Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @6a22637   02/08/13 13:23:22 Sebastian Huber bsp/lpc24xx: Move UART probes to separate files 4.115
(edit) @5455f23a   02/08/13 15:58:52 Sebastian Huber libchip/serial: Make NS16550 handler public This allows derived … 4.115
(edit) @c8bd3cd   02/08/13 12:39:59 Sebastian Huber libchip/serial: Add const qualifier 4.115
(edit) @e4933743   02/08/13 12:43:47 Sebastian Huber libchip/serial: Fix warnings 4.115
(edit) @49f65bef   02/08/13 12:42:02 Sebastian Huber libchip/serial: Fix warnings 4.115
(edit) @d2a4f158   02/08/13 10:58:37 Sebastian Huber libchip/serial: Fix warnings 4.115
(edit) @5de9e8d   02/08/13 10:58:20 Sebastian Huber bsp/erc32: Fix warnings 4.115
(edit) @4b53f191   02/06/13 10:38:29 Sebastian Huber bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE 4.115
(edit) @dc5cd79   02/06/13 10:37:26 Sebastian Huber bsp/mpc55xx: Merge RSM6 variants into one 4.115
(edit) @c082b575   02/05/13 16:23:55 Sebastian Huber bsp/mpc55xx: Add and use BSP specific fatal codes 4.115
(edit) @39de538   02/05/13 16:00:10 Sebastian Huber bsps/powerpc: Add and use ppc_cpu_is_specific_e200 4.115
(edit) @3020614   02/05/13 15:59:36 Sebastian Huber bsps/powerpc: Fix e200 check 4.115
(edit) @93d4d06   02/05/13 15:31:30 Sebastian Huber bsp/mpc55xx: Add mpc55xx_mmu_apply_config() 4.115
(edit) @c934a10d   01/11/13 13:41:53 Sebastian Huber bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH 4.115
(edit) @036788d5   01/11/13 13:41:00 Sebastian Huber bsps/powerpc: Add option for write-through cache 4.115
(edit) @4dafa52   01/28/13 11:38:55 Sebastian Huber bsp/mpc55xx: Fix MMU configuration for RSM6 4.115
(edit) @967278f   01/23/13 00:16:37 Ric Claus Fixed virtex4,5 BSP compile time warnings 4.115
(edit) @7f7b09c   01/18/13 08:48:38 Sebastian Huber bsp/gen83xx: Disable caches in bsp_restart() 4.115
(edit) @f7351e4   01/14/13 07:16:04 Sebastian Huber bsp/virtex5: Fix define location 4.115
(edit) @b1d1021   01/11/13 08:27:50 Sebastian Huber bsp/lpc32xx: Bypass the IrDA modem for UART6 4.115
(edit) @f12ef239   01/09/13 15:25:37 Sebastian Huber bsps/arm: Fix LPC Ethernet driver initialization 4.115
(edit) @da80202   01/09/13 13:31:58 Sebastian Huber bsp/gen83xx: Register I2C SEMTECH SC620 driver 4.115
(edit) @fb070e05   01/09/13 13:31:20 Sebastian Huber libchip: Add I2C SEMTECH SC620 octal LED driver 4.115
(edit) @aeff597   01/09/13 12:17:18 Sebastian Huber bsps/powerpc: Add probe handler to I2C driver 4.115
(edit) @339646e   01/09/13 11:50:55 Sebastian Huber bsps/powerpc: Fix compiler warnings 4.115
(edit) @bfde536e   01/09/13 10:12:48 Sebastian Huber bsp/gen83xx: Invalidate caches only if disabled 4.115
(edit) @5828127   01/09/13 08:29:04 Sebastian Huber bsp/gen83xx: System reset after fatal conditions 4.115
(edit) @d4e2f337   01/09/13 08:28:19 Sebastian Huber bsp/gen83xx: Add bsp_restart() 4.115
(edit) @253cb8b5   01/08/13 09:37:41 Sebastian Huber bsp/gen83xx: Delete obsolete region 4.115
(edit) @f597cc1   01/08/13 18:49:56 Joel Sherrill leon3: disable unused ISR handler 4.115
(edit) @4967f6b   01/08/13 18:37:05 Joel Sherrill leon3/shmsupp: Fix warnings & comment clean up 4.115
(edit) @4fd1ccaa   01/08/13 17:58:41 Joel Sherrill leon3: Open Ethernet Fixed Warning 4.115
(edit) @a0d01664   01/08/13 17:54:19 Joel Sherrill no_bsp: Fix typo and format 4.115
(edit) @72d0926   01/08/13 16:45:35 Joel Sherrill m68k/mvme167: Compiles again Was including non-existent .h file. … 4.115
