# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 06/01/24 06:22:53 Wed, 20 Sep 2017 05:18:53 GMT Sebastian Huber [d7ed684] * c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c (modified) bsps/powerpc: Fix PPC_EXC_CONFIG_USE_FIXED_HANDLER Fix link-time ... Tue, 19 Sep 2017 12:40:06 GMT Sebastian Huber [4c1f442] * c/src/lib/libbsp/powerpc/qoriq/README (modified) bsp/qoriq: Update README Close #3085. Tue, 19 Sep 2017 12:35:02 GMT Sebastian Huber [f100a58] * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) bsp/qoriq: Add hypervisor guest SMP support Update #3085. Tue, 19 Sep 2017 12:34:21 GMT Sebastian Huber [31540bfb] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: MMU configuration as hypervisor guest Re-enable MMU ... Tue, 19 Sep 2017 08:19:30 GMT Sebastian Huber [2720fbf0] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Avoid IVOR38..42 access as hv guest Update #3085. Tue, 19 Sep 2017 08:16:05 GMT Sebastian Huber [6600882b] * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) bsp/qoriq: Avoid MAS8 access as hypervisor guest Update #3085. Tue, 19 Sep 2017 08:06:19 GMT Sebastian Huber [44c0114] * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 (modified) bsp/qoriq: Reduce static memory demands Update #3085. Tue, 19 Sep 2017 07:12:02 GMT Sebastian Huber [ec28f31] * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Add decrementer clock driver Update #3085. Mon, 18 Sep 2017 09:28:26 GMT Sebastian Huber [fd70e206] * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) bsp/qoriq: Add early debug output initialization Update #3085. Tue, 19 Sep 2017 07:02:30 GMT Sebastian Huber [599e6fbd] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: PPC_EXC_CONFIG_USE_FIXED_HANDLER Make ... Mon, 18 Sep 2017 06:22:38 GMT Sebastian Huber [f3b29236] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-generic-timer-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/av5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/clock.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/clock/clockdrv.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) bsps: Clock_driver_support_install_isr() Remove old ISR parameter ... Wed, 13 Sep 2017 08:35:45 GMT Sebastian Huber [a937a5a] * c/src/lib/libbsp/shared/console.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) libio: Add rtems_libio_iop_is_readable() Update #3132. Wed, 13 Sep 2017 08:13:18 GMT Sebastian Huber [ead1281f] * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) bsp/mrm332: Remove dead code Update #3132. Fri, 08 Sep 2017 08:11:20 GMT Sebastian Huber [df62e51] * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) bsp/qoriq: Virtual interrupt controller support Update #3085. Fri, 08 Sep 2017 08:11:32 GMT Sebastian Huber [134fe569] * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) bsp/qoriq: Add byte channel console driver Update #3085. Fri, 08 Sep 2017 06:10:26 GMT Sebastian Huber [356b1b85] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/include/asm/epapr_hcalls.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/asm/fsl_hcalls.h (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/epapr_hcalls.S (added) bsp/qoriq: Port ePAPR hcall interface to RTEMS Update #3085. Fri, 08 Sep 2017 05:45:47 GMT Sebastian Huber [0d51c05b] * c/src/lib/libbsp/powerpc/qoriq/include/asm/epapr_hcalls.h (added) * c/src/lib/libbsp/powerpc/qoriq/include/asm/fsl_hcalls.h (added) * c/src/lib/libbsp/powerpc/qoriq/include/uapi/asm/epapr_hcalls.h (added) bsp/qoriq: Import ePAPR hcalls from Linux 4.12 Update #3085. Fri, 08 Sep 2017 08:11:48 GMT Sebastian Huber [b742de2] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Boot page translation Do not mingle with the boot page ... Fri, 08 Sep 2017 08:50:08 GMT Sebastian Huber [0ce5bfb] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Do not touch MMU as hypervisor guest Update #3085. Thu, 07 Sep 2017 10:49:18 GMT Sebastian Huber [20fc4f9] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) bsp/qoriq: Add QORIQ_IS_HYPERVISOR_GUEST Update #3085. Fri, 08 Sep 2017 06:51:07 GMT Sebastian Huber [458179f1] * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Remove console stuff from bsp_start() Update #3085. Fri, 08 Sep 2017 08:38:46 GMT Sebastian Huber [1bc0ad2] * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (modified) * c/src/lib/libbsp/arm/atsam/console/debug-console.c (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/imx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console-config.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/arm/rtl22xx/console/uart.