.84.95
@87e951a2
06/03/97 16:04:00 |
Joel Sherrill |
Added RTEMS boolean constants.
4.104.114.84.95
@a7156d1
06/03/97 16:00:00 |
Joel Sherrill |
Modifed to make the test run to completion. Primarily provided
the …
4.104.114.84.95
@98150020
06/03/97 15:40:24 |
Joel Sherrill |
Commented out exception handling code since these routines are not …
4.104.114.84.95
@4db9c861
06/03/97 15:39:28 |
Joel Sherrill |
removed with of unchecked_conversion
4.104.114.84.95
@e351c26a
06/03/97 15:25:28 |
Joel Sherrill |
sptest.adb: update Semaphore_Create calling sequence
sp12.adb: …
4.104.114.84.95
@4c3340c
06/03/97 15:22:09 |
Joel Sherrill |
Added Pending_Events and lined up other event constants
4.104.114.84.95
@c1ef834
06/03/97 15:12:23 |
Joel Sherrill |
Fixed problems which prevented the test from compiling and running to …
4.104.114.84.95
@d348ad96
06/03/97 15:11:39 |
Joel Sherrill |
added more constants and fixed numer
4.104.114.84.95
@7d366f1c
06/03/97 00:56:11 |
Joel Sherrill |
changed reference for Configuration Table from BSP to RTEMS.
4.104.114.84.95
@a6b44a8a
06/03/97 00:55:42 |
Joel Sherrill |
added Signal constants, Is_Status_Successful, and Attribute constants.
4.104.114.84.95
@d0f426a1
06/03/97 00:34:04 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@7e3dcbc
06/03/97 00:33:48 |
Joel Sherrill |
added rtems_interrupt_level_attribute routien to return a properly …
4.104.114.84.95
@e56a2ef
06/03/97 00:32:50 |
Joel Sherrill |
updated to run
4.104.114.84.95
@f2078ec
06/03/97 00:13:05 |
Joel Sherrill |
New style main procedure which creates the test's RTEMS initialization …
4.104.114.84.95
@8e7b810
06/02/97 23:47:05 |
Joel Sherrill |
added subtract of 1 to Task_Number to account for the creation
of the …
4.104.114.84.95
@ad9865e
06/02/97 23:46:41 |
Joel Sherrill |
4.104.114.84.95
@d766b7fd
06/02/97 23:46:15 |
Joel Sherrill |
added Minimum_Stack_Size and Mode constants
4.104.114.84.95
@529cdccd
06/02/97 22:41:03 |
Joel Sherrill |
new file
4.104.114.84.95
@7f79b673
06/02/97 22:37:28 |
Joel Sherrill |
readded body for "main" procedures
4.104.114.84.95
@77ff3d10
06/02/97 22:14:51 |
Joel Sherrill |
removed configuration table definition in Ada
4.104.114.84.95
@cf1ced66
06/02/97 21:53:05 |
Joel Sherrill |
new file - automatically generated by a script
4.104.114.84.95
@196a6b9
06/02/97 21:16:14 |
Joel Sherrill |
Changed license and copyright notice.
Added "development" style CVS Id
4.104.114.84.95
@2b7fc9cc
06/02/97 21:12:42 |
Joel Sherrill |
New file -- works in conjunction with support/init.c.
4.104.114.84.95
@b7c2ccc
06/02/97 20:59:29 |
Joel Sherrill |
Removed Ada Configuration Table definition.
4.104.114.84.95
@9917d5da
06/02/97 20:57:52 |
Joel Sherrill |
added screen files from 3.2.1
4.104.114.84.95
@f3f06f79
06/02/97 20:52:48 |
Joel Sherrill |
added new files from test area.
This code has successfully been used …
4.104.114.84.95
@bf9ae83
06/02/97 20:32:11 |
Joel Sherrill |
modified copyright notice to be the same as RTEMS 4.0.0.
changed the …
4.104.114.84.95
@6d4e604b
06/02/97 20:19:03 |
Joel Sherrill |
Initial revision
4.104.114.84.95
@00d2a828
05/28/97 20:36:35 |
Joel Sherrill |
Added support for context switching the data used by the gcc m68k …
4.104.114.84.95
@1f0f3e35
05/27/97 23:39:29 |
Joel Sherrill |
added ka9q stack
4.104.114.84.95
@7922df59
05/27/97 18:27:59 |
Joel Sherrill |
changed version number to 4.1.0.
4.104.114.84.95
@f5bd03c
05/23/97 21:44:19 |
Joel Sherrill |
KA9Q stack removed prior to testing for 4.0.0 public release.
4.104.114.84.95
@edd12702
05/21/97 12:59:40 |
Joel Sherrill |
patch from Eric Norum
4.104.114.84.95
@e8cdda4
04/25/97 18:13:49 |
Joel Sherrill |
Corrected by adding check for NULL address passed into get_status …
4.104.114.84.95
@f8f5106
04/25/97 18:13:26 |
Joel Sherrill |
Added to comment header block to include new status directive.
4.104.114.84.95
@18647b7
04/25/97 16:58:10 |
Joel Sherrill |
updated to reflect new license per John Gwynne's permission.
4.104.114.84.95
@8a7fafb3
04/23/97 18:17:01 |
Joel Sherrill |
Updated to reflect changes since 3.6.0
4.104.114.84.95
@7346e5f
04/22/97 20:43:23 |
Joel Sherrill |
incorrect screen name for multiprocessing tests.
