# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 07:49:03 Thu, 18 Feb 1999 21:09:25 GMT Joel Sherrill [c0438add] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (moved) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (moved) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) Renamed network to wd8003. Thu, 18 Feb 1999 21:07:15 GMT Joel Sherrill [adbaa61] * c/src/lib/libcpu/i386/page.c (added) Patch from Emmanuel Raguet . Missed adding this ... Thu, 18 Feb 1999 21:06:45 GMT Joel Sherrill [13ae6f4] * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) Added INSTALL rule to Makefile. Thu, 18 Feb 1999 21:06:17 GMT Joel Sherrill [1094cf0d] * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (added) * c/src/lib/libbsp/i386/pc386/dec21140/dec21140.c (added) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) Patch from Emmanuel RAGUET to add files that ... Thu, 18 Feb 1999 20:58:46 GMT Joel Sherrill [3204a06] * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) Added comments. Thu, 18 Feb 1999 20:58:13 GMT Joel Sherrill [51450d7] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (added) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (added) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) Added NE2000 Driver from Ian Lance Taylor . Comments: ... Thu, 18 Feb 1999 19:24:08 GMT Joel Sherrill [aa28a083] * c/src/lib/libbsp/m68k/mvme167/README (modified) Fixed top of file. Thu, 18 Feb 1999 19:23:28 GMT Joel Sherrill [5d02459] * c/src/lib/libbsp/m68k/mvme167/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/README (added) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/console/console.c (added) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/fatal/bspfatal.c (added) * c/src/lib/libbsp/m68k/mvme167/fatal/fatal.c (added) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme167/include/fatal.h (added) * c/src/lib/libbsp/m68k/mvme167/include/page_table.h (added) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (added) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (added) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (added) * make/custom/mvme167.cfg (added) MVME167 BSP submitted by Charles Gauthier . Thu, 18 Feb 1999 19:18:28 GMT Joel Sherrill [5c609dd] * c/src/lib/libbsp/powerpc/ppcn_60x/console/config.c (added) Missed this file in the merge. Thu, 18 Feb 1999 18:36:05 GMT Joel Sherrill [8548fe0] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Part of the automake VI patch from Ralf Corsepius [7908ba5b] * c/src/exec/score/cpu/a29k/rtems/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (added) * c/src/exec/score/cpu/a29k/rtems/score/a29ktypes.h (added) * c/src/exec/score/cpu/a29k/rtems/score/cpu.h (added) * c/src/exec/score/cpu/a29k/rtems/score/types.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu_asm.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppatypes.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/types.h (added) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/cpu.h (added) * c/src/exec/score/cpu/i386/rtems/score/i386.h (added) * c/src/exec/score/cpu/i386/rtems/score/i386types.h (added) * c/src/exec/score/cpu/i386/rtems/score/types.h (added) * c/src/exec/score/cpu/i386/wrap/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (added) * c/src/exec/score/cpu/i960/rtems/score/i960.h (added) * c/src/exec/score/cpu/i960/rtems/score/i960types.h (added) * c/src/exec/score/cpu/i960/rtems/score/types.h (added) * c/src/exec/score/cpu/i960/wrap/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (added) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (added) * c/src/exec/score/cpu/m68k/rtems/score/m68ktypes.h (added) * c/src/exec/score/cpu/m68k/rtems/score/types.h (added) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (added) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (added) * c/src/exec/score/cpu/mips/rtems/score/mipstypes.h (added) * c/src/exec/score/cpu/mips/rtems/score/types.h (added) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/idtcpu.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/idtmon.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/iregdef.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/mipstypes.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/types.h (added) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cputypes.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/types.h (added) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/score/cpu.h (added) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/cpu.h (added) * c/src/exec/score/cpu/sh/rtems/score/cpu_isps.h (added) * c/src/exec/score/cpu/sh/rtems/score/iosh7030.h (added) * c/src/exec/score/cpu/sh/rtems/score/iosh7032.h (added) * c/src/exec/score/cpu/sh/rtems/score/ispsh7032.h (added) * c/src/exec/score/cpu/sh/rtems/score/sh.h (added) * c/src/exec/score/cpu/sh/rtems/score/sh_io.h (added) * c/src/exec/score/cpu/sh/rtems/score/shtypes.h (added) * c/src/exec/score/cpu/sh/rtems/score/types.h (added) * c/src/exec/score/cpu/sh/wrap/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (added) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (added) * c/src/exec/score/cpu/sparc/rtems/score/sparctypes.h (added) * c/src/exec/score/cpu/sparc/rtems/score/types.h (added) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (added) * c/src/exec/score/cpu/unix/rtems/score/types.h (added) * c/src/exec/score/cpu/unix/rtems/score/unix.h (added) * c/src/exec/score/cpu/unix/rtems/score/unixtypes.h (added) * c/src/exec/score/cpu/unix/wrap/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (added) * c/src/lib/libcpu/sh/sh7032/include/ispsh7032.h (added) * configure.in (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (added) * cpukit/score/cpu/a29k/rtems/score/cpu.h (added) * cpukit/score/cpu/a29k/rtems/score/types.