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.c (modified) * c/src/lib/libbsp/arm/smdk2410/console/uart.c (modified) * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/debug-console.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/debugio.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/mips/csb350/console/console-io.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-generic.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/console/console.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/dummy_console.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (modified) * c/src/lib/libbsp/shared/console-output-char.c (modified) * c/src/lib/libbsp/shared/src/uart-output-char.c (modified) * c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) Simplify and unify BSP_output_char The BSP_output_char should ... Wed, 06 Sep 2017 05:42:06 GMT Christian Mauderer [f7f420e] * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/mpu.h (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in (modified) bsp/atsam: Fix MPU sections. The nocache section has been hard ... Thu, 24 Aug 2017 14:02:33 GMT Daniel Hellstrom [8570ad2] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) leon,ambapp_bus: make unreferenced global function static Fixes #3072 Thu, 24 Aug 2017 13:41:38 GMT Daniel Hellstrom [efcac22] * c/src/lib/libbsp/sparc/shared/ascs/grascs.c (modified) leon,grascs: fix semaphore policies Closes #2726 Tue, 22 Aug 2017 10:51:18 GMT Daniel Hellstrom [7f13fae8] * c/src/lib/libbsp/sparc/shared/amba/ambapp.c (modified) leon,ambapp: fixes bad allocation check Updates #2496 but to close ... Tue, 22 Aug 2017 10:28:10 GMT Daniel Hellstrom [360fb2f] * c/src/lib/libbsp/sparc/shared/1553/gr1553b.c (modified) leon,gr1553b: improve init check Check in init3 not needed since ... Tue, 22 Aug 2017 08:57:41 GMT Daniel Hellstrom [1ccce05] * c/src/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/preinstall.am (modified) libchip,greth: disable driver if SMP kernel Update #2355 Tue, 22 Aug 2017 08:32:25 GMT Daniel Hellstrom [3471d3d] * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) leon,occan: remove dead code. Fixes #2878 Mon, 19 Jun 2017 10:43:13 GMT Daniel Hellstrom [6b339b5] * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) leon, grspw: for SMP use GRSPW Packet driver The GRSPW packet ... Sun, 27 Aug 2017 19:50:47 GMT Joel Sherrill [c58e4f5] * c/src/lib/libbsp/arm/gumstix/fb/fb.c (modified) fb/fb.c: include for memcpy() Fri, 25 Aug 2017 09:00:32 GMT Sebastian Huber [a97d77c] * c/src/lib/libbsp/arm/csb337/network/network.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_networking/network.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) Include missing Fri, 25 Aug 2017 08:59:52 GMT Sebastian Huber [1f22b26] * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) * c/src/lib/libbsp/i386/pc386/console/gdb_select.c (modified) * cpukit/libmisc/shell/main_cmdchown.c (modified) * cpukit/libmisc/shell/main_drvmgr.c (modified) * cpukit/libmisc/shell/main_pci.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/score/src/condition.c (modified) Include missing Update #2132. Fri, 25 Aug 2017 08:58:58 GMT Sebastian Huber [b2ed712] * c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-read-blocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-write-blocks.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console_select.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/versions.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) * c/src/lib/libbsp/sparc/shared/analog/gradcdac.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (modified) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c (modified) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (modified) * c/src/lib/libbsp/sparc/shared/time/grctm.c (modified) * c/src/lib/libbsp/sparc/shared/time/spwcuc.c (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.c (modified) * cpukit/dev/i2c/ti-lm25066a.c (modified) * cpukit/include/rtems/printer.h (modified) * cpukit/libcsupport/src/cfmakesane.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/libmisc/shell/main_rtrace.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/score/src/threadq.c (modified) Include missing Update #2133. Thu, 10 Aug 2017 09:37:30 GMT Sebastian Huber [695c9c50] * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_64-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_64.cfg (added) bsp/qoriq: Add qoriq_e6500_64 variant Update #3082. Wed, 02 Aug 2017 13:48:03 GMT Sebastian Huber [95a4b1f] * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Enable > 2GiB memory Update #3082. Fri, 11 Aug 2017 08:44:04 GMT Sebastian Huber [c693a3a] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) powerpc: PPC64_NOP_FOR_LINKER_TOC_POINTER_RESTORE In 64-bit mode, ... Wed, 02 Aug 2017 12:36:32 GMT Sebastian Huber [c8aeb76] * c/src/lib/libbsp/powerpc/qoriq/include/mmu.