# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 05/31/24 14:12:15 Wed, 29 Jan 1997 00:12:31 GMT Joel Sherrill [985796a] * c/src/exec/score/cpu/powerpc/cpu_asm.s (modified) * c/src/exec/score/cpu/powerpc/rtems.s (modified) Changed include of asm.h so it is in brackets not quotes. asm.h is ... Wed, 29 Jan 1997 00:11:16 GMT Joel Sherrill [5ddfa53b] * c/src/exec/score/cpu/no_cpu/cpu.h (modified) Fixed spacing on comments. Wed, 29 Jan 1997 00:10:28 GMT Joel Sherrill [375a6c0] * c/src/exec/score/cpu/mips64orion/cpu.h (modified) Fixed spacing on comment. Wed, 29 Jan 1997 00:09:49 GMT Joel Sherrill [860e77a] * c/src/exec/score/cpu/m68k/cpu.h (modified) Fixed comments. Fixed so this file can be included from assembly code. Wed, 29 Jan 1997 00:08:14 GMT Joel Sherrill [95a1d50] * c/src/exec/score/cpu/i386/cpu.h (modified) Added comment. Wed, 29 Jan 1997 00:07:15 GMT Joel Sherrill [7446899] * c/src/exec/score/cpu/a29k/cpu.h (modified) fixed spacing problem Tue, 28 Jan 1997 23:35:01 GMT Joel Sherrill [f7e46cf0] * c/src/exec/sapi/src/posixapi.c (modified) * cpukit/sapi/src/posixapi.c (modified) With the transition from command line macro definitions to ... Tue, 28 Jan 1997 23:33:40 GMT Joel Sherrill [68d8873] * c/src/exec/sapi/optman/no-io.c (modified) * c/src/optman/sapi/no-io.c (modified) removed include of unnecessary include file. Tue, 28 Jan 1997 23:33:22 GMT Joel Sherrill [52d99d4a] * c/src/exec/posix/src/time.c (modified) * cpukit/posix/src/time.c (modified) Switch to using newlib's implementation of time(). Tue, 28 Jan 1997 23:16:16 GMT Joel Sherrill [b1b5a7cb] * c/src/lib/libbsp/i386/force386/bsp_specs (added) * c/src/lib/libbsp/i386/go32/bsp_specs (added) * c/src/lib/libbsp/i386/i386ex/bsp_specs (added) * c/src/lib/libbsp/i960/cvme961/bsp_specs (added) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (added) * c/src/lib/libbsp/m68k/efi332/bsp_specs (added) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (added) * c/src/lib/libbsp/m68k/idp/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (added) * c/src/lib/libbsp/mips/p4000/bsp_specs (added) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (added) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (added) * c/src/lib/libbsp/sparc/erc32/bsp_specs (added) new file used by gcc 2.8.x -specs option Wed, 15 Jan 1997 20:21:48 GMT Joel Sherrill [fc5e2d73] * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * cpukit/score/cpu/m68k/cpu.c (modified) fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof) Wed, 08 Jan 1997 16:22:22 GMT Joel Sherrill [d135fc52] * c/src/tests/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/size.c (modified) _CPU_Trap_Table_area is now conditional based on whether or not the ... Wed, 08 Jan 1997 16:21:38 GMT Joel Sherrill [c6126e57] * c/src/lib/libc/syscalls.c (modified) removed assert() for stat on non-devices. Now it returns -1. This ... Wed, 08 Jan 1997 16:20:47 GMT Joel Sherrill [1019ae4] * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadmp.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadmp.c (modified) added some casts to reduce warnings reported by users with Microtec ... Wed, 08 Jan 1997 16:19:47 GMT Joel Sherrill [0d051533] * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) added type definitions for all supported task entry formats Mon, 02 Dec 1996 22:50:33 GMT Joel Sherrill [ffe316d] * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) Suggested changes from Mark Jordan which eliminate warnings and ... Mon, 02 Dec 1996 22:47:38 GMT Joel Sherrill [e1a06d1b] * c/src/exec/score/cpu/sparc/asm.h (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) * cpukit/score/cpu/sparc/asm.