@96400050
03/26/18 07:04:43 |
Sebastian Huber |
bsp/pc386: Remove unused RTEMS_CPU_MODEL
This patch is a part of the …
5
@b1b7390
03/26/18 06:58:42 |
Sebastian Huber |
bsp/pc386: Fix build
This patch is a part of the BSP source …
5
@f17df94
03/26/18 07:14:16 |
Sebastian Huber |
build: configure.ac is a file
5
@d7fd3bc
03/23/18 16:33:45 |
Gedare Bloom |
sparc64: remove header file with duplicated macros
The boot/stack.h …
5
@b1d3b0f
03/23/18 02:46:49 |
Chris Johns |
libcpu: Only build if there is a valid configure.ac
5
@df8a31d
03/22/18 13:50:02 |
thomas.doerfler |
bsp/tqm8xx: Fix network interface driver
5
@28a6bb8
03/22/18 05:36:11 |
Sebastian Huber |
mpci: Avoid use of RTEMS_RELLDFLAGS
5
@dc1ea01
03/22/18 05:27:31 |
Sebastian Huber |
bsps/mpc55xx: Move libcpu content to bsps
5
@3f3f246a
03/22/18 05:19:16 |
Sebastian Huber |
bsps/mpc55xx: Remove unused files
This patch is a part of the BSP …
5
@bb22a3f3
03/21/18 05:27:24 |
Sebastian Huber |
bsp/powerpc: Move libcpu timer to bsps
Use only one timer driver …
5
@f3a51d62
03/21/18 07:11:33 |
Sebastian Huber |
bsps/powerpc: Remove bsp_timer_internal_clock
The only consumer of …
5
@a7fa9e91
03/20/18 15:16:53 |
Sebastian Huber |
bsp/pc386: Move libcpu content to bsps
5
@5cf0656
03/20/18 13:14:39 |
Eric Tremblay |
bsps/powerpc: Support more than 256MiB of RAM
Close #3322.
5
@5d44981c
03/20/18 06:34:22 |
Sebastian Huber |
bsp/qoriq: Fix bsp_restart()
Update #3085.
5
@09dd82a5
03/13/18 15:43:25 |
Sebastian Huber |
bsp/ss555: Move libcpu content to bsps
5
@bd150801
03/13/18 15:24:16 |
Sebastian Huber |
bsps/powerpc: Move exceptions support to bsps
This patch is a part of …
5
@ff3b9aa
03/13/18 05:23:40 |
Sebastian Huber |
bsps/powerpc: Remove unused files
5
@7dbc43d
03/13/18 05:18:38 |
Sebastian Huber |
bsps/powerpc: Move basic support to bsps
5
@ac04bb85
03/12/18 15:42:16 |
Sebastian Huber |
bsps/powerpc: Move legacy IRQ support
5
@efa0039e
03/13/18 16:14:15 |
amaan.cheval |
i386/smp: Export _CPU_SMP_Prepare_start_multitasking as a function
5
@51614c01
03/13/18 16:14:14 |
amaan.cheval |
i386/smp: Have ld use incremental build for appstart.o
With HAS_SMP …
5
@2e5cf7f
03/16/18 14:09:36 |
Sebastian Huber |
bsps/powerpc: Use shared linker command file
Close #3339.
5
@9860cc7
03/16/18 10:01:03 |
Sebastian Huber |
bsps/powerpc: Fix linker command files
Update #3339.
5
@0a7a30d
03/12/18 19:53:09 |
joel |
Add PowerPC paravirtualization support
Cannot read or write MSR when …
5
@71c5552f
03/12/18 15:43:28 |
christian.mauderer |
bsp/atsam: Allow setting the drive strength.
This adds a simple …
5
@7633f5b
03/12/18 05:59:15 |
Sebastian Huber |
sparc64: Move libcpu content to cpukit
5
@8b5778e
03/12/18 05:37:36 |
Sebastian Huber |
sparc: Move libcpu content to cpukit
5
@c4905d8d
03/10/18 09:17:35 |
Sebastian Huber |
bsps/arm: Move libcpu content to bsps
5
@b6755af
03/09/18 15:45:56 |
Sebastian Huber |
bsps/mips: Move libcpu content to bsps
5
@961e2ef
03/12/18 05:23:08 |
Sebastian Huber |
bsps/mips: Remove Mongoose-V README
5
@4c83f292
03/12/18 07:16:17 |
Sebastian Huber |
bsps: Remove unused RTEMS_CPU_MODEL
5
@a4570829
03/09/18 15:22:25 |
Sebastian Huber |
bsps: Remove unused memcpy() implementations
5
@0706581
03/07/18 20:31:31 |
joel |
misc sh: Remove includes of rtems/score/types.h
5
@d39cc068
03/07/18 05:37:55 |
Sebastian Huber |
bsps: More verbose bsp_fatal_extension()
Close #3318.
