# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 10:12:47 Tue, 24 Apr 2018 05:25:25 GMT Sebastian Huber [b5d4c80] * bsps/powerpc/shared/flash/flash.c (moved) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) bsps: Move flash.c to bsps This patch is a part of the BSP source ... Tue, 24 Apr 2018 05:24:52 GMT Sebastian Huber [afa90ee5] * bsps/powerpc/shared/start/vpd.c (moved) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) bsps: Move vpd.c to bsps This patch is a part of the BSP source ... Tue, 24 Apr 2018 05:24:31 GMT Sebastian Huber [499385e] * bsps/powerpc/motorola_powerpc/start/motorola.c (moved) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) bsps: Move motorola.c to bsps This patch is a part of the BSP ... Tue, 24 Apr 2018 05:23:19 GMT Sebastian Huber [173e157] * bsps/powerpc/motorola_powerpc/start/residual.c (moved) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) bsps: Move residual.c to bsps This patch is a part of the BSP ... Tue, 24 Apr 2018 05:21:51 GMT Sebastian Huber [1cc69e1] * bsps/powerpc/shared/start/showbats.c (moved) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) bsps: Move showbats.c to bsps This patch is a part of the BSP ... Tue, 24 Apr 2018 05:21:22 GMT Sebastian Huber [7091461] * bsps/powerpc/shared/exceptions/ppc-exc-handler-table.c (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) bsps: Move ppc-exc-handler-table.c to bsps This patch is a part of ... Tue, 24 Apr 2018 05:19:46 GMT Sebastian Huber [b8777d93] * bsps/powerpc/shared/start/memcpy.c (moved) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) bsps: Move memcpy.c to bsps This patch is a part of the BSP source ... Tue, 24 Apr 2018 05:19:19 GMT Sebastian Huber [1163f502] * bsps/powerpc/shared/start/tictac.c (moved) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) bsps: Move tictac.c to bsps This patch is a part of the BSP source ... Tue, 24 Apr 2018 05:18:09 GMT Sebastian Huber [670f104] * bsps/powerpc/shared/u-boot/uboot_dump_bdinfo.c (moved) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) bsps: Move uboot_dump_bdinfo.c to bsps This patch is a part of the ... Tue, 24 Apr 2018 05:17:46 GMT Sebastian Huber [2101f54] * bsps/powerpc/shared/u-boot/uboot_getenv.c (moved) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) bsps: Move uboot_getenv.c to bsps This patch is a part of the BSP ... Tue, 24 Apr 2018 05:06:36 GMT Sebastian Huber [03e1d837] * bsps/powerpc/motorola_powerpc/bootloader/README (moved) * bsps/powerpc/motorola_powerpc/bootloader/bootldr.h (moved) * bsps/powerpc/motorola_powerpc/bootloader/em86.c (moved) * bsps/powerpc/motorola_powerpc/bootloader/em86real.S (moved) * bsps/powerpc/motorola_powerpc/bootloader/exception.S (moved) * bsps/powerpc/motorola_powerpc/bootloader/head.S (moved) * bsps/powerpc/motorola_powerpc/bootloader/lib.c (moved) * bsps/powerpc/motorola_powerpc/bootloader/misc.c (moved) * bsps/powerpc/motorola_powerpc/bootloader/mm.c (moved) * bsps/powerpc/motorola_powerpc/bootloader/pci.c (moved) * bsps/powerpc/motorola_powerpc/bootloader/pci.h (moved) * bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds (moved) * bsps/powerpc/motorola_powerpc/bootloader/qemu_fakeres.c (moved) * bsps/powerpc/motorola_powerpc/bootloader/qemu_fakerom.S (moved) * bsps/powerpc/motorola_powerpc/bootloader/zlib.c (moved) * bsps/powerpc/motorola_powerpc/bootloader/zlib.h (moved) * bsps/powerpc/motorola_powerpc/console/console.inl (moved) * bsps/powerpc/motorola_powerpc/console/keyboard.h (moved) * bsps/powerpc/motorola_powerpc/console/polled_io.c (moved) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/Makefile.am (modified) bsps/powerpc: Move bootloader to bsps This bootloader is only used ... Tue, 24 Apr 2018 04:39:19 GMT Sebastian Huber [0180acf2] * c/src/lib/libbsp/arm/shared/comm/uart.c (deleted) bsps/arm: Remove unused shared/comm/uart.c This patch is a part of ... Tue, 24 Apr 2018 04:37:06 GMT Sebastian Huber [65e59cc0] * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/headers.am (modified) * bsps/include/bsp/mm.h (deleted) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/mminit.c (deleted) bsps/arm: Move bsp_memory_management_initialize() This function is ... Tue, 24 Apr 2018 04:19:15 GMT Sebastian Huber [c99e4f4e] * c/src/lib/libbsp/MERGE.PROCEDURE (deleted) * c/src/lib/libbsp/README (deleted) bsps: Remove obsolete documentation This patch is a part of the BSP ... Tue, 24 Apr 2018 04:16:02 GMT Sebastian Huber [56bd37bf] * c/src/lib/libbsp/arm/csb336/times (deleted) * c/src/lib/libbsp/arm/csb337/times (deleted) * c/src/lib/libbsp/arm/edb7312/times (deleted) * c/src/lib/libbsp/arm/rtl22xx/times (deleted) * c/src/lib/libbsp/bfin/TLL6527M/times (deleted) * c/src/lib/libbsp/bfin/eZKit533/times (deleted) * c/src/lib/libbsp/m68k/csb360/times (deleted) * c/src/lib/libbsp/m68k/mcf5206elite/times (deleted) * c/src/lib/libbsp/m68k/mrm332/times (deleted) * c/src/lib/libbsp/m68k/mvme147/times (deleted) * c/src/lib/libbsp/m68k/mvme147s/times (deleted) * c/src/lib/libbsp/m68k/mvme162/times (deleted) * c/src/lib/libbsp/m68k/mvme167/times (deleted) * c/src/lib/libbsp/mips/csb350/times (deleted) * c/src/lib/libbsp/mips/hurricane/times (deleted) * c/src/lib/libbsp/nios2/nios2_iss/times (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/times (deleted) * c/src/lib/libbsp/powerpc/mpc8260ads/times (deleted) * c/src/lib/libbsp/powerpc/ss555/times (deleted) * c/src/lib/libbsp/sh/gensh1/times (deleted) * c/src/lib/libbsp/sh/gensh4/times (deleted) * c/src/lib/libbsp/sparc/erc32/times (deleted) * c/src/lib/libbsp/sparc/leon2/times (deleted) * c/src/lib/libbsp/sparc/leon3/times (deleted) bsps: Remove unmaintained times files This patch is a part of the ... Mon, 23 Apr 2018 11:31:18 GMT Sebastian Huber [21978523] * bsps/lm32/shared/milkymist_ac97/ac97.c (moved) * bsps/lm32/shared/milkymist_buttons/buttons.c (moved) * bsps/lm32/shared/milkymist_clock/ckinit.c (moved) * bsps/lm32/shared/milkymist_clock/clock.h (moved) * bsps/lm32/shared/milkymist_console/console.c (moved) * bsps/lm32/shared/milkymist_console/uart.c (moved) * bsps/lm32/shared/milkymist_console/uart.h (moved) * bsps/lm32/shared/milkymist_dmx/dmx.c (moved) * bsps/lm32/shared/milkymist_flash/flash.c (moved) * bsps/lm32/shared/milkymist_framebuffer/framebuffer.c (moved) * bsps/lm32/shared/milkymist_gpio/gpio.c (moved) * bsps/lm32/shared/milkymist_ir/ir.c (moved) * bsps/lm32/shared/milkymist_memcard/memcard.c (moved) * bsps/lm32/shared/milkymist_midi/midi.c (moved) * bsps/lm32/shared/milkymist_pfpu/pfpu.c (moved) * bsps/lm32/shared/milkymist_timer/timer.c (moved) * bsps/lm32/shared/milkymist_tmu/tmu.c (moved) * bsps/lm32/shared/milkymist_usbinput/comloc.h (moved) * bsps/lm32/shared/milkymist_usbinput/usbinput.c (moved) * bsps/lm32/shared/milkymist_versions/versions.c (moved) * bsps/lm32/shared/milkymist_video/video.c (moved) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) bsps/lm32: Move shared drivers to bsps This patch is a part of the ... Mon, 23 Apr 2018 10:53:28 GMT Sebastian Huber [fc79b26] * bsps/i386/pc386/ata/ide.c (moved) * bsps/i386/pc386/ata/idecfg.c (moved) * bsps/powerpc/gen5200/ata/ata-dma-pio-single.c (moved) * bsps/powerpc/gen5200/ata/ata-instance.c (moved) * bsps/powerpc/gen5200/ata/idecfg.c (moved) * bsps/powerpc/gen5200/ata/pcmcia_ide.c (moved) * bsps/powerpc/gen5200/ata/pcmcia_ide.h (moved) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) bsps: Move ATA drivers to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 10:50:58 GMT Sebastian Huber [5a4e3dc0] * bsps/i386/shared/pci/pci_io.c (moved) * bsps/i386/shared/pci/pcibios.c (moved) * bsps/mips/malta/pci/pci.c (moved) * bsps/powerpc/beatnik/pci/gt_pci_init.c (moved) * bsps/powerpc/beatnik/pci/motload_fixup.c (moved) * bsps/powerpc/beatnik/pci/pci_io_remap.c (moved) * bsps/powerpc/beatnik/pci/pci_io_remap.h (moved) * bsps/powerpc/mvme3100/pci/detect_host_bridge.c (moved) * bsps/powerpc/mvme5500/pci/detect_host_bridge.c (moved) * bsps/powerpc/mvme5500/pci/pci.c (moved) * bsps/powerpc/mvme5500/pci/pci_interface.c (moved) * bsps/powerpc/shared/pci/detect_raven_bridge.c (moved) * bsps/powerpc/shared/pci/generic_clear_hberrs.c (moved) * bsps/powerpc/shared/pci/pci.c (moved) * bsps/powerpc/shared/pci/pcifinddevice.c (moved) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) bsps: Move PCI drivers to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 10:10:19 GMT Sebastian Huber [6e1cf37] * bsps/sh/shared/console/console.c (moved) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) bsps/sh: Move console.c to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 10:10:07 GMT Sebastian Huber [e617455] * bsps/sh/shared/start/setvec.c (moved) bsps/sh: Move setvec.c to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 10:09:58 GMT Sebastian Huber [b4de37fd] * bsps/sh/shared/start/bsphwinit.c (moved) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) bsps/sh: Move bsphwinit.c to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 10:06:14 GMT Sebastian Huber [fd67814] * bsps/lm32/shared/gdbstub/README (moved) * bsps/lm32/shared/gdbstub/gdb_if.h (moved) * bsps/lm32/shared/gdbstub/lm32-debug.S (moved) * bsps/lm32/shared/gdbstub/lm32-stub.c (moved) * bsps/m68k/shared/gdbstub/gdb_if.h (moved) * bsps/m68k/shared/gdbstub/m68k-stub.c (moved) * bsps/mips/shared/gdbstub/README (moved) * bsps/mips/shared/gdbstub/gdb_if.h (moved) * bsps/mips/shared/gdbstub/memlimits.h (moved) * bsps/mips/shared/gdbstub/mips-stub.c (moved) * bsps/mips/shared/gdbstub/mips_opcode.h (moved) bsps: Move GDB stubs to bsps This patch is a part of the BSP source ... Mon, 23 Apr 2018 10:04:31 GMT Sebastian Huber [4ccbac63] * bsps/v850/shared/start/crt1.c (moved) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps/v850: Move crt1.c to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 07:57:54 GMT Sebastian Huber [142175ef] * bsps/sparc64/shared/helenos/LICENSE (moved) * bsps/sparc64/shared/helenos/README (moved) * bsps/sparc64/shared/helenos/boot/genarch/balloc.c (moved) * bsps/sparc64/shared/helenos/boot/genarch/ofw.c (moved) * bsps/sparc64/shared/helenos/boot/genarch/ofw_tree.c (moved) * bsps/sparc64/shared/helenos/boot/generic/string.c (moved) * bsps/sparc64/shared/helenos/boot/sparc64/loader/main.c (moved) * bsps/sparc64/shared/helenos/boot/sparc64/loader/ofwarch.c (moved) * bsps/sparc64/shared/helenos/boot/sparc64/loader/ofwasm.S (moved) * bsps/sparc64/shared/helenos/kernel/sparc64/src/cache.S (moved) * bsps/sparc64/shared/helenos/kernel/sparc64/src/sun4u/takemmu.S (moved) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) bsps/sparc64: Move helenos to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 07:55:15 GMT Sebastian Huber [4fb1b79] * bsps/arm/altera-cyclone-v/rtc/rtc.c (moved) * bsps/arm/atsam/rtc/rtc-config.c (moved) * bsps/arm/lpc176x/rtc/rtc-config.c (moved) * bsps/arm/lpc24xx/rtc/rtc-config.c (moved) * bsps/arm/lpc32xx/rtc/rtc-config.c (moved) * bsps/m68k/mcf5206elite/rtc/ds1307.c (moved) * bsps/m68k/mcf5206elite/rtc/todcfg.c (moved) * bsps/m68k/mvme162/rtc/tod.c (moved) * bsps/powerpc/beatnik/rtc/todcfg.c (moved) * bsps/powerpc/gen5200/rtc/pcf8563.c (moved) * bsps/powerpc/gen5200/rtc/pcf8563.h (moved) * bsps/powerpc/gen5200/rtc/todcfg.c (moved) * bsps/powerpc/mvme3100/rtc/todcfg.c (moved) * bsps/powerpc/mvme5500/rtc/todcfg.c (moved) * bsps/powerpc/qoriq/rtc/rtc-config.c (moved) * bsps/powerpc/shared/rtc/todcfg.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) bsps: Move RTC drivers to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 07:53:31 GMT Sebastian Huber [031df391] * bsps/arm/atsam/net/if_atsam.c (moved) * bsps/arm/csb336/net/lan91c11x.c (moved) * bsps/arm/csb336/net/lan91c11x.h (moved) * bsps/arm/csb336/net/network.c (moved) * bsps/arm/csb337/net/network.c (moved) * bsps/arm/edb7312/net/network.c (moved) * bsps/arm/gumstix/net/rtl8019.c (moved) * bsps/arm/gumstix/net/wd80x3.h (moved) * bsps/arm/rtl22xx/net/network.c (moved) * bsps/arm/shared/net/lpc-ethernet.c (moved) * bsps/bfin/bf537Stamp/net/networkconfig.c (moved) * bsps/i386/pc386/net/3c509.c (moved) * bsps/i386/pc386/net/3c509.h (moved) * bsps/i386/pc386/net/elink.c (moved) * bsps/i386/pc386/net/elink.h (moved) * bsps/i386/pc386/net/ne2000.c (moved) * bsps/i386/pc386/net/wd8003.c (moved) * bsps/lm32/shared/net/dp83848phy.h (moved) * bsps/lm32/shared/net/network.c (moved) * bsps/lm32/shared/net/network.h (moved) * bsps/lm32/shared/net/tsmac.c (moved) * bsps/lm32/shared/net/tsmac.h (moved) * bsps/m68k/av5282/net/network.c (moved) * bsps/m68k/csb360/net/network.c (moved) * bsps/m68k/gen68360/net/network.c (moved) * bsps/m68k/genmcf548x/net/network.c (moved) * bsps/m68k/mcf5235/net/network.c (moved) * bsps/m68k/mcf5329/net/network.c (moved) * bsps/m68k/mvme167/net/network.c (moved) * bsps/m68k/mvme167/net/uti596.h (moved) * bsps/m68k/uC5282/net/network.c (moved) * bsps/mips/csb350/net/network.c (moved) * bsps/powerpc/beatnik/net/if_em/LICENSE (moved) * bsps/powerpc/beatnik/net/if_em/README (moved) * bsps/powerpc/beatnik/net/if_em/if_em.c (moved) * bsps/powerpc/beatnik/net/if_em/if_em.h (moved) * bsps/powerpc/beatnik/net/if_em/if_em_hw.c (moved) * bsps/powerpc/beatnik/net/if_em/if_em_hw.h (moved) * bsps/powerpc/beatnik/net/if_em/if_em_osdep.h (moved) * bsps/powerpc/beatnik/net/if_em/if_em_rtems.c (moved) * bsps/powerpc/beatnik/net/if_em/rtemscompat_defs.h (moved) * bsps/powerpc/beatnik/net/if_gfe/gtethreg.h (moved) * bsps/powerpc/beatnik/net/if_gfe/gtvar.h (moved) * bsps/powerpc/beatnik/net/if_gfe/if_gfe.c (moved) * bsps/powerpc/beatnik/net/if_gfe/if_gfe_rtems.c (moved) * bsps/powerpc/beatnik/net/if_gfe/if_gfevar.h (moved) * bsps/powerpc/beatnik/net/if_gfe/rtemscompat_defs.h (moved) * bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c (moved) * bsps/powerpc/beatnik/net/if_mve/mve_smallbuf_tst.c (moved) * bsps/powerpc/beatnik/net/if_mve/testing.c (moved) * bsps/powerpc/beatnik/net/porting/LICENSE (moved) * bsps/powerpc/beatnik/net/porting/Makefile.template (moved) * bsps/powerpc/beatnik/net/porting/README (moved) * bsps/powerpc/beatnik/net/porting/if_xxx.modini.c (moved) * bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c (moved) * bsps/powerpc/beatnik/net/porting/pcireg.h (moved) * bsps/powerpc/beatnik/net/porting/rtemscompat.h (moved) * bsps/powerpc/beatnik/net/porting/rtemscompat1.h (moved) * bsps/powerpc/beatnik/net/porting/rtemscompat_defs.h.template (moved) * bsps/powerpc/beatnik/net/support/bsp_attach.c (moved) * bsps/powerpc/beatnik/net/support/early_link_status.c (moved) * bsps/powerpc/gen5200/net/network.c (moved) * bsps/powerpc/gen83xx/net/network.c (moved) * bsps/powerpc/haleakala/net/network.c (moved) * bsps/powerpc/mpc55xxevb/net/if_smc.c (moved) * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (moved) * bsps/powerpc/mpc8260ads/net/README (moved) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.c (moved) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.h (moved) * bsps/powerpc/mpc8260ads/net/network.c (moved) * bsps/powerpc/mvme3100/net/tsec.c (moved) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (moved) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (moved) * bsps/powerpc/mvme5500/net/if_1GHz/pci_map.c (moved) * bsps/powerpc/psim/net/README (moved) * bsps/powerpc/psim/net/gdb-6.8-psim-hw_ethtap.diff (moved) * bsps/powerpc/psim/net/if_sim.c (moved) * bsps/powerpc/qoriq/net/if_intercom.c (moved) * bsps/powerpc/qoriq/net/network.c (moved) * bsps/powerpc/tqm8xx/net/network_fec.c (moved) * bsps/powerpc/tqm8xx/net/network_scc.c (moved) * bsps/powerpc/virtex/net/xiltemac.c (moved) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) bsps: Move legacy network drivers to bsps This patch is a part of ... Mon, 23 Apr 2018 07:50:39 GMT Sebastian Huber [8f8ccee] * bsps/arm/beagle/irq/irq.c (moved) * bsps/arm/csb336/irq/irq.c (moved) * bsps/arm/csb337/irq/irq.c (moved) * bsps/arm/edb7312/irq/bsp_irq_asm.S (moved) * bsps/arm/edb7312/irq/irq.c (moved) * bsps/arm/gdbarmsim/irq/irq-dispatch.c (moved) * bsps/arm/gdbarmsim/irq/irq.c (moved) * bsps/arm/gumstix/irq/irq.c (moved) * bsps/arm/lpc176x/irq/irq.c (moved) * bsps/arm/lpc24xx/irq/irq-dispatch.c (moved) * bsps/arm/lpc24xx/irq/irq.c (moved) * bsps/arm/lpc32xx/irq/irq.c (moved) * bsps/arm/raspberrypi/irq/irq.c (moved) * bsps/arm/rtl22xx/irq/irq.c (moved) * bsps/arm/shared/irq/irq-armv7m.c (moved) * bsps/arm/shared/irq/irq-dispatch-armv7m.c (moved) * bsps/arm/shared/irq/irq-gic.c (moved) * bsps/arm/smdk2410/irq/irq.c (moved) * bsps/arm/tms570/irq/irq.c (moved) * bsps/epiphany/epiphany_sim/irq/irq.c (moved) * bsps/i386/shared/irq/elcr.c (moved) * bsps/i386/shared/irq/elcr.h (moved) * bsps/i386/shared/irq/idt.c (moved) * bsps/i386/shared/irq/irq.c (moved) * bsps/i386/shared/irq/irq_asm.S (moved) * bsps/i386/shared/irq/irq_init.c (moved) * bsps/lm32/shared/irq/irq.c (moved) * bsps/m68k/genmcf548x/irq/intc-icr-init-values.c (moved) * bsps/m68k/genmcf548x/irq/irq.c (moved) * bsps/mips/csb350/irq/vectorisrs.c (moved) * bsps/mips/hurricane/irq/vectorisrs.c (moved) * bsps/mips/jmr3904/irq/vectorisrs.c (moved) * bsps/mips/malta/irq/interruptmask.c (moved) * bsps/mips/malta/irq/vectorisrs.c (moved) * bsps/mips/rbtx4925/irq/vectorisrs.c (moved) * bsps/mips/rbtx4938/irq/vectorisrs.c (moved) * bsps/mips/shared/irq/exception.S (moved) * bsps/mips/shared/irq/i8259.c (moved) * bsps/mips/shared/irq/interruptmask.c (moved) * bsps/mips/shared/irq/interruptmask_TX49.c (moved) * bsps/mips/shared/irq/irq.c (moved) * bsps/mips/shared/irq/vectorexceptions.c (moved) * bsps/or1k/generic_or1k/irq/irq.c (moved) * bsps/powerpc/beatnik/irq/discovery_pic.c (moved) * bsps/powerpc/beatnik/irq/irq_init.c (moved) * bsps/powerpc/beatnik/irq/irq_test_app.c (moved) * bsps/powerpc/gen5200/irq/irq.c (moved) * bsps/powerpc/gen83xx/irq/irq.c (moved) * bsps/powerpc/haleakala/irq/irq.c (moved) * bsps/powerpc/haleakala/irq/irq_init.c (moved) * bsps/powerpc/mpc8260ads/irq/irq.c (moved) * bsps/powerpc/mvme3100/irq/irq_init.c (moved) * bsps/powerpc/mvme5500/README.irq (moved) * bsps/powerpc/mvme5500/irq/BSP_irq.c (moved) * bsps/powerpc/mvme5500/irq/irq_init.c (moved) * bsps/powerpc/psim/irq/irq_init.c (moved) * bsps/powerpc/qemuppc/irq/irq_init.c (moved) * bsps/powerpc/qoriq/irq/irq.c (moved) * bsps/powerpc/shared/irq/i8259.c (moved) * bsps/powerpc/shared/irq/irq_init.c (moved) * bsps/powerpc/shared/irq/openpic.c (moved) * bsps/powerpc/shared/irq/openpic_i8259_irq.c (moved) * bsps/powerpc/t32mppc/irq/irq.c (moved) * bsps/powerpc/tqm8xx/irq/irq.c (moved) * bsps/powerpc/virtex/irq/irq_init.c (moved) * bsps/powerpc/virtex4/irq/irq_init.c (moved) * bsps/powerpc/virtex5/irq/irq_init.c (moved) * bsps/riscv/riscv_generic/irq/irq.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) bsps: Move interrupt controller support to bsps This patch is a ... Mon, 23 Apr 2018 07:48:52 GMT Sebastian Huber [276afd2b] * bsps/arm/atsam/spi/atsam_spi_bus.c (moved) * bsps/arm/atsam/spi/atsam_spi_init.c (moved) * bsps/arm/atsam/spi/sc16is752.c (moved) * bsps/arm/imx/spi/imx-ecspi.c (moved) * bsps/arm/raspberrypi/spi/spi.c (moved) * bsps/m68k/gen68360/spi/m360_spi.c (moved) * bsps/m68k/gen68360/spi/m360_spi.h (moved) * bsps/powerpc/gen83xx/spi/spi_init.c (moved) * bsps/powerpc/tqm8xx/spi/spi.c (moved) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsps: Move SPI drivers to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 07:45:28 GMT Sebastian Huber [a2dad96] * bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.c (moved) * bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h (moved) * bsps/arm/altera-cyclone-v/i2c/i2cdrv.c (moved) * bsps/arm/atsam/i2c/atsam_i2c_bus.c (moved) * bsps/arm/atsam/i2c/atsam_i2c_init.c (moved) * bsps/arm/beagle/i2c/bbb-i2c.c (moved) * bsps/arm/imx/i2c/imx-i2c.c (moved) * bsps/arm/lpc24xx/i2c/i2c-config.c (moved) * bsps/arm/lpc24xx/i2c/i2c.c (moved) * bsps/arm/lpc32xx/i2c/i2c.c (moved) * bsps/arm/raspberrypi/i2c/i2c.c (moved) * bsps/arm/stm32f4/i2c/i2c-config.c (moved) * bsps/arm/stm32f4/i2c/i2c.c (moved) * bsps/arm/xilinx-zynq/i2c/cadence-i2c.c (moved) * bsps/m68k/mcf5206elite/i2c/i2c.c (moved) * bsps/m68k/mcf5206elite/i2c/i2cdrv.c (moved) * bsps/powerpc/gen5200/i2c/i2c.c (moved) * bsps/powerpc/gen5200/i2c/i2cdrv.c (moved) * bsps/powerpc/gen5200/i2c/mpc5200mbus.c (moved) * bsps/powerpc/gen5200/i2c/mpc5200mbus.h (moved) * bsps/powerpc/gen83xx/i2c/i2c_init.c (moved) * bsps/powerpc/mpc55xxevb/i2c/i2c_init.c (moved) * bsps/powerpc/mvme3100/i2c/i2c_init.c (moved) * bsps/powerpc/mvme3100/i2c/mpc8540_i2c.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) bsps: Move I2C drivers to bsps This patch is a part of the BSP ... Mon, 23 Apr 2018 07:42:04 GMT Sebastian Huber [3bd30f4a] * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/CMSIS_END_USER_LICENCE_AGREEMENT.rtf (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f401xc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f401xe.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f405xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f407xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f410cx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f410rx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f410tx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f411xe.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f415xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f417xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f427xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f429xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f437xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f439xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f446xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f469xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f479xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/stm32f4xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Include/system_stm32f4xx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Release_Notes.html (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Device/ST/STM32F4xx/Source/Templates/system_stm32f4xx.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/README.txt (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/index.html (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/Legacy/stm32_hal_legacy.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32_hal_legacy.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_adc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_adc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_can.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_cec.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_conf.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_conf_template.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_cortex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_crc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_cryp.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_cryp_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dac.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dac_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dcmi.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dcmi_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_def.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dma.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dma2d.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dma_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_dsi.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_eth.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_flash.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_flash_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_flash_ramfunc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_fmpi2c.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_fmpi2c_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_gpio.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_gpio_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_hash.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_hash_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_hcd.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_i2c.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_i2c_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_i2s.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_i2s_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_irda.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_iwdg.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_lptim.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_ltdc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_ltdc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_nand.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_nor.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_pccard.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_pcd.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_pcd_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_pwr.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_pwr_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_qspi.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_rcc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_rcc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_rng.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_rtc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_rtc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_sai.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_sai_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_sd.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_sdram.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_smartcard.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_spdifrx.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_spi.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_sram.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_tim.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_tim_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_uart.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_usart.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_wwdg.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_fmc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_fsmc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_sdmmc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_usb.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Release_Notes.html (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_adc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_adc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_can.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_cec.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_cortex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_crc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_cryp.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_cryp_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dac.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dac_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dcmi.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dcmi_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dma.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dma2d.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dma_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_dsi.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_eth.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_flash.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_flash_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_flash_ramfunc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_fmpi2c.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_fmpi2c_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_gpio.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_hash.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_hash_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_hcd.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_i2c.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_i2c_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_i2s.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_i2s_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_irda.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_iwdg.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_lptim.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_ltdc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_ltdc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_msp_template.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_nand.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_nor.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pccard.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pcd.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pcd_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pwr.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pwr_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_qspi.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_rcc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_rcc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_rng.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_rtc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_rtc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_sai.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_sai_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_sd.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_sdram.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_smartcard.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_spdifrx.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_spi.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_sram.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_tim.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_tim_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_uart.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_usart.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_wwdg.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_ll_fmc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_ll_fsmc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_ll_sdmmc.c (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/STM32F4xx_HAL_Driver/Src/stm32f4xx_ll_usb.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/CMSIS_END_USER_LICENCE_AGREEMENT.rtf (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Include/stm32f745xx.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Include/stm32f746xx.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Include/stm32f756xx.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Include/stm32f7xx.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Include/system_stm32f7xx.