@4b53f191
02/06/13 10:38:29 |
Sebastian Huber |
bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE
4.115
@dc5cd79
02/06/13 10:37:26 |
Sebastian Huber |
bsp/mpc55xx: Merge RSM6 variants into one
4.115
@c082b575
02/05/13 16:23:55 |
Sebastian Huber |
bsp/mpc55xx: Add and use BSP specific fatal codes
4.115
@39de538
02/05/13 16:00:10 |
Sebastian Huber |
bsps/powerpc: Add and use ppc_cpu_is_specific_e200
4.115
@3020614
02/05/13 15:59:36 |
Sebastian Huber |
bsps/powerpc: Fix e200 check
4.115
@93d4d06
02/05/13 15:31:30 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_mmu_apply_config()
4.115
@c934a10d
01/11/13 13:41:53 |
Sebastian Huber |
bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH
4.115
@036788d5
01/11/13 13:41:00 |
Sebastian Huber |
bsps/powerpc: Add option for write-through cache
4.115
@4dafa52
01/28/13 11:38:55 |
Sebastian Huber |
bsp/mpc55xx: Fix MMU configuration for RSM6
4.115
@967278f
01/23/13 00:16:37 |
Ric Claus |
Fixed virtex4,5 BSP compile time warnings
4.115
@7f7b09c
01/18/13 08:48:38 |
Sebastian Huber |
bsp/gen83xx: Disable caches in bsp_restart()
4.115
@f7351e4
01/14/13 07:16:04 |
Sebastian Huber |
bsp/virtex5: Fix define location
4.115
@b1d1021
01/11/13 08:27:50 |
Sebastian Huber |
bsp/lpc32xx: Bypass the IrDA modem for UART6
4.115
@f12ef239
01/09/13 15:25:37 |
Sebastian Huber |
bsps/arm: Fix LPC Ethernet driver initialization
4.115
@da80202
01/09/13 13:31:58 |
Sebastian Huber |
bsp/gen83xx: Register I2C SEMTECH SC620 driver
4.115
@fb070e05
01/09/13 13:31:20 |
Sebastian Huber |
libchip: Add I2C SEMTECH SC620 octal LED driver
4.115
@aeff597
01/09/13 12:17:18 |
Sebastian Huber |
bsps/powerpc: Add probe handler to I2C driver
4.115
@339646e
01/09/13 11:50:55 |
Sebastian Huber |
bsps/powerpc: Fix compiler warnings
4.115
@bfde536e
01/09/13 10:12:48 |
Sebastian Huber |
bsp/gen83xx: Invalidate caches only if disabled
4.115
@5828127
01/09/13 08:29:04 |
Sebastian Huber |
bsp/gen83xx: System reset after fatal conditions
4.115
@d4e2f337
01/09/13 08:28:19 |
Sebastian Huber |
bsp/gen83xx: Add bsp_restart()
4.115
@253cb8b5
01/08/13 09:37:41 |
Sebastian Huber |
bsp/gen83xx: Delete obsolete region
4.115
@f597cc1
01/08/13 18:49:56 |
Joel Sherrill |
leon3: disable unused ISR handler
4.115
@4967f6b
01/08/13 18:37:05 |
Joel Sherrill |
leon3/shmsupp: Fix warnings & comment clean up
4.115
@4fd1ccaa
01/08/13 17:58:41 |
Joel Sherrill |
leon3: Open Ethernet Fixed Warning
4.115
@a0d01664
01/08/13 17:54:19 |
Joel Sherrill |
no_bsp: Fix typo and format
4.115
@72d0926
01/08/13 16:45:35 |
Joel Sherrill |
m68k/mvme167: Compiles again
Was including non-existent .h file. …
4.115
@1419a86
01/08/13 16:18:06 |
Joel Sherrill |
arm/smdk2410: Update to include bspidle.c
This BSP shares code with …
4.115
@b8051837
01/08/13 16:13:46 |
Joel Sherrill |
arm/gp32: Correct compilation error in BSP Idle Thread
Split BSP Idle …
4.115
@40340b2
01/07/13 15:00:52 |
Sebastian Huber |
bsp/lpc24xx: Declare conditionally
4.115
@dd46d67
01/07/13 13:57:32 |
Sebastian Huber |
bsp/lpc32xx: System reset after fatal conditions
4.115
@f1413c4
01/07/13 13:56:53 |
Sebastian Huber |
bsp/lpc24xx: System reset after fatal conditions
4.115
@2460cc7
01/07/13 13:56:18 |
Sebastian Huber |
bsp/lpc24xx: Request system reset for LPC17XX
4.115
@4cc629cd
