source: rtems/c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @749c54e   07/25/98 17:22:58 Joel Sherrill Added comments and corrected spacing. 4.104.114.84.95
(edit) @cae0504   07/25/98 17:19:45 Joel Sherrill Corrected spacing and added headers. 4.104.114.84.95
(edit) @8739322   07/25/98 17:17:46 Joel Sherrill Added ns16550_set_attributes. 4.104.114.84.95
(edit) @b636d56   07/25/98 17:17:36 Joel Sherrill Corrected spacing and added a comment. 4.104.114.84.95
(edit) @ccfa60b   07/25/98 17:17:05 Joel Sherrill Updated to reflect set attributes. 4.104.114.84.95
(edit) @70a9451   07/25/98 16:53:21 Joel Sherrill Rewrote NS16550 TX interrupt processing to use termios for the buffer … 4.104.114.84.95
(edit) @adedb057   07/25/98 16:52:17 Joel Sherrill Removed TX ring buffer. 4.104.114.84.95
(edit) @cb27f05   07/25/98 16:52:00 Joel Sherrill Changed variable to hold received data to unsigned. 4.104.114.84.95
(edit) @dfb16ce   07/25/98 16:20:33 Joel Sherrill Added constants for z85c30_enable_interrupts. 4.104.114.84.95
(edit) @04c5ac7   07/25/98 16:20:14 Joel Sherrill Removed z85c30_flush(). Reworked transmit interrupt processing to … 4.104.114.84.95
(edit) @c1da250   07/25/98 16:18:46 Joel Sherrill Changed comment on TxBuffer?. 4.104.114.84.95
(edit) @b070d69a   07/25/98 16:18:27 Joel Sherrill Removed mc68681_flush and corrected spacing. 4.104.114.84.95
(edit) @f600da3f   07/25/98 16:17:33 Joel Sherrill Added information on Chris Johns' suggestion to use pointers … 4.104.114.84.95
(edit) @3d2c161   07/25/98 16:16:10 Joel Sherrill Removed "if 0" used to switch between serial ports. 4.104.114.84.95
(edit) @da8ac60a   07/25/98 16:02:21 Joel Sherrill New file. 4.104.114.84.95
(edit) @c68b990   07/25/98 14:51:57 Joel Sherrill Changed to utilize return status from … 4.104.114.84.95
(edit) @a3c9f0d   07/25/98 14:50:07 Joel Sherrill Moved console.c to libbsp/shared. 4.104.114.84.95
(edit) @f246caf   07/25/98 14:13:34 Joel Sherrill Interrupts were incorrectly managed with a disable/disable pair rather … 4.104.114.84.95
(edit) @bf21172   07/24/98 18:30:50 Joel Sherrill changed version to 980724 4.104.114.84.95
(edit) @03c0961   07/24/98 16:18:39 Joel Sherrill Patch from David Fiddes <D.J.Fiddes@…>: Here's a small … 4.104.114.84.95
(edit) @dbab462   07/24/98 16:09:51 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @1501809   07/23/98 22:13:46 Joel Sherrill changed version to 980723 4.104.114.84.95
(edit) @dbaf51a   07/23/98 22:13:10 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: Here is a patch … 4.104.114.84.95
(edit) @67a2288   07/23/98 22:02:34 Joel Sherrill Patch from Eric VALETTE <valette@…>: Here is a … 4.104.114.84.95
(edit) @73452854   07/23/98 20:04:55 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Here is a pure … 4.104.114.84.95
(edit) @c91e032   07/23/98 19:32:01 Joel Sherrill Removed consolex from build list. This file should be obsoleted by … 4.104.114.84.95
(edit) @92fc5a5d   07/21/98 13:59:12 Joel Sherrill Fix from Chris Johns <ccj@…>. Comments: Mask interrupts … 4.104.114.84.95
(edit) @bced36d   07/18/98 18:44:12 Joel Sherrill Changed so we could test interrupts on port 3. 4.104.114.84.95
(edit) @c14a619   07/18/98 18:35:34 Joel Sherrill Removed use of data port for z8530. Move some code around. 4.104.114.84.95
(edit) @3652929e   07/18/98 18:35:07 Joel Sherrill Removed use of data port for z8530. Tested all four ports. MC68681 … 4.104.114.84.95
(edit) @91f16d5   07/18/98 18:34:04 Joel Sherrill New file 4.104.114.84.95
(edit) @a4d34dd2   07/18/98 17:47:50 Joel Sherrill Added z85c30 specific probe routine to decide what the clock rate was. … 4.104.114.84.95
(edit) @f8a5d54e   07/18/98 17:46:33 Joel Sherrill Addresses for SCC were wrong. A and B ports were swapped. Deleted … 4.104.114.84.95
(edit) @c53e1df4   07/18/98 16:56:16 Joel Sherrill Swapped RX and TX since doing this makes the lights blink on the … 4.104.114.84.95
