# # ChangeLog for c in rtems # # Generated by Trac 1.2.1.dev0 # 05/20/24 10:09:20 Tue, 24 Apr 2012 12:03:09 GMT Sebastian Huber [05a20c1f] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.gwlcfm (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5566evb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674fevb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.phycore_mpc5554 (modified) bsp/mpc55xxevb: Enable stack allocator Tue, 24 Apr 2012 12:00:54 GMT Sebastian Huber [3c6d7ae] * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/include/stackalloc.h (modified) * c/src/lib/libbsp/shared/src/stackalloc.c (modified) bsps/stackalloc: Use stack section symbols Tue, 24 Apr 2012 11:34:03 GMT Sebastian Huber [d1018534] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.gwlcfm (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5566evb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc55xx (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674fevb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.phycore_mpc5554 (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.xkt564levb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_core_0 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_core_1 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_p1020rdb (modified) * c/src/lib/libbsp/powerpc/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Add no cache section Tue, 24 Apr 2012 09:21:46 GMT Sebastian Huber [13a8b19] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-early.c (modified) bsp/mpc55xxevb: Change early MMU settings Add internal SRAM ... Mon, 23 Apr 2012 08:44:47 GMT Sebastian Huber [c24d9823] * c/src/lib/libbsp/arm/lpc24xx/include/io.h (modified) bsp/lpc24xx: Fix define name Fri, 20 Apr 2012 13:29:00 GMT Sebastian Huber [d2c665b7] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) bsps/arm: Make the Clock_isr() static again Fri, 20 Apr 2012 13:23:44 GMT Sebastian Huber [37f938d7] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) bsps: Avoid rtems_irq_hdl_param type usage Not every clock ... Fri, 20 Apr 2012 12:03:39 GMT Sebastian Huber [6d136ed9] * c/src/lib/libbsp/m68k/genmcf548x/startup/bspstart.c (modified) bsp/genmcf548x: Enable FPU in BSP startup code Fri, 20 Apr 2012 11:14:58 GMT Sebastian Huber [ca4a4cf] * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) bsp/genmcf548x: Fix BSP options Fri, 20 Apr 2012 07:20:17 GMT Sebastian Huber [64c44c1] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) bsps/arm: Remove superfluous include Thu, 19 Apr 2012 18:16:33 GMT Joel Sherrill [1a3cbfba] * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) s3c24xx shared: Clock driver clean up and ISR Handler Prototype ... Thu, 19 Apr 2012 18:16:20 GMT Joel Sherrill [abb52ce] * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) pxa255 shared: Clock driver clean up and ISR Handler Prototype ... Thu, 19 Apr 2012 18:16:09 GMT Joel Sherrill [bb9cf58d] * c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c (modified) mc9328mxl shared: Clock driver clean up and ISR Handler Prototype ... Thu, 19 Apr 2012 18:15:49 GMT Joel Sherrill [029ced28] * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) lpc22xx shared: Clock driver clean up and ISR Handler Prototype ... Thu, 19 Apr 2012 18:15:34 GMT Joel Sherrill [1401076] * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) at91rm9200 shared: Clock driver clean up and ISR Handler Prototype ... Thu, 19 Apr 2012 18:15:17 GMT Joel Sherrill [b2d9478] * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) lpc shared: Clock driver clean up and ISR Handler Prototype Correction. Thu, 19 Apr 2012 18:15:03 GMT Joel Sherrill [556ac5a] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) armv7m shared: Clock driver clean up and ISR Handler Prototype ... Thu, 19 Apr 2012 17:52:46 GMT Joel Sherrill [b7a4a38] * c/src/lib/libbsp/arm/nds/clock/clock.c (modified) nds: Clock driver clean up and ISR Handler Prototype Correction. Thu, 19 Apr 2012 17:51:53 GMT Joel Sherrill [e1f81100] * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (modified) gba: Clock driver clean up and ISR Handler Prototype Correction. Thu, 19 Apr 2012 