@a397c9c1
08/04/97 21:59:14 |
Joel Sherrill |
Corrected descent to a hardcoded directory and made it dependent on …
4.104.114.84.95
@8bc9051
08/04/97 21:58:30 |
Joel Sherrill |
Fixed typo and removed duplicated code
4.104.114.84.95
@4ef9e99
08/04/97 21:58:00 |
Joel Sherrill |
First attempt at values for PPC
4.104.114.84.95
@50b5f9d
08/04/97 21:57:06 |
Joel Sherrill |
Trying to support all models
4.104.114.84.95
@c74169bd
08/04/97 21:56:48 |
Joel Sherrill |
Trying to support all models.
4.104.114.84.95
@c9647b3
08/04/97 21:56:00 |
Joel Sherrill |
consolex built for all models.
4.104.114.84.95
@81d96577
08/04/97 21:55:30 |
Joel Sherrill |
moved header files into the motorola and zilog subdirectories
4.104.114.84.95
@669123e1
08/04/97 21:53:42 |
Joel Sherrill |
Correcting difference between mvme162lx and mvme162. All versions …
4.104.114.84.95
@02d0880
08/04/97 21:50:35 |
Joel Sherrill |
4.104.114.84.95
@033ec54
08/04/97 21:49:47 |
Joel Sherrill |
Modified to reflect changes in mc68681.h header file.
4.104.114.84.95
@b739617
08/04/97 21:45:27 |
Joel Sherrill |
Header files moved into zilog subdirectory.
4.104.114.84.95
@9b024884
08/04/97 21:44:05 |
Joel Sherrill |
Moved files into the zilog and motorola subdirectories.
4.104.114.84.95
@b61e6e1
08/04/97 21:43:36 |
Joel Sherrill |
Added GNAT configuration parameters.
4.104.114.84.95
@7510f18c
08/04/97 21:42:22 |
Joel Sherrill |
Added include/motorola and include/zilog directories to the
install …
4.104.114.84.95
@28a4b1d
08/04/97 21:39:07 |
Joel Sherrill |
moved from main include directory
4.104.114.84.95
@b2fed481
08/02/97 17:55:09 |
Joel Sherrill |
Added these files to contain bodies for routines included in the API …
4.104.114.84.95
@30e3029
08/01/97 20:58:10 |
Joel Sherrill |
Added conditional for KA9Q.
4.104.114.84.95
@1f581ec
08/01/97 20:57:21 |
Joel Sherrill |
Added include of termios.h which was accidentally left out.
4.104.114.84.95
@bcbd75d4
08/01/97 20:56:36 |
Joel Sherrill |
Added consolex to wrapup
4.104.114.84.95
@a7fcfd0
08/01/97 20:56:24 |
Joel Sherrill |
Corrected typo.
4.104.114.84.95
@adf7b5c4
08/01/97 20:15:02 |
Joel Sherrill |
Made to work.
4.104.114.84.95
@29a9e5d
08/01/97 20:14:57 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@9deb5b8b
08/01/97 18:12:11 |
Joel Sherrill |
Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. …
4.104.114.84.95
@0074691a
07/31/97 22:13:29 |
Joel Sherrill |
Merged very large and much appreciated patch from Chris Johns …
4.104.114.84.95
@91333c2
07/31/97 22:04:17 |
Joel Sherrill |
4.104.114.84.95
@13f09e6
07/31/97 19:48:23 |
Joel Sherrill |
Added support for rtems_message_queue_get_number_pending.
4.104.114.84.95
@e7d8b58
07/31/97 19:01:42 |
Joel Sherrill |
Added rtems_message_queue_get_number_pending directive.
4.104.114.84.95
@a2fa8c25
07/31/97 19:01:05 |
Joel Sherrill |
Added comment to indicate what the commented out C_PIECES indicated.
4.104.114.84.95
@e24e9b5
07/18/97 15:05:05 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@bb566a02
07/10/97 20:24:00 |
Joel Sherrill |
Reordered specs.
4.104.114.84.95
@0b172df9
07/10/97 20:23:27 |
Joel Sherrill |
fixed milliseconds and microseconds to tick conversion routines.
4.104.114.84.95
@bf3a7a5a
07/10/97 19:16:40 |
Joel Sherrill |
Added information on different MVME162 models.
4.104.114.84.95
@487c4f62
07/10/97 19:09:16 |
Joel Sherrill |
Strip the trace bit from the SR register when dispatching a thread …
4.104.114.84.95
@900a3ab1
07/09/97 23:57:56 |
Joel Sherrill |
Repository damaged -- file re-added
4.104.114.84.95
@eb14a2ff
07/09/97 23:55:39 |
Joel Sherrill |
Repository damaged -- files readded.
