# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 04/18/24 14:48:00 Thu, 23 May 1996 20:43:04 GMT Joel Sherrill [d1d7e807] * c/src/tests/psxtests/psxhdrs/signal15.c (added) * c/src/tests/psxtests/psxhdrs/signal16.c (added) * c/src/tests/psxtests/psxhdrs/signal17.c (added) * c/src/tests/psxtests/psxhdrs/signal18.c (added) * c/src/tests/psxtests/psxhdrs/signal19.c (added) * testsuites/psxtests/psxhdrs/signal15.c (added) * testsuites/psxtests/psxhdrs/signal16.c (added) * testsuites/psxtests/psxhdrs/signal17.c (added) * testsuites/psxtests/psxhdrs/signal18.c (added) * testsuites/psxtests/psxhdrs/signal19.c (added) new files Thu, 23 May 1996 20:37:09 GMT Joel Sherrill [a1c86cbe] * c/src/tests/psxtests/psxhdrs/signal11.c (added) * c/src/tests/psxtests/psxhdrs/signal12.c (added) * c/src/tests/psxtests/psxhdrs/signal13.c (added) * c/src/tests/psxtests/psxhdrs/signal14.c (added) * testsuites/psxtests/psxhdrs/signal11.c (added) * testsuites/psxtests/psxhdrs/signal12.c (added) * testsuites/psxtests/psxhdrs/signal13.c (added) * testsuites/psxtests/psxhdrs/signal14.c (added) new files Thu, 23 May 1996 19:56:49 GMT Joel Sherrill [3d135eea] * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched02.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched04.c (modified) * c/src/tests/psxtests/psxhdrs/sched05.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * c/src/tests/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) cleanup Thu, 23 May 1996 19:54:08 GMT Joel Sherrill [d3fed0a3] * c/src/tests/psxtests/psxhdrs/sched01.c (added) * c/src/tests/psxtests/psxhdrs/sched02.c (added) * c/src/tests/psxtests/psxhdrs/sched03.c (added) * c/src/tests/psxtests/psxhdrs/sched04.c (added) * c/src/tests/psxtests/psxhdrs/sched05.c (added) * c/src/tests/psxtests/psxhdrs/sched06.c (added) * c/src/tests/psxtests/psxhdrs/sched07.c (added) * c/src/tests/psxtests/psxhdrs/sched08.c (added) * testsuites/psxtests/psxhdrs/sched01.c (added) * testsuites/psxtests/psxhdrs/sched02.c (added) * testsuites/psxtests/psxhdrs/sched03.c (added) * testsuites/psxtests/psxhdrs/sched04.c (added) * testsuites/psxtests/psxhdrs/sched05.c (added) * testsuites/psxtests/psxhdrs/sched06.c (added) * testsuites/psxtests/psxhdrs/sched07.c (added) * testsuites/psxtests/psxhdrs/sched08.c (added) new files Thu, 23 May 1996 19:31:54 GMT Joel Sherrill [02bfc56] * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * c/src/tests/psxtests/psxhdrs/pthread26.c (modified) * c/src/tests/psxtests/psxhdrs/pthread27.c (modified) * c/src/tests/psxtests/psxhdrs/pthread28.c (modified) * c/src/tests/psxtests/psxhdrs/pthread29.c (modified) * c/src/tests/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) cleanup status vs. result Thu, 23 May 1996 19:23:54 GMT Joel Sherrill [318ac69] * c/src/tests/psxtests/psxhdrs/pthread32.c (added) * c/src/tests/psxtests/psxhdrs/pthread33.c (added) * c/src/tests/psxtests/psxhdrs/pthread34.c (added) * c/src/tests/psxtests/psxhdrs/pthread35.c (added) * c/src/tests/psxtests/psxhdrs/pthread36.c (added) * testsuites/psxtests/psxhdrs/pthread32.c (added) * testsuites/psxtests/psxhdrs/pthread33.c (added) * testsuites/psxtests/psxhdrs/pthread34.c (added) * testsuites/psxtests/psxhdrs/pthread35.c (added) * testsuites/psxtests/psxhdrs/pthread36.c (added) new files Thu, 23 May 1996 19:09:21 GMT Joel Sherrill [7af3a828] * c/src/tests/psxtests/psxhdrs/pthread28.c (added) * c/src/tests/psxtests/psxhdrs/pthread29.c (added) * c/src/tests/psxtests/psxhdrs/pthread30.c (added) * c/src/tests/psxtests/psxhdrs/pthread31.c (added) * testsuites/psxtests/psxhdrs/pthread28.c (added) * testsuites/psxtests/psxhdrs/pthread29.c (added) * testsuites/psxtests/psxhdrs/pthread30.c (added) * testsuites/psxtests/psxhdrs/pthread31.c (added) new files Thu, 23 May 1996 19:04:18 GMT Joel Sherrill [f2cb4ac] * c/src/tests/psxtests/psxhdrs/key04.c (added) * c/src/tests/psxtests/psxhdrs/pthread27.c (added) * testsuites/psxtests/psxhdrs/key04.c (added) * testsuites/psxtests/psxhdrs/pthread27.c (added) new files Thu, 23 May 1996 18:55:32 GMT Joel Sherrill [57fc51c] * c/src/tests/psxtests/psxhdrs/mutex14.c (added) * c/src/tests/psxtests/psxhdrs/mutex15.c (added) * c/src/tests/psxtests/psxhdrs/mutex16.c (added) * c/src/tests/psxtests/psxhdrs/pthread24.c (added) * c/src/tests/psxtests/psxhdrs/pthread25.c (added) * c/src/tests/psxtests/psxhdrs/pthread26.c (added) * testsuites/psxtests/psxhdrs/mutex14.c (added) * testsuites/psxtests/psxhdrs/mutex15.c (added) * testsuites/psxtests/psxhdrs/mutex16.c (added) * testsuites/psxtests/psxhdrs/pthread24.c (added) * testsuites/psxtests/psxhdrs/pthread25.c (added) * testsuites/psxtests/psxhdrs/pthread26.c (added) new files Thu, 23 May 1996 18:43:59 GMT Joel Sherrill [41e7a1d8] * c/src/tests/psxtests/psxhdrs/cond08.c (added) * c/src/tests/psxtests/psxhdrs/cond09.c (added) * c/src/tests/psxtests/psxhdrs/cond10.c (added) * c/src/tests/psxtests/psxhdrs/mutex10.c (added) * c/src/tests/psxtests/psxhdrs/mutex11.c (added) * c/src/tests/psxtests/psxhdrs/mutex12.c (added) * c/src/tests/psxtests/psxhdrs/mutex13.c (added) * c/src/tests/psxtests/psxhdrs/pthread22.c (added) * c/src/tests/psxtests/psxhdrs/pthread23.c (added) * testsuites/psxtests/psxhdrs/cond08.c (added) * testsuites/psxtests/psxhdrs/cond09.c (added) * testsuites/psxtests/psxhdrs/cond10.c (added) * testsuites/psxtests/psxhdrs/mutex10.c (added) * testsuites/psxtests/psxhdrs/mutex11.c (added) * testsuites/psxtests/psxhdrs/mutex12.c (added) * testsuites/psxtests/psxhdrs/mutex13.c (added) * testsuites/psxtests/psxhdrs/pthread22.c (added) * testsuites/psxtests/psxhdrs/pthread23.c (added) new files Thu, 23 May 1996 18:08:15 GMT Joel Sherrill [9854e336] * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/cond03.c (modified) * c/src/tests/psxtests/psxhdrs/cond04.c (modified) * c/src/tests/psxtests/psxhdrs/cond05.c (modified) * c/src/tests/psxtests/psxhdrs/cond06.c (modified) * c/src/tests/psxtests/psxhdrs/cond07.c (modified) * c/src/tests/psxtests/psxhdrs/key01.c (modified) * c/src/tests/psxtests/psxhdrs/key02.c (modified) * c/src/tests/psxtests/psxhdrs/key03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex05.c (modified) * c/src/tests/psxtests/psxhdrs/mutex06.c (modified) * c/src/tests/psxtests/psxhdrs/mutex07.c (modified) * c/src/tests/psxtests/psxhdrs/mutex08.c (modified) * c/src/tests/psxtests/psxhdrs/mutex09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread07.c (modified) * c/src/tests/psxtests/psxhdrs/pthread08.c (modified) * c/src/tests/psxtests/psxhdrs/pthread09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/signal06.c (modified) * c/src/tests/psxtests/psxhdrs/signal07.c (modified) * c/src/tests/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) updated to reflect more constants and feature macros Thu, 23 May 1996 15:37:38 GMT Joel Sherrill [8b2ecf85] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (modified) * c/src/exec/score/cpu/hppa1.1/hppa.h (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libcpu/hppa1.1/timer/timer.c (modified) * c/src/tests/mptests/mp07/task1.c (modified) * c/src/tests/mptests/mp14/exit.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp14/exit.c (modified) updates from Tony Bennett Thu, 23 May 1996 15:36:46 GMT Joel Sherrill [64b976a] * c/src/lib/libbsp/shmdr/dump.c (modified) * c/src/libchip/shmdr/dump.c (modified) added code to insure that delay is always non-zero Thu, 23 May 1996 15:36:08 GMT Joel Sherrill [a6aded4f] * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) updates from tony bennett Thu, 23 May 1996 15:35:56 GMT Joel Sherrill [0553a3a] * c/src/lib/libbsp/hppa1.1/pxfl/README (added) * c/src/lib/libbsp/hppa1.1/pxfl/floss-bsp.h (added) added as example of how to do a bsp which is not in this tree. Thu, 23 May 1996 15:35:32 GMT Joel Sherrill [a5f56a43] * c/src/exec/score/tools/unix/gensize.c (modified) * tools/cpu/unix/gensize.c (modified) *** empty log message *** Thu, 23 May 1996 15:35:26 GMT Joel Sherrill [859f17ce] * c/src/exec/score/src/thread.c (modified) * cpukit/score/src/thread.c (modified) invoke thread stack free routine instead of Workspace free. Thu, 23 May 1996 15:34:54 GMT Joel Sherrill [d196e48] * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * cpukit/score/cpu/unix/cpu.c (modified) updates from Tony Bennett. Broke the setjmp/longjmp pair in the ... Wed, 22 May 1996 22:39:47 GMT Joel Sherrill [2328475] * c/src/tests/psxtests/psxhdrs/clock01.c (added) * c/src/tests/psxtests/psxhdrs/cond01.c (added) * c/src/tests/psxtests/psxhdrs/cond02.c (added) * c/src/tests/psxtests/psxhdrs/cond03.c (added) * c/src/tests/psxtests/psxhdrs/cond04.c (added) * c/src/tests/psxtests/psxhdrs/cond05.c (added) * c/src/tests/psxtests/psxhdrs/cond06.c (added) * c/src/tests/psxtests/psxhdrs/cond07.c (added) * c/src/tests/psxtests/psxhdrs/key01.c (added) * c/src/tests/psxtests/psxhdrs/key02.c (added) * c/src/tests/psxtests/psxhdrs/key03.c (added) * c/src/tests/psxtests/psxhdrs/mutex01.c (added) * c/src/tests/psxtests/psxhdrs/mutex02.c (added) * c/src/tests/psxtests/psxhdrs/mutex03.c (added) * c/src/tests/psxtests/psxhdrs/mutex04.c (added) * c/src/tests/psxtests/psxhdrs/mutex05.c (added) * c/src/tests/psxtests/psxhdrs/mutex06.c (added) * c/src/tests/psxtests/psxhdrs/mutex07.c (added) * c/src/tests/psxtests/psxhdrs/mutex08.c (added) * c/src/tests/psxtests/psxhdrs/mutex09.c (added) * c/src/tests/psxtests/psxhdrs/pthread01.c (added) * c/src/tests/psxtests/psxhdrs/pthread02.c (added) * c/src/tests/psxtests/psxhdrs/pthread03.c (added) * c/src/tests/psxtests/psxhdrs/pthread04.c (added) * c/src/tests/psxtests/psxhdrs/pthread05.c (added) * c/src/tests/psxtests/psxhdrs/pthread06.c (added) * c/src/tests/psxtests/psxhdrs/pthread07.c (added) * c/src/tests/psxtests/psxhdrs/pthread08.c (added) * c/src/tests/psxtests/psxhdrs/pthread09.c (added) * c/src/tests/psxtests/psxhdrs/pthread10.c (added) * c/src/tests/psxtests/psxhdrs/pthread11.c (added) * c/src/tests/psxtests/psxhdrs/pthread12.c (added) * c/src/tests/psxtests/psxhdrs/pthread13.c (added) * c/src/tests/psxtests/psxhdrs/pthread14.c (added) * c/src/tests/psxtests/psxhdrs/pthread15.c (added) * c/src/tests/psxtests/psxhdrs/pthread16.c (added) * c/src/tests/psxtests/psxhdrs/pthread17.c (added) * c/src/tests/psxtests/psxhdrs/pthread18.c (added) * c/src/tests/psxtests/psxhdrs/pthread19.c (added) * c/src/tests/psxtests/psxhdrs/pthread20.c (added) * c/src/tests/psxtests/psxhdrs/pthread21.c (added) * c/src/tests/psxtests/psxhdrs/signal01.c (added) * c/src/tests/psxtests/psxhdrs/signal02.c (added) * c/src/tests/psxtests/psxhdrs/signal03.c (added) * c/src/tests/psxtests/psxhdrs/signal04.c (added) * c/src/tests/psxtests/psxhdrs/signal05.c (added) * c/src/tests/psxtests/psxhdrs/signal06.c (added) * c/src/tests/psxtests/psxhdrs/signal07.c (added) * c/src/tests/psxtests/psxhdrs/signal08.c (added) * c/src/tests/psxtests/psxhdrs/signal09.c (added) * c/src/tests/psxtests/psxhdrs/signal10.c (added) * testsuites/psxtests/psxhdrs/clock01.c (added) * testsuites/psxtests/psxhdrs/cond01.c (added) * testsuites/psxtests/psxhdrs/cond02.c (added) * testsuites/psxtests/psxhdrs/cond03.c (added) * testsuites/psxtests/psxhdrs/cond04.c (added) * testsuites/psxtests/psxhdrs/cond05.c (added) * testsuites/psxtests/psxhdrs/cond06.c (added) * testsuites/psxtests/psxhdrs/cond07.c (added) * testsuites/psxtests/psxhdrs/key01.c (added) * testsuites/psxtests/psxhdrs/key02.c (added) * testsuites/psxtests/psxhdrs/key03.c (added) * testsuites/psxtests/psxhdrs/mutex01.c (added) * testsuites/psxtests/psxhdrs/mutex02.c (added) * testsuites/psxtests/psxhdrs/mutex03.c (added) * testsuites/psxtests/psxhdrs/mutex04.c (added) * testsuites/psxtests/psxhdrs/mutex05.c (added) * testsuites/psxtests/psxhdrs/mutex06.c (added) * testsuites/psxtests/psxhdrs/mutex07.c (added) * testsuites/psxtests/psxhdrs/mutex08.c (added) * testsuites/psxtests/psxhdrs/mutex09.c (added) * testsuites/psxtests/psxhdrs/pthread01.c (added) * testsuites/psxtests/psxhdrs/pthread02.c (added) * testsuites/psxtests/psxhdrs/pthread03.c (added) * testsuites/psxtests/psxhdrs/pthread04.c (added) * testsuites/psxtests/psxhdrs/pthread05.c (added) * testsuites/psxtests/psxhdrs/pthread06.c (added) * testsuites/psxtests/psxhdrs/pthread07.c (added) * testsuites/psxtests/psxhdrs/pthread08.c (added) * testsuites/psxtests/psxhdrs/pthread09.c (added) * testsuites/psxtests/psxhdrs/pthread10.c (added) * testsuites/psxtests/psxhdrs/pthread11.c (added) * testsuites/psxtests/psxhdrs/pthread12.c (added) * testsuites/psxtests/psxhdrs/pthread13.c (added) * testsuites/psxtests/psxhdrs/pthread14.c (added) * testsuites/psxtests/psxhdrs/pthread15.c (added) * testsuites/psxtests/psxhdrs/pthread16.c (added) * testsuites/psxtests/psxhdrs/pthread17.c (added) * testsuites/psxtests/psxhdrs/pthread18.c (added) * testsuites/psxtests/psxhdrs/pthread19.c (added) * testsuites/psxtests/psxhdrs/pthread20.c (added) * testsuites/psxtests/psxhdrs/pthread21.c (added) * testsuites/psxtests/psxhdrs/signal01.c (added) * testsuites/psxtests/psxhdrs/signal02.c (added) * testsuites/psxtests/psxhdrs/signal03.c (added) * testsuites/psxtests/psxhdrs/signal04.c (added) * testsuites/psxtests/psxhdrs/signal05.c (added) * testsuites/psxtests/psxhdrs/signal06.c (added) * testsuites/psxtests/psxhdrs/signal07.c (added) * testsuites/psxtests/psxhdrs/signal08.c (added) * testsuites/psxtests/psxhdrs/signal09.c (added) * testsuites/psxtests/psxhdrs/signal10.c (added) created posix test suite with test of header files Wed, 22 May 1996 22:34:18 GMT Joel Sherrill [ef006c1] * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/object.h (modified) Modified to correct variables which defined the range of object ... Wed, 22 May 1996 22:32:39 GMT Joel Sherrill [f4719d5a] * c/src/exec/libcsupport/src/utsname.c (modified) * c/src/exec/posix/src/aio.c (modified) * c/src/exec/posix/src/cancel.c (modified) * c/src/exec/posix/src/cond.c (modified) * c/src/exec/posix/src/devctl.c (modified) * c/src/exec/posix/src/intr.c (modified) * c/src/exec/posix/src/key.c (modified) * c/src/exec/posix/src/mqueue.c (modified) * c/src/exec/posix/src/mutex.c (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/sched.c (modified) * c/src/exec/posix/src/time.c (modified) * c/src/exec/posix/src/types.c (modified) * c/src/exec/posix/src/unistd.c (modified) * c/src/exec/posix/src/utsname.c (modified) * c/src/lib/libc/utsname.c (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/posix/src/aio.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/devctl.c (modified) * cpukit/posix/src/intr.