@db8e8a8b
08/14/98 15:23:33 |
Joel Sherrill |
Added information on caching.
4.104.114.84.95
@0088e39c
08/14/98 15:23:22 |
Joel Sherrill |
Updated.
4.104.114.84.95
@2097470
08/13/98 22:46:59 |
Joel Sherrill |
Fixed version reference
4.104.114.84.95
@3978eec2
08/13/98 22:46:35 |
Joel Sherrill |
Updated.
4.104.114.84.95
@43abd4d
08/13/98 22:03:14 |
Joel Sherrill |
Fixed preinstall stanza so the prebuild works.
4.104.114.84.95
@8626d6d
08/13/98 17:46:27 |
Joel Sherrill |
base line -- copied from erc32
4.104.114.84.95
@af3e81c9
08/13/98 16:53:37 |
Joel Sherrill |
Enable TX interrupts only when we need TDAs.
4.104.114.84.95
@1253f39
08/13/98 16:20:14 |
Joel Sherrill |
Cleaned up some debugging stuff.
Redid interrupt handler to read …
4.104.114.84.95
@70502bc4
08/13/98 15:52:40 |
Joel Sherrill |
Don't disable the RX/TX on close in polled mode.
Fixed a comment.
4.104.114.84.95
@9898425
08/13/98 14:28:22 |
Joel Sherrill |
Patch from Chris Johns <ccj@…> to change the way in which the …
4.104.114.84.95
@26e5cd4
08/13/98 14:23:37 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>. Comments follow:
Here is a …
4.104.114.84.95
@7e19c72b
08/13/98 14:22:48 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@ae320e0
08/12/98 23:53:23 |
Joel Sherrill |
Removed spurious prints and cleaned up XXX.
4.104.114.84.95
@9693fac4
08/12/98 23:10:38 |
Joel Sherrill |
Added more debug information. There are probably debug prints left …
4.104.114.84.95
@4f38b713
08/12/98 16:28:17 |
Joel Sherrill |
Fixed bug where the last link of the RDA was not initialized properly.
4.104.114.84.95
@7d07970
08/11/98 14:20:26 |
Joel Sherrill |
Added SONIC_DEBUG_DESCRIPTORS and changed debug level.
4.104.114.84.95
@339737b
08/10/98 23:20:25 |
Joel Sherrill |
Survives 16-20 packets. Appears to be ok on TX buffer management. …
4.104.114.84.95
@3fbd528
08/10/98 22:23:33 |
Joel Sherrill |
Added prints
4.104.114.84.95
@7344fba9
08/10/98 21:45:01 |
Joel Sherrill |
Can now reply to multiple successive pings successfully without being …
4.104.114.84.95
@c153a7b
08/10/98 21:27:33 |
Joel Sherrill |
replies to ping -- forced into prosmiscuous mode
4.104.114.84.95
@0c0419a1
08/08/98 17:57:23 |
Joel Sherrill |
Reordered some stuff.
4.104.114.84.95
@18c2320
08/08/98 16:51:16 |
Joel Sherrill |
changed version to 980808
4.104.114.84.95
@870284d
08/08/98 16:37:43 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@301a2a3c
08/08/98 16:37:25 |
Joel Sherrill |
Changed debug level.
Moved CAM Descriptor types to sonic.h.
CAM …
4.104.114.84.95
@7e2187f4
08/08/98 16:26:35 |
Joel Sherrill |
changed version to 9800808
4.104.114.84.95
@13451a3
08/06/98 19:01:03 |
Joel Sherrill |
Removed SonicRegisters? structure since we now use register indices
and …
4.104.114.84.95
@e70a8f16
08/06/98 19:01:02 |
Joel Sherrill |
Enabled specific types of debug info.
Added pointer to RDA to sonic …
4.104.114.84.95
@e995f3a1
08/06/98 15:27:08 |
Joel Sherrill |
Changed debug enable macros to support individually enabling different …
4.104.114.84.95
@c23118b
08/06/98 15:05:59 |
Joel Sherrill |
Card Resource Register was a 16-bit register not a 32-bit one.
Used …
4.104.114.84.95
@308e18c
08/06/98 00:24:52 |
Joel Sherrill |
Added support for the Card Resource Register. The new probe routines …
4.104.114.84.95
@0eb85ae
08/05/98 23:57:35 |
Joel Sherrill |
Commented out the code which yields the CPU when the serial controller …
4.104.114.84.95
@d4bf16c
08/05/98 23:56:48 |
Joel Sherrill |
Added constants which made the multiple bit settings more readable
for …
4.104.114.84.95
@dddc0557
08/05/98 23:56:13 |
Joel Sherrill |
DCR setting changed to match what the DY-4 Firmware initialized it to. …
4.104.114.84.95
@bd8c8b2a
08/05/98 16:51:39 |
Joel Sherrill |
Patch from Eric Valette <valette@…> which brings the i386ex …
4.104.114.84.95
@ab0df696
08/05/98 15:15:46 |
Joel Sherrill |
Automatic CPU type detection code from Eric Valette …
4.104.114.84.95
@5094711
08/05/98 15:12:03 |
Joel Sherrill |
Fixed name of Buffer so this would compile.
