# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 05/01/24 16:03:06 Sat, 14 Sep 2002 20:45:14 GMT Joel Sherrill [aebde08e] * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (modified) 2002-09-14 Joel Sherrill * cpu.c: ... Sat, 14 Sep 2002 19:57:24 GMT Joel Sherrill [c98110a] * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/clock/clock.c (modified) 2002-09-14 Joel Sherrill * ... Sat, 14 Sep 2002 19:39:16 GMT Joel Sherrill [536f5f94] * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/startup/bspstart.c (modified) 2002-09-14 Joel Sherrill * ... Sat, 14 Sep 2002 18:47:56 GMT Joel Sherrill [0c0d089] * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/sp32/.cvsignore (added) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp32/.cvsignore (added) 2002-09-14 Joel Sherrill * ... Sat, 14 Sep 2002 18:47:07 GMT Joel Sherrill [0af7c20] * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/sptests/sp32/Makefile.am (added) * c/src/tests/sptests/sp32/init.c (added) * c/src/tests/sptests/sp32/sp32.scn (added) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp32/Makefile.am (added) * testsuites/sptests/sp32/init.c (added) * testsuites/sptests/sp32/sp32.scn (added) 2002-09-14 Aaron J. Grier * PR271 was ... Sat, 14 Sep 2002 17:59:49 GMT Joel Sherrill [9db34c3f] * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/include/bsp.h (modified) * c/src/lib/libbsp/or32/orp/startup/Makefile.am (modified) * c/src/lib/libbsp/or32/orp/startup/bspclean.c (modified) 2002-09-14 Ivan Guzvinec * ... Sat, 14 Sep 2002 16:59:42 GMT Joel Sherrill [2b2e1e96] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) 2002-09-13 Eric Norum * ... Fri, 13 Sep 2002 20:40:48 GMT Eric Norum [8f099da] * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) 2002-09-13 Eric Norum * ... Fri, 13 Sep 2002 17:34:10 GMT Joel Sherrill [d814e2c] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) 2002-09-13 Joel Sherrill * ... Fri, 13 Sep 2002 17:00:18 GMT Joel Sherrill [d7ff09b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/hello/Makefile.am (modified) 2002-09-13 Joel Sherrill * ... Fri, 13 Sep 2002 13:40:37 GMT Joel Sherrill [d464fe7] * c/make/ChangeLog (modified) * c/make/target.cfg.in (modified) 2002-09-13 Joel Sherrill * Part of ... Fri, 13 Sep 2002 13:39:52 GMT Joel Sherrill [ccf2cfd] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/ChangeLog (modified) * make/compilers/gcc-target-default.cfg (modified) * make/main.cfg (modified) 2002-09-13 Joel Sherrill * Part of ... Sun, 08 Sep 2002 08:11:01 GMT Ralf Corsepius [cb72774] * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) 2002-09-08 Ralf Corsepius * ... Sun, 08 Sep 2002 07:59:05 GMT Ralf Corsepius [c386c63] * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) 2002-09-08 Ralf Corsepius * ... Sun, 08 Sep 2002 07:50:57 GMT Ralf Corsepius [e293efaf] * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/Makefile.am (modified) 2002-09-08 Ralf Corsepius * ... Sun, 08 Sep 2002 07:36:11 GMT Ralf Corsepius [bca73c8] * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) 2002-09-08 Ralf Corsepius * ... Sun, 08 Sep 2002 07:14:45 GMT Ralf Corsepius [bdd85dc2] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) 2002-09-08 Ralf Corsepius * ... Sun, 08 Sep 2002 07:11:54 GMT Ralf Corsepius [6373910] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) 2002-09-08 Ralf Corsepius * ... Sat, 07 Sep 2002 23:16:12 GMT Joel Sherrill [ca756e9] * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/clock/clock.c (modified) 2002-09-07 Joel Sherrill * ... Sat, 07 Sep 2002 23:12:07 GMT Joel Sherrill [4e7ba21] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/base_mp/config.h (added) 2002-09-07 Joel Sherrill * ... Sat, 07 Sep 2002 23:09:47 GMT Joel Sherrill [a2117cd6] * c/src/libchip/ChangeLog (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.cs8900 (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/cs8900.c.bsp (added) * c/src/libchip/network/cs8900.h (modified) 2002-09-07 Chris Johns * ... Sat, 07 Sep 2002 