(edit) @fe05ec5e   07/18/98 16:11:13 Joel Sherrill Added RS-422 converter information and cable building information. 4.104.114.84.95
(edit) @cc3d33ac   07/18/98 15:34:03 Joel Sherrill Added information on the MC68681. 4.104.114.84.95
(edit) @f7d6e57   07/18/98 15:24:14 Joel Sherrill Added background and setup to add section on RS-422. 4.104.114.84.95
(edit) @f77670be   07/18/98 15:23:56 Joel Sherrill Reworked to removed dependency on DY-4 CSS ROM monitor interface. 4.104.114.84.95
(edit) @e286479   07/18/98 15:23:24 Joel Sherrill Removed css_iface. 4.104.114.84.95
(edit) @6d4062f   07/18/98 15:22:54 Joel Sherrill Removed. We are no longer dependent on DY-4 CSS interface code. 4.104.114.84.95
(edit) @cce1200e   07/18/98 15:19:28 Joel Sherrill New file. 4.104.114.84.95
(edit) @4555bc1e   07/17/98 22:34:54 Joel Sherrill Initialized tty->refcount to 0. When (for whatever reason) malloc() … 4.104.114.84.95
(edit) @f95d2b53   07/17/98 15:49:12 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>. Comments: * … 4.104.114.84.95
(edit) @8123c635   07/17/98 15:43:42 Joel Sherrill Added scitab directory. 4.104.114.84.95
(edit) @a56e475f   07/17/98 15:42:39 Joel Sherrill Turned stack checker on. 4.104.114.84.95
(edit) @bdba552f   07/17/98 15:19:04 Joel Sherrill Patch fromalf Corsepius <corsepiu@…>: * … 4.104.114.84.95
(edit) @fa21a843   07/17/98 15:17:29 Joel Sherrill New files from Ralf Corsepius <corsepiu@…>. His … 4.104.114.84.95
(edit) @6e65840   07/17/98 13:05:03 Joel Sherrill Patch from Dario Alcocer <alcocer@…>. His comments: … 4.104.114.84.95
(edit) @16d0e63   07/16/98 00:16:22 Joel Sherrill Corrected header files. 4.104.114.84.95
(edit) @a6f441b   07/16/98 00:16:11 Joel Sherrill Minor corrections for typos to get it to compile. 4.104.114.84.95
(edit) @dd5d2f04   07/16/98 00:03:01 Joel Sherrill Split default baud rate table into its own file. This shrinks the … 4.104.114.84.95
(edit) @4a11d8c   07/15/98 23:58:08 Joel Sherrill Fixed typo in which last port did not get switched to default register … 4.104.114.84.95
(edit) @849dc107   07/15/98 23:57:41 Joel Sherrill Fixed typos. 4.104.114.84.95
(edit) @670d037   07/15/98 23:55:04 Joel Sherrill Switched to usign the default z8530 and mc68681 register access routines. 4.104.114.84.95
(edit) @8414c033   07/15/98 23:54:24 Joel Sherrill Added default z85c30 register access routines. 4.104.114.84.95
(edit) @cce9322   07/15/98 23:54:08 Joel Sherrill Added default mc68681 register access routines. 4.104.114.84.95
(edit) @991a1ab4   07/15/98 23:21:55 Joel Sherrill Added check for proper deviceType to interrupt processing code. 4.104.114.84.95
(edit) @efaf85fa   07/15/98 23:21:30 Joel Sherrill Added interrupt mask and interrupt status register bit constants. … 4.104.114.84.95
(edit) @49370cd   07/15/98 23:20:50 Joel Sherrill Added default mc68681 register access routines. 4.104.114.84.95
(edit) @198d851   07/15/98 23:20:33 Joel Sherrill Switched from driver's own buffering to using termios. This … 4.104.114.84.95
(edit) @27a66bd   07/15/98 23:15:49 Joel Sherrill Added information on the deviceType field. 4.104.114.84.95
(edit) @66f95fc   07/15/98 23:15:32 Joel Sherrill Added default mc68681 register access routines. 4.104.114.84.95
(edit) @8a2e9c41   07/15/98 21:43:28 Joel Sherrill Added SCV64_Get_Interrupt_Enable(). Added proper headers to routines. 4.104.114.84.95
(edit) @d0cff6dc   07/15/98 21:43:00 Joel Sherrill Added SCV64_Get_Interrupt_Enable(). 4.104.114.84.95
(edit) @38e717f   07/15/98 21:42:26 Joel Sherrill Added chip type identifier field. This was necessary because a single … 4.104.114.84.95
(edit) @c0573d7   07/15/98 21:40:42 Joel Sherrill Added comment to remove use of TxBuffer? ring buffer in all libchip … 4.104.114.84.95
(edit) @0f61336   07/15/98 19:28:29 Joel Sherrill Added comments. 4.104.114.84.95
