Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @a871a6c7   07/11/06 03:32:01 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @c9b005a9   07/09/06 10:05:27 Thomas.Doerfler applied patches for PR1117/1118/1119/1120 4.104.114.84.95
(edit) @bf1cade   06/29/06 09:08:07 Ralf Corsepius 2006-06-28 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @82d11fc5   06/29/06 08:55:00 Ralf Corsepius 2006-06-28 Ralf Corsépius <ralf.corsepius@…> * ampolish3: … 4.104.114.84.95
(edit) @2758e1fc   06/25/06 00:36:40 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @272ac23a   06/25/06 00:36:35 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @f3323e1   06/25/06 00:36:29 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @b8de9518   06/25/06 00:36:23 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @f70c44da   06/25/06 00:14:10 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @6f96a1d   06/24/06 14:49:51 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * configure.ac: 4.104.114.84.95
(edit) @504c5ca   06/23/06 16:04:33 Joel Sherrill 2006-06-23 Worth Burruss <worth@…> * Makefile.am, … 4.104.114.84.95
(edit) @026e4793   06/22/06 18:54:46 Joel Sherrill 2006-06-22 Joel Sherrill <joel@…> PR 1100/bsps * … 4.104.114.84.95
(edit) @e5f55a1   06/21/06 13:52:18 Joel Sherrill Fix formatting. 4.104.114.84.95
(edit) @06cfd95   06/19/06 20:51:19 strauman Indicate that it's ok to use decoupled cycles to access on-board … 4.104.114.84.95
(edit) @9a30162   06/19/06 20:34:07 strauman Added address-modifier codes for BLT/MBLT. 4.104.114.84.95
(edit) @bf94317   06/19/06 20:30:08 strauman re-checked synchronization requirements when manipulating the caches … 4.104.114.84.95
(edit) @261a1b2   06/19/06 20:24:08 strauman Added altivec exception. Unfortunately, this doesn't fit the normal … 4.104.114.84.95
(edit) @df9cadc2   06/19/06 20:19:06 strauman Only set/access the _BSP_vme_bridge_irq variable on BSPs that define … 4.104.114.84.95
(edit) @599e719a   06/19/06 20:14:05 strauman filter exception vector for altivec and remap 0xf20 to assigned … 4.104.114.84.95
(edit) @d1999c8b   06/19/06 20:08:41 strauman fixed compiler warnings (bspIo.h inclusion, cast of number constants … 4.104.114.84.95
(edit) @368894f   06/19/06 19:59:59 strauman FP context switch may be called from environment with no FPU … 4.104.114.84.95
(edit) @bbc8785   06/19/06 19:57:01 strauman Never allow the FPU to be switched on for integer-only tasks (new gcc … 4.104.114.84.95
(edit) @efc0cd8   06/19/06 19:49:11 strauman Never allow the FPU to be switched on for integer-only tasks (new gcc … 4.104.114.84.95
(edit) @eeef62e   06/18/06 13:37:35 Joel Sherrill 2006-06-18 Joel Sherrill <joel@…> * README: 4.104.114.84.95
(edit) @7c99007   06/08/06 18:03:55 gregory.menke B.Robinson MIPS patch 4.104.114.84.95
(edit) @965c3924   06/03/06 03:24:00 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * shared/irq/irq_init.c: … 4.104.114.84.95
(edit) @1453d92   06/03/06 03:22:19 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * startup/linkcmds: … 4.104.114.84.95
(edit) @20e266ca   06/03/06 03:21:30 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * times: Reran timing … 4.104.114.84.95
(edit) @47dbc76   06/03/06 03:20:15 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @9cdfb0e   06/03/06 03:18:46 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * Makefile.am, … 4.104.114.84.95
(edit) @bc19e2a   06/03/06 03:16:18 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * … 4.104.114.84.95
(edit) @7afe5a2   06/03/06 03:14:07 Jay Monkman 2006-06-02 Jay Monkman * at91rm9200/irq/bsp_irq_init.c, … 4.104.114.84.95
(edit) @ada5201   06/03/06 03:12:06 Jay Monkman 2006-06-02 Jay Monkman * at91rm9200/irq/bsp_irq_init.c, … 4.104.114.84.95
(edit) @128bbf9   06/03/06 03:08:01 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * irq/bsp_irq_init.c: … 4.104.114.84.95
(edit) @1ca844f9   06/03/06 03:06:54 Jay Monkman 2006-06-02 Jay Monkman * irq/bsp_irq_init.c: Changed interrupt … 4.104.114.84.95
(edit) @9c05850c   06/03/06 03:04:41 Jay Monkman 2006-06-02 Jay Monkman * network/network.c: Changed interrupt … 4.104.114.84.95
(edit) @0eede05   06/02/06 21:53:04 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * start/start.S, … 4.104.114.84.95
(edit) @1db81f98   06/01/06 15:23:31 Joel Sherrill Formatting. 4.104.114.84.95
(edit) @5c89efa   05/31/06 13:46:23 Joel Sherrill 2006-05-31 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @2ba4b72   05/31/06 13:43:16 Joel Sherrill 2006-05-31 Joel Sherrill <joel@…> * clock/clock.c: Switch … 4.104.114.84.95
(edit) @4bee7d9c   05/16/06 14:32:21 Ralf Corsepius 2006-05-16 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @068cf700   05/16/06 14:26:57 Ralf Corsepius 2006-05-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @8a742dd   05/15/06 15:59:01 WENorum Allow single spurious FPGA interrupt. 4.104.114.84.95
(edit) @a7edc92   05/15/06 14:47:32 WENorum Improve handling of unexpected FPGA interrupt conditions. 4.104.114.84.95
(edit) @84c86f2   04/19/06 02:55:03 Joel Sherrill 2006-04-18 Joel Sherrill <joel@…> * aclocal/version.m4: … 4.104.114.84.95
