@4359c43
04/10/18 14:32:59 |
Sebastian Huber |
bsps: Simplify source file path in Makefile.am
This patch is a part …
5
@b10caf8
04/10/18 05:16:30 |
Sebastian Huber |
bsps: Remove headers from librtemsbsp_a_SOURCES
This was used by the …
5
@b78b814
04/10/18 04:36:19 |
Sebastian Huber |
bsps: Avoid source variables in Makefile.am
This patch is a part of …
5
@6c4140c
04/10/18 04:17:10 |
Sebastian Huber |
bsps: Avoid line continuation in Makefile.am
5
@1032bf9
04/07/18 17:46:01 |
Sebastian Huber |
bsp/mvme5500: Avoid RTEMS_RELLDFLAGS
5
@b46f943c
04/07/18 17:38:55 |
Sebastian Huber |
bsp/motorola_powerpc: Move polled_io.c
This file was used by this BSP …
5
@efb893f
04/07/18 17:28:42 |
Sebastian Huber |
bsp/beatnik: Avoid RTEMS_RELLDFLAGS
Avoid extra CPPFLAGS.
5
@b43ea9f
04/05/18 15:07:20 |
Sebastian Huber |
bsps: Move legacy console driver to bsps
This patch is a part of the …
5
@f0bcae38
04/05/18 14:45:26 |
Sebastian Huber |
bsps: Remove unused console_select_simple.c
5
@b8c59353
04/11/18 03:26:58 |
Chris Johns |
build: Fix make clean.
Update #3254.
5
@aa567bc1
04/10/18 06:06:39 |
Chris Johns |
configure: Add subdir-objects to all automake flags.
This option …
5
@7ff743d
04/10/18 00:32:25 |
Chris Johns |
Generate an error if a BSP in the --enable-rtemsbsp list is not valid
5
@cb7b4dc4
04/09/18 03:47:36 |
Chris Johns |
bsp/lpc24xx: Exclude iconv POSIX tests.
These are now built to …
5
@b606998
04/09/18 09:40:28 |
Sebastian Huber |
bsp/genmcf548x: Fix IRQ support
This patch is a part of the BSP …
5
@01d34a3
04/09/18 09:37:27 |
Sebastian Huber |
bsp/csb337: Fix umon support
This patch is a part of the BSP source …
5
@9edb72e
04/05/18 04:56:26 |
Sebastian Huber |
build: Remove DISTCLEANFILES
A "make distclean" is not supported. So, …
5
@9b7c456
04/05/18 04:40:02 |
Sebastian Huber |
bsps: Move generic IRQ support to bsps
5
@d584269
04/04/18 14:44:52 |
Sebastian Huber |
bsps: Remove librtemsbsp.a wrapup
5
@4b28d3c
04/04/18 14:39:58 |
Sebastian Huber |
bsps: Move shmdr to bsps
5
@814eccb4
04/03/18 14:41:16 |
Sebastian Huber |
bsps: Move VME support to bsps
The VME support is only used by …
5
@671c31fc
04/03/18 14:24:31 |
Sebastian Huber |
bsp: Move umon support to bsps
The umon support is only used by the …
5
@d03ec77d
04/04/18 14:26:28 |
Sebastian Huber |
bsps/powerpc: Rename to shared-sources.am
5
@6799a78
04/04/18 14:25:21 |
Sebastian Huber |
bsps/powerpc: Rename to exceptions-sources.am
5
@0f0f249c
04/04/18 14:24:15 |
Sebastian Huber |
bsps/m68k: Rename fpsp.am to fpsp-sources.am
5
@82bc976
04/04/18 14:23:09 |
Sebastian Huber |
bsps/bfin: Rename shared.am to shared-sources.am
5
@27de4e1f
04/03/18 05:20:11 |
Sebastian Huber |
bsps: Move libchip to bsps
5
@8621ed38
04/03/18 05:28:03 |
Sebastian Huber |
bsps: Move config macros to RTEMS_BSP_CONFIGURE
Provide …
5
@4f0dca3a
04/03/18 05:09:11 |
Sebastian Huber |
bsps: Move version.c and use bspopts.h
5
@ce0ea6f
04/03/18 05:08:24 |
Sebastian Huber |
bsps: Add shared-sources.am
5
@66b99a1
04/03/18 04:28:00 |
Sebastian Huber |
bsps: Add RTEMS_BSP to bspopts.h
5
@2d0bc83
03/30/18 18:42:21 |
Sebastian Huber |
build: Remove EXTRA_DIST
A "make dist" is not supported. So, it makes …
5
@0b8a6d7
03/28/18 16:17:45 |
joel |
Eliminate PowerPC libcpu/page.h
Started to eliminate warnings and …
5
@4f0dcb69
03/27/18 11:07:57 |