01/07/13 13:55:54 |
Sebastian Huber |
bsp/lpc24xx: Add WWDT module defines
4.115
@04f399d
01/07/13 09:19:23 |
Sebastian Huber |
arm: Add and use _ARMV7M_Exception_default()
4.115
@0f7abd99
01/04/13 15:25:19 |
Sebastian Huber |
arm: Rename inline functions
Rename arm_status_irq_enable() to …
4.115
@8df0e91
01/04/13 15:22:18 |
Sebastian Huber |
arm: Move inline functions
4.115
@13cf952
01/04/13 14:47:34 |
Sebastian Huber |
arm: Add and use default exception handler
Add and use …
4.115
@370c2c80
01/04/13 12:06:51 |
Sebastian Huber |
arm: Rename arm_exc_interrupt()
Rename arm_exc_interrupt() to …
4.115
@9b2e7143
01/04/13 12:05:28 |
Sebastian Huber |
arm: Move prototypes to new file
Move bsp_interrupt_dispatch() and …
4.115
@9224905b
01/03/13 14:41:16 |
Sebastian Huber |
bsps: Fix rtems_interrupt_server_handler_remove()
4.115
@3af7e23e
12/21/12 13:11:36 |
Sebastian Huber |
bsp/gen83xx: Add GPR_1 to register map
4.115
@a640b204
12/21/12 08:26:27 |
Sebastian Huber |
bsp/gen83xx: Fix RCWLR_CEVCO defines
4.115
@566c05c
12/19/12 12:41:27 |
Sebastian Huber |
bsp/gen83xx: Fix CSB clock calculation for MPC8309
4.115
@4592658
12/18/12 08:24:56 |
Sebastian Huber |
bsps/arm: Move promiscuous mode setting
4.115
@3f58ac7
12/17/12 14:41:53 |
Sebastian Huber |
bsps/arm: Add PHY up/down
All PHYs will be set to power up/down state …
4.115
@50233d37
12/17/12 10:12:20 |
Sebastian Huber |
bsps/arm: Add PHY timeout detection
4.115
@2cd48da
12/14/12 12:08:10 |
Sebastian Huber |
bsps/arm: Add interface down support
4.115
@e99893f9
12/14/12 11:17:15 |
Sebastian Huber |
bsps/arm: Prepare for interface down support
4.115
@573822b
12/14/12 11:07:28 |
Sebastian Huber |
bsps/arm: Use assert() instead of status macros
4.115
@5970dcc9
12/14/12 09:28:18 |
Sebastian Huber |
bsps/arm: Remove superfluous attributes
4.115
@e5a7f846
12/14/12 08:40:44 |
Sebastian Huber |
bsps/arm: Avoid mbuf migration in LPC ethernet
The receive task will …
4.115
@c9562c5
12/18/12 10:18:40 |
Sebastian Huber |
bsp/lpc32xx: Add UART_CLKMODE settings
4.115
@380628ea
12/18/12 09:45:13 |
Sebastian Huber |
bsp/lpc32xx: Configure U4_TX pin for UART 4
4.115
@d1cf326
12/18/12 09:44:48 |
Sebastian Huber |
bsp/lpc32xx: Fix function prototype
4.115
@f25d31f
12/17/12 15:40:23 |
Sebastian Huber |
bsp/lpc32xx: Add idle thread body
4.115
@7371995
12/12/12 08:26:51 |
Sebastian Huber |
bsp/lpc32xx: Fix console baud configuration
4.115
@80232ee7
12/07/12 08:50:27 |
Sebastian Huber |
bsps/powerpc: Use explicit compiler options
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@1bb8782
12/06/12 16:44:55 |
Sebastian Huber |
bsp/gdbarmsim: Do not call bsp_cleanup()
4.115
@facf8362
12/06/12 16:42:41 |
Sebastian Huber |
bsps: Add BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT
Use rtems_fatal() …
4.115
@dabdbd91
12/06/12 16:40:42 |
Sebastian Huber |
bsp/mrm332: Use shared bspclean.c
4.115
@40fe4b86
12/06/12 16:40:08 |
Sebastian Huber |
bsps: Use <bsp/bootcard.h>
4.115
@191929cd
12/06/12 16:31:48 |
Sebastian Huber |
bsps/powerpc: Install missing <bsp/vectors.h>
4.115
@2858aeb9
11/23/12 16:25:54 |
Sebastian Huber |
bsp/mpc55xx: New BSP variants for RSM6
4.115
@e1e248f
11/26/12 16:02:44 |
Sebastian Huber |
bsp/mpc55xx: Add optional EBI configuration
4.115
@f4309b0
11/26/12 15:58:58 |
