# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 05/05/24 20:28:31 Sat, 18 Jul 1998 15:19:28 GMT Joel Sherrill [cce1200e] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (added) New file. Fri, 17 Jul 1998 22:34:54 GMT Joel Sherrill [4555bc1e] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Initialized tty->refcount to 0. When (for whatever reason) malloc() ... Fri, 17 Jul 1998 15:49:12 GMT Joel Sherrill [f95d2b53] * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/update-tools/Makefile.in (modified) * configure.in (modified) * make/host.cfg.in (modified) * make/main.cfg (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Patch from Ralf Corsepius . Comments: ... Fri, 17 Jul 1998 15:43:42 GMT Joel Sherrill [8123c635] * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) Added scitab directory. Fri, 17 Jul 1998 15:42:39 GMT Joel Sherrill [a56e475f] * c/src/tests/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/system.h (modified) Turned stack checker on. Fri, 17 Jul 1998 15:19:04 GMT Joel Sherrill [bdba552f] * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (added) Patch fromalf Corsepius : * ... Fri, 17 Jul 1998 15:17:29 GMT Joel Sherrill [fa21a843] * c/src/exec/score/tools/sh/AUTHORS (added) * c/src/exec/score/tools/sh/COPYING (added) * c/src/exec/score/tools/sh/Makefile.in (added) * c/src/exec/score/tools/sh/TODO (added) * c/src/exec/score/tools/sh/sci.c (added) * c/src/exec/score/tools/sh/sci.h (added) * c/src/exec/score/tools/sh/shgen.c (added) * tools/cpu/sh/AUTHORS (added) * tools/cpu/sh/COPYING (added) * tools/cpu/sh/Makefile.in (added) * tools/cpu/sh/TODO (added) * tools/cpu/sh/sci.c (added) * tools/cpu/sh/sci.h (added) * tools/cpu/sh/shgen.c (added) New files from Ralf Corsepius . His ... Fri, 17 Jul 1998 13:05:03 GMT Joel Sherrill [6e65840] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Patch from Dario Alcocer . His comments: ... Thu, 16 Jul 1998 00:16:22 GMT Joel Sherrill [16d0e63] * c/src/lib/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/mc68681_baud.c (modified) Corrected header files. Thu, 16 Jul 1998 00:16:11 GMT Joel Sherrill [a6f441b] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Minor corrections for typos to get it to compile. Thu, 16 Jul 1998 00:03:01 GMT Joel Sherrill [dd5d2f04] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_baud.c (added) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_baud.c (added) Split default baud rate table into its own file. This shrinks the ... Wed, 15 Jul 1998 23:58:08 GMT Joel Sherrill [4a11d8c] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Fixed typo in which last port did not get switched to default ... Wed, 15 Jul 1998 23:57:41 GMT Joel Sherrill [849dc107] * c/src/lib/libchip/serial/mc68681_reg.c (modified) * c/src/lib/libchip/serial/mc68681_reg2.c (modified) * c/src/lib/libchip/serial/mc68681_reg4.c (modified) * c/src/lib/libchip/serial/mc68681_reg8.c (modified) * c/src/libchip/serial/mc68681_reg.c (modified) * c/src/libchip/serial/mc68681_reg2.c (modified) * c/src/libchip/serial/mc68681_reg4.c (modified) * c/src/libchip/serial/mc68681_reg8.c (modified) Fixed typos. Wed, 15 Jul 1998 23:55:04 GMT Joel Sherrill [670d037] * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.h (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.h (deleted) Switched to usign the default z8530 and mc68681 register access routines. Wed, 15 Jul 1998 23:54:24 GMT Joel Sherrill [8414c033] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/z85c30.h (modified) * c/src/lib/libchip/serial/z85c30_reg.c (added) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/z85c30.h (modified) * c/src/libchip/serial/z85c30_reg.c (added) Added default z85c30 register access routines. Wed, 15 Jul 1998 23:54:08 GMT Joel Sherrill [cce9322] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_reg.c (added) * c/src/lib/libchip/serial/mc68681_reg2.c (added) * c/src/lib/libchip/serial/mc68681_reg4.c (added) * c/src/lib/libchip/serial/mc68681_reg8.c (added) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_reg.c (added) * c/src/libchip/serial/mc68681_reg2.c (added) * c/src/libchip/serial/mc68681_reg4.c (added) * c/src/libchip/serial/mc68681_reg8.c (added) Added default mc68681 register access routines. Wed, 15 Jul 1998 23:21:55 GMT Joel Sherrill [991a1ab4] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) Added check for proper deviceType to interrupt processing code. Wed, 15 Jul 1998 23:21:30 GMT Joel Sherrill [efaf85fa] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added interrupt mask and interrupt status register bit constants. ... Wed, 15 Jul 1998 23:20:50 GMT Joel Sherrill [49370cd] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added default mc68681 register access routines. Wed, 15 Jul 1998 23:20:33 GMT Joel Sherrill [198d851] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched from driver's own buffering to using termios. This ... Wed, 15 Jul 1998 23:15:49 GMT Joel Sherrill [27a66bd] * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/README.z85c30 (modified) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/README.z85c30 (modified) Added information on the deviceType field. Wed, 15 Jul 1998 23:15:32 GMT Joel Sherrill [66f95fc] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added default mc68681 register access routines. Wed, 15 Jul 1998 21:43:28 GMT Joel Sherrill [8a2e9c41] * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (modified) Added SCV64_Get_Interrupt_Enable(). Added proper headers to routines. Wed, 15 Jul 1998 21:43:00 GMT Joel Sherrill [d0cff6dc] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added SCV64_Get_Interrupt_Enable(). Wed, 15 Jul 1998 21:42:26 GMT Joel Sherrill [38e717f] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added chip type identifier field. This was necessary because a ... Wed, 15 Jul 1998 21:40:42 GMT Joel Sherrill [c0573d7] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Added comment to remove use of TxBuffer ring buffer in all libchip ... Wed, 15 Jul 1998 19:28:29 GMT Joel Sherrill [0f61336] * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (modified) Added comments. Wed, 15 Jul 1998 19:20:20 GMT Joel Sherrill [a69f0ad9] * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (modified) Added comments. Wed, 15 Jul 1998 19:19:14 GMT Joel Sherrill [100a4e5] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Masked out interrupts not being used prior to processing the status ... Wed, 15 Jul 1998 19:12:11 GMT Joel Sherrill [6c45da17] * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (modified) Added routine to return interrupt mask. Added comments. Wed, 15 Jul 1998 14:06:37 GMT Joel Sherrill [01e54b8] * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Added scv64 subdirectory. Wed, 15 Jul 1998 14:06:08 GMT Joel Sherrill [e49ef37c] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Switched to SCV64. Wed, 15 Jul 1998 14:05:51 GMT Joel Sherrill [8f563b9b] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added CSCV64 functions and addresses. Wed, 15 Jul 1998 14:04:31 GMT Joel Sherrill [30a3f76] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Switched from polling to interrupts and in the process added a ... Wed, 15 Jul 1998 14:00:23 GMT Joel Sherrill [437b5a7d] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) Added scv64 subdirectory. Wed, 15 Jul 1998 14:00:09 GMT Joel Sherrill [090a3511] * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (added) New files. Wed, 15 Jul 1998 13:58:23 GMT Joel Sherrill [be8cbbf] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched deviceOutputUsesInterrupts to TRUE so output would be ... Wed, 15 Jul 1998 13:53:58 GMT Joel Sherrill [e283140c] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.c (modified) Switched to "deviceOutput = TRUE" which made device output use ... Sat, 11 Jul 1998 14:23:53 GMT Joel Sherrill [5b8c1b7] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Yet another EXEEXT patch. This one is from Ralf Corsepius ... Fri, 10 Jul 1998 19:05:20 GMT Joel Sherrill [3a447c3] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980710 