4.104.114.84.95
@4d11a92f
08/05/98 15:11:33 |
Joel Sherrill |
Redid Makefiles to properly do a preinstall. There was remnants of …
4.104.114.84.95
@7fc5d54e
08/03/98 21:01:21 |
Joel Sherrill |
Switched to read/write register routines and added some basic debug
help.
4.104.114.84.95
@92ef225
08/03/98 15:06:27 |
Joel Sherrill |
Under allcoated task stacks.
4.104.114.84.95
@93e3b8a3
08/01/98 15:01:59 |
Joel Sherrill |
Moved to network demos
4.104.114.84.95
@8c6e195
08/01/98 14:41:45 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…> to make ASFLAGS include …
4.104.114.84.95
@906577f4
08/01/98 14:41:20 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…> to not use this file for …
4.104.114.84.95
@5ef4fae
08/01/98 14:40:51 |
Joel Sherrill |
Merged patch from David Fiddes <D.J.Fiddes@…> to add ColdFire? …
4.104.114.84.95
@2889189
07/30/98 22:57:21 |
Joel Sherrill |
Changed name of network driver.
4.104.114.84.95
@fa655207
07/30/98 22:57:12 |
Joel Sherrill |
Added temporary include of dmv170.h
4.104.114.84.95
@4fbf114
07/30/98 22:56:56 |
Joel Sherrill |
Added SONIC configuration information.
4.104.114.84.95
@56392179
07/30/98 22:56:17 |
Joel Sherrill |
Added a hint to continue writing this.
4.104.114.84.95
@d9bc023a
07/30/98 21:30:46 |
Joel Sherrill |
Updated.
4.104.114.84.95
@509dc7c1
07/30/98 21:27:51 |
Joel Sherrill |
Added getRealTime() and setRealTime().
Reimplemented checkRealTime() …
4.104.114.84.95
@91af3e4
07/30/98 21:27:01 |
Joel Sherrill |
Changed clock rate from 32 Khz to 1 Mhz.
Registers are at 8 byte …
4.104.114.84.95
@a47bca7c
07/30/98 21:26:25 |
Joel Sherrill |
Changed comment to be more polite.
4.104.114.84.95
@8e992e1
07/30/98 21:26:11 |
Joel Sherrill |
Updating to make more readable.
4.104.114.84.95
@192a1e0
07/30/98 19:51:03 |
Joel Sherrill |
New files.
4.104.114.84.95
@1aa4186
07/30/98 19:41:46 |
Joel Sherrill |
Spacing corrected.
4.104.114.84.95
@1a256e3
07/30/98 19:41:41 |
Joel Sherrill |
New file based on email from DY-4 technical support.
4.104.114.84.95
@1c5f4e1
07/30/98 19:26:47 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@8751f800
07/30/98 19:25:54 |
Joel Sherrill |
Updated to accurately reflect the dmv177.
4.104.114.84.95
@41d07439
07/30/98 18:06:51 |
Joel Sherrill |
Patch from Eric Valette <valette@…>:
Now that Joel …
4.104.114.84.95
@7fd8641
07/30/98 16:07:54 |
Joel Sherrill |
Made chain.h shared
4.104.114.84.95
@3fdde4ce
07/30/98 16:05:14 |
Joel Sherrill |
Made tod.h shared
4.104.114.84.95
@02733a96
07/29/98 00:38:51 |
Joel Sherrill |
New file. Based on merged of shared libchip style console.c and the …
4.104.114.84.95
@acac0e8
07/29/98 00:38:14 |
Joel Sherrill |
Cleaned up comment.
Modified open so it uses a local variable rather …
4.104.114.84.95
@6a0f5ac2
07/29/98 00:37:37 |
Joel Sherrill |
Added reference to shared TOD driver.
4.104.114.84.95
@c95e927
07/29/98 00:18:11 |
Joel Sherrill |
Added prototype for default register access routines to header files.
4.104.114.84.95
@ee306fd
07/29/98 00:17:01 |
Joel Sherrill |
Corrected to reflect the ICM7170 which is really on this board.
4.104.114.84.95
@55dcdfd
07/29/98 00:16:44 |
Joel Sherrill |
Added config.c and deleted tod.c.