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Release_Notes.html (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Source/Templates/arm/startup_stm32f745xx.s (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Source/Templates/arm/startup_stm32f746xx.s (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Source/Templates/arm/startup_stm32f756xx.s (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Source/Templates/gcc/startup_stm32f745xx.s (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Source/Templates/gcc/startup_stm32f746xx.s (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Source/Templates/gcc/startup_stm32f756xx.s (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Device/ST/STM32F7xx/Source/Templates/system_stm32f7xx.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/README.txt (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/index.html (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/Legacy/stm32_hal_legacy.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/headers.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_adc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_adc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_can.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_cec.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_conf.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_conf_template.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_cortex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_crc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_crc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_cryp.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_cryp_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_dac.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_dac_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_dcmi.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_dcmi_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_def.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_dma.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_dma2d.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_dma_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_eth.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_flash.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_flash_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_gpio.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_gpio_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_hash.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_hash_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_hcd.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_i2c.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_i2c_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_i2s.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_irda.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_irda_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_iwdg.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_lptim.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_ltdc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_nand.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_nor.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_pcd.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_pcd_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_pwr.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_pwr_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_qspi.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_rcc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_rcc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_rng.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_rtc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_rtc_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_sai.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_sai_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_sd.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_sdram.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_smartcard.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_smartcard_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_spdifrx.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_spi.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_sram.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_tim.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_tim_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_uart.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_uart_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_usart.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_usart_ex.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_hal_wwdg.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_ll_fmc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_ll_sdmmc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Inc/stm32f7xx_ll_usb.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Release_Notes.html (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_adc.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_adc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_can.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_cec.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_cortex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_crc.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_crc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_cryp.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_cryp_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_dac.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_dac_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_dcmi.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_dcmi_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_dma.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_dma2d.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_dma_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_eth.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_flash.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_flash_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_gpio.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_hash.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_hash_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_hcd.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_i2c.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_i2c_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_i2s.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_irda.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_iwdg.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_lptim.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_ltdc.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_msp_template.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_nand.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_nor.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_pcd.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_pcd_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_pwr.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_pwr_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_qspi.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_rcc.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_rcc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_rng.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_rtc.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_rtc_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_sai.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_sai_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_sd.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_sdram.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_smartcard.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_smartcard_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_spdifrx.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_spi.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_sram.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_tim.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_tim_ex.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_uart.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_usart.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_hal_wwdg.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_ll_fmc.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_ll_sdmmc.c (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/STM32F7xx_HAL_Driver/Src/stm32f7xx_ll_usb.c (deleted) bsps/arm: Remove unused stm32f* files This patch is a part of the ... Sun, 22 Apr 2018 13:38:55 GMT Sebastian Huber [a62c75c1] * bsps/arm/tms570/start/bspstarthooks-hwinit.c (moved) * bsps/arm/tms570/start/fail_notification.c (moved) * bsps/arm/tms570/start/init_emif_sdram.c (moved) * bsps/arm/tms570/start/init_esm.c (moved) * bsps/arm/tms570/start/init_pinmux.c (moved) * bsps/arm/tms570/start/init_system.c (moved) * bsps/arm/tms570/start/pinmux.c (moved) * bsps/arm/tms570/start/tms570-pom.c (moved) * bsps/arm/tms570/start/tms570_selftest.c (moved) * bsps/arm/tms570/start/tms570_selftest_par_can.c (moved) * bsps/arm/tms570/start/tms570_selftest_par_mibspi.c (moved) * bsps/arm/tms570/start/tms570_selftest_par_std.c (moved) * bsps/arm/tms570/start/tms570_selftest_parity.c (moved) * bsps/arm/tms570/start/tms570_sys_core.S (moved) * bsps/arm/tms570/start/tms570_tcram_tests.c (moved) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) bsp/tms570: Move more start to bsps This patch is a part of the BSP ... Sun, 22 Apr 2018 13:32:38 GMT Sebastian Huber [a0f04d6] * bsps/powerpc/gen5200/bestcomm/bestcomm_api.c (moved) * bsps/powerpc/gen5200/bestcomm/bestcomm_glue.c (moved) * bsps/powerpc/gen5200/bestcomm/dma_image.c (moved) * bsps/powerpc/gen5200/bestcomm/dma_image.reloc.c (moved) * bsps/powerpc/gen5200/bestcomm/load_task.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_ata.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_bdtable.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_0.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_1.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_fec_rx_bd.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_fec_tx_bd.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_dp_0.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_dp_1.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_dp_2.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_dp_3.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_0.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_1.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_rx_bd.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_gen_tx_bd.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_lpc.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_pci_rx.c (moved) * bsps/powerpc/gen5200/bestcomm/tasksetup_pci_tx.c (moved) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) bsp/gen5200: Move bestcomm to bsps This patch is a part of the BSP ... Sun, 22 Apr 2018 13:11:43 GMT Sebastian Huber [54aabb7] * bsps/arm/atsam/contrib/libraries/libboard/board.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/board_v71_xult.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/bmp.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/board_lowlevel.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/board_memories.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/cs2100.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/dbg_console.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/frame_buffer.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/gmacb_phy.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/gmii.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/ili9488.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/ili9488_dma.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/ili9488_ebi.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/ili9488_ebi_dma.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/ili9488_reg.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/ili9488_spi.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/ili9488_spi_dma.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/image_sensor_inf.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/lcd_color.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/lcd_draw.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/lcd_font.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/lcd_font10x14.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/lcd_gimp_image.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/lcdd.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/led.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/math.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/mcan_config.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/rtc_calib.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/s25fl1.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/include/wm8904.h (moved) * bsps/arm/atsam/contrib/libraries/libboard/resources_v71/system_samv71.c (moved) * bsps/arm/atsam/contrib/libraries/libboard/source/board_lowlevel.c (moved) * bsps/arm/atsam/contrib/libraries/libboard/source/board_memories.c (moved) * bsps/arm/atsam/contrib/libraries/libboard/source/dbg_console.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/acc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/aes.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/afe_dma.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/afec.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/dac_dma.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/efc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/exceptions.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/flashd.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/gmac.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/gmacd.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/hsmci.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/icm.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/isi.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/mcan.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/mediaLB.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/mpu.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/pio.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/pio_capture.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/pio_it.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/pmc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/pwmc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/qspi.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/qspi_dma.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/rstc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/rtc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/rtt.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/sdramc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/spi.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/spi_dma.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/ssc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/supc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/tc.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/trng.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/twi.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/twid.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/uart.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/uart_dma.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/usart.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/usart_dma.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/wdt.