Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @d1d7e807   05/23/96 20:43:04 Joel Sherrill new files 4.104.114.84.95
(edit) @a1c86cbe   05/23/96 20:37:09 Joel Sherrill new files 4.104.114.84.95
(edit) @3d135eea   05/23/96 19:56:49 Joel Sherrill cleanup 4.104.114.84.95
(edit) @d3fed0a3   05/23/96 19:54:08 Joel Sherrill new files 4.104.114.84.95
(edit) @02bfc56   05/23/96 19:31:54 Joel Sherrill cleanup status vs. result 4.104.114.84.95
(edit) @318ac69   05/23/96 19:23:54 Joel Sherrill new files 4.104.114.84.95
(edit) @7af3a828   05/23/96 19:09:21 Joel Sherrill new files 4.104.114.84.95
(edit) @f2cb4ac   05/23/96 19:04:18 Joel Sherrill new files 4.104.114.84.95
(edit) @57fc51c   05/23/96 18:55:32 Joel Sherrill new files 4.104.114.84.95
(edit) @41e7a1d8   05/23/96 18:43:59 Joel Sherrill new files 4.104.114.84.95
(edit) @9854e336   05/23/96 18:08:15 Joel Sherrill updated to reflect more constants and feature macros 4.104.114.84.95
(edit) @8b2ecf85   05/23/96 15:37:38 Joel Sherrill updates from Tony Bennett 4.104.114.84.95
(edit) @64b976a   05/23/96 15:36:46 Joel Sherrill added code to insure that delay is always non-zero 4.104.114.84.95
(edit) @a6aded4f   05/23/96 15:36:08 Joel Sherrill updates from tony bennett 4.104.114.84.95
(edit) @0553a3a   05/23/96 15:35:56 Joel Sherrill added as example of how to do a bsp which is not in this tree. 4.104.114.84.95
(edit) @a5f56a43   05/23/96 15:35:32 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @859f17ce   05/23/96 15:35:26 Joel Sherrill invoke thread stack free routine instead of Workspace free. 4.104.114.84.95
(edit) @d196e48   05/23/96 15:34:54 Joel Sherrill updates from Tony Bennett. Broke the setjmp/longjmp pair in the … 4.104.114.84.95
(edit) @2328475   05/22/96 22:39:47 Joel Sherrill created posix test suite with test of header files 4.104.114.84.95
(edit) @ef006c1   05/22/96 22:34:18 Joel Sherrill Modified to correct variables which defined the range of object … 4.104.114.84.95
(edit) @f4719d5a   05/22/96 22:32:39 Joel Sherrill These files have been modified in the initial pass at getting the … 4.104.114.84.95
(edit) @05195890   05/22/96 22:31:51 Joel Sherrill These files have been modified in the initial pass at getting the … 4.104.114.84.95
(edit) @4e684a31   05/10/96 20:24:07 Joel Sherrill added posix test directory 4.104.114.84.95
(edit) @92262ab   05/10/96 20:23:27 Joel Sherrill fixed typo 4.104.114.84.95
(edit) @3e7b167   05/08/96 21:55:41 Joel Sherrill updated to remove workaround for bug in binutils 2.5.2 ld now that we … 4.104.114.84.95
(edit) @1c964ffa   05/08/96 21:53:50 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @bf6661e   05/02/96 14:39:07 Joel Sherrill Updated version to 3.5.15. 4.104.114.84.95
(edit) @996a9cb4   05/01/96 15:25:33 Joel Sherrill Updates from Eric Norum. 4.104.114.84.95
(edit) @dce1c1a1   05/01/96 15:24:37 Joel Sherrill Updates from Eric Norum to use the mcpu32 flags and fix comments. 4.104.114.84.95
(edit) @a412622   04/24/96 21:21:14 Joel Sherrill changed version number to 3.5.14 4.104.114.84.95
(edit) @11532ca   04/24/96 20:05:52 Joel Sherrill Hacked so gld will accept this so we can purge the aout toolset. This … 4.104.114.84.95
(edit) @1543932   04/24/96 17:36:35 Joel Sherrill added comment regarding stack alignment issues to thread stack … 4.104.114.84.95