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/cpu.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/types.h (added) * cpukit/score/cpu/i386/rtems/score/cpu.h (added) * cpukit/score/cpu/i386/rtems/score/i386.h (added) * cpukit/score/cpu/i386/rtems/score/types.h (added) * cpukit/score/cpu/i960/rtems/score/cpu.h (added) * cpukit/score/cpu/i960/rtems/score/i960.h (added) * cpukit/score/cpu/i960/rtems/score/types.h (added) * cpukit/score/cpu/m68k/rtems/score/cpu.h (added) * cpukit/score/cpu/m68k/rtems/score/m68k.h (added) * cpukit/score/cpu/m68k/rtems/score/types.h (added) * cpukit/score/cpu/mips/rtems/score/cpu.h (added) * cpukit/score/cpu/mips/rtems/score/types.h (added) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (added) * cpukit/score/cpu/mips64orion/rtems/score/types.h (added) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (added) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (added) * cpukit/score/cpu/no_cpu/rtems/score/types.h (added) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (added) * cpukit/score/cpu/sh/rtems/score/cpu.h (added) * cpukit/score/cpu/sh/rtems/score/sh.h (added) * cpukit/score/cpu/sh/rtems/score/sh_io.h (added) * cpukit/score/cpu/sh/rtems/score/types.h (added) * cpukit/score/cpu/sparc/rtems/score/cpu.h (added) * cpukit/score/cpu/sparc/rtems/score/sparc.h (added) * cpukit/score/cpu/sparc/rtems/score/types.h (added) * cpukit/score/cpu/unix/rtems/score/cpu.h (added) * cpukit/score/cpu/unix/rtems/score/types.h (added) * cpukit/score/cpu/unix/rtems/score/unix.h (added) Part of the automake VI patch from Ralf Corsepius [52b0d9d] * c/src/exec/score/cpu/a29k/wrap/Makefile.in (added) Another part of automake VI patch from Ralf Corsepius [25d457b8] * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/a29k.h (deleted) * c/src/exec/score/cpu/a29k/a29ktypes.h (deleted) * c/src/exec/score/cpu/a29k/cpu.h (deleted) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (deleted) * c/src/exec/score/cpu/hppa1.1/cpu_asm.h (deleted) * c/src/exec/score/cpu/hppa1.1/hppa.h (deleted) * c/src/exec/score/cpu/hppa1.1/hppatypes.h (deleted) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.h (deleted) * c/src/exec/score/cpu/i386/i386.h (deleted) * c/src/exec/score/cpu/i386/i386types.h (deleted) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/cpu.h (deleted) * c/src/exec/score/cpu/i960/i960.h (deleted) * c/src/exec/score/cpu/i960/i960types.h (deleted) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/cpu.h (deleted) * c/src/exec/score/cpu/m68k/m68k.h (deleted) * c/src/exec/score/cpu/m68k/m68ktypes.h (deleted) * c/src/exec/score/cpu/mips/idtcpu.h (deleted) * c/src/exec/score/cpu/mips/idtmon.h (deleted) * c/src/exec/score/cpu/mips/iregdef.h (deleted) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (deleted) * c/src/exec/score/cpu/mips64orion/idtcpu.h (deleted) * c/src/exec/score/cpu/mips64orion/idtmon.h (deleted) * c/src/exec/score/cpu/mips64orion/iregdef.h (deleted) * c/src/exec/score/cpu/mips64orion/mipstypes.h (deleted) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (deleted) * c/src/exec/score/cpu/no_cpu/no_cpu.h (deleted) * c/src/exec/score/cpu/no_cpu/no_cputypes.h (deleted) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/cpu.h (deleted) * c/src/exec/score/cpu/powerpc/ppc.h (deleted) * c/src/exec/score/cpu/powerpc/ppctypes.h (deleted) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/cpu.h (deleted) * c/src/exec/score/cpu/sh/cpu_isps.h (deleted) * c/src/exec/score/cpu/sh/iosh7030.h (deleted) * c/src/exec/score/cpu/sh/sh.h (deleted) * c/src/exec/score/cpu/sh/sh_io.h (deleted) * c/src/exec/score/cpu/sh/shtypes.h (deleted) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/cpu.h (deleted) * c/src/exec/score/cpu/sparc/sparc.h (deleted) * c/src/exec/score/cpu/sparc/sparctypes.h (deleted) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/cpu.h (deleted) * c/src/exec/score/cpu/unix/unix.h (deleted) * c/src/exec/score/cpu/unix/unixtypes.h (deleted) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * cpukit/score/cpu/mips/idtcpu.h (deleted) * cpukit/score/cpu/mips/iregdef.h (deleted) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (deleted) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (deleted) * cpukit/score/cpu/mips64orion/idtcpu.h (deleted) * cpukit/score/cpu/mips64orion/idtmon.h (deleted) * cpukit/score/cpu/mips64orion/iregdef.h (deleted) Yet another part of automake VI from Ralf Corsepius [38840f7b] * c/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * make/leaf.cfg (modified) Part of the automake VI patch from Ralf Corsepius [4cc89bd] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added rejected patch from automake VI from Ralf Corsepius. Thu, 18 Feb 1999 17:55:49 GMT Joel Sherrill [a110b68] * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/ods68302.cfg (modified) Part of automake VI patch from Ralf Corsepius [011677f] * c/src/make/host.cfg.in (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) Part of automake VI Patch from Ralf Corsepius [1fdc990] * c/Makefile.in (modified) * make/leaf.cfg (modified) Part of the targopts.h change in generation patch from Ralf Corsepius ... Thu, 18 Feb 1999 17:26:37 GMT Joel Sherrill [6b9aaf7] * c/src/exec/score/macros/Makefile.in (modified) Corrected. Thu, 18 Feb 1999 17:26:11 GMT Joel Sherrill [3b7f138] * c/src/exec/score/inline/Makefile.in (added) Readded. Thu, 18 Feb 1999 17:26:10 GMT Joel Sherrill [0fc85c50] * c/src/exec/score/inline/Makefile.in (deleted) * c/src/exec/score/inline/address.inl (deleted) * c/src/exec/score/inline/chain.inl (deleted) * c/src/exec/score/inline/coremsg.inl (deleted) * c/src/exec/score/inline/coremutex.inl (deleted) * c/src/exec/score/inline/coresem.inl (deleted) * c/src/exec/score/inline/heap.inl (deleted) * c/src/exec/score/inline/isr.inl (deleted) * c/src/exec/score/inline/mppkt.inl (deleted) * c/src/exec/score/inline/object.inl (deleted) * c/src/exec/score/inline/objectmp.inl (deleted) * c/src/exec/score/inline/priority.inl (deleted) * c/src/exec/score/inline/stack.inl (deleted) * c/src/exec/score/inline/states.inl (deleted) * c/src/exec/score/inline/sysstate.inl (deleted) * c/src/exec/score/inline/thread.inl (deleted) * c/src/exec/score/inline/threadmp.inl (deleted) * c/src/exec/score/inline/tod.inl (deleted) * c/src/exec/score/inline/tqdata.inl (deleted) * c/src/exec/score/inline/userext.inl (deleted) * c/src/exec/score/inline/watchdog.inl (deleted) * c/src/exec/score/inline/wkspace.inl (deleted) * c/src/exec/score/macros/address.inl (deleted) * c/src/exec/score/macros/chain.inl (deleted) * c/src/exec/score/macros/coremsg.inl (deleted) * c/src/exec/score/macros/coremutex.inl (deleted) * c/src/exec/score/macros/coresem.inl (deleted) * c/src/exec/score/macros/heap.inl (deleted) * c/src/exec/score/macros/isr.inl (deleted) * c/src/exec/score/macros/mppkt.inl (deleted) * c/src/exec/score/macros/object.inl (deleted) * c/src/exec/score/macros/objectmp.inl (deleted) * c/src/exec/score/macros/priority.inl (deleted) * c/src/exec/score/macros/stack.inl (deleted) * c/src/exec/score/macros/states.inl (deleted) * c/src/exec/score/macros/sysstate.inl (deleted) * c/src/exec/score/macros/thread.inl (deleted) * c/src/exec/score/macros/threadmp.inl (deleted) * c/src/exec/score/macros/tod.inl (deleted) * c/src/exec/score/macros/tqdata.inl (deleted) * c/src/exec/score/macros/userext.inl (deleted) * c/src/exec/score/macros/watchdog.inl (deleted) * c/src/exec/score/macros/wkspace.inl (deleted) Should have been removed earlier. Thu, 18 Feb 1999 17:16:48 GMT Joel Sherrill [e4071cf] * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) Patch from Ralf Corsepius : This patch ... Thu, 18 Feb 1999 16:48:14 GMT Joel Sherrill [0c04c377] * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/README (added) * c/src/lib/libbsp/powerpc/ppcn_60x/STATUS (added) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/clock.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042vga.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042vga.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550cfg.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550cfg.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/vga.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/vga_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30cfg.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30cfg.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/chain.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/extisrdrv.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/nvram.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/pci.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/tod.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/amd79c970.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/amd79c970.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/ds1385.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/mk48t18.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/nvram.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/prepnvr.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/stk11c68.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/pci.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/start.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bsptrap.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/genpvec.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/rtems-ctor.cc (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/spurious.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/swap.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/timer.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/cmos.