Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @d880d40a   10/08/12 14:22:25 Sebastian Huber bsp/qoriq: Fix maximum packet size 4.115
(edit) @52c8df84   10/01/12 13:43:22 dufault bsp/mpc55xx: PR2077: Add BSP_DEFAULT_BAUD_RATE 4.115
(edit) @6527d87   10/01/12 13:25:32 dufault bsp/mpc55xx: PR2077: Avoid PPC_USE_SPE 4.115
(edit) @2a6ec317   10/01/12 13:22:52 dufault bsp/mpc55xx: PR2077: Mapping for external flash 4.115
(edit) @967481a0   10/01/12 13:12:25 dufault bsps: PR2076: SMC91111 fixes for mpc55xxevb BSP - A typo prevents … 4.115
(edit) @245cad5   10/01/12 12:28:32 Sebastian Huber bsp/mpc55xx: Fix bsp_idle_thread() 4.115
(edit) @94102775   10/01/12 13:02:57 Sebastian Huber bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILY 4.115
(edit) @63241f8   09/28/12 21:37:58 Joel Sherrill pc386: Add Cirrus FB Driver to Makefile and configure.ac The user has … 4.115
(edit) @f97e450   09/28/12 21:37:58 alex.sever.h FB driver for Cirrus GD5446 graphic hardware. Implementation is … 4.115
(edit) @b762488e   09/28/12 14:02:28 Sebastian Huber bsp/mpc55xx: Add e200z7 specific idle task 4.115
(edit) @7f5ab84e   09/28/12 11:48:32 Sebastian Huber bsps/arm: Fix rtems_mii_ioctl() usage 4.115
(edit) @afd1967   09/24/12 10:51:47 Sebastian Huber bsps/arm: Add LPC_DMA_CHANNEL_COUNT 4.115
(edit) @3850af9   09/06/12 14:40:17 Joel Sherrill mpc55xxevb: Fix compilation in start-config-siu-pcr.c 4.115
(edit) @7b865a4   08/16/12 13:55:03 christian.mauderer bsp/mpc55xx: Use a one second timeout 4.115
(edit) @f9fe954   08/16/12 10:19:14 christian.mauderer bsp/mpc55xx: Fix SMSC9218I_BIG_ENDIAN_SUPPORT 4.115
(edit) @6f89813   08/09/12 13:47:08 christian.mauderer bsp/mpc55xx: Move work from ISR to task context 4.115
(edit) @d9af2ed4   08/20/12 08:15:20 thomas.doerfler bsp/gen83xx: Add br_uid BSP variant 4.115
(edit) @25802b42   08/13/12 13:32:03 Sebastian Huber bsp/lpc32xx: Specify scratch area alignment 4.115
(edit) @f5db5d2   08/13/12 13:24:03 Sebastian Huber bsp/lpc32xx: Stop unused DDRAM_CLK 4.115
(edit) @25a8c022   08/13/12 09:51:45 Sebastian Huber bsp/lpc32xx: Fix clock name Rename lpc32xx_dram_clk() in … 4.115
(edit) @6cfe52f   07/25/12 13:51:21 Sebastian Huber bsp/lpc32xx: Add lpc32xx_select_nand_controller() 4.115
(edit) @833ac60   08/06/12 16:32:49 Sebastian Huber bsp/lpc24xx: Use USB RAM for fast data section 4.115
(edit) @ea97782   08/06/12 17:06:35 Gedare Bloom Delete leftover bspopts.h.in from revert 4.115
(edit) @c717fda5   08/06/12 17:03:46 Gedare Bloom Revert "Add bspopts.h.in." This reverts commit … 4.115
(edit) @69b346b   07/25/12 11:48:20 Sebastian Huber bsp/mpc55xx: eQADC register changes 4.115
(edit) @b0753c3   07/19/12 07:18:17 Sebastian Huber bsp/mpc55xx: Add MPC55XX_CONSOLE_MINOR Remove MPC55XX_ESCI_CONSOLE_MINOR. 4.115
(edit) @89c92a0   07/19/12 07:08:07 Sebastian Huber bsp/mpc55xx: Whitespace changes 4.115
(edit) @208f479   07/19/12 07:05:46 Sebastian Huber bsp/mpc55xx: New EBI settings for MPC5674F boards 4.115
(edit) @0ec2c36   07/19/12 15:02:16 Ralf Corsepius Use http://www.rtems.org/bugzilla as bug-URL. 4.115
(edit) @d7af336   07/19/12 15:00:56 Ralf Corsepius Reformat AC_INIT. 4.115
(edit) @1c554014   07/19/12 14:14:53 Ralf Corsepius Remove CVS-Ids. 4.115
(edit) @59bd5115   07/19/12 13:59:46 Ralf Corsepius Remove CVS-Ids. 4.115
(edit) @bb2b825   07/19/12 13:47:55 Ralf Corsepius Require automake-1.12.2. 4.115
(edit) @0f77281   07/19/12 13:44:32 Ralf Corsepius Require autoconf-2.69. 4.115