17:51:03 GMT Joel Sherrill [7867bbd] * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) edb7312: Clock driver clean up and ISR Handler Prototype Correction. Thu, 19 Apr 2012 18:11:18 GMT Joel Sherrill [46cbefd8] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) Clock Driver Shell - Correct PIC IRQ Prototype. Thu, 19 Apr 2012 17:34:28 GMT Daniel Hellstrom [e621bde] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (moved) LEON3: rename console/debugputs.c to printk_support.c Thu, 19 Apr 2012 13:21:25 GMT Daniel Hellstrom [5d48037] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) LEON3: added TX-wait-complete and CR on NL support for UART ... Thu, 19 Apr 2012 13:21:24 GMT Daniel Hellstrom [605b4b64] * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) LEON3: debugputs removed pointless isinit code, invoked only once ... Thu, 19 Apr 2012 13:21:23 GMT Daniel Hellstrom [5903484] * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) LEON3: debugputs added printk mem buffer when no UART present ... Thu, 19 Apr 2012 13:46:10 GMT Daniel Hellstrom [62694fd] * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) LEON3: add console interrupt mode support The comment in ... Thu, 19 Apr 2012 13:21:21 GMT Daniel Hellstrom [07557c8] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) LEON3: add console attributes such as parity and baudrate ... Thu, 19 Apr 2012 13:21:20 GMT Daniel Hellstrom [6845f80] * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) LEON3: console, lower bus utilization waiting for UART TX ready ... Tue, 17 Apr 2012 14:25:42 GMT Daniel Hellstrom [7a01a888] * c/src/lib/libbsp/sparc/leon2/cchip/cchip.c (modified) * c/src/lib/libbsp/sparc/leon2/rasta/rasta.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553brm.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c (modified) * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) * c/src/lib/libbsp/sparc/shared/can/occan_pci.c (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm.h (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) * c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/include/grspw.h (modified) * c/src/lib/libbsp/sparc/shared/include/grspw_pci.h (modified) * c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/include/i2cmst.h (modified) * c/src/lib/libbsp/sparc/shared/include/occan.h (modified) * c/src/lib/libbsp/sparc/shared/include/occan_pci.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c (modified) LEON: updated drivers to use new AMBAPP Layer The drivers are ... Tue, 17 Apr 2012 14:25:41 GMT Daniel Hellstrom [fc6f872] * c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c (modified) * c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c (modified) * c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c (modified) LEON3: Network initialization code updated to new AMBAPP layer ... Tue, 17 Apr 2012 14:25:40 GMT Daniel Hellstrom [ddf0d60] * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/leon3/include/amba.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) LEON3: updated console driver for new AMBAPP layer Signed-off-by: ... Tue, 17 Apr 2012 14:25:39 GMT Daniel Hellstrom [1f7cfbe3] * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) LEON2: clock driver use new AMBAPP layer Signed-off-by: Daniel ... Tue, 17 Apr 2012 14:25:38 GMT Daniel Hellstrom [9ea65119] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/include/amba.h (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c (added) * c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c (added) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h (added) LEON: updated AMBA PnP API The old layer had some ... Mon, 16 Apr 2012 23:35:25 GMT Gedare Bloom [e99dbaa] * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) no_cpu: replace no_cpu_isr with rtems_isr Mon, 16 Apr 2012 02:28:14 GMT Gedare Bloom [a114011d] * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/shared/startup/setvec.c (deleted) lm32: use shared setvec.c Mon, 16 Apr 2012 02:26:41 GMT Gedare Bloom [06d34af] * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (deleted) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) m68k: use shared setvec.c Mon, 16 Apr 2012 02:23:59 GMT Gedare Bloom [416f1efb] * c/src/lib/libbsp/lm32/shared/startup/setvec.