Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @43613a90   02/11/15 11:54:57 Daniel Hellstrom AMBAPP_BUS: fix build warnings 4.115
(edit) @56662f5c   02/11/15 11:52:14 Daniel Hellstrom LEON CONS: fix build warnings 4.115
(edit) @103bbde   02/11/15 11:50:35 Daniel Hellstrom GR-TMTC-1553: fix build warnings 4.115
(edit) @dd8abfc   02/11/15 11:40:17 Daniel Hellstrom GR-RASTA-TMTC: fix build warnings 4.115
(edit) @90fd587   02/11/15 11:39:40 Daniel Hellstrom GR-RASTA-SPW-ROUTER: fix build warnings 4.115
(edit) @960aebf   02/11/15 11:39:04 Daniel Hellstrom GR-RASTA-IO: fix build warnings 4.115
(edit) @03037b4   02/11/15 11:38:22 Daniel Hellstrom GR-RASTA-ADCDAC: fix build warnings 4.115
(edit) @ef7a009   02/11/15 11:37:28 Daniel Hellstrom GR-LEON4-N2X: fix build warnings 4.115
(edit) @05a45c79   02/11/15 11:36:50 Daniel Hellstrom GR_701: fix build warnings 4.115
(edit) @cb64b862   02/11/15 11:35:53 Daniel Hellstrom GRGPIO: fix buld warnings 4.115
(edit) @c39de3c4   02/11/15 11:35:36 Daniel Hellstrom GPIOLIB: fix build warnings 4.115
(edit) @7bc74ed   02/11/15 11:34:48 Daniel Hellstrom GRADCDAC: fix build warnings 4.115
(edit) @0355ad4   02/11/15 11:34:02 Daniel Hellstrom GENIRQ: fix build warnings 4.115
(edit) @9d05c6df   02/11/15 11:32:22 Daniel Hellstrom GRPWM: fix build warnings 4.115
(edit) @126b25d   02/11/15 11:31:26 Daniel Hellstrom SPWCUC: fix build warnings 4.115
(edit) @8c6c53d   02/11/15 11:27:05 Daniel Hellstrom SPICTRL: fix build warnings 4.115
(edit) @9b90342   02/11/15 11:23:45 Daniel Hellstrom GRSPW router: fix build warnings 4.115
(edit) @b6292a0b   02/11/15 11:23:04 Daniel Hellstrom GRSPW_PKT: fix build warnings 4.115
(edit) @fd7eaa2   02/11/15 08:40:15 Daniel Hellstrom TLIB: fix build warnings 4.115
(edit) @6048035   02/11/15 08:39:48 Daniel Hellstrom TLIB Clock: fix build warnings 4.115
(edit) @a93b3aa4   02/11/15 08:37:50 Daniel Hellstrom GRASCS: fix build warnings 4.115
(edit) @3823f5c   02/11/15 08:20:40 Daniel Hellstrom GRCTM: fix build warnings 4.115
(edit) @60d392b7   02/11/15 08:19:53 Daniel Hellstrom GRTM: fix build warnings 4.115
(edit) @e21a5b0   02/11/15 08:18:53 Daniel Hellstrom GRTC: fix build warnings 4.115
(edit) @6657a3d   02/10/15 15:33:16 Daniel Hellstrom LEON: GRPCI2 driver warning fixes 4.115
(edit) @48191662   02/10/15 15:29:39 Daniel Hellstrom LEON: I2CMST driver warnings fixes 4.115
(edit) @c9f75435   02/10/15 15:28:55 Daniel Hellstrom LEON: OCCAN driver warnings fixes 4.115
(edit) @be815e78   02/10/15 15:28:19 Daniel Hellstrom LEON: B1553BRM driver warnings fixes 4.115
(edit) @44e514f   02/10/15 15:28:03 Daniel Hellstrom LEON: B1553RT driver warnings fixes 4.115
(edit) @3f38335b   02/10/15 15:05:38 Daniel Hellstrom LEON: added get_resarray_count() helper routine 4.115
(edit) @b787bead   02/10/15 08:23:48 Daniel Hellstrom GR1553B: fixed build warnings 4.115
(edit) @05ce8bd5   02/10/15 07:32:42 Daniel Hellstrom AT697PCI: fix build warnings 4.115
(edit) @e3c9937   02/18/15 14:34:39 Daniel Hellstrom GPTIMER: move ISR install from init1 To avoid install ISRs during … 4.115
(edit) @f37a3c2   02/06/15 10:10:17 Daniel Hellstrom GPTIMER: fix build warnings 4.115
(edit) @7a03ac29   02/06/15 08:59:13 Daniel Hellstrom APBUART_CONS: fix build warning 4.115
(edit) @d77b16d   02/06/15 08:27:08 Daniel Hellstrom GR-RASTA-SPW-ROUTER: fix build warnings 4.115
(edit) @28950f0b   02/05/15 13:35:33 Daniel Hellstrom PCIF: fixed build warnings 4.115
(edit) @f407c51   02/05/15 13:31:42 Daniel Hellstrom GRPCI: fixed build warnings 4.115
(edit) @0d9bc25   02/05/15 08:52:00 Daniel Hellstrom GRSPW: fix build warnings 4.115
