Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @89a32784   08/04/97 22:12:39 Joel Sherrill Fixed type 4.104.114.84.95
(edit) @3dd8372   08/04/97 22:03:03 Joel Sherrill Corrected typo 4.104.114.84.95
(edit) @a397c9c1   08/04/97 21:59:14 Joel Sherrill Corrected descent to a hardcoded directory and made it dependent on … 4.104.114.84.95
(edit) @8bc9051   08/04/97 21:58:30 Joel Sherrill Fixed typo and removed duplicated code 4.104.114.84.95
(edit) @4ef9e99   08/04/97 21:58:00 Joel Sherrill First attempt at values for PPC 4.104.114.84.95
(edit) @50b5f9d   08/04/97 21:57:06 Joel Sherrill Trying to support all models 4.104.114.84.95
(edit) @c74169bd   08/04/97 21:56:48 Joel Sherrill Trying to support all models. 4.104.114.84.95
(edit) @c9647b3   08/04/97 21:56:00 Joel Sherrill consolex built for all models. 4.104.114.84.95
(edit) @81d96577   08/04/97 21:55:30 Joel Sherrill moved header files into the motorola and zilog subdirectories 4.104.114.84.95
(edit) @669123e1   08/04/97 21:53:42 Joel Sherrill Correcting difference between mvme162lx and mvme162. All versions … 4.104.114.84.95
(edit) @02d0880   08/04/97 21:50:35 Joel Sherrill moved header files into the motorola and zilog subdirectories 4.104.114.84.95
(edit) @033ec54   08/04/97 21:49:47 Joel Sherrill Modified to reflect changes in mc68681.h header file. 4.104.114.84.95
(edit) @b739617   08/04/97 21:45:27 Joel Sherrill Header files moved into zilog subdirectory. 4.104.114.84.95
(edit) @9b024884   08/04/97 21:44:05 Joel Sherrill Moved files into the zilog and motorola subdirectories. 4.104.114.84.95
(edit) @b61e6e1   08/04/97 21:43:36 Joel Sherrill Added GNAT configuration parameters. 4.104.114.84.95
(edit) @7510f18c   08/04/97 21:42:22 Joel Sherrill Added include/motorola and include/zilog directories to the install … 4.104.114.84.95
(edit) @28a4b1d   08/04/97 21:39:07 Joel Sherrill moved from main include directory 4.104.114.84.95
(edit) @b2fed481   08/02/97 17:55:09 Joel Sherrill Added these files to contain bodies for routines included in the API … 4.104.114.84.95
(edit) @30e3029   08/01/97 20:58:10 Joel Sherrill Added conditional for KA9Q. 4.104.114.84.95
(edit) @1f581ec   08/01/97 20:57:21 Joel Sherrill Added include of termios.h which was accidentally left out. 4.104.114.84.95
(edit) @bcbd75d4   08/01/97 20:56:36 Joel Sherrill Added consolex to wrapup 4.104.114.84.95
(edit) @a7fcfd0   08/01/97 20:56:24 Joel Sherrill Corrected typo. 4.104.114.84.95
(edit) @adf7b5c4   08/01/97 20:15:02 Joel Sherrill Made to work. 4.104.114.84.95
(edit) @29a9e5d   08/01/97 20:14:57 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @9deb5b8b   08/01/97 18:12:11 Joel Sherrill Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. … 4.104.114.84.95
(edit) @0074691a   07/31/97 22:13:29 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @91333c2   07/31/97 22:04:17 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @13f09e6   07/31/97 19:48:23 Joel Sherrill Added support for rtems_message_queue_get_number_pending. 4.104.114.84.95
(edit) @e7d8b58   07/31/97 19:01:42 Joel Sherrill Added rtems_message_queue_get_number_pending directive. 4.104.114.84.95
(edit) @a2fa8c25   07/31/97 19:01:05 Joel Sherrill Added comment to indicate what the commented out C_PIECES indicated. 4.104.114.84.95
(edit) @e24e9b5   07/18/97 15:05:05 Joel Sherrill fixed typo 4.104.114.84.95
(edit) @bb566a02   07/10/97 20:24:00 Joel Sherrill Reordered specs. 4.104.114.84.95
(edit) @0b172df9   07/10/97 20:23:27 Joel Sherrill fixed milliseconds and microseconds to tick conversion routines. 4.104.114.84.95
