@0545e15
11/16/99 22:57:58 |
Joel Sherrill |
Fixed screen.
4.104.114.84.95
@0b0441af
11/16/99 22:57:32 |
Joel Sherrill |
Added TERMINAL_IDENTIFICATION pieces.
4.104.114.84.95
@38d65f80
11/16/99 22:56:53 |
Joel Sherrill |
Fixed alignment problem on _endtext.
4.104.114.84.95
@aad726e
11/16/99 22:56:38 |
Joel Sherrill |
Moved task_variable pointer to basic shared part of TCB instead of …
4.104.114.84.95
@987445b
11/16/99 22:55:11 |
Joel Sherrill |
Added proper nesting level for dispatch disable check.
4.104.114.84.95
@96c2db6
11/16/99 22:51:47 |
Joel Sherrill |
Added code so if dispatching level is specified to be -1, then no …
4.104.114.84.95
@cea3304
11/16/99 22:51:06 |
Joel Sherrill |
Corrected nesting level on dispatching verification.
4.104.114.84.95
@0beded61
11/16/99 22:50:08 |
Joel Sherrill |
Corrected disable dispatch nesting count checks.
4.104.114.84.95
@4efe2b7a
11/16/99 22:47:23 |
Jennifer.Averett |
Added check to return passed if task is not suspended.
4.104.114.84.95
@0fa51b5b
11/16/99 22:46:55 |
Jennifer.Averett |
Added code to catch the error of suspend count exceding the counter value.
4.104.114.84.95
@9181246
11/16/99 22:45:51 |
Jennifer.Averett |
Fixed bug.
4.104.114.84.95
@18c3155
11/16/99 22:45:33 |
Jennifer.Averett |
Added handler for fsync. For the memfile it is the same as the data sync.
4.104.114.84.95
@ca7d922
11/16/99 21:32:09 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@9c7867b
11/16/99 21:30:41 |
Jennifer.Averett |
Inserted output from the erc32 run into the output file.
4.104.114.84.95
@7fe5ff38
11/16/99 21:15:03 |
Joel Sherrill |
Use miniIMFS like hello from samples.
4.104.114.84.95
@a470c0ee
11/16/99 21:10:48 |
Joel Sherrill |
Increased stack space because message buffers are on the stack.
4.104.114.84.95
@22542b6b
11/16/99 20:50:36 |
Jennifer.Averett |
Removed leading space from output.
4.104.114.84.95
@f89df68
11/16/99 20:50:07 |
Jennifer.Averett |
Added comment indicating that dup is known to be broken.
4.104.114.84.95
@47c7705
11/16/99 20:49:18 |
Jennifer.Averett |
Added data to the log file so it matches the real output.
4.104.114.84.95
@ac0ba842
11/16/99 20:48:48 |
Jennifer.Averett |
Added comment to log file indicating that task order is not
critical.
4.104.114.84.95
@36072c8a
11/16/99 20:47:30 |
Jennifer.Averett |
Added test case of rsm_tsk and frsm_tsk on a task not suspended.
This …
4.104.114.84.95
@90378e4
11/16/99 16:23:26 |
Joel Sherrill |
Added BSP_MAXIMUM_OPERATION_COUNT and BSP_ITERATION_COUNT
which allow …
4.104.114.84.95
@4b960e5
11/16/99 16:21:00 |
Joel Sherrill |
Added code to the macros which checked directive status to also
check …
4.104.114.84.95
@72d4b1d9
11/16/99 16:19:06 |
Joel Sherrill |
Use the miniIMFS to reduce code space.
4.104.114.84.95
@a20190a4
11/16/99 16:15:05 |
Joel Sherrill |
Added test cases for uname().
4.104.114.84.95
@65a38bc
11/16/99 16:14:37 |
Joel Sherrill |
Web server uses the POSIX API. Therefor, it must be disabled when the …
4.104.114.84.95
@ce18601a
11/16/99 16:13:26 |
Joel Sherrill |
Removed start subdirectory and distributed contents to the appropriate …
4.104.114.84.95
@0cb7cb9
11/16/99 16:10:39 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@d3fdf459
11/16/99 16:09:50 |
Joel Sherrill |
Now use _Thread_Reset().
4.104.114.84.95
@88cb6b2
11/16/99 16:08:10 |
Joel Sherrill |
Added threadreset.c.
4.104.114.84.95
@f6d0821
11/16/99 16:07:52 |
Joel Sherrill |
Added prototype for _Thread_Reset() and numerous comments.
4.104.114.84.95
@c094542
11/16/99 16:07:17 |
Joel Sherrill |
Only check for System V IPC if multiprocessing is enabled. The unix …
4.104.114.84.95
@f4b76ab5
11/16/99 16:04:51 |
Joel Sherrill |
Fixed so can be included multiple times in the executive source.