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/xdma_hardware_interface.c (moved) * bsps/arm/atsam/contrib/libraries/libchip/source/xdmad.c (moved) * bsps/arm/atsam/contrib/utils/utility.h (moved) * bsps/arm/atsam/start/iocopy.c (moved) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) bsp/atsam: Move libraries to bsps This patch is a part of the BSP ... Sun, 22 Apr 2018 13:05:47 GMT Sebastian Huber [f004ace8] * bsps/arm/altera-cyclone-v/contrib/hwlib/README.txt (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/include/alt_qspi.h (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_16550_uart.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_address_space.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_clock_manager.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_dma.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_dma_program.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_generalpurpose_io.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_i2c.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_qspi.c (moved) * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_reset_manager.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) bsp/altera-cyclone-v: Move hwlib to bsps This patch is a part of ... Sat, 21 Apr 2018 08:22:08 GMT Sebastian Huber [adb85dd] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * bootstrap (modified) * bsps/arm/altera-cyclone-v/config/altcycv.inc (moved) * bsps/arm/altera-cyclone-v/config/altcycv_devkit.cfg (moved) * bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg (moved) * bsps/arm/atsam/config/atsamv-testsuite.tcfg (moved) * bsps/arm/atsam/config/atsamv.cfg (moved) * bsps/arm/beagle/config/beagle.inc (moved) * bsps/arm/beagle/config/beagleboardorig.cfg (moved) * bsps/arm/beagle/config/beagleboardxm.cfg (moved) * bsps/arm/beagle/config/beagleboneblack.cfg (moved) * bsps/arm/beagle/config/beaglebonewhite.cfg (moved) * bsps/arm/csb336/config/csb336.cfg (moved) * bsps/arm/csb337/config/csb337.cfg (moved) * bsps/arm/csb337/config/csb637.cfg (moved) * bsps/arm/csb337/config/kit637_v6.cfg (moved) * bsps/arm/edb7312/config/edb7312.cfg (moved) * bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm1136jfs.cfg (moved) * bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm1136js.cfg (moved) * bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm7tdmi.cfg (moved) * bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm920.cfg (moved) * bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/armcortexa9.cfg (moved) * bsps/arm/gumstix/config/gumstix.cfg (moved) * bsps/arm/imx/config/imx7.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s3749-testsuite.tcfg (moved) * bsps/arm/lm3s69xx/config/lm3s3749.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s6965-testsuite.tcfg (moved) * bsps/arm/lm3s69xx/config/lm3s6965.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s6965_qemu.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s69xx.inc (moved) * bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg (moved) * bsps/arm/lm3s69xx/config/lm4f120.cfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed-testsuite.tcfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed.cfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram-testsuite.tcfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram.cfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram_eth.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx.inc (moved) * bsps/arm/lpc24xx/config/lpc17xx_ea_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_ea_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_ea_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_plx800_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_plx800_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_plx800_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc2362-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc2362.cfg (moved) * bsps/arm/lpc24xx/config/lpc23xx_tli800-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc23xx_tli800.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx.inc (moved) * bsps/arm/lpc24xx/config/lpc24xx_ea.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_rom_ext.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_plx800_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_plx800_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_plx800_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc40xx.inc (moved) * bsps/arm/lpc24xx/config/lpc40xx_ea_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc40xx_ea_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc40xx_ea_rom_int.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx.inc (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx_stage_1-testsuite.tcfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx_stage_1.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx_stage_2.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_phycore.cfg (moved) * bsps/arm/raspberrypi/config/raspberrypi.cfg (moved) * bsps/arm/raspberrypi/config/raspberrypi.inc (moved) * bsps/arm/raspberrypi/config/raspberrypi2.cfg (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu.cfg (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg (moved) * bsps/arm/rtl22xx/config/rtl22xx-testsuite.tcfg (moved) * bsps/arm/rtl22xx/config/rtl22xx.cfg (moved) * bsps/arm/rtl22xx/config/rtl22xx_t-testsuite.tcfg (moved) * bsps/arm/rtl22xx/config/rtl22xx_t.cfg (moved) * bsps/arm/smdk2410/config/smdk2410.cfg (moved) * bsps/arm/stm32f4/config/stm32f105rc-testsuite.tcfg (moved) * bsps/arm/stm32f4/config/stm32f105rc.cfg (moved) * bsps/arm/stm32f4/config/stm32f4-testsuite.tcfg (moved) * bsps/arm/stm32f4/config/stm32f4.cfg (moved) * bsps/arm/tms570/config/tms570ls3137.inc (moved) * bsps/arm/tms570/config/tms570ls3137_hdk-testsuite.tcfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk.cfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_intram-testsuite.tcfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_intram.cfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_sdram.cfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_with_loader-testsuite.tcfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_with_loader.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq.inc (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_a9_qemu.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zc702.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zc706.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zedboard.cfg (moved) * bsps/bfin/TLL6527M/config/TLL6527M.cfg (moved) * bsps/bfin/bf537Stamp/config/bf537Stamp.cfg (moved) * bsps/bfin/eZKit533/config/eZKit533.cfg (moved) * bsps/epiphany/epiphany_sim/config/epiphany_sim.cfg (moved) * bsps/i386/pc386/config/pc386.cfg (moved) * bsps/i386/pc386/config/pc486.cfg (moved) * bsps/i386/pc386/config/pc586-sse.cfg (moved) * bsps/i386/pc386/config/pc586.cfg (moved) * bsps/i386/pc386/config/pc686.cfg (moved) * bsps/i386/pc386/config/pcp4.cfg (moved) * bsps/lm32/lm32_evr/config/lm32_evr.cfg (moved) * bsps/lm32/lm32_evr/config/lm32_evr_gdbsim-testsuite.tcfg (moved) * bsps/lm32/lm32_evr/config/lm32_evr_gdbsim.cfg (moved) * bsps/lm32/milkymist/config/milkymist.cfg (moved) * bsps/m32c/m32cbsp/config/m32csim-testsuite.tcfg (moved) * bsps/m32c/m32cbsp/config/m32csim.cfg (moved) * bsps/m68k/av5282/config/av5282.cfg (moved) * bsps/m68k/csb360/config/csb360.cfg (moved) * bsps/m68k/gen68340/config/gen68340.cfg (moved) * bsps/m68k/gen68360/config/gen68360.cfg (moved) * bsps/m68k/gen68360/config/gen68360_040.cfg (moved) * bsps/m68k/gen68360/config/pgh360.cfg (moved) * bsps/m68k/genmcf548x/config/COBRA5475.cfg (moved) * bsps/m68k/genmcf548x/config/genmcf548x.inc (moved) * bsps/m68k/genmcf548x/config/m5484FireEngine.cfg (moved) * bsps/m68k/mcf5206elite/config/mcf5206elite-testsuite.tcfg (moved) * bsps/m68k/mcf5206elite/config/mcf5206elite.cfg (moved) * bsps/m68k/mcf52235/config/mcf52235-testsuite.tcfg (moved) * bsps/m68k/mcf52235/config/mcf52235.cfg (moved) * bsps/m68k/mcf5225x/config/mcf5225x-testsuite.tcfg (moved) * bsps/m68k/mcf5225x/config/mcf5225x.cfg (moved) * bsps/m68k/mcf5235/config/mcf5235.cfg (moved) * bsps/m68k/mcf5329/config/mcf5329.cfg (moved) * bsps/m68k/mrm332/config/mrm332-testsuite.tcfg (moved) * bsps/m68k/mrm332/config/mrm332.cfg (moved) * bsps/m68k/mvme147/config/mvme147.cfg (moved) * bsps/m68k/mvme147s/config/mvme147s.cfg (moved) * bsps/m68k/mvme162/config/mvme162-testsuite.tcfg (moved) * bsps/m68k/mvme162/config/mvme162.cfg (moved) * bsps/m68k/mvme162/config/mvme162lx-testsuite.tcfg (moved) * bsps/m68k/mvme162/config/mvme162lx.cfg (moved) * bsps/m68k/mvme167/config/mvme167.cfg (moved) * bsps/m68k/uC5282/config/uC5282.cfg (moved) * bsps/mips/csb350/config/csb350.cfg (moved) * bsps/mips/hurricane/config/hurricane-testsuite.tcfg (moved) * bsps/mips/hurricane/config/hurricane.cfg (moved) * bsps/mips/jmr3904/config/jmr3904-testsuite.tcfg (moved) * bsps/mips/jmr3904/config/jmr3904.cfg (moved) * bsps/mips/malta/config/malta.cfg (moved) * bsps/mips/rbtx4925/config/rbtx4925-testsuite.tcfg (moved) * bsps/mips/rbtx4925/config/rbtx4925.cfg (moved) * bsps/mips/rbtx4938/config/rbtx4938-testsuite.tcfg (moved) * bsps/mips/rbtx4938/config/rbtx4938.cfg (moved) * bsps/moxie/moxiesim/config/moxiesim-testsuite.tcfg (moved) * bsps/moxie/moxiesim/config/moxiesim.cfg (moved) * bsps/nios2/nios2_iss/config/nios2_iss.cfg (moved) * bsps/no_cpu/no_bsp/config/no_bsp.cfg (moved) * bsps/or1k/generic_or1k/config/generic_or1k-testsuite.tcfg (moved) * bsps/or1k/generic_or1k/config/generic_or1k.cfg (moved) * bsps/powerpc/beatnik/config/beatnik.cfg (moved) * bsps/powerpc/gen5200/config/brs5l.cfg (moved) * bsps/powerpc/gen5200/config/brs6l.cfg (moved) * bsps/powerpc/gen5200/config/dp2.cfg (moved) * bsps/powerpc/gen5200/config/gen5200.inc (moved) * bsps/powerpc/gen5200/config/icecube.cfg (moved) * bsps/powerpc/gen5200/config/pm520_cr825.cfg (moved) * bsps/powerpc/gen5200/config/pm520_ze30.cfg (moved) * bsps/powerpc/gen83xx/config/br_uid.cfg (moved) * bsps/powerpc/gen83xx/config/gen83xx.inc (moved) * bsps/powerpc/gen83xx/config/hsc_cm01.cfg (moved) * bsps/powerpc/gen83xx/config/mpc8309som.cfg (moved) * bsps/powerpc/gen83xx/config/mpc8313erdb.cfg (moved) * bsps/powerpc/gen83xx/config/mpc8349eamds.cfg (moved) * bsps/powerpc/haleakala/config/haleakala.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mcp750.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mtx603e.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mvme2100.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mvme2307.cfg (moved) * bsps/powerpc/motorola_powerpc/config/qemuprep-altivec.cfg (moved) * bsps/powerpc/motorola_powerpc/config/qemuprep.cfg (moved) * bsps/powerpc/mpc55xxevb/config/gwlcfm-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/gwlcfm.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb_spe-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb_spe.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc55xx.inc (moved) * bsps/powerpc/mpc55xxevb/config/mpc55xx_spe.inc (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_evb-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_evb.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5668g-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5668g.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_app-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_app.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_boot-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_boot.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_rsm6-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_rsm6.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb_spe-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb_spe.cfg (moved) * bsps/powerpc/mpc55xxevb/config/phycore_mpc5554-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/phycore_mpc5554.cfg (moved) * bsps/powerpc/mpc8260ads/config/mpc8260ads.cfg (moved) * bsps/powerpc/mvme3100/config/mvme3100.cfg (moved) * bsps/powerpc/mvme5500/config/mvme5500.cfg (moved) * bsps/powerpc/psim/config/psim.cfg (moved) * bsps/powerpc/qemuppc/config/qemuppc.cfg (moved) * bsps/powerpc/qoriq/config/qoriq.inc (moved) * bsps/powerpc/qoriq/config/qoriq_core_0-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_core_0.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_core_1-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_core_1.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_e500-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_e500.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_32-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_64-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg (moved) * bsps/powerpc/ss555/config/ss555.cfg (moved) * bsps/powerpc/t32mppc/config/t32mppc.cfg (moved) * bsps/powerpc/tqm8xx/config/pghplus.cfg (moved) * bsps/powerpc/tqm8xx/config/tqm8xx.inc (moved) * bsps/powerpc/tqm8xx/config/tqm8xx_stk8xx.cfg (moved) * bsps/powerpc/virtex/config/virtex.cfg (moved) * bsps/powerpc/virtex4/config/virtex4.cfg (moved) * bsps/powerpc/virtex5/config/virtex5.cfg (moved) * bsps/riscv/riscv_generic/config/riscv64_generic.cfg (moved) * bsps/riscv/riscv_generic/config/riscv_generic.cfg (moved) * bsps/sh/gensh1/config/gensh1-testsuite.tcfg (moved) * bsps/sh/gensh1/config/gensh1.cfg (moved) * bsps/sh/gensh2/config/gensh2-testsuite.tcfg (moved) * bsps/sh/gensh2/config/gensh2.cfg (moved) * bsps/sh/gensh4/config/gensh4.cfg (moved) * bsps/sh/shsim/config/simsh1-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh1.cfg (moved) * bsps/sh/shsim/config/simsh2-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh2.cfg (moved) * bsps/sh/shsim/config/simsh2e-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh2e.cfg (moved) * bsps/sh/shsim/config/simsh4-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh4.cfg (moved) * bsps/sparc/erc32/config/erc32.cfg (moved) * bsps/sparc/leon2/config/at697f.cfg (moved) * bsps/sparc/leon2/config/leon2.cfg (moved) * bsps/sparc/leon3/config/gr712rc.cfg (moved) * bsps/sparc/leon3/config/gr740.cfg (moved) * bsps/sparc/leon3/config/leon3.cfg (moved) * bsps/sparc/leon3/config/ut699.cfg (moved) * bsps/sparc/leon3/config/ut700.cfg (moved) * bsps/sparc64/niagara/config/niagara.cfg (moved) * bsps/sparc64/usiii/config/usiii.cfg (moved) * bsps/v850/gdbv850sim/config/v850e1sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850e1sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850e2sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850e2sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850e2v3sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850e2v3sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850esim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850esim.cfg (moved) * bsps/v850/gdbv850sim/config/v850essim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850essim.cfg (moved) * bsps/v850/gdbv850sim/config/v850sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850sim.inc (moved) * c/configure.ac (modified) * c/src/aclocal/bsp-alias.m4 (modified) * c/src/aclocal/check-custom-bsp.m4 (modified) * rtems-bsps (modified) * testsuites/aclocal/rtems-test-check.m4 (modified) bsps: Move make/custom/* files to bsps Adjust various build files. ... Sat, 21 Apr 2018 08:00:43 GMT Sebastian Huber [37dc047] * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/epiphany/configure.ac (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/generic_or1k/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/riscv/configure.ac (modified) * c/src/lib/libbsp/riscv/riscv_generic/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) bsps: Remove AC_CONFIG_SRCDIR() This AC_CONFIG_SRCDIR() is just a ... Fri, 20 Apr 2018 13:33:09 GMT Sebastian Huber [4b70ed9] * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) bsps/mvme147s: Fix Makefile.am This patch is a part of the BSP ... Fri, 20 Apr 2018 11:47:16 GMT Sebastian Huber [13091dc4] * bsps/sparc/leon3/start/amba.c (moved) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/leon3: Move AMBA support to bsps This patch is a part of the ... Fri, 20 Apr 2018 11:45:16 GMT Sebastian Huber [67e472c] * bsps/sparc/leon2/pci/at697_pci.c (moved) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) bsps/leon2: Move PCI driver to bsps This patch is a part of the BSP ... Fri, 20 Apr 2018 11:44:00 GMT Sebastian Huber [96faf12] * bsps/sparc/erc32/gnatsupp/gnatsupp.c (moved) * bsps/sparc/leon2/gnatsupp/gnatsupp.c (moved) * bsps/sparc/leon3/gnatsupp/gnatsupp.c (moved) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move gnatsupp to bsps This patch is a part of the BSP ... Fri, 20 Apr 2018 11:38:33 GMT Sebastian Huber [1efa1c8] * bsps/m68k/mvme147s/mpci/addrconv.c (moved) * bsps/m68k/mvme147s/mpci/getcfg.c (moved) * bsps/m68k/mvme147s/mpci/lock.c (moved) * bsps/m68k/mvme147s/mpci/mpisr.c (moved) * bsps/no_cpu/no_bsp/mpci/addrconv.c (moved) * bsps/no_cpu/no_bsp/mpci/getcfg.c (moved) * bsps/no_cpu/no_bsp/mpci/lock.c (moved) * bsps/no_cpu/no_bsp/mpci/mpisr.c (moved) * bsps/powerpc/psim/mpci/README (moved) * bsps/powerpc/psim/mpci/addrconv.c (moved) * bsps/powerpc/psim/mpci/getcfg.c (moved) * bsps/powerpc/psim/mpci/lock.c (moved) * bsps/powerpc/psim/mpci/mpisr.c (moved) * bsps/powerpc/qoriq/mpci/intercom-mpci.c (moved) * bsps/powerpc/qoriq/mpci/intercom.c (moved) * bsps/powerpc/qoriq/mpci/lock.S (moved) * bsps/sparc/leon3/mpci/README (moved) * bsps/sparc/leon3/mpci/addrconv.c (moved) * bsps/sparc/leon3/mpci/getcfg.c (moved) * bsps/sparc/leon3/mpci/lock.c (moved) * bsps/sparc/leon3/mpci/mpisr.c (moved) * c/src/aclocal/check-multiprocessing.m4 (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps: Move MPCI support to bsps This patch is a part of the BSP ... Fri, 20 Apr 2018 11:36:14 GMT Sebastian Huber [b15cb636] * bsps/sparc/erc32/net/erc32sonic.c (moved) * bsps/sparc/leon2/net/leon_open_eth.c (moved) * bsps/sparc/leon2/net/leon_smc91111.c (moved) * bsps/sparc/leon3/net/leon_greth.c (moved) * bsps/sparc/leon3/net/leon_open_eth.c (moved) * bsps/sparc/leon3/net/leon_smc91111.c (moved) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move network drivers to bsps This patch is a part of ... Fri, 20 Apr 2018 11:33:24 GMT Sebastian Huber [d60d303c] * bsps/sparc/shared/1553/b1553brm.c (moved) * bsps/sparc/shared/1553/b1553rt.c (moved) * bsps/sparc/shared/1553/gr1553b.c (moved) * bsps/sparc/shared/1553/gr1553bc.c (moved) * bsps/sparc/shared/1553/gr1553bm.c (moved) * bsps/sparc/shared/1553/gr1553rt.c (moved) * bsps/sparc/shared/amba/ahbstat.c (moved) * bsps/sparc/shared/amba/ambapp.c (moved) * bsps/sparc/shared/amba/ambapp_alloc.c (moved) * bsps/sparc/shared/amba/ambapp_count.c (moved) * bsps/sparc/shared/amba/ambapp_depth.c (moved) * bsps/sparc/shared/amba/ambapp_find_by_idx.c (moved) * bsps/sparc/shared/amba/ambapp_freq.c (moved) * bsps/sparc/shared/amba/ambapp_names.c (moved) * bsps/sparc/shared/amba/ambapp_old.c (moved) * bsps/sparc/shared/amba/ambapp_parent.c (moved) * bsps/sparc/shared/amba/ambapp_show.c (moved) * bsps/sparc/shared/analog/gradcdac.c (moved) * bsps/sparc/shared/ascs/grascs.c (moved) * bsps/sparc/shared/can/canmux.c (moved) * bsps/sparc/shared/can/grcan.c (moved) * bsps/sparc/shared/can/occan.c (moved) * bsps/sparc/shared/can/satcan.c (moved) * bsps/sparc/shared/drvmgr/ambapp_bus.c (moved) * bsps/sparc/shared/drvmgr/ambapp_bus_grlib.c (moved) * bsps/sparc/shared/drvmgr/ambapp_bus_leon2.c (moved) * bsps/sparc/shared/drvmgr/get_resarray_count.c (moved) * bsps/sparc/shared/drvmgr/leon2_amba_bus.c (moved) * bsps/sparc/shared/gnatcommon.c (moved) * bsps/sparc/shared/gpio/gpiolib.c (moved) * bsps/sparc/shared/gpio/grgpio.c (moved) * bsps/sparc/shared/i2c/i2cmst.c (moved) * bsps/sparc/shared/iommu/griommu.c (moved) * bsps/sparc/shared/irq/bsp_isr_handler.c (moved) * bsps/sparc/shared/irq/genirq.c (moved) * bsps/sparc/shared/irq/irq-shared.c (moved) * bsps/sparc/shared/l2c/l2c.c (moved) * bsps/sparc/shared/mem/mctrl.c (moved) * bsps/sparc/shared/net/README (moved) * bsps/sparc/shared/net/greth.c (moved) * bsps/sparc/shared/net/network_interface_add.c (moved) * bsps/sparc/shared/pci/gr_701.c (moved) * bsps/sparc/shared/pci/gr_cpci_gr740.c (moved) * bsps/sparc/shared/pci/gr_leon4_n2x.c (moved) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (moved) * bsps/sparc/shared/pci/gr_rasta_io.c (moved) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (moved) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (moved) * bsps/sparc/shared/pci/gr_tmtc_1553.c (moved) * bsps/sparc/shared/pci/grpci.c (moved) * bsps/sparc/shared/pci/grpci2.c (moved) * bsps/sparc/shared/pci/grpci2dma.c (moved) * bsps/sparc/shared/pci/pci_memreg_sparc_be.c (moved) * bsps/sparc/shared/pci/pci_memreg_sparc_le.c (moved) * bsps/sparc/shared/pci/pcif.c (moved) * bsps/sparc/shared/pwm/grpwm.c (moved) * bsps/sparc/shared/scrub/memscrub.c (moved) * bsps/sparc/shared/slink/grslink.c (moved) * bsps/sparc/shared/spi/spictrl.c (moved) * bsps/sparc/shared/spw/grspw.c (moved) * bsps/sparc/shared/spw/grspw_pkt.c (moved) * bsps/sparc/shared/spw/grspw_router.c (moved) * bsps/sparc/shared/stat/l4stat.c (moved) * bsps/sparc/shared/time/grctm.c (moved) * bsps/sparc/shared/time/spwcuc.c (moved) * bsps/sparc/shared/tmtc/grtc.c (moved) * bsps/sparc/shared/tmtc/grtm.c (moved) * bsps/sparc/shared/uart/apbuart_cons.c (moved) * bsps/sparc/shared/uart/apbuart_termios.c (moved) * bsps/sparc/shared/uart/cons.c (moved) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move shared files to bsps This patch is a part of the ... Fri, 20 Apr 2018 11:22:29 GMT Sebastian Huber [c49896f1] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu_asm.S (moved) sparc: Move irq_asm.S This file is BSP-independent. This patch is ... Fri, 20 Apr 2018 11:19:28 GMT Sebastian Huber [28b4c7ac] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/shared/cpu.c (deleted) * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Move _CPU_Trap_slot_template The definition of ... Fri, 20 Apr 2018 10:08:42 GMT Sebastian Huber [e0dd8a5a] * bsps/arm/csb336/btimer/btimer.c (moved) * bsps/arm/csb337/btimer/btimer.c (moved) * bsps/arm/edb7312/btimer/btimer.c (moved) * bsps/arm/gumstix/btimer/btimer.c (moved) * bsps/arm/lpc176x/btimer/btimer.c (moved) * bsps/arm/rtl22xx/btimer/btimer.c (moved) * bsps/arm/rtl22xx/btimer/lpc_timer.h (moved) * bsps/arm/smdk2410/btimer/btimer.c (moved) * bsps/epiphany/epiphany_sim/btimer/btimer.c (moved) * bsps/i386/pc386/btimer/btimer.c (moved) * bsps/i386/pc386/btimer/timerisr.S (moved) * bsps/lm32/shared/btimer/btimer.c (moved) * bsps/m32c/m32cbsp/btimer/btimer.c (moved) * bsps/m68k/av5282/btimer/btimer.c (moved) * bsps/m68k/gen68340/btimer/btimer.c (moved) * bsps/m68k/gen68360/btimer/btimer.c (moved) * bsps/m68k/genmcf548x/btimer/btimer.c (moved) * bsps/m68k/mcf52235/btimer/btimer.c (moved) * bsps/m68k/mcf5225x/btimer/btimer.c (moved) * bsps/m68k/mcf5235/btimer/btimer.c (moved) * bsps/m68k/mcf5329/btimer/btimer.c (moved) * bsps/m68k/mrm332/btimer/btimer.c (moved) * bsps/m68k/mvme147/btimer/btimer.c (moved) * bsps/m68k/mvme147/btimer/timerisr.S (moved) * bsps/m68k/mvme162/btimer/btimer.c (moved) * bsps/m68k/mvme162/btimer/timerisr.S (moved) * bsps/m68k/mvme167/btimer/btimer.c (moved) * bsps/m68k/mvme167/btimer/timerisr.S (moved) * bsps/m68k/uC5282/btimer/btimer.c (moved) * bsps/mips/csb350/btimer/btimer.c (moved) * bsps/mips/jmr3904/btimer/btimer.c (moved) * bsps/nios2/nios2_iss/btimer/btimer.c (moved) * bsps/no_cpu/no_bsp/btimer/btimer.c (moved) * bsps/no_cpu/no_bsp/btimer/timerisr.c (moved) * bsps/or1k/generic_or1k/btimer/btimer.c (moved) * bsps/powerpc/qoriq/btimer/btimer.c (moved) * bsps/powerpc/tqm8xx/btimer/btimer.c (moved) * bsps/riscv/riscv_generic/btimer/btimer.c (moved) * bsps/sh/gensh1/btimer/btimer.c (moved) * bsps/sh/gensh2/btimer/btimer.c (moved) * bsps/sh/gensh4/btimer/btimer.c (moved) * bsps/sparc/erc32/btimer/btimer.c (moved) * bsps/sparc/leon2/btimer/btimer.c (moved) * bsps/sparc/leon3/btimer/btimer.c (moved) * bsps/sparc/leon3/btimer/watchdog.c (moved) * bsps/sparc/shared/btimer/gptimer.c (moved) * bsps/sparc/shared/btimer/tlib.c (moved) * bsps/sparc/shared/btimer/tlib_ckinit.c (moved) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps: Move benchmark timer to bsps This patch is a part of the BSP ... Fri, 20 Apr 2018 08:35:35 GMT Sebastian Huber [9964895] * bsps/arm/altera-cyclone-v/start/bsp_specs (moved) * bsps/arm/altera-cyclone-v/start/bspclean.c (moved) * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (moved) * bsps/arm/altera-cyclone-v/start/bspreset.c (moved) * bsps/arm/altera-cyclone-v/start/bspsmp.c (moved) * bsps/arm/altera-cyclone-v/start/bspstart.c (moved) * bsps/arm/altera-cyclone-v/start/bspstarthooks.c (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (moved) * bsps/arm/altera-cyclone-v/start/mmu-config.c (moved) * bsps/arm/atsam/start/bsp_specs (moved) * bsps/arm/atsam/start/bspstart.c (moved) * bsps/arm/atsam/start/bspstarthooks.c (moved) * bsps/arm/atsam/start/getentropy-trng.c (moved) * bsps/arm/atsam/start/linkcmds (moved) * bsps/arm/atsam/start/linkcmds.intsram (moved) * bsps/arm/atsam/start/linkcmds.memory.in (moved) * bsps/arm/atsam/start/linkcmds.qspiflash (moved) * bsps/arm/atsam/start/linkcmds.sdram (moved) * bsps/arm/atsam/start/pin-config.c (moved) * bsps/arm/atsam/start/pmc-config.c (moved) * bsps/arm/atsam/start/power-clock.c (moved) * bsps/arm/atsam/start/power-rtc.c (moved) * bsps/arm/atsam/start/power.c (moved) * bsps/arm/atsam/start/restart.c (moved) * bsps/arm/atsam/start/sdram-config.c (moved) * bsps/arm/beagle/start/bsp_specs (moved) * bsps/arm/beagle/start/bspreset.c (moved) * bsps/arm/beagle/start/bspstart.c (moved) * bsps/arm/beagle/start/bspstarthooks.c (moved) * bsps/arm/beagle/start/bspstartmmu.c (moved) * bsps/arm/beagle/start/linkcmds.beagle (moved) * bsps/arm/csb336/start/bsp_specs (moved) * bsps/arm/csb336/start/bspstart.c (moved) * bsps/arm/csb336/start/linkcmds (moved) * bsps/arm/csb336/start/memmap.c (moved) * bsps/arm/csb337/start/bsp_specs (moved) * bsps/arm/csb337/start/bspreset.c (moved) * bsps/arm/csb337/start/bspstart.c (moved) * bsps/arm/csb337/start/linkcmds.csb337 (moved) * bsps/arm/csb337/start/linkcmds.csb637 (moved) * bsps/arm/csb337/start/memmap.c (moved) * bsps/arm/csb337/start/pmc.c (moved) * bsps/arm/csb337/start/umonsupp.c (moved) * bsps/arm/edb7312/start/bsp_specs (moved) * bsps/arm/edb7312/start/bspreset.c (moved) * bsps/arm/edb7312/start/bspstart.c (moved) * bsps/arm/edb7312/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/bsp_specs (moved) * bsps/arm/gdbarmsim/start/bspreset.c (moved) * bsps/arm/gdbarmsim/start/bspstart.c (moved) * bsps/arm/gdbarmsim/start/bspstarthooks.c (moved) * bsps/arm/gdbarmsim/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/syscalls.c (moved) * bsps/arm/gumstix/start/bsp_specs (moved) * bsps/arm/gumstix/start/bspreset.c (moved) * bsps/arm/gumstix/start/bspstart.c (moved) * bsps/arm/gumstix/start/linkcmds (moved) * bsps/arm/gumstix/start/memmap.c (moved) * bsps/arm/imx/start/bsp_specs (moved) * bsps/arm/imx/start/bspreset.c (moved) * bsps/arm/imx/start/bspsmp.c (moved) * bsps/arm/imx/start/bspstart.c (moved) * bsps/arm/imx/start/bspstarthooks.c (moved) * bsps/arm/imx/start/ccm.c (moved) * bsps/arm/imx/start/imx_iomux.c (moved) * bsps/arm/imx/start/linkcmds.imx7 (moved) * bsps/arm/lm3s69xx/start/bsp_specs (moved) * bsps/arm/lm3s69xx/start/bspstart.c (moved) * bsps/arm/lm3s69xx/start/bspstarthook.c (moved) * bsps/arm/lm3s69xx/start/io.c (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s3749 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965_qemu (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm4f120 (moved) * bsps/arm/lm3s69xx/start/syscon.c (moved) * bsps/arm/lpc176x/start/bsp_specs (moved) * bsps/arm/lpc176x/start/bspstart.c (moved) * bsps/arm/lpc176x/start/bspstarthooks.c (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram_eth (moved) * bsps/arm/lpc24xx/start/bsp_specs (moved) * bsps/arm/lpc24xx/start/bspreset-armv4.c (moved) * bsps/arm/lpc24xx/start/bspstart.c (moved) * bsps/arm/lpc24xx/start/bspstarthooks.c (moved) * bsps/arm/lpc24xx/start/fb-config.c (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc2362 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc23xx_tli800 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ea (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_ext (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (moved) * bsps/arm/lpc24xx/start/start-config-emc-static.c (moved) * bsps/arm/lpc24xx/start/start-config-mpu.c (moved) * bsps/arm/lpc24xx/start/start-config-pinsel.c (moved) * bsps/arm/lpc32xx/start/bsp_specs (moved) * bsps/arm/lpc32xx/start/bspreset.c (moved) * bsps/arm/lpc32xx/start/bspstart.c (moved) * bsps/arm/lpc32xx/start/bspstarthooks.c (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_1 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_2 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore (moved) * bsps/arm/raspberrypi/start/bsp_specs (moved) * bsps/arm/raspberrypi/start/bspgetworkarea.c (moved) * bsps/arm/raspberrypi/start/bspreset.c (moved) * bsps/arm/raspberrypi/start/bspsmp.c (moved) * bsps/arm/raspberrypi/start/bspsmp_init.c (moved) * bsps/arm/raspberrypi/start/bspstart.c (moved) * bsps/arm/raspberrypi/start/bspstarthooks.c (moved) * bsps/arm/raspberrypi/start/cmdline.c (moved) * bsps/arm/raspberrypi/start/linkcmds.in (moved) * bsps/arm/raspberrypi/start/mm_config_table.c (moved) * bsps/arm/realview-pbx-a9/start/bsp_specs (moved) * bsps/arm/realview-pbx-a9/start/bspreset.c (moved) * bsps/arm/realview-pbx-a9/start/bspsmp.c (moved) * bsps/arm/realview-pbx-a9/start/bspstart.c (moved) * bsps/arm/realview-pbx-a9/start/bspstarthooks.c (moved) * bsps/arm/realview-pbx-a9/start/fb-config.c (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (moved) * bsps/arm/rtl22xx/start/bsp_specs (moved) * bsps/arm/rtl22xx/start/bspreset.c (moved) * bsps/arm/rtl22xx/start/bspstart.c (moved) * bsps/arm/rtl22xx/start/linkcmds (moved) * bsps/arm/shared/start/bsp-start-in-hyp-support.S (moved) * bsps/arm/shared/start/bsp-start-init-registers.S (moved) * bsps/arm/shared/start/bsp-start-memcpy.S (moved) * bsps/arm/shared/start/linkcmds.armv4 (moved) * bsps/arm/shared/start/linkcmds.armv7m (moved) * bsps/arm/shared/start/linkcmds.base (moved) * bsps/arm/smdk2410/start/bsp_specs (moved) * bsps/arm/smdk2410/start/bspidle.c (moved) * bsps/arm/smdk2410/start/bspreset.c (moved) * bsps/arm/smdk2410/start/bspstart.c (moved) * bsps/arm/smdk2410/start/linkcmds (moved) * bsps/arm/smdk2410/start/memmap.c (moved) * bsps/arm/stm32f4/start/bsp_specs (moved) * bsps/arm/stm32f4/start/bspreset.c (moved) * bsps/arm/stm32f4/start/bspstart.c (moved) * bsps/arm/stm32f4/start/bspstarthook.c (moved) * bsps/arm/stm32f4/start/io.c (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f105rc (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f4 (moved) * bsps/arm/stm32f4/start/rcc.c (moved) * bsps/arm/stm32f4/start/start-config-io.c (moved) * bsps/arm/tms570/start/bsp_specs (moved) * bsps/arm/tms570/start/bspreset.c (moved) * bsps/arm/tms570/start/bspstart.c (moved) * bsps/arm/tms570/start/bspstarthooks.c (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_intram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_sdram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_with_loader (moved) * bsps/arm/xilinx-zynq/start/bsp_specs (moved) * bsps/arm/xilinx-zynq/start/bspreset.c (moved) * bsps/arm/xilinx-zynq/start/bspsmp.c (moved) * bsps/arm/xilinx-zynq/start/bspstart.c (moved) * bsps/arm/xilinx-zynq/start/bspstarthooks.c (moved) * bsps/arm/xilinx-zynq/start/bspstartmmu.c (moved) * bsps/arm/xilinx-zynq/start/linkcmds.in (moved) * bsps/bfin/TLL6527M/start/bsp_specs (moved) * bsps/bfin/TLL6527M/start/bspstart.c (moved) * bsps/bfin/TLL6527M/start/linkcmds (moved) * bsps/bfin/bf537Stamp/start/bsp_specs (moved) * bsps/bfin/bf537Stamp/start/bspstart.c (moved) * bsps/bfin/bf537Stamp/start/linkcmds (moved) * bsps/bfin/eZKit533/start/bsp_specs (moved) * bsps/bfin/eZKit533/start/bspstart.c (moved) * bsps/bfin/eZKit533/start/linkcmds (moved) * bsps/epiphany/epiphany_sim/start/bsp_specs (moved) * bsps/epiphany/epiphany_sim/start/linkcmds (moved) * bsps/i386/pc386/start/bsp_fatal_halt.c (moved) * bsps/i386/pc386/start/bsp_specs (moved) * bsps/i386/pc386/start/bspcmdline.c (moved) * bsps/i386/pc386/start/bspgetworkarea.c (moved) * bsps/i386/pc386/start/bspidle.S (moved) * bsps/i386/pc386/start/bspreset.c (moved) * bsps/i386/pc386/start/bspstart.c (moved) * bsps/i386/pc386/start/ldsegs.S (moved) * bsps/i386/pc386/start/linkcmds (moved) * bsps/lm32/lm32_evr/start/bsp_specs (moved) * bsps/lm32/lm32_evr/start/linkcmds (moved) * bsps/lm32/milkymist/start/bsp_specs (moved) * bsps/lm32/milkymist/start/bspclean.c (moved) * bsps/lm32/milkymist/start/linkcmds (moved) * bsps/lm32/shared/start/bspreset.c (moved) * bsps/lm32/shared/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/bsp_specs (moved) * bsps/m32c/m32cbsp/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/crtn.S (moved) * bsps/m32c/m32cbsp/start/linkcmds (moved) * bsps/m68k/av5282/start/bsp_specs (moved) * bsps/m68k/av5282/start/bspstart.c (moved) * bsps/m68k/av5282/start/init5282.c (moved) * bsps/m68k/av5282/start/linkcmds (moved) * bsps/m68k/av5282/start/linkcmdsflash (moved) * bsps/m68k/av5282/start/linkcmdsram (moved) * bsps/m68k/csb360/start/bsp_specs (moved) * bsps/m68k/csb360/start/init5272.c (moved) * bsps/m68k/csb360/start/linkcmds (moved) * bsps/m68k/gen68340/start/bsp_specs (moved) * bsps/m68k/gen68340/start/dumpanic.c (moved) * bsps/m68k/gen68340/start/init68340.c (moved) * bsps/m68k/gen68340/start/linkcmds (moved) * bsps/m68k/gen68360/start/alloc360.c (moved) * bsps/m68k/gen68360/start/bsp_specs (moved) * bsps/m68k/gen68360/start/init68360.c (moved) * bsps/m68k/gen68360/start/linkcmds (moved) * bsps/m68k/gen68360/start/linkcmds.bootp (moved) * bsps/m68k/gen68360/start/linkcmds.prom (moved) * bsps/m68k/genmcf548x/start/bsp_specs (moved) * bsps/m68k/genmcf548x/start/bspstart.c (moved) * bsps/m68k/genmcf548x/start/init548x.c (moved) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (moved) * bsps/m68k/mcf5206elite/start/bsp_specs (moved) * bsps/m68k/mcf5206elite/start/gdbinit (moved) * bsps/m68k/mcf5206elite/start/init5206e.c (moved) * bsps/m68k/mcf5206elite/start/linkcmds (moved) * bsps/m68k/mcf5206elite/start/linkcmds.flash (moved) * bsps/m68k/mcf52235/start/bsp_specs (moved) * bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf52235/start/cfinit.c (moved) * bsps/m68k/mcf52235/start/init52235.c (moved) * bsps/m68k/mcf52235/start/linkcmds (moved) * bsps/m68k/mcf5225x/start/bsp_specs (moved) * bsps/m68k/mcf5225x/start/bspclean.c (moved) * bsps/m68k/mcf5225x/start/bspstart.c (moved) * bsps/m68k/mcf5225x/start/init5225x.c (moved) * bsps/m68k/mcf5225x/start/linkcmds (moved) * bsps/m68k/mcf5235/start/bsp_specs (moved) * bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf5235/start/bspstart.c (moved) * bsps/m68k/mcf5235/start/copyvectors.c (moved) * bsps/m68k/mcf5235/start/init5235.c (moved) * bsps/m68k/mcf5235/start/linkcmds (moved) * bsps/m68k/mcf5235/start/linkcmdsflash (moved) * bsps/m68k/mcf5235/start/linkcmdsram (moved) * bsps/m68k/mcf5329/start/bsp_specs (moved) * bsps/m68k/mcf5329/start/bspstart.c (moved) * bsps/m68k/mcf5329/start/cfinit.c (moved) * bsps/m68k/mcf5329/start/init5329.c (moved) * bsps/m68k/mcf5329/start/linkcmds (moved) * bsps/m68k/mcf5329/start/linkcmdsflash (moved) * bsps/m68k/mrm332/start/bsp_specs (moved) * bsps/m68k/mrm332/start/linkcmds (moved) * bsps/m68k/mrm332/start/start_c.c (moved) * bsps/m68k/mvme147/start/bsp_specs (moved) * bsps/m68k/mvme147/start/bspclean.c (moved) * bsps/m68k/mvme147/start/bspstart.c (moved) * bsps/m68k/mvme147/start/linkcmds (moved) * bsps/m68k/mvme147s/start/bsp_specs (moved) * bsps/m68k/mvme147s/start/bspstart.c (moved) * bsps/m68k/mvme147s/start/linkcmds (moved) * bsps/m68k/mvme162/start/bsp_specs (moved) * bsps/m68k/mvme162/start/bspclean.c (moved) * bsps/m68k/mvme162/start/bspstart.c (moved) * bsps/m68k/mvme162/start/linkcmds (moved) * bsps/m68k/mvme162/start/page_table.c (moved) * bsps/m68k/mvme167/start/bsp_specs (moved) * bsps/m68k/mvme167/start/bspclean.c (moved) * bsps/m68k/mvme167/start/bspstart.c (moved) * bsps/m68k/mvme167/start/linkcmds (moved) * bsps/m68k/mvme167/start/page_table.c (moved) * bsps/m68k/shared/start/linkcmds.base (moved) * bsps/m68k/uC5282/start/bsp_specs (moved) * bsps/m68k/uC5282/start/bspclean.c (moved) * bsps/m68k/uC5282/start/bspreset.c (moved) * bsps/m68k/uC5282/start/bspstart.c (moved) * bsps/m68k/uC5282/start/init5282.c (moved) * bsps/m68k/uC5282/start/linkcmds (moved) * bsps/mips/csb350/start/bsp_specs (moved) * bsps/mips/csb350/start/bspreset.c (moved) * bsps/mips/csb350/start/bspstart.c (moved) * bsps/mips/csb350/start/linkcmds (moved) * bsps/mips/hurricane/start/bsp_specs (moved) * bsps/mips/hurricane/start/bspstart.c (moved) * bsps/mips/hurricane/start/ghlinkcmds (moved) * bsps/mips/hurricane/start/inittlb.c (moved) * bsps/mips/hurricane/start/linkcmds (moved) * bsps/mips/hurricane/start/usc.S (moved) * bsps/mips/jmr3904/start/bsp_specs (moved) * bsps/mips/jmr3904/start/bspstart.c (moved) * bsps/mips/jmr3904/start/linkcmds (moved) * bsps/mips/malta/start/bsp_specs (moved) * bsps/mips/malta/start/bspreset.c (moved) * bsps/mips/malta/start/bspstart.c (moved) * bsps/mips/malta/start/inittlb.c (moved) * bsps/mips/malta/start/linkcmds (moved) * bsps/mips/malta/start/simple_access.c (moved) * bsps/mips/rbtx4925/start/bsp_specs (moved) * bsps/mips/rbtx4925/start/bspstart.c (moved) * bsps/mips/rbtx4925/start/idttlb.S (moved) * bsps/mips/rbtx4925/start/inittlb.c (moved) * bsps/mips/rbtx4925/start/linkcmds (moved) * bsps/mips/rbtx4938/start/bsp_specs (moved) * bsps/mips/rbtx4938/start/bspstart.c (moved) * bsps/mips/rbtx4938/start/inittlb.c (moved) * bsps/mips/rbtx4938/start/linkcmds (moved) * bsps/mips/shared/start/idtmem.S (moved) * bsps/mips/shared/start/idttlb.S (moved) * bsps/moxie/moxiesim/start/bsp_specs (moved) * bsps/moxie/moxiesim/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/bsp_specs (moved) * bsps/nios2/nios2_iss/start/bspstart.c (moved) * bsps/nios2/nios2_iss/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/main.c (moved) * bsps/nios2/nios2_iss/start/setvec.c (moved) * bsps/no_cpu/no_bsp/start/bsp_specs (moved) * bsps/no_cpu/no_bsp/start/bspstart.c (moved) * bsps/no_cpu/no_bsp/start/linkcmds (moved) * bsps/no_cpu/no_bsp/start/setvec.c (moved) * bsps/or1k/generic_or1k/start/bsp_specs (moved) * bsps/or1k/generic_or1k/start/bspstart.c (moved) * bsps/or1k/generic_or1k/start/linkcmds (moved) * bsps/or1k/shared/start/linkcmds.base (moved) * bsps/powerpc/beatnik/start/bsp_specs (moved) * bsps/powerpc/beatnik/start/bspclean.c (moved) * bsps/powerpc/beatnik/start/bspreset.c (moved) * bsps/powerpc/beatnik/start/bspstart.c (moved) * bsps/powerpc/beatnik/start/i2c_init.c (moved) * bsps/powerpc/beatnik/start/linkcmds (moved) * bsps/powerpc/gen5200/start/bestcomm.c (moved) * bsps/powerpc/gen5200/start/bsp_specs (moved) * bsps/powerpc/gen5200/start/bspreset.c (moved) * bsps/powerpc/gen5200/start/bspstart.c (moved) * bsps/powerpc/gen5200/start/cpuinit.c (moved) * bsps/powerpc/gen5200/start/linkcmds.brs5l (moved) * bsps/powerpc/gen5200/start/linkcmds.brs6l (moved) * bsps/powerpc/gen5200/start/linkcmds.dp2 (moved) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (moved) * bsps/powerpc/gen5200/start/linkcmds.icecube (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_cr825 (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_ze30 (moved) * bsps/powerpc/gen5200/start/uboot_support.c (moved) * bsps/powerpc/gen83xx/start/bsp_specs (moved) * bsps/powerpc/gen83xx/start/bspreset.c (moved) * bsps/powerpc/gen83xx/start/bsprestart.c (moved) * bsps/powerpc/gen83xx/start/bspstart.c (moved) * bsps/powerpc/gen83xx/start/cpuinit.c (moved) * bsps/powerpc/gen83xx/start/linkcmds (moved) * bsps/powerpc/gen83xx/start/linkcmds.br_uid (moved) * bsps/powerpc/gen83xx/start/linkcmds.hsc_cm01 (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8309som (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8313erdb (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8349eamds (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc83xx (moved) * bsps/powerpc/gen83xx/start/uboot_support.c (moved) * bsps/powerpc/haleakala/start/bsp_specs (moved) * bsps/powerpc/haleakala/start/bspstart.c (moved) * bsps/powerpc/haleakala/start/linkcmds (moved) * bsps/powerpc/motorola_powerpc/start/bsp_specs (moved) * bsps/powerpc/motorola_powerpc/start/bspreset.c (moved) * bsps/powerpc/motorola_powerpc/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/bsp_specs (moved) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (moved) * bsps/powerpc/mpc55xxevb/start/bspreset.c (moved) * bsps/powerpc/mpc55xxevb/start/bspstart.c (moved) * bsps/powerpc/mpc55xxevb/start/exc-vector-base.S (moved) * bsps/powerpc/mpc55xxevb/start/get-system-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/idle-thread.c (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.gwlcfm (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc55xx (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_dpu (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5668g (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_app (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_boot (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6_base (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.phycore_mpc5554 (moved) * bsps/powerpc/mpc55xxevb/start/restart.c (moved) * bsps/powerpc/mpc55xxevb/start/sd-card-init.c (moved) * bsps/powerpc/mpc55xxevb/start/start-cache.S (moved) * bsps/powerpc/mpc55xxevb/start/start-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs-cal.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-siu-pcr.c (moved) * bsps/powerpc/mpc55xxevb/start/start-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-flash.S (moved) * bsps/powerpc/mpc55xxevb/start/start-prologue.c (moved) * bsps/powerpc/mpc55xxevb/start/start-watchdog.c (moved) * bsps/powerpc/mpc8260ads/start/bsp_specs (moved) * bsps/powerpc/mpc8260ads/start/bspstart.c (moved) * bsps/powerpc/mpc8260ads/start/cpuinit.c (moved) * bsps/powerpc/mpc8260ads/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/bsp_specs (moved) * bsps/powerpc/mvme3100/start/bspstart.c (moved) * bsps/powerpc/mvme3100/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/misc.c (moved) * bsps/powerpc/mvme5500/start/bootpstuff.c (moved) * bsps/powerpc/mvme5500/start/bsp_specs (moved) * bsps/powerpc/mvme5500/start/bspclean.c (moved) * bsps/powerpc/mvme5500/start/bspreset.c (moved) * bsps/powerpc/mvme5500/start/bspstart.c (moved) * bsps/powerpc/mvme5500/start/linkcmds (moved) * bsps/powerpc/mvme5500/start/pgtbl_activate.c (moved) * bsps/powerpc/psim/start/bsp_specs (moved) * bsps/powerpc/psim/start/bspstart.c (moved) * bsps/powerpc/psim/start/device-tree (moved) * bsps/powerpc/psim/start/linkcmds (moved) * bsps/powerpc/qemuppc/start/bsp_specs (moved) * bsps/powerpc/qemuppc/start/bspstart.c (moved) * bsps/powerpc/qemuppc/start/cmain.c (moved) * bsps/powerpc/qemuppc/start/linkcmds (moved) * bsps/powerpc/qoriq/start/bsp_specs (moved) * bsps/powerpc/qoriq/start/bspreset.c (moved) * bsps/powerpc/qoriq/start/bsprestart.c (moved) * bsps/powerpc/qoriq/start/bspsmp.c (moved) * bsps/powerpc/qoriq/start/bspstart.c (moved) * bsps/powerpc/qoriq/start/epapr_hcalls.S (moved) * bsps/powerpc/qoriq/start/l1cache.S (moved) * bsps/powerpc/qoriq/start/l2cache.S (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_0 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_1 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_64 (moved) * bsps/powerpc/qoriq/start/mmu-config.c (moved) * bsps/powerpc/qoriq/start/mmu-tlb1.S (moved) * bsps/powerpc/qoriq/start/mmu.c (moved) * bsps/powerpc/qoriq/start/portal.c (moved) * bsps/powerpc/qoriq/start/restart.S (moved) * bsps/powerpc/shared/start/bspgetworkarea.c (moved) * bsps/powerpc/shared/start/bspidle.c (moved) * bsps/powerpc/shared/start/linkcmds.base (moved) * bsps/powerpc/shared/start/linkcmds.share (moved) * bsps/powerpc/shared/start/pgtbl_activate.c (moved) * bsps/powerpc/shared/start/pgtbl_setup.c (moved) * bsps/powerpc/shared/start/ppc_idle.c (moved) * bsps/powerpc/shared/start/probeMemEnd.c (moved) * bsps/powerpc/shared/start/sbrk.c (moved) * bsps/powerpc/shared/start/zerobss.c (moved) * bsps/powerpc/ss555/start/bsp_specs (moved) * bsps/powerpc/ss555/start/bspstart.c (moved) * bsps/powerpc/ss555/start/iss555.c (moved) * bsps/powerpc/ss555/start/linkcmds (moved) * bsps/powerpc/ss555/start/tm27supp.c (moved) * bsps/powerpc/t32mppc/start/bsp_specs (moved) * bsps/powerpc/t32mppc/start/bspreset.c (moved) * bsps/powerpc/t32mppc/start/bspstart.c (moved) * bsps/powerpc/t32mppc/start/linkcmds.t32mppc (moved) * bsps/powerpc/tqm8xx/start/bsp_specs (moved) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (moved) * bsps/powerpc/tqm8xx/start/bspstart.c (moved) * bsps/powerpc/tqm8xx/start/cpuinit.c (moved) * bsps/powerpc/tqm8xx/start/linkcmds (moved) * bsps/powerpc/tqm8xx/start/mmutlbtab.c (moved) * bsps/powerpc/virtex/start/bsp_specs (moved) * bsps/powerpc/virtex/start/bspstart.c (moved) * bsps/powerpc/virtex/start/linkcmds.in (moved) * bsps/powerpc/virtex4/start/bsp_specs (moved) * bsps/powerpc/virtex4/start/bspclean.c (moved) * bsps/powerpc/virtex4/start/bspstart.c (moved) * bsps/powerpc/virtex4/start/dummy_console.c (moved) * bsps/powerpc/virtex4/start/linkcmds (moved) * bsps/powerpc/virtex5/start/bsp_specs (moved) * bsps/powerpc/virtex5/start/bspclean.c (moved) * bsps/powerpc/virtex5/start/bspstart.c (moved) * bsps/powerpc/virtex5/start/dummy_console.c (moved) * bsps/powerpc/virtex5/start/linkcmds (moved) * bsps/riscv/riscv_generic/start/bsp_fatal_halt.c (moved) * bsps/riscv/riscv_generic/start/bsp_specs (moved) * bsps/riscv/riscv_generic/start/linkcmds (moved) * bsps/sh/gensh1/start/bsp_specs (moved) * bsps/sh/gensh1/start/cpu_asm.c (moved) * bsps/sh/gensh1/start/ispsh7032.c (moved) * bsps/sh/gensh1/start/linkcmds (moved) * bsps/sh/gensh2/start/bsp_specs (moved) * bsps/sh/gensh2/start/cpu_asm.c (moved) * bsps/sh/gensh2/start/hw_init.c (moved) * bsps/sh/gensh2/start/ispsh7045.c (moved) * bsps/sh/gensh2/start/linkcmds (moved) * bsps/sh/gensh2/start/linkcmds.ram (moved) * bsps/sh/gensh2/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/bsp_specs (moved) * bsps/sh/gensh4/start/cpu_asm.c (moved) * bsps/sh/gensh4/start/ispsh7750.c (moved) * bsps/sh/gensh4/start/linkcmds (moved) * bsps/sh/gensh4/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/linkcmds.rom2ram (moved) * bsps/sh/shared/start/bspstart.c (moved) * bsps/sh/shsim/start/bsp_specs (moved) * bsps/sh/shsim/start/cpu_asm.c (moved) * bsps/sh/shsim/start/ispshgdb.c (moved) * bsps/sh/shsim/start/linkcmds (moved) * bsps/sh/shsim/start/sysexit.c (moved) * bsps/sparc/erc32/start/boardinit.S (moved) * bsps/sparc/erc32/start/bsp_specs (moved) * bsps/sparc/erc32/start/bspdelay.c (moved) * bsps/sparc/erc32/start/bspidle.c (moved) * bsps/sparc/erc32/start/erc32mec.c (moved) * bsps/sparc/erc32/start/linkcmds (moved) * bsps/sparc/erc32/start/setvec.c (moved) * bsps/sparc/erc32/start/spurious.c (moved) * bsps/sparc/leon2/start/bsp_specs (moved) * bsps/sparc/leon2/start/bspdelay.c (moved) * bsps/sparc/leon2/start/bspidle.c (moved) * bsps/sparc/leon2/start/bspstart.c (moved) * bsps/sparc/leon2/start/linkcmds (moved) * bsps/sparc/leon2/start/linkcmds.at697f (moved) * bsps/sparc/leon2/start/linkcmds.leon2 (moved) * bsps/sparc/leon2/start/setvec.c (moved) * bsps/sparc/leon2/start/spurious.c (moved) * bsps/sparc/leon3/start/bsp_fatal_halt.c (moved) * bsps/sparc/leon3/start/bsp_specs (moved) * bsps/sparc/leon3/start/bspclean.c (moved) * bsps/sparc/leon3/start/bspdelay.c (moved) * bsps/sparc/leon3/start/bspidle.S (moved) * bsps/sparc/leon3/start/bspsmp.c (moved) * bsps/sparc/leon3/start/bspstart.c (moved) * bsps/sparc/leon3/start/cpucounter.c (moved) * bsps/sparc/leon3/start/eirq.c (moved) * bsps/sparc/leon3/start/linkcmds.gr712rc (moved) * bsps/sparc/leon3/start/linkcmds.gr740 (moved) * bsps/sparc/leon3/start/linkcmds.leon3 (moved) * bsps/sparc/leon3/start/linkcmds.ut699 (moved) * bsps/sparc/leon3/start/linkcmds.ut700 (moved) * bsps/sparc/leon3/start/setvec.c (moved) * bsps/sparc/leon3/start/spurious.c (moved) * bsps/sparc/shared/start/bsp_fatal_exit.c (moved) * bsps/sparc/shared/start/bsp_fatal_halt.c (moved) * bsps/sparc/shared/start/bspgetworkarea.c (moved) * bsps/sparc/shared/start/linkcmds.base (moved) * bsps/sparc64/niagara/start/bsp_specs (moved) * bsps/sparc64/niagara/start/bspclean.c (moved) * bsps/sparc64/niagara/start/m5op.h (moved) * bsps/sparc64/niagara/start/m5op_sparc.S (moved) * bsps/sparc64/niagara/start/m5ops.h (moved) * bsps/sparc64/shared/start/linkcmds (moved) * bsps/sparc64/shared/start/setvec.c (moved) * bsps/sparc64/usiii/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bspreset.c (moved) * bsps/v850/gdbv850sim/start/linkcmds (moved) * bsps/v850/gdbv850sim/start/trap.S (moved) * c/src/aclocal/bsp-linkcmds.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/rtems-bsp-linkcmds.m4 (modified) bsps: Move startup files to bsps Adjust build support files to new ... Fri, 20 Apr 2018 08:19:28 GMT Sebastian Huber [fbcd7c8f] * bsps/arm/csb336/start/start.S (moved) * bsps/arm/csb337/start/start.S (moved) * bsps/arm/edb7312/start/start.S (moved) * bsps/arm/gumstix/start/start.S (moved) * bsps/arm/rtl22xx/start/start.S (moved) * bsps/arm/shared/start/start.S (moved) * bsps/arm/smdk2410/start/start.S (moved) * bsps/bfin/bf537Stamp/start/start.S (moved) * bsps/bfin/shared/start/start.S (moved) * bsps/epiphany/epiphany_sim/start/start.S (moved) * bsps/i386/pc386/start/start.S (moved) * bsps/i386/pc386/start/start16.S (moved) * bsps/lm32/shared/start/start.S (moved) * bsps/m32c/m32cbsp/start/start.S (moved) * bsps/m68k/av5282/start/start.S (moved) * bsps/m68k/csb360/start/start.S (moved) * bsps/m68k/gen68340/start/start.S (moved) * bsps/m68k/gen68360/start/start.S (moved) * bsps/m68k/genmcf548x/start/start.S (moved) * bsps/m68k/mcf5206elite/start/start.S (moved) * bsps/m68k/mcf52235/start/start.S (moved) * bsps/m68k/mcf5225x/start/start.S (moved) * bsps/m68k/mcf5235/start/start.S (moved) * bsps/m68k/mcf5329/start/start.S (moved) * bsps/m68k/mrm332/start/start.S (moved) * bsps/m68k/shared/start/start.S (moved) * bsps/m68k/uC5282/start/start.S (moved) * bsps/mips/csb350/start/start.S (moved) * bsps/mips/hurricane/start/start.S (moved) * bsps/mips/jmr3904/start/start.S (moved) * bsps/mips/malta/start/start.S (moved) * bsps/mips/rbtx4925/start/start.S (moved) * bsps/mips/rbtx4938/start/start.S (moved) * bsps/moxie/moxiesim/start/start.S (moved) * bsps/nios2/nios2_iss/start/crtnn.S (moved) * bsps/nios2/nios2_iss/start/start.S (moved) * bsps/or1k/generic_or1k/start/start.S (moved) * bsps/powerpc/gen5200/start/start.S (moved) * bsps/powerpc/gen83xx/start/start.S (moved) * bsps/powerpc/mpc55xxevb/start/start.S (moved) * bsps/powerpc/mpc8260ads/start/start.S (moved) * bsps/powerpc/mvme3100/start/start.S (moved) * bsps/powerpc/mvme5500/start/start.S (moved) * bsps/powerpc/psim/start/start.S (moved) * bsps/powerpc/qemuppc/start/start.S (moved) * bsps/powerpc/qoriq/start/start.S (moved) * bsps/powerpc/shared/start/preload.S (moved) * bsps/powerpc/shared/start/rtems_crti.S (moved) * bsps/powerpc/shared/start/rtems_crtn.S (moved) * bsps/powerpc/shared/start/start.S (moved) * bsps/powerpc/shared/start/vectors_entry.S (moved) * bsps/powerpc/ss555/start/start.S (moved) * bsps/powerpc/t32mppc/start/start.S (moved) * bsps/powerpc/tqm8xx/start/start.S (moved) * bsps/powerpc/virtex/start/start.S (moved) * bsps/powerpc/virtex4/start/start.S (moved) * bsps/powerpc/virtex5/start/start.S (moved) * bsps/riscv/riscv_generic/start/start.S (moved) * bsps/sh/gensh1/start/start.S (moved) * bsps/sh/gensh2/start/start.S (moved) * bsps/sh/gensh2/start/start.ram (moved) * bsps/sh/gensh2/start/start.rom (moved) * bsps/sh/gensh4/start/start.S (moved) * bsps/sh/shsim/start/start.S (moved) * bsps/sparc/shared/start/start.S (moved) * bsps/sparc64/niagara/start/bspinit.S (moved) * bsps/sparc64/shared/start/start.S (moved) * bsps/sparc64/shared/start/trap_table.S (moved) * bsps/sparc64/usiii/start/bspinit.S (moved) * bsps/v850/gdbv850sim/start/start.S (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move start files to bsps This patch is a part of the BSP ... Thu, 19 Apr 2018 04:28:01 GMT Sebastian Huber [d7d66d7] * bsps/arm/altera-cyclone-v/console/console-config.c (moved) * bsps/arm/atsam/console/console.c (moved) * bsps/arm/atsam/console/debug-console.c (moved) * bsps/arm/beagle/console/console-config.c (moved) * bsps/arm/csb336/console/uart.c (moved) * bsps/arm/csb337/console/dbgu.c (moved) * bsps/arm/csb337/console/fbcons.c (moved) * bsps/arm/csb337/console/sed1356.c (moved) * bsps/arm/csb337/console/uarts.c (moved) * bsps/arm/csb337/console/usart.c (moved) * bsps/arm/edb7312/console/uart.c (moved) * bsps/arm/gdbarmsim/console/console-io.c (moved) * bsps/arm/gumstix/console/ffuart.c (moved) * bsps/arm/gumstix/console/uarts.c (moved) * bsps/arm/imx/console/console-config.c (moved) * bsps/arm/lm3s69xx/console/console-config.c (moved) * bsps/arm/lm3s69xx/console/uart.c (moved) * bsps/arm/lpc176x/console/console-config.c (moved) * bsps/arm/lpc24xx/console/console-config.c (moved) * bsps/arm/lpc24xx/console/uart-probe-1.c (moved) * bsps/arm/lpc24xx/console/uart-probe-2.c (moved) * bsps/arm/lpc24xx/console/uart-probe-3.c (moved) * bsps/arm/lpc32xx/console/console-config.c (moved) * bsps/arm/lpc32xx/console/hsu.c (moved) * bsps/arm/raspberrypi/console/console-config.c (moved) * bsps/arm/raspberrypi/console/console_select.c (moved) * bsps/arm/raspberrypi/console/fb.c (moved) * bsps/arm/raspberrypi/console/fbcons.c (moved) * bsps/arm/raspberrypi/console/font_data.h (moved) * bsps/arm/raspberrypi/console/outch.c (moved) * bsps/arm/raspberrypi/console/usart.c (moved) * bsps/arm/realview-pbx-a9/console/console-config.c (moved) * bsps/arm/rtl22xx/console/lpc22xx_uart.h (moved) * bsps/arm/rtl22xx/console/uart.c (moved) * bsps/arm/smdk2410/console/uart.c (moved) * bsps/arm/stm32f4/console/console-config.c (moved) * bsps/arm/stm32f4/console/usart.c (moved) * bsps/arm/tms570/console/printk-support.c (moved) * bsps/arm/tms570/console/tms570-sci.c (moved) * bsps/arm/xilinx-zynq/console/console-config.c (moved) * bsps/arm/xilinx-zynq/console/debug-console.c (moved) * bsps/arm/xilinx-zynq/console/zynq-uart.c (moved) * bsps/bfin/TLL6527M/console/console.c (moved) * bsps/bfin/bf537Stamp/console/console.c (moved) * bsps/bfin/eZKit533/console/console-io.c (moved) * bsps/epiphany/epiphany_sim/console/console-io.c (moved) * bsps/i386/pc386/console/conscfg.c (moved) * bsps/i386/pc386/console/console_control.c (moved) * bsps/i386/pc386/console/console_select.c (moved) * bsps/i386/pc386/console/defkeymap.c (moved) * bsps/i386/pc386/console/exar17d15x.c (moved) * bsps/i386/pc386/console/fb_cirrus.c (moved) * bsps/i386/pc386/console/fb_vesa_rm.c (moved) * bsps/i386/pc386/console/fb_vga.c (moved) * bsps/i386/pc386/console/gdb_select.c (moved) * bsps/i386/pc386/console/i386kbd.h (moved) * bsps/i386/pc386/console/inch.c (moved) * bsps/i386/pc386/console/kbd_parser.c (moved) * bsps/i386/pc386/console/keyboard.c (moved) * bsps/i386/pc386/console/outch.c (moved) * bsps/i386/pc386/console/pc_keyb.c (moved) * bsps/i386/pc386/console/printk_support.c (moved) * bsps/i386/pc386/console/ps2_mouse.c (moved) * bsps/i386/pc386/console/ps2_mouse.h (moved) * bsps/i386/pc386/console/rtd316.c (moved) * bsps/i386/pc386/console/serial_mouse_config.c (moved) * bsps/i386/pc386/console/uart_bus_pci.c (moved) * bsps/i386/pc386/console/vgacons.c (moved) * bsps/i386/pc386/console/vgainit.c (moved) * bsps/i386/pc386/console/videoAsm.S (moved) * bsps/i386/pc386/console/vt.c (moved) * bsps/lm32/shared/console/console.c (moved) * bsps/lm32/shared/console/uart.c (moved) * bsps/lm32/shared/console/uart.h (moved) * bsps/m32c/m32cbsp/console/console-io.c (moved) * bsps/m32c/m32cbsp/console/syscalls.S (moved) * bsps/m68k/av5282/console/console.c (moved) * bsps/m68k/csb360/console/console-io.c (moved) * bsps/m68k/gen68340/console/console.c (moved) * bsps/m68k/gen68340/console/m340uart.c (moved) * bsps/m68k/gen68360/console/console.c (moved) * bsps/m68k/genmcf548x/console/console.c (moved) * bsps/m68k/mcf5206elite/console/console.c (moved) * bsps/m68k/mcf52235/console/console.c (moved) * bsps/m68k/mcf52235/console/debugio.c (moved) * bsps/m68k/mcf5225x/console/console.c (moved) * bsps/m68k/mcf5225x/console/debugio.c (moved) * bsps/m68k/mcf5235/console/console.c (moved) * bsps/m68k/mcf5329/console/console.c (moved) * bsps/m68k/mrm332/console/console.c (moved) * bsps/m68k/mrm332/console/sci.c (moved) * bsps/m68k/mrm332/console/sci.h (moved) * bsps/m68k/mvme147/console/console.c (moved) * bsps/m68k/mvme162/console/console.c (moved) * bsps/m68k/mvme167/console/console-recording.h (moved) * bsps/m68k/mvme167/console/console.c (moved) * bsps/m68k/uC5282/console/console.c (moved) * bsps/mips/csb350/console/console-io.c (moved) * bsps/mips/hurricane/console/console.c (moved) * bsps/mips/jmr3904/console/console-io.c (moved) * bsps/mips/malta/console/conscfg.c (moved) * bsps/mips/malta/console/printk_support.c (moved) * bsps/mips/rbtx4925/console/console-io.c (moved) * bsps/mips/rbtx4938/console/console-io.c (moved) * bsps/mips/rbtx4938/console/yamon_api.h (moved) * bsps/moxie/moxiesim/console/console-io.c (moved) * bsps/moxie/moxiesim/console/syscalls.S (moved) * bsps/nios2/nios2_iss/console/console.c (moved) * bsps/no_cpu/no_bsp/console/console.c (moved) * bsps/or1k/generic_or1k/console/console-config.c (moved) * bsps/or1k/generic_or1k/console/uart.c (moved) * bsps/powerpc/gen5200/console/console.c (moved) * bsps/powerpc/gen83xx/console/console-config.c (moved) * bsps/powerpc/mpc55xxevb/console/console-config.c (moved) * bsps/powerpc/mpc55xxevb/console/console-esci.c (moved) * bsps/powerpc/mpc55xxevb/console/console-generic.c (moved) * bsps/powerpc/mpc55xxevb/console/console-linflex.c (moved) * bsps/powerpc/mpc8260ads/console/console.c (moved) * bsps/powerpc/psim/console/console-io.c (moved) * bsps/powerpc/psim/console/consupp.S (moved) * bsps/powerpc/qemuppc/console/console-io.c (moved) * bsps/powerpc/qoriq/console/console-config.c (moved) * bsps/powerpc/qoriq/console/uart-bridge-master.c (moved) * bsps/powerpc/qoriq/console/uart-bridge-slave.c (moved) * bsps/powerpc/shared/console/console.c (moved) * bsps/powerpc/shared/console/uart.c (moved) * bsps/powerpc/ss555/console/console.c (moved) * bsps/powerpc/t32mppc/console/console.c (moved) * bsps/powerpc/tqm8xx/console/console.c (moved) * bsps/powerpc/virtex/console/consolelite.c (moved) * bsps/riscv/riscv_generic/console/console-io.c (moved) * bsps/sh/gensh1/console/sci.c (moved) * bsps/sh/gensh2/console/config.c (moved) * bsps/sh/gensh2/console/sci.c (moved) * bsps/sh/gensh2/console/sci_termios.c (moved) * bsps/sh/gensh4/console/console.c (moved) * bsps/sh/gensh4/console/sh4uart.c (moved) * bsps/sh/shsim/console/console-debugio.c (moved) * bsps/sh/shsim/console/console-io.c (moved) * bsps/sh/shsim/console/console-support.S (moved) * bsps/shared/dev/serial/console-output-char.c (moved) * bsps/shared/dev/serial/console-polled.c (moved) * bsps/shared/dev/serial/console-termios-init.c (moved) * bsps/shared/dev/serial/console-termios.c (moved) * bsps/shared/dev/serial/getserialmouseps2.c (moved) * bsps/shared/dev/serial/printk-dummy.c (moved) * bsps/sparc/erc32/console/debugputs.c (moved) * bsps/sparc/erc32/console/erc32_console.c (moved) * bsps/sparc/leon2/console/console.c (moved) * bsps/sparc/leon2/console/debugputs.c (moved) * bsps/sparc/leon3/console/console.c (moved) * bsps/sparc/leon3/console/printk_support.c (moved) * bsps/sparc64/shared/console/conscfg.c (moved) * bsps/v850/gdbv850sim/console/console-io.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move console drivers to bsps This patch is a part of the BSP ... Fri, 20 Apr 2018 07:59:43 GMT Sebastian Huber [58adad4] * bsps/powerpc/shared/btimer/btimer-ppc-dec.c (moved) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) bsps/powerpc: Move shared btimer support This patch is a part of ... Thu, 19 Apr 2018 04:35:52 GMT Sebastian Huber [7632906] * bsps/arm/atsam/clock/systick-freq.c (moved) * bsps/arm/csb336/clock/clockdrv.c (moved) * bsps/arm/csb337/clock/clock.c (moved) * bsps/arm/edb7312/clock/clockdrv.c (moved) * bsps/arm/gumstix/clock/clock.c (moved) * bsps/arm/raspberrypi/clock/clockdrv.c (moved) * bsps/arm/rtl22xx/clock/clockdrv.c (moved) * bsps/arm/shared/clock/clock-armv7m.c (moved) * bsps/arm/shared/clock/clock-nxp-lpc.c (moved) * bsps/arm/smdk2410/clock/clockdrv.c (moved) * bsps/arm/smdk2410/clock/support.c (moved) * bsps/arm/tms570/clock/clock.c (moved) * bsps/i386/pc386/clock/ckinit.c (moved) * bsps/i386/pc386/clock/rtc.c (moved) * bsps/i386/pc386/clock/todcfg.c (moved) * bsps/lm32/shared/clock/ckinit.c (moved) * bsps/lm32/shared/clock/clock.h (moved) * bsps/m68k/av5282/clock/clock.c (moved) * bsps/m68k/gen68340/clock/ckinit.c (moved) * bsps/m68k/gen68360/clock/clock.c (moved) * bsps/m68k/genmcf548x/clock/clock.c (moved) * bsps/m68k/mcf52235/clock/clock.c (moved) * bsps/m68k/mcf5225x/clock/clock.c (moved) * bsps/m68k/mcf5235/clock/clock.c (moved) * bsps/m68k/mcf5329/clock/clock.c (moved) * bsps/m68k/mrm332/clock/ckinit.c (moved) * bsps/m68k/mvme147/clock/ckinit.c (moved) * bsps/m68k/mvme162/clock/ckinit.c (moved) * bsps/m68k/mvme167/clock/ckinit.c (moved) * bsps/m68k/uC5282/clock/clock.c (moved) * bsps/mips/csb350/clock/clockdrv.c (moved) * bsps/mips/hurricane/clock/ckinit.c (moved) * bsps/mips/hurricane/clock/clock.S (moved) * bsps/mips/hurricane/clock/clock.h (moved) * bsps/mips/jmr3904/clock/clockdrv.c (moved) * bsps/mips/rbtx4925/clock/clockdrv.c (moved) * bsps/mips/rbtx4938/clock/clockdrv.c (moved) * bsps/mips/rbtx4938/clock/yamon_api.h (moved) * bsps/mips/shared/clock/clockdrv.c (moved) * bsps/mips/shared/clock/mips_timer.S (moved) * bsps/nios2/nios2_iss/clock/clock.c (moved) * bsps/no_cpu/no_bsp/clock/ckinit.c (moved) * bsps/or1k/generic_or1k/clock/clockdrv.c (moved) * bsps/powerpc/mpc55xxevb/clock/clock-config.c (moved) * bsps/powerpc/mpc8260ads/clock/p_clock.c (moved) * bsps/powerpc/qoriq/clock/clock-config.c (moved) * bsps/powerpc/shared/clock/clock-ppc-dec.c (moved) * bsps/powerpc/shared/clock/clock-ppc403.c (moved) * bsps/powerpc/shared/clock/clock.c (moved) * bsps/powerpc/shared/clock/p_clock.c (moved) * bsps/powerpc/ss555/clock/clock.c (moved) * bsps/powerpc/ss555/clock/p_clock.c (moved) * bsps/powerpc/t32mppc/clock/clock-config.c (moved) * bsps/powerpc/tqm8xx/clock/p_clock.c (moved) * bsps/riscv/riscv_generic/clock/clockdrv.c (moved) * bsps/sh/gensh1/clock/ckinit.c (moved) * bsps/sh/gensh1/clock/delay.c (moved) * bsps/sh/gensh2/clock/ckinit.c (moved) * bsps/sh/gensh4/clock/ckinit.c (moved) * bsps/shared/dev/clock/clock-simidle.c (moved) * bsps/shared/dev/clock/clockimpl.h (moved) * bsps/sparc/erc32/clock/ckinit.c (moved) * bsps/sparc/leon2/clock/ckinit.c (moved) * bsps/sparc/leon3/clock/ckinit.c (moved) * bsps/sparc64/shared/clock/ckinit.c (moved) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-generic-timer-clock-config.c (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move clock drivers to bsps This patch is a part of the BSP ... Thu, 19 Apr 2018 04:26:42 GMT Sebastian Huber [5c5b021] * bsps/shared/start/getcurrentprocessor-zero.c (moved) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) bsps: Move bspsmpgetcurrentprocessor.c to bsps This patch is a part ... Thu, 19 Apr 2018 04:26:03 GMT Sebastian Huber [2584f5b] * bsps/shared/start/bspsmp-dummy.c (moved) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) bsps: Move bspsmp.c to bsps This patch is a part of the BSP source ... Thu, 19 Apr 2018 04:24:09 GMT Sebastian Huber [bc010a8d] * bsps/shared/start/setvec.c (moved) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) bsps: Move setvec.c to bsps This patch is a part of the BSP source ... Thu, 19 Apr 2018 04:23:59 GMT Sebastian Huber [a442939] * bsps/shared/start/sbrk.