# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 05/18/24 19:17:08 Tue, 02 Jul 2013 13:14:51 GMT Sebastian Huber [d91d50f] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/get-system-clock.c (modified) bsp/mpc55xx: Avoid integer overflow Tue, 02 Jul 2013 13:13:54 GMT Sebastian Huber [c97d3dd] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-clock.c (modified) bsp/mpc55xx: Round PLL divider up Mon, 24 Jun 2013 15:14:08 GMT Ralf Kirchner [cd7db89] * c/src/lib/libbsp/powerpc/psim/make/custom/psim.cfg (modified) bsp/psim: Use EABI and System V small-data area Mon, 24 Jun 2013 15:16:16 GMT Ralf Kirchner [3da02169] * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) bsps/powerpc: Avoid placement in small-data area Mon, 24 Jun 2013 15:15:42 GMT Ralf Kirchner [1b47871d] * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) bsp/psim: Fix declaration It declares a symbol defined in the ... Fri, 28 Jun 2013 19:26:59 GMT Sebastian Huber [3b645c1] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/shared/arm-pl050.c (added) * c/src/lib/libbsp/arm/shared/include/arm-pl050-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl050.h (added) bsps/arm: Add PL050 support Sun, 23 Jun 2013 12:39:47 GMT Sebastian Huber [c8312b3] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/fb-config.c (added) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (added) * c/src/lib/libbsp/arm/shared/include/arm-pl111-fb.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl111-regs.h (added) bsps/arm: Add PL111 support Fri, 28 Jun 2013 19:26:11 GMT Sebastian Huber [e310dcd] * c/src/libchip/serial/serial.h (modified) libchip/serial: Add const qualifier Sun, 23 Jun 2013 15:50:55 GMT Sebastian Huber [311ba73] * c/src/lib/libbsp/arm/gumstix/fb/fb.c (modified) * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * cpukit/libcsupport/include/rtems/framebuffer.h (modified) framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME Sat, 29 Jun 2013 12:00:39 GMT Sebastian Huber [98db96e] * c/src/make/compilers/gcc-target-default.cfg (modified) make: Use C flags for C++ as default In case a BSP selects special ... Fri, 28 Jun 2013 13:05:30 GMT Sebastian Huber [40ce265] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/startup/psim_registers.c (deleted) bsp/psim: Use plain symbol for PSIM This avoids a linker assertion ... Fri, 28 Jun 2013 07:07:13 GMT Sebastian Huber [4800ffe] * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Update debug sections Fri, 28 Jun 2013 07:03:11 GMT Sebastian Huber [ca59217] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) bsps/arm: Set vector base on all processors Wed, 26 Jun 2013 07:40:44 GMT Sebastian Huber [a3a4cd5] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Move input sections Move input sections to preserve order ... Wed, 26 Jun 2013 08:25:42 GMT Sebastian Huber [56435e6] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix Altivec support Use the right context. Fri, 21 Jun 2013 07:59:27 GMT Sebastian Huber [4b83e8f1] * c/src/lib/libbsp/arm/shared/arm-cp15-set-exception-handler.c (modified) bsps/arm: Fix set exception handler for ARMv7 Mon, 24 Jun 2013 15:29:11 GMT Sebastian Huber [e18db9f] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf52235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c (modified) termios: Update due to API changes Termios notifies now the driver ... Mon, 24 Jun 2013 09:00:36 GMT Sebastian Huber [1df348b] * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) bsps/arm: Rename function Rename ... Fri, 21 Jun 2013 15:17:28 GMT Sebastian Huber [e916b125] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Use shared clock driver Thu, 20 Jun 2013 14:22:16 GMT Sebastian Huber [0110491] * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) bsp/virtex: Add console devices only if present Thu, 20 Jun 2013 14:20:43 GMT Sebastian Huber [dbf62b3] * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) bsp/virtex: Fix warnings Thu, 20 Jun 2013 12:33:19 GMT Sebastian Huber [c4cfc62] * c/src/lib/libbsp/powerpc/virtex/include/opbintctrl.h (modified) bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR This define is also ... Thu, 20 Jun 2013 12:32:12 GMT Sebastian Huber [dfb5805] * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) bsp/virtex: Remove unused configure macros Tue, 18 Jun 2013 14:42:25 GMT Sebastian Huber [53dc697] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete BSP_ask_for_reset and BSP_panic Tue, 18 Jun 2013 15:20:28 GMT Sebastian Huber [39c1534f] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/opbintctrl.