@fac9da63
03/09/14 13:22:55 |
Pavel Pisa |
bsps/arm: Add DP83848 PHY support to LPC Ethernet
4.115
@14c3cb6
02/21/14 13:59:57 |
Pavel Pisa |
bsps/arm: Add PHY detection to LPC Ethernet
4.115
@369bb13b
02/21/14 13:08:03 |
Pavel Pisa |
bsps/arm: Reset MII management in LPC Ethernet
Reduce MII clock to …
4.115
@810815c4
02/21/14 13:05:01 |
Pavel Pisa |
bsp/lpc24xx: Add LPC24XX_PIN_ETHERNET_POWER_DOWN
4.115
@986ddf5
02/21/14 13:03:50 |
Sebastian Huber |
bsp/lpc24xx: Add lpc24xx_pin_get_first_index()
4.115
@1550242
03/05/14 16:14:21 |
Sebastian Huber |
bsps/powerpc: Add support for interrupt profiling
4.115
@234ecedd
03/07/14 06:52:12 |
Sebastian Huber |
bsps/leon3: Add interrupt delay profiling support
4.115
@de5d6d0
03/05/14 11:07:42 |
Sebastian Huber |
sparc: Add support for interrupt profiling
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@ebb6a8d
03/14/14 07:42:31 |
Sebastian Huber |
libchip: Include <bsp.h> BSP options definition
4.115
@9a8bf95b
03/13/14 15:45:40 |
Sebastian Huber |
libchip: Check interrupt extension availability
4.115
@062f9532
03/13/14 15:41:46 |
Sebastian Huber |
libchip: Avoid <bsp/utility.h>
4.115
@ad010285
08/01/13 12:30:50 |
ralf.kirchner |
bsp/altera-cyclone-v: Made hwlib compile clean
Made Alteras hwlib …
4.115
@0b03ca39
02/14/14 14:00:31 |
ralf.kirchner |
bsp/altera-cyclone-v: Add Alteras hwlib
Add files from Alteras hwlib
4.115
@f73cfe99
07/31/13 07:45:59 |
ralf.kirchner |
bsp/altera-cyclone-v: New BSP
Implemented so far:
- nocache heap for …
4.115
@4953b724
02/17/14 14:43:53 |
ralf.kirchner |
libchip: Add dwmac 10/100/1000 network driver
4.115
@bbc5527
02/17/14 09:24:24 |
ralf.kirchner |
libbsp/xilinx-zynq: Share handling for ARM cache controller L2C-310
4.115
@9fcd1b35
02/17/14 09:22:16 |
ralf.kirchner |
bsp/arm: Add handling for level 2 L2C-310 cache controller
4.115
@0b74e10f
02/17/14 10:57:19 |
ralf.kirchner |
bsp/arm: Add SCU errata handling for L2C-310 cache
4.115
@b0553f47
02/26/14 08:22:41 |
ralf.kirchner |
bsp/xilinx-zynq: Add arm-errata.h and arm-release-id.h
4.115
@f2bb3ccb
02/26/14 08:20:57 |
ralf.kirchner |
bsp/realview-pbx-a9: Add arm-errata.h and arm-release-id.h
4.115
@f2a8b60
02/26/14 08:19:17 |
ralf.kirchner |
bsp/raspberrypi: Add arm-errata.h and arm-release-id.h
4.115
@deccde3
02/26/14 08:17:23 |
ralf.kirchner |
bsp/lpc32xx: Add arm-errata.h and arm-release-id.h
4.115
@b87bf0b
02/17/14 10:44:47 |
ralf.kirchner |
bsp/arm: Add arm-errata.h and arm-release-id.h
4.115
@f241977
02/17/14 12:27:11 |
ralf.kirchner |
bsp/arm: Add linker symbol bsp_processor_count
4.115
@0656a00a
01/23/14 09:56:31 |
ralf.kirchner |
bsp/arm: Add CP15 methods
4.115
@a502d677
02/18/14 13:31:26 |
ralf.kirchner |
bsp/arm: Separate setup for translation table
4.115
@f5c10645
10/16/13 08:39:05 |
ralf.kirchner |
bsp/arm: Invalidate SCU
4.115
@34568acf
03/05/14 08:14:59 |
ralf.kirchner |
bsp/arm: SMP support for a9mpcore_clock_cleanup()
4.115
@17864a4
08/01/13 14:45:42 |
ralf.kirchner |
bsp/arm: Avoid warning
4.115
@dedc1393
03/12/14 15:37:10 |
Sebastian Huber |
bsps/powerpc: Fix GET_INTERRUPT_MASK macro
Use …
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@ae88aa7
03/10/14 07:15:37 |
Sebastian Huber |
sapi: Use one SMP lock for all chains
This partially reverts commit …
4.115
@6b115b3
03/06/14 12:17:04 |
Sebastian Huber |
bsp/leon3: Use interrupt timestamping counter
Use the interrupt …