5
@befae6ab
03/07/18 09:32:42 |
Sebastian Huber |
bsp/genmcf548x: Fix printk() support
5
@d440a9e
03/07/18 09:32:09 |
Sebastian Huber |
bsps/m68k: Fix entry point in linkcmds.base
Updates #3520.
5
@4899759
03/06/18 06:23:07 |
Thanassis.Tsiodras |
bsps/sparc: Fix global construction/destruction
The
KEEP …
5
@40c623a8
09/21/17 20:20:29 |
joel |
powerpc/shared/startup/linkcmds.base: Add wildcards on some sections
5
@6878519
02/06/18 15:28:28 |
bsp/atsam: Fix cache / DMA handling in SPI.
This patch fixes the …
5
@538a0a8
02/02/18 06:06:16 |
bsp/atsam: Allow to use a decoder for SPI CS.
The SPI controller …
5
@03fecae
01/11/18 07:54:27 |
Christian.Mauderer |
bsp/atsam: Add option to disable 32kHz XTAL.
5
@ea7f4a0c
01/30/18 23:25:20 |
joel |
sparc/*/linkcmds*: Move ENTRY() from linkcmds.base to top linkcmds
5
@3454179
02/05/18 12:54:48 |
Sebastian Huber |
bsp/altera-cyclone-v: Add device tree support
Update #3290.
5
@0f4a7391
02/05/18 10:45:17 |
Sebastian Huber |
bsps/powerpc: Remove support for mpc505
Close #3270.
5
@5f0a6376
02/01/18 08:39:14 |
Sebastian Huber |
bsp/leon3: Do not use internal cache API
Update #3285.
5
@4cf93658
01/27/18 13:37:51 |
Sebastian Huber |
bsps: Rework cache manager implementation
The previous cache manager …
5
@d8d6a08
01/27/18 10:12:44 |
Sebastian Huber |
bsps: Move network define to source files
Define …
5
@9819425
01/31/18 07:02:21 |
Sebastian Huber |
epiphany: Fixes for GCC 7.3
GCC 7.3 defines USER_LABEL_PREFIX to …
5
@865b3027
01/29/18 12:53:13 |
Sebastian Huber |
Avoid Newlib-specific _EXFUN()
5
@2afb22b
12/23/17 07:18:56 |
Chris Johns |
Remove make preinstall
A speciality of the RTEMS build system was the …
5
@469fdeb
01/23/18 06:28:51 |
Sebastian Huber |
bsp/qoriq: Fix define for optional intercom
Update #3085.
5
@e79bb0c3
01/22/18 12:15:56 |
Sebastian Huber |
bsp/gen5200: Use public include path
Update #3254.
5
@b391fbc6
01/17/18 08:39:16 |
Sebastian Huber |
bsp/qoriq: Fix hypervisor guest interrupt init
Update #3085.
5
@2fd684e
01/16/18 10:42:34 |
Sebastian Huber |
bsp/qoriq: Fix hypervisor guest irq vector max
Update #3085.
5
@0df59b7c
01/16/18 10:40:17 |
Sebastian Huber |
bsp/qoriq: Optional multiprocessing support
Update #3085.
5
@44ba969
01/15/18 12:56:12 |
Sebastian Huber |
bsp/qoriq: Fix hypervisor guest polled console
Update #3085.
5
@2f54488f
01/15/18 12:55:41 |
Sebastian Huber |
bsp/qoriq: Fix hypervisor guest IRQ support
Update #3085.
5
@81eced53
01/15/18 12:54:45 |
Sebastian Huber |
bsp/qoriq: Fix bsp_fdt_map_intr()
Update #3085.
5
@9ec5ff4e
01/09/18 09:09:57 |
Sebastian Huber |
bsp/qoriq: Fix hypervisor guest MMU config
Account for DPAA resources …
5
@17fd0ff
01/12/18 06:56:42 |
Sebastian Huber |
bsps: Move wd80x3.h to libchip/wd80x3.h
This header is used also by …
5
@d898f6e
01/19/18 14:28:33 |
Sebastian Huber |
bsp/gen5200: Fix i2c.h and i2cdrv.h installation
Install these files …
5
@0a49929
01/18/18 12:13:10 |
Sebastian Huber |
bsp/leon3: Fix interrupt timestamp timecounter
5
@ac0e0208
01/17/18 16:46:17 |
joel |
leon3: Simplify bsp_specs
Updates #3520.
5
@85b59a57
01/17/18 16:46:16 |
joel |
leon2: Simplify bsp_specs
Updates #3520.
5
@ca188aa6
01/17/18 16:46:15 |
joel |
sparc/erc32: Simplify bsp_specs
Updates #3520.