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/sched.c (modified) * cpukit/posix/src/time.c (modified) * cpukit/posix/src/types.c (modified) These files have been modified in the initial pass at getting the ... Wed, 22 May 1996 22:31:51 GMT Joel Sherrill [05195890] * c/src/exec/posix/base/limits.h (modified) * c/src/exec/posix/base/pthread.h (modified) * c/src/exec/posix/base/sched.h (modified) * c/src/exec/posix/include/limits.h (modified) * c/src/exec/posix/include/pthread.h (modified) * c/src/exec/posix/include/sched.h (modified) * cpukit/posix/include/sched.h (modified) These files have been modified in the initial pass at getting the ... Fri, 10 May 1996 20:24:07 GMT Joel Sherrill [4e684a31] * c/src/tests/README (modified) * testsuites/README (modified) added posix test directory Fri, 10 May 1996 20:23:27 GMT Joel Sherrill [92262ab] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) fixed typo Wed, 08 May 1996 21:55:41 GMT Joel Sherrill [3e7b167] * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) updated to remove workaround for bug in binutils 2.5.2 ld now that we ... Wed, 08 May 1996 21:53:50 GMT Joel Sherrill [1c964ffa] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) *** empty log message *** Thu, 02 May 1996 14:39:07 GMT Joel Sherrill [bf6661e] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) Updated version to 3.5.15. Wed, 01 May 1996 15:25:33 GMT Joel Sherrill [996a9cb4] * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/start/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (added) Updates from Eric Norum. Wed, 01 May 1996 15:24:37 GMT Joel Sherrill [dce1c1a1] * c/src/exec/score/cpu/m68k/m68360.h (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * cpukit/score/cpu/m68k/m68360.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68360.h (modified) Updates from Eric Norum to use the mcpu32 flags and fix comments. Wed, 24 Apr 1996 21:21:14 GMT Joel Sherrill [a412622] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version number to 3.5.14 Wed, 24 Apr 1996 20:05:52 GMT Joel Sherrill [11532ca] * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) Hacked so gld will accept this so we can purge the aout toolset. ... Wed, 24 Apr 1996 17:36:35 GMT Joel Sherrill [1543932] * c/src/exec/score/src/thread.c (modified) * cpukit/score/src/thread.c (modified) added comment regarding stack alignment issues to thread stack ... Mon, 22 Apr 1996 23:58:40 GMT Joel Sherrill [d2d6467] * c/src/tests/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/task1.c (modified) Lowered number of messages created to reduce burden on workspace. Mon, 22 Apr 1996 16:53:46 GMT Joel Sherrill [8389628] * c/src/exec/libcsupport/include/rtems/assoc.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/src/assoc.c (modified) * c/src/exec/libcsupport/src/error.c (modified) * c/src/exec/score/tools/hppa1.1/genoffsets.c (modified) * c/src/lib/include/rtems/assoc.h (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/ttydrv.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libc/assoc.c (modified) * c/src/lib/libc/assoc.h (modified) * c/src/lib/libc/error.c (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libmisc/assoc/assoc.c (modified) * c/src/lib/libmisc/assoc/assoc.h (modified) * c/src/lib/libmisc/error/error.c (modified) * c/src/lib/libmisc/error/error.h (modified) * c/src/lib/libmisc/monitor/mon-command.c (modified) * c/src/lib/libmisc/monitor/mon-config.c (modified) * c/src/lib/libmisc/monitor/mon-dname.c (modified) * c/src/lib/libmisc/monitor/mon-driver.c (modified) * c/src/lib/libmisc/monitor/mon-extension.c (modified) * c/src/lib/libmisc/monitor/mon-itask.c (modified) * c/src/lib/libmisc/monitor/mon-manager.c (modified) * c/src/lib/libmisc/monitor/mon-monitor.c (modified) * c/src/lib/libmisc/monitor/mon-mpci.c (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/mon-prmisc.c (modified) * c/src/lib/libmisc/monitor/mon-queue.c (modified) * c/src/lib/libmisc/monitor/mon-server.c (modified) * c/src/lib/libmisc/monitor/mon-symbols.c (modified) * c/src/lib/libmisc/monitor/mon-task.c (modified) * c/src/lib/libmisc/monitor/monitor.h (modified) * c/src/lib/libmisc/monitor/symbols.h (modified) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libmisc/assoc/assoc.c (modified) * c/src/libmisc/assoc/assoc.h (modified) * c/src/libmisc/error/error.c (modified) * c/src/libmisc/error/error.h (modified) * c/src/libmisc/monitor/mon-command.c (modified) * c/src/libmisc/monitor/mon-config.c (modified) * c/src/libmisc/monitor/mon-dname.c (modified) * c/src/libmisc/monitor/mon-driver.c (modified) * c/src/libmisc/monitor/mon-extension.c (modified) * c/src/libmisc/monitor/mon-itask.c (modified) * c/src/libmisc/monitor/mon-manager.c (modified) * c/src/libmisc/monitor/mon-monitor.c (modified) * c/src/libmisc/monitor/mon-mpci.c (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/mon-prmisc.c (modified) * c/src/libmisc/monitor/mon-queue.c (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * c/src/libmisc/monitor/mon-task.c (modified) * c/src/libmisc/monitor/monitor.h (modified) * c/src/libmisc/monitor/symbols.h (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tools/generic/difftest (modified) * cpukit/libcsupport/include/rtems/assoc.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/src/assoc.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-dname.c (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/monitor/symbols.