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/tod.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/universe.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/README (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/align_h.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/vectors.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (added) * make/custom/ppcn_60x.cfg (added) ./clock/Makefile.in,v ./clock/clock.c,v ./console/Makefile.in,v ... Thu, 18 Feb 1999 16:47:06 GMT Joel Sherrill [3492f29] * c/src/lib/libbsp/powerpc/ppcn_60x/console/debugio.c (added) ./clock/Makefile.in,v ./clock/clock.c,v ./console/Makefile.in,v ... Thu, 18 Feb 1999 16:09:25 GMT Joel Sherrill [df0ac0b] * c/src/exec/score/headers/Makefile.in (deleted) * c/src/exec/score/headers/address.h (deleted) * c/src/exec/score/headers/apiext.h (deleted) * c/src/exec/score/headers/bitfield.h (deleted) * c/src/exec/score/headers/chain.h (deleted) * c/src/exec/score/headers/context.h (deleted) * c/src/exec/score/headers/copyrt.h (deleted) * c/src/exec/score/headers/coremsg.h (deleted) * c/src/exec/score/headers/coremutex.h (deleted) * c/src/exec/score/headers/coresem.h (deleted) * c/src/exec/score/headers/debug.h (deleted) * c/src/exec/score/headers/heap.h (deleted) * c/src/exec/score/headers/interr.h (deleted) * c/src/exec/score/headers/isr.h (deleted) * c/src/exec/score/headers/mpci.h (deleted) * c/src/exec/score/headers/mppkt.h (deleted) * c/src/exec/score/headers/object.h (deleted) * c/src/exec/score/headers/objectmp.h (deleted) * c/src/exec/score/headers/priority.h (deleted) * c/src/exec/score/headers/stack.h (deleted) * c/src/exec/score/headers/states.h (deleted) * c/src/exec/score/headers/sysstate.h (deleted) * c/src/exec/score/headers/system.h (deleted) * c/src/exec/score/headers/thread.h (deleted) * c/src/exec/score/headers/threadmp.h (deleted) * c/src/exec/score/headers/threadq.h (deleted) * c/src/exec/score/headers/tod.h (deleted) * c/src/exec/score/headers/tqdata.h (deleted) * c/src/exec/score/headers/userext.h (deleted) * c/src/exec/score/headers/watchdog.h (deleted) * c/src/exec/score/headers/wkspace.h (deleted) Should have been removed from cvs early. Thu, 18 Feb 1999 15:16:37 GMT Joel Sherrill [e029467] * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/registers.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) Patch from Emmanuel Raguet : You will find ... Thu, 18 Feb 1999 15:11:41 GMT Joel Sherrill [edfb0eb] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) GLobal reentrancy structure is now dynamically initialized. Thu, 18 Feb 1999 15:11:24 GMT Joel Sherrill [60f67aea] * c/src/lib/libcpu/powerpc/mpc860/include/console.h (modified) Added CVS Id string. Thu, 18 Feb 1999 15:09:59 GMT Joel Sherrill [9e5c391] * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/info.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/network.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/mmu.c (modified) Added or corrected CVS Id strings. Thu, 18 Feb 1999 15:09:27 GMT Joel Sherrill [4ef40152] * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/powerpc/ppc.h (modified) MPC860 support submitted by Jay Monkman . Wed, 17 Feb 1999 20:24:53 GMT Joel Sherrill [ee733965] * c/src/exec/score/cpu/powerpc/mpc860.h (added) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/README (added) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (added) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (added) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (added) * c/src/lib/libbsp/powerpc/eth_comm/include/canbus.h (added) * c/src/lib/libbsp/powerpc/eth_comm/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/eth_comm/include/info.h (added) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/network/README (added) * c/src/lib/libbsp/powerpc/eth_comm/network/network.c (added) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/alloc860.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/mmu.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/eth_comm/times (added) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/README (added) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (added) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/include/console.h (added) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/timer/timer.c (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/README (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/align_h.S (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/vectors.S (added) * make/custom/eth_comm.cfg (added) Jay Monkman submitted the eth_comm BSP for a ... Mon, 15 Feb 1999 18:56:08 GMT Joel Sherrill [7e2a525b] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) Patch from Eric Valette to undo the patch ... Mon, 15 Feb 1999 16:46:54 GMT Joel Sherrill [7cc7a74] * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) Patch from Eric Valette to correct _exit ... Wed, 10 Feb 1999 17:23:53 GMT Joel Sherrill [c8b5487] * VERSION (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 19990210 Wed, 10 Feb 1999 17:22:16 GMT Joel Sherrill [dae18b5] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) POSIX timer support. Wed, 