# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 12:54:10 Sat, 22 Dec 2018 17:31:04 GMT Sebastian Huber [7eb606d3] * bsps/shared/grlib-sources.am (added) * bsps/shared/grlib/1553/b1553brm.c (moved) * bsps/shared/grlib/1553/b1553rt.c (moved) * bsps/shared/grlib/1553/gr1553b.c (moved) * bsps/shared/grlib/1553/gr1553bc.c (moved) * bsps/shared/grlib/1553/gr1553bm.c (moved) * bsps/shared/grlib/1553/gr1553rt.c (moved) * bsps/shared/grlib/amba/ahbstat.c (moved) * bsps/shared/grlib/amba/ambapp.c (moved) * bsps/shared/grlib/amba/ambapp_alloc.c (moved) * bsps/shared/grlib/amba/ambapp_count.c (moved) * bsps/shared/grlib/amba/ambapp_depth.c (moved) * bsps/shared/grlib/amba/ambapp_find_by_idx.c (moved) * bsps/shared/grlib/amba/ambapp_freq.c (moved) * bsps/shared/grlib/amba/ambapp_names.c (moved) * bsps/shared/grlib/amba/ambapp_old.c (moved) * bsps/shared/grlib/amba/ambapp_parent.c (moved) * bsps/shared/grlib/amba/ambapp_show.c (moved) * bsps/shared/grlib/analog/gradcdac.c (moved) * bsps/shared/grlib/ascs/grascs.c (moved) * bsps/shared/grlib/btimer/gptimer.c (moved) * bsps/shared/grlib/btimer/tlib.c (moved) * bsps/shared/grlib/btimer/tlib_ckinit.c (moved) * bsps/shared/grlib/can/canmux.c (moved) * bsps/shared/grlib/can/grcan.c (moved) * bsps/shared/grlib/can/occan.c (moved) * bsps/shared/grlib/can/satcan.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c (moved) * bsps/shared/grlib/drvmgr/get_resarray_count.c (moved) * bsps/shared/grlib/gpio/gpiolib.c (moved) * bsps/shared/grlib/gpio/grgpio.c (moved) * bsps/shared/grlib/i2c/i2cmst.c (moved) * bsps/shared/grlib/iommu/griommu.c (moved) * bsps/shared/grlib/irq/genirq.c (moved) * bsps/shared/grlib/l2c/l2c.c (moved) * bsps/shared/grlib/mem/mctrl.c (moved) * bsps/shared/grlib/net/README (moved) * bsps/shared/grlib/net/greth.c (moved) * bsps/shared/grlib/net/network_interface_add.c (moved) * bsps/shared/grlib/pci/gr_701.c (moved) * bsps/shared/grlib/pci/gr_rasta_adcdac.c (moved) * bsps/shared/grlib/pci/gr_rasta_io.c (moved) * bsps/shared/grlib/pci/gr_rasta_spw_router.c (moved) * bsps/shared/grlib/pci/gr_rasta_tmtc.c (moved) * bsps/shared/grlib/pci/gr_tmtc_1553.c (moved) * bsps/shared/grlib/pci/grpci.c (moved) * bsps/shared/grlib/pci/grpci2.c (moved) * bsps/shared/grlib/pci/grpci2dma.c (moved) * bsps/shared/grlib/pci/pcif.c (moved) * bsps/shared/grlib/pwm/grpwm.c (moved) * bsps/shared/grlib/scrub/memscrub.c (moved) * bsps/shared/grlib/slink/grslink.c (moved) * bsps/shared/grlib/spi/spictrl.c (moved) * bsps/shared/grlib/spw/grspw.c (moved) * bsps/shared/grlib/spw/grspw_pkt.c (moved) * bsps/shared/grlib/spw/grspw_router.c (moved) * bsps/shared/grlib/spw/spwtdp.c (moved) * bsps/shared/grlib/stat/l4stat.c (moved) * bsps/shared/grlib/time/grctm.c (moved) * bsps/shared/grlib/time/spwcuc.c (moved) * bsps/shared/grlib/tmtc/grtc.c (moved) * bsps/shared/grlib/tmtc/grtm.c (moved) * bsps/shared/grlib/uart/apbuart_cons.c (moved) * bsps/shared/grlib/uart/apbuart_polled.c (moved) * bsps/shared/grlib/uart/apbuart_termios.c (moved) * bsps/shared/grlib/uart/cons.c (moved) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) grlib: Move source files Update #3678. Fri, 21 Dec 2018 07:39:33 GMT Sebastian Huber [41a557bc] * bsps/arm/shared/cache/cache-cp15.c (modified) * bsps/arm/shared/cache/cache-v7ar-disable-data.S (added) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) bsps/arm: Add ARMv7-AR disable data cache Close #3667. Thu, 13 Dec 2018 08:39:20 GMT Sebastian Huber [6b0a729b] * ampolish3 (deleted) * c/src/aclocal/project-root.m4 (modified) * c/src/aclocal/rtems-ampolish.m4 (deleted) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * cpukit/aclocal/rtems-ampolish.m4 (deleted) * cpukit/configure.ac (modified) build: Remove ampolish3 Update #3254. Thu, 03 May 2018 11:03:27 GMT Sebastian Huber [0a1f5df9] * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * bsps/shared/dev/cpucounter/cpucounterdiff.c (deleted) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon2/clock/ckinit.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/include/leon.h (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc/sparc-counter.c (deleted) Simplify _CPU_Counter_difference() In order to simplify the use of ... Fri, 16 Nov 2018 07:55:30 GMT Sebastian Huber [5f5bbd1] * bsps/x86_64/amd64/start/linkcmds (modified) * bsps/x86_64/amd64/start/start.S (added) * bsps/x86_64/amd64/start/start.c (deleted) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) bsps/x86_64: Use interrupt stack for init stack Update #3459. Thu, 15 Nov 2018 19:47:22 GMT Sebastian Huber [84e59b7c] * bsps/powerpc/gen5200/start/start.S (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/haleakala/start/start.S (moved) * bsps/powerpc/mpc8260ads/start/start.S (modified) * bsps/powerpc/mvme3100/start/start.S (modified) * bsps/powerpc/mvme5500/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.share (modified) * bsps/powerpc/shared/start/start.S (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/virtex/start/start.S (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) bsps/powerpc: Use interrupt stack for init stack Move start.o to ... Thu, 08 Nov 2018 15:21:48 GMT Sebastian Huber [bfcf1473] * bsps/m32c/m32cbsp/README (deleted) * bsps/m32c/m32cbsp/btimer/btimer.c (deleted) * bsps/m32c/m32cbsp/config/m32csim-testsuite.tcfg (deleted) * bsps/m32c/m32cbsp/config/m32csim.cfg (deleted) * bsps/m32c/m32cbsp/console/console-io.c (deleted) * bsps/m32c/m32cbsp/console/syscalls.S (deleted) * bsps/m32c/m32cbsp/doxygen.h (deleted) * bsps/m32c/m32cbsp/headers.am (deleted) * bsps/m32c/m32cbsp/include/bsp.h (deleted) * bsps/m32c/m32cbsp/include/tm27.h (deleted) * bsps/m32c/m32cbsp/start/bsp_specs (deleted) * bsps/m32c/m32cbsp/start/bspstart.c (deleted) * bsps/m32c/m32cbsp/start/crtn.S (deleted) * bsps/m32c/m32cbsp/start/linkcmds (deleted) * bsps/m32c/m32cbsp/start/start.S (deleted) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/m32c/Makefile.am (deleted) * c/src/lib/libbsp/m32c/acinclude.m4 (deleted) * c/src/lib/libbsp/m32c/configure.ac (deleted) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (deleted) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (deleted) * cpukit/Makefile.am (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/score/cpu/m32c/context_init.c (deleted) * cpukit/score/cpu/m32c/context_switch.S (deleted) * cpukit/score/cpu/m32c/cpu.c (deleted) * cpukit/score/cpu/m32c/headers.am (deleted) * cpukit/score/cpu/m32c/include/rtems/asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/m32c.h (deleted) * cpukit/score/cpu/m32c/include/varvects.h (deleted) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (deleted) * cpukit/score/cpu/m32c/varvects.S (deleted) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptimer_err02/init.c (modified) m32c: Remove this target Update #3599. Wed, 07 Nov 2018 10:08:50 GMT Sebastian Huber [2faea99] * bsps/arm/realview-pbx-a9/console/console-config.c (modified) * bsps/arm/realview-pbx-a9/console/console-polled.c (added) * bsps/arm/realview-pbx-a9/include/bsp/console.