4.115
@ba15b92
03/06/14 08:26:37 |
Sebastian Huber |
bsps/sparc: Add missing IRQMP registers
4.115
@f4accfd
03/06/14 10:19:56 |
Sebastian Huber |
bsps/sparc: Remove fix for ERC32 with FPU rev. B/C
4.115
@718124e
03/03/14 09:18:01 |
Sebastian Huber |
rtems: Add RTEMS_INTERRUPT_REPLACE
A new option …
4.115
@e0609ac
03/03/14 08:49:12 |
Sebastian Huber |
bsps: SMP support for generic interrupt support
4.115
@7fe05615
02/18/14 10:50:25 |
Daniel Hellstrom |
bsp/leon3: Unmask IPI only on secondary processor
4.115
@9ec4a48d
02/26/14 10:31:51 |
Sebastian Huber |
bsp/leon3: Add L2 cache support
4.115
@c5b1e20
02/26/14 11:14:27 |
Sebastian Huber |
bsp/leon3: Add L2C registers
4.115
@64f4ac2
02/24/14 09:48:13 |
Sebastian Huber |
bsp/leon3: Add new cache manager implementation
The previous …
4.115
@80186ca8
02/27/14 07:32:52 |
Sebastian Huber |
bsp/leon3: Add and use cache register functions
4.115
@e1d7bf0
02/26/14 10:08:31 |
Sebastian Huber |
rtems: Add cache size functions
Add rtems_cache_get_data_cache_size() …
4.115
@e7549ff4
02/26/14 10:00:17 |
Sebastian Huber |
rtems: Use size_t for cache line size
A cache line cannot have a …
4.115
@0a2096b
02/24/14 16:06:52 |
Sebastian Huber |
bsp/leon3: Use ambapp_freq_get() for CPU counter
4.115
@dce7bba7
02/24/14 15:25:24 |
Sebastian Huber |
bsps: Delete LEON3_FATAL_CPU_COUNTER_INIT
4.115
@6faf789
02/26/14 14:45:02 |
Sebastian Huber |
bsps: Fix empty interrupt handler entry
The vector number of spurious …
4.115
@a4bc90af
02/24/14 11:45:00 |
Sebastian Huber |
sparc: Fix CPU counter support
The SPARC processors supported by …
4.115
@0b9fd991
02/21/14 16:12:16 |
Sebastian Huber |
bsps: Add empty cache manager
This is necessary to add tests that use …
4.115
@0fe0718
02/21/14 12:32:13 |
Sebastian Huber |
bsps/powerpc: Use System V small-data area
The 32-bit ABIs for …
4.115
@07713db6
02/18/14 11:46:08 |
Sebastian Huber |
bsp/leon3: Add bsp_reset() for SMP configuration
4.115
@7ec8d95
02/19/14 15:42:23 |
Sebastian Huber |
bsp/leon3: Add and use leon3_get_cpu_count()
4.115
@4fe6759e
02/19/14 15:41:52 |
Sebastian Huber |
bsp/leon3: Add leon3_power_down_loop()
4.115
@c8c877f
02/19/14 14:19:30 |
Sebastian Huber |
bsps/sparc: Delete unused file
4.115
@1be15db1
02/19/14 14:15:18 |
Sebastian Huber |
bsp/score603e: Remove unused BSP_fatal_return()
4.115
@2cb0877
02/18/14 11:42:58 |
Sebastian Huber |
bsp/leon3: Add and use LEON3_IrqCtrl_Lock
Disabling of interrupts is …
4.115
@a171e0a8
02/18/14 10:54:07 |
Sebastian Huber |
bsp/leon3: Declare LEON3_IrqCtrl_EIrq only once
4.115
@f71f3d31
02/18/14 10:52:48 |
Sebastian Huber |
bsp/leon3: Declare leon3_ext_irq_init() in header
4.115
@4d9bd56
02/17/14 14:12:43 |
Sebastian Huber |
score: Rename rtems_smp_process_interrupt()
Rename …
4.115
@911b1d2
02/17/14 14:02:54 |
Sebastian Huber |
score: Rename rtems_smp_secondary_cpu_initialize()
Rename …
4.115
@f8ff2a0
02/17/14 13:31:32 |
Sebastian Huber |
score: Delete bsp_smp_broadcast_interrupt()
Since the per-CPU SMP …
4.115
@4627fcd
02/17/14 13:25:29 |
Sebastian Huber |
score: Rename bsp_smp_initialize()
Rename bsp_smp_initialize() into …
4.115
@46d7fa5
02/17/14 10:54:35 |
Sebastian Huber |
bsp/leon3: Add and use fatal codes
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@801b5d8
02/17/14 08:23:59 |
Sebastian Huber |
powerpc: Change interrupt disable implemetation
Instead of SPRG0 (= …
4.115
@88ef740e