23:07:58 GMT Joel Sherrill [19ed3cf] * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/ipcp.c (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/pppd/ipcp.c (modified) 2002-09-07 Joel Sherrill * ... Fri, 06 Sep 2002 02:45:50 GMT Ralf Corsepius [640e0dd6] * c/src/make/ChangeLog (modified) * c/src/make/Makefile.inc.in (modified) 2002-09-06 Ralf Corsepius * ... Tue, 03 Sep 2002 18:31:23 GMT Joel Sherrill [addebe67] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (deleted) 2002-09-03 Joel Sherrill * base_mp ... Mon, 02 Sep 2002 06:21:03 GMT Ralf Corsepius [c7dcfe36] * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_webserver/md5.h (modified) * cpukit/httpd/md5.h (modified) 2002-09-02 Ralf Corsepius * ... Mon, 02 Sep 2002 06:17:39 GMT Ralf Corsepius [4adabccd] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc8260/exceptions/raw_exception.c (modified) 2002-09-02 Ralf Corsepius * ... Mon, 02 Sep 2002 06:15:21 GMT Ralf Corsepius [6ce94bc3] * c/src/lib/libbsp/i386/shared/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) 2002-09-02 Ralf Corsepius * ... Mon, 02 Sep 2002 05:19:01 GMT Ralf Corsepius [7625d9a3] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp01/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp02/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp02/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp03/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp03/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp04/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp04/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp05/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp05/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp06/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp06/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp07/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp07/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp08/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp08/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp09/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp09/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp10/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp10/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp11/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp11/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp12/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp12/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp13/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp13/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp14/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp14/node2/.cvsignore (added) * c/src/ada-tests/samples/base_mp/node1/.cvsignore (added) * c/src/ada-tests/samples/base_mp/node2/.cvsignore (added) 2002-09-02 Ralf Corsepius * ... Mon, 02 Sep 2002 05:08:57 GMT Ralf Corsepius [0c7ef52] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/mptests/Makefile.am (added) * c/src/ada-tests/mptests/mp01/Makefile.am (added) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (added) * c/src/ada-tests/samples/base_mp/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (added) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (added) 2002-09-02 Ralf Corsepius * ... Sat, 31 Aug 2002 14:44:15 GMT Joel Sherrill [5432fc4] * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/rtems_webserver/webmain.c (modified) * cpukit/httpd/webmain.c (modified) 2002-08-31 Joel Sherrill * ... Fri, 30 Aug 2002 13:13:07 GMT Ralf Corsepius [84206479] * c/src/libmisc/ChangeLog (modified) * c/src/libmisc/shell/shell.c (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) 2002-08-30 Ralf Corsepius * ... Fri, 30 Aug 2002 12:14:51 GMT Ralf Corsepius [2d9c50b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm20/Makefile.am (modified) 2002-08-30 Ralf Corsepius * ... Fri, 30 Aug 2002 12:09:48 GMT Joel Sherrill [b83fd620] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) 2002-08-30 Joel Sherrill * ... Fri, 30 Aug 2002 12:07:54 GMT Joel Sherrill [182e9f8] * c/src/ada/ChangeLog (modified) * c/src/ada/rtems.adb (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/rtems.adb (modified) 2002-08-30 Joel Sherrill * ... Thu, 29 Aug 2002 15:54:25 GMT Ralf Corsepius [b88e366] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/mouse_parser.c (modified) * c/src/lib/libbsp/i386/pc386/console/vt.c (modified) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (modified) 2002-08-29 Ralf Corsepius * ... Wed, 28 Aug 2002 17:35:01 GMT Joel Sherrill [b29709d] * c/src/ada-tests/ChangeLog (modified) 2002-08-27 Joel Sherrill * ... Wed, 28 Aug 2002 14:16:18 GMT Ralf Corsepius [a456af96] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2002-08-28 Ralf Corsepius * ... Tue, 27 Aug 2002 20:25:20 GMT Joel Sherrill [40edeae] * c/src/ada-tests/samples/base_mp/.cvsignore (added) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 17:06:30 GMT Ralf Corsepius [bf6fa0f4] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) 2002-08-27 Ralf Corsepius * ... Tue, 27 Aug 2002 14:05:45 GMT Joel Sherrill [cbb09503] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 13:35:42 GMT Ralf Corsepius [abe09384] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) 2002-08-27 Ralf Corsepius * ... Tue, 27 Aug 2002 13:17:27 GMT Ralf Corsepius [d73a01fd] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/sptest.adb (deleted) 2002-08-27 Ralf Corsepius * ... Tue, 27 Aug 2002 13:12:33 GMT Joel Sherrill [aa57f84] * c/src/ada/ChangeLog (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/rtems.ads (modified) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 13:12:04 GMT Joel Sherrill [e8c20a0] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 11:48:54 GMT Joel Sherrill [b0e8b47e] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (added) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 11:45:33 GMT Joel Sherrill [3634ed9] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm27/.cvsignore (deleted) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 07:47:42 GMT Ralf Corsepius [f3013b8] * c/src/ada-tests/tmtests/tm26/.cvsignore (deleted) Removed Tue, 27 Aug 2002 06:57:46 GMT Ralf Corsepius [a846105] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/ada.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) 2002-08-27 Ralf Corsepius * ... Mon, 26 Aug 2002 17:25:59 GMT Joel Sherrill [c94a454] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm26/config.h (deleted) * c/src/ada-tests/tmtests/tm27/config.h (deleted) 2002-08-26 Joel Sherrill * tm27 and ... Mon, 26 Aug 2002 17:24:44 GMT Joel Sherrill [b2b7cfc9] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/tmtests/Makefile.am (modified) * c/src/ada-tests/tmtests/tm26/Makefile.am (deleted) * c/src/ada-tests/tmtests/tm26/README (deleted) * c/src/ada-tests/tmtests/tm26/tm26.adb (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.adp (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm27/Makefile.am (deleted) * c/src/ada-tests/tmtests/tm27/README (deleted) * c/src/ada-tests/tmtests/tm27/tm27.adb (deleted) * c/src/ada-tests/tmtests/tm27/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm27/tmtest.ads (deleted) 2002-08-26 Joel Sherrill * tm27 and ... Mon, 26 Aug 2002 17:20:36 GMT Joel Sherrill [f435621b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (added) * c/src/ada-tests/sptests/sp19/sptest.adb (modified) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 14:27:21 GMT Joel Sherrill [190f5c23] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 13:44:35 GMT Joel Sherrill [8a0e8da] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sptest.adb (moved) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 13:37:16 GMT Joel Sherrill [61cd8db] * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 13:06:55 GMT Joel Sherrill [44c44c5] * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/startup/linkcmds (modified) 2002-08-21 Joel Sherrill * ... Mon, 26 Aug 2002 10:10:43 GMT Ralf Corsepius [2085b08e] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 09:38:29 GMT Ralf Corsepius [7edb3d3a] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/samples/base_mp/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp02/Makefile.am (modified) * c/src/ada-tests/sptests/sp03/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp05/Makefile.am (modified) * c/src/ada-tests/sptests/sp06/Makefile.am (modified) * c/src/ada-tests/sptests/sp07/Makefile.am (modified) * c/src/ada-tests/sptests/sp08/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp11/Makefile.am (modified) * c/src/ada-tests/sptests/sp12/Makefile.am (modified) * c/src/ada-tests/sptests/sp13/Makefile.am (modified) * c/src/ada-tests/sptests/sp14/Makefile.am (modified) * c/src/ada-tests/sptests/sp15/Makefile.am (modified) * c/src/ada-tests/sptests/sp16/Makefile.am (modified) * c/src/ada-tests/sptests/sp17/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp20/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/Makefile.am (modified) * c/src/ada-tests/sptests/sp22/Makefile.am (modified) * c/src/ada-tests/sptests/sp23/Makefile.am (modified) * c/src/ada-tests/sptests/sp24/Makefile.am (modified) * c/src/ada-tests/sptests/sp25/Makefile.am (modified) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 09:27:51 GMT Ralf Corsepius [0270bc8] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/Makefile.am (added) * c/src/ada-tests/tmtests/tm01/Makefile.am (added) * c/src/ada-tests/tmtests/tm02/Makefile.am (added) * c/src/ada-tests/tmtests/tm03/Makefile.am (added) * c/src/ada-tests/tmtests/tm04/Makefile.am (added) * c/src/ada-tests/tmtests/tm05/Makefile.am (added) * c/src/ada-tests/tmtests/tm06/Makefile.am (added) * c/src/ada-tests/tmtests/tm07/Makefile.am (added) * c/src/ada-tests/tmtests/tm08/Makefile.am (added) * c/src/ada-tests/tmtests/tm09/Makefile.am (added) * c/src/ada-tests/tmtests/tm10/Makefile.am (added) * c/src/ada-tests/tmtests/tm11/Makefile.am (added) * c/src/ada-tests/tmtests/tm12/Makefile.am (added) * c/src/ada-tests/tmtests/tm13/Makefile.am (added) * c/src/ada-tests/tmtests/tm14/Makefile.am (added) * c/src/ada-tests/tmtests/tm15/Makefile.am (added) * c/src/ada-tests/tmtests/tm16/Makefile.am (added) * c/src/ada-tests/tmtests/tm17/Makefile.am (added) * c/src/ada-tests/tmtests/tm18/Makefile.am (added) * c/src/ada-tests/tmtests/tm19/Makefile.am (added) * c/src/ada-tests/tmtests/tm20/Makefile.am (added) * c/src/ada-tests/tmtests/tm21/Makefile.am (added) * c/src/ada-tests/tmtests/tm22/Makefile.am (added) * c/src/ada-tests/tmtests/tm23/Makefile.am (added) * c/src/ada-tests/tmtests/tm24/Makefile.am (added) * c/src/ada-tests/tmtests/tm25/Makefile.am (added) * c/src/ada-tests/tmtests/tm26/Makefile.am (added) * c/src/ada-tests/tmtests/tm26/tmtest.adb (added) * c/src/ada-tests/tmtests/tm27/Makefile.am (added) * c/src/ada-tests/tmtests/tm28/Makefile.am (added) * c/src/ada-tests/tmtests/tm29/Makefile.am (added) * c/src/ada-tests/tmtests/tmck/Makefile.am (added) * c/src/ada-tests/tmtests/tmoverhd/Makefile.am (added) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 06:12:08 GMT Ralf Corsepius [2af6056] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (added) * c/src/ada-tests/ada.am (added) * c/src/ada-tests/configure.ac (added) * c/src/ada-tests/samples/Makefile.am (added) * c/src/ada-tests/samples/base_mp/Makefile.am (added) * c/src/ada-tests/samples/base_sp/Makefile.am (added) * c/src/ada-tests/samples/hello/Makefile.am (added) * c/src/ada-tests/samples/ticker/Makefile.am (added) * c/src/ada-tests/support/Makefile.am (added) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 06:04:49 GMT Ralf Corsepius [1a5f405b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/Makefile.am (added) * c/src/ada-tests/sptests/sp01/Makefile.am (added) * c/src/ada-tests/sptests/sp02/Makefile.am (added) * c/src/ada-tests/sptests/sp03/Makefile.am (added) * c/src/ada-tests/sptests/sp04/Makefile.am (added) * c/src/ada-tests/sptests/sp05/Makefile.am (added) * c/src/ada-tests/sptests/sp06/Makefile.am (added) * c/src/ada-tests/sptests/sp07/Makefile.am (added) * c/src/ada-tests/sptests/sp08/Makefile.am (added) * c/src/ada-tests/sptests/sp09/Makefile.am (added) * c/src/ada-tests/sptests/sp11/Makefile.am (added) * c/src/ada-tests/sptests/sp12/Makefile.am (added) * c/src/ada-tests/sptests/sp13/Makefile.am (added) * c/src/ada-tests/sptests/sp14/Makefile.am (added) * c/src/ada-tests/sptests/sp15/Makefile.am (added) * c/src/ada-tests/sptests/sp16/Makefile.am (added) * c/src/ada-tests/sptests/sp17/Makefile.am (added) * c/src/ada-tests/sptests/sp19/Makefile.am (added) * c/src/ada-tests/sptests/sp20/Makefile.am (added) * c/src/ada-tests/sptests/sp21/Makefile.am (added) * c/src/ada-tests/sptests/sp22/Makefile.am (added) * c/src/ada-tests/sptests/sp23/Makefile.am (added) * c/src/ada-tests/sptests/sp24/Makefile.am (added) * c/src/ada-tests/sptests/sp25/Makefile.am (added) * c/src/ada-tests/sptests/spsize/Makefile.am (added) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 05:51:56 GMT Ralf Corsepius [28cf529] * c/src/ada-tests/.cvsignore (added) * c/src/ada-tests/ChangeLog (added) * c/src/ada-tests/mptests/.cvsignore (added) * c/src/ada-tests/mptests/mp01/.cvsignore (added) * c/src/ada-tests/mptests/mp02/.cvsignore (added) * c/src/ada-tests/mptests/mp03/.cvsignore (added) * c/src/ada-tests/mptests/mp04/.cvsignore (added) * c/src/ada-tests/mptests/mp05/.cvsignore (added) * c/src/ada-tests/mptests/mp06/.cvsignore (added) * c/src/ada-tests/mptests/mp07/.cvsignore (added) * c/src/ada-tests/mptests/mp08/.cvsignore (added) * c/src/ada-tests/mptests/mp09/.cvsignore (added) * c/src/ada-tests/mptests/mp10/.cvsignore (added) * c/src/ada-tests/mptests/mp11/.cvsignore (added) * c/src/ada-tests/mptests/mp12/.cvsignore (added) * c/src/ada-tests/mptests/mp13/.cvsignore (added) * c/src/ada-tests/mptests/mp14/.cvsignore (added) * c/src/ada-tests/samples/.cvsignore (added) * c/src/ada-tests/samples/base_sp/.cvsignore (added) * c/src/ada-tests/samples/hello/.cvsignore (added) * c/src/ada-tests/samples/ticker/.cvsignore (added) * c/src/ada-tests/sptests/.cvsignore (added) * c/src/ada-tests/sptests/sp01/.cvsignore (added) * c/src/ada-tests/sptests/sp02/.cvsignore (added) * c/src/ada-tests/sptests/sp03/.cvsignore (added) * c/src/ada-tests/sptests/sp04/.cvsignore (added) * c/src/ada-tests/sptests/sp05/.cvsignore (added) * c/src/ada-tests/sptests/sp06/.cvsignore (added) * c/src/ada-tests/sptests/sp07/.cvsignore (added) * c/src/ada-tests/sptests/sp08/.cvsignore (added) * c/src/ada-tests/sptests/sp09/.cvsignore (added) * c/src/ada-tests/sptests/sp11/.cvsignore (added) * c/src/ada-tests/sptests/sp12/.cvsignore (added) * c/src/ada-tests/sptests/sp13/.cvsignore (added) * c/src/ada-tests/sptests/sp14/.cvsignore (added) * c/src/ada-tests/sptests/sp15/.cvsignore (added) * c/src/ada-tests/sptests/sp16/.cvsignore (added) * c/src/ada-tests/sptests/sp17/.cvsignore (added) * c/src/ada-tests/sptests/sp19/.cvsignore (added) * c/src/ada-tests/sptests/sp20/.cvsignore (added) * c/src/ada-tests/sptests/sp21/.cvsignore (added) * c/src/ada-tests/sptests/sp22/.cvsignore (added) * c/src/ada-tests/sptests/sp23/.cvsignore (added) * c/src/ada-tests/sptests/sp24/.cvsignore (added) * c/src/ada-tests/sptests/sp25/.cvsignore (added) * c/src/ada-tests/sptests/spsize/.cvsignore (added) * c/src/ada-tests/support/.cvsignore (added) * c/src/ada-tests/tmtests/.cvsignore (added) * c/src/ada-tests/tmtests/tm01/.cvsignore (added) * c/src/ada-tests/tmtests/tm02/.cvsignore (added) * c/src/ada-tests/tmtests/tm03/.cvsignore (added) * c/src/ada-tests/tmtests/tm04/.cvsignore (added) * c/src/ada-tests/tmtests/tm05/.cvsignore (added) * c/src/ada-tests/tmtests/tm06/.cvsignore (added) * c/src/ada-tests/tmtests/tm07/.cvsignore (added) * c/src/ada-tests/tmtests/tm08/.cvsignore (added) * c/src/ada-tests/tmtests/tm09/.cvsignore (added) * c/src/ada-tests/tmtests/tm10/.cvsignore (added) * c/src/ada-tests/tmtests/tm11/.cvsignore (added) * c/src/ada-tests/tmtests/tm12/.cvsignore (added) * c/src/ada-tests/tmtests/tm13/.cvsignore (added) * c/src/ada-tests/tmtests/tm14/.cvsignore (added) * c/src/ada-tests/tmtests/tm15/.cvsignore (added) * c/src/ada-tests/tmtests/tm16/.cvsignore (added) * c/src/ada-tests/tmtests/tm17/.cvsignore (added) * c/src/ada-tests/tmtests/tm18/.cvsignore (added) * c/src/ada-tests/tmtests/tm19/.cvsignore (added) * c/src/ada-tests/tmtests/tm20/.cvsignore (added) * c/src/ada-tests/tmtests/tm21/.cvsignore (added) * c/src/ada-tests/tmtests/tm22/.cvsignore (added) * c/src/ada-tests/tmtests/tm23/.cvsignore (added) * c/src/ada-tests/tmtests/tm24/.cvsignore (added) * c/src/ada-tests/tmtests/tm25/.cvsignore (added) * c/src/ada-tests/tmtests/tm26/.cvsignore (added) * c/src/ada-tests/tmtests/tm27/.cvsignore (added) * c/src/ada-tests/tmtests/tm28/.cvsignore (added) * c/src/ada-tests/tmtests/tm29/.cvsignore (added) * c/src/ada-tests/tmtests/tmck/.cvsignore (added) * c/src/ada-tests/tmtests/tmoverhd/.cvsignore (added) 2002-08-26 Ralf Corsepius * ... Fri, 23 Aug 2002 13:52:42 GMT Ralf Corsepius [72deed0] * c/src/ada/.cvsignore (added) * c/src/ada/ChangeLog (modified) * c/src/ada/Makefile.am (added) * cpukit/ada/.cvsignore (added) * cpukit/ada/ChangeLog (modified) * cpukit/ada/Makefile.am (added) * cpukit/ada/configure.ac (added) 2001-08-23 Ralf Corsepius * ... Wed, 21 Aug 2002 17:43:48 GMT Joel Sherrill [06a27bbf] * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/shared/misc/Makefile.am (modified) * c/src/lib/libcpu/m68k/shared/misc/m68kidle.c (added) 2002-08-21 Joel Sherrill * ... Wed, 21 Aug 2002 17:41:26 GMT Joel Sherrill [0308c805] * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/wrapup/Makefile.am (modified) 2002-08-21 Joel Sherrill * ... Wed, 21 Aug 2002 17:06:22 GMT Joel Sherrill [a2ae30c2] * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/bsp_specs (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/bsp_specs (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/bsp_specs (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/bsp_specs (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/bsp_specs (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/bsp_specs (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/bsp_specs (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/bsp_specs (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/bsp_specs (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/bsp_specs (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/bsp_specs (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/bsp_specs (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/bsp_specs (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/bsp_specs (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/bsp_specs (modified) 2002-08-21 Joel Sherrill * ... Wed, 21 Aug 2002 14:57:25 GMT Ralf Corsepius [1846a62] * c/src/ChangeLog (modified) * c/src/Makefile.am (modified) 2002-08-21 Ralf Corsepius * ... Wed, 21 Aug 2002 10:04:45 GMT Ralf Corsepius [304cdca] * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/Makefile.am (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/support/include/Makefile.am (deleted) * testsuites/support/ChangeLog (modified) * testsuites/support/Makefile.am (modified) * testsuites/support/configure.ac (modified) 2002-08-21 Ralf Corsepius * ... Wed, 14 Aug 2002 22:58:30 GMT Joel Sherrill [a681285] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/mips/shared/gdbstub/gdb_if.h (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) * c/src/lib/libbsp/mips/shared/gdbstub/rtems-stub-glue.c (modified) 2002-08-14 Greg Menke * ... Wed, 14 Aug 2002 22:43:10 GMT Joel Sherrill [37bb9bf] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) 2002-08-14 Joel Sherrill * ... Wed, 14 Aug 2002 10:44:49 GMT Ralf Corsepius [2129ac8] * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/md5.c (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_telnetd/telnetd.c (modified) * c/src/libnetworking/rtems_webserver/webmain.