(edit) @b55aa49   02/05/15 07:07:15 Daniel Hellstrom LEON3: watchdog use common timer defines 4.115
(edit) @5ba49066   02/05/15 07:06:26 Daniel Hellstrom LEON3: export debug uart to console uart driver 4.115
(edit) @aedc9849   02/05/15 07:05:56 Daniel Hellstrom GRETH: fix build warnings with GCC-4.9 4.115
(edit) @bf6fe958   02/04/15 15:22:59 Daniel Hellstrom GPTIMER: avoid build warnings 4.115
(edit) @0fcd4b33   02/04/15 15:22:41 Daniel Hellstrom AHBSTAT: fix build warnings 4.115
(edit) @bb689e6   11/04/14 07:57:55 Daniel Hellstrom GRTM: fixed descriptor TS bit declaration 4.115
(edit) @5f4028b   11/04/14 07:52:39 Daniel Hellstrom GRSPW_PKT: grspw_status renamed in header 4.115
(edit) @e8f6005f   08/08/14 08:01:41 Daniel Hellstrom GR-RASTA-TMTC,rev1: add GRGPIO[0] register init 4.115
(edit) @fed905c8   08/08/14 07:59:36 Daniel Hellstrom B1553BRM: change the init of the RT legalization registers 4.115
(edit) @d2a94ab   05/02/14 12:28:44 Daniel Hellstrom GRSPW: added clock cycles after GRSPW reset added clock cycles after … 4.115
(edit) @56fc7809   07/03/13 08:16:30 andreas GRSPW_PKT: Add support for Interrupt-codes Update: Daniel Hellstrom … 4.115
(edit) @c119c0e   07/03/13 08:06:37 andreas GRSPW: Fix incorrect register defines - presently functionally … 4.115
(edit) @f1b1668   12/20/13 09:17:22 Daniel Hellstrom AMBAPP: updated PnP IDs database with SPWTDP 4.115
(edit) @fa12bb43   11/29/13 13:58:58 Daniel Hellstrom GRTIMER: added to GPTIMER driver GRTIMER is compatible with GPTIMER, … 4.115
(edit) @9b8e04e2   10/22/13 10:03:41 Daniel Hellstrom GRETH: avoid hw generated UDP/TCP cksum generation Hardware generated … 4.115
(edit) @80b9c8ac   12/20/13 13:03:10 Daniel Hellstrom GR-RASTA-IO: updated for new version From this driver's point of view … 4.115
(edit) @fc76056e   12/20/13 13:01:12 Daniel Hellstrom GR-RASTA-TMTC: updated for new version From this driver's point of … 4.115
(edit) @9d88008   12/18/13 15:42:16 Daniel Hellstrom AT697PCI: fix PCI cfg writes 4.115
(edit) @ddc4002   11/22/13 09:22:56 Daniel Hellstrom AT697 PCI: abort whhen a peripheral PCI system detected 4.115
(edit) @3c236cc   02/05/14 16:17:53 Daniel Hellstrom LEON PCI: fix for PCI host bridge driver CFG space access 4.115
(edit) @acf7047e   09/10/13 11:46:29 Daniel Hellstrom GPTIMER: timer probing must not be on timer0 Timers are identical … 4.115
(edit) @51347053   07/01/13 13:00:21 Daniel Hellstrom LEON PCI: host bridge driver support for probing dev0=AD16 Before the … 4.115
(edit) @d936c1a   06/03/13 12:12:08 Daniel Hellstrom APBUART: debug bit was cleared incorrectly 4.115
(edit) @ab907e8e   05/21/13 08:10:21 Daniel Hellstrom NGMP PCI: added support for NGMP prototype boards 4.115
(edit) @bc89145   02/11/15 13:39:34 Daniel Hellstrom LEON GRSPW: updated to new DRVMGR translation interface 4.115
(edit) @ffd8002d   05/08/13 12:41:13 Daniel Hellstrom GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device … 4.115
(edit) @8aa446a   05/08/13 12:38:10 Daniel Hellstrom GRPCI2: updated register layout to newer specification 4.115
(edit) @ecbd577   04/30/13 07:49:32 Daniel Hellstrom AMBAPP: update AMBA PnP ID database 4.115
(edit) @175b9a64   04/24/13 15:36:44 Daniel Hellstrom GRPCI2: work-around for rev0 bug by limiting prefetching 4.115
(edit) @819de55b   03/18/13 07:29:39 Daniel Hellstrom PCI-RASTA: set GRPCI1 target cache-line-size to avoid poor performance 4.115
(edit) @37ac3b86   03/14/13 09:20:15 Daniel Hellstrom GRETH: cleaned up parts of PHY init code 4.115