Sebastian Huber |
bsps/riscv: Fix warnings
5
@699fee43
03/26/18 11:33:29 |
Sebastian Huber |
bsps: Remove libcpu
5
@5d39512
03/26/18 11:25:36 |
Sebastian Huber |
bsps/m68k: Remove libcpu/m68k
5
@b54558ac
03/26/18 11:20:43 |
Sebastian Huber |
bsps/mcf5225x: Move libcpu content to bsps
5
@945095d
03/26/18 11:08:07 |
Sebastian Huber |
bsps/genmcf548x: Move libcpu content to bsps
5
@ddf3ea2
03/26/18 10:23:22 |
Sebastian Huber |
bsps/csb360: Move libcpu content to bsps
5
@2190bc6
03/26/18 10:20:45 |
Sebastian Huber |
bsps/mcf5206elite: Move libcpu content to bsps
5
@3cf2bf63
03/26/18 10:17:06 |
Sebastian Huber |
bsps/m68k: Move fpsp support to bsps
5
@fc2ec62
03/26/18 10:10:15 |
Sebastian Huber |
bsps/m68k: Move libcpu content to bsps
5
@1e23c47
03/26/18 10:01:18 |
Sebastian Huber |
bsps/m68k: Remove unused define
5
@f8e4755f
03/26/18 09:59:23 |
Sebastian Huber |
bsps/m68k: Use namespace header
5
@1048a165
03/26/18 08:36:52 |
Sebastian Huber |
bsp/tqm8xx: Use shared linker command file
Update #3339.
5
@11a8296
03/26/18 05:57:53 |
Sebastian Huber |
bsp/mvme3100: Simplify Makefile.am
5
@5f59e2a
03/26/18 05:52:57 |
Sebastian Huber |
bsps/powerpc: Move dec timer driver
5
@6882be7
03/26/18 05:47:02 |
Sebastian Huber |
bsps/powerpc: Remove libcpu/powerpc
5
@2d33672a
03/26/18 05:43:09 |
Sebastian Huber |
bsps/powerpc: Move ppc403 clock driver to bsps
5
@d7c232f
03/26/18 05:18:20 |
Sebastian Huber |
bsps/powerpc: Remove unused files
5
@4fd1ff0f
03/26/18 04:57:10 |
Sebastian Huber |
bsps/powerpc: Move AltiVec? support to bsps
5
@d813d9aa
03/26/18 04:24:55 |
Sebastian Huber |
bsps/powerpc: Move dec clock driver to bsps
5
@11fe8c59
03/26/18 04:18:51 |
Sebastian Huber |
bsps/powerpc: Move MMU support to bsps
5
@b8c468b
03/23/18 15:11:55 |
Sebastian Huber |
bsp/tqm8xx: Move libcpu content to bsps
5
@a12dcff8
03/23/18 15:04:18 |
Sebastian Huber |
bsp/mpc8260: Move libcpu content to bsps
5
@0cab067
03/23/18 14:54:12 |
Sebastian Huber |
bsps/powerpc: Move libcpu content to bsps
5
@e2bd1f6
03/21/18 15:38:43 |
Sebastian Huber |
bsp/bfin: Move libcpu content to bsps
5
@96400050
03/26/18 07:04:43 |
Sebastian Huber |
bsp/pc386: Remove unused RTEMS_CPU_MODEL
5
@b1b7390
03/26/18 06:58:42 |
Sebastian Huber |
bsp/pc386: Fix build
5
@f17df94
03/26/18 07:14:16 |
Sebastian Huber |
build: configure.ac is a file
5
@d7fd3bc
03/23/18 16:33:45 |
Gedare Bloom |
sparc64: remove header file with duplicated macros
The boot/stack.h …
5
@b1d3b0f
03/23/18 02:46:49 |
Chris Johns |
libcpu: Only build if there is a valid configure.ac
5
@df8a31d
03/22/18 13:50:02 |
thomas.doerfler |
bsp/tqm8xx: Fix network interface driver
5
@28a6bb8
03/22/18 05:36:11 |
Sebastian Huber |
mpci: Avoid use of RTEMS_RELLDFLAGS
5
@dc1ea01
03/22/18 05:27:31 |
Sebastian Huber |
bsps/mpc55xx: Move libcpu content to bsps
5
@3f3f246a
03/22/18 05:19:16 |
Sebastian Huber |
bsps/mpc55xx: Remove unused files
5
@bb22a3f3
03/21/18 05:27:24 |
Sebastian Huber |
bsp/powerpc: Move libcpu timer to bsps
Use only one timer driver …
5
@f3a51d62
03/21/18 07:11:33 |
Sebastian Huber |
bsps/powerpc: Remove bsp_timer_internal_clock
The only consumer of …
5
@a7fa9e91
03/20/18 15:16:53 |
Sebastian Huber |
bsp/pc386: Move libcpu content to bsps
5
@5cf0656
03/20/18 13:14:39 |
Eric Tremblay |
bsps/powerpc: Support more than 256MiB of RAM
Close #3322.
