# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 13:15:16 Fri, 15 Dec 2006 05:56:01 GMT Ralf Corsepius [18c0e30] * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) 2006-12-15 Ralf Corsépius * ... Fri, 15 Dec 2006 05:53:50 GMT Ralf Corsepius [cdf41adb] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) 2006-12-15 Ralf Corsépius * ... Fri, 15 Dec 2006 05:48:16 GMT Ralf Corsepius [bb2a2253] * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) 2006-12-15 Ralf Corsépius * ... Fri, 15 Dec 2006 05:48:07 GMT Ralf Corsepius [7a5265ff] * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb337/network/network.c (modified) * c/src/lib/libbsp/i386/i386ex/network/network.c (modified) Use ioctl_command_t. Fri, 15 Dec 2006 05:46:15 GMT Ralf Corsepius [9994f29] * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) 2006-12-15 Ralf Corsépius * ... Fri, 15 Dec 2006 05:44:51 GMT Ralf Corsepius [2a0951e5] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) 2006-12-15 Ralf Corsépius * ... Fri, 15 Dec 2006 04:37:55 GMT Till Straumann [215e019] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) * startup/bspstart.c: Changed BSP_installVME_isr() so that ... Thu, 14 Dec 2006 23:13:07 GMT Till Straumann [0c3167b] * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h (modified) * m68k/mcf5282/include/mcf5282.h: added __may_alias__ ... Thu, 14 Dec 2006 23:11:08 GMT Till Straumann [fd8f417] * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h (modified) 2006-12-14 Till Straumann ... Thu, 14 Dec 2006 12:22:49 GMT Joel Sherrill [7c3b2dd3] * c/src/lib/libbsp/shared/ChangeLog (modified) Fixed line length -- must be < 80. Thu, 14 Dec 2006 07:24:56 GMT Ralf Corsepius [df591b5] * c/src/ChangeLog (modified) 2006-12-14 Ralf Corsépius * ... Thu, 14 Dec 2006 07:24:39 GMT Ralf Corsepius [bd20bc8] * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/if_fxp.c (modified) Use ioctl_command_t as ioctl argument. Thu, 14 Dec 2006 05:45:58 GMT Ralf Corsepius [0efdeff] * c/src/lib/libbsp/arm/ChangeLog (modified) 2006-12-14 Ralf Corsépius * ... Thu, 14 Dec 2006 05:45:51 GMT Ralf Corsepius [2bced8f] * c/src/lib/libbsp/arm/shared/irq/irq_init.c (modified) Remove unused var. Wed, 13 Dec 2006 22:03:42 GMT Till Straumann [60b8e96] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (modified) * mvme5500/Makefile.am, mvme5500/preinstall.am: need to ... Wed, 13 Dec 2006 21:53:54 GMT Till Straumann [ff221cf4] * c/src/lib/libbsp/powerpc/ChangeLog (modified) 2006-12-13 Till Straumann ... Wed, 13 Dec 2006 20:50:20 GMT Till Straumann [de8174fe] * c/src/lib/libbsp/powerpc/shared/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c (modified) 2006-12-13 Till Straumann ... Wed, 13 Dec 2006 20:04:05 GMT Till Straumann [afd4c7b] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vme_am_defs.h (modified) * vmeUniverse/vme_am_defs.h: Added address modifiers for 2eVME. Added ... Wed, 13 Dec 2006 15:52:00 GMT Joel Sherrill [600a241e] * c/src/ChangeLog (modified) * c/src/librtems++/include/rtems++/rtemsEvent.h (modified) * c/src/librtems++/include/rtems++/rtemsMessageQueue.h (modified) * c/src/librtems++/include/rtems++/rtemsSemaphore.h (modified) * c/src/librtems++/include/rtems++/rtemsTask.h (modified) * c/src/librtems++/src/rtemsEvent.cc (modified) * c/src/librtems++/src/rtemsMessageQueue.cc (modified) * c/src/librtems++/src/rtemsSemaphore.cc (modified) * c/src/librtems++/src/rtemsTask.cc (modified) 2006-12-13 Joel Sherrill * ... Wed, 13 Dec 2006 14:48:55 GMT Joel Sherrill [5e11c97] * c/src/ChangeLog (modified) * c/src/optman/rtems/no-msg.c (modified) 2006-12-13 Joel Sherrill PR ... Wed, 13 Dec 2006 14:46:41 GMT Joel Sherrill [460cd5b7] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) 2006-12-13 Joel Sherrill PR ... Wed, 13 Dec 2006 14:43:44 GMT Ralf Corsepius [0ab63e50] * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c (modified) 2006-12-13 Ralf Corsépius * ... Wed, 13 Dec 2006 12:35:01 GMT Joel Sherrill [71ce7e7] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) 2006-12-13 Alexey Shamrin PR ... Wed, 13 Dec 2006 05:39:19 GMT Ralf Corsepius [294de470] * c/src/ChangeLog (modified) * cpukit/ChangeLog (modified) 2006-12-13 Ralf Corsépius * ... Wed, 13 Dec 2006 05:37:07 GMT Ralf Corsepius [b25d6119] * c/src/aclocal/rtems-ampolish.m4 (modified) * cpukit/aclocal/rtems-ampolish.m4 (modified) Use am_aux_dir/ampolish3. Wed, 13 Dec 2006 02:21:10 GMT Ralf Corsepius [062f6705] * c/src/ChangeLog (modified) 2006-12-12 Ralf Corsépius * ... Wed, 13 Dec 2006 02:20:29 GMT Ralf Corsepius [a7529ced] * c/src/aclocal/project-root.m4 (modified) Require RTEMS_AMPOLISH. Wed, 13 Dec 2006 02:19:13 GMT Ralf Corsepius [4db0f6f3] * c/src/aclocal/rtems-top.m4 (modified) Remove RTEMS_AMPOLISH. Wed, 13 Dec 2006 02:18:46 GMT Ralf Corsepius [ff01b21f] * c/src/aclocal/rtems-ampolish.m4 (modified) Require AM_MAINTAINER_MODE. Tue, 12 Dec 2006 14:48:05 GMT Ralf Corsepius [6b1e9217] * c/src/lib/libcpu/nios2/ChangeLog (modified) 2006-12-12 Ralf Corsépius * ... Tue, 12 Dec 2006 14:47:57 GMT Ralf Corsepius [f1d96dbd] * c/src/lib/libcpu/nios2/configure.ac (modified) Add RTEMS_AMPOLISH3. Tue, 12 Dec 2006 10:43:30 GMT Ralf Corsepius [34e7be2] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) 2006-12-12 Ralf Corsépius * ... Tue, 12 Dec 2006 10:26:29 GMT Ralf Corsepius [0b933d6a] * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) 2006-12-12 Ralf Corsépius * ... Tue, 12 Dec 2006 10:26:18 GMT Ralf Corsepius [ec76139c] * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) Use uint32_t instead of unsigned32. Tue, 12 Dec 2006 10:24:26 GMT Ralf Corsepius [4ce019ce] * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) 2006-12-12 Ralf Corsépius * ... Tue, 12 Dec 2006 10:24:16 GMT Ralf Corsepius [1408ea8d] * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) * c/src/lib/libbsp/sparc/leon2/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c (modified) * c/src/lib/libbsp/sparc/leon3/timer/timer.c (modified) Use uint32_t instead of rtems_unsigned32/unsigned32. Tue, 12 Dec 2006 10:22:18 GMT Ralf Corsepius [b8e42a76] * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) 2006-12-12 Ralf Corsépius * ... Sat, 02 Dec 2006 06:06:55 GMT Ralf Corsepius [fcb0cd46] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/bfin/ChangeLog (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/nios2/ChangeLog (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/tools/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/ChangeLog (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/apt-conf/ChangeLog (modified) * contrib/apt-conf/configure.ac (modified) * contrib/crossrpms/ChangeLog (modified) * contrib/crossrpms/configure.ac (modified) * contrib/repo-conf/ChangeLog (modified) * contrib/repo-conf/configure.ac (modified) * contrib/rtemsrpms/ChangeLog (modified) * contrib/rtemsrpms/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/ChangeLog (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2006-12-02 Ralf Corsépius * ... Thu, 30 Nov 2006 16:05:50 GMT Joel Sherrill [fe6f68c] * c/src/lib/libbsp/shared/ChangeLog (modified) Fix formatting. Thu, 30 Nov 2006 02:28:49 GMT Till Straumann [43ea369] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (modified) * vmeUniverse/vmeTsi148.h: user now must define a symbol for the ... Mon, 20 Nov 2006 05:51:08 GMT Ralf Corsepius [c73ba8b5] * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (modified) Regenerate. Mon, 20 Nov 2006 05:50:22 GMT Ralf Corsepius [f6670ed1] * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/include/coverhd.h (deleted) 2006-11-20 Ralf Corsépius * ... Mon, 20 Nov 2006 05:47:35 GMT Ralf Corsepius [d17f2b5] * c/src/ChangeLog (modified) * c/src/Makefile.am (modified) 2006-11-20 Ralf Corsépius * ... Fri, 17 Nov 2006 23:08:55 GMT Joel Sherrill [76ce226] * c/src/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) 2006-11-17 Joel Sherrill * ... Fri, 17 Nov 2006 22:46:31 GMT Joel Sherrill [3ca2768] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) 2006-11-17 Joel Sherrill * ... Fri, 17 Nov 2006 22:46:22 GMT Joel Sherrill [d89bfb3] * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) 2006-11-17 Joel Sherrill * ... Fri, 17 Nov 2006 22:44:10 GMT Joel Sherrill [3664346e] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/clock_driver_stub.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.c (modified) 2006-11-17 Joel Sherrill * ... Fri, 17 Nov 2006 22:42:54 GMT Joel Sherrill [ad19e3c] * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/psim (modified) * c/src/lib/libbsp/powerpc/psim/tools/psim-gdb (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) 2006-11-17 Joel Sherrill * psim, ... Fri, 17 Nov 2006 22:42:18 GMT Joel Sherrill [248b6a4] * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/runtest (modified) 2006-11-17 Joel Sherrill * runtest: ... Fri, 17 Nov 2006 22:41:41 GMT Joel Sherrill [461c9167] * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) 2006-11-17 Joel Sherrill * ... Thu, 16 Nov 2006 16:31:38 GMT Joel Sherrill [9824dafe] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/bspstart.c (modified) * c/src/lib/libbsp/sparc/shared/start.S (modified) 2006-11-16 Joel Sherrill * ... Thu, 16 Nov 2006 16:31:36 GMT Joel Sherrill [29d1fce] * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) 2006-11-16 Joel Sherrill * ... Thu, 16 Nov 2006 16:31:34 GMT Joel Sherrill [2d4b256] * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) 2006-11-16 Joel Sherrill * ... Thu, 16 Nov 2006 16:31:32 GMT Joel Sherrill [74b09f1] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) 2006-11-16 Joel Sherrill * ... Wed, 15 Nov 2006 15:24:01 GMT Joel Sherrill [aa4369c] * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) 2006-11-15 Joel Sherrill * ... Wed, 15 Nov 2006 15:21:24 GMT Joel Sherrill [920fb9c] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) 2006-11-15 Joel Sherrill * ... Wed, 15 Nov 2006 15:21:12 GMT Joel Sherrill [9b86dabd] * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) 2006-11-15 Joel Sherrill * ... Wed, 15 Nov 2006 15:20:05 GMT Joel Sherrill [66d973ff] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/main.c (deleted) 2006-11-15 Joel Sherrill * ... Wed, 15 Nov 2006 14:35:56 GMT Ralf Corsepius [3b6c332] * c/src/ChangeLog (modified) 2006-11-15 Ralf Corsépius * ... Wed, 15 Nov 2006 14:35:15 GMT Ralf Corsepius [498057d] * c/src/ampolish3 (deleted) Remove. Wed, 15 Nov 2006 14:34:44 GMT Ralf Corsepius [4b02af0] * c/src/aclocal/rtems-top.m4 (modified) Add RTEMS_AMPOLISH3. Wed, 15 Nov 2006 14:34:23 GMT Ralf Corsepius [633bae4] * c/src/aclocal/rtems-ampolish.m4 (modified) Pick up ampolish3 from ac_aux_dir. Wed, 15 Nov 2006 14:34:00 GMT Ralf Corsepius [d4e28828] * c/src/aclocal/bsp-configure.m4 (modified) AC_PREREQ(2.60). Remove checks for AMPOLISH3. Wed, 15 Nov 2006 14:33:30 GMT Ralf Corsepius [7a00d74e] * c/src/configure.ac (modified) Remove RTEMS_AMPOLISH3. Wed, 15 Nov 2006 11:03:09 GMT Ralf Corsepius [64d01b9] * c/src/lib/libcpu/nios2/preinstall.am (modified) * cpukit/score/cpu/nios2/preinstall.am (modified) Regenerate. Wed, 15 Nov 2006 09:55:27 GMT Ralf Corsepius [e4a0c4e] * c/src/ChangeLog (modified) * c/src/aclocal/target.m4 (modified) 2006-11-15 Ralf Corsépius * ... Wed, 15 Nov 2006 09:47:09 GMT Ralf Corsepius [7198611] * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) 2006-11-15 Ralf Corsépius * ... Wed, 15 Nov 2006 06:29:07 GMT Ralf Corsepius [f8235c07] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/configure.ac (modified) 2006-11-15 Ralf Corsépius * ... Sat, 11 Nov 2006 05:12:05 GMT Ralf Corsepius [78897bc] * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/linkcmds (modified) 2006-11-11 Ralf Corsépius * ... Sat, 11 Nov 2006 05:09:26 GMT Ralf Corsepius [21a7c424] * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/linkcmds (modified) 2006-11-10 Alain Schaefer * ... Wed, 01 Nov 2006 16:06:03 GMT Joel Sherrill [e1d578d8] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/bsp_specs (modified) 2006-11-01 Joel Sherrill * ... Mon, 30 Oct 2006 22:23:46 GMT Joel Sherrill [550d13e] * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/startup/rtems-ctor.cc (modified) 2006-10-30 Joel Sherrill * ... Mon, 30 Oct 2006 16:56:10 GMT Joel Sherrill [842a8fe1] * c/src/lib/libbsp/bfin/.cvsignore (added) * c/src/lib/libbsp/bfin/ChangeLog (modified) 2006-10-30 Joel Sherrill * ... Mon, 30 Oct 2006 16:53:54 GMT Joel Sherrill [b174ee8] * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/bsp_specs (modified) * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/bsp_specs (modified) 2006-10-30 Joel Sherrill * ... Thu, 26 Oct 2006 13:47:07 GMT Joel Sherrill [7ced9142] * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/configure (deleted) * c/src/lib/libbsp/bfin/eZKit533/include/bspopts.h.in (deleted) 2006-10-26 Joel Sherrill * ... Tue, 24 Oct 2006 20:25:23 GMT Joel Sherrill [f6f79332] * c/src/lib/libbsp/bfin/ChangeLog (modified) * c/src/lib/libbsp/bfin/shared/start/start.S (modified) 2006-10-24 Joel Sherrill * ... Tue, 24 Oct 2006 20:24:44 GMT Joel Sherrill [c959c32] * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) 2006-10-24 Joel Sherrill * ... Tue, 24 Oct 2006 20:21:24 GMT Joel Sherrill [1e28c89c] * c/src/lib/libbsp/bfin/ChangeLog (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/bfin/shared/start/start.S (modified) 2006-10-24 Alain Schaefer * ... Mon, 23 Oct 2006 19:39:05 GMT Joel Sherrill [bb932d4] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2006-10-23 Joel Sherrill * ... Mon, 23 Oct 2006 19:38:12 GMT Joel Sherrill [8d41236] * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/bfin/ChangeLog (added) * c/src/lib/libbsp/bfin/Makefile.am (added) * c/src/lib/libbsp/bfin/acinclude.m4 (added) * c/src/lib/libbsp/bfin/configure.ac (added) * c/src/lib/libbsp/bfin/eZKit533/.cvsignore (added) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (added) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (added) * c/src/lib/libbsp/bfin/eZKit533/README (added) * c/src/lib/libbsp/bfin/eZKit533/bsp_specs (added) * c/src/lib/libbsp/bfin/eZKit533/configure (added) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (added) * c/src/lib/libbsp/bfin/eZKit533/console/console-io.c (added) * c/src/lib/libbsp/bfin/eZKit533/include/.cvsignore (added) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (added) * c/src/lib/libbsp/bfin/eZKit533/include/bspopts.h.in (added) * c/src/lib/libbsp/bfin/eZKit533/include/coverhd.h (added) * c/src/lib/libbsp/bfin/eZKit533/include/tm27.h (added) * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (added) * c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c (added) * c/src/lib/libbsp/bfin/eZKit533/startup/linkcmds (added) * c/src/lib/libbsp/bfin/eZKit533/times (added) * c/src/lib/libbsp/bfin/shared/clock/clockdrv.c (added) * c/src/lib/libbsp/bfin/shared/clock/rtc.c (added) * c/src/lib/libbsp/bfin/shared/clock/tod.h (added) * c/src/lib/libbsp/bfin/shared/console/console.c (added) * c/src/lib/libbsp/bfin/shared/start/start.S (added) * c/src/lib/libbsp/bfin/shared/timer/timer.c (added) 2006-10-23 Joel Sherrill * ... Fri, 20 Oct 2006 06:21:46 GMT Ralf Corsepius [04cc8d1] * c/src/lib/libbsp/arm/gba/include/.cvsignore (added) * c/src/lib/libbsp/m68k/av5282/include/.cvsignore (added) * c/src/lib/libbsp/m68k/uC5282/include/.cvsignore (added) * c/src/lib/libbsp/nios2/nios2_iss/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/mvme5500/include/.cvsignore (added) New. Fri, 20 Oct 2006 06:15:12 GMT Ralf Corsepius [bcadcc84] * c/src/lib/libbsp/arm/gba/include/bspopts.h.in (deleted) * c/src/lib/libbsp/m68k/av5282/include/bspopts.h.in (deleted) * c/src/lib/libbsp/m68k/uC5282/include/bspopts.h.in (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/bspopts.h.in (deleted) * c/src/lib/libbsp/powerpc/mvme5500/include/bspopts.h.in (deleted) Remove (bogus). Thu, 19 Oct 2006 19:20:50 GMT Joel Sherrill [24029b2] * c/src/lib/libbsp/shared/ChangeLog (modified) Fix comment. Thu, 19 Oct 2006 19:18:20 GMT Joel Sherrill [e307735] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) 2006-10-19 Joel Sherrill * ... Thu, 19 Oct 2006 19:16:20 GMT Joel Sherrill [9a60096b] * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (modified) 2006-10-19 Joel Sherrill * ... Thu, 19 Oct 2006 19:16:19 GMT Joel Sherrill [98339b8c] * c/src/lib/libbsp/shared/ChangeLog (modified) 2006-10-19 Joel Sherrill * ... Wed, 18 Oct 2006 11:56:36 GMT Ralf Corsepius [104ff62] * c/src/ChangeLog (modified) * c/src/automake/compile.am (modified) 2006-10-18 Ralf Corsépius * ... Wed, 18 Oct 2006 03:37:19 GMT Ralf Corsepius [9b5e72b] * ChangeLog (modified) * aclocal/rtems-top.m4 (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/aclocal/version.m4 (modified) 2006-10-18 Ralf Corsépius * ... Tue, 17 Oct 2006 17:12:18 GMT Ralf Corsepius [6436036c] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/LICENSE (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 17:09:33 GMT Ralf Corsepius [4f5e472] * c/src/ChangeLog (modified) * c/src/aclocal/prog-ccas.m4 (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 17:06:38 GMT Ralf Corsepius [d6a6cff2] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cxx.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/prog-cxx.m4 (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 15:49:31 GMT Ralf Corsepius [2e28876] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 08:58:44 GMT Ralf Corsepius [57357d9] * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 07:38:02 GMT Ralf Corsepius [ba2c04f] * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * cpukit/ChangeLog (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/ChangeLog (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 06:35:01 GMT Ralf Corsepius [11c60096] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/nios2/ChangeLog (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/tools/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/ChangeLog (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 06:21:56 GMT Ralf Corsepius [754610f] * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 02:42:28 GMT Ralf Corsepius [2c278a4] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 02:40:57 GMT Ralf Corsepius [1af911b8] * c/src/lib/libbsp/powerpc/gen5200/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.h (modified) * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen5200/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/gen5200/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/gen5200/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/m93cxx.h (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.c (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.h (modified) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c (modified) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen5200/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/gen5200/vectors/vectors_init.c (modified) Convert to utf-8. Tue, 17 Oct 2006 02:35:27 GMT Ralf Corsepius [748bc60] * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 02:35:11 GMT Ralf Corsepius [ca97282] * c/src/lib/libbsp/m68k/gen68340/include/m68349.inc (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (modified) Convert to utf-8