4.104.114.84.95
@e74735b2
07/29/98 00:16:32 |
Joel Sherrill |
Simplified RTC base address.
4.104.114.84.95
@5217d5a
07/29/98 00:16:11 |
Joel Sherrill |
Changed cast on RTC address and added base address of RTC fields as …
4.104.114.84.95
@fb339a8
07/29/98 00:04:02 |
Joel Sherrill |
Deleted probe routine as device specific.
Renamed port table.
4.104.114.84.95
@866c9dd5
07/29/98 00:03:12 |
Joel Sherrill |
Added function table.
4.104.114.84.95
@cb5e6f68
07/29/98 00:03:07 |
Joel Sherrill |
Renamed control register constants.
Set time->ticks to 0.
Added …
4.104.114.84.95
@1177cda
07/29/98 00:02:11 |
Joel Sherrill |
New files for Harris Semiconductor ICM7170.
4.104.114.84.95
@8d6e7120
07/29/98 00:01:56 |
Joel Sherrill |
New files.
4.104.114.84.95
@677943a
07/29/98 00:01:44 |
Joel Sherrill |
Added new files.
4.104.114.84.95
@9968efb
07/28/98 23:16:34 |
Joel Sherrill |
First cut at configuration table for libchip RTC. At this point, we …
4.104.114.84.95
@a1f514f
07/28/98 23:03:40 |
Joel Sherrill |
First cut implementation of real-time clock support in libchip. This …
4.104.114.84.95
@009c235
07/28/98 21:18:17 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@07e91808
07/28/98 21:18:11 |
Joel Sherrill |
Added rtc directory.
4.104.114.84.95
@30cde042
07/28/98 16:50:14 |
Joel Sherrill |
Added missing parts of patch from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@bd7c547
07/28/98 16:49:36 |
Joel Sherrill |
Closed window thanks to patch from Eric Norum.
4.104.114.84.95
@5752f930
07/25/98 17:34:41 |
Joel Sherrill |
New file -- copied from dmv177 but same as ppcn_60x.
4.104.114.84.95
@749c54e
07/25/98 17:22:58 |
Joel Sherrill |
Added comments and corrected spacing.
4.104.114.84.95
@cae0504
07/25/98 17:19:45 |
Joel Sherrill |
Corrected spacing and added headers.
4.104.114.84.95
@8739322
07/25/98 17:17:46 |
Joel Sherrill |
Added ns16550_set_attributes.
4.104.114.84.95
@b636d56
07/25/98 17:17:36 |
Joel Sherrill |
Corrected spacing and added a comment.
4.104.114.84.95
@ccfa60b
07/25/98 17:17:05 |
Joel Sherrill |
Updated to reflect set attributes.
4.104.114.84.95
@70a9451
07/25/98 16:53:21 |
Joel Sherrill |
Rewrote NS16550 TX interrupt processing to use termios for the buffer …
4.104.114.84.95
@adedb057
07/25/98 16:52:17 |
Joel Sherrill |
Removed TX ring buffer.
4.104.114.84.95
@cb27f05
07/25/98 16:52:00 |
Joel Sherrill |
Changed variable to hold received data to unsigned.
4.104.114.84.95
@dfb16ce
07/25/98 16:20:33 |
Joel Sherrill |
Added constants for z85c30_enable_interrupts.
4.104.114.84.95
@04c5ac7
07/25/98 16:20:14 |
Joel Sherrill |
Removed z85c30_flush().
Reworked transmit interrupt processing to …
4.104.114.84.95
@c1da250
07/25/98 16:18:46 |
Joel Sherrill |
Changed comment on TxBuffer?.
4.104.114.84.95
@b070d69a
07/25/98 16:18:27 |
Joel Sherrill |
Removed mc68681_flush and corrected spacing.
4.104.114.84.95
@f600da3f
07/25/98 16:17:33 |
Joel Sherrill |
Added information on Chris Johns' suggestion to use pointers …
4.104.114.84.95
@3d2c161
07/25/98 16:16:10 |
Joel Sherrill |
Removed "if 0" used to switch between serial ports.
4.104.114.84.95
@da8ac60a
07/25/98 16:02:21 |
Joel Sherrill |
New file.
4.104.114.84.95
@c68b990
07/25/98 14:51:57 |
Joel Sherrill |
Changed to utilize return status from …
4.104.114.84.95
@a3c9f0d
07/25/98 14:50:07 |
Joel Sherrill |
Moved console.c to libbsp/shared.
4.104.114.84.95
@f246caf
07/25/98 14:13:34 |
Joel Sherrill |
Interrupts were incorrectly managed with a disable/disable pair rather …
4.104.114.84.95
@bf21172
07/24/98 18:30:50 |
Joel Sherrill |
changed version to 980724
4.104.114.84.95
