Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @9710790   03/25/16 15:45:35 joel m68k/mcf5206elite/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @967f9a2d   03/25/16 15:45:33 joel m68k/genmcf548x/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @047aa95   03/25/16 15:45:32 joel m68k/gen68360/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @009b737   03/25/16 15:45:30 joel m68k/gen68340/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @03faf21   03/25/16 15:45:27 joel m68k/csb360/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @2ffc23c5   03/25/16 15:45:24 joel m68k/av5282/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @e778231   03/25/16 15:45:21 joel m32c/m32cbsp/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @1dee8c84   03/25/16 15:45:17 joel lm32/milkymist/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @366c42ef   03/25/16 15:45:16 joel lm32/lm32_evr/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @3abf685f   03/25/16 15:45:14 joel i386/pc386/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @7aa8c18   03/25/16 15:45:11 joel epiphany/epiphany_sim/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @514f2d5   03/25/16 15:45:10 joel bfin/eZKit533/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @64cd0a5   03/25/16 15:45:09 joel bfin/bf537Stamp/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @864fae6   03/25/16 15:45:08 joel bfin/TLL6527M/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @9899c91b   03/25/16 15:45:03 joel arm/xilinx-zynq/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @7dde6b48   03/25/16 15:45:02 joel arm/tms570/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @c40f81d4   03/25/16 15:45:01 joel arm/stm32f4/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @7f21dac   03/25/16 15:45:00 joel arm/smdk2410/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @947985aa   03/25/16 15:44:59 joel arm/rtl22xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @dbf08e3   03/25/16 15:44:58 joel arm/realview-pbx-a9/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @ebc8a11   03/25/16 15:44:57 joel arm/raspberrypi/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @4b9db426   03/25/16 15:44:54 joel arm/lpc32xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @32971366   03/25/16 15:44:52 joel arm/lpc24xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @98e910b4   03/25/16 15:44:43 joel arm/lpc176x/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @d41577c   03/25/16 15:44:39 joel arm/lm3s69xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @30617a1   03/25/16 15:44:34 joel arm/gumstix/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @846219a1   03/25/16 15:44:30 joel arm/gdbarmsim/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @9604d7ed   03/25/16 15:44:28 joel arm/edb7312/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @c14ece5c   03/25/16 15:44:27 joel arm/csb337/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @85f20112   03/25/16 15:44:26 joel arm/csb336/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @413e6e1   03/25/16 15:44:25 joel arm/atsam/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @77c0135   03/25/16 15:44:23 joel arm/altera-cyclone-v/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @eaf03e9f   03/22/16 22:58:42 joel pc386/README: Replace contents with discussion of console/printk … 5
(edit) @561dec5   03/21/16 15:53:32 joel powerpc/shared/openpic/openpic.c: Ignore warnings for … 5
