@5a234809
08/27/96 15:19:33 |
Joel Sherrill |
check that we were passed a valid mutex and ignore errors from the …
4.104.114.84.95
@e4cc4176
08/23/96 15:58:24 |
Mark.Johannes |
Changed all EFAULTS to EINVALs
4.104.114.84.95
@3adf786
08/23/96 15:56:50 |
Mark.Johannes |
filled in screen
4.104.114.84.95
@237088c
08/23/96 15:56:22 |
Mark.Johannes |
Filled in screen
4.104.114.84.95
@78f5dae
08/23/96 15:55:02 |
Mark.Johannes |
Filled in the screen
4.104.114.84.95
@e2ceeca7
08/23/96 15:50:53 |
Mark.Johannes |
Added build_time statement to provide a tm for the test
4.104.114.84.95
@257adba
08/23/96 15:17:16 |
Mark.Johannes |
Changed test 5 to test 10 at bottom
4.104.114.84.95
@0b710dbb
08/23/96 14:47:58 |
Mark.Johannes |
pthread_create: changed EINVAL for no more threads back to EAGAIN
4.104.114.84.95
@df70c6b
08/22/96 20:18:44 |
Mark.Johannes |
Commented out the EINVAL for mutex not acquired befor cond_wait call
4.104.114.84.95
@6702bffc
08/21/96 15:49:21 |
Mark.Johannes |
updated to support ENOTSUP
4.104.114.84.95
@256a462
08/20/96 21:41:08 |
Mark.Johannes |
Added Einval case for mutex not initialized
4.104.114.84.95
@c5c5f8c
08/19/96 15:30:25 |
Mark.Johannes |
Changed all EFAULTs to EINVALs
4.104.114.84.95
@02f041e
08/19/96 15:27:37 |
Mark.Johannes |
pthread_mutex_init: added error messages for NULL mutex and EBUSY
4.104.114.84.95
@cd3868cd
08/15/96 21:09:02 |
Joel Sherrill |
updates from Tony Bennett (tbennett@…)
4.104.114.84.95
@0600e86f
08/15/96 21:05:21 |
Joel Sherrill |
_Thread_Start_multitasking: added code to initialize the floating …
4.104.114.84.95
@9ac3e76
08/15/96 19:38:46 |
Mark.Johannes |
changed ENOMEM error message
4.104.114.84.95
@7fb19bb
08/15/96 19:27:08 |
Mark.Johannes |
init: added tests for pthread_kill and kill errors.
4.104.114.84.95
@851b18d
08/15/96 18:59:34 |
Joel Sherrill |
changed error code
4.104.114.84.95
@fdf6917
08/15/96 18:59:00 |
Joel Sherrill |
changed error for too many threads to EAGAIN
4.104.114.84.95
@f3e19146
08/15/96 18:58:09 |
Joel Sherrill |
clock_gettime: changed assert condition to a standard error code
4.104.114.84.95
@b03ab630
08/15/96 18:57:07 |
Joel Sherrill |
sched_rr_get_interval: converted assert condition into a standard …
4.104.114.84.95
@57dae56
08/15/96 18:56:09 |
Joel Sherrill |
added constant to indicate there is no mutex associated with this …
4.104.114.84.95
@de45ddc
08/15/96 16:29:00 |
Mark.Johannes |
pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO
4.104.114.84.95
@948721c
08/15/96 16:24:44 |
Mark.Johannes |
pthread_kill: moved check for SA_SIGINFO to allow for validation of …
4.104.114.84.95
@48e685c
08/15/96 16:22:59 |
Mark.Johannes |
fixed typo for NOTSUP -> ENOTSUP
4.104.114.84.95
@fb7d080
08/14/96 20:25:57 |
Joel Sherrill |
pthread_mutex_init returns EAGAIN not ENOMEM when there are too many …
4.104.114.84.95
@ac81b6ca
08/14/96 19:41:47 |
Joel Sherrill |
added test cases for NULL being passed to pthread attribute get routines
4.104.114.84.95
@ff53a6d4
08/14/96 19:30:49 |
Joel Sherrill |
added test case for pthread_attr_getscope being passed a NULL …
4.104.114.84.95
@4e63ae5
08/14/96 17:20:45 |
Mark.Johannes |
commented of ENOTSUP until fixed in newlib
4.104.114.84.95
@aae1c932
08/14/96 17:20:03 |
Mark.Johannes |
pthread_cond_timedwait: added error cases for abstime
4.104.114.84.95
@87c8fd09
08/14/96 17:19:03 |
Mark.Johannes |
system.h: added task3 and changed condition variable config to 1
4.104.114.84.95
@b0c483ed
08/14/96 17:18:02 |
Mark.Johannes |
task3: added to test error case in Wait_support for lock on mutex
4.104.114.84.95
@520949bf
08/14/96 17:16:14 |
Mark.Johannes |
init: added error case for wait timedwait, and wait support
4.104.114.84.95
@645fc954
08/14/96 15:27:14 |
Joel Sherrill |
pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope
4.104.114.84.95
@dce801d
08/13/96 21:32:49 |
Mark.Johannes |