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/webmain.c (modified) * cpukit/pppd/md5.c (modified) * cpukit/telnetd/telnetd.c (modified) 2002-08-14 Ralf Corsepius * ... Mon, 12 Aug 2002 14:29:54 GMT Ralf Corsepius [67bfd9a6] * c/src/ChangeLog (modified) * c/src/Makefile.am (modified) * c/src/configure.ac (modified) * c/src/wrapup/Makefile.am (modified) 2002-08-12 Ralf Corsepius ... Mon, 12 Aug 2002 11:23:44 GMT Joel Sherrill [299a523f] * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/utils.c (modified) * cpukit/pppd/utils.c (modified) 2002-08-12 Joel Sherrill * ... Mon, 12 Aug 2002 05:12:39 GMT Ralf Corsepius [f471a45c] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c (modified) 2002-08-12 Ralf Corsepius * ... Sun, 11 Aug 2002 10:50:47 GMT Ralf Corsepius [2dd806a6] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 08:59:17 GMT Ralf Corsepius [af10cd4c] * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:21:01 GMT Ralf Corsepius [55ac4e1] * c/src/ChangeLog (modified) * c/src/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:18:31 GMT Ralf Corsepius [4eb22aa] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:17:05 GMT Ralf Corsepius [73af0d9] * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:13:50 GMT Ralf Corsepius [982fcee] * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:12:59 GMT Ralf Corsepius [6fd7b93] * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/start/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:10:51 GMT Ralf Corsepius [c633eb4] * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/start/Makefile.am (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/start/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:06:08 GMT Ralf Corsepius [8d6eee18] * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:04:36 GMT Ralf Corsepius [0740a89] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:04:12 GMT Ralf Corsepius [d869f64e] * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:03:53 GMT Ralf Corsepius [61f1ba5] * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:03:25 GMT Ralf Corsepius [1f5a123a] * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:02:49 GMT Ralf Corsepius [fb82bff] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) Fix broken ChangeLog Sun, 11 Aug 2002 07:02:19 GMT Ralf Corsepius [dc17e8ed] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:02:13 GMT Ralf Corsepius [730ad0c] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:00:57 GMT Ralf Corsepius [61a1c787] * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:00:30 GMT Ralf Corsepius [8f8dd40c] * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 07:00:09 GMT Ralf Corsepius [d30b703] * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen405/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen405/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:59:42 GMT Ralf Corsepius [162cc99] * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:59:03 GMT Ralf Corsepius [b7afdf13] * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:58:28 GMT Ralf Corsepius [c61c097] * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:55:19 GMT Ralf Corsepius [914981ce] * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:54:29 GMT Ralf Corsepius [88a67b6] * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/clock/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/console/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/start/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/timer/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/clock/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/console/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/start/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/timer/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:51:35 GMT Ralf Corsepius [2b62b3d] * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:45:06 GMT Ralf Corsepius [2568abf3] * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 06:44:20 GMT Ralf Corsepius [d4425210] * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) 2002-08-11 Ralf Corsepius * ...