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move sbrk.c to bsps This patch is a part of the BSP source ... Thu, 19 Apr 2018 04:22:32 GMT Sebastian Huber [7806d9c0] * bsps/shared/dev/cpucounter/cpucounterdiff.c (moved) * bsps/shared/dev/cpucounter/cpucounterread.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) bsps: Move shared CPU counter support to bsps This patch is a part ... Thu, 19 Apr 2018 04:21:59 GMT Sebastian Huber [79b9fe67] * bsps/shared/dev/getentropy/getentropy-cpucounter.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move getentropy-cpucounter.c to bsps This patch is a part of ... Thu, 19 Apr 2018 04:18:55 GMT Sebastian Huber [ef78454] * bsps/shared/dev/gpio/gpio-support.c (moved) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsps: Move gpio.c to bsps This patch is a part of the BSP source ... Thu, 19 Apr 2018 04:17:52 GMT Sebastian Huber [d6fb37a] * bsps/shared/dev/btimer/btimer-cpucounter.c (moved) * bsps/shared/dev/btimer/btimer-stub.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move shared btimer support to bsps This patch is a part of ... Thu, 19 Apr 2018 04:14:56 GMT Sebastian Huber [4b9015c] * c/src/lib/libbsp/shared/include/irq.h (deleted) bsps: Remove unused irq.h template file This patch is a part of the ... Thu, 19 Apr 2018 04:13:03 GMT Sebastian Huber [8d04f18] * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (deleted) bsps: Remove unused rtems-stub-glue.c This patch is a part of the ... Thu, 19 Apr 2018 04:10:36 GMT Sebastian Huber [9ec8cfc5] * bsps/shared/dev/pci/pci_find_device.c (moved) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) bsps: Move pci_find_device.c to bsps This patch is a part of the ... Thu, 19 Apr 2018 04:10:18 GMT Sebastian Huber [f923901] * bsps/shared/dev/pci/pci_bus_count.c (moved) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) bsps: Move pci_bus_count.c to bsps This patch is a part of the BSP ... Wed, 18 Apr 2018 04:35:03 GMT Sebastian Huber [0510cd50] * bsps/arm/shared/doxygen.h (moved) * bsps/bfin/shared/doxygen.h (moved) * bsps/i386/shared/doxygen.h (moved) * bsps/lm32/shared/doxygen.h (moved) * bsps/m32c/m32cbsp/doxygen.h (moved) * bsps/m68k/gen68360/doxygen.h (moved) * bsps/m68k/shared/doxygen.h (moved) * bsps/mips/shared/doxygen.h (moved) * bsps/powerpc/mvme3100/doxygen.h (moved) * bsps/powerpc/shared/doxygen.h (moved) * bsps/shared/doxygen.h (moved) * bsps/sparc/shared/doxygen.h (moved) * c/src/lib/libbsp/shared/include/doxygen.h (deleted) bsps: Move doxygen.h files to bsps This patch is a part of the BSP ... Tue, 17 Apr 2018 04:57:46 GMT Sebastian Huber [c4ccf26c] * bsps/include/bsp/bootcard.h (modified) * bsps/m68k/mrm332/start/bspstart.c (moved) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mvme3100/include/bsp.h (modified) * bsps/shared/start/bootcard.c (modified) * bsps/sparc/erc32/start/bspstart.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsppredriverhook.c (deleted) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bsppredriverhook.c (deleted) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/start/start.S (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/shared/bsppredriverhook.c (deleted) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c (deleted) * c/src/lib/libbsp/sparc/leon2/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c (deleted) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Convert all bsp_predriver_hook() Use RTEMS_SYSINIT_ITEM() ... Tue, 17 Apr 2018 07:49:49 GMT Sebastian Huber [a884df3] * bsps/powerpc/motorola_powerpc/start/bspstart.c (moved) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) bsp/motorola_powerpc: Move bspstart.c to bsps This shared powerpc ... Tue, 17 Apr 2018 04:33:51 GMT Sebastian Huber [5a06b187] * bsps/shared/start/bspgetworkarea-default.c (moved) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move bspgetworkarea.c to bsps This patch is a part of the BSP ... Tue, 17 Apr 2018 04:31:30 GMT Sebastian Huber [6d21a3f2] * c/src/lib/libbsp/shared/bspdriverlevelhook.c (deleted) * c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c (modified) * cpukit/include/drvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr.c (modified) drvmgr: Remove bsp_driver_level_hook() Use RTEMS_SYSINIT_ITEM() ... Tue, 17 Apr 2018 04:19:17 GMT Sebastian Huber [0b93d4f8] * bsps/shared/start/bspstart-empty.c (moved) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move bspstart.c to bsps This patch is a part of the BSP ... Tue, 17 Apr 2018 04:18:43 GMT Sebastian Huber [0736410] * bsps/shared/start/bspreset-loop.c (moved) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) bsps: Move bspreset_loop.c to bsps This patch is a part of the BSP ... Tue, 17 Apr 2018 04:18:30 GMT Sebastian Huber [554e39c] * bsps/shared/start/bspreset-empty.c (moved) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) bsps: Move bspreset.c to bsps This patch is a part of the BSP ... Tue, 17 Apr 2018 04:18:02 GMT Sebastian Huber [43bda786] * bsps/shared/start/bspfatal-default.c (moved) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move bspclean.c to bsps This patch is a part of the BSP ... Fri, 20 Apr 2018 07:19:02 GMT Sebastian Huber [4826858] * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) motorola_powerpc: Remove headers from *_SOURCES This was used by ... Tue, 17 Apr 2018 15:05:27 GMT Joel Sherrill [4c4dc17] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) misc arm tcfg: Add dl06, too large for memory Mon, 16 Apr 2018 22:04:02 GMT Joel Sherrill [2da4a6c] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) misc tcfg: Use disable-mrfs-tests.tcfg, do not duplicate test list Mon, 16 Apr 2018 17:59:51 GMT Joel Sherrill [2aa60e57] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Use disable-iconv-tests.tcfg, do not ... Mon, 16 Apr 2018 17:56:45 GMT Joel Sherrill [8d9aa9a] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/gwlcfm-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_dpu-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/phycore_mpc5554-testsuite.tcfg (modified) misc tcfg: Use disable-jffs2-tests.tcfg, do not duplicate test list Thu, 12 Apr 2018 15:17:35 GMT Joel Sherrill [d245eb0] * c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k-testsuite.tcfg (modified) generic_or1k: Disable sptls02 until or1k GCC updated from 4.9.x ... Thu, 12 Apr 2018 15:13:48 GMT Joel Sherrill [1b2681fe] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx_ea_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx_plx800_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_ncs_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_plx800_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg (modified) * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332-testsuite.tcfg (modified) * c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_app-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_boot-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/gensh1/make/custom/gensh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/gensh2/make/custom/gensh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh4-testsuite.tcfg (modified) * testsuites/testdata/disable-iconv-tests.tcfg (added) Multiple BSP tcfg: Disable iconv files. Fri, 13 Apr 2018 07:15:05 GMT Sebastian Huber [223e22f] * bsps/shared/dev/serial/uart-output-char.c (moved) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) bsps: Move uart-output-char.c to bsps This patch is a part of the ... Fri, 13 Apr 2018 07:14:56 GMT Sebastian Huber [0a09ac58] * bsps/shared/start/stackalloc.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) bsps: Move stackalloc.c to bsps This patch is a part of the BSP ... Fri, 13 Apr 2018 07:14:36 GMT Sebastian Huber [9d44ae7] * bsps/shared/start/bsp-uboot-board-info.c (moved) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) bsps: Move bsp-uboot-board-info.c to bsps This patch is a part of ... Fri, 13 Apr 2018 07:11:58 GMT Sebastian Huber [1cba1de] * bsps/shared/start/bsp-fdt.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) bsps: Move bsp-fdt.c to bsps This patch is a part of the BSP source ... Fri, 13 Apr 2018 06:57:30 GMT Sebastian Huber [90013f59] * bsps/shared/dev/rtc/rtc-support.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) bsps: Move tod.c to bsps and rename This patch is a part of the BSP ... Thu, 12 Apr 2018 05:27:41 GMT Sebastian Huber [4ff09d5b] * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/generic_or1k/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/riscv/riscv_generic/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) build: Remove subdir-objects from BSP configure.ac The ... Wed, 11 Apr 2018 04:19:26 GMT Sebastian Huber [ff24c90d] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/shared/gnatinstallhandler.c (deleted) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Remove empty gnatinstallhandler.c This patch is a part of the ... Wed, 11 Apr 2018 04:18:32 GMT Sebastian Huber [c5fe4431] * bsps/shared/shared-sources.am (modified) * bsps/shared/start/bootcard.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move bootcard.c to bsps This patch is a part of the BSP ... Tue, 10 Apr 2018 14:32:59 GMT Sebastian Huber [4359c43] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Simplify source file path in Makefile.am This patch is a part ... Tue, 10 Apr 2018 05:16:30 GMT Sebastian Huber [b10caf8] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps: Remove headers from librtemsbsp_a_SOURCES This was used by ... Tue, 10 Apr 2018 04:36:19 GMT Sebastian Huber [b78b814] * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) bsps: Avoid source variables in Makefile.am This patch is a part of ... Tue, 10 Apr 2018 04:17:10 GMT Sebastian Huber [6c4140c] * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) bsps: Avoid line continuation in Makefile.am This patch is a part ... Sat, 07 Apr 2018 17:46:01 GMT Sebastian Huber [1032bf9] * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) bsp/mvme5500: Avoid RTEMS_RELLDFLAGS Sat, 07 Apr 2018 17:38:55 GMT Sebastian Huber [b46f943c] * bsps/powerpc/motorola_powerpc/dev/console.inl (moved) * bsps/powerpc/motorola_powerpc/dev/keyboard.h (moved) * bsps/powerpc/motorola_powerpc/dev/polled_io.c (moved) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) bsp/motorola_powerpc: Move polled_io.c This file was used by this ... Sat, 07 Apr 2018 17:28:42 GMT Sebastian Huber [efb893f] * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em_hw.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em_hw.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em_osdep.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em_rtems.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/rtemscompat_defs.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe_rtems.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/rtemscompat_defs.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mv643xx_eth.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/if_xxx_rtems.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/rtemscompat.h (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/rtemscompat1.h (modified) bsp/beatnik: Avoid RTEMS_RELLDFLAGS Avoid extra CPPFLAGS. Thu, 05 Apr 2018 15:07:20 GMT Sebastian Huber [b43ea9f] * bsps/shared/dev/serial/legacy-console-control.c (moved) * bsps/shared/dev/serial/legacy-console-select.c (moved) * bsps/shared/dev/serial/legacy-console.c (moved) * bsps/shared/dev/serial/legacy-console.h (moved) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console_select.c (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.c (modified) * c/src/lib/libbsp/i386/pc386/console/gdb_select.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/pc386/console/rtd316.c (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse_config.c (modified) * c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/shared/console_read.c (deleted) * c/src/lib/libbsp/shared/console_write.c (deleted) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) bsps: Move legacy console driver to bsps This patch is a part of ... Thu, 05 Apr 2018 14:45:26 GMT Sebastian Huber [f0bcae38] * c/src/lib/libbsp/shared/console_select_simple.c (deleted) bsps: Remove unused console_select_simple.c This patch is a part of ... Wed, 11 Apr 2018 03:26:58 GMT Chris Johns [b8c59353] * c/src/automake/subdirs.am (modified) * cpukit/automake/subdirs.am (modified) * testsuites/automake/subdirs.am (modified) build: Fix make clean. Update #3254. Tue, 10 Apr 2018 06:06:39 GMT Chris Johns [aa567bc1] * c/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/generic_or1k/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/riscv/riscv_generic/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * testsuites/ada/configure.ac (modified) * testsuites/benchmarks/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/rhealstone/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) configure: Add subdir-objects to all automake flags. This option ... Tue, 10 Apr 2018 00:32:25 GMT Chris Johns [7ff743d] * aclocal/enable-rtemsbsp.m4 (modified) * c/src/aclocal/enable-rtemsbsp.m4 (deleted) * testsuites/aclocal/enable-rtemsbsp.m4 (deleted) Generate an error if a BSP in the --enable-rtemsbsp list is not valid ... Mon, 09 Apr 2018 03:47:36 GMT Chris Johns [cb7b4dc4] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) bsp/lpc24xx: Exclude iconv POSIX tests. These are now built to ...