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/libchip/network/open_eth.c (modified) * cpukit/score/cpu/lm32/rtems/score/types.h (modified) lm32: replace lm32_isr with rtems_isr Mon, 16 Apr 2012 02:22:36 GMT Gedare Bloom [1fec9e0] * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/startup/init68340.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/start/start.S (modified) * c/src/lib/libbsp/m68k/mrm332/startup/start_c.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/README (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/libchip/network/open_eth.c (modified) * c/src/libchip/network/sonic.c (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) m68k: replace m68k_isr with rtems_isr Sun, 15 Apr 2012 19:15:22 GMT Sebastian Huber [7be19f8] * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/console/usart.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/io.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/rcc.h (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/io.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/rcc.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/start-config-io.c (added) bsp/stm32f4: API changes Thu, 12 Apr 2012 19:27:56 GMT Sebastian Huber [228ece9] * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (modified) * c/src/lib/libbsp/arm/stm32f4/console/usart.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/io.h (added) * c/src/lib/libbsp/arm/stm32f4/include/rcc.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h (modified) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/startup/io.c (added) * c/src/lib/libbsp/arm/stm32f4/startup/rcc.c (added) bsp/stm32f4: Add IO and RCC Tue, 10 Apr 2012 19:12:23 GMT Daniel Hellstrom [7afcb26] * c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c (modified) PR2052: LEON3: fix open_eth interrupt initialization bug Fixed a ... Thu, 29 Mar 2012 19:23:14 GMT Sebastian Huber [e230fb4] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (added) * c/src/lib/libbsp/arm/stm32f4/README (added) * c/src/lib/libbsp/arm/stm32f4/bsp_specs (added) * c/src/lib/libbsp/arm/stm32f4/configure.ac (added) * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (added) * c/src/lib/libbsp/arm/stm32f4/console/usart.c (added) * c/src/lib/libbsp/arm/stm32f4/include/bsp.h (added) * c/src/lib/libbsp/arm/stm32f4/include/irq.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h (added) * c/src/lib/libbsp/arm/stm32f4/include/usart.h (added) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4.cfg (added) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (added) * c/src/lib/libbsp/arm/stm32f4/startup/bspreset.c (added) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (added) * c/src/lib/libbsp/arm/stm32f4/startup/bspstarthook.c (added) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f4 (added) bsp/stm32f4: New BSP Mon, 26 Mar 2012 16:41:45 GMT Sebastian Huber [d8f05c83] * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY Mon, 26 Mar 2012 16:40:31 GMT Sebastian Huber [5ea637ed] * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT Sat, 07 Apr 2012 17:07:04 GMT Sebastian Huber [1aebb70] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) bsps: Update due to API changes Thu, 05 Apr 2012 15:23:17 GMT Daniel Hellstrom [7499b84] * c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c (modified) * c/src/libchip/network/greth.c (modified) * c/src/libchip/network/greth.h (modified) GRETH: use shared-irq service instead of BSP specific set_vec() The ... Thu, 05 Apr 2012 15:23:16 GMT Daniel Hellstrom [0f04edd] * c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c (modified) * c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c (modified) * c/src/libchip/network/smc91111.c (modified) * c/src/libchip/network/smc91111exp.h (modified) SMC91111: updated to use shared IRQ service Signed-off-by: Daniel ... Fri, 06 Apr 2012 14:09:35 GMT Joel Sherrill [c500cbc] * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) LEON3 - Fix spacing Thu, 05 Apr 2012 15:23:21 GMT Daniel Hellstrom [3722ff5a] * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) LEON3: added IRQAMP support Thu, 05 Apr 2012 15:23:20 GMT Daniel Hellstrom [684b54a] * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) LEON3: halt boot if IRQ controller not found Signed-off-by: Daniel ... Fri, 06 Apr 2012 10:05:07 GMT Daniel Hellstrom [95518e59] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (added) * c/src/lib/libbsp/sparc/erc32/include/erc32.h (modified) * c/src/lib/libbsp/sparc/erc32/preinstall.