4.104.114.84.95
@31473b7
11/16/99 16:03:21 |
Joel Sherrill |
Works now.
Removed times() since the version in the C Library support …
4.104.114.84.95
@165fe39
11/16/99 16:01:54 |
Joel Sherrill |
Return a reasonable error other than ENOSYS.
4.104.114.84.95
@7fec3b7a
11/16/99 16:01:32 |
Joel Sherrill |
Added call to _Watchdog_Remove to remove the sporadic timer. It was …
4.104.114.84.95
@2c0e896e
11/16/99 16:00:11 |
Joel Sherrill |
Moved utsname from "build for now" (unimplemented files) to the main …
4.104.114.84.95
@d280ce18
11/16/99 15:58:21 |
Joel Sherrill |
Comment fixed when adding prototype for …
4.104.114.84.95
@bd462d1
11/16/99 15:52:49 |
Joel Sherrill |
New file.
4.104.114.84.95
@d6c83529
11/16/99 15:48:11 |
Joel Sherrill |
Patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius …
4.104.114.84.95
@fa3346f
11/16/99 15:41:58 |
Jennifer.Averett |
Modified file to match seen output.
4.104.114.84.95
@f9879915
11/16/99 15:41:29 |
Jennifer.Averett |
Modified output file to match seen output. Added comment to all ino …
4.104.114.84.95
@e9b00d7
11/16/99 15:40:40 |
Jennifer.Averett |
Removed compiler warning.
4.104.114.84.95
@d37aa444
11/16/99 15:39:08 |
Jennifer.Averett |
Changed asserts to tmmacros.
4.104.114.84.95
@2d82857
11/16/99 15:38:44 |
Jennifer.Averett |
Updated scn file to match new output. Left out unemplemented
parts as …
4.104.114.84.95
@47619951
11/16/99 15:33:10 |
Jennifer.Averett |
+ Changed ID to 1. ( Compilation error introduced by modifications. )
4.104.114.84.95
@1da9f4bd
11/16/99 15:30:04 |
Jennifer.Averett |
Modified scan file to match.
4.104.114.84.95
@817031f
11/16/99 15:28:03 |
Joel Sherrill |
New file.
4.104.114.84.95
@c7016198
11/16/99 15:27:52 |
Joel Sherrill |
Added.
4.104.114.84.95
@b88691c
11/16/99 15:26:29 |
Joel Sherrill |
Source and destination arguments to strncpy were swapped. This …
4.104.114.84.95
@c276c87
11/16/99 15:24:30 |
Joel Sherrill |
Added itron tests.
4.104.114.84.95
@3fb7b70b
11/16/99 14:39:56 |
Jennifer.Averett |
Changed to call tmmacros instead of assert.
4.104.114.84.95
@ac656f2d
11/16/99 14:15:56 |
Joel Sherrill |
Moved start code from lib/start to libbsp.
4.104.114.84.95
@25f705e
11/16/99 13:55:35 |
Joel Sherrill |
4.104.114.84.95
@1d04e16
11/16/99 13:45:51 |
Joel Sherrill |
4.104.114.84.95
@7f93f772
11/16/99 13:37:49 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@a7d988a
11/16/99 13:37:25 |
Joel Sherrill |
Minor changes since new Makefile.
4.104.114.84.95
@14dbf50
11/16/99 13:34:41 |
Joel Sherrill |
Added start subdirectory.
4.104.114.84.95
@1bcdb3f6
11/16/99 13:31:13 |
Joel Sherrill |
4.104.114.84.95
@80fd699
11/15/99 22:19:51 |
Joel Sherrill |
Removed nanosleep() since it is now in its own file.
4.104.114.84.95
@40aac29
11/15/99 21:37:56 |
Jennifer.Averett |
Returned third parameter for a NULL name to the objects open call.
4.104.114.84.95
@25789705
11/15/99 21:35:14 |
Jennifer.Averett |
+ Fixed files to consistantly use a case of the location after calls
4.104.114.84.95
@1ae60eb4
11/15/99 21:31:28 |
Jennifer.Averett |
+ Modified to use new Thread_Reset routine instead of the restart method.
4.104.114.84.95
@e672263
11/15/99 21:28:21 |
Jennifer.Averett |
Fixed verificaiton checks to call correct macro if dispatch is disabled.
4.104.114.84.95
@06380cfe
11/15/99 21:25:53 |
Jennifer.Averett |
+ Added check that a task could be sent to a dormant state
then …
4.104.114.84.95
@0f88857
11/15/99 21:19:58 |
Jennifer.Averett |
+ Changed preempt routine into two dummy tasks one that is in dormant
4.104.114.84.95
@9da0994
11/15/99 17:15:58 |
Joel Sherrill |
Split ITRON Message Buffer Manager into multiple files.