(edit) @1419a86   01/08/13 16:18:06 Joel Sherrill arm/smdk2410: Update to include bspidle.c This BSP shares code with … 4.115
(edit) @b8051837   01/08/13 16:13:46 Joel Sherrill arm/gp32: Correct compilation error in BSP Idle Thread Split BSP Idle … 4.115
(edit) @40340b2   01/07/13 15:00:52 Sebastian Huber bsp/lpc24xx: Declare conditionally 4.115
(edit) @dd46d67   01/07/13 13:57:32 Sebastian Huber bsp/lpc32xx: System reset after fatal conditions 4.115
(edit) @f1413c4   01/07/13 13:56:53 Sebastian Huber bsp/lpc24xx: System reset after fatal conditions 4.115
(edit) @2460cc7   01/07/13 13:56:18 Sebastian Huber bsp/lpc24xx: Request system reset for LPC17XX 4.115
(edit) @4cc629cd   01/07/13 13:55:54 Sebastian Huber bsp/lpc24xx: Add WWDT module defines 4.115
(edit) @04f399d   01/07/13 09:19:23 Sebastian Huber arm: Add and use _ARMV7M_Exception_default() 4.115
(edit) @0f7abd99   01/04/13 15:25:19 Sebastian Huber arm: Rename inline functions Rename arm_status_irq_enable() to … 4.115
(edit) @8df0e91   01/04/13 15:22:18 Sebastian Huber arm: Move inline functions 4.115
(edit) @13cf952   01/04/13 14:47:34 Sebastian Huber arm: Add and use default exception handler Add and use … 4.115
(edit) @370c2c80   01/04/13 12:06:51 Sebastian Huber arm: Rename arm_exc_interrupt() Rename arm_exc_interrupt() to … 4.115
(edit) @9b2e7143   01/04/13 12:05:28 Sebastian Huber arm: Move prototypes to new file Move bsp_interrupt_dispatch() and … 4.115
(edit) @9224905b   01/03/13 14:41:16 Sebastian Huber bsps: Fix rtems_interrupt_server_handler_remove() 4.115
(edit) @3af7e23e   12/21/12 13:11:36 Sebastian Huber bsp/gen83xx: Add GPR_1 to register map 4.115
(edit) @a640b204   12/21/12 08:26:27 Sebastian Huber bsp/gen83xx: Fix RCWLR_CEVCO defines 4.115
(edit) @566c05c   12/19/12 12:41:27 Sebastian Huber bsp/gen83xx: Fix CSB clock calculation for MPC8309 4.115
(edit) @4592658   12/18/12 08:24:56 Sebastian Huber bsps/arm: Move promiscuous mode setting 4.115
(edit) @3f58ac7   12/17/12 14:41:53 Sebastian Huber bsps/arm: Add PHY up/down All PHYs will be set to power up/down state … 4.115
(edit) @50233d37   12/17/12 10:12:20 Sebastian Huber bsps/arm: Add PHY timeout detection 4.115
(edit) @2cd48da   12/14/12 12:08:10 Sebastian Huber bsps/arm: Add interface down support 4.115
(edit) @e99893f9   12/14/12 11:17:15 Sebastian Huber bsps/arm: Prepare for interface down support 4.115
(edit) @573822b   12/14/12 11:07:28 Sebastian Huber bsps/arm: Use assert() instead of status macros 4.115
(edit) @5970dcc9   12/14/12 09:28:18 Sebastian Huber bsps/arm: Remove superfluous attributes 4.115
(edit) @e5a7f846   12/14/12 08:40:44 Sebastian Huber bsps/arm: Avoid mbuf migration in LPC ethernet The receive task will … 4.115
(edit) @c9562c5   12/18/12 10:18:40 Sebastian Huber bsp/lpc32xx: Add UART_CLKMODE settings 4.115
(edit) @380628ea   12/18/12 09:45:13 Sebastian Huber bsp/lpc32xx: Configure U4_TX pin for UART 4 4.115
(edit) @d1cf326   12/18/12 09:44:48 Sebastian Huber bsp/lpc32xx: Fix function prototype 4.115
(edit) @f25d31f   12/17/12 15:40:23 Sebastian Huber bsp/lpc32xx: Add idle thread body 4.115
(edit) @7371995   12/12/12 08:26:51 Sebastian Huber bsp/lpc32xx: Fix console baud configuration 4.115
(edit) @80232ee7   12/07/12 08:50:27 Sebastian Huber bsps/powerpc: Use explicit compiler options 4.115
(edit) @48bff53b   12/06/12 16:47:30 Sebastian Huber score: rtems_initialize_start_multitasking() Do not return from … 4.115