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu.c (modified) bsp/qoriq: 64-bit MMU support Update #3082. Thu, 10 Aug 2017 12:14:26 GMT Sebastian Huber [77c81016] * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) bsp/qoriq: 64-bit support for interrupt controller Update #3082. Wed, 02 Aug 2017 07:16:10 GMT Sebastian Huber [5f42a0e] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Enable 64-bit mode for exceptions Update #3082. Tue, 01 Aug 2017 06:42:45 GMT Sebastian Huber [f14da45] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) bsp/qoriq: 64-bit support for spin table Update #3082. Tue, 01 Aug 2017 06:41:07 GMT Sebastian Huber [0ae1916b] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Copy FDT later We need a ready to use TOC section before ... Thu, 10 Aug 2017 09:39:43 GMT Sebastian Huber [43cc2b4] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/bsp_specs (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/intercom.c (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_64 (added) bsp/qoriq: Add basic 64-bit support Update #3082. Mon, 31 Jul 2017 13:10:33 GMT Sebastian Huber [c6994af] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsp/qoriq: Use LA to load an address Add 64-bit support for LA. ... Tue, 01 Aug 2017 13:35:16 GMT Sebastian Huber [0e26c19a] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/bsp_specs (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/shared/start/rtems_crti.S (modified) * c/src/lib/libbsp/powerpc/shared/start/rtems_crtn.S (added) bsps/powerpc: Add 64-bit CRT init/fini support Update #3082. Tue, 01 Aug 2017 09:54:25 GMT Sebastian Huber [d50124d] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) bsps/powerpc: Rename ppc_exc_wrap_async_normal_end Rename ... Mon, 31 Jul 2017 13:25:12 GMT Sebastian Huber [50382788] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsps/powerpc: Add 64-bit SET_SELF_CPU_CONTROL Update #3082. Thu, 10 Aug 2017 09:38:46 GMT Sebastian Huber [60d077f] * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Add 64-bit linker sections Update #3082. Wed, 02 Aug 2017 12:13:06 GMT Sebastian Huber [241d2f2] * c/src/lib/libbsp/shared/src/bsp-fdt.c (modified) bsps: Fix integer types in bsp_fdt_copy() Update #3082. Tue, 01 Aug 2017 06:37:12 GMT Sebastian Huber [d8012bbd] * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/shared/src/bsp-fdt.c (modified) bsps: Add BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA Thu, 10 Aug 2017 12:23:02 GMT Sebastian Huber [ec25c6ef] * c/src/lib/libbsp/shared/src/irq-generic.c (modified) bsps: Fix integer to/from pointer Update #3082. Tue, 01 Aug 2017 08:57:46 GMT Sebastian Huber [a6f84b27] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Add 64-bit context/interrupt support Update #3082. Thu, 10 Aug 2017 11:09:22 GMT Sebastian Huber [7837728b] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: 64-bit _CPU_Context_Initialize() support Update #3082. Tue, 22 Aug 2017 09:37:41 GMT Sebastian Huber [5e1a831] * c/src/libchip/serial/ns16550-context.c (modified) libchip/serial: Fix integer types Update #3082. Thu, 10 Aug 2017 11:01:57 GMT Sebastian Huber [b98e407] * c/src/libchip/ide/ata.c (modified) libchip/ata: Fix integer to/from pointer Update #3082. Fri, 04 Aug 2017 12:46:17 GMT Sebastian Huber [ca9490c] * c/src/lib/libbsp/arm/imx/console/console-config.c (modified) bsp/imx: Fix UART interrupt Update #3090. Thu, 03 Aug 2017 06:53:13 GMT Sebastian Huber [694c31f9] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (added) * c/src/lib/libbsp/arm/imx/bsp_specs (added) * c/src/lib/libbsp/arm/imx/configure.ac (added) * c/src/lib/libbsp/arm/imx/console/console-config.c (added) * c/src/lib/libbsp/arm/imx/include/arm/freescale/imx/imx_ccmvar.h (added) * c/src/lib/libbsp/arm/imx/include/arm/freescale/imx/imx_uartreg.h (added) * c/src/lib/libbsp/arm/imx/include/bsp.h (added) * c/src/lib/libbsp/arm/imx/include/irq.h (added) * c/src/lib/libbsp/arm/imx/include/tm27.h (added) * c/src/lib/libbsp/arm/imx/make/custom/imx7.cfg (added) * c/src/lib/libbsp/arm/imx/preinstall.am (added) * c/src/lib/libbsp/arm/imx/startup/bspreset.c (added) * c/src/lib/libbsp/arm/imx/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/imx/startup/bspstart.c (added) * c/src/lib/libbsp/arm/imx/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/imx/startup/ccm.c (added) * c/src/lib/libbsp/arm/imx/startup/linkcmds.imx7 (added) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsp/imx: New BSP Update #3090. Fri, 04 Aug 2017 11:56:42 GMT Sebastian Huber [ffe7c0e] * c/src/lib/libbsp/arm/shared/arm-generic-timer-clock-config.c (added) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: Add ARMv7-AR Generic Timer clock driver Update #3090. Fri, 04 Aug 2017 11:51:42 GMT Sebastian Huber [ef04443] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add ARMv7-AR Generic Timer support Update #3090. Thu, 03 Aug 2017 12:48:04 GMT Sebastian Huber [30be024a] * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) Optional Clock_driver_support_shutdown_hardware() Make ... Tue, 01 Aug 2017 09:43:57 GMT Sebastian Huber [a8694035] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Add PPC_EXC_INTERRUPT_FRAME_SIZE Use a specific ... Tue, 01 Aug 2017 09:38:32 GMT Sebastian Huber [23cb9af] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) bsps/powerpc: Rename ppc_exc_wrap_async_normal Rename ... Mon, 31 Jul 2017 12:14:46 GMT Sebastian Huber [b7be9439] * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Do not set ouput format and arch There is no need to ... Mon, 31 Jul 2017 11:39:34 GMT Sebastian Huber [65ee42c] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (added) * c/src/lib/libcpu/powerpc/preinstall.am (modified) bsp/qoriq: Simplify fatal exceptions Avoid use of small-data area, ... Mon, 31 Jul 2017 11:35:21 GMT Sebastian Huber [2d0a805] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) bsps/powerpc: Fix format specifiers Fri, 28 Jul 2017 19:15:36 GMT Joel Sherrill [dd6992fd] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_edison.c (deleted) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/make/custom/edison.cfg (deleted) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspreset.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) Remove Edison BSP. Intel has obsoleted this hardware and the BSP ... Fri, 28 Jul 2017 16:27:54 GMT Joel Sherrill [9cb874d] * c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c (modified) beagle/i2c/bbb-i2c.c: Eliminiate set but not used warning Fri, 28 Jul 2017 13:39:39 GMT Sebastian Huber [8966e8a] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) bsp/qoriq: Fix pre-processor expansion Update #3082. Update #3085. Fri, 28 Jul 2017 13:03:47 GMT Sebastian Huber [5d0fa047] * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) bsp/t32mppc: Set PPC_PER_CPU_CONTROL_REGISTER Fri, 28 Jul 2017 12:42:53 GMT Sebastian Huber [585706a4] * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) bsp/t32mppc: Add SMP support Fri, 28 Jul 2017 11:50:12 GMT Sebastian Huber [cd7991b8] * c/src/lib/libbsp/powerpc/shared/src/memcpy.c (modified) bsps/powerpc: Fix warning Fri, 28 Jul 2017 11:40:45 GMT Sebastian Huber [9379c70] * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) bsps/sparc64: Fix warning Fri, 28 Jul 2017 11:10:19 GMT Sebastian Huber [0684f35] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) bsp/i386: Fix warning Fri, 28 Jul 2017 11:06:55 GMT Sebastian Huber [fd3437c] * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) bsp/gen5200: Fix warnings Fri, 28 Jul 2017 11:06:41 GMT Sebastian Huber [a9f5812] * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) bsp/qoriq: Fix warning Thu, 27 Jul 2017 13:36:11 GMT Sebastian Huber [0db7c55] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e500-testsuite.tcfg (moved) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e500.cfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_32-testsuite.tcfg (moved) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_32.cfg (moved) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_p1020rdb.cfg (deleted) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb-testsuite.tcfg (deleted) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb.cfg (deleted) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e500 (moved) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 (moved) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_t4240rdb (deleted) bsp/qoriq: New BSP names Due to the FDT support we can now reduce ... Thu, 27 Jul 2017 13:16:36 GMT Sebastian Huber [b615e9b] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Simplify initialization Do not flush/invalidate the ... Mon, 17 Jul 2017 05:30:46 GMT Sebastian Huber [146adb1] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (deleted) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * testsuites/sptests/spfatal30/init.c (modified) * testsuites/sptests/spfatal31/init.c (modified) * testsuites/sptests/spsize/size.c (modified) sparc: Add lazy floating point switch The SPARC ABI is a bit ... Wed, 19 Jul 2017 07:07:17 GMT Sebastian Huber [600d88d] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal30/Makefile.am (added) * testsuites/sptests/spfatal30/init.c (added) * testsuites/sptests/spfatal30/spfatal30.doc (added) * testsuites/sptests/spfatal30/spfatal30.scn (added) * testsuites/sptests/spfatal31/Makefile.am (added) * testsuites/sptests/spfatal31/init.c (added) * testsuites/sptests/spfatal31/spfatal31.doc (added) * testsuites/sptests/spfatal31/spfatal31.