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) bsp/realview-pbx-a9: Fix printk() support Avoid dependencies on the ... Wed, 24 Oct 2018 08:17:58 GMT Sebastian Huber [01595a4] * bsps/arm/imx/start/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) bsp/imx: Adjust workspace according to device tree Mon, 24 Sep 2018 14:32:49 GMT Joel Sherrill [b4043ea] * c/src/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) check-networking.m4: Disable legacy stack for x86_64 and epiphany ... Mon, 15 Oct 2018 05:22:42 GMT Sebastian Huber [fb12215] * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) build: Remove specialized CPPFLAGS Close #3375. Sat, 06 Oct 2018 08:59:10 GMT Sebastian Huber [477bca2] * automake/local.am (deleted) * c/src/Makefile.am (modified) * c/src/automake/local.am (deleted) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/lib/libbsp/x86_64/Makefile.am (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * c/src/make/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/local.am (deleted) * cpukit/score/cpu/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/ada/Makefile.am (modified) * testsuites/ada/mptests/Makefile.am (modified) * testsuites/ada/mptests/mp01/Makefile.am (modified) * testsuites/ada/mptests/mp01/node1/Makefile.am (modified) * testsuites/ada/mptests/mp01/node2/Makefile.am (modified) * testsuites/ada/mptests/mp03/Makefile.am (modified) * testsuites/ada/mptests/mp03/node1/Makefile.am (modified) * testsuites/ada/mptests/mp03/node2/Makefile.am (modified) * testsuites/ada/mptests/mp04/Makefile.am (modified) * testsuites/ada/mptests/mp04/node1/Makefile.am (modified) * testsuites/ada/mptests/mp04/node2/Makefile.am (modified) * testsuites/ada/mptests/mp05/Makefile.am (modified) * testsuites/ada/mptests/mp05/node1/Makefile.am (modified) * testsuites/ada/mptests/mp05/node2/Makefile.am (modified) * testsuites/ada/mptests/mp06/Makefile.am (modified) * testsuites/ada/mptests/mp06/node1/Makefile.am (modified) * testsuites/ada/mptests/mp06/node2/Makefile.am (modified) * testsuites/ada/mptests/mp07/Makefile.am (modified) * testsuites/ada/mptests/mp07/node1/Makefile.am (modified) * testsuites/ada/mptests/mp07/node2/Makefile.am (modified) * testsuites/ada/mptests/mp08/Makefile.am (modified) * testsuites/ada/mptests/mp08/node1/Makefile.am (modified) * testsuites/ada/mptests/mp08/node2/Makefile.am (modified) * testsuites/ada/mptests/mp09/Makefile.am (modified) * testsuites/ada/mptests/mp09/node1/Makefile.am (modified) * testsuites/ada/mptests/mp09/node2/Makefile.am (modified) * testsuites/ada/mptests/mp10/Makefile.am (modified) * testsuites/ada/mptests/mp10/node1/Makefile.am (modified) * testsuites/ada/mptests/mp10/node2/Makefile.am (modified) * testsuites/ada/mptests/mp11/Makefile.am (modified) * testsuites/ada/mptests/mp11/node1/Makefile.am (modified) * testsuites/ada/mptests/mp11/node2/Makefile.am (modified) * testsuites/ada/mptests/mp12/Makefile.am (modified) * testsuites/ada/mptests/mp12/node1/Makefile.am (modified) * testsuites/ada/mptests/mp12/node2/Makefile.am (modified) * testsuites/ada/mptests/mp13/Makefile.am (modified) * testsuites/ada/mptests/mp13/node1/Makefile.am (modified) * testsuites/ada/mptests/mp13/node2/Makefile.am (modified) * testsuites/ada/mptests/mp14/Makefile.am (modified) * testsuites/ada/mptests/mp14/node1/Makefile.am (modified) * testsuites/ada/mptests/mp14/node2/Makefile.am (modified) * testsuites/ada/samples/Makefile.am (modified) * testsuites/ada/samples/base_mp/Makefile.am (modified) * testsuites/ada/samples/base_mp/node1/Makefile.am (modified) * testsuites/ada/samples/base_mp/node2/Makefile.am (modified) * testsuites/ada/samples/base_sp/Makefile.am (modified) * testsuites/ada/samples/hello/Makefile.am (modified) * testsuites/ada/samples/nsecs/Makefile.am (modified) * testsuites/ada/samples/ticker/Makefile.am (modified) * testsuites/ada/sptests/Makefile.am (modified) * testsuites/ada/sptests/sp01/Makefile.am (modified) * testsuites/ada/sptests/sp02/Makefile.am (modified) * testsuites/ada/sptests/sp03/Makefile.am (modified) * testsuites/ada/sptests/sp04/Makefile.am (modified) * testsuites/ada/sptests/sp05/Makefile.am (modified) * testsuites/ada/sptests/sp06/Makefile.am (modified) * testsuites/ada/sptests/sp07/Makefile.am (modified) * testsuites/ada/sptests/sp08/Makefile.am (modified) * testsuites/ada/sptests/sp09/Makefile.am (modified) * testsuites/ada/sptests/sp11/Makefile.am (modified) * testsuites/ada/sptests/sp12/Makefile.am (modified) * testsuites/ada/sptests/sp13/Makefile.am (modified) * testsuites/ada/sptests/sp14/Makefile.am (modified) * testsuites/ada/sptests/sp15/Makefile.am (modified) * testsuites/ada/sptests/sp16/Makefile.am (modified) * testsuites/ada/sptests/sp17/Makefile.am (modified) * testsuites/ada/sptests/sp19/Makefile.am (modified) * testsuites/ada/sptests/sp20/Makefile.am (modified) * testsuites/ada/sptests/sp22/Makefile.am (modified) * testsuites/ada/sptests/sp23/Makefile.am (modified) * testsuites/ada/sptests/sp24/Makefile.am (modified) * testsuites/ada/sptests/sp25/Makefile.am (modified) * testsuites/ada/sptests/spatcb01/Makefile.am (modified) * testsuites/ada/sptests/spname01/Makefile.am (modified) * testsuites/ada/support/Makefile.am (modified) * testsuites/ada/tmtests/Makefile.am (modified) * testsuites/ada/tmtests/tm01/Makefile.am (modified) * testsuites/ada/tmtests/tm02/Makefile.am (modified) * testsuites/ada/tmtests/tm03/Makefile.am (modified) * testsuites/ada/tmtests/tm04/Makefile.am (modified) * testsuites/ada/tmtests/tm05/Makefile.am (modified) * testsuites/ada/tmtests/tm06/Makefile.am (modified) * testsuites/ada/tmtests/tm07/Makefile.am (modified) * testsuites/ada/tmtests/tm08/Makefile.am (modified) * testsuites/ada/tmtests/tm09/Makefile.am (modified) * testsuites/ada/tmtests/tm10/Makefile.am (modified) * testsuites/ada/tmtests/tm11/Makefile.am (modified) * testsuites/ada/tmtests/tm12/Makefile.am (modified) * testsuites/ada/tmtests/tm13/Makefile.am (modified) * testsuites/ada/tmtests/tm14/Makefile.am (modified) * testsuites/ada/tmtests/tm15/Makefile.am (modified) * testsuites/ada/tmtests/tm16/Makefile.am (modified) * testsuites/ada/tmtests/tm17/Makefile.am (modified) * testsuites/ada/tmtests/tm18/Makefile.am (modified) * testsuites/ada/tmtests/tm19/Makefile.am (modified) * testsuites/ada/tmtests/tm20/Makefile.am (modified) * testsuites/ada/tmtests/tm21/Makefile.am (modified) * testsuites/ada/tmtests/tm22/Makefile.am (modified) * testsuites/ada/tmtests/tm23/Makefile.am (modified) * testsuites/ada/tmtests/tm24/Makefile.am (modified) * testsuites/ada/tmtests/tm25/Makefile.am (modified) * testsuites/ada/tmtests/tm28/Makefile.am (modified) * testsuites/ada/tmtests/tm29/Makefile.am (modified) * testsuites/ada/tmtests/tmck/Makefile.am (modified) * testsuites/ada/tmtests/tmoverhd/Makefile.am (modified) * testsuites/automake/local.am (deleted) * testsuites/benchmarks/Makefile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/mptests/mp01/Makefile.am (modified) * testsuites/mptests/mp03/Makefile.am (modified) * testsuites/mptests/mp04/Makefile.am (modified) * testsuites/mptests/mp05/Makefile.am (modified) * testsuites/mptests/mp06/Makefile.am (modified) * testsuites/mptests/mp07/Makefile.am (modified) * testsuites/mptests/mp08/Makefile.am (modified) * testsuites/mptests/mp09/Makefile.am (modified) * testsuites/mptests/mp10/Makefile.am (modified) * testsuites/mptests/mp11/Makefile.am (modified) * testsuites/mptests/mp12/Makefile.am (modified) * testsuites/mptests/mp13/Makefile.am (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/rhealstone/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) build: Remove local.am Fri, 21 Jul 2017 12:18:50 GMT Javier Jalle [6dc0b5f] * bsps/sparc/headers.am (modified) * bsps/sparc/include/bsp/spwtdp.h (added) * bsps/sparc/include/drvmgr/ambapp_bus.h (modified) * bsps/sparc/shared/spw/spwtdp.c (added) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/include/drvmgr/drvmgr_confdefs.h (modified) leon, spwtdp: Initial driver commit Tue, 11 Sep 2018 04:25:26 GMT Sebastian Huber [2d17e88] * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) bsps/mips: Remove unused command line defines Update #3375. Fri, 21 Sep 2018 05:38:23 GMT Sebastian Huber [69a24c3] * bsps/arm/imx/start/ccm.c (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) bsp/imx: Add imx_ccm_sdhci_hz() Update #3525. Wed, 07 Feb 2018 11:35:33 GMT Jacob Hansen [5cbc9c5] * c/src/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/gcc-specs.m4 (added) * testsuites/aclocal/prog-cc.m4 (modified) clang: Keep -qrtems and -B for compilers without -specs support ... Mon, 17 Sep 2018 06:28:29 GMT Sebastian Huber [62cb39d7] * bsps/powerpc/tqm8xx/dev/clock.c (deleted) * bsps/powerpc/tqm8xx/dev/console-generic.c (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Remove unused files Close #3513. Wed, 12 Sep 2018 09:47:19 GMT Sebastian Huber [d22147e] * bsps/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Convert console to new Termios API Update #3513. Fri, 31 Aug 2018 05:44:53 GMT Sebastian Huber [fad3f79b] * bsps/arm/raspberrypi/start/bspgetworkarea.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/include/bsp.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/virtex/include/bsp.h (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN Remove the ... Wed, 29 Aug 2018 17:51:50 GMT Joel Sherrill [66e78854] * bsps/sparc64/shared/helenos/boot/generic/string.c (deleted) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) Remove bsps/sparc64/shared/helenos/boot/generic/string.c Mon, 13 Aug 2018 10:55:34 GMT Amaan Cheval [bc731313] * bsps/x86_64/amd64/clock/clock.c (added) * bsps/x86_64/amd64/headers.am (modified) * bsps/x86_64/amd64/include/apic.h (added) * bsps/x86_64/amd64/include/clock.h (added) * bsps/x86_64/amd64/include/pic.h (added) * bsps/x86_64/amd64/interrupts/pic.c (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add APIC timer based clock driver The APIC timer is ... Mon, 13 Aug 2018 10:50:38 GMT Amaan Cheval [6869321] * bsps/x86_64/amd64/interrupts/idt.c (added) * bsps/x86_64/amd64/interrupts/isr_handler.S (added) * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/headers.am (modified) * bsps/x86_64/include/bsp/irq.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/idt.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (modified) bsps/x86_64: Add support for RTEMS interrupts Updates #2898. Mon, 13 Aug 2018 10:33:12 GMT Amaan Cheval [4544749e] * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/amd64/start/page.c (added) * bsps/x86_64/headers.am (added) * bsps/x86_64/include/libcpu/page.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add paging support with 1GiB super pages Updates #2898. Thu, 09 Aug 2018 07:20:33 GMT Sebastian Huber [f4424cfb] * bsps/sparc/include/bsp/apbuart.h (modified) * bsps/sparc/include/bsp/apbuart_termios.h (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/shared/uart/apbuart_cons.c (modified) * bsps/sparc/shared/uart/apbuart_polled.c (added) * bsps/sparc/shared/uart/apbuart_termios.c (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move polled APBUART functions This reduces the ... Fri, 03 Aug 2018 12:03:39 GMT Sebastian Huber [32ccc01] * bsps/shared/irq-sources.am (modified) * bsps/shared/irq/irq-generic.c (modified) * bsps/shared/irq/irq-lock.c (added) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) bsps: Fix the generic IRQ support The genmcf548x partly uses is own ... Tue, 24 Jul 2018 08:10:12 GMT Sebastian Huber [6552ba8] * bsps/riscv/riscv/btimer/btimer.c (deleted) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Use CPU counter btimer Update #3433. Fri, 20 Jul 2018 11:11:04 GMT Sebastian Huber [447fd89] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspsmp.c (added) * bsps/riscv/riscv/start/bspstart.c (modified) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Add basic SMP startup Update #3433. Thu, 19 Jul 2018 13:12:11 GMT Sebastian Huber [f5fd8eb] * bsps/riscv/include/bsp/linker-symbols.h (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsps/riscv: Update linker-symbols.h Update #3433. Thu, 19 Jul 2018 12:06:10 GMT Sebastian Huber [791d9ac5] * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Disable HTIF support by default The HTIF is a legacy ... Thu, 19 Jul 2018 10:11:19 GMT Sebastian Huber [8db3f0e] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/include/bsp/linker-symbols.h (modified) * bsps/riscv/riscv/btimer/btimer.c (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspstart.c (moved) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Rework exception handling Remove ... Mon, 09 Jul 2018 11:12:57 GMT Amaan Cheval [cf811a4] * bsps/x86_64/amd64/console/console.c (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) x86_64/console: Add NS16550 polled console driver This addition ... Mon, 09 Jul 2018 11:12:56 GMT Amaan Cheval [76c03152] * bsps/x86_64/amd64/config/amd64.cfg (added) * bsps/x86_64/amd64/console/console.c (added) * bsps/x86_64/amd64/headers.am (added) * bsps/x86_64/amd64/include/bsp.h (added) * bsps/x86_64/amd64/include/start.h (added) * bsps/x86_64/amd64/include/tm27.h (added) * bsps/x86_64/amd64/start/bsp_specs (added) * bsps/x86_64/amd64/start/bspstart.c (added) * bsps/x86_64/amd64/start/linkcmds (added) * bsps/x86_64/amd64/start/start.c (added) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/x86_64/Makefile.am (added) * c/src/lib/libbsp/x86_64/acinclude.m4 (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (added) * c/src/lib/libbsp/x86_64/amd64/configure.ac (added) * c/src/lib/libbsp/x86_64/configure.ac (added) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/x86_64/Makefile.am (added) * cpukit/score/cpu/x86_64/cpu.c (added) * cpukit/score/cpu/x86_64/headers.am (added) * cpukit/score/cpu/x86_64/include/machine/elf_machdep.h (added) * cpukit/score/cpu/x86_64/include/rtems/asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (added) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (added) bsp/x86_64: Minimal bootable BSP Current state: - Basic context ... Fri, 06 Jul 2018 09:20:31 GMT Sebastian Huber [1a19239] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/console/console-config.c (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add console support for NS16550 devices Update #3433. Mon, 25 Jun 2018 06:44:16 GMT Sebastian Huber [1232cd46] * bsps/riscv/riscv/console/console-config.c (added) * bsps/riscv/riscv/console/htif.c (moved) * bsps/riscv/riscv/include/dev/serial/htif.h (added) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add device tree support for console Update #3433. Fri, 22 Jun 2018 06:01:48 GMT Sebastian Huber [fe2cd01b] * bsps/riscv/riscv/include/bsp.h (modified) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add device tree support Update #3433. Fri, 11 May 2018 04:54:59 GMT Sebastian Huber [2086948a] * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * testsuites/smptests/smpfatal08/init.c (modified) riscv: Add dummy SMP support Update #3433. Fri, 11 May 2018 04:25:47 GMT Sebastian Huber [853c5ef] * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) build: Enable RISC-V SMP build Update #3433. Fri, 22 Jun 2018 05:51:08 GMT Sebastian Huber [16d905f] * bsps/riscv/riscv/start/linkcmds.in (moved) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add BSP options to define RAM region Update #3433. Fri, 22 Jun 2018 05:35:27 GMT Sebastian Huber [37a1fc2] * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Remove unused BSP options Update #3433. Fri, 22 Jun 2018 05:06:57 GMT Sebastian Huber [6f5d88a] * bsps/riscv/riscv/btimer/btimer.c (moved) * bsps/riscv/riscv/clock/clockdrv.c (moved) * bsps/riscv/riscv/config/rv32i.cfg (moved) * bsps/riscv/riscv/config/rv32iac.cfg (moved) * bsps/riscv/riscv/config/rv32im.cfg (moved) * bsps/riscv/riscv/config/rv32imac.cfg (moved) * bsps/riscv/riscv/config/rv32imafc.cfg (moved) * bsps/riscv/riscv/config/rv64imac.cfg (moved) * bsps/riscv/riscv/config/rv64imafdc.cfg (moved) * bsps/riscv/riscv/console/console-io.c (moved) * bsps/riscv/riscv/headers.am (added) * bsps/riscv/riscv/include/bsp.h (moved) * bsps/riscv/riscv/include/bsp/irq.h (moved) * bsps/riscv/riscv/include/tm27.h (moved) * bsps/riscv/riscv/irq/irq.c (moved) * bsps/riscv/riscv/start/bsp_fatal_halt.c (moved) * bsps/riscv/riscv/start/bsp_specs (moved) * bsps/riscv/riscv/start/linkcmds (moved) * bsps/riscv/riscv/start/linkcmds.base (moved) * bsps/riscv/riscv/start/start.S (moved) * bsps/riscv/riscv_generic/headers.am (deleted) * c/src/lib/libbsp/riscv/acinclude.m4 (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (moved) * c/src/lib/libbsp/riscv/riscv/configure.ac (moved) bsp/riscv_generic: Rename to "riscv" Update #3433. Tue, 29 May 2018 07:14:24 GMT Sebastian Huber [9e3bb45] * bsps/riscv/riscv_generic/console/console-io.c (modified) * bsps/riscv/riscv_generic/start/linkcmds (modified) * bsps/riscv/riscv_generic/start/linkcmds.base (added) * bsps/riscv/riscv_generic/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) bsp/riscv_generic: New linker command file This linker command file ... Tue, 19 Jun 2018 07:09:51 GMT Sebastian Huber [511dc4b] * bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg (deleted) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (deleted) * bsps/arm/csb336/start/start.S (modified) * bsps/arm/csb337/start/start.S (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/gumstix/start/start.S (modified) * bsps/arm/imx/start/linkcmds.imx7 (modified) * bsps/arm/include/bsp/linker-symbols.h (modified) * bsps/arm/raspberrypi/start/bspsmp.c (modified) * bsps/arm/raspberrypi/start/linkcmds (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg (deleted) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (deleted) * bsps/arm/rtl22xx/start/start.S (modified) * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) * bsps/arm/shared/start/linkcmds.base (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/start/start.S (modified) * bsps/arm/xilinx-zynq/start/linkcmds.in (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/lm32/shared/start/start.S (modified) * bsps/m32c/m32cbsp/start/linkcmds (modified) * bsps/m32c/m32cbsp/start/start.S (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68340/start/start.S (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/gen68360/start/start.S (modified) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf52235/start/start.S (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/start.S (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mcf5329/start/start.S (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/mrm332/start/start.S (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/shared/start/start.S (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/csb350/start/start.S (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/jmr3904/start/start.S (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/malta/start/start.S (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/mips/shared/irq/exception.S (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/include/bsp.h (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/gen83xx/include/bsp.h (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/dlentry.