5
@9d68284
01/17/18 16:46:14 |
joel |
qemuppc: Simplify bsp_specs
Updates #3520.
5
@47cc206
01/16/18 06:05:39 |
Sebastian Huber |
bsps/powerpc: Move BSP specific file to BSP
Update #3254.
5
@e806b731
01/12/18 09:09:53 |
Chris Johns |
bsps/arm: Add header guard, fix defines
5
@c883bc9
01/12/18 09:09:01 |
Sebastian Huber |
bsps/m68k: Fix CACR register defines
5
@5b94266
01/12/18 09:02:37 |
Chris Johns |
bsps: Fix redefine warning
5
@3f5d4e95
01/10/18 06:48:49 |
Sebastian Huber |
bsp/mvme167: Fix warnings
5
@0d08844
01/12/18 06:32:06 |
Sebastian Huber |
bsps: Add AM_CPPFLAGS to special case CPPFLAGS
This is necessary to …
5
@4b12436
01/12/18 06:31:40 |
Sebastian Huber |
libchip: Use public include path
Update #3254.
5
@a67f44c
01/12/18 06:25:01 |
Sebastian Huber |
bsps/lm32: Do not include network headers in bsp.h
Update #3254.
5
@0178f9d
01/05/18 13:23:09 |
Sebastian Huber |
bsp/gen5200: Fix linker command file
Updates #3520.
5
@7cd389e
01/04/18 08:31:47 |
Sebastian Huber |
bsps/m68k: Install shared <mvme16x_hw.h>
Update #3254.
5
@a7b0da2
01/04/18 08:06:57 |
Chris Johns |
bsps/mips: Fix AC_CONFIG_SRCDIR()
Update #3254.
5
@816f999f
01/04/18 08:06:20 |
Chris Johns |
bsps/i386: Fix AC_CONFIG_SRCDIR()
Update #3254.
5
@8428b40
01/04/18 07:59:34 |
Chris Johns |
bsp/edb7312: Use public include path
Update #3254.
5
@f4dc9737
01/04/18 07:58:51 |
Chris Johns |
bsps: Use public include path
Update #3254.
5
@26ac19c
01/04/18 07:58:23 |
Chris Johns |
bsps/powerpc: Use public include path
Update #3254.
5
@731abf4
01/04/18 07:57:58 |
Chris Johns |
bsp/mvme3100: Use public include path
Update #3254.
5
@3964329
01/04/18 07:57:18 |
Chris Johns |
bsp/beatnik: Use public include path
Update #3254.
5
@9dd2fdb9
01/04/18 07:55:19 |
Chris Johns |
bsps/bfin: Use public include path
Update #3254.
5
@010bf86
01/04/18 07:54:29 |
Chris Johns |
Update #3254.
5
@e2cf289
01/04/18 07:53:45 |
Chris Johns |
bsp/mcf548x: Use public include path
Update #3254.
5
@230acc55
01/04/18 07:52:26 |
Chris Johns |
Update #3254.
5
@caeaae26
01/04/18 07:50:56 |
Chris Johns |
Update #3254.
5
@9c91520
01/04/18 07:41:45 |
Chris Johns |
bsps/lm32: Use public include path
Update #3254.
5
@1efd148b
01/04/18 07:39:40 |
Chris Johns |
bsp/pc386: Use public include path
Update #3254.
5
@3eed4f3
01/04/18 07:10:48 |
Chris Johns |
bsp/altera-cyclone-v: Use public include path
Update #3254.
5
@6897cb1
12/28/17 12:21:14 |
Chris Johns |
5
@f636e91a
01/04/18 07:29:38 |
Sebastian Huber |
bsp/pc386: Do not install console_private.h
The name suggests that …
5
@6494f7d
01/03/18 08:17:02 |
Sebastian Huber |
bsps/powerpc: Remove unused RTEMS_CPU_MODEL
5
@375e923d
01/03/18 08:08:59 |
Sebastian Huber |
bsps/powerpc: Rename BSP specific linkcmds.base
Avoid name conflicts …
5
@fb01816b
01/03/18 06:39:16 |
Sebastian Huber |
bsps/powerpc: Move shared irq.h
This header file is only used by …
5
@569fd50
01/02/18 10:56:36 |
Sebastian Huber |
sparc: Remove BSP specifics from <pci/irq.h>
Update #3254.
Update …
5
@7190005
01/02/18 10:42:48 |
Sebastian Huber |
sparc: Move <libcpu/byteorder.h>
Update #3254.
Update #3260.
5
@e1c0d67
01/02/18 10:20:07 |
Sebastian Huber |
bsp/mpc55xxevb: Move <bsp/irq.h>
Update #3254.
Update #3268.
5
@ec32100
01/02/18 06:37:44 |
Sebastian Huber |
bsps: Use CPPASCOMPILE for startfile
Update #3254.
5