Fri, 10 Jul 1998 15:43:18 GMT Joel Sherrill [dbfa3148] * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) Patch from Quality Quorum . Comments: ... Fri, 10 Jul 1998 14:13:59 GMT Joel Sherrill [cc8a388a] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Ralf Corsepius . Comments: ... Thu, 09 Jul 1998 23:32:07 GMT Joel Sherrill [fb32356b] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_p.h (modified) Added set attributes routine but did not hook it in to the table. ... Thu, 09 Jul 1998 23:31:48 GMT Joel Sherrill [abd8c82] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added new files. Thu, 09 Jul 1998 23:31:26 GMT Joel Sherrill [31cad72c] * c/src/lib/libchip/serial/sersupp.c (deleted) Renamed so we could have one file per routine. Thu, 09 Jul 1998 23:30:32 GMT Joel Sherrill [064b9be] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.c (modified) Switched to shared default probe routine. Thu, 09 Jul 1998 23:30:02 GMT Joel Sherrill [693b5b88] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched to default probe routine. Thu, 09 Jul 1998 23:29:33 GMT Joel Sherrill [61ff7ac8] * c/src/lib/libchip/serial/serprobe.c (added) * c/src/lib/libchip/serial/sersupp.h (modified) * c/src/lib/libchip/serial/termios_baud2index.c (added) * c/src/lib/libchip/serial/termios_baud2num.c (added) * c/src/libchip/serial/serprobe.c (added) * c/src/libchip/serial/sersupp.h (modified) * c/src/libchip/serial/termios_baud2index.c (added) * c/src/libchip/serial/termios_baud2num.c (added) Added new baud rate to number function and default serial probe ... Thu, 09 Jul 1998 22:59:32 GMT Joel Sherrill [11c6a92d] * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.c (modified) Commented out the system call invocation since we don't know what ... Thu, 09 Jul 1998 22:59:13 GMT Joel Sherrill [a6e36dff] * c/src/lib/libbsp/powerpc/dmv177/start/start.s (modified) Removed call back to exit() since that has already been called. Thu, 09 Jul 1998 22:21:54 GMT Joel Sherrill [e78c474b] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added proper handling of extended baud rate table selection at boot ... Thu, 09 Jul 1998 22:16:27 GMT Joel Sherrill [2c5ea01] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Properly handle extended baud rate set commands. Temporarily "if 0" ... Thu, 09 Jul 1998 22:11:49 GMT Joel Sherrill [e3c59dd] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Corrected definition of MC68681_RX_BUFFER. Thu, 09 Jul 1998 18:50:13 GMT Joel Sherrill [2ba0a0c2] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Corrected z85c30 address and clock constants. Thu, 09 Jul 1998 18:49:49 GMT Joel Sherrill [459c1d2] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added board specific baud rate table and set driver function table ... Thu, 09 Jul 1998 18:45:28 GMT Joel Sherrill [2d8e51aa] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Changed static to MC68681_STATIC to make all data and routines ... Thu, 09 Jul 1998 18:44:10 GMT Joel Sherrill [b2ec38c8] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Removed commented out line. Thu, 09 Jul 1998 18:41:49 GMT Joel Sherrill [8f6f641e] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added sersupp.c. Thu, 09 Jul 1998 18:41:33 GMT Joel Sherrill [d94d47b3] * c/src/lib/libchip/serial/sersupp.c (added) * c/src/lib/libchip/serial/sersupp.h (added) * c/src/libchip/serial/sersupp.h (added) New files to contain generally needed serial driver support routines. Thu, 09 Jul 1998 18:40:27 GMT Joel Sherrill [37e8259] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Changed static to MC68681_STATIC to make all routines and data global ... Thu, 09 Jul 1998 18:39:50 GMT Joel Sherrill [8b2492f] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added support for the Extended Baud Rate set control found in the ... Thu, 09 Jul 1998 18:38:18 GMT Joel Sherrill [27045a82] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Changed static to NS16550_STATIC to make all routines and data global ... Thu, 09 Jul 1998 18:37:47 GMT Joel Sherrill [677a503] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_p.h (modified) Changed static to Z85C30_STATIC so all data and routines could be ... Thu, 09 Jul 1998 18:36:19 GMT Joel Sherrill [80b1c2f] * c/src/lib/libchip/serial/README (added) * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/README.z85c30 (added) * c/src/libchip/serial/README (added) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/README.z85c30 (added) Added information to README.mc68681. Created the basic README and ... Tue, 07 Jul 1998 19:05:55 GMT Joel Sherrill [0d1184f] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980707 Tue, 07 Jul 1998 19:00:26 GMT Joel Sherrill [d859b5f] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 9800707 Tue, 07 Jul 1998 16:38:18 GMT Joel Sherrill [030ff417] * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) Conditionals for CONSOLE_USE_INTERRUPTS should have been "if" not ... Mon, 06 Jul 1998 19:00:33 GMT Joel Sherrill [270d58f] * c/src/exec/libcsupport/src/getdents.c (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/getdents.c (added) * cpukit/libcsupport/src/getdents.c (added) New file to satisfy readdir() family. Mon, 06 Jul 1998 18:44:32 GMT Joel Sherrill [a90b990] * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (added) Missed this file in the initial merge. Mon, 06 Jul 1998 14:52:30 GMT Joel Sherrill [b5bb3d6] * c/src/lib/libbsp/m68k/gen68340/README (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.s (modified) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.s (modified) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (modified) Update from Geoffroy Montel (g_montel@yahoo.com) to get in sync with ... Mon, 06 Jul 1998 14:51:39 GMT Joel Sherrill [1d22b03] * c/ACKNOWLEDGEMENTS (modified) Added Geoffroy Montel (g_montel@yahoo.com) for the gen68340 BSP. Sun, 05 Jul 1998 11:04:31 GMT Joel Sherrill [5ae415b] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Added include of termios.h. Also added a block of comments above ... Sun, 05 Jul 1998 11:01:21 GMT Joel Sherrill [bc2ebb4] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added some address constants for the SCC and DUART to make it easier ... Sun, 05 Jul 1998 11:00:57 GMT Joel Sherrill [e7ff2b2] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (added) New file added in the process of converting the console driver to ... Sun, 05 Jul 1998 11:00:00 GMT Joel Sherrill [92a6454] * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/debugio.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/duart.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.h (added) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.h (added) Converted the console driver to use libchip/serial and added support ... Thu, 02 Jul 1998 18:07:09 GMT Joel Sherrill [0e8c2000] * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.s (added) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.s (added) Renamed old_start340.s to startfor340only.s Wed, 01 Jul 1998 22:03:20 GMT Joel Sherrill [132f194] * c/src/lib/libbsp/m68k/gen68340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/README (added) * c/src/lib/libbsp/m68k/gen68340/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.s (added) * c/src/lib/libbsp/m68k/gen68340/console/console.c (added) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (added) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (added) * c/src/lib/libbsp/m68k/gen68340/include/coverhd.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.inc (added) * c/src/lib/libbsp/m68k/gen68340/include/m68349.inc (added) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start340/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/init68340.