# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 08:10:50 Mon, 12 Jun 2000 16:37:04 GMT Joel Sherrill [1bce637] * c/src/exec/include/rtems/bspIo.h (added) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/printk.c (added) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/bspIo.h (added) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/printk.c (added) * cpukit/include/rtems/bspIo.h (added) * cpukit/libcsupport/src/printk.c (added) Added printk as a generic, shared routine. Mon, 12 Jun 2000 16:36:25 GMT Joel Sherrill [1f5cb74] * c/src/lib/libbsp/shared/console-polled.c (added) New file. This is a simple termios console driver which is ... Mon, 12 Jun 2000 16:34:46 GMT Joel Sherrill [68c498f4] * c/src/lib/libbsp/i960/i960sim/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/bsp_specs (added) * c/src/lib/libbsp/i960/i960sim/configure.in (added) * c/src/lib/libbsp/i960/i960sim/console/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/console/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/console/console-io.c (added) * c/src/lib/libbsp/i960/i960sim/console/mon-syscalls.S (added) * c/src/lib/libbsp/i960/i960sim/include/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/include/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/include/bsp.h (added) * c/src/lib/libbsp/i960/i960sim/start/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/start/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/start/start.c (added) * c/src/lib/libbsp/i960/i960sim/startup/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/startup/bspstart.c (added) * c/src/lib/libbsp/i960/i960sim/startup/linkcmds (added) * c/src/lib/libbsp/i960/i960sim/wrapup/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/wrapup/Makefile.am (added) * make/custom/i960sim.cfg (added) Added i960sim BSP which (ignoring the 3 instructions not supported ... Mon, 12 Jun 2000 15:39:38 GMT Joel Sherrill [edeed26] * c/src/libnetworking/pppd/modem_example/modem.c (modified) Merge lossage. Apparently the DOS/UNIX CRLF issue got lost. Mon, 12 Jun 2000 15:00:15 GMT Joel Sherrill [df49c60] * Makefile.am (modified) * VERSION (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/target.m4 (modified) * automake/host.am (added) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/libcsupport/src/termiosreserveresources.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/memory.h (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/if_loop.c (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/sys/un.h (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/README_RTEMS (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpc/auth.h (modified) * c/src/exec/librpc/include/rpc/auth_des.h (modified) * c/src/exec/librpc/include/rpc/auth_unix.h (modified) * c/src/exec/librpc/include/rpc/clnt.h (modified) * c/src/exec/librpc/include/rpc/des.h (modified) * c/src/exec/librpc/include/rpc/des_crypt.h (modified) * c/src/exec/librpc/include/rpc/pmap_clnt.h (modified) * c/src/exec/librpc/include/rpc/pmap_prot.h (modified) * c/src/exec/librpc/include/rpc/pmap_rmt.h (modified) * c/src/exec/librpc/include/rpc/rpc.h (modified) * c/src/exec/librpc/include/rpc/rpc_com.h (modified) * c/src/exec/librpc/include/rpc/rpc_msg.h (modified) * c/src/exec/librpc/include/rpc/svc.h (modified) * c/src/exec/librpc/include/rpc/svc_auth.h (modified) * c/src/exec/librpc/include/rpc/types.h (modified) * c/src/exec/librpc/include/rpc/xdr.h (modified) * c/src/exec/librpc/include/rpcsvc/.cvsignore (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/crypt.x (modified) * c/src/exec/librpc/include/rpcsvc/key_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/mount.x (modified) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/nis.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_db.h (modified) * c/src/exec/librpc/include/rpcsvc/nis_object.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/exec/librpc/include/rpcsvc/nislib.h (modified) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/rex.x (modified) * c/src/exec/librpc/include/rpcsvc/rnusers.x (modified) * c/src/exec/librpc/include/rpcsvc/rquota.x (modified) * c/src/exec/librpc/include/rpcsvc/rstat.x (modified) * c/src/exec/librpc/include/rpcsvc/rwall.x (modified) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/exec/librpc/include/rpcsvc/spray.x (modified) * c/src/exec/librpc/include/rpcsvc/yp.x (modified) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/DISCLAIMER (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/exec/librpc/src/rpc/README (modified) * c/src/exec/librpc/src/rpc/auth_des.c (modified) * c/src/exec/librpc/src/rpc/auth_none.c (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/auth_unix.c (modified) * c/src/exec/librpc/src/rpc/authdes_prot.c (modified) * c/src/exec/librpc/src/rpc/authunix_prot.c (modified) * c/src/exec/librpc/src/rpc/bindresvport.3 (modified) * c/src/exec/librpc/src/rpc/bindresvport.c (modified) * c/src/exec/librpc/src/rpc/clnt_generic.c (modified) * c/src/exec/librpc/src/rpc/clnt_perror.c (modified) * c/src/exec/librpc/src/rpc/clnt_raw.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/crypt_client.c (modified) * c/src/exec/librpc/src/rpc/des_crypt.3 (modified) * c/src/exec/librpc/src/rpc/des_crypt.c (modified) * c/src/exec/librpc/src/rpc/des_soft.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/getpublickey.c (modified) * c/src/exec/librpc/src/rpc/getrpcent.3 (modified) * c/src/exec/librpc/src/rpc/getrpcent.c (modified) * c/src/exec/librpc/src/rpc/getrpcport.3 (modified) * c/src/exec/librpc/src/rpc/getrpcport.c (modified) * c/src/exec/librpc/src/rpc/key_call.c (modified) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/exec/librpc/src/rpc/netname.c (modified) * c/src/exec/librpc/src/rpc/netnamer.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot2.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/publickey.3 (modified) * c/src/exec/librpc/src/rpc/publickey.5 (modified) * c/src/exec/librpc/src/rpc/rpc.3 (modified) * c/src/exec/librpc/src/rpc/rpc.5 (modified) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/exec/librpc/src/rpc/rpc_commondata.c (modified) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/exec/librpc/src/rpc/rpc_prot.c (modified) * c/src/exec/librpc/src/rpc/rpc_secure.3 (modified) * c/src/exec/librpc/src/rpc/rpcdname.c (modified) * c/src/exec/librpc/src/rpc/rstat.1 (modified) * c/src/exec/librpc/src/rpc/rstat_svc.8 (modified) * c/src/exec/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/exec/librpc/src/rpc/rtems_rpc.c (modified) * c/src/exec/librpc/src/rpc/rtime.3 (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc.c (modified) * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_des.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/exec/librpc/src/rpc/svc_raw.c (modified) * c/src/exec/librpc/src/rpc/svc_run.c (modified) * c/src/exec/librpc/src/rpc/svc_simple.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/exec/librpc/src/xdr/xdr.3 (modified) * c/src/exec/librpc/src/xdr/xdr.c (modified) * c/src/exec/librpc/src/xdr/xdr_array.c (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/exec/librpc/src/xdr/xdr_mem.c (modified) * c/src/exec/librpc/src/xdr/xdr_rec.c (modified) * c/src/exec/librpc/src/xdr/xdr_reference.c (modified) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/exec/librpc/src/xdr/xdr_stdio.c (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/pthread.h (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskvariableget.c (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/include/rtems/README (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/README (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/dotests (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libc/termiosreserveresources.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/memory.h (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/if_loop.c (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/netinet/in.h (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/balloc.c (modified) * c/src/libnetworking/rtems_webserver/ejlex.c (modified) * c/src/libnetworking/rtems_webserver/handler.c (modified) * c/src/libnetworking/rtems_webserver/uemf.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/un.h (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/README_RTEMS (modified) * c/src/librpc/configure.in (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpc/auth.h (modified) * c/src/librpc/include/rpc/auth_des.h (modified) * c/src/librpc/include/rpc/auth_unix.h (modified) * c/src/librpc/include/rpc/clnt.h (modified) * c/src/librpc/include/rpc/des.h (modified) * c/src/librpc/include/rpc/des_crypt.h (modified) * c/src/librpc/include/rpc/pmap_clnt.h (modified) * c/src/librpc/include/rpc/pmap_prot.h (modified) * c/src/librpc/include/rpc/pmap_rmt.h (modified) * c/src/librpc/include/rpc/rpc.h (modified) * c/src/librpc/include/rpc/rpc_com.h (modified) * c/src/librpc/include/rpc/rpc_msg.h (modified) * c/src/librpc/include/rpc/svc.h (modified) * c/src/librpc/include/rpc/svc_auth.h (modified) * c/src/librpc/include/rpc/types.h (modified) * c/src/librpc/include/rpc/xdr.h (modified) * c/src/librpc/include/rpcsvc/.cvsignore (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/librpc/include/rpcsvc/crypt.x (modified) * c/src/librpc/include/rpcsvc/key_prot.x (modified) * c/src/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/librpc/include/rpcsvc/mount.x (modified) * c/src/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/librpc/include/rpcsvc/nis.x (modified) * c/src/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/librpc/include/rpcsvc/nis_db.h (modified) * c/src/librpc/include/rpcsvc/nis_object.x (modified) * c/src/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/librpc/include/rpcsvc/nislib.h (modified) * c/src/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/librpc/include/rpcsvc/rex.x (modified) * c/src/librpc/include/rpcsvc/rnusers.x (modified) * c/src/librpc/include/rpcsvc/rquota.x (modified) * c/src/librpc/include/rpcsvc/rstat.x (modified) * c/src/librpc/include/rpcsvc/rwall.x (modified) * c/src/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/librpc/include/rpcsvc/spray.x (modified) * c/src/librpc/include/rpcsvc/yp.x (modified) * c/src/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/DISCLAIMER (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/librpc/src/rpc/README (modified) * c/src/librpc/src/rpc/auth_des.c (modified) * c/src/librpc/src/rpc/auth_none.c (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/auth_unix.c (modified) * c/src/librpc/src/rpc/authdes_prot.c (modified) * c/src/librpc/src/rpc/authunix_prot.c (modified) * c/src/librpc/src/rpc/bindresvport.3 (modified) * c/src/librpc/src/rpc/bindresvport.c (modified) * c/src/librpc/src/rpc/clnt_generic.c (modified) * c/src/librpc/src/rpc/clnt_perror.c (modified) * c/src/librpc/src/rpc/clnt_raw.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/crypt_client.c (modified) * c/src/librpc/src/rpc/des_crypt.3 (modified) * c/src/librpc/src/rpc/des_crypt.c (modified) * c/src/librpc/src/rpc/des_soft.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/getpublickey.c (modified) * c/src/librpc/src/rpc/getrpcent.3 (modified) * c/src/librpc/src/rpc/getrpcent.c (modified) * c/src/librpc/src/rpc/getrpcport.3 (modified) * c/src/librpc/src/rpc/getrpcport.c (modified) * c/src/librpc/src/rpc/key_call.c (modified) * c/src/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/librpc/src/rpc/netname.c (modified) * c/src/librpc/src/rpc/netnamer.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_prot.c (modified) * c/src/librpc/src/rpc/pmap_prot2.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/publickey.3 (modified) * c/src/librpc/src/rpc/publickey.5 (modified) * c/src/librpc/src/rpc/rpc.3 (modified) * c/src/librpc/src/rpc/rpc.5 (modified) * c/src/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/librpc/src/rpc/rpc_commondata.c (modified) * c/src/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/librpc/src/rpc/rpc_prot.c (modified) * c/src/librpc/src/rpc/rpc_secure.3 (modified) * c/src/librpc/src/rpc/rpcdname.c (modified) * c/src/librpc/src/rpc/rstat.1 (modified) * c/src/librpc/src/rpc/rstat_svc.8 (modified) * c/src/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/librpc/src/rpc/rtems_rpc.c (modified) * c/src/librpc/src/rpc/rtime.3 (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth_des.c (modified) * c/src/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/librpc/src/rpc/svc_raw.c (modified) * c/src/librpc/src/rpc/svc_run.c (modified) * c/src/librpc/src/rpc/svc_simple.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/src/rpc_callmsg.c (deleted) * c/src/librpc/src/rpc_prot.c (deleted) * c/src/librpc/src/svc.c (deleted) * c/src/librpc/src/svc_auth.c (deleted) * c/src/librpc/src/svc_udp.c (deleted) * c/src/librpc/src/xdr.c (deleted) * c/src/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/src/xdr/xdr.3 (modified) * c/src/librpc/src/xdr/xdr.c (modified) * c/src/librpc/src/xdr/xdr_array.