(edit) @d165fd2   03/21/16 00:33:57 joel erc32/*/erc32sonic.c: Fix warnings 5
(edit) @1a738ed   03/22/16 14:58:04 joel lpc1768_mbed.cfg: Turn on per function sections Closes #2576. 5
(edit) @e12f4e17   03/18/16 09:58:41 Sebastian Huber bsp/qoriq: Invalidate TLS anchor 5
(edit) @d64f2e7   03/17/16 12:30:54 Sebastian Huber sparc: Fix SMP context switch The value of register %g1 was … 5
(edit) @d731bc6f   03/17/16 22:44:06 joel bspgetworkarea.c: File header now uses Doxygen 5
(edit) @bfb886d   03/17/16 22:43:31 joel mcf5235/start/start.S: Fix spacing from bad tab expansion 5
(edit) @0d2067c   03/17/16 22:42:55 joel pc386/console/conscfg.c: Fix name of Edison console 5
(edit) @6c4aaf4   03/17/16 08:12:19 Daniel Hellstrom sparc: Fix window underflow trap handler The window underflow trap … 5
(edit) @1547b623   03/17/16 07:23:30 Sebastian Huber bsp/realview_pbx_a9_qemu: Fix compiler flags 5
(edit) @59461e5   03/16/16 12:59:29 joel pc386/.../bspimpl.h: New file missed in previous commit. 5
(edit) @b0443736   03/16/16 09:29:48 Sebastian Huber bsp/mpc55xx: Fix BSS initialization 5
(edit) @364866d   03/16/16 00:36:41 joel pc386: Do not include rtems/pci.h from bsp.h. Add bsp/bspimpl.h Start … 5
(edit) @78c9fe8   03/16/16 00:36:26 joel atsamv-testsuite.tcfg: Add more tests 5
(edit) @5a0b27ed   03/15/16 13:29:15 Sebastian Huber bsp/leon3: Clock driver workaround for GR712RC 5
(edit) @057154e   03/15/16 07:15:53 Sebastian Huber bsp/beatnik: Delete unused linkcmds file 5
(edit) @734118d9   03/14/16 09:55:57 Sebastian Huber bsp/qoriq: Fix interrupt numbers 5
(edit) @5e368e84   03/11/16 22:07:35 joel pc386: Fix linker usage issues with -r and function sections closes #2638. 5
(edit) @83a116b   03/11/16 20:13:48 joel lm32/shared/.../ckinit.c: Fix typo so fast idle on simulator is enabled 5
(edit) @a29aa21   03/10/16 23:59:01 joel v850/gdbv850sim: Add per-section compilation and linking support … 5
(edit) @2533e79   03/10/16 23:43:44 joel sparc64/usiii: Add per-section compilation and linking support … 5
(edit) @e3fdbc06   03/10/16 23:37:55 joel sparc64/niagara: Add per-section compilation and linking support … 5
(edit) @45e5623   03/10/16 23:22:59 joel powerpc/motorola_powerpc: Add per-section compilation and linking … 5
(edit) @f34c41a   03/10/16 23:09:20 joel sh/simsh: Add per-section compilation and linking support updates … 5
(edit) @dd642034   03/10/16 23:03:49 joel sh/gensh4: Add per-section compilation and linking support updates … 5
(edit) @5d75bb6b   03/10/16 22:49:33 joel sh/gensh2: Add per-section compilation and linking support updates … 5
(edit) @fd9ea74   03/10/16 22:46:02 joel sh/gensh1: Add per-section compilation and linking support updates … 5
(edit) @e1768fdd   03/10/16 22:28:12 joel or1k/generic_or1k: Add per-section compilation and linking support … 5
(edit) @14926616   03/10/16 22:22:49 joel no_bsp.cfg: Add hints for CFLAGS and LDFLAGS updates #2577. 5
(edit) @1909efdb   03/10/16 22:21:20 joel nios2/nios2_iss: Add per-section compilation and linking support … 5
(edit) @7d80eea   03/10/16 22:12:27 joel m32csim.cfg: GCC PR37665 is fixed but there is still a compiler error. … 5
(edit) @4a199a9   03/10/16 22:08:29 joel m32c/m32csim: Add per-section compilation and linking support updates … 5
(edit) @5758838   03/10/16 22:04:31 joel lm32/lm32_evr: Add per-section compilation and linking support … 5
(edit) @f953a85   03/10/16 21:58:08 joel lm32/lm32_evr: Add per-section compilation and linking support … 5