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (added) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (added) * make/custom/gen68340.cfg (added) Initial submission of gen68340 BSP (should run on a 68349) from ... Wed, 01 Jul 1998 21:33:38 GMT Joel Sherrill [a05de51] * c/src/lib/libc/newlibifr.c (modified) Added _stat_r and changed spacing. Wed, 01 Jul 1998 21:33:11 GMT Joel Sherrill [dd6dddc] * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/inline/heap.inl (modified) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) Fixed typo. Mon, 29 Jun 1998 17:51:50 GMT Joel Sherrill [dc95ee8d] * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) Changed prototype for console_write_support to eliminate a warning. Sat, 27 Jun 1998 20:01:28 GMT Joel Sherrill [cf65c408] * README.configure (modified) * c/PROBLEMS (modified) * c/src/lib/libbsp/bare/README (modified) * c/src/lib/libbsp/bare/build-tools (added) * c/src/lib/libbsp/bare/do-bare-bsp-build (added) Bare BSP patch from Chris Johns . He also ... Sat, 27 Jun 1998 18:51:49 GMT Joel Sherrill [5d18fb0] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/pc386/tools/binpatch.c (added) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * make/custom/pc386.cfg (modified) * tools/build/binpatch.c (added) PC386 BSP enhancements from Aleksey Romanov (Quality Quorum ... Sat, 27 Jun 1998 17:09:47 GMT Joel Sherrill [98100d2] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/ar-s.m4 (added) * aclocal/canonicalize-tools.m4 (modified) * aclocal/cygwin.m4 (added) * aclocal/exeext.m4 (added) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * c/PROBLEMS (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/README (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/size_rtems.in (modified) Monstrous patch from Ralf Corsepius . I ... Thu, 25 Jun 1998 18:42:30 GMT Joel Sherrill [d13b247] * c/src/lib/libbsp/i386/pc386/start/start16.s (modified) Clean up from Aleksey Romanov (Quality Quorum ). ... Thu, 25 Jun 1998 16:54:08 GMT Joel Sherrill [7252f656] * c/ACKNOWLEDGEMENTS (modified) Added David Fiddes for ColdFire. Thu, 25 Jun 1998 16:26:43 GMT Joel Sherrill [b22b1294] * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) Coldfire support patch from David Fiddes . Thu, 25 Jun 1998 16:10:45 GMT Joel Sherrill [924e17a] * c/src/exec/score/cpu/m68k/m68k.h (modified) Patch from Robin Kirkham to ... Wed, 24 Jun 1998 17:58:56 GMT Joel Sherrill [803de41] * c/src/exec/score/cpu/m68k/cpu.h (modified) Suggestion from Robin Kirkham to ... Wed, 24 Jun 1998 14:51:09 GMT Joel Sherrill [414ab59] * c/PROBLEMS (modified) Updated. Tue, 23 Jun 1998 17:42:46 GMT Joel Sherrill [4f0ffa57] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Removed RTS and DTR handling code since the MC68681 seems to only ... Tue, 23 Jun 1998 17:40:00 GMT Joel Sherrill [ae21568c] * c/src/lib/libchip/serial/README.mc68681 (added) * c/src/libchip/serial/README.mc68681 (added) New file describing mc68681 libchip driver. Tue, 23 Jun 1998 16:02:52 GMT Joel Sherrill [beaaf49f] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added numerous comments. Tue, 23 Jun 1998 15:54:33 GMT Joel Sherrill [a5d0c7c] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added concept of "mate" -- the other port on the same DUART. This is ... Tue, 23 Jun 1998 14:59:26 GMT Joel Sherrill [b7ebcea3] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added close. Tue, 23 Jun 1998 14:55:21 GMT Joel Sherrill [25c3ff91] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added set attributes and written initialize and first open. Tue, 23 Jun 1998 14:54:42 GMT Joel Sherrill [790d421] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added more registers. Tue, 23 Jun 1998 14:54:30 GMT Joel Sherrill [9eef52b] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added set attributes prototype. Tue, 23 Jun 1998 14:54:09 GMT Joel Sherrill [8a2d4f2b] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/serial.h (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/serial/z85c30.c (modified) Added NULL entry for setAttributes. Mon, 22 Jun 1998 11:49:38 GMT Joel Sherrill [7deeb16] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) Added initial part of iniitialization. Mon, 22 Jun 1998 11:09:32 GMT Joel Sherrill [ab2dbd7] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added mc68681 stuff to the makefile. Added numerous constants to ...