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/start.S (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/start.S (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/ss555/start/start.S (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/include/bsp.h (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/riscv/riscv_generic/start/start.S (modified) * bsps/sh/gensh1/include/bsp.h (modified) * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh1/start/start.S (modified) * bsps/sh/gensh2/include/bsp.h (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh2/start/start.S (modified) * bsps/sh/gensh2/start/start.ram (modified) * bsps/sh/gensh2/start/start.rom (modified) * bsps/sh/gensh4/include/bsp.h (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/gensh4/start/start.S (modified) * bsps/sh/shared/start/bspstart.c (modified) * bsps/sh/shsim/include/bsp.h (modified) * bsps/sh/shsim/start/cpu_asm.c (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sh/shsim/start/start.S (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * bsps/sparc/shared/start/start.S (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/start.S (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/cpu.c (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/cpu_asm.S (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/percpuasm.c (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spsize/size.c (modified) Rework initialization and interrupt stack support Statically ... Tue, 22 May 2018 06:52:13 GMT Sebastian Huber [762fa62] * bsps/arm/include/bsp/clock-armv7m.h (added) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) arm: Simplify CPU counter support Use the standard ARMv7-M systick ... Wed, 23 May 2018 12:17:25 GMT Sebastian Huber [65f868c] * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * bsps/arm/include/bsp/arm-a9mpcore-clock.h (modified) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/lpc24xx/start/system-clocks.c (modified) * bsps/arm/lpc32xx/start/bspstart.c (modified) * bsps/arm/realview-pbx-a9/start/bspstart.c (modified) * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * bsps/arm/tms570/cpucounter/cpucounterread.c (modified) * bsps/arm/xilinx-zynq/start/bspstart.c (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/shared/dev/cpucounter/cpucounterfrequency.c (added) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (added) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) Add _CPU_Counter_frequency() Add rtems_counter_frequency() API ... Fri, 15 Jun 2018 06:18:26 GMT Sebastian Huber [bac8d934] * Makefile.am (modified) * c/src/make/README (modified) * c/src/make/host.cfg.in (modified) * configure.ac (modified) * tools/build/Makefile.am (deleted) * tools/build/README (deleted) * tools/build/config.h.in (deleted) * tools/build/configure.ac (deleted) * tools/build/install-if-change.in (deleted) tools: Remove install-if-change program The last installed tool in ... Fri, 15 Jun 2018 06:05:27 GMT Sebastian Huber [6fb0223] * c/src/make/configure.ac (modified) make: Remove obsolete AC_SUBST() Fri, 15 Jun 2018 05:53:42 GMT Sebastian Huber [5ff9547a] * c/src/make/README (modified) make: Remove CFLAGS_DEBUG_OPTIMIZE_V Do not document ... Thu, 07 Jun 2018 04:37:39 GMT Sebastian Huber [e8b28ba] * aclocal/project-root.m4 (modified) * bsps/m68k/mrm332/config/mrm332.cfg (modified) * bsps/m68k/mvme147/config/mvme147.cfg (modified) * bsps/m68k/mvme147s/config/mvme147s.cfg (modified) * bsps/mips/hurricane/config/hurricane.cfg (modified) * bsps/mips/rbtx4925/config/rbtx4925.cfg (modified) * c/src/make/host.cfg.in (modified) * testsuites/aclocal/project-root.m4 (modified) * tools/build/Makefile.am (modified) * tools/build/configure.ac (modified) * tools/build/packhex.c (deleted) tools: Remove packhex All tools should be removed from the RTEMS ... Thu, 07 Jun 2018 04:13:38 GMT Sebastian Huber [ea092ccc] * aclocal/project-root.m4 (modified) * c/src/make/host.cfg.in (modified) * testsuites/aclocal/project-root.m4 (modified) * testsuites/fstests/fsdosfsname01/create_image.sh (modified) * tools/build/Makefile.am (modified) * tools/build/rtems-bin2c.c (deleted) tools: Remove rtems-bin2c This tool is now included in the RTEMS ... Wed, 06 Jun 2018 14:21:22 GMT Sebastian Huber [8c62cf4] * bsps/sh/gensh1/console/sci.c (modified) * bsps/sh/gensh1/console/scitab.c (added) * bsps/sh/gensh1/include/bsp.h (modified) * bsps/sh/gensh2/console/sci.c (modified) * bsps/sh/gensh2/console/scitab.c (added) * bsps/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/sh/AUTHORS (deleted) * tools/cpu/sh/COPYING (deleted) * tools/cpu/sh/Makefile.am (deleted) * tools/cpu/sh/TODO (deleted) * tools/cpu/sh/configure.ac (deleted) * tools/cpu/sh/sci.c (deleted) * tools/cpu/sh/sci.h (deleted) * tools/cpu/sh/shgen.c (deleted) tools: Remove shgen All tools should be removed from the RTEMS ... Mon, 30 Apr 2018 05:35:09 GMT Sebastian Huber [3248137] * c/src/configure.ac (modified) build: Force warnings Always append some standard warning flags. Wed, 16 May 2018 15:07:26 GMT Joel Sherrill [eaf5bec] * bsps/powerpc/virtex5/config/virtex5.cfg (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) virtex5: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 15:01:26 GMT Joel Sherrill [17f69e4] * bsps/powerpc/virtex4/config/virtex4.cfg (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) virtex4: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 15:01:09 GMT Joel Sherrill [4afc1efa] * bsps/powerpc/virtex/config/virtex.cfg (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) virtex: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:58:13 GMT Joel Sherrill [3d43c475] * bsps/powerpc/tqm8xx/config/tqm8xx.inc (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) tqm8xx: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:57:54 GMT Joel Sherrill [3274ec75] * bsps/powerpc/t32mppc/config/t32mppc.cfg (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) t32mppc: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:57:37 GMT Joel Sherrill [c20001c4] * bsps/powerpc/ss555/config/ss555.cfg (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) ss555: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:55:14 GMT Joel Sherrill [1a41818] * bsps/powerpc/qoriq/config/qoriq.inc (modified) * bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg (modified) * bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) qoriq: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:54:50 GMT Joel Sherrill [b06e8d61] * bsps/powerpc/qemuppc/config/qemuppc.cfg (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) qemuppc: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:54:33 GMT Joel Sherrill [c3b609d5] * bsps/powerpc/psim/config/psim.cfg (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) psim: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:54:13 GMT Joel Sherrill [beb4468] * bsps/powerpc/mvme5500/config/mvme5500.cfg (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) mvme5500: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:50:11 GMT Joel Sherrill [5aa8ac2] * bsps/powerpc/mvme3100/config/mvme3100.cfg (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) mvme3100: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:49:51 GMT Joel Sherrill [a03f73c] * bsps/powerpc/mpc8260ads/config/mpc8260ads.cfg (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) mpc8260ads: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:49:22 GMT Joel Sherrill [1e84462] * bsps/powerpc/mpc55xxevb/config/mpc55xx.inc (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) mpc55xxevb: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:47:40 GMT Joel Sherrill [2261ef2] * bsps/powerpc/motorola_powerpc/config/mcp750.cfg (modified) * bsps/powerpc/motorola_powerpc/config/mtx603e.cfg (modified) * bsps/powerpc/motorola_powerpc/config/mvme2100.cfg (modified) * bsps/powerpc/motorola_powerpc/config/qemuprep-altivec.cfg (modified) * bsps/powerpc/motorola_powerpc/config/qemuprep.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) motorola_powerpc: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:47:07 GMT Joel Sherrill [01da0ac] * bsps/powerpc/haleakala/config/haleakala.cfg (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) haleakala: Move -Dxxx to configure.ac Updates #3425. Wed, 16 May 2018 14:43:24 GMT Joel Sherrill [b1b5afba] * bsps/powerpc/beatnik/config/beatnik.cfg (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) beatnik: Move -Dxxx to configure.ac Updates #3425. Tue, 15 May 2018 14:17:03 GMT Joel Sherrill [9d62874] * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) sparc64 BSPs: Hard define configuration required settings Updates #3425. Mon, 30 Apr 2018 16:34:50 GMT Amaan Cheval [4387010] * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) no_cpu/no_bsp: Fix Makefile Wed, 09 May 2018 20:22:04 GMT Joel Sherrill [c8dcdf54] * bsps/sparc64/include/arch/arch.h (modified) * bsps/sparc64/include/arch/mm/frame.h (modified) * bsps/sparc64/include/arch/mm/mmu.h (modified) * bsps/sparc64/include/arch/mm/tlb.h (modified) * bsps/sparc64/include/arch/mm/tte.h (modified) * bsps/sparc64/niagara/config/niagara.cfg (modified) * bsps/sparc64/usiii/config/usiii.cfg (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) sparc64 niagara, usiii: Remove -D options from cfg file and move to ... Wed, 09 May 2018 19:47:37 GMT Joel Sherrill [85602e0d] * bsps/arm/smdk2410/config/smdk2410.cfg (modified) * bsps/arm/smdk2410/include/bsp/irq.h (modified) * bsps/arm/smdk2410/include/s3c24xx.h (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) smdk2410: Move define of CPU_S3C2410 to bspopts.h Updates #3425. Thu, 26 Apr 2018 05:29:28 GMT Sebastian Huber [3d703f4] * bsps/i386/pc386/config/pc386.cfg (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (deleted) * c/src/lib/libbsp/i386/pc386/tools/Spec.doc (deleted) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (deleted) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (deleted) bsp/pc386: Remove bin2boot support Update #3408. Close #3410. Wed, 25 Apr 2018 14:06:34 GMT Sebastian Huber [419d1e9] * bsps/m68k/mcf5206elite/runtest (moved) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/Makefile.am (deleted) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (deleted) bsp/mcf5206elite: Do not install runtest script Provide the runtest ... Wed, 25 Apr 2018 13:06:08 GMT Sebastian Huber [eb36d11] * bsps/arm/altera-cyclone-v/README (moved) * bsps/arm/atsam/README (moved) * bsps/arm/beagle/README (moved) * bsps/arm/beagle/README.JTAG (moved) * bsps/arm/beagle/TESTING (moved) * bsps/arm/beagle/pwm/README (moved) * bsps/arm/beagle/simscripts/bbxm.cfg (moved) * bsps/arm/beagle/simscripts/gdbinit.bbxm (moved) * bsps/arm/beagle/simscripts/qemu-beagleboard.in (moved) * bsps/arm/beagle/simscripts/sdcard.sh (moved) * bsps/arm/csb336/README (moved) * bsps/arm/csb337/README (moved) * bsps/arm/csb337/README.kit637_v6 (moved) * bsps/arm/edb7312/README (moved) * bsps/arm/gumstix/README (moved) * bsps/arm/lm3s69xx/0001-target-arm-Fixed-ARMv7-M-SHPR-access.patch (moved) * bsps/arm/lm3s69xx/0002-target-arm-Disable-priority_mask-feature.patch (moved) * bsps/arm/lm3s69xx/0003-target-arm-Evil-hack-for-BASEPRI-and-BASEPRI_MAX.patch (moved) * bsps/arm/lm3s69xx/0004-target-arm-Evil-hack-to-increase-the-RAM-size.patch (moved) * bsps/arm/lm3s69xx/0005-target-arm-Fix-system_clock_scale-initial-value.patch (moved) * bsps/arm/lm3s69xx/README (moved) * bsps/arm/lpc176x/README (moved) * bsps/arm/lpc24xx/README (moved) * bsps/arm/lpc32xx/README (moved) * bsps/arm/raspberrypi/README (moved) * bsps/arm/realview-pbx-a9/README (moved) * bsps/arm/rtl22xx/README (moved) * bsps/arm/smdk2410/README (moved) * bsps/arm/stm32f4/README (moved) * bsps/arm/tms570/README (moved) * bsps/arm/xilinx-zynq/README (moved) * bsps/bfin/TLL6527M/README (moved) * bsps/bfin/bf537Stamp/README (moved) * bsps/bfin/eZKit533/README (moved) * bsps/epiphany/epiphany_sim/README (moved) * bsps/i386/pc386/HOWTO (moved) * bsps/i386/pc386/README (moved) * bsps/i386/pc386/README.dec21140 (moved) * bsps/i386/pc386/STATUS (moved) * bsps/lm32/lm32_evr/README (moved) * bsps/lm32/milkymist/Documentation/uart.txt (moved) * bsps/lm32/milkymist/README (moved) * bsps/m32c/m32cbsp/README (moved) * bsps/m68k/av5282/README (moved) * bsps/m68k/csb360/README (moved) * bsps/m68k/gen68340/README (moved) * bsps/m68k/gen68360/README (moved) * bsps/m68k/genmcf548x/README (moved) * bsps/m68k/mcf5206elite/README (moved) * bsps/m68k/mcf52235/README (moved) * bsps/m68k/mcf52235/gdb-init (moved) * bsps/m68k/mcf5225x/README (moved) * bsps/m68k/mcf5225x/gdb-init (moved) * bsps/m68k/mcf5235/README (moved) * bsps/m68k/mcf5235/gdb-init (moved) * bsps/m68k/mcf5329/README (moved) * bsps/m68k/mcf5329/gdb-init (moved) * bsps/m68k/mrm332/README (moved) * bsps/m68k/mrm332/misc/dotests (moved) * bsps/m68k/mrm332/misc/gdbinit68 (moved) * bsps/m68k/mvme147/README (moved) * bsps/m68k/mvme147s/README (moved) * bsps/m68k/mvme162/README (moved) * bsps/m68k/mvme162/README.models (moved) * bsps/m68k/mvme167/README (moved) * bsps/m68k/uC5282/README (moved) * bsps/m68k/uC5282/TIMES (moved) * bsps/mips/csb350/README (moved) * bsps/mips/hurricane/README (moved) * bsps/mips/jmr3904/README (moved) * bsps/mips/malta/STATUS (moved) * bsps/mips/rbtx4925/README (moved) * bsps/mips/rbtx4938/README (moved) * bsps/nios2/README (moved) * bsps/nios2/nios2_iss/nios2_iss.ptf (moved) * bsps/nios2/nios2_iss/nios2_iss.sh (moved) * bsps/no_cpu/no_bsp/README (moved) * bsps/or1k/generic_or1k/README (moved) * bsps/or1k/generic_or1k/sim.cfg (moved) * bsps/powerpc/beatnik/LICENSE (moved) * bsps/powerpc/beatnik/README (moved) * bsps/powerpc/gen5200/README (moved) * bsps/powerpc/gen5200/README.IceCube (moved) * bsps/powerpc/gen83xx/README.mpc8313erdb (moved) * bsps/powerpc/gen83xx/README.mpc8349eamds (moved) * bsps/powerpc/haleakala/README (moved) * bsps/powerpc/motorola_powerpc/BOOTING (moved) * bsps/powerpc/motorola_powerpc/README (moved) * bsps/powerpc/motorola_powerpc/README.MVME2100 (moved) * bsps/powerpc/motorola_powerpc/README.MVME2300 (moved) * bsps/powerpc/motorola_powerpc/README.MVME2400 (moved) * bsps/powerpc/motorola_powerpc/README.OTHERBOARDS (moved) * bsps/powerpc/motorola_powerpc/README.dec21140 (moved) * bsps/powerpc/motorola_powerpc/README.mtx603e (moved) * bsps/powerpc/motorola_powerpc/README.qemu (moved) * bsps/powerpc/mpc55xxevb/README (moved) * bsps/powerpc/mpc8260ads/README (moved) * bsps/powerpc/mvme3100/KNOWN_PROBLEMS (moved) * bsps/powerpc/mvme3100/LICENSE (moved) * bsps/powerpc/mvme3100/README (moved) * bsps/powerpc/mvme5500/LICENSE (moved) * bsps/powerpc/mvme5500/README (moved) * bsps/powerpc/mvme5500/README.VME (moved) * bsps/powerpc/mvme5500/README.booting (moved) * bsps/powerpc/psim/README (moved) * bsps/powerpc/psim/README.vectors (moved) * bsps/powerpc/qemuppc/README (moved) * bsps/powerpc/qoriq/README (moved) * bsps/powerpc/ss555/README (moved) * bsps/powerpc/t32mppc/README (moved) * bsps/powerpc/t32mppc/configsim.t32 (moved) * bsps/powerpc/t32mppc/init.cmm (moved) * bsps/powerpc/tqm8xx/README (moved) * bsps/powerpc/virtex/README (moved) * bsps/powerpc/virtex4/README (moved) * bsps/powerpc/virtex5/README (moved) * bsps/sh/gensh1/README (moved) * bsps/sh/gensh2/README (moved) * bsps/sh/gensh2/README.EVB7045F (moved) * bsps/sh/gensh4/README (moved) * bsps/sh/shsim/README (moved) * bsps/sparc/erc32/README (moved) * bsps/sparc/leon2/README (moved) * bsps/sparc/leon3/README (moved) * bsps/sparc64/niagara/README (moved) * bsps/sparc64/usiii/README (moved) * bsps/v850/gdbv850sim/README (moved) bsps: Move documentation, etc. files to bsps This patch is a part ... Wed, 25 Apr 2018 12:58:50 GMT Sebastian Huber [8eb264d3] * c/src/lib/libbsp/i386/pc386/times_i486dx (deleted) * c/src/lib/libbsp/i386/pc386/times_p5 (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mcp750 (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mvme2307 (deleted) bsps: Remove unmaintained times files This patch is a part of the ... Wed, 25 Apr 2018 12:54:27 GMT Sebastian Huber [1554415e] * bsps/sparc64/shared/start/halt.S (moved) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) bsp/sparc64: Move asm.S to bsps and rename This patch is a part of ... Wed, 25 Apr 2018 12:53:33 GMT Sebastian Huber [a5bf9b6] * bsps/mips/shared/liblnk/lnklib.S (moved) * bsps/mips/shared/liblnk/pmon.S (moved) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) bsps/mips: Move liblnk to bsps This patch is a part of the BSP ... Wed, 25 Apr 2018 12:51:49 GMT Sebastian Huber [3460c522] * bsps/powerpc/shared/start/bsp-start-zero.S (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) bsps/powerpc: Move bsp-start-zero.S to bsps This patch is a part of ... Wed, 25 Apr 2018 12:51:01 GMT Sebastian Huber [b80be135] * bsps/powerpc/psim/start/align_h.S (moved) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) bsp/psim: Move align_h.S to bsps This patch is a part of the BSP ... Wed, 25 Apr 2018 12:50:36 GMT Sebastian Huber [0b60c54] * bsps/powerpc/haleakala/start/dlentry.S (moved) * bsps/powerpc/haleakala/start/mmu_405asm.S (moved) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) bsp/haleakala: Move assembler files to bsps This patch is a part of ... Wed, 25 Apr 2018 18:33:20 GMT Sebastian Huber [b3e5aa5] * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) bsp/qemuppc: Install linkcmds.base Update #3339. Close #3411. Wed, 25 Apr 2018 09:03:31 GMT Sebastian Huber [1913eb16] * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/CMSIS/Include/arm_common_tables.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/arm_const_structs.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/arm_math.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/cmsis_armcc.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/cmsis_armcc_V6.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm0.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm0plus.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm3.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm4.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_sc000.