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c (added) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h (added) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c (added) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (added) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c (added) * c/src/lib/libbsp/sparc/leon3/startup/eirq.c (added) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (added) SPARC BSPs: implemented shared-irq using libbsp/shared layer The ... Thu, 05 Apr 2012 15:23:19 GMT Daniel Hellstrom [e60e862] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) LEON3: console use register pointers instead of UART indexes ... Thu, 05 Apr 2012 15:23:18 GMT Daniel Hellstrom [4b557617] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) LEON3: cleanup console UART indexing handling The UART indexing was ... Wed, 04 Apr 2012 17:21:15 GMT Jennifer Averett [a36d1b4] * c/src/lib/libbsp/mips/acinclude.m4 (modified) * c/src/lib/libbsp/mips/malta/ChangeLog (added) * c/src/lib/libbsp/mips/malta/Makefile.am (added) * c/src/lib/libbsp/mips/malta/STATUS (added) * c/src/lib/libbsp/mips/malta/bsp_specs (added) * c/src/lib/libbsp/mips/malta/configure.ac (added) * c/src/lib/libbsp/mips/malta/console/conscfg.c (added) * c/src/lib/libbsp/mips/malta/console/printk_support.c (added) * c/src/lib/libbsp/mips/malta/include/bsp.h (added) * c/src/lib/libbsp/mips/malta/include/irq.h (added) * c/src/lib/libbsp/mips/malta/include/pci.h (added) * c/src/lib/libbsp/mips/malta/irq/interruptmask.c (added) * c/src/lib/libbsp/mips/malta/irq/maxvectors.c (added) * c/src/lib/libbsp/mips/malta/irq/vectorisrs.c (added) * c/src/lib/libbsp/mips/malta/make/custom/malta.cfg (added) * c/src/lib/libbsp/mips/malta/pci/pci.c (added) * c/src/lib/libbsp/mips/malta/pci/pcifinddevice.c (added) * c/src/lib/libbsp/mips/malta/pci/pcilistdevices.c (added) * c/src/lib/libbsp/mips/malta/preinstall.am (added) * c/src/lib/libbsp/mips/malta/start/start.S (added) * c/src/lib/libbsp/mips/malta/startup/bspreset.c (added) * c/src/lib/libbsp/mips/malta/startup/bspstart.c (added) * c/src/lib/libbsp/mips/malta/startup/inittlb.c (added) * c/src/lib/libbsp/mips/malta/startup/linkcmds (added) * c/src/lib/libbsp/mips/malta/startup/simple_access.c (added) Add MIPS/Malta BSP. Wed, 04 Apr 2012 13:39:46 GMT Jennifer Averett [0c0181d] * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/bsp_specs (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/include/irq.h (added) * c/src/lib/libbsp/mips/csb350/irq/vectorisrs.c (added) * c/src/lib/libbsp/mips/csb350/network/network.c (modified) * c/src/lib/libbsp/mips/csb350/preinstall.am (modified) * c/src/lib/libbsp/mips/csb350/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/irq.h (added) * c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c (added) * c/src/lib/libbsp/mips/genmongoosev/preinstall.am (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/clock/ckinit.c (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/irq.h (added) * c/src/lib/libbsp/mips/hurricane/irq/vectorisrs.c (added) * c/src/lib/libbsp/mips/hurricane/preinstall.am (modified) * c/src/lib/libbsp/mips/hurricane/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/irq.h (added) * c/src/lib/libbsp/mips/jmr3904/irq/vectorisrs.c (added) * c/src/lib/libbsp/mips/jmr3904/preinstall.am (modified) * c/src/lib/libbsp/mips/jmr3904/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/irq.h (added) * c/src/lib/libbsp/mips/rbtx4925/irq/vectorisrs.c (added) * c/src/lib/libbsp/mips/rbtx4925/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/irq.h (added) * c/src/lib/libbsp/mips/rbtx4938/irq/vectorisrs.c (added) * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (added) * c/src/lib/libbsp/mips/shared/clock/mips_timer.S (added) * c/src/lib/libbsp/mips/shared/irq/i8259.c (added) * c/src/lib/libbsp/mips/shared/irq/i8259.h (added) * c/src/lib/libbsp/mips/shared/irq/interruptmask.c (added) * c/src/lib/libbsp/mips/shared/irq/interruptmask_TX49.c (added) * c/src/lib/libbsp/mips/shared/irq/irq.c (added) * c/src/lib/libbsp/mips/shared/irq/maxvectors.c (moved) * c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c (moved) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/au1x00/include/au1x00.h (modified) * c/src/lib/libcpu/mips/au1x00/vectorisrs/maxvectors.c (deleted) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/maxvectors.c (deleted) * c/src/lib/libcpu/mips/rm52xx/include/rm5231.h (modified) * c/src/lib/libcpu/mips/rm52xx/vectorisrs/maxvectors.c (deleted) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.h (modified) * c/src/lib/libcpu/mips/tx39/include/tx3904.h (modified) * c/src/lib/libcpu/mips/tx39/vectorisrs/maxvectors.c (deleted) * c/src/lib/libcpu/mips/tx49/include/tx4925.h (modified) * c/src/lib/libcpu/mips/tx49/include/tx4938.h (modified) * c/src/lib/libcpu/mips/tx49/vectorisrs/maxvectors.c (deleted) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) PR 1993 - Convert MIPS to PIC IRQ model Tue, 03 Apr 2012 15:11:10 GMT Sebastian Huber [eb6362dc] * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs.h (modified) bsp/mpc55xx: Add and use chip features Add defines MPC55XX_HAS_SIU ... Mon, 02 Apr 2012 12:07:52 GMT Sebastian Huber [ba56882c] * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/preinstall.am (modified) bsp/tqm8xx: Install header file Mon, 02 Apr 2012 12:07:10 GMT Sebastian Huber [270fa1e] * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/preinstall.am (modified) bsp/qemuppc: Install header file Mon, 02 Apr 2012 11:37:31 GMT Sebastian Huber [b0b32b8] * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) bsps: Fix for clock driver Do not use the e300 core decrementer ... Mon, 02 Apr 2012 09:59:36 GMT Sebastian Huber [c988f180] * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) bsp/gen83xx: Fix console driver configuration Mon, 02 Apr 2012 09:59:06 GMT Sebastian Huber [15fde68c] * c/src/lib/libbsp/powerpc/gen83xx/console/ns16550cfg.h (deleted) bsp/gen83xx: Removed file Mon, 02 Apr 2012 09:48:30 GMT Sebastian Huber [06b6a03] * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) bsp/gen83xx: Regenerate Mon, 02 Apr 2012 09:32:11 GMT Sebastian Huber [8bb00ac] * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) bsps: More accurate PowerPC clock driver The clock driver used ... Mon, 02 Apr 2012 09:06:34 GMT Sebastian Huber [1bb72a9] * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) bsp/gen83xx: Support cache BSP options Mon, 02 Apr 2012 09:05:29 GMT Sebastian Huber [a3db5ff4] * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) bsp/gen83xx: Support for MPC830X Mon, 02 Apr 2012 09:04:44 GMT Sebastian Huber [31ea3109] * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.base (modified) bsp/gen83xx: Add sections for BSD support Mon, 02 Apr 2012 08:59:17 GMT Sebastian Huber [73f1b303] * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) bsp/gen83xx: Install new header file Mon, 02 Apr 2012 08:58:50 GMT Sebastian Huber [69237c16] * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (modified) bsp/virtex5: Regenerate Fri, 30 Mar 2012 15:03:43 GMT Ric Claus [16a8616] * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (added) * c/src/lib/libbsp/powerpc/virtex4/bsp_specs (added) * c/src/lib/libbsp/powerpc/virtex4/clock/clock.c (added) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (added) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (added) * c/src/lib/libbsp/powerpc/virtex4/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/virtex4/include/irq.h (added) * c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg (added) * c/src/lib/libbsp/powerpc/virtex4/preinstall.am (added) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/virtex4/startup/dummy_console.c (added) * c/src/lib/libbsp/powerpc/virtex4/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/virtex4/startup/start.S (added) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (added) * c/src/lib/libbsp/powerpc/virtex5/bsp_specs (added) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (added) * c/src/lib/libbsp/powerpc/virtex5/console/dummy_console.c (added) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (added) * c/src/lib/libbsp/powerpc/virtex5/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/virtex5/include/irq.h (added) * c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg (added) * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (added) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (added) * c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/virtex5/startup/start.S (added) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/README (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/debugmod.h (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) Add Virtex4 and Virtex5 BSPs This commit covers at least PR2020, ... Fri, 30 Mar 2012 13:41:15 GMT Jennifer Averett [0b095f76] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.c (added) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.h (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.c (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * cpukit/sapi/inline/rtems/rbtree.inl (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (added) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/rtems/score/nios2-utility.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/inline/rtems/score/rbtree.inl (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreepeek.c (modified) * cpukit/score/src/scheduleredf.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) Resolve link problems with psim irq-server Add IRQ support ... Fri, 30 Mar 2012 13:38:14 GMT Jennifer Averett [97f82fc] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Resolve link problems with psim irq-server Thu, 29 Mar 2012 20:53:16 GMT Joel Sherrill [8d0913b8] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) PC386 - Add files missed in previous commit Thu, 29 Mar 2012 20:28:13 GMT Joel Sherrill [2cc30b0d] * c/src/lib/libbsp/i386/pc386/console/exar17d15x.c (added) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.h (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.c (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.h (added) PC386 Add RTD316 and Exar 17D15x multi-port serial card support - ... Thu, 29 Mar 2012 11:52:16 GMT Daniel Hellstrom [2cee553] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) LEON3: various cleanups in leon.h Removed old LEON2 definitions ... Thu, 29 Mar 2012 11:52:14 GMT Daniel Hellstrom [226771c] * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) LEON3: IRQ index mask was bad, but always shifted out anyway ... Thu, 29 Mar 2012 11:52:13 GMT Daniel Hellstrom [4fa6be9] * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) LEON3: clock timer indexing should be consequent Signed-off-by: ... Thu, 29 Mar 2012 17:07:30 GMT Jennifer Averett [752f876e] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) Address Conflicts: c/src/lib/libbsp/powerpc/psim/startup/linkcmds Wed, 28 Mar 2012 08:49:27 GMT Daniel Hellstrom [0729e2a7] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/sparc/shared/startup/early_malloc.c (added) SPARC: bsp_early_malloc() routine for startup memory allocation If ... Thu, 29 Mar 2012 11:52:12 GMT Daniel Hellstrom [b9d8cd33] * c/src/libchip/network/smc91111.c (modified) SMC91111: remove old unused LEON2/LEON3 intialization code ... Thu, 29 Mar 2012 11:52:11 GMT Daniel Hellstrom [d0dbcf8] * c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c (modified) LEON3: fix GRETH interrupt initialization bug Fixed a bug where the ... Thu, 29 Mar 2012 11:52:10 GMT Daniel Hellstrom [e6f327c] * c/src/libchip/network/greth.c (modified) GRETH: removed the use of rtems_set_clock() in auto-nego timeout ... Fri, 02 Dec 2011 09:53:35 GMT Daniel Hellstrom [39671330] * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/libchip/network/greth.c (modified) GRETH: added support for non-snooping GRETH 10/100 systems When ... Sat, 24 Mar 2012 21:56:37 GMT Sebastian Huber [a73884e9] * c/src/lib/libbsp/arm/lm3s69xx/README (modified) bsp/lm3s69xx: Reflect new Qemu patch Sat, 24 Mar 2012 21:53:07 GMT Sebastian Huber [bd0fb473] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/irq/irq.c (deleted) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq-dispatch.c (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/shared/armv7m/include/armv7m-irq.h (added) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq-dispatch.c (added) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (added) bsps: Shared ARMv7-M interrupt support Sat, 24 Mar 2012 21:01:08 GMT Sebastian Huber [0f31fddc] * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (modified) * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/lm32/shared/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c (modified) * c/src/lib/libbsp/shared/src/irq-default-handler.c (added) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) bsps: Add shared default IRQ handler Sat, 24 Mar 2012 20:04:40 GMT Sebastian Huber [b2ee4d5f] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (modified) bsp/lm3s69xx: Format Sat, 24 Mar 2012 19:57:21 GMT Sebastian Huber [954393ca] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/timer/timer.c (deleted) bsp/lm3s69xx: Use shared timer stub driver Sat, 24 Mar 2012 19:55:40 GMT Sebastian Huber [1ed238e] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/start/start.S (deleted) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstarthook.c (modified) bsp/lm3s69xx: Use shared start.S Sat, 24 Mar 2012 19:14:27 GMT Sebastian Huber [34c61517] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (moved) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) bsps: Shared ARMv7-M clock driver Sat, 24 Mar 2012 19:06:49 GMT Sebastian Huber [3c0e7f9b] * c/src/lib/libbsp/arm/lm3s69xx/0005-target-arm-Fix-system_clock_scale-initial-value.patch (added) bsp/lm3s69xx: New Qemu patch Sat, 24 Mar 2012 16:33:22 GMT Sebastian Huber [5cc813f] * c/src/lib/libbsp/shared/include/irq-generic.h (modified) bsps: Provide optional prototype Sat, 24 Mar 2012 15:59:25 GMT Sebastian Huber [e8adc8e3] * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (modified) bsp/lpc24xx: Use proper clock value Sat, 24 Mar 2012 15:58:31 GMT Sebastian Huber [f3cdf279] * c/src/lib/libbsp/arm/lpc24xx/include/io.h (modified) bsp/lpc24xx: More CAN pin definitions Mon, 06 Feb 2012 14:15:49 GMT Daniel Hellstrom [67b1ce4] * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/libchip/network/smc91111.c (modified) SMC91111: ERC32 was never supported by driver Moved the ... Mon, 06 Feb 2012 14:15:48 GMT Daniel Hellstrom [f636ba64] * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/include/irq.h (modified) shared-irq: add support for custom BSP vector verification ... Mon, 06 Feb 2012 14:15:47 GMT Daniel Hellstrom [b4dfce9b] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) LEON3: spurious trap handler print out trap in hex instead ... Wed, 08 Feb 2012 14:57:03 GMT Daniel Hellstrom [80d01b3c] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/access/access.S (added) * c/src/lib/libcpu/sparc/access/access_le.c (added) * c/src/lib/libcpu/sparc/include/libcpu/access.h (added) * c/src/lib/libcpu/sparc/include/libcpu/byteorder.h (added) * c/src/lib/libcpu/sparc/preinstall.am (modified) SPARC: added libcpu lowlevel access and byteorder ... Fri, 16 Mar 2012 13:23:43 GMT Jennifer Averett [7e664023] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Added irq server and link commands for new libbsd support. Wed, 14 Mar 2012 17:06:13 GMT Gedare Bloom [67baf60] * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) PR2041: sparc64: vector number not included in CPU_Interrupt_frame ... Wed, 14 Mar 2012 15:45:26 GMT Sebastian Huber [4868c771] * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_plx800_ram.cfg (added) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_plx800_rom_int.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_ram (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-dynamic.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-static.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-pinsel.c (modified) bsp/lpc24xx: New BSP variant