pthread_cond_destroy: added enable dispatch to EBUSY case
4.104.114.84.95
@95b76bc
08/13/96 21:10:06 |
Mark.Johannes |
pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First
4.104.114.84.95
@456b3769
08/13/96 20:50:54 |
Mark.Johannes |
pthread_cond_destroy: EBUSY case now uses Thread_queue_First
4.104.114.84.95
@c53eb2c3
08/13/96 20:46:10 |
Mark.Johannes |
removed count from Thread_queue_Control
4.104.114.84.95
@a66fcc5
08/13/96 20:43:51 |
Mark.Johannes |
removed Thread_queue_Get_number_waiting
4.104.114.84.95
@392b35e
08/13/96 20:38:30 |
Joel Sherrill |
deleted a line for spacing correction
4.104.114.84.95
@48b40d8
08/13/96 19:53:51 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: changed status of lock and …
4.104.114.84.95
@c8a4ed6
08/13/96 19:06:45 |
Mark.Johannes |
task_2: added comments and print statement for task exit
4.104.114.84.95
@1d428a3c
08/13/96 19:06:12 |
Mark.Johannes |
task_1: added comments and print statement for task exit
4.104.114.84.95
@c9c94387
08/13/96 19:05:27 |
Mark.Johannes |
Init.c: added timewait case, added broadcast case
4.104.114.84.95
@76f03c6
08/13/96 19:03:29 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: fixed the timeout sequence.
4.104.114.84.95
@b2e8026
08/13/96 15:43:12 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@9b67f170
08/13/96 15:36:28 |
Joel Sherrill |
corrected problem in which sigtimedwait() was being invoked with
the …
4.104.114.84.95
@fc960ab
08/13/96 15:35:36 |
Joel Sherrill |
chenaged format of output
4.104.114.84.95
@0d59c7a
08/13/96 14:47:52 |
Joel Sherrill |
added include of errno.h so the test can check for EINTR.
4.104.114.84.95
@85f5b4ab
08/13/96 14:47:31 |
Joel Sherrill |
nanosleep now returns -1 and EINTR when a signal interrupts EINTR.
4.104.114.84.95
@f48c9068
08/13/96 14:24:00 |
Joel Sherrill |
removed errors for TOD not set yet.
made nanosleep return -1/EINTR …
4.104.114.84.95
@aac34f7b
08/13/96 14:23:16 |
Joel Sherrill |
added page break before sysconf()
4.104.114.84.95
@e9624663
08/12/96 21:52:37 |
Mark.Johannes |
task_1: added to handle cases of waiting tasks on condition variables
4.104.114.84.95
@a7f4c5a
08/12/96 21:51:44 |
Mark.Johannes |
system.h: added protoypes for task and task2, added mutex id, and task ids
4.104.114.84.95
@aad3fe6
08/12/96 21:49:54 |
Mark.Johannes |
Init.c: added cases for signal, wait and broadcast
4.104.114.84.95
@08515de
08/12/96 21:49:14 |
Mark.Johannes |
Task2: new task for broadcast case
4.104.114.84.95
@5da2ae8
08/12/96 21:15:15 |
Joel Sherrill |
added test cases for clock_getres
4.104.114.84.95
@1087564
08/12/96 20:59:41 |
Joel Sherrill |
clock_getres: added error check for NULL pointer being passed in.
4.104.114.84.95
@3fbfbcd
08/12/96 20:48:13 |
Joel Sherrill |
sleep: wrong page number
4.104.114.84.95
@702a31c
08/12/96 20:08:36 |
Joel Sherrill |
removed comment about NO_UNINITIALIZED_WARNINGS since that macro
no …
4.104.114.84.95
@221bd65
08/12/96 20:00:02 |
Joel Sherrill |
added test case for stack too large
4.104.114.84.95
@5f08fd6
08/12/96 19:55:09 |
Joel Sherrill |
nanosleep: verify rqtp parameter is non-NULL.
nanosleep: return 0 …
4.104.114.84.95
@c4f5e752
08/12/96 19:54:12 |
Joel Sherrill |
added test cases for clock_gettime (invalid id), clock_settime …
4.104.114.84.95
@d60d9505
08/12/96 19:20:18 |
Joel Sherrill |
added test case for non-NULL parameter to time()
4.104.114.84.95
@40cfab47
08/12/96 19:19:03 |
Joel Sherrill |
time: It is not an error if the TOD is not set.
4.104.114.84.95
@9b77fee
08/12/96 19:00:12 |
Mark.Johannes |
Wait_support: removed the calls to mutex core to posix status codes
4.104.114.84.95
@3b97b7a0
08/12/96 18:58:12 |
Mark.Johannes |
mutex.h: removes the promotion of core status code to POSXI status codes
4.104.114.84.95
@1402ee25
08/12/96 18:56:04 |
Joel Sherrill |
fixed spacing ; moved a dummy MP support routine to clean up printout.