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_sc300.h (deleted) * c/src/lib/libbsp/arm/shared/CMSIS/README (deleted) bsps/arm: Remove unused files This patch is a part of the BSP ... Wed, 25 Apr 2018 09:01:45 GMT Sebastian Huber [f7eaf316] * bsps/include/bsp/u-boot.h (modified) * c/src/lib/libbsp/powerpc/shared/include/u-boot-generic-board-info.h (deleted) bsps: Remove unused u-boot-generic-board-info.h This patch is a ... Wed, 25 Apr 2018 08:50:12 GMT Sebastian Huber [531d160] * bsps/arm/beagle/clock/clock.c (moved) * bsps/arm/beagle/gpio/bbb-gpio.c (moved) * bsps/arm/beagle/pwm/pwm.c (moved) * bsps/arm/beagle/rtc/rtc.c (moved) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) bsp/beagle: Move source files to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:49:53 GMT Sebastian Huber [720ebc0] * bsps/arm/gumstix/fb/fb.c (moved) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) bsp/gumstix: Move fb.c to bsps This patch is a part of the BSP ... Wed, 25 Apr 2018 08:49:39 GMT Sebastian Huber [82bfda92] * bsps/arm/lm3s69xx/i2c/ssi.c (moved) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) bsp/lm3s69xx: Move ssi.c to bsps This patch is a part of the BSP ... Wed, 25 Apr 2018 08:43:38 GMT Sebastian Huber [e945b049] * bsps/arm/lpc176x/btimer/btimer.c (modified) * bsps/arm/lpc176x/can/can.c (moved) * bsps/arm/lpc176x/gpio/lpc-gpio.c (moved) * bsps/arm/lpc176x/pwm/pwmout.c (moved) * bsps/arm/lpc176x/start/adc.c (moved) * bsps/arm/lpc176x/start/bspidle.c (moved) * bsps/arm/lpc176x/start/dma-copy.c (moved) * bsps/arm/lpc176x/start/dma.c (moved) * bsps/arm/lpc176x/start/io.c (moved) * bsps/arm/lpc176x/start/restart.c (moved) * bsps/arm/lpc176x/start/system-clocks.c (moved) * bsps/arm/lpc176x/start/watchdog.c (moved) * bsps/arm/lpc176x/timer/timer.c (added) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (deleted) bsp/lpc176x: Move source files to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:40:40 GMT Sebastian Huber [74df15c] * bsps/arm/lpc24xx/fb/lcd.c (moved) * bsps/arm/lpc24xx/spi/ssp.c (moved) * bsps/arm/lpc24xx/start/bspidle.c (moved) * bsps/arm/lpc24xx/start/dma-copy.c (moved) * bsps/arm/lpc24xx/start/dma.c (moved) * bsps/arm/lpc24xx/start/io.c (moved) * bsps/arm/lpc24xx/start/restart.c (moved) * bsps/arm/lpc24xx/start/system-clocks.c (moved) * bsps/arm/lpc24xx/start/timer.c (moved) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) bsp/lpc24xx: Move source files to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:36:52 GMT Sebastian Huber [43250167] * bsps/arm/lpc32xx/nand/nand-mlc-erase-block-safe.c (moved) * bsps/arm/lpc32xx/nand/nand-mlc-read-blocks.c (moved) * bsps/arm/lpc32xx/nand/nand-mlc-write-blocks.c (moved) * bsps/arm/lpc32xx/nand/nand-mlc.c (moved) * bsps/arm/lpc32xx/nand/nand-select.c (moved) * bsps/arm/lpc32xx/start/boot.c (moved) * bsps/arm/lpc32xx/start/bspidle.c (moved) * bsps/arm/lpc32xx/start/emc.c (moved) * bsps/arm/lpc32xx/start/restart.c (moved) * bsps/arm/lpc32xx/start/system-clocks.c (moved) * bsps/arm/lpc32xx/start/timer.c (moved) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) bsp/lpc32xx: Move source files to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:36:01 GMT Sebastian Huber [fc1bdb83] * bsps/arm/raspberrypi/gpio/gpio-interfaces-pi1-rev2.c (moved) * bsps/arm/raspberrypi/gpio/rpi-gpio.c (moved) * bsps/arm/raspberrypi/start/mailbox.c (moved) * bsps/arm/raspberrypi/start/timer.c (moved) * bsps/arm/raspberrypi/start/vc.c (moved) * bsps/arm/raspberrypi/start/vc_defines.h (moved) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsp/raspberrypi: Move source files to bsps This patch is a part of ... Wed, 25 Apr 2018 08:34:09 GMT Sebastian Huber [ede0eb3] * bsps/arm/smdk2410/smc/smc.c (moved) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) bsp/smdk2410: Move smc.c to bsps This patch is a part of the BSP ... Wed, 25 Apr 2018 08:33:35 GMT Sebastian Huber [4183b711] * bsps/arm/tms570/cpucounter/cpucounterread.c (moved) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) bsp/tms570: Move cpucounterread.c to bsps This patch is a part of ... Wed, 25 Apr 2018 08:32:28 GMT Sebastian Huber [a79d650] * bsps/m68k/mcf5206elite/nvram/nvram.c (moved) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) bsp/mcf5206elite: Move nvram.c to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:32:09 GMT Sebastian Huber [0e15ba3] * bsps/m68k/mrm332/start/interr.c (moved) bsp/mrm332: Move interr.c to bsps This patch is a part of the BSP ... Wed, 25 Apr 2018 08:31:53 GMT Sebastian Huber [100c9723] * bsps/m68k/mrm332/start/spinit.c (moved) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) bsp/mrm332: Move spinit.c to bsps This patch is a part of the BSP ... Wed, 25 Apr 2018 08:26:24 GMT Sebastian Huber [64d4fc7] * bsps/powerpc/gen5200/mscan/mscan-base.c (moved) * bsps/powerpc/gen5200/mscan/mscan.c (moved) * bsps/powerpc/gen5200/mscan/mscan_int.h (moved) * bsps/powerpc/gen5200/nvram/m93cxx.h (moved) * bsps/powerpc/gen5200/nvram/nvram.c (moved) * bsps/powerpc/gen5200/slicetimer/slicetimer.c (moved) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) bsp/gen5200: Move source files to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:26:05 GMT Sebastian Huber [95d5426c] * bsps/powerpc/haleakala/start/mmu_405.c (moved) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) bsp/haleakala: Move mmu_405.c to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:25:00 GMT Sebastian Huber [8266fb53] * bsps/powerpc/beatnik/flash/flashcfg.c (moved) * bsps/powerpc/beatnik/marvell/discovery.c (moved) * bsps/powerpc/beatnik/marvell/gt.c (moved) * bsps/powerpc/beatnik/marvell/gt_timer.c (moved) * bsps/powerpc/beatnik/marvell/gti2c.c (moved) * bsps/powerpc/beatnik/vme/vme_dma.c (moved) * bsps/powerpc/beatnik/vme/vmeconfig.c (moved) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) bsp/beatnik: Move source files to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:24:49 GMT Sebastian Huber [bf16ee5] * bsps/powerpc/mvme3100/flash/flashcfg.c (moved) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) bsp/mvme3100: Move flashcfg.c to bsps This patch is a part of the ... Wed, 25 Apr 2018 08:22:37 GMT Sebastian Huber [8f12ee32] * bsps/powerpc/mvme5500/GT64260/GT64260TWSI.c (moved) * bsps/powerpc/mvme5500/GT64260/MVME5500I2C.c (moved) * bsps/powerpc/mvme5500/start/exceptionhandler.c (moved) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) bsp/mvme5500: Move source files to bsps This patch is a part of the ...