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) Changes to reflect new revision of erc32 per Jiri Gaisler's ... Mon, 02 Dec 1996 22:42:30 GMT Joel Sherrill [6764c84] * c/src/exec/score/cpu/m68k/cpu.h (modified) minor changes to eliminate warnings from C++ compilers per user ... Mon, 02 Dec 1996 22:36:28 GMT Joel Sherrill [7f96eef] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (added) * c/src/lib/libbsp/sparc/erc32/console/console.c (added) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (added) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (added) Replacement for the sis bsp which supports the simulator and real ... Mon, 02 Dec 1996 22:35:22 GMT Joel Sherrill [c766cac] * c/src/lib/libbsp/sparc/erc32/README (added) * c/src/lib/libbsp/sparc/erc32/times (added) New bsp for the erc32/sis from Jiri Gaisler ... Mon, 02 Dec 1996 19:48:29 GMT Joel Sherrill [29d8227e] * c/src/exec/score/cpu/a29k/a29k.h (modified) * c/src/exec/score/cpu/a29k/cpu.c (modified) * c/src/exec/score/cpu/a29k/cpu.h (modified) * c/src/exec/score/cpu/a29k/cpu_asm.s (modified) * cpukit/score/cpu/a29k/cpu.c (modified) Updates from Derrick Ostertag to fix bug in ... Mon, 02 Dec 1996 19:43:22 GMT Joel Sherrill [f4b7e297] * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * cpukit/score/cpu/m68k/cpu.c (modified) Update from Chris Johns to add better support for ... Fri, 08 Nov 1996 20:08:52 GMT Joel Sherrill [331d9e3b] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/syscalls.c (modified) * cpukit/libcsupport/src/libio.c (modified) Added asserts for unhandled conditions which need to result in error ... Tue, 15 Oct 1996 21:58:32 GMT Joel Sherrill [9e406d9] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) added ENOSYS support Tue, 15 Oct 1996 21:39:27 GMT Joel Sherrill [fe6ef776] * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) updated to format of 3.6.0 Tue, 15 Oct 1996 21:39:15 GMT Joel Sherrill [6c58b6f] * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) updated to format of 3.6.0 console drivers Tue, 15 Oct 1996 21:39:06 GMT Joel Sherrill [39cafa5] * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) updated to format of 3.6.0 clock drivers Tue, 15 Oct 1996 21:38:43 GMT Joel Sherrill [27f0d424] * c/src/exec/score/src/thread.c (modified) * cpukit/score/src/thread.c (modified) added support for cpu time used field in tcb Tue, 15 Oct 1996 21:38:33 GMT Joel Sherrill [f8c6333] * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) added cpu time used field to tcb Tue, 15 Oct 1996 21:38:16 GMT Joel Sherrill [af999a8f] * c/ACKNOWLEDGEMENTS (modified) added i386ex from Erik Ivanenko Tue, 15 Oct 1996 21:01:55 GMT Joel Sherrill [60e2964] * c/src/lib/libbsp/i386/i386ex/README (added) new file Tue, 15 Oct 1996 21:00:41 GMT Joel Sherrill [d1dbcab9] * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) reference to Force CPU-386 removed. added standard comments about ... Tue, 15 Oct 1996 20:57:04 GMT Joel Sherrill [752cd8f] * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (added) * c/src/lib/libbsp/i386/i386ex/console/console.c (added) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (added) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (added) * c/src/lib/libbsp/i386/i386ex/startup/README (added) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (added) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (added) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (added) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (added) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.s (added) initial version from Erik Mon, 14 Oct 1996 19:17:37 GMT Joel Sherrill [2d0383b] * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) patches to erc32.h to correct handling of timer mirror from Jiri Gaisler. Tue, 01 Oct 1996 17:36:57 GMT Joel Sherrill [355c262c] * c/src/exec/score/cpu/i386/i386.h (modified) i386_nofp cpu model entry incorrectly had floating point enabled. Mon, 30 Sep 1996 20:16:05 GMT Joel Sherrill [93bea77] * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) changed INLINE to inline since INLINE is no longer defined by RTEMS Mon, 30 Sep 1996 20:15:01 GMT Joel Sherrill [855edec] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. Mon, 30 Sep 1996 20:14:27 GMT Joel Sherrill [8880e9c7] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version