4.104.114.84.95
@fb27af76
11/15/99 16:39:01 |
Joel Sherrill |
Split ITRON semaphore manager into multiple files.
4.104.114.84.95
@afb11f8
11/12/99 22:00:10 |
Joel Sherrill |
+ Modified calls to use TSK_SLF for calls to self.
+ Modified calls to …
4.104.114.84.95
@624d7ca4
11/12/99 21:27:42 |
Joel Sherrill |
+ Added comments on paths tested.
4.104.114.84.95
@e8c902c
11/12/99 21:26:54 |
Joel Sherrill |
+ Added check for priority over 256.
+ Modified output to correctly …
4.104.114.84.95
@8ed3125d
11/12/99 21:24:56 |
Joel Sherrill |
Added comments for path's tested.
4.104.114.84.95
@d8f3f65b
11/12/99 21:23:34 |
Joel Sherrill |
+ Changed validation of the_thread to validation of location.
4.104.114.84.95
@2979c28
11/12/99 21:21:09 |
Joel Sherrill |
4.104.114.84.95
@3971537
11/12/99 21:20:04 |
Joel Sherrill |
4.104.114.84.95
@037a7b1
11/12/99 21:18:36 |
Joel Sherrill |
+ Moved error checks to before the disable dispatch where possible.
4.104.114.84.95
@0c5ab522
11/12/99 21:16:45 |
Joel Sherrill |
Added comment about the E_CTX error condition (Implementation dependent).
4.104.114.84.95
@c257429f
11/12/99 21:15:12 |
Joel Sherrill |
+ Moved error checks to before the dispatch disable where possible.
4.104.114.84.95
@2183b65
11/12/99 21:13:52 |
Joel Sherrill |
+ Modified correct return path to call _ITRON_return_errorno( E_OK ) …
4.104.114.84.95
@ea6bfcb
11/12/99 21:12:27 |
Joel Sherrill |
4.104.114.84.95
@6af81435
11/12/99 15:54:48 |
Joel Sherrill |
Corrected so now actually indexes into the allocation block.
4.104.114.84.95
@1925ec9b
11/12/99 15:54:07 |
Joel Sherrill |
Corrected remaining references to struct rtems_task_variable_t since …
4.104.114.84.95
@a8d72dea
11/12/99 15:53:29 |
Joel Sherrill |
Removed unnecessary 3rd parameter.
4.104.114.84.95
@6bd132e5
11/12/99 15:37:09 |
Joel Sherrill |
New file.
4.104.114.84.95
@95bb279
11/12/99 14:54:13 |
Joel Sherrill |
Used typedef so all "struct rtems_task_variable_t" uses are now
just …
4.104.114.84.95
@884b460
11/12/99 14:52:36 |
Joel Sherrill |
Added per-task variable data stucture (rtems_task_variable_t), …
4.104.114.84.95
@f4771656
11/12/99 14:51:03 |
Joel Sherrill |
Test name changed to reflect placement after merger.
4.104.114.84.95
@ec0b5ce
11/12/99 14:50:42 |
Joel Sherrill |
Changed output …
4.104.114.84.95
@3136f5c9
11/12/99 14:49:47 |
Joel Sherrill |
Increased stack …
4.104.114.84.95
@5aa5560
11/12/99 14:38:19 |
Joel Sherrill |
Added per task variables based on patch from Eric Norum …
4.104.114.84.95
@3c49a508
11/12/99 14:15:50 |
Joel Sherrill |
Cleaned up style.
4.104.114.84.95
@3ad17f5
11/12/99 13:46:04 |
Joel Sherrill |
Removed redundant line.
4.104.114.84.95
@6977b38
11/12/99 13:45:39 |
Joel Sherrill |
Enabled after merging message buffer code.
4.104.114.84.95
@f9078d1
11/12/99 13:22:31 |
Joel Sherrill |
Added comment block and removed include of deleted file.
4.104.114.84.95
@d102810e
11/11/99 02:39:12 |
Joel Sherrill |
Updated.
4.104.114.84.95
@dc83752
11/11/99 02:23:26 |
Joel Sherrill |
Screen updated.
4.104.114.84.95
@458d4e66
11/11/99 02:23:04 |
Joel Sherrill |
Added new test sp28 to test the task variable directives.
4.104.114.84.95
@713b2ea
11/10/99 22:15:42 |
Joel Sherrill |
General cleanup. Test documentation improved. The message buffer …
4.104.114.84.95
@59d1127
11/10/99 22:14:26 |
Joel Sherrill |
Corrected to account for the way memory is divided up in …
4.104.114.84.95
@7d29dc7f
11/10/99 22:13:42 |
Joel Sherrill |
Added line to make sure HAS_ITRON_API is defined in Makefile.
4.104.114.84.95