5
@5d44981c
03/20/18 06:34:22 |
Sebastian Huber |
bsp/qoriq: Fix bsp_restart()
Update #3085.
5
@09dd82a5
03/13/18 15:43:25 |
Sebastian Huber |
bsp/ss555: Move libcpu content to bsps
5
@bd150801
03/13/18 15:24:16 |
Sebastian Huber |
bsps/powerpc: Move exceptions support to bsps
5
@ff3b9aa
03/13/18 05:23:40 |
Sebastian Huber |
5
@7dbc43d
03/13/18 05:18:38 |
Sebastian Huber |
bsps/powerpc: Move basic support to bsps
5
@ac04bb85
03/12/18 15:42:16 |
Sebastian Huber |
bsps/powerpc: Move legacy IRQ support
5
@efa0039e
03/13/18 16:14:15 |
amaan.cheval |
i386/smp: Export _CPU_SMP_Prepare_start_multitasking as a function
5
@51614c01
03/13/18 16:14:14 |
amaan.cheval |
i386/smp: Have ld use incremental build for appstart.o
With HAS_SMP …
5
@2e5cf7f
03/16/18 14:09:36 |
Sebastian Huber |
bsps/powerpc: Use shared linker command file
Close #3339.
5
@9860cc7
03/16/18 10:01:03 |
Sebastian Huber |
bsps/powerpc: Fix linker command files
Update #3339.
5
@0a7a30d
03/12/18 19:53:09 |
joel |
Add PowerPC paravirtualization support
Cannot read or write MSR when …
5
@71c5552f
03/12/18 15:43:28 |
christian.mauderer |
bsp/atsam: Allow setting the drive strength.
This adds a simple …
5
@7633f5b
03/12/18 05:59:15 |
Sebastian Huber |
sparc64: Move libcpu content to cpukit
5
@8b5778e
03/12/18 05:37:36 |
Sebastian Huber |
sparc: Move libcpu content to cpukit
5
@c4905d8d
03/10/18 09:17:35 |
Sebastian Huber |
bsps/arm: Move libcpu content to bsps
5
@b6755af
03/09/18 15:45:56 |
Sebastian Huber |
bsps/mips: Move libcpu content to bsps
5
@961e2ef
03/12/18 05:23:08 |
Sebastian Huber |
bsps/mips: Remove Mongoose-V README
5
@4c83f292
03/12/18 07:16:17 |
Sebastian Huber |
bsps: Remove unused RTEMS_CPU_MODEL
5
@a4570829
03/09/18 15:22:25 |
Sebastian Huber |
bsps: Remove unused memcpy() implementations
5
@0706581
03/07/18 20:31:31 |
joel |
misc sh: Remove includes of rtems/score/types.h
5
@d39cc068
03/07/18 05:37:55 |
Sebastian Huber |
bsps: More verbose bsp_fatal_extension()
Close #3318.
5
@befae6ab
03/07/18 09:32:42 |
Sebastian Huber |
bsp/genmcf548x: Fix printk() support
5
@d440a9e
03/07/18 09:32:09 |
Sebastian Huber |
bsps/m68k: Fix entry point in linkcmds.base
Updates #3520.
5
@4899759
03/06/18 06:23:07 |
Thanassis.Tsiodras |
bsps/sparc: Fix global construction/destruction
The
KEEP …
5
@40c623a8
09/21/17 20:20:29 |
joel |
powerpc/shared/startup/linkcmds.base: Add wildcards on some sections
5
@6878519
02/06/18 15:28:28 |
bsp/atsam: Fix cache / DMA handling in SPI.
This patch fixes the …
5
@538a0a8
02/02/18 06:06:16 |
bsp/atsam: Allow to use a decoder for SPI CS.
The SPI controller …
5
@03fecae
01/11/18 07:54:27 |
Christian.Mauderer |
bsp/atsam: Add option to disable 32kHz XTAL.
5
@ea7f4a0c
01/30/18 23:25:20 |
joel |
sparc/*/linkcmds*: Move ENTRY() from linkcmds.base to top linkcmds
5
@3454179
02/05/18 12:54:48 |
Sebastian Huber |
bsp/altera-cyclone-v: Add device tree support
Update #3290.
5
@0f4a7391
02/05/18 10:45:17 |
Sebastian Huber |
bsps/powerpc: Remove support for mpc505
Close #3270.
5