4.104.114.84.95
@a14d2af
07/09/97 23:52:08 |
Joel Sherrill |
Changed name from entry to thread_entry to be more compatible with
Ada …
4.104.114.84.95
@db17316
07/09/97 23:51:21 |
Joel Sherrill |
Used macro instead of hard coded number.
4.104.114.84.95
@2a02b0a
07/09/97 23:50:45 |
Joel Sherrill |
Added postswitch extension.
4.104.114.84.95
@b5fc21c
07/09/97 23:50:28 |
Joel Sherrill |
Added post switch extension.
4.104.114.84.95
@2c5d78b
07/09/97 23:46:59 |
Joel Sherrill |
Corrected typos and spacing.
4.104.114.84.95
@1d320bac
07/09/97 23:41:20 |
Joel Sherrill |
This code was in the tree but not actually being compiled. There
were …
4.104.114.84.95
@8fabc273
07/09/97 23:33:08 |
Joel Sherrill |
Added sp, sfc, and fpcsr register defines.
4.104.114.84.95
@e7f86ef
06/04/97 18:54:18 |
Joel Sherrill |
new file
4.104.114.84.95
@b42675f
06/03/97 23:04:25 |
Joel Sherrill |
corrected name of test suite
4.104.114.84.95
@1e97a20
06/03/97 23:00:45 |
Joel Sherrill |
fixed comment
4.104.114.84.95
@9b3853a
06/03/97 22:58:48 |
Joel Sherrill |
Removed configuration information.
4.104.114.84.95
@430d81a
06/03/97 22:57:58 |
Joel Sherrill |
new file
4.104.114.84.95
@08c192b
06/03/97 22:54:45 |
Joel Sherrill |
Removed Configuration Information.
4.104.114.84.95
@8640cc99
06/03/97 22:52:39 |
Joel Sherrill |
new files.
4.104.114.84.95
@4fd88bc
06/03/97 22:52:34 |
Joel Sherrill |
4.104.114.84.95
@5d0f4a56
06/03/97 22:49:47 |
Joel Sherrill |
new files
4.104.114.84.95
@7c498800
06/03/97 22:49:19 |
Joel Sherrill |
new file.
4.104.114.84.95
@8ed37e3c
06/03/97 22:47:47 |
Joel Sherrill |
corrected to compile with the new binding.
4.104.114.84.95
@1b141533
06/03/97 22:40:57 |
Joel Sherrill |
Corrected for this test.
4.104.114.84.95
@2bef691
06/03/97 22:39:55 |
Joel Sherrill |
Added correct contents
4.104.114.84.95
@5363249
06/03/97 22:38:10 |
Joel Sherrill |
new file
4.104.114.84.95
@2ef9d4a
06/03/97 22:22:52 |
Joel Sherrill |
Corrected maximum number of messages to be non-zero
4.104.114.84.95
@6e98a517
06/03/97 22:21:18 |
Joel Sherrill |
removed reference to Stub Device Driver
4.104.114.84.95
@f94917d7
06/03/97 22:18:54 |
Joel Sherrill |
Replaced prototype for Last_Task which was accidentally removed when …
4.104.114.84.95
@46063740
06/03/97 22:16:25 |
Joel Sherrill |
Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems.
4.104.114.84.95
@e3b4ccd
06/03/97 22:11:55 |
Joel Sherrill |
Fixed incorrect invocation of Message_Queue_Create
4.104.114.84.95
@79e0b6fd
06/03/97 22:10:18 |
Joel Sherrill |
fixed typo which resulted in Message_Queue_Create being invoked …
4.104.114.84.95
@688ecaa0
06/03/97 22:08:59 |
Joel Sherrill |
Fixed calls to Message_Queue_Create to include maximum message size …
4.104.114.84.95
@e17ffea
06/03/97 22:06:49 |
Joel Sherrill |
Changed to variable length messages.
4.104.114.84.95
@bc35a6ef
06/03/97 21:48:57 |
Joel Sherrill |
Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0.
4.104.114.84.95
@1338cdb
06/03/97 21:46:18 |
Joel Sherrill |
Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0.
4.104.114.84.95
@c7f646b5
06/03/97 21:43:20 |
Joel Sherrill |
Fixed all references to Semaphore_Create to have the correct
argument …
4.104.114.84.95
@9db72b4
06/03/97 21:39:35 |
Joel Sherrill |
New file.