10 Feb 1999 17:07:54 GMT Joel Sherrill [386289b] * c/src/tests/sptests/spfatal/README (added) * testsuites/sptests/spfatal/README (added) Added this file. Wed, 10 Feb 1999 17:06:53 GMT Joel Sherrill [3234c27] * c/src/tests/sptests/Makefile.in (modified) Don't build spfatal since it won't run anyway. Wed, 10 Feb 1999 17:06:27 GMT Joel Sherrill [f93d996] * c/src/tests/psxtests/psxtimer/Makefile.in (modified) Changed file name. Wed, 10 Feb 1999 17:05:55 GMT Joel Sherrill [9619ff3] * c/src/exec/libcsupport/src/open.c (modified) * c/src/lib/libc/open.c (modified) * cpukit/libcsupport/src/open.c (modified) Set the read/write offset to 0 when the file is opened. The ACVC had ... Wed, 10 Feb 1999 17:04:54 GMT Joel Sherrill [efb1b830] * c/src/exec/libfs/src/imfs/memfile.c (modified) * c/src/lib/libc/memfile.c (modified) * c/src/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) Corrected multiple places the file size was not being properly updated. Wed, 10 Feb 1999 17:04:12 GMT Joel Sherrill [3165b4d3] * c/src/exec/libcsupport/src/getcwd.c (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/getcwd.c (added) * cpukit/libcsupport/src/getcwd.c (added) Added getcwd(). Wed, 10 Feb 1999 17:03:46 GMT Joel Sherrill [aee3d68] * c/src/exec/posix/src/pthreadkill.c (modified) * c/src/exec/posix/src/sigaction.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) POSIX timer support modifications. Wed, 10 Feb 1999 00:29:02 GMT Joel Sherrill [dd746c38] * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) Comments fixed after problem report from Ian Lance Taylor . Fri, 05 Feb 1999 00:34:17 GMT Joel Sherrill [c9c67390] * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/dmvsonic.c (added) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (added) * c/src/lib/libchip/network/README (added) * c/src/lib/libchip/network/README.sonic (added) * c/src/lib/libchip/network/sonic.c (added) * c/src/lib/libchip/network/sonic.h (added) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (added) * c/src/libchip/network/README (added) * c/src/libchip/network/README.sonic (added) * c/src/libchip/network/sonic.c (moved) * c/src/libchip/network/sonic.h (moved) * c/src/wrapup/Makefile.in (modified) Split SONIC chip into appropriate files for libchip'ing. The ... Fri, 05 Feb 1999 00:29:23 GMT Joel Sherrill [ecec2ba] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to correct bug induced by select() patch. Fri, 05 Feb 1999 00:28:43 GMT Joel Sherrill [2f87c843] * c/src/exec/libcsupport/src/mount.c (modified) * c/src/exec/libcsupport/src/open.c (modified) * c/src/exec/libfs/src/imfs/imfs_eval.c (modified) * c/src/lib/libc/imfs_eval.c (modified) * c/src/lib/libc/mount.c (modified) * c/src/lib/libc/open.c (modified) * c/src/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) Corrected spacing and added some new error checks that were needed ... Fri, 05 Feb 1999 00:27:30 GMT Joel Sherrill [e824fa5] * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) Added optional data and instruction caching enable calls. Fri, 05 Feb 1999 00:26:49 GMT Joel Sherrill [26e663d] * c/src/exec/score/cpu/powerpc/Makefile.in (modified) Added caching enable routines. Thu, 04 Feb 1999 23:45:55 GMT Joel Sherrill [13cc89e1] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Reorganized into libchip style but not yet split out into multiple ... Thu, 04 Feb 1999 22:59:46 GMT Joel Sherrill [7397638] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Works great now. Thu, 04 Feb 1999 15:00:14 GMT Joel Sherrill [354b00bc] * c/src/exec/libnetworking/sys/mbuf.h (modified) * c/src/lib/libnetworking/sys/mbuf.h (modified) * c/src/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/sys/mbuf.h (modified) Added printf()'s that can be uncommented to trace MBUF operations. ... Thu, 04 Feb 1999 14:59:42 GMT Joel Sherrill [83c7b00] * c/src/exec/libnetworking/rtems/tftp.h (modified) * c/src/lib/libnetworking/rtems/tftp.h (modified) * c/src/libnetworking/rtems/tftp.h (modified) * cpukit/libnetworking/rtems/tftp.h (modified) Modifed to reflect transition from device driver to file system. Thu, 04 Feb 1999 14:58:01 GMT Joel Sherrill [d3c1060] * c/src/exec/libnetworking/net/if.h (modified) * c/src/lib/libnetworking/net/if.h (modified) * c/src/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if.h (modified) Added debug printf()'s that are commented out. Uncommenting these ... Thu, 04 Feb 1999 14:56:09 GMT Joel Sherrill [1564ca8] * c/src/exec/libnetworking/netinet/in_cksum_powerpc.