(edit) @bf3a7a5a   07/10/97 19:16:40 Joel Sherrill Added information on different MVME162 models. 4.104.114.84.95
(edit) @487c4f62   07/10/97 19:09:16 Joel Sherrill Strip the trace bit from the SR register when dispatching a thread … 4.104.114.84.95
(edit) @900a3ab1   07/09/97 23:57:56 Joel Sherrill Repository damaged -- file re-added 4.104.114.84.95
(edit) @eb14a2ff   07/09/97 23:55:39 Joel Sherrill Repository damaged -- files readded. 4.104.114.84.95
(edit) @a14d2af   07/09/97 23:52:08 Joel Sherrill Changed name from entry to thread_entry to be more compatible with Ada … 4.104.114.84.95
(edit) @db17316   07/09/97 23:51:21 Joel Sherrill Used macro instead of hard coded number. 4.104.114.84.95
(edit) @2a02b0a   07/09/97 23:50:45 Joel Sherrill Added postswitch extension. 4.104.114.84.95
(edit) @b5fc21c   07/09/97 23:50:28 Joel Sherrill Added post switch extension. 4.104.114.84.95
(edit) @2c5d78b   07/09/97 23:46:59 Joel Sherrill Corrected typos and spacing. 4.104.114.84.95
(edit) @1d320bac   07/09/97 23:41:20 Joel Sherrill This code was in the tree but not actually being compiled. There were … 4.104.114.84.95
(edit) @8fabc273   07/09/97 23:33:08 Joel Sherrill Added sp, sfc, and fpcsr register defines. 4.104.114.84.95
(edit) @e7f86ef   06/04/97 18:54:18 Joel Sherrill new file 4.104.114.84.95
(edit) @b42675f   06/03/97 23:04:25 Joel Sherrill corrected name of test suite 4.104.114.84.95
(edit) @1e97a20   06/03/97 23:00:45 Joel Sherrill fixed comment 4.104.114.84.95
(edit) @9b3853a   06/03/97 22:58:48 Joel Sherrill Removed configuration information. 4.104.114.84.95
(edit) @430d81a   06/03/97 22:57:58 Joel Sherrill new file 4.104.114.84.95
(edit) @08c192b   06/03/97 22:54:45 Joel Sherrill Removed Configuration Information. 4.104.114.84.95
(edit) @8640cc99   06/03/97 22:52:39 Joel Sherrill new files. 4.104.114.84.95
(edit) @4fd88bc   06/03/97 22:52:34 Joel Sherrill Removed configuration information. 4.104.114.84.95
(edit) @5d0f4a56   06/03/97 22:49:47 Joel Sherrill new files 4.104.114.84.95
(edit) @7c498800   06/03/97 22:49:19 Joel Sherrill new file. 4.104.114.84.95
(edit) @8ed37e3c   06/03/97 22:47:47 Joel Sherrill corrected to compile with the new binding. 4.104.114.84.95
(edit) @1b141533   06/03/97 22:40:57 Joel Sherrill Corrected for this test. 4.104.114.84.95
(edit) @2bef691   06/03/97 22:39:55 Joel Sherrill Added correct contents 4.104.114.84.95
(edit) @5363249   06/03/97 22:38:10 Joel Sherrill new file 4.104.114.84.95
(edit) @2ef9d4a   06/03/97 22:22:52 Joel Sherrill Corrected maximum number of messages to be non-zero 4.104.114.84.95
(edit) @6e98a517   06/03/97 22:21:18 Joel Sherrill removed reference to Stub Device Driver 4.104.114.84.95
(edit) @f94917d7   06/03/97 22:18:54 Joel Sherrill Replaced prototype for Last_Task which was accidentally removed when … 4.104.114.84.95
(edit) @46063740   06/03/97 22:16:25 Joel Sherrill Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems. 4.104.114.84.95
(edit) @e3b4ccd   06/03/97 22:11:55 Joel Sherrill Fixed incorrect invocation of Message_Queue_Create 4.104.114.84.95
(edit) @79e0b6fd   06/03/97 22:10:18 Joel Sherrill fixed typo which resulted in Message_Queue_Create being invoked … 4.104.114.84.95
(edit) @688ecaa0   06/03/97 22:08:59 Joel Sherrill Fixed calls to Message_Queue_Create to include maximum message size … 4.104.114.84.95
(edit) @e17ffea   06/03/97 22:06:49 Joel Sherrill Changed to variable length messages. 4.104.114.84.95
(edit) @bc35a6ef   06/03/97 21:48:57 Joel Sherrill Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. 4.104.114.84.95