4.104.114.84.95
@4b067069
06/03/97 21:27:16 |
Joel Sherrill |
new file
4.104.114.84.95
@b4be04e
06/03/97 20:24:11 |
Joel Sherrill |
Removed Configuration Table information.
4.104.114.84.95
@7b93a327
06/03/97 20:20:39 |
Joel Sherrill |
Corrected call to Semaphore_Create to have the proper calling sequence
4.104.114.84.95
@b67e6ec
06/03/97 20:20:23 |
Joel Sherrill |
4.104.114.84.95
@43437e97
06/03/97 20:20:10 |
Joel Sherrill |
new file
4.104.114.84.95
@f222e9d4
06/03/97 19:26:36 |
Joel Sherrill |
Removed unnecessary dependency on RTEMS_Test_Support which existed
in …
4.104.114.84.95
@a1ceec8
06/03/97 19:25:56 |
Joel Sherrill |
new file
4.104.114.84.95
@be1618a
06/03/97 19:21:25 |
Joel Sherrill |
removed reference to the Stub Device Driver
4.104.114.84.95
@d6a9988
06/03/97 19:18:15 |
Joel Sherrill |
Changed mode and priority of initialization task.
4.104.114.84.95
@5687a1e9
06/03/97 18:38:58 |
Joel Sherrill |
Changed attribute of Initialization Task to Floating_Point
4.104.114.84.95
@ac953f2
06/03/97 18:38:40 |
Joel Sherrill |
new files
4.104.114.84.95
@dc300df
06/03/97 18:37:40 |
Joel Sherrill |
new file
4.104.114.84.95
@82870ab
06/03/97 18:28:38 |
Joel Sherrill |
new file
4.104.114.84.95
@91c78ffd
06/03/97 18:28:23 |
Joel Sherrill |
Changed from RTEMS.Boolean to Standard.Boolean to avoid problems.
4.104.114.84.95
@93bd518
06/03/97 18:07:51 |
Joel Sherrill |
new files
4.104.114.84.95
@6666ea88
06/03/97 18:07:30 |
Joel Sherrill |
Added True and False constants for RTEMS.Boolean types. This …
4.104.114.84.95
@9bec37b
06/03/97 18:06:46 |
Joel Sherrill |
Switched to proper types for booleans and increased the stack space …
4.104.114.84.95
@87e951a2
06/03/97 16:04:00 |
Joel Sherrill |
Added RTEMS boolean constants.
4.104.114.84.95
@a7156d1
06/03/97 16:00:00 |
Joel Sherrill |
Modifed to make the test run to completion. Primarily provided
the …
4.104.114.84.95
@98150020
06/03/97 15:40:24 |
Joel Sherrill |
Commented out exception handling code since these routines are not …
4.104.114.84.95
@4db9c861
06/03/97 15:39:28 |
Joel Sherrill |
removed with of unchecked_conversion
4.104.114.84.95
@e351c26a
06/03/97 15:25:28 |
Joel Sherrill |
sptest.adb: update Semaphore_Create calling sequence
sp12.adb: …
4.104.114.84.95
@4c3340c
06/03/97 15:22:09 |
Joel Sherrill |
Added Pending_Events and lined up other event constants
4.104.114.84.95
@c1ef834
06/03/97 15:12:23 |
Joel Sherrill |
Fixed problems which prevented the test from compiling and running to …
4.104.114.84.95
@d348ad96
06/03/97 15:11:39 |
Joel Sherrill |
added more constants and fixed numer
4.104.114.84.95
@7d366f1c
06/03/97 00:56:11 |
Joel Sherrill |
changed reference for Configuration Table from BSP to RTEMS.
4.104.114.84.95
@a6b44a8a
06/03/97 00:55:42 |
Joel Sherrill |
added Signal constants, Is_Status_Successful, and Attribute constants.
4.104.114.84.95
@d0f426a1
06/03/97 00:34:04 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@7e3dcbc
06/03/97 00:33:48 |
Joel Sherrill |
added rtems_interrupt_level_attribute routien to return a properly …
4.104.114.84.95
@e56a2ef
06/03/97 00:32:50 |
Joel Sherrill |
updated to run
4.104.114.84.95
@f2078ec
06/03/97 00:13:05 |
Joel Sherrill |
New style main procedure which creates the test's RTEMS initialization …
4.104.114.84.95
@8e7b810
06/02/97 23:47:05 |
Joel Sherrill |
added subtract of 1 to Task_Number to account for the creation
of the …
4.104.114.84.95