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * tools/cpu/hppa1.1/genoffsets.c (modified) updates from Tony Bennett Mon, 22 Apr 1996 16:53:05 GMT Joel Sherrill [5a36154a] * c/src/tests/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen03.c (modified) addition of optional user provided stack allocator means that we can ... Mon, 22 Apr 1996 16:50:17 GMT Joel Sherrill [1f94ed6b] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/rtems-ctor.cc (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) Updates from Tony Bennett. Mon, 22 Apr 1996 16:49:53 GMT Joel Sherrill [34f3d17] * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) Updates from Tony Bennett. rtems_environp removed among other minor ... Mon, 22 Apr 1996 16:49:25 GMT Joel Sherrill [f5674938] * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) Fixed so now supports more than 16 nodes. Tested for up to 24 nodes ... Mon, 22 Apr 1996 16:46:36 GMT Joel Sherrill [8faca06] * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/wkspace.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/wkspace.c (modified) thread.c: added support for optional user provided stack allocator ... Mon, 22 Apr 1996 16:46:00 GMT Joel Sherrill [6365f81] * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/inline/wkspace.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/wkspace.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) made initialization routine a regular subroutine Mon, 22 Apr 1996 16:45:47 GMT Joel Sherrill [a155b3c] * c/src/exec/score/headers/interr.h (modified) * c/src/exec/score/headers/wkspace.h (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) interr.h: added stack allocater error code wkspace.h: made ... Mon, 22 Apr 1996 16:44:54 GMT Joel Sherrill [cc4c1fe4] * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * cpukit/score/cpu/unix/cpu.c (modified) added stack allocation fields to the cpu table updates from Tony ... Mon, 22 Apr 1996 16:44:04 GMT Joel Sherrill [96981e3a] * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) added stack allocation fields to the cpu table Mon, 22 Apr 1996 16:43:44 GMT Joel Sherrill [9a1ccb3] * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/m68360.h (added) * c/src/exec/score/cpu/m68k/m68k.h (modified) * cpukit/score/cpu/m68k/m68360.h (added) * cpukit/score/cpu/m68k/rtems/m68k/m68360.h (added) added stack allocation fields to the cpu table added ... Mon, 22 Apr 1996 16:30:30 GMT Joel Sherrill [f581163a] * c/src/exec/score/cpu/i386/cpu.h (modified) added stack allocation fields to the cpu table Mon, 22 Apr 1996 16:30:02 GMT Joel Sherrill [d0b7c4e6] * c/src/exec/score/cpu/hppa1.1/cpu.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (modified) * c/src/exec/score/cpu/hppa1.1/hppa.h (modified) * cpukit/score/cpu/hppa1.1/cpu.c (modified) updartes from Tony Bennett Sat, 20 Apr 1996 16:48:30 GMT Joel Sherrill [767a6c6] * c/src/lib/libbsp/i386/force386/startup/ldsegs.s (modified) swapped order of operands on a movw to fix LOAD_SEGMENTS macro Fri, 19 Apr 1996 21:10:58 GMT Joel Sherrill [debe919] * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/sem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/sem.c (modified) event.c: _Event_Manager_initialization no longer a static inline ... Fri, 19 Apr 1996 21:10:38 GMT Joel Sherrill [78b2ff1] * c/src/exec/rtems/macros/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) _Event_Manager_initialization no longer a static inline Fri, 19 Apr 1996 21:10:32 GMT Joel Sherrill [c26b62f] * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) event.h: _Event_Manager_initialization no longer a static inline Fri, 19 Apr 1996 21:10:27 GMT Joel Sherrill [8f9e9bdc] * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) event.h: _Event_Manager_initialization no longer a static inline ... Fri, 19 Apr 1996 21:09:20 GMT Joel Sherrill [3b76313] * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) modified to generate fatal error when an unconfigured directive is ... Fri, 19 Apr 1996 19:36:59 GMT Joel Sherrill [f4d52cd7] * c/src/exec/score/headers/chain.h (modified) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) changes to compile in macro configuration without warnings. Thu, 21 Mar 1996 20:20:40 GMT Joel Sherrill [8cf88427] * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) minor mods to get to compile locally Thu, 21 Mar 1996 20:20:27 GMT Joel Sherrill [487a7ca] * c/src/lib/libbsp/m68k/gen68360/start/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (modified) some instructions altered for older binutils Thu, 21 Mar 1996 20:20:13 GMT Joel Sherrill [99e7cbbb] * c/src/lib/libbsp/m68k/gen68360/README (modified) updated Thu, 21 Mar 1996 20:19:55 GMT Joel Sherrill [14966f8] * c/src/exec/score/headers/address.