(edit) @1338cdb   06/03/97 21:46:18 Joel Sherrill Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0. 4.104.114.84.95
(edit) @c7f646b5   06/03/97 21:43:20 Joel Sherrill Fixed all references to Semaphore_Create to have the correct argument … 4.104.114.84.95
(edit) @9db72b4   06/03/97 21:39:35 Joel Sherrill New file. 4.104.114.84.95
(edit) @4b067069   06/03/97 21:27:16 Joel Sherrill new file 4.104.114.84.95
(edit) @b4be04e   06/03/97 20:24:11 Joel Sherrill Removed Configuration Table information. 4.104.114.84.95
(edit) @7b93a327   06/03/97 20:20:39 Joel Sherrill Corrected call to Semaphore_Create to have the proper calling sequence 4.104.114.84.95
(edit) @b67e6ec   06/03/97 20:20:23 Joel Sherrill Removed Configuration Table information 4.104.114.84.95
(edit) @43437e97   06/03/97 20:20:10 Joel Sherrill new file 4.104.114.84.95
(edit) @f222e9d4   06/03/97 19:26:36 Joel Sherrill Removed unnecessary dependency on RTEMS_Test_Support which existed in … 4.104.114.84.95
(edit) @a1ceec8   06/03/97 19:25:56 Joel Sherrill new file 4.104.114.84.95
(edit) @be1618a   06/03/97 19:21:25 Joel Sherrill removed reference to the Stub Device Driver 4.104.114.84.95
(edit) @d6a9988   06/03/97 19:18:15 Joel Sherrill Changed mode and priority of initialization task. 4.104.114.84.95
(edit) @5687a1e9   06/03/97 18:38:58 Joel Sherrill Changed attribute of Initialization Task to Floating_Point 4.104.114.84.95
(edit) @ac953f2   06/03/97 18:38:40 Joel Sherrill new files 4.104.114.84.95
(edit) @dc300df   06/03/97 18:37:40 Joel Sherrill new file 4.104.114.84.95
(edit) @82870ab   06/03/97 18:28:38 Joel Sherrill new file 4.104.114.84.95
(edit) @91c78ffd   06/03/97 18:28:23 Joel Sherrill Changed from RTEMS.Boolean to Standard.Boolean to avoid problems. 4.104.114.84.95
(edit) @93bd518   06/03/97 18:07:51 Joel Sherrill new files 4.104.114.84.95
(edit) @6666ea88   06/03/97 18:07:30 Joel Sherrill Added True and False constants for RTEMS.Boolean types. This … 4.104.114.84.95
(edit) @9bec37b   06/03/97 18:06:46 Joel Sherrill Switched to proper types for booleans and increased the stack space … 4.104.114.84.95
(edit) @87e951a2   06/03/97 16:04:00 Joel Sherrill Added RTEMS boolean constants. 4.104.114.84.95
(edit) @a7156d1   06/03/97 16:00:00 Joel Sherrill Modifed to make the test run to completion. Primarily provided the … 4.104.114.84.95
(edit) @98150020   06/03/97 15:40:24 Joel Sherrill Commented out exception handling code since these routines are not … 4.104.114.84.95
(edit) @4db9c861   06/03/97 15:39:28 Joel Sherrill removed with of unchecked_conversion 4.104.114.84.95
(edit) @e351c26a   06/03/97 15:25:28 Joel Sherrill sptest.adb: update Semaphore_Create calling sequence sp12.adb: … 4.104.114.84.95
(edit) @4c3340c   06/03/97 15:22:09 Joel Sherrill Added Pending_Events and lined up other event constants 4.104.114.84.95
(edit) @c1ef834   06/03/97 15:12:23 Joel Sherrill Fixed problems which prevented the test from compiling and running to … 4.104.114.84.95
(edit) @d348ad96   06/03/97 15:11:39 Joel Sherrill added more constants and fixed numer 4.104.114.84.95
(edit) @7d366f1c   06/03/97 00:56:11 Joel Sherrill changed reference for Configuration Table from BSP to RTEMS. 4.104.114.84.95
(edit) @a6b44a8a   06/03/97 00:55:42 Joel Sherrill added Signal constants, Is_Status_Successful, and Attribute constants. 4.104.114.84.95
(edit) @d0f426a1   06/03/97 00:34:04 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @7e3dcbc   06/03/97 00:33:48 Joel Sherrill added rtems_interrupt_level_attribute routien to return a properly … 4.104.114.84.95
(edit) @e56a2ef   06/03/97 00:32:50 Joel Sherrill updated to run 4.104.114.84.95