string to 3.6.0 Mon, 30 Sep 1996 20:14:08 GMT Joel Sherrill [348ba42] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) changed stack size of posix initialization threads to double the ... Mon, 30 Sep 1996 20:07:07 GMT Joel Sherrill [6ae41fd] * c/PROBLEMS (modified) updated for Release 3.6.0 to reflect status of posix threads. Fri, 27 Sep 1996 15:49:44 GMT Joel Sherrill [caf87fd7] * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) data and control addresses were swapped for channel a of the scc Fri, 20 Sep 1996 14:25:24 GMT Joel Sherrill [b6082b01] * c/ACKNOWLEDGEMENTS (modified) added missing word in ACKNOWLEDGEMENTS Wed, 18 Sep 1996 22:23:15 GMT Joel Sherrill [1f4f392a] * c/src/tests/psxtests/psx04/task1.c (added) * c/src/tests/psxtests/psx04/task2.c (added) * c/src/tests/psxtests/psx04/task3.c (added) * testsuites/psxtests/psx04/task1.c (added) * testsuites/psxtests/psx04/task2.c (added) * testsuites/psxtests/psx04/task3.c (added) new files Wed, 18 Sep 1996 21:13:10 GMT Joel Sherrill [0836603] * c/src/lib/libbsp/a29k/portsw/README (added) * c/src/lib/libbsp/a29k/portsw/console/concntl.h (added) * c/src/lib/libbsp/a29k/portsw/console/console.c (added) * c/src/lib/libbsp/a29k/portsw/console/serial.c (added) * c/src/lib/libbsp/a29k/portsw/console/serial.h (added) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (added) * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (added) * c/src/lib/libbsp/a29k/portsw/startup/bspclean.c (added) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (added) * c/src/lib/libbsp/a29k/portsw/startup/iface.c (added) * c/src/lib/libbsp/a29k/portsw/startup/main.c (added) * c/src/lib/libbsp/a29k/portsw/startup/ramlink (added) * c/src/lib/libbsp/a29k/portsw/startup/romlink (added) * c/src/lib/libbsp/a29k/portsw/startup/setvec.c (added) * c/src/lib/libbsp/a29k/portsw/times (added) new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick ... Wed, 18 Sep 1996 21:07:37 GMT Joel Sherrill [7abd27b] * c/src/tests/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task1.c (modified) added cast Wed, 18 Sep 1996 21:07:14 GMT Joel Sherrill [c3e3d07] * c/src/tests/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/blow.c (modified) address arithmetic changed to be more portable Wed, 18 Sep 1996 21:06:49 GMT Joel Sherrill [4a5e651] * c/src/tests/libtests/malloctest/init.c (added) * c/src/tests/libtests/malloctest/system.h (added) * c/src/tests/libtests/malloctest/task1.c (added) * testsuites/libtests/malloctest/init.c (added) * testsuites/libtests/malloctest/system.h (added) * testsuites/libtests/malloctest/task1.c (added) new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick ... Wed, 18 Sep 1996 20:56:35 GMT Joel Sherrill [d6b2bba] * c/src/lib/libbsp/a29k/portsw/start/amd.ah (added) * c/src/lib/libbsp/a29k/portsw/start/pswmacro.ah (added) * c/src/lib/libbsp/a29k/portsw/start/register.ah (added) * c/src/lib/start/a29k/amd.ah (added) * c/src/lib/start/a29k/crt0.s (added) * c/src/lib/start/a29k/pswmacro.ah (added) * c/src/lib/start/a29k/register.ah (added) * c/src/lib/start/a29k/register.s (added) new files submitted by Craig Lebakken (lebakken@minn.net) and ... Wed, 18 Sep 1996 20:55:53 GMT Joel Sherrill [5697c28] * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/check.c (modified) pointer arithmetic reworked to be more portable Wed, 18 Sep 1996 20:55:13 GMT Joel Sherrill [be95da0] * c/src/lib/libmisc/monitor/mon-driver.c (modified) * c/src/lib/libmisc/monitor/mon-extension.c (modified) * c/src/lib/libmisc/monitor/mon-itask.c (modified) * c/src/lib/libmisc/monitor/mon-manager.c (modified) * c/src/lib/libmisc/monitor/mon-monitor.c (modified) * c/src/lib/libmisc/monitor/mon-mpci.c (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/mon-server.c (modified) * c/src/lib/libmisc/monitor/mon-task.c (modified) * c/src/lib/libmisc/monitor/monitor.h (modified) * c/src/libmisc/monitor/mon-driver.c (modified) * c/src/libmisc/monitor/mon-extension.c (modified) * c/src/libmisc/monitor/mon-itask.c (modified) * c/src/libmisc/monitor/mon-manager.c (modified) * c/src/libmisc/monitor/mon-monitor.c (modified) * c/src/libmisc/monitor/mon-mpci.c (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/monitor/mon-task.c (modified) * c/src/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) casts added to numerous arguments, prototypes corrected, and proper ... Wed, 18 Sep 1996 20:54:05 GMT Joel Sherrill [0c35efe] * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/libcsupport/src/unixlibc.c (modified) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/unixlibc.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libcsupport/src/unixlibc.c (modified) dummy function added to satisfy ANSI Wed, 18 Sep 1996 20:53:35 GMT Joel Sherrill [5e9a594] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) modified to support non-GNU compilers and to use calloc rather than ... Wed, 18 Sep 1996 20:52:47 GMT Joel Sherrill [1f2d5df] * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/lib/libc/malloc.c (modified) * cpukit/libcsupport/src/malloc.c (modified) added malloc_walk miscellaneous corrections in casting. Wed, 18 Sep 1996 20:52:16 GMT Joel Sherrill [b1c215e] * c/src/exec/libcsupport/include/rtems/libcsupport.h (modified) * c/src/lib/include/rtems/libcsupport.h (modified) * c/src/lib/libc/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) added prototype for malloc_walk Wed, 18 Sep 1996 20:51:48 GMT Joel Sherrill [94218b8] * c/src/exec/score/src/wkspace.c (modified) * cpukit/score/src/wkspace.c (modified) loop to clear workspace memory changed to use sizeof rather than ... Wed, 18 Sep 1996 20:50:58 GMT Joel Sherrill [56e0b88] * c/src/exec/score/src/object.c (modified) * cpukit/score/src/object.c (modified) corrected prototype of _Objects_Get_next Wed, 18 Sep 1996 20:50:27 GMT Joel Sherrill [3861130] * c/src/exec/score/src/heap.c (modified) * cpukit/score/src/heap.c (modified) uses address object rather than direct pointer arithmetic Wed, 18 Sep 1996 20:50:04 GMT Joel Sherrill [4944b5bf] * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/object.h (modified) OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than ... Wed, 18 Sep 1996 20:49:36 GMT Joel Sherrill [857c52f] * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof ... Wed, 18 Sep 1996 20:48:56 GMT Joel Sherrill [533f89f] * c/src/exec/score/headers/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) modified declaration of CORE_message_queue_Buffer_control to avoid ... Wed, 18 Sep 1996 20:47:39 GMT Joel Sherrill [2069773] * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) use address object to avoid direct pointer arithmetic Wed, 18 Sep 1996 20:47:31 GMT Joel Sherrill [d1193c7] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) corrected white space problems added CPU_STRUCTURE_ALIGNMENT to ... Wed, 18 Sep 1996 20:45:27 GMT Joel Sherrill [a4d97d94] * c/src/exec/score/cpu/a29k/a29k.h (added) * c/src/exec/score/cpu/a29k/a29ktypes.h (added) * c/src/exec/score/cpu/a29k/amd.ah (added) * c/src/exec/score/cpu/a29k/asm.h (added) * c/src/exec/score/cpu/a29k/cpu.c (added) * c/src/exec/score/cpu/a29k/cpu.h (added) * c/src/exec/score/cpu/a29k/cpu_asm.h (added) * c/src/exec/score/cpu/a29k/cpu_asm.s (added) * c/src/exec/score/cpu/a29k/pswmacro.ah (added) * c/src/exec/score/cpu/a29k/rtems.c (added) * cpukit/score/cpu/a29k/amd.ah (added) * cpukit/score/cpu/a29k/asm.h (added) * cpukit/score/cpu/a29k/cpu.c (added) * cpukit/score/cpu/a29k/pswmacro.ah (added) new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick ... Wed, 18 Sep 1996 20:29:00 GMT Joel Sherrill [5961dbab] * c/ACKNOWLEDGEMENTS (modified) added AMD 29K port Wed, 18 Sep 1996 14:23:44 GMT Joel Sherrill [0465d128] * c/ACKNOWLEDGEMENTS (modified) added mvme147s from Dominique le Campion Wed, 18 Sep 1996 14:17:54 GMT Joel Sherrill [afe99c2] * c/src/lib/libbsp/m68k/mvme147s/README (added) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (added) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme147s/times (added) new file submitted by Dominique le Campion. Tue, 17 Sep 1996 21:38:59 GMT Joel Sherrill [cc51de91] * c/src/tests/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/system.h (modified) extended Task_id and Task_name arrays to avoid indexing past end of ... Tue, 17 Sep 1996 21:33:07 GMT Joel Sherrill [1d9d044] * c/src/exec/score/src/coremutex.c (modified) * cpukit/score/src/coremutex.c (modified) Reversed logic in conditional to correctly distinguish between FIFO ... Tue, 17 Sep 1996 21:31:30 GMT Joel Sherrill [41be2e8] * c/src/exec/posix/src/time.c (modified) * cpukit/posix/src/time.c (modified) added routine _POSIX_Timespec_subtract Tue, 17 Sep 1996 21:31:10 GMT Joel Sherrill [aa48536] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) Added code to insure that the post switch extension was executed and ... Tue, 17 Sep 1996 21:29:51 GMT Joel Sherrill [9093c3c] * c/src/exec/posix/src/cond.c (modified) * cpukit/posix/src/cond.c (modified) Corrected implementation of timed wait on condition variables. First ... Tue, 17 Sep 1996 21:26:25 GMT Joel Sherrill [ded66f8] * c/src/exec/posix/headers/time.h (modified) * c/src/exec/posix/include/rtems/posix/time.h (modified) * cpukit/posix/include/rtems/posix/time.h (modified) added prototype for _POSIX_Timespec_subtract Thu, 12 Sep 1996 20:41:27 GMT Mark Johannes [09093ee] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Fixed test to match change to pthread_cond_timedwait which now takes ... Wed, 11 Sep 1996 19:16:07 GMT Joel Sherrill [cda277f] * c/src/exec/score/cpu/mips/asm.h (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/cpu_asm.h (modified) * c/src/exec/score/cpu/mips/idtcpu.h (modified) * c/src/exec/score/cpu/mips/idtmon.h (modified) * c/src/exec/score/cpu/mips/iregdef.h (modified) * c/src/exec/score/cpu/mips/rtems.c (modified) * c/src/exec/score/cpu/mips64orion/asm.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.c (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (modified) * c/src/exec/score/cpu/mips64orion/idtcpu.h (modified) * c/src/exec/score/cpu/mips64orion/idtmon.h (modified) * c/src/exec/score/cpu/mips64orion/iregdef.h (modified) * c/src/exec/score/cpu/mips64orion/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/mipstypes.h (modified) * c/src/exec/score/cpu/mips64orion/rtems.c (modified) * cpukit/score/cpu/mips/asm.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/asm.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips64orion/asm.h (modified) * cpukit/score/cpu/mips64orion/cpu.c (modified) * cpukit/score/cpu/mips64orion/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu_asm.h (modified) * cpukit/score/cpu/mips64orion/idtcpu.h (modified) * cpukit/score/cpu/mips64orion/idtmon.h (modified) * cpukit/score/cpu/mips64orion/iregdef.h (modified) added $Id$ to file headers cpu.h: added prototype for ... Wed, 11 Sep 1996 19:15:09 GMT Joel Sherrill [0971cd5] * c/src/lib/libbsp/mips/p4000/start/start.S (modified) * c/src/lib/libbsp/mips64orion/p4000/start/start.S (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/clock/clock.S (modified) * c/src/lib/libcpu/mips/clock/clock.h (modified) * c/src/lib/libcpu/mips/timer/gettime.S (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/clock/clock.S (modified) * c/src/lib/libcpu/mips64orion/clock/clock.h (modified) * c/src/lib/libcpu/mips64orion/timer/gettime.S (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/start/mips64orion/idt_csu.S (modified) added $ string to file header Wed, 11 Sep 1996 19:13:44 GMT Joel Sherrill [5bb00a8] * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/console/led.S (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips/p4000/startup/linkcmds (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/led.S (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/linkcmds (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) added $Id$ string to file header Wed, 11 Sep 1996 19:12:43 GMT Joel Sherrill [9c0d032] * c/src/lib/libbsp/mips/p4000/startup/idttlb.S (added) * c/src/lib/libbsp/mips/p4000/startup/inittlb.c (added) * c/src/lib/libbsp/mips64orion/p4000/startup/idttlb.S (added) * c/src/lib/libbsp/mips64orion/p4000/startup/inittlb.c (added) new files Sun, 08 Sep 1996 16:24:43 GMT Joel Sherrill [b944007b] * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) added definition of EXT_INT5 Sun, 08 Sep 1996 16:24:13 GMT Joel Sherrill [3d07c8b] * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/libchip/shmdr/shm_driver.h (modified) added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE Sun, 08 Sep 1996 16:23:35 GMT Joel Sherrill [bdef2d8] * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) idtmem.S: changed reference to include files to correct location ... Sun, 08 Sep 1996 16:22:29 GMT Joel Sherrill [eaa34e7] * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/lnklib.S (modified) changed reference to include files to correct location Sun, 08 Sep 1996 16:22:05 GMT Joel Sherrill [3335420] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it ... Sun, 08 Sep 1996 16:21:48 GMT Joel Sherrill [e7a36a9] * c/src/exec/posix/src/adasupp.c (modified) * cpukit/posix/src/adasupp.c (modified) Ada task stack size minimize is twice that for regular pthreads. Sun, 08 Sep 1996 16:21:16 GMT Joel Sherrill [ed5a518] * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would ... Fri, 06 Sep 1996 19:57:39 GMT Joel Sherrill [d1d3796c] * c/ACKNOWLEDGEMENTS (modified) changed to reflect status of R4600 work. Fri, 06 Sep 1996 19:57:21 GMT Joel Sherrill [8445e57] * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) removed need for exceptbdr.h file Fri, 06 Sep 1996 18:11:41 GMT Joel Sherrill [f198c63] * c/src/exec/score/cpu/mips/asm.h (added) * c/src/exec/score/cpu/mips/cpu.c (added) * c/src/exec/score/cpu/mips/cpu_asm.S (added) * c/src/exec/score/cpu/mips/cpu_asm.h (added) * c/src/exec/score/cpu/mips/idtcpu.h (added) * c/src/exec/score/cpu/mips/idtmon.h (added) * c/src/exec/score/cpu/mips/iregdef.h (added) * c/src/exec/score/cpu/mips/rtems.c (added) * c/src/exec/score/cpu/mips64orion/asm.h (added) * c/src/exec/score/cpu/mips64orion/cpu.c (added) * c/src/exec/score/cpu/mips64orion/cpu.h (added) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (added) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (added) * c/src/exec/score/cpu/mips64orion/idtcpu.h (added) * c/src/exec/score/cpu/mips64orion/idtmon.h (added) * c/src/exec/score/cpu/mips64orion/iregdef.h (added) * c/src/exec/score/cpu/mips64orion/mips64orion.h (added) * c/src/exec/score/cpu/mips64orion/mipstypes.h (added) * c/src/exec/score/cpu/mips64orion/rtems.c (added) * c/src/lib/libbsp/mips/p4000/README (added) * c/src/lib/libbsp/mips/p4000/console/console.c (added) * c/src/lib/libbsp/mips/p4000/console/led.S (added) * c/src/lib/libbsp/mips/p4000/include/bsp.h (added) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (added) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (added) * c/src/lib/libbsp/mips/p4000/start/start.S (added) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (added) * c/src/lib/libbsp/mips/p4000/startup/ghlinkcmds (added) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (added) * c/src/lib/libbsp/mips/p4000/startup/linkcmds (added) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (added) * c/src/lib/libbsp/mips/p4000/times (added) * c/src/lib/libbsp/mips64orion/p4000/README (added) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (added) * c/src/lib/libbsp/mips64orion/p4000/console/led.S (added) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (added) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (added) * c/src/lib/libbsp/mips64orion/p4000/liblnk/lnklib.S (added) * c/src/lib/libbsp/mips64orion/p4000/start/start.S (added) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (added) * c/src/lib/libbsp/mips64orion/p4000/startup/ghlinkcmds (added) * c/src/lib/libbsp/mips64orion/p4000/startup/idtmem.S (added) * c/src/lib/libbsp/mips64orion/p4000/startup/linkcmds (added) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (added) * c/src/lib/libbsp/mips64orion/p4000/times (added) * c/src/lib/libcpu/mips/clock/ckinit.c (added) * c/src/lib/libcpu/mips/clock/clock.S (added) * c/src/lib/libcpu/mips/clock/clock.h (added) * c/src/lib/libcpu/mips/timer/gettime.S (added) * c/src/lib/libcpu/mips/timer/timer.c (added) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (added) * c/src/lib/libcpu/mips64orion/clock/clock.S (added) * c/src/lib/libcpu/mips64orion/clock/clock.h (added) * c/src/lib/libcpu/mips64orion/timer/gettime.S (added) * c/src/lib/libcpu/mips64orion/timer/timer.c (added) * c/src/lib/start/mips64orion/idt_csu.S (added) * cpukit/score/cpu/mips/asm.h (added) * cpukit/score/cpu/mips/cpu.c (added) * cpukit/score/cpu/mips/cpu_asm.S (added) * cpukit/score/cpu/mips/idtcpu.h (added) * cpukit/score/cpu/mips/iregdef.h (added) * cpukit/score/cpu/mips/rtems/asm.h (added) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (added) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (added) * cpukit/score/cpu/mips64orion/asm.h (added) * cpukit/score/cpu/mips64orion/cpu.c (added) * cpukit/score/cpu/mips64orion/cpu_asm.S (added) * cpukit/score/cpu/mips64orion/cpu_asm.h (added) * cpukit/score/cpu/mips64orion/idtcpu.h (added) * cpukit/score/cpu/mips64orion/idtmon.h (added) * cpukit/score/cpu/mips64orion/iregdef.h (added) new file for MIPS port by Craig Lebakken (lebakken@minn.net) and ... Fri, 06 Sep 1996 18:09:25 GMT Joel Sherrill [f29032c] * c/ACKNOWLEDGEMENTS (modified) added MIPS port by Craig Lebakken (lebakken@minn.net) and Derrick ... Fri, 06 Sep 1996 15:17:39 GMT Joel Sherrill [2ffcc2ed] * c/src/tests/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/init.c (modified) modified test to take into account change in default value of ... Fri, 06 Sep 1996 15:16:19 GMT Joel Sherrill [7fea679b] * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/tod.inl (modified) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/tod.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/src/coretod.c (modified) changed _TOD_Is_set from a function to a boolean variable Thu, 05 Sep 1996 20:45:05 GMT Joel Sherrill [65c421f] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) default thread attributes: default value for inheritsched changed ... Thu, 05 Sep 1996 20:41:10 GMT Joel Sherrill [297be5c] * c/src/exec/posix/src/mutex.c (modified) * cpukit/posix/src/mutex.c (modified) pthread_mutex_setprioceiling: fixed bug where returned priority was ... Thu, 05 Sep 1996 20:31:32 GMT Joel Sherrill [7e230f10] * c/src/tests/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task2.c (modified) added printf of status when not successful Thu, 05 Sep 1996 20:29:07 GMT Joel Sherrill [9a5cbef0] * c/src/exec/posix/src/time.c (modified) * cpukit/posix/src/time.c (modified) nanosleep: negative value for tv_sec is no longer an error. It now ... Thu, 05 Sep 1996 20:03:19 GMT Joel Sherrill [f254b93f] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) nanosleep no longer consider a negative value of tv_sec to be an ... Thu, 29 Aug 1996 16:39:01 GMT Joel Sherrill [62bf651f] * c/src/exec/posix/src/adasupp.c (added) * cpukit/posix/src/adasupp.c (added) new file to support GNU Ada. currently the only routine in this ... Tue, 27 Aug 1996 15:19:51 GMT Joel Sherrill [b5c04b6] * c/src/exec/posix/src/sched.c (modified) * cpukit/posix/src/sched.c (modified) fixed typo .. changed == to != Tue, 27 Aug 1996 15:19:33 GMT Joel Sherrill [5a234809] * c/src/exec/posix/src/cond.c (modified) * cpukit/posix/src/cond.c (modified) check that we were passed a valid mutex and ignore errors from the ... Fri, 23 Aug 1996 15:58:24 GMT Mark Johannes [e4cc4176] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) Changed all EFAULTS to EINVALs Fri, 23 Aug 1996 15:56:50 GMT Mark Johannes [3adf786] * c/src/tests/psxtests/psx12/psx12.scn (modified) * testsuites/psxtests/psx12/psx12.scn (modified) filled in screen