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/src/thread.c (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/src/thread.c (modified) *** empty log message *** Thu, 21 Mar 1996 20:19:33 GMT Joel Sherrill [f398452] * c/src/exec/score/cpu/m68k/asm.h (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) updated for 68302 and so gen68360 bsp would compile Thu, 21 Mar 1996 20:19:03 GMT Joel Sherrill [d08b1c75] * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/optman/rtems/no-mp.c (modified) update to reflect internal threads reorganization Thu, 21 Mar 1996 20:18:05 GMT Joel Sherrill [f99538d] * c/ACKNOWLEDGEMENTS (modified) updated to reflect gen68360 from Eric Norum. Wed, 06 Mar 1996 22:25:11 GMT Joel Sherrill [bdf531ee] * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) include of mc68360.h changed to m68360.h to reflect filename change. Wed, 06 Mar 1996 22:23:56 GMT Joel Sherrill [110f4ff7] * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) Added 68360 support submitted by W. Eric Norum ... Wed, 06 Mar 1996 22:01:11 GMT Joel Sherrill [457b6ae] * c/src/lib/libbsp/m68k/gen68360/README (added) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/gen68360/console/console.c (added) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (added) * c/src/lib/libbsp/m68k/gen68360/include/coverhd.h (added) * c/src/lib/libbsp/m68k/gen68360/start/start360.s (added) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (added) * c/src/lib/libbsp/m68k/gen68360/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (added) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (added) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (added) Generic 68360 BSP (gen360) submitted by: W. Eric Norum ... Wed, 06 Mar 1996 21:37:43 GMT Joel Sherrill [e6424462] * c/src/exec/libcsupport/src/error.c (modified) * c/src/lib/libc/error.c (modified) * c/src/lib/libmisc/error/error.c (modified) * c/src/lib/libmisc/monitor/mon-config.c (modified) * c/src/lib/libmisc/monitor/mon-dname.c (modified) * c/src/lib/libmisc/monitor/mon-driver.c (modified) * c/src/lib/libmisc/monitor/mon-itask.c (modified) * c/src/lib/libmisc/monitor/mon-mpci.c (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/mon-symbols.c (modified) * c/src/libmisc/error/error.c (modified) * c/src/libmisc/monitor/mon-config.c (modified) * c/src/libmisc/monitor/mon-dname.c (modified) * c/src/libmisc/monitor/mon-driver.c (modified) * c/src/libmisc/monitor/mon-itask.c (modified) * c/src/libmisc/monitor/mon-mpci.c (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-dname.c (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * testsuites/tmtests/tm26/task1.c (modified) As part of reducing visibility into rtems and hiding the .inl files ... Wed, 06 Mar 1996 21:34:57 GMT Joel Sherrill [1a8fde6c] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/rtems/headers/asr.h (modified) * c/src/exec/rtems/headers/attr.h (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/eventset.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/modes.h (modified) * c/src/exec/rtems/headers/options.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/headers/support.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/inline/asr.inl (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/dpmem.inl (modified) * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/eventset.inl (modified) * c/src/exec/rtems/inline/message.inl (modified) * c/src/exec/rtems/inline/modes.inl (modified) * c/src/exec/rtems/inline/options.inl (modified) * c/src/exec/rtems/inline/part.inl (modified) * c/src/exec/rtems/inline/ratemon.inl (modified) * c/src/exec/rtems/inline/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/options.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/part.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/support.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/inline/sem.inl (modified) * c/src/exec/rtems/inline/status.inl (modified) * c/src/exec/rtems/inline/support.inl (modified) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/inline/timer.inl (modified) * c/src/exec/rtems/macros/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/inline/extension.inl (modified) * c/src/exec/sapi/inline/rtems/extension.inl (modified) * c/src/exec/score/headers/address.h (modified) * c/src/exec/score/headers/chain.h (modified) * c/src/exec/score/headers/coremsg.h (modified) * c/src/exec/score/headers/coremutex.h (modified) * c/src/exec/score/headers/coresem.h (modified) * c/src/exec/score/headers/heap.h (modified) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/priority.h (modified) * c/src/exec/score/headers/stack.h (modified) * c/src/exec/score/headers/states.h (modified) * c/src/exec/score/headers/sysstate.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/headers/threadmp.h (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/headers/tqdata.h (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/headers/watchdog.h (modified) * c/src/exec/score/headers/wkspace.