(edit) @cece8db   07/17/12 15:41:21 Sebastian Huber bsp/mpc55xx: Add SMSC9218I_IRQ_PIN 4.115
(edit) @f024d4f   07/17/12 15:40:53 Sebastian Huber bsp/mpc55xx: Add SMSC9218I_RESET_PIN 4.115
(edit) @dec7231   07/17/12 15:39:00 Sebastian Huber bsp/mpc55xx: Add SMSC9218I_ENABLE_LED_OUTPUTS 4.115
(edit) @86c5b1c   07/17/12 15:23:31 Sebastian Huber bsp/mpc55xx: Add SMSC9218I_BIG_ENDIAN_SUPPORT 4.115
(edit) @d740e60   07/17/12 15:00:16 Sebastian Huber bsp/mpc55xx: New ECU508 BSPs 4.115
(edit) @64d72e8   07/17/12 15:51:46 Sebastian Huber bsp/mpc55xx: Add ESCI_C and ESCI_D support 4.115
(edit) @dafacfa7   07/18/12 07:26:13 Sebastian Huber bsp/mpc55xx: Add MPC55XX_SYSTEM_CLOCK_DIVIDER 4.115
(edit) @b9b3f3b7   07/18/12 07:20:46 Sebastian Huber bsp/mpc55xx: Add MPC55XX_NULL_POINTER_PROTECTION 4.115
(edit) @32ec0f6b   07/17/12 14:56:58 Sebastian Huber bsp/mpc55xx: Add MPC55XX_NEEDS_LOW_LEVEL_INIT 4.115
(edit) @356c928   04/03/12 12:35:55 Christian.Mauderer bsp/mpc55xx: Implement network interface off 4.115
(edit) @2d43f2d   03/29/12 08:58:37 christian.mauderer bsp/mpc55xx: Support re-initialization of eDMA 4.115
(edit) @c838ca2d   03/29/12 08:58:10 christian.mauderer bsp/mpc55xx: Add bsp_restart() 4.115
(edit) @c44b517   07/17/12 13:00:47 Sebastian Huber bsp/mpc55xx: Add union name 4.115
(edit) @afcbd3b2   07/17/12 14:44:50 Sebastian Huber bsp/mpc55xx: Add output value to PCR config 4.115
(edit) @864cf50   07/17/12 21:20:01 Joel Sherrill mips/malta: Add sections for new FreeBSD TCP/IP stack 4.115
(edit) @c4547d81   07/17/12 21:19:44 Joel Sherrill mips/jmr3904: Add sections for new FreeBSD TCP/IP stack 4.115
(edit) @aae7daa9   07/16/12 08:56:30 Sebastian Huber Fix broken _endtext symbol 4.115
(edit) @93b1e4b   07/14/12 19:26:43 Joel Sherrill shsim linkcmds: Add new FreeBSD TCP/IP stack sections 4.115
(edit) @c2395717   07/14/12 19:26:20 Joel Sherrill sparc linkcmds.base: Add new FreeBSD TCP/IP stack sections 4.115
(edit) @c5ba8ba   07/09/12 08:44:47 xiangfu bsps/lm32: PR2045: Add mic boost option 4.115
(edit) @574ab8a   06/22/12 08:31:44 Sebastian Huber bsps/powerpc: Add more BSP sections and sort them 4.115
(edit) @a94bcc5a   06/15/12 11:44:08 Sebastian Huber bsp/lpc24xx: More flexible region configuration 4.115
(edit) @62b4fe1   06/15/12 11:07:52 Sebastian Huber bsp/lpc24xx: Fix timing for M29W320E70 4.115
(edit) @4e0755c8   06/15/12 07:51:14 Sebastian Huber bsp/lpc24xx: Add lpc24xx_module_is_enabled() 4.115
(edit) @696c451   06/12/12 07:53:52 Sebastian Huber bsp/lpc24xx: Ethernet support for EA LPC1788 board 4.115
(edit) @e7395c7   06/12/12 07:55:52 Sebastian Huber bsp/lpc24xx: Ethernet support for LPC17XX 4.115
(edit) @8462a96d   06/12/12 07:53:27 Sebastian Huber bsp/lpc24xx: Use external RAM 4.115
(edit) @3e600b2   06/13/12 11:54:36 Sebastian Huber bsp/lpc24xx: Use RAS and CAS of 2 for IS42S32800B 4.115
(edit) @e4bda046   06/11/12 12:48:42 Sebastian Huber bsp/lpc24xx: Simplify EMCDLYCTL handling 4.115
(edit) @f7deb58   06/11/12 06:51:32 Sebastian Huber bsp/lpc24xx: Simplify EMC configuration 4.115
(edit) @d40b09d   06/06/12 13:03:37 Sebastian Huber bsp/lpc24xx: New BSP variants (PLX800 on LPC1778) 4.115
(edit) @7329f55   06/06/12 12:48:23 Sebastian Huber bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m 4.115
(edit) @c39148d6   06/14/12 12:27:58 Sebastian Huber libchip: Add support for NS16550 with FDR 4.115
(edit) @50fc8f6   06/13/12 07:44:32 Sebastian Huber sapi: Add nanoseconds_per_tick to configuration Add … 4.115