(edit) @a69f0ad9   07/15/98 19:20:20 Joel Sherrill Added comments. 4.104.114.84.95
(edit) @100a4e5   07/15/98 19:19:14 Joel Sherrill Masked out interrupts not being used prior to processing the status … 4.104.114.84.95
(edit) @6c45da17   07/15/98 19:12:11 Joel Sherrill Added routine to return interrupt mask. Added comments. 4.104.114.84.95
(edit) @01e54b8   07/15/98 14:06:37 Joel Sherrill Added scv64 subdirectory. 4.104.114.84.95
(edit) @e49ef37c   07/15/98 14:06:08 Joel Sherrill Switched to SCV64. 4.104.114.84.95
(edit) @8f563b9b   07/15/98 14:05:51 Joel Sherrill Added CSCV64 functions and addresses. 4.104.114.84.95
(edit) @30a3f76   07/15/98 14:04:31 Joel Sherrill Switched from polling to interrupts and in the process added a … 4.104.114.84.95
(edit) @437b5a7d   07/15/98 14:00:23 Joel Sherrill Added scv64 subdirectory. 4.104.114.84.95
(edit) @090a3511   07/15/98 14:00:09 Joel Sherrill New files. 4.104.114.84.95
(edit) @be8cbbf   07/15/98 13:58:23 Joel Sherrill Switched deviceOutputUsesInterrupts to TRUE so output would be … 4.104.114.84.95
(edit) @e283140c   07/15/98 13:53:58 Joel Sherrill Switched to "deviceOutput = TRUE" which made device output use interrupts. 4.104.114.84.95
(edit) @5b8c1b7   07/11/98 14:23:53 Joel Sherrill Yet another EXEEXT patch. This one is from Ralf Corsepius … 4.104.114.84.95
(edit) @3a447c3   07/10/98 19:05:20 Joel Sherrill changed version to 980710 4.104.114.84.95
(edit) @dbfa3148   07/10/98 15:43:18 Joel Sherrill Patch from Quality Quorum <qqi@…>. Comments: … 4.104.114.84.95
(edit) @cc8a388a   07/10/98 14:13:59 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>. Comments: > … 4.104.114.84.95
(edit) @fb32356b   07/09/98 23:32:07 Joel Sherrill Added set attributes routine but did not hook it in to the table. … 4.104.114.84.95
(edit) @abd8c82   07/09/98 23:31:48 Joel Sherrill Added new files. 4.104.114.84.95
(edit) @31cad72c   07/09/98 23:31:26 Joel Sherrill Renamed so we could have one file per routine. 4.104.114.84.95
(edit) @064b9be   07/09/98 23:30:32 Joel Sherrill Switched to shared default probe routine. 4.104.114.84.95
(edit) @693b5b88   07/09/98 23:30:02 Joel Sherrill Switched to default probe routine. 4.104.114.84.95
(edit) @61ff7ac8   07/09/98 23:29:33 Joel Sherrill Added new baud rate to number function and default serial probe … 4.104.114.84.95
(edit) @11c6a92d   07/09/98 22:59:32 Joel Sherrill Commented out the system call invocation since we don't know what … 4.104.114.84.95
(edit) @a6e36dff   07/09/98 22:59:13 Joel Sherrill Removed call back to exit() since that has already been called. 4.104.114.84.95
(edit) @e78c474b   07/09/98 22:21:54 Joel Sherrill Added proper handling of extended baud rate table selection at boot … 4.104.114.84.95
(edit) @2c5ea01   07/09/98 22:16:27 Joel Sherrill Properly handle extended baud rate set commands. Temporarily "if 0" … 4.104.114.84.95
(edit) @e3c59dd   07/09/98 22:11:49 Joel Sherrill Corrected definition of MC68681_RX_BUFFER. 4.104.114.84.95
(edit) @2ba0a0c2   07/09/98 18:50:13 Joel Sherrill Corrected z85c30 address and clock constants. 4.104.114.84.95
(edit) @459c1d2   07/09/98 18:49:49 Joel Sherrill Added board specific baud rate table and set driver function table to … 4.104.114.84.95
(edit) @2d8e51aa   07/09/98 18:45:28 Joel Sherrill Changed static to MC68681_STATIC to make all data and routines … 4.104.114.84.95
(edit) @b2ec38c8   07/09/98 18:44:10 Joel Sherrill Removed commented out line. 4.104.114.84.95
(edit) @8f6f641e   07/09/98 18:41:49 Joel Sherrill Added sersupp.c. 4.104.114.84.95
(edit) @d94d47b3   07/09/98 18:41:33 Joel Sherrill New files to contain generally needed serial driver support routines. 4.104.114.84.95
(edit) @37e8259   07/09/98 18:40:27 Joel Sherrill Changed static to MC68681_STATIC to make all routines and data global … 4.104.114.84.95