(edit) @f6b798a6   03/10/16 21:48:49 joel pc386.cfg: Add disabled per-function-sections updates #2638. 5
(edit) @22e8c5a3   03/10/16 21:09:24 joel epiphany/epiphany_sim: Add per-section compilation and linking support … 5
(edit) @74ad76a   03/10/16 20:36:25 joel bfin/TLL6527M: Add per-section compilation and linking support … 5
(edit) @32a4aea5   03/10/16 20:25:36 joel bfin/bf537Stamp: Add per-section compilation and linking support … 5
(edit) @9008c77   03/10/16 20:21:40 joel bfin/eZKit533: Add per-section compilation and linking support … 5
(edit) @5460722   03/10/16 20:12:53 joel arm/xilinx_zynq: Add per-section compilation and linking support … 5
(edit) @9d431a0   03/10/16 19:35:14 joel arm/tms570: Add per-section compilation and linking support updates … 5
(edit) @a006671a   03/10/16 19:29:22 joel arm/stm32f4: Add per-section compilation and linking support updates … 5
(edit) @e354ef11   03/10/16 19:25:13 joel arm/smdk2410: Add per-section compilation and linking support updates … 5
(edit) @5fd3cc07   03/10/16 19:16:30 joel arm/rtl22xx: Add per-section compilation and linking support updates … 5
(edit) @07252899   03/10/16 19:08:26 joel arm/realview_pbx_a9_qemu: Add per-section compilation and linking … 5
(edit) @fa9c057   03/10/16 18:31:37 joel arm/raspberrypi: Add per-section compilation and linking suppo … 5
(edit) @7276954   03/10/16 18:13:57 joel arm/lpc32xx: Add per-section compilation and linking suppo updates … 5
(edit) @bfc87114   03/10/16 17:39:54 joel arm/lpc24xx (lpc40xx variants) Add per-section compilation and linking … 5
(edit) @55159ee9   03/10/16 17:13:29 joel arm/lpc24xx (lpc24xx variants) Add per-section compilation and linking … 5
(edit) @8467c31   03/10/16 00:51:30 joel atsamv-testsuite.tcfg: new file] 5
(edit) @4e059db8   03/10/16 15:36:16 joel arm/lpc24xx (lpc17xx variants): Add per-section compilation and … 5
(edit) @9430052   03/09/16 21:45:44 joel powerpc/mvme5500: Use shared pci_find_device() 5
(edit) @81df701a   03/09/16 21:30:24 joel mips/malta: Use shared pci_find_device() and removed unused … 5
(edit) @22bbb9f1   03/09/16 18:48:39 joel pc386: Add --disable-com1-com4 boot argument 5
(edit) @efbf6c9   03/09/16 17:25:38 joel libbsp/shared/console.c: Clean up memory allocation for per device data 5
(edit) @6db5ea03   03/09/16 17:25:13 joel pc386/startup/bsp_fatal_halt.c: Fix noreturn does return warning 5
(edit) @2e516dd4   03/09/16 17:24:33 joel pc386/startup/bspstart.c: Reformat and cleanup file header 5
(edit) @356b2c23   03/04/16 21:40:49 joel pc386: Add PCI UART support 5
(edit) @0ac1538   03/04/16 19:21:02 joel console_private.h: Improve comment for vt_ioctl() 5
(edit) @36627387   03/04/16 19:20:38 joel console_private.h: Remove prototypes for non-existent methods … 5
(edit) @c3c57b1   03/10/16 16:33:27 joel pc386: Improve boot command arguments for console/printk device … 5
(edit) @f770fcb   03/03/16 16:36:24 joel Add shared PCI support and enhance pc386 to support non-legacy PCI … 5
(edit) @36717645   03/03/16 15:23:47 joel pc386/configure.ac: Delete incorrect and unused AM_CONDITIONAL 5
(edit) @3b697232   03/02/16 19:31:45 joel i386/shared/pci/pcibios.c: Remove unused pcib_find_by_class() 5
(edit) @8ce16a4   03/02/16 19:30:27 joel i386/shared/pci/pcibios.c: Remove unused pcib_special_cycle() 5
(edit) @12c9dc8f   03/02/16 19:25:13 joel pc386: Eliminate pcibios.h and begin removal obsolete PCI BIOS API … 5
(edit) @9f5754b5   03/04/16 14:13:45 Sebastian Huber bsps: Avoid Giant lock in simulator clock driver Update #2555. 5