(edit) @fd153c73   06/12/12 13:27:17 Sebastian Huber bsps: Replace NIRVANA region Replace the "NIRVANA" region with the … 4.115
(edit) @51c85da2   06/12/12 10:26:35 Sebastian Huber libchip/ata: Fix pre-processor symbol evaluation 4.115
(edit) @2d7ae960   06/11/12 18:37:29 Joel Sherrill v850 port: Initial addition with BSP for simulator in GDB Port + … 4.115
(edit) @eb1951a   05/22/12 15:21:28 Sebastian Huber powerpc/mpc55xx: BSP variant changes for MPC5643L 4.115
(edit) @5bd7bd5a   06/04/12 11:26:34 Sebastian Huber bsp/t32mppc: Fix Trace32 configuration file 4.115
(edit) @6273201   05/31/12 14:37:02 Sebastian Huber bsps/powerpc: Add load section for .nocache 4.115
(edit) @105ccdd5   05/21/12 08:34:23 Sebastian Huber bsp/qoriq: New BSP option New BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH. 4.115
(edit) @1869bb7   05/18/12 13:47:23 Sebastian Huber powerpc: Simplify context switch PowerPC cores with the SPE (Signal … 4.115
(edit) @721fe34   05/31/12 20:34:36 Joel Sherrill Fix C files which had two semi-colons at EOL 4.115
(edit) @bb08c0c8   05/30/12 18:10:43 Jennifer Averett pc386: Added sections for rtems-libbsd support. 4.115
(edit) @daffa60   05/24/12 04:36:40 Ralf Corsepius Add bspopts.h.in. 4.115
(edit) @14811a0   05/22/12 13:07:48 Sebastian Huber powerpc/t32mppc: Typo 4.115
(edit) @e21c287c   05/21/12 12:56:31 Sebastian Huber powerpc/t32mppc: New BSP 4.115
(edit) @1901afc5   05/21/12 07:57:53 Sebastian Huber powerpc/qoriq: Fix due to console API changes 4.115
(edit) @a880c90   05/18/12 13:41:56 Sebastian Huber powerpc/mpc55xxevb: Fix cache define usage 4.115
(edit) @6963854d   05/18/12 05:47:52 Ralf Corsepius Remove references to configure.in. 4.115
(edit) @cf65bb00   05/18/12 05:37:45 Ralf Corsepius Remove obsolete reference to posix bsp. 4.115
(edit) @8bbf69e   05/16/12 21:04:10 Joel Sherrill pci.h cleanup - Consolidate common defines to cpukit pci.h + … 4.115
(edit) @13647019   05/16/12 19:47:31 Joel Sherrill mvme5500 and cpukit pci.h - Eliminate mvme5500 specific pci.h All … 4.115
(edit) @226d48d8   05/16/12 15:20:35 Daniel Hellstrom LEON: moved register definitions into grlib header file Some register … 4.115
(edit) @da154e14   05/14/12 14:55:41 Sebastian Huber Filesystem: Move operations to mount table entry The scope of the … 4.115
(edit) @65c6425   05/03/12 17:24:46 Joel Sherrill Remove CVS Id Strings (manual edits after script) These modifications … 4.115
(edit) @9b4422a2   05/03/12 15:09:24 Joel Sherrill Remove All CVS Id Strings Possible Using a Script Script does what is … 4.115
(edit) @183af89   05/03/12 19:17:23 Joel Sherrill Miscellaneous - Clean up file headers so patterns followed XXX 4.115
(edit) @9ee5b97   05/11/12 13:33:36 Joel Sherrill librtems++ - Remove junk line accidentally committed 4.115
(edit) @eb7c6a84   05/10/12 16:17:59 Joel Sherrill pc386 - Clock driver compiles again plus clean up The clock drivers … 4.115
(edit) @79fee34   05/10/12 12:59:49 Joel Sherrill clockdrv_shell.h - Fix commment 4.115
(edit) @153ef54   05/10/12 12:59:21 Joel Sherrill clockdrv_shell.c - Remove unreferenced and obsolete file 4.115
(edit) @314fab55   05/10/12 12:27:19 Joel Sherrill Clock Driver Shell - ISR handler prototype should follow port … 4.115
(edit) @42547e07   05/10/12 12:26:07 Joel Sherrill nds - Clock driver compiles again 4.115
(edit) @4523829a   05/10/12 12:25:29 Joel Sherrill nds/libnds - Fix missing prototype warning and formatting 4.115
(edit) @890c55c7   05/09/12 23:02:01 Joel Sherrill hurricane - Remove unused file setvec.c 4.115