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (modified) * c/src/exec/score/include/rtems/score/coresem.h (modified) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/inline/address.inl (modified) * c/src/exec/score/inline/chain.inl (modified) * c/src/exec/score/inline/coremsg.inl (modified) * c/src/exec/score/inline/coremutex.inl (modified) * c/src/exec/score/inline/coresem.inl (modified) * c/src/exec/score/inline/heap.inl (modified) * c/src/exec/score/inline/isr.inl (modified) * c/src/exec/score/inline/mppkt.inl (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/objectmp.inl (modified) * c/src/exec/score/inline/priority.inl (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/chain.inl (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (modified) * c/src/exec/score/inline/rtems/score/coresem.inl (modified) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/objectmp.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/threadmp.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/tqdata.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/inline/stack.inl (modified) * c/src/exec/score/inline/states.inl (modified) * c/src/exec/score/inline/sysstate.inl (modified) * c/src/exec/score/inline/thread.inl (modified) * c/src/exec/score/inline/threadmp.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/inline/tqdata.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * c/src/exec/score/inline/watchdog.inl (modified) * c/src/exec/score/inline/wkspace.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/tqdata.inl (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/eventset.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/options.inl (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/rtems/inline/rtems/rtems/sem.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/inline/rtems/rtems/timer.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/inline/rtems/extension.inl (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/objectmp.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) Removed prototyes for static inline routines and moved the comments ... Wed, 06 Mar 1996 21:26:28 GMT Joel Sherrill [8e76546] * c/src/exec/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) Removed prototyes for static inline rgutines and moved the comments ... Thu, 22 Feb 1996 20:14:36 GMT Joel Sherrill [ba39113] * c/src/tests/sptests/sp07/task1.c (modified) * c/src/tests/sptests/sp09/task1.c (modified) * c/src/tests/sptests/sp11/task1.c (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/task1.c (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp14/task1.c (modified) * c/src/tests/sptests/sp16/task1.c (modified) * c/src/tests/sptests/sp22/task1.c (modified) * c/src/tests/sptests/sp25/task1.c (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) The name of the test support routine pause was changed to ... Wed, 21 Feb 1996 22:37:55 GMT Joel Sherrill [66d9e3ad] * c/src/exec/sapi/src/io.c (modified) * cpukit/sapi/src/io.c (modified) Changed io manager initialization routine to not be static and added ... Wed, 21 Feb 1996 22:37:47 GMT Joel Sherrill [10017a72] * c/src/exec/sapi/optman/no-io.c (modified) * c/src/optman/sapi/no-io.c (modified) Changed io manager initialization routine to not be static. Wed, 21 Feb 1996 22:37:18 GMT Joel Sherrill [4ff1920] * c/src/exec/sapi/headers/io.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/io.h (modified) changed io manager initialization routine to not be static Wed, 21 Feb 1996 14:47:58 GMT Joel Sherrill [0e0d88b] * c/src/tests/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/size.c (modified) Dispersal of internal thread handler resulted in removal of some ... Wed, 21 Feb 1996 14:47:03 GMT Joel Sherrill [8cbbe312] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) Dispersal of internal thread handler resulted in the SYSI task being ... Wed, 21 Feb 1996 14:44:11 GMT Joel Sherrill [adf98bd] * c/src/exec/score/headers/mpci.h (modified) * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/sysstate.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/thread.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/thread.inl (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/thread.c (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/thread.c (modified) Removed the internal thread objects and dispersed its contents to ... Wed, 21 Feb 1996 14:43:34 GMT Joel Sherrill [75f09e5] * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) Dispersal of internal thread handler resulted in IDLE thread becoming ... Wed, 21 Feb 1996 14:37:32 GMT Joel Sherrill [c4b8161d] * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/optman/rtems/no-mp.c (modified) MPCI Receive became a thread and the prototype changed. Wed, 21 Feb 1996 14:32:02 GMT Joel Sherrill [56d34e6] * c/src/exec/sapi/src/exinit.c (modified) * cpukit/sapi/src/exinit.c (modified) Removed the internal thread objects and dispersed its contents to ... Wed, 14 Feb 1996 19:00:00 GMT Joel Sherrill [b2b52cbc] * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) Removed arguments from _Thread_Start_multitasking. Wed, 