(edit) @c5a67176   04/18/06 21:47:28 Joel Sherrill 2006-04-18 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @cd0142d5   04/12/06 20:32:35 Joel Sherrill 2006-04-12 Konrad Eisele <konrad@…> * include/leon.h: Add … 4.104.114.84.95
(edit) @e846fc9   04/11/06 19:17:09 WENorum Add default exception handler. 4.104.114.84.95
(edit) @73ad880   04/05/06 20:12:51 Joel Sherrill Fix formatting. 4.104.114.84.95
(edit) @56758965   04/05/06 20:11:57 Joel Sherrill 2006-04-05 Victor V. Vengerov <Victor.Vengerov@…> * … 4.104.114.84.95
(edit) @c19b37d4   04/02/06 06:57:50 Ralf Corsepius 2006-04-02 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @84572474   03/24/06 20:07:57 WENorum Add missing reset cause bit. 4.104.114.84.95
(edit) @a71c31b   03/22/06 13:53:32 Joel Sherrill 2006-03-22 Joel Sherrill <joel@…> * include/.cvsignore: … 4.104.114.84.95
(edit) @26d61ce4   03/17/06 15:31:13 Ralf Corsepius 2006-03-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c1a96804   03/17/06 10:34:12 Ralf Corsepius Misc. cosmetics. 4.104.114.84.95
(edit) @674be421   03/17/06 10:11:37 Ralf Corsepius Remove eof include file 4.104.114.84.95
(edit) @0c3269ce   03/16/06 18:12:27 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @01d8a42   03/16/06 18:11:32 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @401fe875   03/16/06 18:10:19 Ralf Corsepius 2006-03-16 Ralf Corsépius <ralf.corsepius@…> * Makefile.am, … 4.104.114.84.95
(edit) @6cd6923   03/16/06 18:07:22 Ralf Corsepius 2006-03-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @3a3e5dae   03/16/06 18:06:54 Ralf Corsepius New (Submission by Bruce Robinson <brucer@…>). 4.104.114.84.95
(edit) @b22b31fd   03/16/06 17:57:42 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @da7d7c2   03/16/06 17:57:27 Ralf Corsepius AC_CONFIG_SRCDIR(csb350). 4.104.114.84.95
(edit) @43b09557   03/16/06 17:57:12 Ralf Corsepius 2006-03-16 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @b7b487cb   03/16/06 17:43:00 Ralf Corsepius New. 4.104.114.84.95
(edit) @79b1dea5   03/16/06 17:42:47 Ralf Corsepius Add preinstall.am 4.104.114.84.95
(edit) @4ba5ac6   03/16/06 17:41:28 Ralf Corsepius New (Submission by Bruce Robinson <brucer@…>). 4.104.114.84.95
(edit) @c6254224   03/16/06 17:36:21 Ralf Corsepius Add preinstall.am 4.104.114.84.95
(edit) @991f9022   03/16/06 17:35:34 Ralf Corsepius New. 4.104.114.84.95
(edit) @15ebdf1f   03/16/06 17:34:05 Ralf Corsepius New (Submission by Bruce Robinson <brucer@…>) 4.104.114.84.95
(edit) @128f3d0   03/16/06 17:29:44 Ralf Corsepius New. 4.104.114.84.95
(edit) @7283768   03/16/06 17:18:20 Ralf Corsepius New (Submission by Bruce Robinson <brucer@…>). 4.104.114.84.95
(edit) @3a14c7b   03/16/06 11:22:00 Ralf Corsepius 2006-03-16 Ralf Corsepius <ralf.corsepius@…> * README: … 4.104.114.84.95
(edit) @b5e0694   03/16/06 11:20:59 Ralf Corsepius 2006-03-16 Ralf Corsepius <ralf.corsepius@…> * acinclude.m4: … 4.104.114.84.95
(edit) @1a24742e   03/16/06 11:18:43 Ralf Corsepius Remove (abandoned). 4.104.114.84.95
(edit) @bd86290d   03/08/06 18:51:44 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @7c11146a   03/08/06 18:51:26 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @e46416d   03/08/06 18:51:21 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @84138c1   03/08/06 18:51:12 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @4ba9e20   03/08/06 18:50:56 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @bb1626a   03/08/06 18:49:09 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @c8e821cd   03/08/06 18:49:05 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @d5ed9e1   03/07/06 22:05:22 Joel Sherrill 2006-03-07 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
(edit) @ab8394f6   03/07/06 21:07:25 Joel Sherrill Add PRs. 4.104.114.84.95
(edit) @75bf564   03/07/06 21:05:28 Joel Sherrill 2006-03-07 Lars Munch <lars@…> * at91rm9200/clock/clock.c: The … 4.104.114.84.95
(edit) @7f7298c4   02/23/06 21:05:16 WENorum Changes from Daron Chabot 4.104.114.84.95
(edit) @902a417   02/14/06 03:02:47 strauman 2006-02-13 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @0fc5b85   02/08/06 22:28:32 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @6dbe4d6   02/08/06 17:59:35 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * clock/clockdrv.c: … 4.104.114.84.95
(edit) @4bbea13f   02/08/06 17:59:06 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @0564ff51   02/08/06 17:18:25 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @4217b96   02/08/06 12:28:38 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @350808f   02/08/06 12:28:11 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @869eaa9   02/08/06 12:28:03 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @ae3ab74   02/08/06 12:27:59 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @c177d27   02/08/06 12:27:45 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @6ffb898b   02/08/06 12:26:35 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @9a7474b   02/08/06 12:26:31 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @894fc7f   02/08/06 12:26:28 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds.dl: … 4.104.114.84.95
(edit) @ff167ec   02/08/06 12:25:24 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