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT Add new fatal ... Tue, 18 Jul 2017 13:11:41 GMT Sebastian Huber [a400d06f] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Rename SPARC_USE_SAFE_FP_SUPPORT Rename ... Wed, 19 Jul 2017 12:06:06 GMT Sebastian Huber [671efc50] * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/make/custom/at697f.cfg (added) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds.at697f (added) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds.leon2 (added) bsp/leon2: Add at697f variant Wed, 19 Jul 2017 12:05:24 GMT Sebastian Huber [9f84bdb] * c/src/lib/libbsp/sparc/leon2/make/custom/leon2.cfg (modified) bsp/leon2: Use hard-float by default Wed, 19 Jul 2017 13:54:16 GMT Sebastian Huber [7ed8ad0] * c/src/lib/libcpu/sparc/cache/cache_.h (modified) bsps/sparc: Fix cache support Fix infinite loop in ... Wed, 19 Jul 2017 12:29:41 GMT Sebastian Huber [734444ce] * c/src/libchip/network/smc91111.c (modified) libchip: Fix format warning Wed, 19 Jul 2017 12:26:19 GMT Sebastian Huber [dcc3ccc] * c/src/lib/libbsp/shared/src/irq-server.c (modified) bsps: Fix warning Update #3071. Fri, 14 Jul 2017 12:12:07 GMT Daniel Cederman [4debaca6] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg (added) * c/src/lib/libbsp/sparc/leon3/make/custom/gr740.cfg (moved) * c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg (added) * c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg (added) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc (added) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr740 (moved) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699 (added) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700 (added) bsps/sparc: Add leon3 BSP variants Rename NGMP to GR740 and add ... Thu, 13 Jul 2017 07:26:50 GMT Daniel Cederman [2f8704b6] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Add assembly workaround for LEON3FT B2BST errata This patch ... Wed, 12 Jul 2017 08:55:59 GMT Sebastian Huber [e19da87a] * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) bsps: Include missing header file Update #3071. Tue, 11 Jul 2017 10:51:19 GMT Sichen Zhao <1473996754@…> [f6115d7c] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) bsp/beagle: Add FDT support for Beaglebone Black Tue, 11 Jul 2017 09:54:30 GMT Sebastian Huber [af207fa9] * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/eirq.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/score/include/rtems/score/processormask.h (modified) Add interrupt vector set/get affinity Close #3071. Tue, 11 Jul 2017 09:20:06 GMT Sebastian Huber [ccc87c8b] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add interrupt server move Update #3071. Tue, 11 Jul 2017 07:08:15 GMT Sebastian Huber [d184140] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add interrupt server set affinity Update #3071. Tue, 11 Jul 2017 06:48:15 GMT Sebastian Huber [a961e198] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) Add interrupt server suspend/resume This mechanism can be used to ... Tue, 11 Jul 2017 06:25:09 GMT Sebastian Huber [e7ee719f] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Create one interrupt server per processor This allows load ... Tue, 11 Jul 2017 12:15:47 GMT Sebastian Huber [c29eb085] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) bsps/sparc: Fix ambapp_int_set_affinity() Update #3059. Fri, 07 Jul 2017 05:45:57 GMT Sebastian Huber [76d1198] * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Introduce _SMP_Get_online_processors() Update #3059. Mon, 03 Jul 2017 09:46:12 GMT Sebastian Huber [3dfe55ee] * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Use for Processor_mask Implement the ... Fri, 23 Jun 2017 09:51:14 GMT Sebastian Huber [5bfeab95] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add rtems_interrupt_server_handler_iterate() Thu, 15 Jun 2017 17:40:25 GMT Joel Sherrill [ec230fc7] * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) i386/shared/comm/i386-stub-glue.c: Fix duplicate const warning Thu, 15 Jun 2017 17:40:04 GMT Joel Sherrill [9177426] * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) lpc176x/misc/restart.c: Fix duplicate const warning