14 Feb 1996 18:59:37 GMT Joel Sherrill [f972294d] * c/src/exec/sapi/src/exinit.c (modified) * cpukit/sapi/src/exinit.c (modified) idle thread now created before system initialization thread. Also ... Wed, 14 Feb 1996 18:48:39 GMT Joel Sherrill [744d2878] * c/src/exec/score/src/thread.c (modified) * cpukit/score/src/thread.c (modified) removed arguments from _Thread_Start_multitasking Wed, 14 Feb 1996 17:06:57 GMT Joel Sherrill [df26b788] * c/src/exec/score/src/thread.c (modified) * cpukit/score/src/thread.c (modified) white space problem Wed, 14 Feb 1996 17:06:40 GMT Joel Sherrill [389fa850] * c/src/exec/sapi/src/exinit.c (modified) * cpukit/sapi/src/exinit.c (modified) Moved some initialization from the system initialization thread to ... Tue, 13 Feb 1996 22:16:36 GMT Joel Sherrill [8bde6ea9] * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/spfatal/system.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/spfatal/system.h (modified) removed post switch extension Tue, 13 Feb 1996 22:15:52 GMT Joel Sherrill [da646dd] * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) fixed bug when outbyte had argument in wrong order relative to those ... Tue, 13 Feb 1996 22:14:48 GMT Joel Sherrill [94b3ec59] * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/score/headers/apiext.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/include/rtems/score/apiext.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/userext.inl (modified) * c/src/exec/score/src/apiext.c (modified) * c/src/exec/score/src/thread.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/thread.c (modified) changed post task extension from user set to api set and added flag ... Tue, 13 Feb 1996 22:14:25 GMT Joel Sherrill [6ca1184] * c/src/exec/score/cpu/sparc/cpu_asm.s (modified) added clear of _ISR_Signals_to_thread_executing Tue, 13 Feb 1996 15:38:37 GMT Joel Sherrill [391f6628] * c/src/exec/score/src/threadq.c (modified) * cpukit/score/src/threadq.c (modified) more comments added and existing ones cleaned up in synchronization paths Tue, 13 Feb 1996 15:38:03 GMT Joel Sherrill [b38955b] * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) comma removed from end of last enumerated element Tue, 13 Feb 1996 15:37:33 GMT Joel Sherrill [18269cef] * c/src/exec/rtems/src/event.c (modified) * cpukit/rtems/src/event.c (modified) comment added to describe synchronization logic in timeout routine Mon, 12 Feb 1996 14:36:09 GMT Joel Sherrill [a31ddf7] * c/src/exec/sapi/src/exinit.c (modified) * cpukit/sapi/src/exinit.c (modified) *** empty log message *** Fri, 09 Feb 1996 14:31:39 GMT Joel Sherrill [8c8a924] * c/src/tests/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/size.c (modified) As part of implementing the new isr synchronization algorithm using a ... Fri, 09 Feb 1996 14:30:42 GMT Joel Sherrill [107ce47b] * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/score/headers/tqdata.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/inline/rtems/score/tqdata.inl (modified) * c/src/exec/score/inline/tqdata.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/tqdata.inl (modified) * c/src/exec/score/src/threadq.c (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/src/event.c (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) * cpukit/score/src/threadq.c (modified) new isr synchronization algorithm using a single enumerated set of ... Fri, 09 Feb 1996 14:25:33 GMT Joel Sherrill [6dae1c2d] * c/src/exec/rtems/headers/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) added rtems_interrupt_is_in_progress Fri, 09 Feb 1996 14:21:37 GMT Joel Sherrill [8a38f3b] * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) added clear of _ISR_Signals_to_thread_executing Thu, 08 Feb 1996 22:16:35 GMT Joel Sherrill [f3dabb04] * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) changed synchronization algorithm to be a single list of enumerated ... Thu, 08 Feb 1996 16:18:38 GMT Joel Sherrill [d57392d] * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/wkspace.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT Thu, 01 Feb 1996 22:09:07 GMT Joel Sherrill [4f60309b] * c/src/exec/score/src/coremutex.c (modified) * cpukit/score/src/coremutex.c (modified) Swapped order of nested acquisition check and check for returning ... Thu, 01 Feb 1996 21:54:40 GMT Joel Sherrill [f00a0522] * c/src/exec/score/src/threadq.c (modified) * cpukit/score/src/threadq.c (modified) synchronization state bugs address Thu, 01 Feb 1996 19:39:21 GMT Joel Sherrill [665356af] * c/src/exec/score/src/coresem.c (modified) * cpukit/score/src/coresem.c (modified) invalid use of tcb field resource count Mon, 22 Jan 1996 21:12:12 GMT Joel Sherrill [4f7c546e] * c/src/lib/libbsp/i386/force386/times (modified) new times for 3.5.1 Fri, 19 Jan 1996 22:22:12 GMT Joel Sherrill [c3dcd6e] * c/src/tests/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/size.c (modified) Added RTEMS API control structure to per task memory usage macro.