Sebastian Huber |
bsp/mpc55xx: Use RTEMS_ARRAY_SIZE()
4.115
@29919ec0
11/23/12 14:12:41 |
Sebastian Huber |
bsp/mpc55xx: Add .sysram section
4.115
@65ab304b
11/23/12 13:47:47 |
Sebastian Huber |
bsp/mpc55xx: Add .dsram section
4.115
@bb3090c5
11/23/12 13:43:04 |
Sebastian Huber |
bsp/mpc55xx: Delete <bsp/mpc55xxevb.h>
4.115
@113768f
11/23/12 13:16:11 |
Sebastian Huber |
bsps/powerpc: Add .nvram section
4.115
@95aebbe
11/23/12 09:11:55 |
Sebastian Huber |
bsp/mpc55xx: Add and use STARTROM
4.115
@840dd00
11/23/12 09:11:22 |
Sebastian Huber |
bsp/mpc55xx: Add and use linkcmds.mpc5674f_ecu508
4.115
@c6d35ad4
11/21/12 08:46:58 |
Sebastian Huber |
bsp/mpc55xx: Errata e4396 for e200z7
4.115
@2e80662
11/19/12 08:12:07 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_BOOKE_ONLY
4.115
@3ce66aa
11/19/12 08:02:12 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@1c479be4
11/16/12 09:06:07 |
Sebastian Huber |
bsp/mpc55xx: Documentation
4.115
@fee41c9
12/03/12 12:08:42 |
Sebastian Huber |
bsp/mpc55xx: Add and use mpc55xx_fatal_code
4.115
@6eb0ce2
11/15/12 16:33:15 |
christian.mauderer |
bsp/mpc55xx: Fix SMSC9218I MAC address setting
4.115
@da2fa4eb
11/15/12 16:01:29 |
Sebastian Huber |
bsp/mpc55xx: Remove BSP_panic()
4.115
@67338ed
11/15/12 15:57:02 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_wait_for_interrupt()
Use …
4.115
@2d561b9
11/13/12 13:39:19 |
Sebastian Huber |
bsp/mpc55xx: Use BSP_START_DATA_SECTION
4.115
@bd75e589
11/13/12 11:20:59 |
Sebastian Huber |
bsp/mpc55xx: Fix INTC initialization
4.115
@6c454104
11/13/12 10:50:38 |
Sebastian Huber |
bsp/mpc55xx: Fix no-cache section load
4.115
@353f0fa
11/22/12 15:21:32 |
Sebastian Huber |
bsp/mpc55xx: Add union tags
4.115
@fe1a4e4b
11/21/12 08:54:32 |
Sebastian Huber |
bsp/qoriq: Set PPC_EXC_CONFIG_BOOKE_ONLY
4.115
@f6999e6
11/21/12 08:54:12 |
Sebastian Huber |
bsp/qoriq: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@c383372
11/13/12 14:01:24 |
Sebastian Huber |
bsps/powerpc: Add and use bsp_text input section
4.115
@d33f743
11/13/12 14:00:53 |
Sebastian Huber |
bsps/powerpc: Move .fast_text after .text section
4.115
@f665f13
11/19/12 07:37:04 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_BOOKE_ONLY
In combination with the …
4.115
@4bd4c9e
11/23/12 08:32:52 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_USE_FIXED_HANDLER
In case a BSP …
4.115
@4263155
11/23/12 08:27:20 |
Sebastian Huber |
bsps/powerpc: Declare ppc_exc_handler_table
4.115
@3bf002a
11/30/12 12:21:37 |
Sebastian Huber |
bsp/gen83xx: Workaround for USB stack
4.115
@7ac89a6f
11/30/12 12:14:34 |
Sebastian Huber |
bsp/gen83xx: Add sections for USB stack
4.115
@fd5c1eb
12/03/12 09:02:29 |
Sebastian Huber |
bsp/csb637: Fix memory map
4.115
@e168410
12/03/12 08:57:59 |
Sebastian Huber |
bsp/csb337: Fix memory map
4.115
@809b726a
12/01/12 00:12:59 |
Ric Claus |
Print MCSR and ESR.
The Machine Check and Exception Syndrome …
4.115
@655bd39
11/30/12 23:58:32 |
Ric Claus |
Virtex5 BSP: Various updates and improvements.
This BSP now uses the …
4.115
@5b822ab
11/30/12 23:56:04 |
Ric Claus |
Virtex4 BSP: Various updates and improvements.
Switched to using the …
4.115
@84b19b5
11/30/12 23:47:34 |
Ric Claus |
Restored to pre PPC440 changes.
This file was originally modified by …
4.115