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_powerpc.c (modified) * c/src/libnetworking/netinet/in_cksum_powerpc.c (modified) * cpukit/libnetworking/netinet/in_cksum_powerpc.c (modified) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (modified) Added PowerPC specific header checksum code. Thu, 04 Feb 1999 14:56:03 GMT Joel Sherrill [8cce445] * c/src/exec/libnetworking/machine/in_cksum.h (modified) * c/src/lib/libnetworking/machine/in_cksum.h (modified) * c/src/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) Added PowerPC specific header checksum code. Added volatile to i386 ... Thu, 04 Feb 1999 14:54:31 GMT Joel Sherrill [c1a37d3e] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Debugged and now works except for handling of minor number. Thu, 04 Feb 1999 14:53:06 GMT Joel Sherrill [7c7fd4d] * c/src/exec/libnetworking/netinet/tcp_debug.c (modified) * c/src/exec/libnetworking/opt_tcpdebug.h (modified) * c/src/lib/libnetworking/netinet/tcp_debug.c (modified) * c/src/lib/libnetworking/opt_tcpdebug.h (modified) * c/src/libnetworking/netinet/tcp_debug.c (modified) * c/src/libnetworking/opt_tcpdebug.h (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/opt_tcpdebug.h (modified) Modified to include comments on how to get TCPDEBUG turned on and ... Wed, 03 Feb 1999 22:12:28 GMT Joel Sherrill [cd792a86] * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/malloctest/task1.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) Patch from John S Gwynne for malloctest. His ... Wed, 03 Feb 1999 16:22:18 GMT Joel Sherrill [0747e2d] * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/include/rtems/posix/ptimer.h (added) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/src/ptimer.c (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/src/posixapi.c (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/ptimer.h (added) * cpukit/posix/src/ptimer.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/posixapi.c (modified) POSIX Timers submitted by Juan Zamorano Flores ... Wed, 03 Feb 1999 16:21:11 GMT Joel Sherrill [c30d04d7] * c/src/tests/psxtests/Makefile.in (modified) New test from Juan Zamorano Flores ... Wed, 03 Feb 1999 16:20:38 GMT Joel Sherrill [657be8f5] * c/src/tests/psxtests/psxtimer/Makefile.in (added) * c/src/tests/psxtests/psxtimer/psxtimer.c (added) * c/src/tests/psxtests/psxtimer/psxtimer.scn (added) * c/src/tests/psxtests/psxtimer/system.h (added) * testsuites/psxtests/psxtimer/psxtimer.c (added) * testsuites/psxtests/psxtimer/psxtimer.scn (added) * testsuites/psxtests/psxtimer/system.h (added) New files from Juan Zamorano Flores ... Tue, 02 Feb 1999 21:56:15 GMT Joel Sherrill [9e43ee5] * c/src/exec/score/cpu/powerpc/ppccache.c (added) New file. Tue, 02 Feb 1999 21:15:15 GMT Joel Sherrill [13e11f6] * c/src/exec/libnetworking/netinet/ip_icmp.c (modified) * c/src/lib/libnetworking/netinet/ip_icmp.c (modified) * c/src/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) Added debug #define and commented it out. Tue, 02 Feb 1999 21:15:02 GMT Joel Sherrill [5d5f23b] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) Added PowerPC specific in_cksum file. Tue, 02 Feb 1999 21:14:44 GMT Joel Sherrill [9b9c4dfd] * c/src/exec/libnetworking/netinet/in_cksum_powerpc.c (added) * c/src/lib/libnetworking/netinet/in_cksum_powerpc.c (added) * c/src/libnetworking/netinet/in_cksum_powerpc.c (added) * cpukit/libnetworking/netinet/in_cksum_powerpc.c (added) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (added) New file. Based on the i386 version. Tue, 02 Feb 1999 16:28:42 GMT Joel Sherrill [811115de] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Added debug print routines for TX and RX descriptors. Fixed bug ... Tue, 02 Feb 1999 16:27:37 GMT Joel Sherrill [14faf00] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) Converted from DOS text file. Sun, 31 Jan 1999 20:52:35 GMT Joel Sherrill [01a2e18] * c/src/tests/psxtests/psxreaddir/test.c (modified) * testsuites/psxtests/psxreaddir/test.c (modified) Removed unneeded include of libio_.h. Sun, 31 Jan 1999 20:50:49 GMT Joel Sherrill [7b158663] * c/src/exec/libnetworking/sys/mbuf.h (modified) * c/src/lib/libnetworking/sys/mbuf.h (modified) * c/src/libnetworking/sys/mbuf.h (modified) * cpukit/libnetworking/sys/mbuf.h (modified) Prepended macro variables with "_" to avoid name conflicts in expansions. Sun, 31 Jan 1999 20:49:54 GMT Joel Sherrill [0e94e3b3] * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) Added bump buffer. Sun, 31 Jan 1999 20:49:36 GMT Joel Sherrill [d93b23d] * c/src/lib/libmisc/Makefile.in (modified) Added dump buffer. Sun, 31 Jan 1999 20:46:52 GMT Joel Sherrill [7dbab720] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) Can send and receive packets but fails when TDA wraps. There appears ... Sun, 31 Jan 1999 20:45:31 GMT Joel Sherrill [07d880f4] * c/src/exec/posix/include/rtems/posix/psignal.h (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/src/alarm.c (added) * c/src/exec/posix/src/kill.c (added) * c/src/exec/posix/src/killinfo.c (added) * c/src/exec/posix/src/pause.c (added) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/posix/src/pthreadkill.c (added) * c/src/exec/posix/src/pthreadsigmask.c (added) * c/src/exec/posix/src/sigaction.c (added) * c/src/exec/posix/src/sigaddset.c (added) * c/src/exec/posix/src/sigdelset.c (added) * c/src/exec/posix/src/sigemptyset.c (added) * c/src/exec/posix/src/sigfillset.c (added) * c/src/exec/posix/src/sigismember.c (added) * c/src/exec/posix/src/sigpending.c (added) * c/src/exec/posix/src/sigprocmask.c (added) * c/src/exec/posix/src/sigqueue.c (added) * c/src/exec/posix/src/sigsuspend.c (added) * c/src/exec/posix/src/sigtimedwait.c (added) * c/src/exec/posix/src/sigwait.c (added) * c/src/exec/posix/src/sigwaitinfo.c (added) * cpukit/posix/include/rtems/posix/psignal.h (modified) * cpukit/posix/src/alarm.c (added) * cpukit/posix/src/kill.c (added) * cpukit/posix/src/killinfo.c (added) * cpukit/posix/src/pause.c (added) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/pthreadkill.c (added) * cpukit/posix/src/pthreadsigmask.c (added) * cpukit/posix/src/sigaction.c (added) * cpukit/posix/src/sigaddset.c (added) * cpukit/posix/src/sigdelset.c (added) * cpukit/posix/src/sigemptyset.c (added) * cpukit/posix/src/sigfillset.c (added) * cpukit/posix/src/sigismember.c (added) * cpukit/posix/src/sigpending.c (added) * cpukit/posix/src/sigprocmask.c (added) * cpukit/posix/src/sigqueue.c (added) * cpukit/posix/src/sigsuspend.c (added) * cpukit/posix/src/sigtimedwait.c (added) * cpukit/posix/src/sigwait.c (added) * cpukit/posix/src/sigwaitinfo.c (added) Split psignal.c into many more files. This reduced the amount of ... Sun, 31 Jan 1999 19:12:46 GMT Joel Sherrill [379d2ed] * c/src/lib/libmisc/dumpbuf/Makefile.in (added) * c/src/lib/libmisc/dumpbuf/dumpbuf.c (added) * c/src/lib/libmisc/dumpbuf/dumpbuf.h (added) * c/src/libmisc/dumpbuf/Makefile.in (added) * c/src/libmisc/dumpbuf/dumpbuf.c (added) * c/src/libmisc/dumpbuf/dumpbuf.h (added) * cpukit/libmisc/dumpbuf/dumpbuf.c (added) * cpukit/libmisc/dumpbuf/dumpbuf.h (added) New files added to ease debugging. Thu, 28 Jan 1999 18:42:34 GMT Joel Sherrill [cdf8a300] * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum to avoid dereferencing ... Thu, 28 Jan 1999 18:42:04 GMT Joel Sherrill [c9df8d8f] * c/src/exec/libcsupport/src/libio_sockets.c (modified) * c/src/lib/libc/libio_sockets.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) Patch from Eric Norum to set more flags in ... Tue, 26 Jan 1999 16:00:04 GMT Joel Sherrill [d90df9aa] * c/src/exec/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) Added include of so a macro would expand ... Tue, 26 Jan 1999 01:50:31 GMT Joel Sherrill [39ba9122] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer ... Tue, 26 Jan 1999 01:49:56 GMT Joel Sherrill [887618b0] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) Switched from printf() to puts(). Tue, 26 Jan 1999 01:49:31 GMT Joel Sherrill [d78b7a9e] * c/src/exec/libcsupport/src/libio_sockets.c (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/libio_sockets.c (added) * cpukit/libcsupport/src/libio_sockets.c (added) Added libio_sockets.c to hold support routines for networking code. Tue, 26 Jan 1999 01:48:58 GMT Joel Sherrill [39c9723] * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) Added prototype information about the SONIC driver. Mon, 25 Jan 1999 23:20:52 GMT Joel Sherrill [03598b1] * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadatfork.c (modified) * c/src/exec/posix/src/pthreadattrdestroy.c (added) * c/src/exec/posix/src/pthreadattrgetdetachstate.c (added) * c/src/exec/posix/src/pthreadattrgetinheritsched.c (added) * c/src/exec/posix/src/pthreadattrgetschedparam.c (added) * c/src/exec/posix/src/pthreadattrgetschedpolicy.c (added) * c/src/exec/posix/src/pthreadattrgetscope.c (added) * c/src/exec/posix/src/pthreadattrgetstackaddr.c (added) * c/src/exec/posix/src/pthreadattrgetstacksize.c (added) * c/src/exec/posix/src/pthreadattrinit.c (added) * c/src/exec/posix/src/pthreadattrsetdetachstate.c (added) * c/src/exec/posix/src/pthreadattrsetinheritsched.c (added) * c/src/exec/posix/src/pthreadattrsetschedparam.c (added) * c/src/exec/posix/src/pthreadattrsetschedpolicy.c (added) * c/src/exec/posix/src/pthreadattrsetscope.c (added) * c/src/exec/posix/src/pthreadattrsetstackaddr.c (added) * c/src/exec/posix/src/pthreadattrsetstacksize.c (added) * c/src/exec/posix/src/pthreadcreate.c (added) * c/src/exec/posix/src/pthreaddetach.c (added) * c/src/exec/posix/src/pthreadequal.c (added) * c/src/exec/posix/src/pthreadexit.c (added) * c/src/exec/posix/src/pthreadgetcpuclockid.c (added) * c/src/exec/posix/src/pthreadgetcputime.c (added) * c/src/exec/posix/src/pthreadgetschedparam.c (added) * c/src/exec/posix/src/pthreadjoin.c (added) * c/src/exec/posix/src/pthreadonce.c (added) * c/src/exec/posix/src/pthreadself.c (added) * c/src/exec/posix/src/pthreadsetcputime.c (added) * c/src/exec/posix/src/pthreadsetschedparam.c (added) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (added) * cpukit/posix/src/pthreadattrgetdetachstate.c (added) * cpukit/posix/src/pthreadattrgetinheritsched.c (added) * cpukit/posix/src/pthreadattrgetschedparam.c (added) * cpukit/posix/src/pthreadattrgetschedpolicy.c (added) * cpukit/posix/src/pthreadattrgetscope.c (added) * cpukit/posix/src/pthreadattrgetstackaddr.c (added) * cpukit/posix/src/pthreadattrgetstacksize.c (added) * cpukit/posix/src/pthreadattrinit.c (added) * cpukit/posix/src/pthreadattrsetdetachstate.c (added) * cpukit/posix/src/pthreadattrsetinheritsched.c (added) * cpukit/posix/src/pthreadattrsetschedparam.c (added) * cpukit/posix/src/pthreadattrsetschedpolicy.c (added) * cpukit/posix/src/pthreadattrsetscope.c (added) * cpukit/posix/src/pthreadattrsetstackaddr.c (added) * cpukit/posix/src/pthreadattrsetstacksize.c (added) * cpukit/posix/src/pthreadcreate.c (added) * cpukit/posix/src/pthreaddetach.c (added) * cpukit/posix/src/pthreadequal.c (added) * cpukit/posix/src/pthreadexit.c (added) * cpukit/posix/src/pthreadgetcpuclockid.c (added) * cpukit/posix/src/pthreadgetcputime.c (added) * cpukit/posix/src/pthreadgetschedparam.c (added) * cpukit/posix/src/pthreadjoin.c (added) * cpukit/posix/src/pthreadonce.c (added) * cpukit/posix/src/pthreadself.c (added) * cpukit/posix/src/pthreadsetcputime.c (added) * cpukit/posix/src/pthreadsetschedparam.c (added) Split most of POSIX Threads Manager into multiple files. Mon, 25 Jan 1999 23:20:39 GMT Joel Sherrill [535db3ae] * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) Added enough prototypes to allow most of POSIX Threads Manager to be ... Thu, 21 Jan 1999 22:25:43 GMT Joel Sherrill [94b3ee13] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/exec/libnetworking/libc/res_config.h (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_select.c (added) * c/src/exec/libnetworking/rtems/sghostname.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/libc/res_config.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_select.c (added) * c/src/lib/libnetworking/rtems/sghostname.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/libc/res_config.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_select.c (added) * c/src/libnetworking/rtems/sghostname.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_select.c (added) * cpukit/libnetworking/rtems/sghostname.c (modified) Made to compile after hacking tftp driver into beginnings of a mini- ... Wed, 20 Jan 1999 21:59:09 GMT Joel Sherrill [97d6366] * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) Changed call to __rtems_close() to close(). Wed, 20 Jan 1999 18:55:50 GMT Joel Sherrill [c27b2d0d] * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/network/netexterns.h (modified) * c/src/lib/libbsp/i386/i386ex/network/network.c (modified) * c/src/lib/libbsp/i386/i386ex/network/uti596.h (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) Update of network driver from Erik Ivanenko ... Wed, 20 Jan 1999 15:55:52 GMT Joel Sherrill [f91b8df1] * c/src/exec/score/cpu/m68k/m68360.h (modified) * cpukit/score/cpu/m68k/m68360.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68360.h (modified) Patch from Eric Norum to make m68360.h usable ... Wed, 20 Jan 1999 15:48:22 GMT Joel Sherrill [2d733c42] * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fstat.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fstat.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) More general fix based on bug report and patch from Ian Lance Taylor ... Tue, 19 Jan 1999 21:29:29 GMT Joel Sherrill [5f22d091] * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) Removed referencing to network driver since it has not been merged yet. Tue, 19 Jan 1999 20:23:57 GMT Joel Sherrill [7d0dbf1a] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Changed definition of ASMFLAGS since as does not recognize -B option ... Tue, 19 Jan 1999 20:23:15 GMT Joel Sherrill [a7c4314d] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Added comments for changing to a filesystem Tue, 19 Jan 1999 20:19:22 GMT Joel Sherrill [eb6fafd] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) Per bug report from Jiri Gaisler that RTEMS would no longer build ... Tue, 19 Jan 1999 20:17:33 GMT Joel Sherrill [1924610] * c/src/exec/score/inline/Makefile.in (modified) Removed duplicate lines in file. Tue, 19 Jan 1999 20:09:33 GMT Joel Sherrill [ba2adf5] * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (modified) * c/src/lib/libbsp/sparc/erc32/start/start.S (modified) * c/src/lib/libbsp/sparc/erc32/startsis/startsis.S (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) Patch from Jiri Gaisler : getting the ... Tue, 19 Jan 1999 17:38:13 GMT Joel Sherrill [b33d8a2] * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/sys/ioctl.h (deleted) * c/src/lib/include/Makefile.in (modified) Moved sys/ioctl.h to libc support Wed, 13 Jan 1999 14:13:47 GMT Joel Sherrill [16a9ee1] * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) Bug report from Jiri Gaisler : > > I think I ... Tue, 05 Jan 1999 17:50:03 GMT Joel Sherrill [97503aa5] * c/src/lib/libbsp/shared/main.c (modified) Patch from Chris Johns to get around a C++ problem with ... Mon, 04 Jan 1999 16:35:31 GMT Joel Sherrill [eb0d7ae] * c/src/exec/libnetworking/netinet/in_cksum_i386.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_i386.c (modified) * c/src/libnetworking/netinet/in_cksum_i386.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.h (modified) Patch from D. V. Henkel-Wallace to use puts and ... Mon, 04 Jan 1999 16:30:06 GMT Joel Sherrill [88a0908] * c/src/exec/libnetworking/netinet/tcp_input.c (modified) * c/src/lib/libnetworking/netinet/tcp_input.c (modified) * c/src/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) Patch from D. V. Henkel-Wallace to fix braces ... Mon, 04 Jan 1999 16:28:49 GMT Joel Sherrill [60a2d689] * c/src/exec/libnetworking/net/route.h (modified) * c/src/lib/libnetworking/net/route.h (modified) * c/src/libnetworking/net/route.h (modified) * cpukit/libnetworking/net/route.h (modified) Patch from D. V. Henkel-Wallace to make macro nest ...