4.104.114.84.95
@c7a9c66
08/12/96 18:06:27 |
Joel Sherrill |
_POSIX_Mutex_Get: made null id an error
4.104.114.84.95
@ccdf4c57
08/12/96 18:05:47 |
Joel Sherrill |
pthread_mutex_getprioceiling: added error check for null old_ceiling
4.104.114.84.95
@d06e9ca
08/12/96 18:04:38 |
Joel Sherrill |
added numerous error test cases.
4.104.114.84.95
@b1af454
08/12/96 17:41:37 |
Mark.Johannes |
mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status
4.104.114.84.95
@af04a791
08/12/96 17:40:56 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: added …
4.104.114.84.95
@cdcea6ce
08/12/96 17:21:04 |
Mark.Johannes |
_POSIX_Condition_variables_Signal_support: added setting mutex back to …
4.104.114.84.95
@f126ae2
08/12/96 17:04:13 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: fixed typo
4.104.114.84.95
@db8e9011
08/12/96 17:02:39 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: valid priority ceiling check looked …
4.104.114.84.95
@684c3c4
08/12/96 16:29:14 |
Joel Sherrill |
pthread_mutexattr_getprotocol: added check for attribute structure …
4.104.114.84.95
@0cd15947
08/12/96 15:15:51 |
Mark.Johannes |
Init: added pthread_cond_init with an attr non-NULL, initialized the …
4.104.114.84.95
@5263668
08/12/96 14:49:02 |
Mark.Johannes |
Init: added prliminary phtread_cond_init and destroy cases.
4.104.114.84.95
@da4e38d
08/12/96 14:48:13 |
Mark.Johannes |
system.h: added condition variable #define for 10 condition variables
4.104.114.84.95
@da2e539
08/09/96 21:16:01 |
Joel Sherrill |
added test cases for errors in pthread_mutexattr_getpshared
4.104.114.84.95
@b9444fb9
08/09/96 19:58:58 |
Joel Sherrill |
added code to catch NULL pointers for return values passed to get routines
4.104.114.84.95
@13adea0
08/09/96 19:55:04 |
Joel Sherrill |
added test cases for EINVAL cases in pthread_mutexattr_destroy
4.104.114.84.95
@c03aeaf
08/09/96 19:50:26 |
Joel Sherrill |
added test case for pthread_mutexattr_init being passed a null pointer.
4.104.114.84.95
@76117f2b
08/09/96 19:20:54 |
Joel Sherrill |
changed style of output to match other tests
4.104.114.84.95
@1406a4b
08/09/96 19:10:50 |
Mark.Johannes |
system.h: initial cvs
4.104.114.84.95
@c7dd091f
08/09/96 18:48:33 |
Joel Sherrill |
lowered maximum number of threads to 2 to make test case easier.
4.104.114.84.95
@d0b5249
08/09/96 18:47:58 |
Joel Sherrill |
added test case for sched_yield.
changed format of some output.
4.104.114.84.95
@f643e230
08/09/96 18:47:38 |
Joel Sherrill |
added test cases for errors in sched_get_priority_min and …
4.104.114.84.95
@8699a70
08/09/96 18:45:10 |
Joel Sherrill |
sched_yield: was not invoking the dispatcher.
4.104.114.84.95
@695dd0b
08/09/96 18:28:21 |
Mark.Johannes |
Init: added condattr - destroy, init, set and get cases
4.104.114.84.95
@66dfd0b
08/09/96 17:44:04 |
Joel Sherrill |
added test cases for invalid key ids
4.104.114.84.95
@d858fdb
08/09/96 17:30:13 |
Joel Sherrill |
merged remote object id and invalid id error cases.
4.104.114.84.95
@760ee96d
08/09/96 16:02:06 |
Joel Sherrill |
reduced maximum keys to 2 to more easily generate error
4.104.114.84.95
@5b08e20
08/09/96 16:01:50 |
Joel Sherrill |
changed printf's which could be puts's to puts
4.104.114.84.95
@54e34e7
08/08/96 23:02:13 |
Joel Sherrill |
new test to test scheduling policy and paremeter paths in pthread_create.
4.104.114.84.95
@13642cbc
08/08/96 22:26:55 |
Mark.Johannes |
Init: Original file - tests for condition variables.
4.104.114.84.95
@79f189e
08/08/96 21:58:26 |
Joel Sherrill |
split test into multiple tasks.
4.104.114.84.95
@76de65b3
08/08/96 21:46:40 |
Joel Sherrill |
added cases to increase coverage of pthread_create. cases added …
4.104.114.84.95
@2b613588
08/08/96 20:47:49 |
Joel Sherrill |
added test to complete coverage of pthread_setschedparam and increase …
4.104.114.84.95