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_mem.c (modified) * c/src/librpc/src/xdr/xdr_rec.c (modified) * c/src/librpc/src/xdr/xdr_reference.c (modified) * c/src/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/librpc/src/xdr/xdr_stdio.c (modified) * c/src/librpc/src/xdr_array.c (deleted) * c/src/librpc/src/xdr_mem.c (deleted) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/sapi/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/itronmbox01.scn (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/itrontime01.scn (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/cpuuse/cpuuse.scn (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/malloctest/malloctest.scn (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmount/main.c (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/main.c (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/system.h (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/samples/unlimited/init.c (modified) * c/src/tests/samples/unlimited/system.h (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp27/init.c (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/sp29/init.c (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/system.h (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.in (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/webs.c (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/memory.h (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/README_RTEMS (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/des.h (modified) * cpukit/librpc/include/rpc/des_crypt.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/.cvsignore (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (modified) * cpukit/librpc/include/rpcsvc/crypt.x (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/klm_prot.x (modified) * cpukit/librpc/include/rpcsvc/mount.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nis.x (modified) * cpukit/librpc/include/rpcsvc/nis_cache.x (modified) * cpukit/librpc/include/rpcsvc/nis_callback.x (modified) * cpukit/librpc/include/rpcsvc/nis_db.h (modified) * cpukit/librpc/include/rpcsvc/nis_object.x (modified) * cpukit/librpc/include/rpcsvc/nis_tags.h (modified) * cpukit/librpc/include/rpcsvc/nislib.h (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rex.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) * cpukit/librpc/include/rpcsvc/rquota.x (modified) * cpukit/librpc/include/rpcsvc/rstat.x (modified) * cpukit/librpc/include/rpcsvc/rwall.x (modified) * cpukit/librpc/include/rpcsvc/sm_inter.x (modified) * cpukit/librpc/include/rpcsvc/spray.x (modified) * cpukit/librpc/include/rpcsvc/yp.x (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (modified) * cpukit/librpc/include/rpcsvc/ypxfrd.x (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/DISCLAIMER (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * cpukit/librpc/src/rpc/README (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authdes_prot.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.3 (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/crypt_client.c (modified) * cpukit/librpc/src/rpc/des_crypt.3 (modified) * cpukit/librpc/src/rpc/des_crypt.c (modified) * cpukit/librpc/src/rpc/des_soft.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getpublickey.c (modified) * cpukit/librpc/src/rpc/getrpcent.3 (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.3 (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/key_call.c (modified) * cpukit/librpc/src/rpc/key_prot_xdr.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/publickey.3 (modified) * cpukit/librpc/src/rpc/publickey.5 (modified) * cpukit/librpc/src/rpc/rpc.3 (modified) * cpukit/librpc/src/rpc/rpc.5 (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpc_secure.3 (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rstat.1 (modified) * cpukit/librpc/src/rpc/rstat_svc.8 (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.3 (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/src/xdr/xdr.3 (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/objectcopynamestring.c (modified) * make/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Makefile.am (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/.cvsignore (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/.cvsignore (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/.cvsignore (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkbinutilspec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup.def (modified) * scripts/Makefile.am (modified) * scripts/binutils/.cvsignore (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/.cvsignore (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/.cvsignore (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/.cvsignore (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/itronmbox01.scn (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/itrontests/itrontime01/itrontime01.scn (modified) * testsuites/itrontests/itrontime01/system.h (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/cpuuse.scn (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/psxtests/psxtimer/system.h (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/system.h (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/gensize.c (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) * tools/update/rtems-polish.sh (modified) Merged from 4.5.0-beta3a Wed, 24 May 2000 16:51:23 GMT Joel Sherrill [fea048f] * c/src/tests/libtests/malloctest/malloctest.scn (added) * testsuites/libtests/malloctest/malloctest.scn (added) New file. Mon, 08 May 2000 21:17:50 GMT Joel Sherrill [b27c15f] * c/src/exec/libcsupport/src/gxx_wrappers.c (added) * c/src/lib/libc/gxx_wrappers.c (added) * cpukit/libcsupport/src/gxx_wrappers.c (added) New file added on 4.5 branch Mon, 08 May 2000 20:36:59 GMT Joel Sherrill [3f2f553] * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (added) New file added on 4.5 branch Wed, 03 May 2000 13:55:42 GMT Joel Sherrill [31aa66a8] * c/src/exec/librpc/src/rpc/rtems_portmapper.c (added) * c/src/exec/librpc/src/rpc/rtems_rpc.c (added) * c/src/librpc/src/rpc/rtems_portmapper.c (added) * c/src/librpc/src/rpc/rtems_rpc.c (added) * cpukit/librpc/src/rpc/rtems_portmapper.c (added) * cpukit/librpc/src/rpc/rtems_rpc.c (added) Added on 4.5 branch. Mon, 01 May 2000 14:57:46 GMT Joel Sherrill [f3c096a] * c/src/exec/librpc/include/rpcsvc/.cvsignore (added) * c/src/exec/librpc/include/rpcsvc/Makefile.am (added) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (added) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (added) * c/src/librpc/include/rpcsvc/.cvsignore (added) * c/src/librpc/include/rpcsvc/Makefile.am (added) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (added) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (added) * cpukit/librpc/include/rpcsvc/.cvsignore (added) * cpukit/librpc/include/rpcsvc/Makefile.am (added) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (added) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (added) Added on 4.5-branch Sat, 29 Apr 2000 19:41:47 GMT Joel Sherrill [84a90acf] * c/src/exec/librpc/src/rpc/.cvsignore (added) * c/src/exec/librpc/src/xdr/.cvsignore (added) * c/src/librpc/src/rpc/.cvsignore (added) * c/src/librpc/src/xdr/.cvsignore (added) * cpukit/librpc/src/rpc/.cvsignore (added) * cpukit/librpc/src/xdr/.cvsignore (added) New files. Sat, 29 Apr 2000 19:13:19 GMT Joel Sherrill [87ec19a3] * c/src/exec/librpc/README_RTEMS (added) * c/src/exec/librpc/include/rpcsvc/rex.x (added) * c/src/exec/librpc/include/rpcsvc/rnusers.x (added) * c/src/exec/librpc/include/rpcsvc/rquota.x (added) * c/src/exec/librpc/include/rpcsvc/rstat.x (added) * c/src/exec/librpc/include/rpcsvc/rwall.x (added) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (added) * c/src/exec/librpc/include/rpcsvc/spray.x (added) * c/src/exec/librpc/include/rpcsvc/yp.x (added) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (added) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (added) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (added) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (added) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (added) * c/src/librpc/README_RTEMS (added) * c/src/librpc/include/rpcsvc/rex.x (added) * c/src/librpc/include/rpcsvc/rnusers.x (added) * c/src/librpc/include/rpcsvc/rquota.x (added) * c/src/librpc/include/rpcsvc/rstat.x (added) * c/src/librpc/include/rpcsvc/rwall.x (added) * c/src/librpc/include/rpcsvc/sm_inter.x (added) * c/src/librpc/include/rpcsvc/spray.x (added) * c/src/librpc/include/rpcsvc/yp.x (added) * c/src/librpc/include/rpcsvc/yp_prot.h (added) * c/src/librpc/include/rpcsvc/ypclnt.h (added) * c/src/librpc/include/rpcsvc/yppasswd.x (added) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (added) * c/src/librpc/include/rpcsvc/ypxfrd.x (added) * cpukit/librpc/README_RTEMS (added) * cpukit/librpc/include/rpcsvc/rex.x (added) * cpukit/librpc/include/rpcsvc/rnusers.x (added) * cpukit/librpc/include/rpcsvc/rquota.x (added) * cpukit/librpc/include/rpcsvc/rstat.x (added) * cpukit/librpc/include/rpcsvc/rwall.x (added) * cpukit/librpc/include/rpcsvc/sm_inter.x (added) * cpukit/librpc/include/rpcsvc/spray.x (added) * cpukit/librpc/include/rpcsvc/yp.x (added) * cpukit/librpc/include/rpcsvc/yp_prot.h (added) * cpukit/librpc/include/rpcsvc/ypclnt.h (added) * cpukit/librpc/include/rpcsvc/yppasswd.x (added) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (added) * cpukit/librpc/include/rpcsvc/ypxfrd.x (added) New files added as part of librpc upgrade. Sat, 29 Apr 2000 19:04:37 GMT Joel Sherrill [5ad350a4] * c/src/exec/librpc/src/rpc/DISCLAIMER (added) * c/src/exec/librpc/src/rpc/Makefile.am (added) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (added) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (added) * c/src/exec/librpc/src/rpc/README (added) * c/src/exec/librpc/src/rpc/auth_des.c (added) * c/src/exec/librpc/src/rpc/auth_none.c (added) * c/src/exec/librpc/src/rpc/auth_time.c (added) * c/src/exec/librpc/src/rpc/auth_unix.c (added) * c/src/exec/librpc/src/rpc/authdes_prot.c (added) * c/src/exec/librpc/src/rpc/authunix_prot.c (added) * c/src/exec/librpc/src/rpc/bindresvport.3 (added) * c/src/exec/librpc/src/rpc/bindresvport.c (added) * c/src/exec/librpc/src/rpc/clnt_generic.c (added) * c/src/exec/librpc/src/rpc/clnt_perror.c (added) * c/src/exec/librpc/src/rpc/clnt_raw.c (added) * c/src/exec/librpc/src/rpc/clnt_simple.c (added) * c/src/exec/librpc/src/rpc/clnt_tcp.c (added) * c/src/exec/librpc/src/rpc/clnt_udp.c (added) * c/src/exec/librpc/src/rpc/clnt_unix.c (added) * c/src/exec/librpc/src/rpc/crypt_client.c (added) * c/src/exec/librpc/src/rpc/des_crypt.3 (added) * c/src/exec/librpc/src/rpc/des_crypt.c (added) * c/src/exec/librpc/src/rpc/des_soft.c (added) * c/src/exec/librpc/src/rpc/get_myaddress.c (added) * c/src/exec/librpc/src/rpc/getpublickey.c (added) * c/src/exec/librpc/src/rpc/getrpcent.3 (added) * c/src/exec/librpc/src/rpc/getrpcent.c (added) * c/src/exec/librpc/src/rpc/getrpcport.3 (added) * c/src/exec/librpc/src/rpc/getrpcport.c (added) * c/src/exec/librpc/src/rpc/key_call.c (added) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (added) * c/src/exec/librpc/src/rpc/netname.c (added) * c/src/exec/librpc/src/rpc/netnamer.c (added) * c/src/exec/librpc/src/rpc/pmap_clnt.c (added) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (added) * c/src/exec/librpc/src/rpc/pmap_getport.c (added) * c/src/exec/librpc/src/rpc/pmap_prot.c (added) * c/src/exec/librpc/src/rpc/pmap_prot2.c (added) * c/src/exec/librpc/src/rpc/pmap_rmt.c (added) * c/src/exec/librpc/src/rpc/publickey.3 (added) * c/src/exec/librpc/src/rpc/publickey.5 (added) * c/src/exec/librpc/src/rpc/rpc.3 (added) * c/src/exec/librpc/src/rpc/rpc.5 (added) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (added) * c/src/exec/librpc/src/rpc/rpc_commondata.c (added) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (added) * c/src/exec/librpc/src/rpc/rpc_prot.c (added) * c/src/exec/librpc/src/rpc/rpc_secure.3 (added) * c/src/exec/librpc/src/rpc/rpcdname.c (added) * c/src/exec/librpc/src/rpc/rstat.1 (added) * c/src/exec/librpc/src/rpc/rstat_svc.8 (added) * c/src/exec/librpc/src/rpc/rtime.3 (added) * c/src/exec/librpc/src/rpc/rtime.c (added) * c/src/exec/librpc/src/rpc/svc.c (added) * c/src/exec/librpc/src/rpc/svc_auth.c (added) * c/src/exec/librpc/src/rpc/svc_auth_des.c (added) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (added) * c/src/exec/librpc/src/rpc/svc_raw.c (added) * c/src/exec/librpc/src/rpc/svc_run.c (added) * c/src/exec/librpc/src/rpc/svc_simple.c (added) * c/src/exec/librpc/src/rpc/svc_tcp.c (added) * c/src/exec/librpc/src/rpc/svc_udp.c (added) * c/src/exec/librpc/src/rpc/svc_unix.c (added) * c/src/exec/librpc/src/xdr/Makefile.am (added) * c/src/exec/librpc/src/xdr/xdr.3 (added) * c/src/exec/librpc/src/xdr/xdr.c (added) * c/src/exec/librpc/src/xdr/xdr_array.c (added) * c/src/exec/librpc/src/xdr/xdr_float.c (added) * c/src/exec/librpc/src/xdr/xdr_mem.c (added) * c/src/exec/librpc/src/xdr/xdr_rec.c (added) * c/src/exec/librpc/src/xdr/xdr_reference.c (added) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (added) * c/src/exec/librpc/src/xdr/xdr_stdio.c (added) * c/src/librpc/src/rpc/DISCLAIMER (added) * c/src/librpc/src/rpc/Makefile.am (added) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (added) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (added) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (added) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (added) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (added) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (added) * c/src/librpc/src/rpc/README (added) * c/src/librpc/src/rpc/auth_des.c (added) * c/src/librpc/src/rpc/auth_none.c (added) * c/src/librpc/src/rpc/auth_time.c (added) * c/src/librpc/src/rpc/auth_unix.c (added) * c/src/librpc/src/rpc/authdes_prot.c (added) * c/src/librpc/src/rpc/authunix_prot.c (added) * c/src/librpc/src/rpc/bindresvport.3 (added) * c/src/librpc/src/rpc/bindresvport.c (added) * c/src/librpc/src/rpc/clnt_generic.c (added) * c/src/librpc/src/rpc/clnt_perror.c (added) * c/src/librpc/src/rpc/clnt_raw.c (added) * c/src/librpc/src/rpc/clnt_simple.c (added) * c/src/librpc/src/rpc/clnt_tcp.c (added) * c/src/librpc/src/rpc/clnt_udp.c (added) * c/src/librpc/src/rpc/clnt_unix.c (added) * c/src/librpc/src/rpc/crypt_client.c (added) * c/src/librpc/src/rpc/des_crypt.3 (added) * c/src/librpc/src/rpc/des_crypt.c (added) * c/src/librpc/src/rpc/des_soft.c (added) * c/src/librpc/src/rpc/get_myaddress.c (added) * c/src/librpc/src/rpc/getpublickey.c (added) * c/src/librpc/src/rpc/getrpcent.3 (added) * c/src/librpc/src/rpc/getrpcent.c (added) * c/src/librpc/src/rpc/getrpcport.3 (added) * c/src/librpc/src/rpc/getrpcport.c (added) * c/src/librpc/src/rpc/key_call.c (added) * c/src/librpc/src/rpc/key_prot_xdr.c (added) * c/src/librpc/src/rpc/netname.c (added) * c/src/librpc/src/rpc/netnamer.c (added) * c/src/librpc/src/rpc/pmap_clnt.c (added) * c/src/librpc/src/rpc/pmap_getmaps.c (added) * c/src/librpc/src/rpc/pmap_getport.c (added) * c/src/librpc/src/rpc/pmap_prot.c (added) * c/src/librpc/src/rpc/pmap_prot2.c (added) * c/src/librpc/src/rpc/pmap_rmt.c (added) * c/src/librpc/src/rpc/publickey.3 (added) * c/src/librpc/src/rpc/publickey.5 (added) * c/src/librpc/src/rpc/rpc.3 (added) * c/src/librpc/src/rpc/rpc.5 (added) * c/src/librpc/src/rpc/rpc_callmsg.c (added) * c/src/librpc/src/rpc/rpc_commondata.c (added) * c/src/librpc/src/rpc/rpc_dtablesize.c (added) * c/src/librpc/src/rpc/rpc_prot.c (added) * c/src/librpc/src/rpc/rpc_secure.3 (added) * c/src/librpc/src/rpc/rpcdname.c (added) * c/src/librpc/src/rpc/rstat.1 (added) * c/src/librpc/src/rpc/rstat_svc.8 (added) * c/src/librpc/src/rpc/rtime.3 (added) * c/src/librpc/src/rpc/rtime.c (added) * c/src/librpc/src/rpc/svc.c (added) * c/src/librpc/src/rpc/svc_auth.c (added) * c/src/librpc/src/rpc/svc_auth_des.c (added) * c/src/librpc/src/rpc/svc_auth_unix.c (added) * c/src/librpc/src/rpc/svc_raw.c (added) * c/src/librpc/src/rpc/svc_run.c (added) * c/src/librpc/src/rpc/svc_simple.c (added) * c/src/librpc/src/rpc/svc_tcp.c (added) * c/src/librpc/src/rpc/svc_udp.c (added) * c/src/librpc/src/rpc/svc_unix.c (added) * c/src/librpc/src/xdr/Makefile.am (added) * c/src/librpc/src/xdr/xdr.3 (added) * c/src/librpc/src/xdr/xdr.c (added) * c/src/librpc/src/xdr/xdr_array.c (added) * c/src/librpc/src/xdr/xdr_float.c (added) * c/src/librpc/src/xdr/xdr_mem.c (added) * c/src/librpc/src/xdr/xdr_rec.c (added) * c/src/librpc/src/xdr/xdr_reference.c (added) * c/src/librpc/src/xdr/xdr_sizeof.c (added) * c/src/librpc/src/xdr/xdr_stdio.c (added) * cpukit/librpc/src/rpc/DISCLAIMER (added) * cpukit/librpc/src/rpc/Makefile.am (added) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (added) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (added) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (added) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (added) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (added) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (added) * cpukit/librpc/src/rpc/README (added) * cpukit/librpc/src/rpc/auth_des.c (added) * cpukit/librpc/src/rpc/auth_none.c (added) * cpukit/librpc/src/rpc/auth_time.c (added) * cpukit/librpc/src/rpc/auth_unix.c (added) * cpukit/librpc/src/rpc/authdes_prot.c (added) * cpukit/librpc/src/rpc/authunix_prot.c (added) * cpukit/librpc/src/rpc/bindresvport.3 (added) * cpukit/librpc/src/rpc/bindresvport.c (added) * cpukit/librpc/src/rpc/clnt_generic.c (added) * cpukit/librpc/src/rpc/clnt_perror.c (added) * cpukit/librpc/src/rpc/clnt_raw.c (added) * cpukit/librpc/src/rpc/clnt_simple.c (added) * cpukit/librpc/src/rpc/clnt_tcp.c (added) * cpukit/librpc/src/rpc/clnt_udp.c (added) * cpukit/librpc/src/rpc/clnt_unix.c (added) * cpukit/librpc/src/rpc/crypt_client.c (added) * cpukit/librpc/src/rpc/des_crypt.3 (added) * cpukit/librpc/src/rpc/des_crypt.c (added) * cpukit/librpc/src/rpc/des_soft.c (added) * cpukit/librpc/src/rpc/get_myaddress.c (added) * cpukit/librpc/src/rpc/getpublickey.c (added) * cpukit/librpc/src/rpc/getrpcent.3 (added) * cpukit/librpc/src/rpc/getrpcent.c (added) * cpukit/librpc/src/rpc/getrpcport.3 (added) * cpukit/librpc/src/rpc/getrpcport.c (added) * cpukit/librpc/src/rpc/key_call.c (added) * cpukit/librpc/src/rpc/key_prot_xdr.c (added) * cpukit/librpc/src/rpc/netname.c (added) * cpukit/librpc/src/rpc/netnamer.c (added) * cpukit/librpc/src/rpc/pmap_clnt.c (added) * cpukit/librpc/src/rpc/pmap_getmaps.c (added) * cpukit/librpc/src/rpc/pmap_getport.c (added) * cpukit/librpc/src/rpc/pmap_prot.c (added) * cpukit/librpc/src/rpc/pmap_prot2.c (added) * cpukit/librpc/src/rpc/pmap_rmt.c (added) * cpukit/librpc/src/rpc/publickey.3 (added) * cpukit/librpc/src/rpc/publickey.5 (added) * cpukit/librpc/src/rpc/rpc.3 (added) * cpukit/librpc/src/rpc/rpc.5 (added) * cpukit/librpc/src/rpc/rpc_callmsg.c (added) * cpukit/librpc/src/rpc/rpc_commondata.c (added) * cpukit/librpc/src/rpc/rpc_dtablesize.c (added) * cpukit/librpc/src/rpc/rpc_prot.c (added) * cpukit/librpc/src/rpc/rpc_secure.3 (added) * cpukit/librpc/src/rpc/rpcdname.c (added) * cpukit/librpc/src/rpc/rstat.1 (added) * cpukit/librpc/src/rpc/rstat_svc.8 (added) * cpukit/librpc/src/rpc/rtime.3 (added) * cpukit/librpc/src/rpc/rtime.c (added) * cpukit/librpc/src/rpc/svc.c (added) * cpukit/librpc/src/rpc/svc_auth.c (added) * cpukit/librpc/src/rpc/svc_auth_des.c (added) * cpukit/librpc/src/rpc/svc_auth_unix.c (added) * cpukit/librpc/src/rpc/svc_raw.c (added) * cpukit/librpc/src/rpc/svc_run.c (added) * cpukit/librpc/src/rpc/svc_simple.c (added) * cpukit/librpc/src/rpc/svc_tcp.c (added) * cpukit/librpc/src/rpc/svc_udp.c (added) * cpukit/librpc/src/rpc/svc_unix.c (added) * cpukit/librpc/src/xdr/Makefile.am (added) * cpukit/librpc/src/xdr/xdr.3 (added) * cpukit/librpc/src/xdr/xdr.c (added) * cpukit/librpc/src/xdr/xdr_array.c (added) * cpukit/librpc/src/xdr/xdr_float.c (added) * cpukit/librpc/src/xdr/xdr_mem.c (added) * cpukit/librpc/src/xdr/xdr_rec.c (added) * cpukit/librpc/src/xdr/xdr_reference.c (added) * cpukit/librpc/src/xdr/xdr_sizeof.c (added) * cpukit/librpc/src/xdr/xdr_stdio.c (added) New files added as part of librpc upgrade. Sat, 29 Apr 2000 18:50:41 GMT Joel Sherrill [775e786] * c/src/exec/librpc/include/rpc/auth_des.h (added) * c/src/exec/librpc/include/rpc/auth_unix.h (added) * c/src/exec/librpc/include/rpc/des.h (added) * c/src/exec/librpc/include/rpc/des_crypt.h (added) * c/src/exec/librpc/include/rpc/pmap_clnt.h (added) * c/src/exec/librpc/include/rpc/pmap_prot.h (added) * c/src/exec/librpc/include/rpc/pmap_rmt.h (added) * c/src/exec/librpc/include/rpc/rpc_com.h (added) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (added) * c/src/exec/librpc/include/rpcsvc/crypt.x (added) * c/src/exec/librpc/include/rpcsvc/key_prot.x (added) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (added) * c/src/exec/librpc/include/rpcsvc/mount.x (added) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (added) * c/src/exec/librpc/include/rpcsvc/nis.x (added) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (added) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (added) * c/src/exec/librpc/include/rpcsvc/nis_db.h (added) * c/src/exec/librpc/include/rpcsvc/nis_object.x (added) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (added) * c/src/exec/librpc/include/rpcsvc/nislib.h (added) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (added) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (added) * c/src/librpc/include/rpc/auth_des.h (added) * c/src/librpc/include/rpc/auth_unix.h (added) * c/src/librpc/include/rpc/des.h (added) * c/src/librpc/include/rpc/des_crypt.h (added) * c/src/librpc/include/rpc/pmap_clnt.h (added) * c/src/librpc/include/rpc/pmap_prot.h (added) * c/src/librpc/include/rpc/pmap_rmt.h (added) * c/src/librpc/include/rpc/rpc_com.h (added) * c/src/librpc/include/rpcsvc/bootparam_prot.x (added) * c/src/librpc/include/rpcsvc/crypt.x (added) * c/src/librpc/include/rpcsvc/key_prot.x (added) * c/src/librpc/include/rpcsvc/klm_prot.x (added) * c/src/librpc/include/rpcsvc/mount.x (added) * c/src/librpc/include/rpcsvc/nfs_prot.x (added) * c/src/librpc/include/rpcsvc/nis.x (added) * c/src/librpc/include/rpcsvc/nis_cache.x (added) * c/src/librpc/include/rpcsvc/nis_callback.x (added) * c/src/librpc/include/rpcsvc/nis_db.h (added) * c/src/librpc/include/rpcsvc/nis_object.x (added) * c/src/librpc/include/rpcsvc/nis_tags.h (added) * c/src/librpc/include/rpcsvc/nislib.h (added) * c/src/librpc/include/rpcsvc/nlm_prot.x (added) * c/src/librpc/include/rpcsvc/pmap_prot.x (added) * cpukit/librpc/include/rpc/auth_des.h (added) * cpukit/librpc/include/rpc/auth_unix.h (added) * cpukit/librpc/include/rpc/des.h (added) * cpukit/librpc/include/rpc/des_crypt.h (added) * cpukit/librpc/include/rpc/pmap_clnt.h (added) * cpukit/librpc/include/rpc/pmap_prot.h (added) * cpukit/librpc/include/rpc/pmap_rmt.h (added) * cpukit/librpc/include/rpc/rpc_com.h (added) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (added) * cpukit/librpc/include/rpcsvc/crypt.x (added) * cpukit/librpc/include/rpcsvc/key_prot.x (added) * cpukit/librpc/include/rpcsvc/klm_prot.x (added) * cpukit/librpc/include/rpcsvc/mount.x (added) * cpukit/librpc/include/rpcsvc/nfs_prot.x (added) * cpukit/librpc/include/rpcsvc/nis.x (added) * cpukit/librpc/include/rpcsvc/nis_cache.x (added) * cpukit/librpc/include/rpcsvc/nis_callback.x (added) * cpukit/librpc/include/rpcsvc/nis_db.h (added) * cpukit/librpc/include/rpcsvc/nis_object.x (added) * cpukit/librpc/include/rpcsvc/nis_tags.h (added) * cpukit/librpc/include/rpcsvc/nislib.h (added) * cpukit/librpc/include/rpcsvc/nlm_prot.x (added) * cpukit/librpc/include/rpcsvc/pmap_prot.x (added) New directory added as part of librpc upgrade. Fri, 28 Apr 2000 17:42:16 GMT Joel Sherrill [a4460152] * c/src/exec/libnetworking/memory.h (added) * c/src/exec/libnetworking/sys/un.h (added) * c/src/libnetworking/memory.h (added) * c/src/libnetworking/sys/un.h (added) * cpukit/libnetworking/memory.h (added) * cpukit/libnetworking/sys/un.h (added) New files added on 4.5 branch. Thu, 13 Apr 2000 15:16:49 GMT Joel Sherrill [17177e2c] * c/src/lib/libbsp/m68k/mvme167/times (added) New file. Thu, 13 Apr 2000 14:47:15 GMT Joel Sherrill [e4c07444] * c/src/exec/.cvsignore (added) * c/src/exec/libcsupport/include/.cvsignore (added) * c/src/exec/libcsupport/include/motorola/.cvsignore (added) * c/src/exec/libcsupport/include/sys/.cvsignore (added) * c/src/exec/libcsupport/include/zilog/.cvsignore (added) * c/src/exec/score/.cvsignore (added) * c/src/exec/score/cpu/.cvsignore (added) * c/src/exec/score/cpu/powerpc/.cvsignore (added) * c/src/exec/score/cpu/sh/.cvsignore (added) * c/src/exec/score/cpu/sh/rtems/.cvsignore (added) * c/src/exec/score/cpu/sh/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/sparc/.cvsignore (added) * c/src/exec/score/cpu/sparc/rtems/.cvsignore (added) * c/src/exec/score/cpu/sparc/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/unix/.cvsignore (added) * c/src/exec/score/cpu/unix/rtems/.cvsignore (added) * c/src/exec/score/cpu/unix/rtems/score/.cvsignore (added) * c/src/exec/score/include/.cvsignore (added) * c/src/exec/score/include/rtems/.cvsignore (added) * c/src/exec/score/include/rtems/score/.cvsignore (added) * c/src/exec/score/inline/.cvsignore (added) * c/src/exec/score/inline/rtems/.cvsignore (added) * c/src/exec/score/inline/rtems/score/.cvsignore (added) * c/src/exec/score/macros/.cvsignore (added) * c/src/exec/score/macros/rtems/.cvsignore (added) * c/src/exec/score/macros/rtems/score/.cvsignore (added) * c/src/exec/score/src/.cvsignore (added) * c/src/exec/wrapup/.cvsignore (added) * c/src/exec/wrapup/itron/.cvsignore (added) * c/src/exec/wrapup/posix/.cvsignore (added) * c/src/exec/wrapup/rtems/.cvsignore (added) * c/src/lib/include/.cvsignore (added) * c/src/lib/include/motorola/.cvsignore (added) * c/src/lib/include/sys/.cvsignore (added) * c/src/lib/include/zilog/.cvsignore (added) * c/src/lib/libbsp/a29k/.cvsignore (added) * c/src/lib/libbsp/a29k/portsw/.cvsignore (added) * c/src/lib/libbsp/a29k/portsw/console/.cvsignore (added) * c/src/lib/libbsp/a29k/portsw/include/.cvsignore (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/.cvsignore (added) * c/src/lib/libbsp/a29k/portsw/start/.cvsignore (added) * c/src/lib/libbsp/a29k/portsw/startup/.cvsignore (added) * c/src/lib/libbsp/a29k/portsw/wrapup/.cvsignore (added) * c/src/lib/libbsp/bare/.cvsignore (added) * c/src/lib/libbsp/bare/include/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/pxfl/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/start/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/tools/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/tty/.cvsignore (added) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/.cvsignore (added) * c/src/lib/libbsp/i386/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/clock/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/console/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/include/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/network/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/start/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/startup/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/timer/.cvsignore (added) * c/src/lib/libbsp/i386/i386ex/wrapup/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/3c509/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/clock/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/console/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/include/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/ne2000/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/start/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/startup/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/timer/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/tools/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/wd8003/.cvsignore (added) * c/src/lib/libbsp/i386/pc386/wrapup/.cvsignore (added) * c/src/lib/libbsp/i386/shared/.cvsignore (added) * c/src/lib/libbsp/i386/shared/comm/.cvsignore (added) * c/src/lib/libbsp/i386/shared/io/.cvsignore (added) * c/src/lib/libbsp/i386/shared/irq/.cvsignore (added) * c/src/lib/libbsp/i386/shared/pci/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/clock/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/console/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/include/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/network/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/start/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/startup/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/timer/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/.cvsignore (added) * c/src/lib/libbsp/i386/ts_386ex/wrapup/.cvsignore (added) * c/src/lib/libbsp/i960/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/clock/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/console/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/include/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/start/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/startup/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/timer/.cvsignore (added) * c/src/lib/libbsp/i960/cvme961/wrapup/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/clock/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/console/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/include/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/startup/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/timer/.cvsignore (added) * c/src/lib/libbsp/i960/rxgen960/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/console/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/include/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/spurious/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/start/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/dmv152/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/console/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/include/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/spurious/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/start/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/efi332/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/console/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/include/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/spurious/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/start/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/efi68k/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/console/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/include/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/start/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68302/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/console/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/include/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/start/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68340/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/console/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/include/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/network/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/start/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/gen68360/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/console/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/include/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/start/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/idp/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/console/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/include/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/start/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme136/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/console/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/include/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/start/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/console/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/include/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/start/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme147s/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/console/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/consolex/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/include/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/start/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/tod/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/tools/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme162/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/console/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/fatal/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/include/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/network/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/start/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/mvme167/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/console/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/include/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/start/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/timer/.cvsignore (added) * c/src/lib/libbsp/m68k/ods68302/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/shared/.cvsignore (added) * c/src/lib/libbsp/mips/.cvsignore (added) * c/src/lib/libbsp/mips/p4000/.cvsignore (added) * c/src/lib/libbsp/mips/p4000/console/.cvsignore (added) * c/src/lib/libbsp/mips/p4000/include/.cvsignore (added) * c/src/lib/libbsp/mips/p4000/liblnk/.cvsignore (added) * c/src/lib/libbsp/mips/p4000/start/.cvsignore (added) * c/src/lib/libbsp/mips/p4000/startup/.cvsignore (added) * c/src/lib/libbsp/mips/p4000/wrapup/.cvsignore (added) * c/src/lib/libbsp/mips64orion/.cvsignore (added) * c/src/lib/libbsp/mips64orion/p4000/.cvsignore (added) * c/src/lib/libbsp/mips64orion/p4000/console/.cvsignore (added) * c/src/lib/libbsp/mips64orion/p4000/include/.cvsignore (added) * c/src/lib/libbsp/mips64orion/p4000/liblnk/.cvsignore (added) * c/src/lib/libbsp/mips64orion/p4000/start/.cvsignore (added) * c/src/lib/libbsp/mips64orion/p4000/startup/.cvsignore (added) * c/src/lib/libbsp/mips64orion/p4000/wrapup/.cvsignore (added) * c/src/lib/libbsp/no_cpu/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/clock/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/console/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/include/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/timer/.cvsignore (added) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/clock/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/console/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/scv64/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/sonic/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/timer/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/tod/.cvsignore (added) * c/src/lib/libbsp/powerpc/dmv177/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/console/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/network/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/helas403/.cvsignore (added) * c/src/lib/libbsp/powerpc/helas403/dlentry/.cvsignore (added) * c/src/lib/libbsp/powerpc/helas403/flashentry/.cvsignore (added) * c/src/lib/libbsp/powerpc/helas403/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/helas403/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/helas403/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/papyrus/.cvsignore (added) * c/src/lib/libbsp/powerpc/papyrus/dlentry/.cvsignore (added) * c/src/lib/libbsp/powerpc/papyrus/flashentry/.cvsignore (added) * c/src/lib/libbsp/powerpc/papyrus/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/papyrus/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/papyrus/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/clock/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/console/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/timer/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/tools/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/psim/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/clock/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/console/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/timer/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/tod/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/score603e/wrapup/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/bootloader/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/clock/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/console/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/irq/.cvsignore (added) * cpukit/.cvsignore (added) * cpukit/libcsupport/include/.cvsignore (added) * cpukit/libcsupport/include/motorola/.cvsignore (added) * cpukit/libcsupport/include/sys/.cvsignore (added) * cpukit/libcsupport/include/zilog/.cvsignore (added) * cpukit/score/.cvsignore (added) * cpukit/score/cpu/.cvsignore (added) * cpukit/score/cpu/powerpc/.cvsignore (added) * cpukit/score/cpu/sh/.cvsignore (added) * cpukit/score/cpu/sh/rtems/.cvsignore (added) * cpukit/score/cpu/sh/rtems/score/.cvsignore (added) * cpukit/score/cpu/sparc/.cvsignore (added) * cpukit/score/cpu/sparc/rtems/.cvsignore (added) * cpukit/score/cpu/sparc/rtems/score/.cvsignore (added) * cpukit/score/cpu/unix/.cvsignore (added) * cpukit/score/cpu/unix/rtems/.cvsignore (added) * cpukit/score/cpu/unix/rtems/score/.cvsignore (added) * cpukit/score/include/.cvsignore (added) * cpukit/score/include/rtems/.cvsignore (added) * cpukit/score/include/rtems/score/.cvsignore (added) * cpukit/score/inline/.cvsignore (added) * cpukit/score/inline/rtems/.cvsignore (added) * cpukit/score/inline/rtems/score/.cvsignore (added) * cpukit/score/macros/.cvsignore (added) * cpukit/score/macros/rtems/.cvsignore (added) * cpukit/score/macros/rtems/score/.cvsignore (added) * cpukit/score/src/.cvsignore (added) * cpukit/wrapup/.cvsignore (added) Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius [bf85b19] * c/.cvsignore (added) * c/make/.cvsignore (added) * c/src/.cvsignore (added) * c/src/exec/itron/.cvsignore (added) * c/src/exec/itron/include/.cvsignore (added) * c/src/exec/itron/include/itronsys/.cvsignore (added) * c/src/exec/itron/include/rtems/.cvsignore (added) * c/src/exec/itron/include/rtems/itron/.cvsignore (added) * c/src/exec/itron/inline/.cvsignore (added) * c/src/exec/itron/inline/rtems/.cvsignore (added) * c/src/exec/itron/inline/rtems/itron/.cvsignore (added) * c/src/exec/itron/src/.cvsignore (added) * c/src/exec/libcsupport/.cvsignore (added) * c/src/exec/libnetworking/.cvsignore (added) * c/src/exec/libnetworking/arpa/.cvsignore (added) * c/src/exec/libnetworking/kern/.cvsignore (added) * c/src/exec/libnetworking/lib/.cvsignore (added) * c/src/exec/libnetworking/libc/.cvsignore (added) * c/src/exec/libnetworking/machine/.cvsignore (added) * c/src/exec/libnetworking/net/.cvsignore (added) * c/src/exec/libnetworking/netinet/.cvsignore (added) * c/src/exec/libnetworking/nfs/.cvsignore (added) * c/src/exec/libnetworking/rtems/.cvsignore (added) * c/src/exec/libnetworking/sys/.cvsignore (added) * c/src/exec/libnetworking/vm/.cvsignore (added) * c/src/exec/libnetworking/wrapup/.cvsignore (added) * c/src/exec/librpc/.cvsignore (added) * c/src/exec/librpc/include/.cvsignore (added) * c/src/exec/librpc/include/rpc/.cvsignore (added) * c/src/exec/librpc/src/.cvsignore (added) * c/src/exec/posix/.cvsignore (added) * c/src/exec/posix/include/.cvsignore (added) * c/src/exec/posix/include/rtems/.cvsignore (added) * c/src/exec/posix/include/rtems/posix/.cvsignore (added) * c/src/exec/posix/include/sys/.cvsignore (added) * c/src/exec/posix/inline/.cvsignore (added) * c/src/exec/posix/inline/rtems/.cvsignore (added) * c/src/exec/posix/inline/rtems/posix/.cvsignore (added) * c/src/exec/posix/macros/.cvsignore (added) * c/src/exec/posix/macros/rtems/.cvsignore (added) * c/src/exec/posix/macros/rtems/posix/.cvsignore (added) * c/src/exec/posix/optman/.cvsignore (added) * c/src/exec/posix/src/.cvsignore (added) * c/src/exec/rtems/.cvsignore (added) * c/src/exec/rtems/include/.cvsignore (added) * c/src/exec/rtems/include/rtems/.cvsignore (added) * c/src/exec/rtems/include/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/inline/.cvsignore (added) * c/src/exec/rtems/inline/rtems/.cvsignore (added) * c/src/exec/rtems/inline/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/macros/.cvsignore (added) * c/src/exec/rtems/macros/rtems/.cvsignore (added) * c/src/exec/rtems/macros/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/optman/.cvsignore (added) * c/src/exec/rtems/src/.cvsignore (added) * c/src/exec/sapi/.cvsignore (added) * c/src/exec/sapi/include/.cvsignore (added) * c/src/exec/sapi/include/rtems/.cvsignore (added) * c/src/exec/sapi/inline/.cvsignore (added) * c/src/exec/sapi/inline/rtems/.cvsignore (added) * c/src/exec/sapi/macros/.cvsignore (added) * c/src/exec/sapi/macros/rtems/.cvsignore (added) * c/src/exec/sapi/optman/.cvsignore (added) * c/src/exec/sapi/src/.cvsignore (added) * c/src/exec/score/cpu/a29k/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i386/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i960/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/m68k/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/shared/.cvsignore (added) * c/src/lib/.cvsignore (added) * c/src/lib/libbsp/.cvsignore (added) * c/src/lib/libbsp/powerpc/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/motorola/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/openpic/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/pci/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/residual/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/.cvsignore (added) * c/src/lib/libbsp/sh/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/shared/.cvsignore (added) * c/src/lib/libbsp/shmdr/.cvsignore (added) * c/src/lib/libbsp/sparc/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/clock/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/console/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/gnatsupp/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/include/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/start/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/startup/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/timer/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/wrapup/.cvsignore (added) * c/src/lib/libbsp/unix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/clock/.cvsignore (added) * c/src/lib/libbsp/unix/posix/console/.cvsignore (added) * c/src/lib/libbsp/unix/posix/include/.cvsignore (added) * c/src/lib/libbsp/unix/posix/shmsupp/.cvsignore (added) * c/src/lib/libbsp/unix/posix/startup/.cvsignore (added) * c/src/lib/libbsp/unix/posix/timer/.cvsignore (added) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (added) * c/src/lib/libbsp/unix/posix/wrapup/.cvsignore (added) * c/src/lib/libc/.cvsignore (added) * c/src/lib/libcpu/.cvsignore (added) * c/src/lib/libcpu/a29k/.cvsignore (added) * c/src/lib/libcpu/a29k/clock/.cvsignore (added) * c/src/lib/libcpu/a29k/timer/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/clock/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/include/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/milli/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/semaphore/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/timer/.cvsignore (added) * c/src/lib/libcpu/i386/.cvsignore (added) * c/src/lib/libcpu/m68k/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (added) * c/src/lib/libcpu/mips/.cvsignore (added) * c/src/lib/libcpu/mips/clock/.cvsignore (added) * c/src/lib/libcpu/mips/timer/.cvsignore (added) * c/src/lib/libcpu/mips64orion/.cvsignore (added) * c/src/lib/libcpu/mips64orion/clock/.cvsignore (added) * c/src/lib/libcpu/mips64orion/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/shared/.cvsignore (added) * c/src/lib/libcpu/powerpc/wrapup/.cvsignore (added) * c/src/lib/libcpu/sh/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (added) * c/src/lib/libcpu/sparc/.cvsignore (added) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (added) * c/src/lib/libcpu/sparc/syscall/.cvsignore (added) * c/src/libchip/.cvsignore (added) * c/src/libchip/network/.cvsignore (added) * c/src/libchip/rtc/.cvsignore (added) * c/src/libchip/serial/.cvsignore (added) * c/src/libchip/shmdr/.cvsignore (added) * c/src/libmisc/.cvsignore (added) * c/src/libmisc/cpuuse/.cvsignore (added) * c/src/libmisc/dummy/.cvsignore (added) * c/src/libmisc/dumpbuf/.cvsignore (added) * c/src/libmisc/monitor/.cvsignore (added) * c/src/libmisc/rtmonuse/.cvsignore (added) * c/src/libmisc/stackchk/.cvsignore (added) * c/src/libmisc/untar/.cvsignore (added) * c/src/libmisc/wrapup/.cvsignore (added) * c/src/libnetworking/.cvsignore (added) * c/src/libnetworking/arpa/.cvsignore (added) * c/src/libnetworking/include/.cvsignore (added) * c/src/libnetworking/kern/.cvsignore (added) * c/src/libnetworking/lib/.cvsignore (added) * c/src/libnetworking/libc/.cvsignore (added) * c/src/libnetworking/machine/.cvsignore (added) * c/src/libnetworking/net/.cvsignore (added) * c/src/libnetworking/netinet/.cvsignore (added) * c/src/libnetworking/nfs/.cvsignore (added) * c/src/libnetworking/pppd/.cvsignore (added) * c/src/libnetworking/rtems/.cvsignore (added) * c/src/libnetworking/rtems_servers/.cvsignore (added) * c/src/libnetworking/rtems_webserver/.cvsignore (added) * c/src/libnetworking/sys/.cvsignore (added) * c/src/libnetworking/vm/.cvsignore (added) * c/src/libnetworking/wrapup/.cvsignore (added) * c/src/librdbg/.cvsignore (added) * c/src/librdbg/include/.cvsignore (added) * c/src/librdbg/include/rdbg/.cvsignore (added) * c/src/librdbg/include/rdbg/i386/.cvsignore (added) * c/src/librdbg/include/rdbg/powerpc/.cvsignore (added) * c/src/librdbg/src/.cvsignore (added) * c/src/librdbg/src/i386/.cvsignore (added) * c/src/librdbg/src/i386/any/.cvsignore (added) * c/src/librdbg/src/powerpc/.cvsignore (added) * c/src/librdbg/src/powerpc/mcp750/.cvsignore (added) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (added) * c/src/librpc/.cvsignore (added) * c/src/librpc/include/.cvsignore (added) * c/src/librpc/include/rpc/.cvsignore (added) * c/src/librpc/src/.cvsignore (added) * c/src/librtems++/.cvsignore (added) * c/src/librtems++/include/.cvsignore (added) * c/src/librtems++/include/rtems++/.cvsignore (added) * c/src/librtems++/src/.cvsignore (added) * c/src/make/.cvsignore (added) * c/src/make/compilers/.cvsignore (added) * c/src/make/custom/.cvsignore (added) * c/src/tests/.cvsignore (added) * c/src/tests/itrontests/.cvsignore (added) * c/src/tests/itrontests/itronhello/.cvsignore (added) * c/src/tests/itrontests/itronmbf01/.cvsignore (added) * c/src/tests/itrontests/itronmbox01/.cvsignore (added) * c/src/tests/itrontests/itronsem01/.cvsignore (added) * c/src/tests/itrontests/itrontask01/.cvsignore (added) * c/src/tests/itrontests/itrontask02/.cvsignore (added) * c/src/tests/itrontests/itrontask03/.cvsignore (added) * c/src/tests/itrontests/itrontask04/.cvsignore (added) * c/src/tests/itrontests/itrontime01/.cvsignore (added) * c/src/tests/libtests/.cvsignore (added) * c/src/tests/libtests/cpuuse/.cvsignore (added) * c/src/tests/libtests/malloctest/.cvsignore (added) * c/src/tests/libtests/monitor/.cvsignore (added) * c/src/tests/libtests/putenvtest/.cvsignore (added) * c/src/tests/libtests/rtems++/.cvsignore (added) * c/src/tests/libtests/rtmonuse/.cvsignore (added) * c/src/tests/libtests/stackchk/.cvsignore (added) * c/src/tests/libtests/termios/.cvsignore (added) * c/src/tests/mptests/.cvsignore (added) * c/src/tests/mptests/mp01/.cvsignore (added) * c/src/tests/mptests/mp01/node1/.cvsignore (added) * c/src/tests/mptests/mp01/node2/.cvsignore (added) * c/src/tests/mptests/mp02/.cvsignore (added) * c/src/tests/mptests/mp02/node1/.cvsignore (added) * c/src/tests/mptests/mp02/node2/.cvsignore (added) * c/src/tests/mptests/mp03/.cvsignore (added) * c/src/tests/mptests/mp03/node1/.cvsignore (added) * c/src/tests/mptests/mp03/node2/.cvsignore (added) * c/src/tests/mptests/mp04/.cvsignore (added) * c/src/tests/mptests/mp04/node1/.cvsignore (added) * c/src/tests/mptests/mp04/node2/.cvsignore (added) * c/src/tests/mptests/mp05/.cvsignore (added) * c/src/tests/mptests/mp05/node1/.cvsignore (added) * c/src/tests/mptests/mp05/node2/.cvsignore (added) * c/src/tests/mptests/mp06/.cvsignore (added) * c/src/tests/mptests/mp06/node1/.cvsignore (added) * c/src/tests/mptests/mp06/node2/.cvsignore (added) * c/src/tests/mptests/mp07/.cvsignore (added) * c/src/tests/mptests/mp07/node1/.cvsignore (added) * c/src/tests/mptests/mp07/node2/.cvsignore (added) * c/src/tests/mptests/mp08/.cvsignore (added) * c/src/tests/mptests/mp08/node1/.cvsignore (added) * c/src/tests/mptests/mp08/node2/.cvsignore (added) * c/src/tests/mptests/mp09/.cvsignore (added) * c/src/tests/mptests/mp09/node1/.cvsignore (added) * c/src/tests/mptests/mp09/node2/.cvsignore (added) * c/src/tests/mptests/mp10/.cvsignore (added) * c/src/tests/mptests/mp10/node1/.cvsignore (added) * c/src/tests/mptests/mp10/node2/.cvsignore (added) * c/src/tests/mptests/mp11/.cvsignore (added) * c/src/tests/mptests/mp11/node1/.cvsignore (added) * c/src/tests/mptests/mp11/node2/.cvsignore (added) * c/src/tests/mptests/mp12/.cvsignore (added) * c/src/tests/mptests/mp12/node1/.cvsignore (added) * c/src/tests/mptests/mp12/node2/.cvsignore (added) * c/src/tests/mptests/mp13/.cvsignore (added) * c/src/tests/mptests/mp13/node1/.cvsignore (added) * c/src/tests/mptests/mp13/node2/.cvsignore (added) * c/src/tests/mptests/mp14/.cvsignore (added) * c/src/tests/mptests/mp14/node1/.cvsignore (added) * c/src/tests/mptests/mp14/node2/.cvsignore (added) * c/src/tests/psxtests/.cvsignore (added) * c/src/tests/psxtests/include/.cvsignore (added) * c/src/tests/psxtests/psx01/.cvsignore (added) * c/src/tests/psxtests/psx02/.cvsignore (added) * c/src/tests/psxtests/psx03/.cvsignore (added) * c/src/tests/psxtests/psx04/.cvsignore (added) * c/src/tests/psxtests/psx05/.cvsignore (added) * c/src/tests/psxtests/psx06/.cvsignore (added) * c/src/tests/psxtests/psx07/.cvsignore (added) * c/src/tests/psxtests/psx08/.cvsignore (added) * c/src/tests/psxtests/psx09/.cvsignore (added) * c/src/tests/psxtests/psx10/.cvsignore (added) * c/src/tests/psxtests/psx11/.cvsignore (added) * c/src/tests/psxtests/psx12/.cvsignore (added) * c/src/tests/psxtests/psx13/.cvsignore (added) * c/src/tests/psxtests/psxcancel/.cvsignore (added) * c/src/tests/psxtests/psxfile01/.cvsignore (added) * c/src/tests/psxtests/psxhdrs/.cvsignore (added) * c/src/tests/psxtests/psxmount/.cvsignore (added) * c/src/tests/psxtests/psxmsgq01/.cvsignore (added) * c/src/tests/psxtests/psxreaddir/.cvsignore (added) * c/src/tests/psxtests/psxsem01/.cvsignore (added) * c/src/tests/psxtests/psxstat/.cvsignore (added) * c/src/tests/psxtests/psxtime/.cvsignore (added) * c/src/tests/psxtests/psxtimer/.cvsignore (added) * c/src/tests/samples/.cvsignore (added) * c/src/tests/samples/base_mp/.cvsignore (added) * c/src/tests/samples/base_mp/node1/.cvsignore (added) * c/src/tests/samples/base_mp/node2/.cvsignore (added) * c/src/tests/samples/base_sp/.cvsignore (added) * c/src/tests/samples/cdtest/.cvsignore (added) * c/src/tests/samples/hello/.cvsignore (added) * c/src/tests/samples/minimum/.cvsignore (added) * c/src/tests/samples/paranoia/.cvsignore (added) * c/src/tests/samples/ticker/.cvsignore (added) * c/src/tests/samples/unlimited/.cvsignore (added) * c/src/tests/sptests/.cvsignore (added) * c/src/tests/sptests/sp01/.cvsignore (added) * c/src/tests/sptests/sp02/.cvsignore (added) * c/src/tests/sptests/sp03/.cvsignore (added) * c/src/tests/sptests/sp04/.cvsignore (added) * c/src/tests/sptests/sp05/.cvsignore (added) * c/src/tests/sptests/sp06/.cvsignore (added) * c/src/tests/sptests/sp07/.cvsignore (added) * c/src/tests/sptests/sp08/.cvsignore (added) * c/src/tests/sptests/sp09/.cvsignore (added) * c/src/tests/sptests/sp11/.cvsignore (added) * c/src/tests/sptests/sp12/.cvsignore (added) * c/src/tests/sptests/sp13/.cvsignore (added) * c/src/tests/sptests/sp14/.cvsignore (added) * c/src/tests/sptests/sp15/.cvsignore (added) * c/src/tests/sptests/sp16/.cvsignore (added) * c/src/tests/sptests/sp17/.cvsignore (added) * c/src/tests/sptests/sp19/.cvsignore (added) * c/src/tests/sptests/sp20/.cvsignore (added) * c/src/tests/sptests/sp21/.cvsignore (added) * c/src/tests/sptests/sp22/.cvsignore (added) * c/src/tests/sptests/sp23/.cvsignore (added) * c/src/tests/sptests/sp24/.cvsignore (added) * c/src/tests/sptests/sp25/.cvsignore (added) * c/src/tests/sptests/sp26/.cvsignore (added) * c/src/tests/sptests/sp27/.cvsignore (added) * c/src/tests/sptests/sp28/.cvsignore (added) * c/src/tests/sptests/sp29/.cvsignore (added) * c/src/tests/sptests/spfatal/.cvsignore (added) * c/src/tests/sptests/spsize/.cvsignore (added) * c/src/tests/support/.cvsignore (added) * c/src/tests/support/include/.cvsignore (added) * c/src/tests/support/stubdr/.cvsignore (added) * c/src/tests/support/wrapup/.cvsignore (added) * c/src/tests/tmitrontests/.cvsignore (added) * c/src/tests/tmitrontests/include/.cvsignore (added) * c/src/tests/tmitrontests/tmitronsem01/.cvsignore (added) * c/src/tests/tmtests/.cvsignore (added) * c/src/tests/tmtests/include/.cvsignore (added) * c/src/tests/tmtests/tm01/.cvsignore (added) * c/src/tests/tmtests/tm02/.cvsignore (added) * c/src/tests/tmtests/tm03/.cvsignore (added) * c/src/tests/tmtests/tm04/.cvsignore (added) * c/src/tests/tmtests/tm05/.cvsignore (added) * c/src/tests/tmtests/tm06/.cvsignore (added) * c/src/tests/tmtests/tm07/.cvsignore (added) * c/src/tests/tmtests/tm08/.cvsignore (added) * c/src/tests/tmtests/tm09/.cvsignore (added) * c/src/tests/tmtests/tm10/.cvsignore (added) * c/src/tests/tmtests/tm11/.cvsignore (added) * c/src/tests/tmtests/tm12/.cvsignore (added) * c/src/tests/tmtests/tm13/.cvsignore (added) * c/src/tests/tmtests/tm14/.cvsignore (added) * c/src/tests/tmtests/tm15/.cvsignore (added) * c/src/tests/tmtests/tm16/.cvsignore (added) * c/src/tests/tmtests/tm17/.cvsignore (added) * c/src/tests/tmtests/tm18/.cvsignore (added) * c/src/tests/tmtests/tm19/.cvsignore (added) * c/src/tests/tmtests/tm20/.cvsignore (added) * c/src/tests/tmtests/tm21/.cvsignore (added) * c/src/tests/tmtests/tm22/.cvsignore (added) * c/src/tests/tmtests/tm23/.cvsignore (added) * c/src/tests/tmtests/tm24/.cvsignore (added) * c/src/tests/tmtests/tm25/.cvsignore (added) * c/src/tests/tmtests/tm26/.cvsignore (added) * c/src/tests/tmtests/tm27/.cvsignore (added) * c/src/tests/tmtests/tm28/.cvsignore (added) * c/src/tests/tmtests/tm29/.cvsignore (added) * c/src/tests/tmtests/tmck/.cvsignore (added) * c/src/tests/tmtests/tmoverhd/.cvsignore (added) * c/src/tests/tools/.cvsignore (added) * c/src/tests/tools/generic/.cvsignore (added) * c/src/wrapup/.cvsignore (added) * cpukit/httpd/.cvsignore (added) * cpukit/itron/.cvsignore (added) * cpukit/itron/include/.cvsignore (added) * cpukit/itron/include/itronsys/.cvsignore (added) * cpukit/itron/include/rtems/.cvsignore (added) * cpukit/itron/include/rtems/itron/.cvsignore (added) * cpukit/itron/inline/.cvsignore (added) * cpukit/itron/inline/rtems/.cvsignore (added) * cpukit/itron/inline/rtems/itron/.cvsignore (added) * cpukit/itron/src/.cvsignore (added) * cpukit/libcsupport/.cvsignore (added) * cpukit/libmisc/.cvsignore (added) * cpukit/libmisc/cpuuse/.cvsignore (added) * cpukit/libmisc/dummy/.cvsignore (added) * cpukit/libmisc/dumpbuf/.cvsignore (added) * cpukit/libmisc/monitor/.cvsignore (added) * cpukit/libmisc/rtmonuse/.cvsignore (added) * cpukit/libmisc/stackchk/.cvsignore (added) * cpukit/libmisc/untar/.cvsignore (added) * cpukit/libmisc/wrapup/.cvsignore (added) * cpukit/libnetworking/.cvsignore (added) * cpukit/libnetworking/arpa/.cvsignore (added) * cpukit/libnetworking/kern/.cvsignore (added) * cpukit/libnetworking/lib/.cvsignore (added) * cpukit/libnetworking/libc/.cvsignore (added) * cpukit/libnetworking/machine/.cvsignore (added) * cpukit/libnetworking/net/.cvsignore (added) * cpukit/libnetworking/netinet/.cvsignore (added) * cpukit/libnetworking/nfs/.cvsignore (added) * cpukit/libnetworking/rtems/.cvsignore (added) * cpukit/libnetworking/sys/.cvsignore (added) * cpukit/libnetworking/vm/.cvsignore (added) * cpukit/libnetworking/wrapup/.cvsignore (added) * cpukit/librpc/.cvsignore (added) * cpukit/librpc/include/.cvsignore (added) * cpukit/librpc/include/rpc/.cvsignore (added) * cpukit/librpc/src/.cvsignore (added) * cpukit/posix/.cvsignore (added) * cpukit/posix/include/.cvsignore (added) * cpukit/posix/include/rtems/.cvsignore (added) * cpukit/posix/include/rtems/posix/.cvsignore (added) * cpukit/posix/inline/.cvsignore (added) * cpukit/posix/inline/rtems/.cvsignore (added) * cpukit/posix/inline/rtems/posix/.cvsignore (added) * cpukit/posix/macros/.cvsignore (added) * cpukit/posix/macros/rtems/.cvsignore (added) * cpukit/posix/macros/rtems/posix/.cvsignore (added) * cpukit/posix/src/.cvsignore (added) * cpukit/rtems/.cvsignore (added) * cpukit/rtems/include/.cvsignore (added) * cpukit/rtems/include/rtems/.cvsignore (added) * cpukit/rtems/include/rtems/rtems/.cvsignore (added) * cpukit/rtems/inline/.cvsignore (added) * cpukit/rtems/inline/rtems/.cvsignore (added) * cpukit/rtems/inline/rtems/rtems/.cvsignore (added) * cpukit/rtems/macros/.cvsignore (added) * cpukit/rtems/macros/rtems/.cvsignore (added) * cpukit/rtems/macros/rtems/rtems/.cvsignore (added) * cpukit/rtems/src/.cvsignore (added) * cpukit/sapi/.cvsignore (added) * cpukit/sapi/include/.cvsignore (added) * cpukit/sapi/include/rtems/.cvsignore (added) * cpukit/sapi/inline/.cvsignore (added) * cpukit/sapi/inline/rtems/.cvsignore (added) * cpukit/sapi/macros/.cvsignore (added) * cpukit/sapi/macros/rtems/.cvsignore (added) * cpukit/sapi/src/.cvsignore (added) * cpukit/score/cpu/a29k/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/score/.cvsignore (added) * cpukit/score/cpu/hppa1.1/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * cpukit/score/cpu/i386/.cvsignore (added) * cpukit/score/cpu/i386/rtems/.cvsignore (added) * cpukit/score/cpu/i386/rtems/score/.cvsignore (added) * cpukit/score/cpu/i960/.cvsignore (added) * cpukit/score/cpu/i960/rtems/.cvsignore (added) * cpukit/score/cpu/i960/rtems/score/.cvsignore (added) * cpukit/score/cpu/m68k/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips/.cvsignore (added) * cpukit/score/cpu/mips/rtems/.cvsignore (added) * cpukit/score/cpu/mips/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips64orion/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/score/.cvsignore (added) * cpukit/score/cpu/no_cpu/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (added) * doc/.cvsignore (added) * make/.cvsignore (added) * make/Templates/.cvsignore (added) * make/compilers/.cvsignore (added) * make/custom/.cvsignore (added) * scripts-ada/.cvsignore (added) * scripts-ada/binutils/.cvsignore (added) * scripts-ada/gdb/.cvsignore (added) * scripts-ada/gnatnewlib/.cvsignore (added) * scripts/.cvsignore (added) * scripts/binutils/.cvsignore (added) * scripts/gccnewlib/.cvsignore (added) * scripts/gdb/.cvsignore (added) * scripts/rtems/.cvsignore (added) * testsuites/.cvsignore (added) * testsuites/itrontests/.cvsignore (added) * testsuites/itrontests/itronhello/.cvsignore (added) * testsuites/itrontests/itronmbf01/.cvsignore (added) * testsuites/itrontests/itronmbox01/.cvsignore (added) * testsuites/itrontests/itronsem01/.cvsignore (added) * testsuites/itrontests/itrontask01/.cvsignore (added) * testsuites/itrontests/itrontask02/.cvsignore (added) * testsuites/itrontests/itrontask03/.cvsignore (added) * testsuites/itrontests/itrontask04/.cvsignore (added) * testsuites/itrontests/itrontime01/.cvsignore (added) * testsuites/libtests/.cvsignore (added) * testsuites/libtests/cpuuse/.cvsignore (added) * testsuites/libtests/malloctest/.cvsignore (added) * testsuites/libtests/monitor/.cvsignore (added) * testsuites/libtests/putenvtest/.cvsignore (added) * testsuites/libtests/rtems++/.cvsignore (added) * testsuites/libtests/rtmonuse/.cvsignore (added) * testsuites/libtests/stackchk/.cvsignore (added) * testsuites/libtests/termios/.cvsignore (added) * testsuites/mptests/.cvsignore (added) * testsuites/mptests/mp01/.cvsignore (added) * testsuites/mptests/mp01/node1/.cvsignore (added) * testsuites/mptests/mp01/node2/.cvsignore (added) * testsuites/mptests/mp02/.cvsignore (added) * testsuites/mptests/mp02/node1/.cvsignore (added) * testsuites/mptests/mp02/node2/.cvsignore (added) * testsuites/mptests/mp03/.cvsignore (added) * testsuites/mptests/mp03/node1/.cvsignore (added) * testsuites/mptests/mp03/node2/.cvsignore (added) * testsuites/mptests/mp04/.cvsignore (added) * testsuites/mptests/mp04/node1/.cvsignore (added) * testsuites/mptests/mp04/node2/.cvsignore (added) * testsuites/mptests/mp05/.cvsignore (added) * testsuites/mptests/mp05/node1/.cvsignore (added) * testsuites/mptests/mp05/node2/.cvsignore (added) * testsuites/mptests/mp06/.cvsignore (added) * testsuites/mptests/mp06/node1/.cvsignore (added) * testsuites/mptests/mp06/node2/.cvsignore (added) * testsuites/mptests/mp07/.cvsignore (added) * testsuites/mptests/mp07/node1/.cvsignore (added) * testsuites/mptests/mp07/node2/.cvsignore (added) * testsuites/mptests/mp08/.cvsignore (added) * testsuites/mptests/mp08/node1/.cvsignore (added) * testsuites/mptests/mp08/node2/.cvsignore (added) * testsuites/mptests/mp09/.cvsignore (added) * testsuites/mptests/mp09/node1/.cvsignore (added) * testsuites/mptests/mp09/node2/.cvsignore (added) * testsuites/mptests/mp10/.cvsignore (added) * testsuites/mptests/mp10/node1/.cvsignore (added) * testsuites/mptests/mp10/node2/.cvsignore (added) * testsuites/mptests/mp11/.cvsignore (added) * testsuites/mptests/mp11/node1/.cvsignore (added) * testsuites/mptests/mp11/node2/.cvsignore (added) * testsuites/mptests/mp12/.cvsignore (added) * testsuites/mptests/mp12/node1/.cvsignore (added) * testsuites/mptests/mp12/node2/.cvsignore (added) * testsuites/mptests/mp13/.cvsignore (added) * testsuites/mptests/mp13/node1/.cvsignore (added) * testsuites/mptests/mp13/node2/.cvsignore (added) * testsuites/mptests/mp14/.cvsignore (added) * testsuites/mptests/mp14/node1/.cvsignore (added) * testsuites/mptests/mp14/node2/.cvsignore (added) * testsuites/psxtests/.cvsignore (added) * testsuites/psxtests/include/.cvsignore (added) * testsuites/psxtests/psx01/.cvsignore (added) * testsuites/psxtests/psx02/.cvsignore (added) * testsuites/psxtests/psx03/.cvsignore (added) * testsuites/psxtests/psx04/.cvsignore (added) * testsuites/psxtests/psx05/.cvsignore (added) * testsuites/psxtests/psx06/.cvsignore (added) * testsuites/psxtests/psx07/.cvsignore (added) * testsuites/psxtests/psx08/.cvsignore (added) * testsuites/psxtests/psx09/.cvsignore (added) * testsuites/psxtests/psx10/.cvsignore (added) * testsuites/psxtests/psx11/.cvsignore (added) * testsuites/psxtests/psx12/.cvsignore (added) * testsuites/psxtests/psx13/.cvsignore (added) * testsuites/psxtests/psxcancel/.cvsignore (added) * testsuites/psxtests/psxfile01/.cvsignore (added) * testsuites/psxtests/psxhdrs/.cvsignore (added) * testsuites/psxtests/psxmount/.cvsignore (added) * testsuites/psxtests/psxmsgq01/.cvsignore (added) * testsuites/psxtests/psxreaddir/.cvsignore (added) * testsuites/psxtests/psxsem01/.cvsignore (added) * testsuites/psxtests/psxstat/.cvsignore (added) * testsuites/psxtests/psxtime/.cvsignore (added) * testsuites/psxtests/psxtimer/.cvsignore (added) * testsuites/samples/.cvsignore (added) * testsuites/samples/base_mp/.cvsignore (added) * testsuites/samples/base_mp/node1/.cvsignore (added) * testsuites/samples/base_mp/node2/.cvsignore (added) * testsuites/samples/base_sp/.cvsignore (added) * testsuites/samples/cdtest/.cvsignore (added) * testsuites/samples/hello/.cvsignore (added) * testsuites/samples/minimum/.cvsignore (added) * testsuites/samples/paranoia/.cvsignore (added) * testsuites/samples/ticker/.cvsignore (added) * testsuites/samples/unlimited/.cvsignore (added) * testsuites/sptests/.cvsignore (added) * testsuites/sptests/sp01/.cvsignore (added) * testsuites/sptests/sp02/.cvsignore (added) * testsuites/sptests/sp03/.cvsignore (added) * testsuites/sptests/sp04/.cvsignore (added) * testsuites/sptests/sp05/.cvsignore (added) * testsuites/sptests/sp06/.cvsignore (added) * testsuites/sptests/sp07/.cvsignore (added) * testsuites/sptests/sp08/.cvsignore (added) * testsuites/sptests/sp09/.cvsignore (added) * testsuites/sptests/sp11/.cvsignore (added) * testsuites/sptests/sp12/.cvsignore (added) * testsuites/sptests/sp13/.cvsignore (added) * testsuites/sptests/sp14/.cvsignore (added) * testsuites/sptests/sp15/.cvsignore (added) * testsuites/sptests/sp16/.cvsignore (added) * testsuites/sptests/sp17/.cvsignore (added) * testsuites/sptests/sp19/.cvsignore (added) * testsuites/sptests/sp20/.cvsignore (added) * testsuites/sptests/sp21/.cvsignore (added) * testsuites/sptests/sp22/.cvsignore (added) * testsuites/sptests/sp23/.cvsignore (added) * testsuites/sptests/sp24/.cvsignore (added) * testsuites/sptests/sp25/.cvsignore (added) * testsuites/sptests/sp26/.cvsignore (added) * testsuites/sptests/sp27/.cvsignore (added) * testsuites/sptests/sp28/.cvsignore (added) * testsuites/sptests/sp29/.cvsignore (added) * testsuites/sptests/spfatal/.cvsignore (added) * testsuites/sptests/spsize/.cvsignore (added) * testsuites/support/.cvsignore (added) * testsuites/support/include/.cvsignore (added) * testsuites/tmitrontests/.cvsignore (added) * testsuites/tmitrontests/include/.cvsignore (added) * testsuites/tmitrontests/tmitronsem01/.cvsignore (added) * testsuites/tmtests/.cvsignore (added) * testsuites/tmtests/include/.cvsignore (added) * testsuites/tmtests/tm01/.cvsignore (added) * testsuites/tmtests/tm02/.cvsignore (added) * testsuites/tmtests/tm03/.cvsignore (added) * testsuites/tmtests/tm04/.cvsignore (added) * testsuites/tmtests/tm05/.cvsignore (added) * testsuites/tmtests/tm06/.cvsignore (added) * testsuites/tmtests/tm07/.cvsignore (added) * testsuites/tmtests/tm08/.cvsignore (added) * testsuites/tmtests/tm09/.cvsignore (added) * testsuites/tmtests/tm10/.cvsignore (added) * testsuites/tmtests/tm11/.cvsignore (added) * testsuites/tmtests/tm12/.cvsignore (added) * testsuites/tmtests/tm13/.cvsignore (added) * testsuites/tmtests/tm14/.cvsignore (added) * testsuites/tmtests/tm15/.cvsignore (added) * testsuites/tmtests/tm16/.cvsignore (added) * testsuites/tmtests/tm17/.cvsignore (added) * testsuites/tmtests/tm18/.cvsignore (added) * testsuites/tmtests/tm19/.cvsignore (added) * testsuites/tmtests/tm20/.cvsignore (added) * testsuites/tmtests/tm21/.cvsignore (added) * testsuites/tmtests/tm22/.cvsignore (added) * testsuites/tmtests/tm23/.cvsignore (added) * testsuites/tmtests/tm24/.cvsignore (added) * testsuites/tmtests/tm25/.cvsignore (added) * testsuites/tmtests/tm26/.cvsignore (added) * testsuites/tmtests/tm27/.cvsignore (added) * testsuites/tmtests/tm28/.cvsignore (added) * testsuites/tmtests/tm29/.cvsignore (added) * testsuites/tmtests/tmck/.cvsignore (added) * testsuites/tmtests/tmoverhd/.cvsignore (added) * testsuites/tools/.cvsignore (added) * testsuites/tools/generic/.cvsignore (added) * tools/.cvsignore (added) * tools/build/.cvsignore (added) * tools/cpu/.cvsignore (added) * tools/cpu/generic/.cvsignore (added) * tools/cpu/hppa1.1/.cvsignore (added) * tools/cpu/sh/.cvsignore (added) * tools/cpu/unix/.cvsignore (added) * tools/update/.cvsignore (added) Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius [81a71b2] * c/src/lib/libbsp/m68k/mvme167/network/netexterns.h (deleted) Removed. Wed, 05 Apr 2000 13:27:52 GMT Joel Sherrill [8613479a] * c/src/lib/libbsp/m68k/mvme167/network/netexterns.h (added) New file. Copied from i386ex BSP as missing from submission. Wed, 05 Apr 2000 13:01:21 GMT Joel Sherrill [5a23ca84] * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/network/network.c (added) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (added) New files from John Cotton and Charles-Antoine ... Mon, 03 Apr 2000 19:56:54 GMT Joel Sherrill [c1c1f33] * c/src/make/leaf.cfg (added) New file from Ralf Corsepius as part of ... Wed, 01 Mar 2000 18:08:53 GMT Joel Sherrill [b6f9b5f1] * c/src/exec/score/cpu/c4x/c4xio.h (modified) * cpukit/score/cpu/c4x/c4xio.h (modified) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (modified) Added routines to get and set C3x IOF register. The code is ... Tue, 29 Feb 2000 16:35:45 GMT Joel Sherrill [8eacefcc] * c/src/exec/score/cpu/c4x/rtems/score/c4x.h (modified) * c/src/lib/libbsp/c4x/c4xsim/README (modified) * c/src/lib/libbsp/c4x/c4xsim/include/Makefile.am (modified) * c/src/lib/libbsp/c4x/shared/bspspuriousinit.c (modified) * cpukit/score/cpu/c4x/rtems/score/c4x.h (modified) * make/custom/c3xsim.cfg (modified) * make/custom/c4xsim.cfg (modified) BSP now compiles and links with CAVSL board information. This ... Mon, 28 Feb 2000 17:33:44 GMT Joel Sherrill [bc8781d] * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) Fixed typo. Tue, 22 Feb 2000 19:14:24 GMT Joel Sherrill [ac49115] * c/src/lib/libbsp/shared/setvec.c (added) New port of RTEMS to TI C3x and C4x. Tue, 22 Feb 2000 18:39:52 GMT Joel Sherrill [61ba9763] * c/src/exec/score/cpu/c4x/Makefile.am (added) * c/src/exec/score/cpu/c4x/asm.h (added) * c/src/exec/score/cpu/c4x/c4xio.h (added) * c/src/exec/score/cpu/c4x/configure.in (added) * c/src/exec/score/cpu/c4x/cpu.c (added) * c/src/exec/score/cpu/c4x/cpu_asm.S (added) * c/src/exec/score/cpu/c4x/irq.c (added) * c/src/exec/score/cpu/c4x/rtems.c (added) * c/src/exec/score/cpu/c4x/rtems/Makefile.am (added) * c/src/exec/score/cpu/c4x/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/c4x/rtems/score/c4x.h (added) * c/src/exec/score/cpu/c4x/rtems/score/c4xtypes.h (added) * c/src/exec/score/cpu/c4x/rtems/score/cpu.h (added) * c/src/exec/score/cpu/c4x/rtems/score/cpu_asm.h (added) * c/src/exec/score/cpu/c4x/rtems/score/types.h (added) * c/src/lib/libbsp/c4x/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/README (added) * c/src/lib/libbsp/c4x/c4xsim/bsp_specs (added) * c/src/lib/libbsp/c4x/c4xsim/clock/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/clock/clock.c (added) * c/src/lib/libbsp/c4x/c4xsim/configure.in (added) * c/src/lib/libbsp/c4x/c4xsim/console/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/console/console.c (added) * c/src/lib/libbsp/c4x/c4xsim/console/consolereserveresources.c (added) * c/src/lib/libbsp/c4x/c4xsim/console/debugio.c (added) * c/src/lib/libbsp/c4x/c4xsim/console/simio.c (added) * c/src/lib/libbsp/c4x/c4xsim/include/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/include/bsp.h (added) * c/src/lib/libbsp/c4x/c4xsim/include/simio.h (added) * c/src/lib/libbsp/c4x/c4xsim/start/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/start/start.S (added) * c/src/lib/libbsp/c4x/c4xsim/startup/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/startup/bspstart.c (added) * c/src/lib/libbsp/c4x/c4xsim/startup/linkcmds (added) * c/src/lib/libbsp/c4x/c4xsim/startup/spurious.c (added) * c/src/lib/libbsp/c4x/c4xsim/timer/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/timer/timer.c (added) * c/src/lib/libbsp/c4x/c4xsim/tools/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.in (added) * c/src/lib/libbsp/c4x/c4xsim/tools/runtest.in (added) * c/src/lib/libbsp/c4x/c4xsim/wrapup/Makefile.am (added) * c/src/lib/libbsp/c4x/configure.in (added) * c/src/lib/libbsp/c4x/shared/Makefile.am (added) * c/src/lib/libbsp/c4x/shared/bspspuriousinit.c (added) * c/src/lib/libbsp/c4x/shared/c3xspurious.c (added) * c/src/lib/libbsp/c4x/shared/c4xspurious.c (added) * cpukit/score/cpu/c4x/Makefile.am (added) * cpukit/score/cpu/c4x/asm.h (added) * cpukit/score/cpu/c4x/c4xio.h (added) * cpukit/score/cpu/c4x/cpu.c (added) * cpukit/score/cpu/c4x/cpu_asm.S (added) * cpukit/score/cpu/c4x/irq.c (added) * cpukit/score/cpu/c4x/rtems/asm.h (added) * cpukit/score/cpu/c4x/rtems/score/c4x.h (added) * cpukit/score/cpu/c4x/rtems/score/cpu.h (added) * cpukit/score/cpu/c4x/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/c4x/rtems/score/types.h (added) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (added) * make/custom/c3xsim.cfg (added) * make/custom/c4xsim.cfg (added) New port of RTEMS to TI C3x and C4x. Fri, 11 Feb 2000 15:54:47 GMT Joel Sherrill [562e7ed1] * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/lib/libc/imfs.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs.h (modified) Increased block size to 128 and added comments based on feedback from ... Fri, 11 Feb 2000 15:21:40 GMT Joel Sherrill [35ece2e] * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) Patch from Eric Norum based on working with Bob ... Tue, 08 Feb 2000 22:33:25 GMT Joel Sherrill [70810dc] * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * c/configure.in (modified) * c/make/Makefile.am (modified) * c/make/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/i386ex/configure.in (modified) * c/src/lib/libbsp/i386/pc386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/m68k/dmv152/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/configure.in (modified) * c/src/lib/libbsp/m68k/efi68k/configure.in (modified) * c/src/lib/libbsp/m68k/gen68302/configure.in (modified) * c/src/lib/libbsp/m68k/gen68340/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/configure.in (modified) * c/src/lib/libbsp/m68k/mvme136/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/ods68302/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips/p4000/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sh/gensh1/configure.in (modified) * c/src/lib/libbsp/sh/gensh2/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/configure.in (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libcpu/hppa1.1/configure.in (modified) * c/src/lib/libcpu/i386/configure.in (modified) * c/src/lib/libcpu/m68k/configure.in (modified) * c/src/lib/libcpu/mips/configure.in (modified) * c/src/lib/libcpu/mips64orion/configure.in (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/sh/configure.in (modified) * c/src/lib/libcpu/sparc/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/configure.in (modified) * c/src/librdbg/include/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/lib.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * configure.in (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/lib.cfg (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/cipolish (modified) * tools/update/configure.in (modified) Patches rtems-rc-20000204-0.diff from Ralf Corsepius [e06d5aed] * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) Fixed typo. Tue, 08 Feb 2000 18:26:40 GMT Joel Sherrill [a9d04b1c] * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) Patch from Eric Norum to remove race conditions ... Fri, 04 Feb 2000 16:32:38 GMT Joel Sherrill [bf24479] * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) Incorrect error status returned. Noted by Andrew Klossner ... Fri, 04 Feb 2000 16:09:38 GMT Joel Sherrill [edb2176] * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) Incorrect error status returned. Noted by Andrew Klossner ... Thu, 03 Feb 2000 22:20:41 GMT Joel Sherrill [b452a40] * c/src/exec/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semcreate.c (modified) Changed behavior to match that expected by EPICS test code. Reported ... Thu, 03 Feb 2000 13:21:38 GMT Joel Sherrill [4bf1801] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (added) * c/src/exec/libnetworking/kern/Makefile.am (added) * c/src/exec/libnetworking/lib/Makefile.am (added) * c/src/exec/libnetworking/libc/Makefile.am (added) * c/src/exec/libnetworking/machine/Makefile.am (added) * c/src/exec/libnetworking/net/Makefile.am (added) * c/src/exec/libnetworking/netinet/Makefile.am (added) * c/src/exec/libnetworking/nfs/Makefile.am (added) * c/src/exec/libnetworking/rtems/Makefile.am (added) * c/src/exec/libnetworking/sys/Makefile.am (added) * c/src/exec/libnetworking/vm/Makefile.am (added) * c/src/exec/libnetworking/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (added) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.am (added) * c/src/libnetworking/include/Makefile.in (deleted) * c/src/libnetworking/kern/Makefile.am (added) * c/src/libnetworking/kern/Makefile.in (deleted) * c/src/libnetworking/lib/Makefile.am (added) * c/src/libnetworking/lib/Makefile.in (deleted) * c/src/libnetworking/libc/Makefile.am (added) * c/src/libnetworking/libc/Makefile.in (deleted) * c/src/libnetworking/machine/Makefile.am (added) * c/src/libnetworking/net/Makefile.am (added) * c/src/libnetworking/net/Makefile.in (deleted) * c/src/libnetworking/netinet/Makefile.am (added) * c/src/libnetworking/netinet/Makefile.in (deleted) * c/src/libnetworking/nfs/Makefile.am (added) * c/src/libnetworking/nfs/Makefile.in (deleted) * c/src/libnetworking/pppd/Makefile.am (added) * c/src/libnetworking/pppd/Makefile.in (deleted) * c/src/libnetworking/rtems/Makefile.am (added) * c/src/libnetworking/rtems/Makefile.in (deleted) * c/src/libnetworking/rtems_servers/Makefile.am (added) * c/src/libnetworking/rtems_servers/Makefile.in (deleted) * c/src/libnetworking/rtems_webserver/Makefile.am (added) * c/src/libnetworking/rtems_webserver/Makefile.in (deleted) * c/src/libnetworking/sys/Makefile.am (added) * c/src/libnetworking/vm/Makefile.am (added) * c/src/libnetworking/wrapup/Makefile.am (added) * c/src/libnetworking/wrapup/Makefile.in (deleted) * cpukit/ftpd/Makefile.am (added) * cpukit/httpd/Makefile.am (added) * cpukit/httpd/Makefile.in (deleted) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (added) * cpukit/libnetworking/kern/Makefile.am (added) * cpukit/libnetworking/lib/Makefile.am (added) * cpukit/libnetworking/libc/Makefile.am (added) * cpukit/libnetworking/machine/Makefile.am (added) * cpukit/libnetworking/net/Makefile.am (added) * cpukit/libnetworking/netinet/Makefile.am (added) * cpukit/libnetworking/nfs/Makefile.am (added) * cpukit/libnetworking/rtems/Makefile.am (added) * cpukit/libnetworking/sys/Makefile.am (added) * cpukit/libnetworking/vm/Makefile.am (added) * cpukit/libnetworking/wrapup/Makefile.am (added) * cpukit/pppd/Makefile.am (added) Patches rtems-rc-20000118-7.diff from Ralf Corsepius [1382cea3] * c/src/exec/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semcreate.c (modified) Fixed spelling errors. Wed, 02 Feb 2000 15:26:41 GMT Joel Sherrill [399432fa] * c/src/lib/libbsp/bsp.am (modified) * make/custom/mcp750.cfg (modified) Patch rtems-rc-20000118-6.diff from Ralf Corsepius [847dbbe] * c/src/lib/libbsp/Makefile.am (added) * c/src/lib/libbsp/Makefile.in (deleted) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/shmdr/Makefile.am (added) * c/src/lib/libbsp/shmdr/Makefile.in (deleted) * c/src/lib/libcpu/Makefile.am (added) * c/src/lib/libcpu/Makefile.in (deleted) * c/src/lib/libcpu/configure.in (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * scripts/setup.def (modified) Patches rtems-rc-20000118-5.diff from Ralf Corsepius [8505e9b] * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) Removed references to non-existent include files. Mon, 31 Jan 2000 19:28:39 GMT Joel Sherrill [819c7da8] * c/src/librdbg/src/ptrace.c (modified) Spelling corrected. Mon, 31 Jan 2000 19:28:18 GMT Joel Sherrill [bb18b95] * c/src/librdbg/src/ptrace.c (modified) Spelling corrected. Mon, 31 Jan 2000 15:27:02 GMT Joel Sherrill [4e36a2f] * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/shared/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (added) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (added) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (added) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (added) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (added) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (deleted) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/src/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from ... Mon, 31 Jan 2000 15:22:23 GMT Joel Sherrill [8fbdf07] * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/base_sp/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) Patch rtems-rc-20000118-2.diff from Ralf Corsepius [d7269fb] * c/src/lib/libbsp/hppa1.1/simhppa/tools/stamp-h.in (deleted) * tools/build/stamp-h.in (deleted) Ralf Corsepius caught some files in CVS ... Mon, 31 Jan 2000 15:15:10 GMT Joel Sherrill [4c46630] * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libcpu/a29k/clock/ckinit.c (modified) * c/src/lib/libcpu/a29k/clock/clock.h (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/timer.c (modified) * c/src/lib/libcpu/a29k/timer/timerisr.c (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * make/custom/dmv152.cfg (modified) * make/custom/gensh2.cfg (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) Patch rtems-rc-20000118-1.diff from Ralf Corsepius [2fabda6] * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) Modification to properly support BSP aliases (pc[456]86). Mon, 31 Jan 2000 14:45:27 GMT Joel Sherrill [71aeab4d] * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) Suggested modification from Rosimildo da Silva ... Mon, 31 Jan 2000 14:43:38 GMT Joel Sherrill [49440a6e] * c/src/lib/libbsp/i386/pc386/configure.in (modified) Added AC_SUBST(RTEMS_BSP) so the makefiles properly honor the BSP ... Mon, 31 Jan 2000 14:42:18 GMT Joel Sherrill [8be7bef] * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) BSP now links although this change is untested. Fri, 28 Jan 2000 15:27:58 GMT Joel Sherrill [c01ba67] * c/src/lib/libbsp/sh/gensh2/README (modified) Patch from John M. Mills to include more ... Thu, 27 Jan 2000 14:37:17 GMT Joel Sherrill [318f591] * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * make/custom/pc686.cfg (added) Added after report from Quality Quorum that ... Wed, 26 Jan 2000 14:22:34 GMT Joel Sherrill [a1f89b4] * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/gettime.S (deleted) * c/src/lib/libcpu/a29k/timer/timer.c (modified) No longer incorrectly references mips. Wed, 26 Jan 2000 14:20:08 GMT Joel Sherrill [21677c0e] * c/src/lib/libbsp/a29k/portsw/bsp_specs (added) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (added) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (deleted) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (added) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (deleted) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (added) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (deleted) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (added) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (deleted) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (added) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (deleted) * c/src/lib/libcpu/a29k/Makefile.am (added) * c/src/lib/libcpu/a29k/clock/Makefile.am (added) * c/src/lib/libcpu/a29k/clock/ckinit.c (added) * c/src/lib/libcpu/a29k/clock/clock.S (added) * c/src/lib/libcpu/a29k/clock/clock.h (added) * c/src/lib/libcpu/a29k/configure.in (added) * c/src/lib/libcpu/a29k/timer/Makefile.am (added) * c/src/lib/libcpu/a29k/timer/gettime.S (added) * c/src/lib/libcpu/a29k/timer/timer.c (added) * c/src/lib/libcpu/a29k/timer/timerisr.c (added) Patch rtems-rc-20000118-0.diff from Ralf Corsepius [8d37343] * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/taskvariableget.c (added) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/taskvariableget.c (added) Directive rtems_task_variable_get() added by Eric Norum. Sun, 23 Jan 2000 18:29:45 GMT Joel Sherrill [41b27b94] * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/sh/gensh2/configure.in (modified) Wrong BSP referenced. Sun, 23 Jan 2000 18:22:02 GMT Joel Sherrill [f13b1c4] * c/src/exec/score/cpu/sh/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/unix/wrap/Makefile.in (deleted) Removing unused file accidentally left in CVS. Discovered by Ralf ... Fri, 21 Jan 2000 15:11:40 GMT Joel Sherrill [4a9b897] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum at the request of Jake ... Fri, 21 Jan 2000 15:07:55 GMT Joel Sherrill [c941a98] * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/tests/sptests/sp28/init.c (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * testsuites/sptests/sp28/init.c (modified) Patch from Eric Norum to implement this: ... Fri, 21 Jan 2000 14:49:31 GMT Joel Sherrill [e570c761] * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) Patch from Eric Norum to remove warnings. Fri, 21 Jan 2000 01:47:22 GMT Joel Sherrill [b9478fc6] * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) Patch from Eric Norum : Some excellent ... Fri, 14 Jan 2000 19:26:23 GMT Joel Sherrill [f8e2a94] * c/src/tests/psxtests/psxsem01/psxsem01.scn (modified) * testsuites/psxtests/psxsem01/psxsem01.scn (modified) Updated to reflect final test output. Fri, 14 Jan 2000 19:26:05 GMT Joel Sherrill [ff70333] * c/src/tests/psxtests/psxmsgq01/psxmsgq01.scn (modified) * testsuites/psxtests/psxmsgq01/psxmsgq01.scn (modified) Updated screen to reflect final test output. Fri, 14 Jan 2000 18:50:19 GMT Joel Sherrill [94a51f8b] * c/src/libnetworking/libc/Makefile.in (modified) Added -U__STRICT_ANSI__ to remove MANY warnings since the BSD code ... Fri, 14 Jan 2000 18:37:59 GMT Joel Sherrill [e49ebbfa] * c/src/exec/posix/src/mqueuesendsupp.c (modified) * c/src/exec/rtems/src/msgqreceive.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) Removed unused variable warning. Fri, 14 Jan 2000 18:37:30 GMT Joel Sherrill [4d1af20] * c/src/exec/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) Removed no prototype of kill() warning. Fri, 14 Jan 2000 17:41:20 GMT Joel Sherrill [20eb69d] * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) Now ignores minimum and does not run it. Fri, 14 Jan 2000 17:40:49 GMT Joel Sherrill [512a536] * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (deleted) Now using Makefile.am to generate this file. Fri, 14 Jan 2000 15:34:47 GMT Joel Sherrill [95f5adb] * c/src/libchip/network/dec21140.c (modified) Warning corrections per feedback from Emmanuel Raguet ... Fri, 14 Jan 2000 14:55:37 GMT Joel Sherrill [752badac] * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i960/cpu.c (modified) Removed warning. Fri, 14 Jan 2000 14:44:11 GMT Joel Sherrill [c819ea4] * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (modified) Removed numerous warnings. Thu, 13 Jan 2000 22:11:35 GMT Joel Sherrill [5890919] * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) Updated files missed in earlier batch from Eric Norum. Thu, 13 Jan 2000 22:08:29 GMT Joel Sherrill [49fa9bc] * c/src/tests/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) Fixed warnings. Thu, 13 Jan 2000 21:07:22 GMT Joel Sherrill [4c3ab846] * c/src/librdbg/configure.in (modified) * c/src/librdbg/src/awk.svc (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/i386/any/remdeb.h (added) * c/src/librdbg/src/i386/any/remdeb_svc.c (added) * c/src/librdbg/src/i386/any/remdeb_xdr.c (added) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/remdeb.h (added) * c/src/librdbg/src/powerpc/mcp750/remdeb_svc.c (added) * c/src/librdbg/src/powerpc/mcp750/remdeb_xdr.c (added) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h (added) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_svc.c (added) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c (added) Patch rtems-rc-20000104-17.diff from Ralf Corsepius [b8c9883] * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/elflinkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/start/debugreset.S (modified) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) All m68k BSPs now build with new ELF style linkcmds. Thu, 13 Jan 2000 19:32:50 GMT Joel Sherrill [11944b9b] * c/src/tests/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) POSIX message queues now include complete functionality including ... Thu, 13 Jan 2000 19:27:33 GMT Joel Sherrill [3e7a0fd] * c/src/tests/sptests/sp13/sp13.scn (modified) * c/src/tests/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/sp13.scn (modified) * testsuites/sptests/sp13/task1.c (modified) Added test case for broadcast to queue with messages pending. Thu, 13 Jan 2000 19:26:38 GMT Joel Sherrill [85d62357] * c/src/tests/psxtests/psxsem01/init.c (modified) * c/src/tests/support/include/tmacros.h (modified) * testsuites/psxtests/psxsem01/init.c (modified) * testsuites/support/include/tmacros.h (modified) Changed error checking macros for POSIX. Thu, 13 Jan 2000 19:25:15 GMT Joel Sherrill [53fb837a] * c/src/exec/itron/src/cre_mbf.c (modified) * c/src/exec/itron/src/snd_mbx.c (modified) * c/src/exec/itron/src/trcv_mbf.c (modified) * c/src/exec/itron/src/tsnd_mbf.c (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/rtems/src/msgqcreate.c (modified) * c/src/exec/rtems/src/msgqreceive.c (modified) * c/src/exec/rtems/src/msgqsubmit.c (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/macros/rtems/score/coremsg.inl (modified) * c/src/exec/score/src/coremsgbroadcast.c (modified) * c/src/exec/score/src/coremsgsubmit.c (modified) * c/src/tests/psxtests/psxmsgq01/init.c (modified) * cpukit/itron/src/cre_mbf.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/trcv_mbf.c (modified) * cpukit/itron/src/tsnd_mbf.c (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsubmit.c (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/macros/rtems/score/coremsg.inl (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) POSIX message queues now include complete functionality including ... Thu, 13 Jan 2000 19:23:59 GMT Joel Sherrill [ee4ddd83] * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (deleted) Missed removing this file in an earlier commit. This is removed ... Thu, 13 Jan 2000 18:32:38 GMT Jennifer Averett [9c1c778d] * c/src/exec/score/src/coremsgclose.c (modified) * c/src/exec/score/src/coremsgflush.c (modified) * c/src/exec/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) + Added comments Thu, 13 Jan 2000 18:32:09 GMT Jennifer Averett [d65c3768] * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/coremsgflushwait.c (added) * c/src/exec/score/src/coremsginsert.c (added) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/coremsgflushwait.c (added) * cpukit/score/src/coremsginsert.c (added) + Added and yellow line tested ... Thu, 13 Jan 2000 18:23:42 GMT Jennifer Averett [e7d76dc] * c/src/exec/score/src/coremutexsurrender.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) Added comment. Thu, 13 Jan 2000 18:22:32 GMT Jennifer Averett [d78c6fe3] * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuenametoid.c (modified) * c/src/exec/posix/src/mqueueopen.c (modified) * c/src/exec/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuenametoid.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) + Comment cleanup Thu, 13 Jan 2000 18:22:09 GMT Jennifer Averett [661ff9a] * c/src/exec/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) Removed referance to rtems error. Added correct include file. Thu, 13 Jan 2000 17:13:12 GMT Jennifer Averett [b0461cd4] * c/src/exec/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semcreate.c (modified) Added comment to indicate this path does not occur. Thu, 13 Jan 2000 17:01:35 GMT Jennifer Averett [0724b658] * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp28/sp28.scn (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp28/sp28.scn (modified) Added start and end herald. Thu, 13 Jan 2000 15:07:03 GMT Joel Sherrill [9b2c969] * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/start/start.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (added) * c/src/lib/libbsp/m68k/shared/start.S (modified) Made sweep of changes to get all BSPs to the same point on the ... Thu, 13 Jan 2000 15:06:24 GMT Joel Sherrill [c0ebf02] * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) New patch from Eric Norum plus some minor mods by Joel. Thu, 13 Jan 2000 14:28:10 GMT Joel Sherrill [e60d75d] * c/src/lib/libbsp/shared/bsplibc.c (modified) Fixed spacing. Thu, 13 Jan 2000 14:05:11 GMT Joel Sherrill [bd9e482a] * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) Made _clear_end a "PROVIDE." Wed, 12 Jan 2000 20:22:04 GMT Jennifer Averett [ea2c1d6] * c/src/exec/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgseize.c (modified) + Added code for waiting send + Yellow lined tested routine with ... Wed, 12 Jan 2000 18:47:22 GMT Jennifer Averett [e38cb52] * c/src/exec/posix/src/mqueuesendsupp.c (modified) * c/src/exec/posix/src/mqueuesetattr.c (modified) * c/src/exec/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) Debugged and yellow line tested routines. Wed, 12 Jan 2000 18:46:54 GMT Jennifer Averett [68b05694] * c/src/exec/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) + Modified return codes + Added messsage size check + Debugged and ... Wed, 12 Jan 2000 18:44:19 GMT Jennifer Averett [bcbc50a] * c/src/exec/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) + Added signal processing. + Yellow line tested source. Wed, 12 Jan 2000 18:43:21 GMT Jennifer Averett [352d01e] * c/src/exec/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) + Modified to correct return codes. + Removed extra flag attribute ... Wed, 12 Jan 2000 18:41:14 GMT Jennifer Averett [70329c80] * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) + Changed call from core flush to core close routine. This flushes ... Wed, 12 Jan 2000 18:40:18 GMT Jennifer Averett [399ba06] * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) + Removed name validation code (this was already done in nametoid. Wed, 12 Jan 2000 17:58:34 GMT Joel Sherrill [c1d2cc9] * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (added) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) Patch rtems-rc-20000104-16.diff from Ralf Corsepius [b2b4835] * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) Eric Norum submitted linker script and bsp_specs ...