4.104.114.84.95
@0a6fb22
04/22/97 20:19:25 |
Joel Sherrill |
Patch from Chris John <cjohns@…> to add use of a select …
4.104.114.84.95
@e0de6ef
04/22/97 20:19:12 |
Joel Sherrill |
promote TOD_MICROSECONDS_TO_TICKS through API as …
4.104.114.84.95
@f2545552
04/22/97 19:57:02 |
Joel Sherrill |
multiprocessing fixed on linux by fixing cpu.c so correct form of …
4.104.114.84.95
@e71ce071
04/22/97 17:47:16 |
Joel Sherrill |
updated with new license information per Tony Bennett.
4.104.114.84.95
@84ff7c23
04/22/97 17:42:17 |
Joel Sherrill |
File changed to reflect change in license and copyright.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@b91726f
04/22/97 17:04:49 |
Joel Sherrill |
LICENSE file is now only in top directory.
README updated.
4.104.114.84.95
@75a1a94
04/22/97 13:06:00 |
Joel Sherrill |
corrected some email addresses
4.104.114.84.95
@784cbc4
04/22/97 12:59:41 |
Joel Sherrill |
corrected Tony Bennett's email address
4.104.114.84.95
@5bb2ed07
04/22/97 12:39:23 |
Joel Sherrill |
Added support for HW API package
4.104.114.84.95
@1d61610
04/18/97 18:39:01 |
Joel Sherrill |
Modified to reflect change from 255 posix priority levels to 254.
4.104.114.84.95
@59097e7
04/18/97 18:38:19 |
Joel Sherrill |
Changed format of comment blocks to C comments.
4.104.114.84.95
@7e7143e
04/18/97 18:37:48 |
Joel Sherrill |
Duplicated timerisr symbol as _timerisr to avoid tool naming problems.
4.104.114.84.95
@dda5cf4
04/18/97 17:50:01 |
Joel Sherrill |
Corrected incorrect settings for locations of psx and sp test screens.
4.104.114.84.95
@9fbba98
04/16/97 17:47:48 |
Joel Sherrill |
Fixed path which points to shared directory for all BSPs.
4.104.114.84.95
@334b01f1
04/16/97 17:46:26 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@f9f375e
04/16/97 17:45:52 |
Joel Sherrill |
added fpsp support.
4.104.114.84.95
@f8f370b6
04/16/97 17:45:35 |
Joel Sherrill |
Update from Eric Norum.
4.104.114.84.95
@34217ccf
04/16/97 17:42:20 |
Joel Sherrill |
Updated to reflect Tony Bennett's new email address and the …
4.104.114.84.95
@5bf6ffb
04/16/97 17:34:40 |
Joel Sherrill |
Added FPSP support for MC68040
4.104.114.84.95
@010e7582
04/16/97 17:34:23 |
Joel Sherrill |
Added CVS Id's
4.104.114.84.95
@f9b93da
04/16/97 17:33:04 |
Joel Sherrill |
Added the MC68040 Floating Point Support Package. This was ported
to …
4.104.114.84.95
@6881e0c
04/15/97 18:02:18 |
Joel Sherrill |
Reduced number of POSIX thread priorities from 255 to 254 to avoid …
4.104.114.84.95
@c24fef3
04/15/97 18:00:03 |
Joel Sherrill |
Added directories to place test output screens into as part of fixing …
4.104.114.84.95
@b1a4ca8
04/15/97 17:40:38 |
Joel Sherrill |
Added line to install test screens so difftest does not have to have
a …
4.104.114.84.95
@b584751
04/15/97 17:37:12 |
Joel Sherrill |
Switched all bsps which had an implementation of sbrk.c which only …
4.104.114.84.95
@ecc4594
04/15/97 17:28:26 |
Joel Sherrill |
Removed many BSPs' copy of setvec.c and let them share the same …
4.104.114.84.95
@bc7d465
04/11/97 18:41:38 |
Joel Sherrill |
replaced linking of source from mvme147 drivers with use of vpath to …
4.104.114.84.95
@18e5d86
04/11/97 18:40:04 |
Joel Sherrill |
removed commented out line performing a link
4.104.114.84.95
@6bcceb8
04/09/97 21:00:33 |
Joel Sherrill |
enabled floating point and fixed confdef reference to initialization …
4.104.114.84.95
@61a183a9
04/09/97 20:19:35 |
Joel Sherrill |
new test
4.104.114.84.95
@dfdaf4ac
04/09/97 20:19:22 |
Joel Sherrill |
added cpuuse and rtmonuse
4.104.114.84.95
@c46ce854
04/09/97 20:19:07 |
Joel Sherrill |
printing task names now instead of id numbers
4.104.114.84.95
@fc7bc51
04/09/97 20:18:54 |
Joel Sherrill |
new files.
4.104.114.84.95
@9d5152f
04/09/97 20:07:22 |
Joel Sherrill |
added rtmonuse and cpuuse directories
4.104.114.84.95
@8f695a1
04/09/97 20:07:09 |
Joel Sherrill |
added cpuuse and rtmonuse directories
4.104.114.84.95
@e39e6f7
04/09/97 20:05:59 |
Joel Sherrill |
added code to prevent attempts to clean up the library when rtems is
down.
4.104.114.84.95
@0956b52
04/09/97 20:05:37 |
Joel Sherrill |
correct incorrect register addresses for port a.
4.104.114.84.95
@8c0dc2c
04/09/97 20:05:12 |
Joel Sherrill |
removed unused is_character_ready routine.
4.104.114.84.95
@3fc076d
04/09/97 20:04:52 |
Joel Sherrill |
added support for tracking thread cpu usage.
4.104.114.84.95