(edit) @1bb8782   12/06/12 16:44:55 Sebastian Huber bsp/gdbarmsim: Do not call bsp_cleanup() 4.115
(edit) @facf8362   12/06/12 16:42:41 Sebastian Huber bsps: Add BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT Use rtems_fatal() … 4.115
(edit) @dabdbd91   12/06/12 16:40:42 Sebastian Huber bsp/mrm332: Use shared bspclean.c 4.115
(edit) @40fe4b86   12/06/12 16:40:08 Sebastian Huber bsps: Use <bsp/bootcard.h> 4.115
(edit) @191929cd   12/06/12 16:31:48 Sebastian Huber bsps/powerpc: Install missing <bsp/vectors.h> 4.115
(edit) @2858aeb9   11/23/12 16:25:54 Sebastian Huber bsp/mpc55xx: New BSP variants for RSM6 4.115
(edit) @e1e248f   11/26/12 16:02:44 Sebastian Huber bsp/mpc55xx: Add optional EBI configuration 4.115
(edit) @f4309b0   11/26/12 15:58:58 Sebastian Huber bsp/mpc55xx: Use RTEMS_ARRAY_SIZE() 4.115
(edit) @29919ec0   11/23/12 14:12:41 Sebastian Huber bsp/mpc55xx: Add .sysram section 4.115
(edit) @65ab304b   11/23/12 13:47:47 Sebastian Huber bsp/mpc55xx: Add .dsram section 4.115
(edit) @bb3090c5   11/23/12 13:43:04 Sebastian Huber bsp/mpc55xx: Delete <bsp/mpc55xxevb.h> 4.115
(edit) @113768f   11/23/12 13:16:11 Sebastian Huber bsps/powerpc: Add .nvram section 4.115
(edit) @95aebbe   11/23/12 09:11:55 Sebastian Huber bsp/mpc55xx: Add and use STARTROM 4.115
(edit) @840dd00   11/23/12 09:11:22 Sebastian Huber bsp/mpc55xx: Add and use linkcmds.mpc5674f_ecu508 4.115
(edit) @c6d35ad4   11/21/12 08:46:58 Sebastian Huber bsp/mpc55xx: Errata e4396 for e200z7 4.115
(edit) @2e80662   11/19/12 08:12:07 Sebastian Huber bsp/mpc55xx: Set PPC_EXC_CONFIG_BOOKE_ONLY 4.115
(edit) @3ce66aa   11/19/12 08:02:12 Sebastian Huber bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER 4.115
(edit) @1c479be4   11/16/12 09:06:07 Sebastian Huber bsp/mpc55xx: Documentation 4.115
(edit) @fee41c9   12/03/12 12:08:42 Sebastian Huber bsp/mpc55xx: Add and use mpc55xx_fatal_code 4.115
(edit) @6eb0ce2   11/15/12 16:33:15 christian.mauderer bsp/mpc55xx: Fix SMSC9218I MAC address setting 4.115
(edit) @da2fa4eb   11/15/12 16:01:29 Sebastian Huber bsp/mpc55xx: Remove BSP_panic() 4.115
(edit) @67338ed   11/15/12 15:57:02 Sebastian Huber bsp/mpc55xx: Add mpc55xx_wait_for_interrupt() Use … 4.115
(edit) @2d561b9   11/13/12 13:39:19 Sebastian Huber bsp/mpc55xx: Use BSP_START_DATA_SECTION 4.115
(edit) @bd75e589   11/13/12 11:20:59 Sebastian Huber bsp/mpc55xx: Fix INTC initialization 4.115
(edit) @6c454104   11/13/12 10:50:38 Sebastian Huber bsp/mpc55xx: Fix no-cache section load 4.115
(edit) @353f0fa   11/22/12 15:21:32 Sebastian Huber bsp/mpc55xx: Add union tags 4.115
(edit) @fe1a4e4b   11/21/12 08:54:32 Sebastian Huber bsp/qoriq: Set PPC_EXC_CONFIG_BOOKE_ONLY 4.115
(edit) @f6999e6   11/21/12 08:54:12 Sebastian Huber bsp/qoriq: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER 4.115
(edit) @c383372   11/13/12 14:01:24 Sebastian Huber bsps/powerpc: Add and use bsp_text input section 4.115
(edit) @d33f743   11/13/12 14:00:53 Sebastian Huber bsps/powerpc: Move .fast_text after .text section 4.115
(edit) @f665f13   11/19/12 07:37:04 Sebastian Huber bsps/powerpc: Add PPC_EXC_CONFIG_BOOKE_ONLY In combination with the … 4.115
(edit) @4bd4c9e   11/23/12 08:32:52 Sebastian Huber bsps/powerpc: Add PPC_EXC_CONFIG_USE_FIXED_HANDLER In case a BSP … 4.115
(edit) @4263155   11/23/12 08:27:20 Sebastian Huber bsps/powerpc: Declare ppc_exc_handler_table 4.115
(edit) @3bf002a   11/30/12 12:21:37 Sebastian Huber bsp/gen83xx: Workaround for USB stack 4.115