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex/opbintctrl/opbintctrl.c (deleted) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Use generic interrupt support Tue, 18 Jun 2013 14:44:40 GMT Sebastian Huber [894e93f] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Fix header includes Tue, 18 Jun 2013 14:39:24 GMT Sebastian Huber [bee7612e] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/timer/timer-config.c (added) bsp/virtex: Move timer config to new file Tue, 18 Jun 2013 14:27:42 GMT Sebastian Huber [48ab8465] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Do not use PPC403 TTY driver Tue, 18 Jun 2013 14:26:25 GMT Sebastian Huber [ad094f4] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Fix warnings Tue, 18 Jun 2013 14:25:53 GMT Sebastian Huber [b45397fb] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete bsp_XAssertHandler() Tue, 18 Jun 2013 14:24:10 GMT Sebastian Huber [ff538bbf] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete unused variables Tue, 18 Jun 2013 14:12:56 GMT Sebastian Huber [0ba2736] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/README (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/start/start.S (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/startup/linkcmds (deleted) * c/src/lib/libbsp/powerpc/virtex/startup/linkcmds.in (added) bsp/virtex: Replace low-level BSP start code Use linkcmds.base. ... Tue, 18 Jun 2013 13:19:19 GMT Sebastian Huber [546c1056] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/bsp_specs (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/start/start.S (moved) bsp/virtex: Rename file dlentry.S in start.S Use default bsp_specs file. Fri, 21 Jun 2013 15:16:37 GMT Sebastian Huber [509e0f3f] * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) bsps/powerpc: Add PPC405 support for shared clock Fri, 21 Jun 2013 14:19:46 GMT Sebastian Huber [7d0e88f2] * c/src/lib/libcpu/powerpc/ppc403/clock/clock_4xx.c (deleted) bsps/powerpc: Delete clock_4xx.c Fri, 21 Jun 2013 13:10:48 GMT Sebastian Huber [27b207a8] * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/shared/bspreset_fatal.c (deleted) bsps: Delete bspreset_fatal.c Use bspreset_loop.c instead. This ... Thu, 20 Jun 2013 09:03:45 GMT Sebastian Huber [f97f46ce] * c/src/libchip/serial/ns16550.c (modified) libchip/serial: Fix warning Tue, 18 Jun 2013 15:47:41 GMT Sebastian Huber [c9db7f9] * c/src/lib/libbsp/shared/console.c (modified) bsps: Use CONSOLE_DEVICE_NAME Tue, 18 Jun 2013 15:45:50 GMT Sebastian Huber [a4bc725e] * c/src/lib/libbsp/shared/console.c (modified) bsps: Remove debug output in shared console driver Thu, 20 Jun 2013 10:00:29 GMT Sebastian Huber [37220fac] * c/src/lib/libbsp/shared/console_select.c (modified) bsps: Do not use printk() in shared console driver Thu, 20 Jun 2013 09:57:34 GMT Sebastian Huber [6307b1a] * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_select.c (modified) * c/src/lib/libbsp/shared/include/generic-fatal.h (modified) bsps: Add fatal errors for shared console driver Thu, 20 Jun 2013 09:44:04 GMT Sebastian Huber [ade27c6] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) * c/src/lib/libbsp/preinstall.am (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/shared/include/generic-fatal.h (added) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) bsps: Move bsp_generic_fatal_code to new file Add bsp_generic_fatal(). Thu, 20 Jun 2013 09:17:23 GMT Sebastian Huber [5f91272] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Delete bsp_exceptions_in_RAM Delete ... Thu, 20 Jun 2013 07:48:27 GMT Ric Claus [cddb8f4] * c/src/lib/libbsp/arm/shared/include/arm-gic.h (modified) bsps/arm: Fix some GIC functions Wed, 19 Jun 2013 09:20:06 GMT Sebastian Huber [9a037da9] * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Set vector base address if necessary Sun, 16 Jun 2013 13:40:03 GMT Jiri Gaisler [45fecbb6] * c/src/libchip/network/greth.c (modified) greth: do not advertise 1000M capability if MAC does not support it. Sun, 16 Jun 2013 13:28:20 GMT Jiri Gaisler [1bdc6d1] * c/src/libchip/network/greth.c (modified) greth: prefer full duplex if available Wed, 19 Jun 2013 10:57:54 GMT Sebastian Huber [cb6b9ba] * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Use magic UART baud divisor Use a baud divisor ... Wed, 19 Jun 2013 10:57:26 GMT Sebastian Huber [3f6a823] * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Do not start transmitter break Tue, 18 Jun 2013 07:18:21 GMT Sebastian Huber [49bc9f81] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Use second UART for console This is in now line ... Mon, 17 Jun 2013 07:57:42 GMT Sebastian Huber [cf46db85] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/shared/console_select_simple.c (added) bsps: Provide simple console selection Mon, 17 Jun 2013 07:57:08 GMT Sebastian Huber [9f868a16] * c/src/lib/libbsp/shared/console_private.h (modified) bsps: Add missing include Fri, 14 Jun 2013 12:26:34 GMT Sebastian Huber [edde99b] * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp04/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpatomic02/init.c (modified) * testsuites/smptests/smpatomic03/init.c (modified) * testsuites/smptests/smpatomic04/init.c (modified) * testsuites/smptests/smpatomic05/init.c (modified) * testsuites/smptests/smpatomic06/init.c (modified) * testsuites/smptests/smpatomic07/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Rename rtems_smp_get_number_of_processors() Rename in ... Wed, 12 Jun 2013 07:25:39 GMT Sebastian Huber [49cdf40] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/support/include/tmacros.h (modified) score: Add and use _Thread_Dispatch_is_enabled() Delete ... Mon, 10 Jun 2013 12:11:07 GMT Sebastian Huber [15f3a91] * c/src/libchip/serial/ns16550.c (modified) libchip: Use Termios API change for NS16550 This avoids a race ... Mon, 10 Jun 2013 12:07:13 GMT Sebastian Huber [6896ca2] * c/src/libchip/serial/ns16550.c (modified) libchip: Delete superfluous assignments Mon, 10 Jun 2013 08:10:43 GMT Sebastian Huber [aec0e195] * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-multiprocessing.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) configure: Documentation Fri, 07 Jun 2013 09:50:37 GMT Sebastian Huber [18e2fbe7] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) smp: Fix PowerPC context switch Mon, 03 Jun 2013 08:03:44 GMT Sebastian Huber [8bed603] * c/src/lib/libbsp/arm/lm3s69xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) bsp/lm3s69xx: Typos Mon, 03 Jun 2013 08:03:10 GMT Sebastian Huber [94c17af] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Add missing #ifdef RTEMS_SMP Fri, 31 May 2013 11:59:47 GMT Sebastian Huber [db42c079] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/README (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu_smp.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu (moved) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu_smp (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (added) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu (moved) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp (added) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add SMP support Fri, 31 May 2013 11:59:34 GMT Sebastian Huber [f2f211c5] * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpusmplock.h (added) smp: Add ARM support Fri, 31 May 2013 08:08:43 GMT Sebastian Huber [bd39add] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (added) bsp/qoriq: Add SMP support Fri, 18 Jan 2013 08:42:49 GMT Sebastian Huber [ffbeb6f] * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * cpukit/aclocal/enable-smp.m4 (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpusmplock.h (added) smp: Add PowerPC support Mon, 27 May 2013 15:31:46 GMT Sebastian Huber [e3be6915] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) score: Remove idle field of Per_CPU_Control This field is unused ... Mon, 27 May 2013 15:29:47 GMT Sebastian Huber [17e09f8e] * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (modified) bsps: Use _Objects_Information_table Eliminate copy and paste. Use ... Fri, 31 May 2013 08:00:07 GMT Sebastian Huber [5b391f85] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Use Write-Allocate cache for ARMv7 Fri, 31 May 2013 07:59:27 GMT Sebastian Huber [1dcf5fe] * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Merge ARMv7 MMU section definitions Tue, 28 May 2013 08:58:19 GMT Sebastian Huber [2f6108f9] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/shared/smp/bspsmp_wait_for.c (deleted) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/smp.c (modified) smp: Simplify SMP initialization sequence Delete ... Tue, 14 May 2013 11:23:10 GMT Sebastian Huber [8cacceb] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/src/smp.c (modified) smp: Delete bsp_smp_secondary_cpu_initialize() Do not call ... Tue, 14 May 2013 08:12:52 GMT Sebastian Huber [baf8f4d] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/src/percpu.c (modified) smp: Simplify main CPU initialization Call ... Tue, 21 May 2013 13:58:12 GMT Sebastian Huber [9344677] * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) bsp/qoriq: Avoid NULL pointer access Mon, 13 May 2013 07:42:51 GMT Sebastian Huber [9984acd] * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsps/arm: Add CLOCK_DRIVER_USE_FAST_IDLE option Mon, 27 May 2013 10:43:53 GMT Sebastian Huber [0d671d70] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Move .fast_text section Move the .fast_text section after ... Tue, 21 May 2013 12:19:24 GMT Sebastian Huber [cab410f] * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) bsps: Update due to linker changes In case the VMA and LMA regions ... Mon, 13 May 2013 11:37:06 GMT Sebastian Huber [6c2eedc] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/thread.c (modified) smp: Add maximum_processors field to config Delete ... Wed, 15 May 2013 15:46:37 GMT Daron Chabot [5e45d36] * c/src/lib/libbsp/shared/vmeUniverse/VME.h (modified) Add c++ guard to header. Wed, 08 May 2013 07:30:31 GMT Sebastian Huber [cfd8d7a] * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Support VFP-D32 and Neon Mon, 06 May 2013 12:34:55 GMT Sebastian Huber [a94d46c8] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (added) * c/src/lib/libbsp/arm/xilinx-zynq/README (added) * c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs (added) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (added) * c/src/lib/libbsp/arm/xilinx-zynq/console/console-config.