02/14/14 09:27:04 |
Sebastian Huber |
bsp/leon3: Declare amba_initialize()
4.115
@e644155a
02/14/14 08:20:08 |
Sebastian Huber |
bsp/leon3: Do not define RTEMS_DEBUG
Move vital code out of debug …
4.115
@ad56361
02/13/14 12:00:00 |
Sebastian Huber |
sparc: Add LEON3_ASR17_PROCESSOR_INDEX_SHIFT
Add …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@382ea27b
02/13/14 09:04:05 |
Sebastian Huber |
bsps/arm: Fix Cortex-A9 MPCore nanoseconds handler
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@97cf623d
02/05/14 10:36:05 |
Sebastian Huber |
sparc: Save/restore only non-volatile context
The …
4.115
@62c5c4a5
02/11/14 09:08:21 |
Sebastian Huber |
bsps/sparc: Fix ambapp_find_by_idx()
The expression "*pi++" …
4.115
@0df8d7f2
02/10/14 11:21:24 |
Sebastian Huber |
bsps/arm: Use Global Timer for Cortex-A9 MPCore
Use the Global Timer …
4.115
@069e10c3
02/10/14 11:17:34 |
Sebastian Huber |
bsps/arm: Include missing header file
4.115
@847fc79
02/07/14 08:32:31 |
Sebastian Huber |
Revert "bsp/leon3: New BSP variant leon3_qemu"
This reverts commit …
4.115
@7579e25
11/25/13 07:46:19 |
Sebastian Huber |
4.115
@224b888
02/06/14 07:39:51 |
Sebastian Huber |
bsp/leon3: Declare bsp_debug_uart_init() in header
Do not return a status.
4.115
@558cc8d
02/05/14 14:41:00 |
Sebastian Huber |
score: _CPU_Context_switch_to_first_task_smp()
Delete …
4.115
@1c1c2a0
02/05/14 14:27:22 |
Sebastian Huber |
bsps: Delete unused bsp_smp_delay()
4.115
@36a52ab
02/05/14 14:26:42 |
Sebastian Huber |
bsp/leon3: Avoid magic delays for IPI broadcast
4.115
@3d77001
02/05/14 14:15:51 |
Sebastian Huber |
bsp/leon3: Fix SMP initialization
Avoid usage of the same stack area …
4.115
@3ef2d17
02/05/14 12:59:07 |
Sebastian Huber |
bsp/leon3: Install IPI handler early
Install inter-processor …
4.115
@d212acb7
02/05/14 12:53:34 |
Sebastian Huber |
bsp/leon3: Use printk() only if debug is enabled
4.115
@20828099
02/05/14 10:01:09 |
Sebastian Huber |
bsps/sparc: Fix comment
4.115
@5ff6a9ca
02/04/14 15:48:13 |
Sebastian Huber |
bsps/sparc: Remove confusing nop
4.115
@f715433
02/04/14 15:44:50 |
Sebastian Huber |
bsps/sparc: Order load/store by increasing offsets
This may increase …
4.115
@a54179d2
02/04/14 15:33:45 |
Sebastian Huber |
bsps/sparc: Fix comments
4.115
@1d5d6de
11/26/13 08:11:57 |
Sebastian Huber |
bsp/leon3: Console driver changes
Move declaration of global …
4.115
@6fe6d017
11/26/13 07:56:08 |
Sebastian Huber |
bsp/leon3: Avoid copy and paste in console driver
4.115
@1e744ef
11/26/13 07:47:37 |
Sebastian Huber |
bsp/leon3: Fix interrupt-driven console driver
4.115
@022851a
01/28/14 11:10:08 |
Sebastian Huber |
Add thread-local storage (TLS) support
Tested and implemented on ARM, …
4.115
@960fd85
01/28/14 10:52:17 |
Sebastian Huber |
bsps: Thread-local storage (TLS) for linkcmds
4.115
@fe535885
02/03/14 12:52:49 |
Sebastian Huber |
bsp/v850: Use proper ABI in linkcmds
4.115
@e5d706c
01/28/14 03:02:35 |
Chris Johns |
bsp/xilinx_zynq: Support configuraton of memory map. Remove SMP …
4.115
@6dce1621
01/31/14 14:13:05 |
Joel Sherrill |
bootcard.c: Comment clean up
4.115
@fd49e3f
01/30/14 15:01:07 |
Sebastian Huber |
bsps/sparc: Fix linkcmds part of new network stack
4.115
@bba0e09
01/30/14 09:37:02 |
Sebastian Huber |
bsps: Fix barrier section definitions
4.115
@6c3517f
01/29/14 08:06:07 |
Sebastian Huber |
bsp/stm32f4: Use BSP_SMALL_MEMORY for a variant
4.115