(edit) @107c5aea   03/13/13 15:40:05 Daniel Hellstrom GRETH: changed the PHY initialization sequence 1. read_mii() now … 4.115
(edit) @a79c36ad   03/12/13 14:30:09 Daniel Hellstrom GRETH: forcing autonegotiation during PHY initialization Looking at … 4.115
(edit) @bee7c46f   03/12/13 13:49:33 Daniel Hellstrom GRETH: updated worker Deamon thread name The name was probably copied … 4.115
(edit) @552d4a9   03/06/13 14:08:31 Daniel Hellstrom GRPCI: initialize cache-line-size and latency timer In some GRPCI … 4.115
(edit) @5dd83de   01/18/13 12:16:05 Daniel Hellstrom GRSPW: fixed SET_RMAPEN and SET_RMAPBUFDIS Both ioctl commands … 4.115
(edit) @4d249b9f   11/19/12 16:41:15 Daniel Hellstrom GPTIMER: support separate & shared irq by clearing pending bit after ISR 4.115
(edit) @7ebc28cd   11/19/12 14:24:21 Daniel Hellstrom GPTIMER: Only probe pending bit on timer0 4.115
(edit) @b583cc5f   02/23/15 12:47:32 Daniel Hellstrom leon,gpiolib: add mask/unmask interrupt support 4.115
(edit) @949d0d6   09/25/12 13:26:00 arvid GRSPW: Make sure buffers are 64-bit aligned This is to improve odds … 4.115
(edit) @18564f5   06/19/12 12:49:40 Daniel Hellstrom APBUART: fix GRMON -u support for older UARTs 4.115
(edit) @0f49c0e   06/19/12 06:50:11 Daniel Hellstrom GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA This patch adds … 4.115
(edit) @16d6e42   06/19/12 06:34:37 Daniel Hellstrom LEON3: fixed nano seconds support in TLIB The … 4.115
(edit) @f00fee8e   05/24/12 15:23:37 Daniel Hellstrom GRTM: fixed bug where transmitter start loop was optimized away 4.115
(edit) @e9378fa   05/16/12 11:17:11 Daniel Hellstrom GRPCI: fix target BAR1 initialization 4.115
(edit) @3bb4122   02/23/15 12:02:39 Daniel Hellstrom LEON: added new drivers to the LEON2/LEON3 BSPs Most drivers use the … 4.115
(edit) @fe1aa9c0   12/21/11 12:21:49 Daniel Hellstrom LEON: added network device configuration helper function 4.115
(edit) @3681925   12/20/11 15:27:54 Daniel Hellstrom LEON: updated shared drivers to Driver Manger framework Some bugfixes … 4.115
(edit) @e67b2b8d   12/20/11 14:58:05 Daniel Hellstrom LEON: updated and added PCI peripherals for LEON BSPs The CCHIP … 4.115
(edit) @3e3fb0d   12/20/11 11:28:32 Daniel Hellstrom LEON2: added support for LEON2-GRLIB systems In some non-standard … 4.115
(edit) @46e41c98   12/16/11 13:10:57 Daniel Hellstrom LEON: replaced old BSP PCI layer with new generic libpci PCI layer … 4.115
(edit) @c1764100   12/16/11 10:39:23 Daniel Hellstrom LEON3: new Console driver, APBUART driver using Driver Manager This … 4.115
(edit) @045de35   04/14/15 07:29:48 Daniel Hellstrom MERGE: new system clock implementation 4.115
(edit) @cd64fbf   12/16/11 09:37:49 Daniel Hellstrom LEON: GPTIMER driver, Timer Library and System Clock for LEON3 With … 4.115
(edit) @3db9e5b0   12/15/11 16:31:17 Daniel Hellstrom LEON2: implemented AMBA Bus Driver for Driver Manager 4.115
(edit) @e05c265   12/15/11 16:00:38 Daniel Hellstrom LEON3: implemented AMBA PnP Bus Driver for Driver Manager 4.115
(edit) @d11f228   12/15/11 15:39:54 Daniel Hellstrom sparc BSPs: implemented libpci IRQ BSP support 4.115
(edit) @e428dc4a   12/12/11 14:50:57 Daniel Hellstrom LEON3: implemented BSP DRVMGR startup initialization 4.115
(edit) @e7fade3   11/28/11 08:52:03 Daniel Hellstrom DRVMGR: added driver manager to cpukit/libdrvmgr 4.115
(edit) @e51eb80   02/19/15 08:25:09 Daniel Hellstrom leon3,ngmp: simplify cpucounter initialization Remove support for … 4.115
(edit) @5da315ff   02/19/15 09:06:54 Daniel Hellstrom leon3: make timer initialization configurable Its now possible to … 4.115