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/tm27.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart-regs.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspreset.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds (added) bsp/xilinx-zynq: New BSP Mon, 06 May 2013 12:01:10 GMT Sebastian Huber [12d182c4] * c/src/lib/libbsp/arm/shared/arm-pl011.c (modified) bsps/arm: Fix register usage Mon, 06 May 2013 08:59:07 GMT Sebastian Huber [e37d57bc] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-tm27.h (added) bsps/arm: Add shared GIC tmtests/tm27 support Mon, 06 May 2013 08:20:26 GMT Sebastian Huber [33c98fd] * c/src/lib/libbsp/arm/shared/arm-cp15-set-exception-handler.c (modified) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Remove superfluous parameter Mon, 06 May 2013 07:59:16 GMT Sebastian Huber [f2e9d0d] * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) bsp/raspberrypi: Use shared start code Mon, 06 May 2013 07:54:02 GMT Sebastian Huber [86b79fb] * c/src/lib/libbsp/arm/lm3s69xx/console/uart.c (modified) bsp/lm3s69xx: Fix initialization value Sun, 05 May 2013 22:02:07 GMT Eugeniy Meshcheryakov [9bc1913e] * c/src/lib/libbsp/arm/lm3s69xx/console/uart.c (modified) bsp/lm3s69xx: Use interrupts for UART receive This makes continuous ... Sun, 05 May 2013 22:02:06 GMT Eugeniy Meshcheryakov [847e2cac] * c/src/lib/libbsp/arm/lm3s69xx/include/lm3s69xx.h (modified) bsp/lm3s69xx: More access macros for UART data register Add mask ... Mon, 06 May 2013 07:37:12 GMT Alan Cudmore [9159711] * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) bsp/raspberrypi: Enable unaligned access Fri, 26 Apr 2013 13:06:32 GMT Sebastian Huber [a91dc98b] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/README (added) * c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs (added) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (added) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspreset.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (added) * c/src/lib/libbsp/arm/shared/arm-pl011.c (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (added) bsp/realview-pbx-a9: New BSP Thu, 02 May 2013 11:37:30 GMT Sebastian Huber [9ce65803] * c/src/lib/libbsp/arm/shared/start/start.S (modified) bsps/arm: Copy vector table only if necessary Thu, 02 May 2013 11:36:03 GMT Sebastian Huber [27690ec3] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Move .vector section The .vector section contains ... Thu, 02 May 2013 09:41:22 GMT Sebastian Huber [ecf7dd9] * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (added) bsps/arm: Move CP15 start initialization Thu, 02 May 2013 09:09:24 GMT Sebastian Huber [fd51f7e] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Support ARMv7 VMSA sections and control Tue, 30 Apr 2013 13:23:45 GMT Sebastian Huber [88cf23f8] * c/src/lib/libbsp/arm/shared/arm-cp15-set-exception-handler.c (added) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_set_exception_handler() Thu, 02 May 2013 15:42:20 GMT Sebastian Huber [037e8ae5] * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/include/mmu.h (modified) * c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c (moved) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_set_trans*_table_entries() Thu, 02 May 2013 15:41:11 GMT Sebastian Huber [544615d] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_mmu_disable() Thu, 02 May 2013 15:40:45 GMT Sebastian Huber [d2d02961] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_get_min_cache_line_size() Thu, 02 May 2013 09:18:09 GMT Sebastian Huber [962e0fac] * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) bsps/arm: Add and use bsp_translation_table_base Fri, 03 May 2013 08:39:26 GMT Sebastian Huber [fb0584f] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstarthook.c (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/startup/bsp-start-copy-sections.c (deleted) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstarthook.c (modified) bsps/arm: Move implementation to inline functions Tue, 30 Apr 2013 17:31:29 GMT Joel Sherrill [5aa4ed9] * c/src/lib/libbsp/i386/pc386/make/custom/pc386dx.cfg (deleted) * c/src/lib/libbsp/i386/pc386/make/custom/pc586-sse.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pcp4.cfg (modified) i386: PR2010: Remove pc386 BSPs using soft-float i386 soft-float is ... Mon, 29 Apr 2013 07:28:58 GMT Sebastian Huber [024a572] * c/src/lib/libcpu/powerpc/mpc55xx/include/siu.h (modified) bsp/mpc55xx: Avoid empty enum