(edit) @d2d6467   04/22/96 23:58:40 Joel Sherrill Lowered number of messages created to reduce burden on workspace. 4.104.114.84.95
(edit) @8389628   04/22/96 16:53:46 Joel Sherrill updates from Tony Bennett 4.104.114.84.95
(edit) @5a36154a   04/22/96 16:53:05 Joel Sherrill addition of optional user provided stack allocator means that we can … 4.104.114.84.95
(edit) @1f94ed6b   04/22/96 16:50:17 Joel Sherrill Updates from Tony Bennett. 4.104.114.84.95
(edit) @34f3d17   04/22/96 16:49:53 Joel Sherrill Updates from Tony Bennett. rtems_environp removed among other minor … 4.104.114.84.95
(edit) @f5674938   04/22/96 16:49:25 Joel Sherrill Fixed so now supports more than 16 nodes. Tested for up to 24 nodes … 4.104.114.84.95
(edit) @8faca06   04/22/96 16:46:36 Joel Sherrill thread.c: added support for optional user provided stack allocator … 4.104.114.84.95
(edit) @6365f81   04/22/96 16:46:00 Joel Sherrill made initialization routine a regular subroutine 4.104.114.84.95
(edit) @a155b3c   04/22/96 16:45:47 Joel Sherrill interr.h: added stack allocater error code wkspace.h: made … 4.104.114.84.95
(edit) @cc4c1fe4   04/22/96 16:44:54 Joel Sherrill added stack allocation fields to the cpu table updates from Tony … 4.104.114.84.95
(edit) @96981e3a   04/22/96 16:44:04 Joel Sherrill added stack allocation fields to the cpu table 4.104.114.84.95
(edit) @9a1ccb3   04/22/96 16:43:44 Joel Sherrill added stack allocation fields to the cpu table added CPU_M68K_EXTB_L … 4.104.114.84.95
(edit) @f581163a   04/22/96 16:30:30 Joel Sherrill added stack allocation fields to the cpu table 4.104.114.84.95
(edit) @d0b7c4e6   04/22/96 16:30:02 Joel Sherrill updartes from Tony Bennett 4.104.114.84.95
(edit) @767a6c6   04/20/96 16:48:30 Joel Sherrill swapped order of operands on a movw to fix LOAD_SEGMENTS macro 4.104.114.84.95
(edit) @debe919   04/19/96 21:10:58 Joel Sherrill event.c: _Event_Manager_initialization no longer a static inline … 4.104.114.84.95
(edit) @78b2ff1   04/19/96 21:10:38 Joel Sherrill _Event_Manager_initialization no longer a static inline 4.104.114.84.95
(edit) @c26b62f   04/19/96 21:10:32 Joel Sherrill event.h: _Event_Manager_initialization no longer a static inline 4.104.114.84.95
(edit) @8f9e9bdc   04/19/96 21:10:27 Joel Sherrill event.h: _Event_Manager_initialization no longer a static inline … 4.104.114.84.95
(edit) @3b76313   04/19/96 21:09:20 Joel Sherrill modified to generate fatal error when an unconfigured directive is invoked. 4.104.114.84.95
(edit) @f4d52cd7   04/19/96 19:36:59 Joel Sherrill changes to compile in macro configuration without warnings. 4.104.114.84.95
(edit) @8cf88427   03/21/96 20:20:40 Joel Sherrill minor mods to get to compile locally 4.104.114.84.95
(edit) @487a7ca   03/21/96 20:20:27 Joel Sherrill some instructions altered for older binutils 4.104.114.84.95
(edit) @99e7cbbb   03/21/96 20:20:13 Joel Sherrill updated 4.104.114.84.95
(edit) @14966f8   03/21/96 20:19:55 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @f398452   03/21/96 20:19:33 Joel Sherrill updated for 68302 and so gen68360 bsp would compile 4.104.114.84.95
(edit) @d08b1c75   03/21/96 20:19:03 Joel Sherrill update to reflect internal threads reorganization 4.104.114.84.95
(edit) @bdf531ee   03/06/96 22:25:11 Joel Sherrill include of mc68360.h changed to m68360.h to reflect filename change. 4.104.114.84.95
(edit) @110f4ff7   03/06/96 22:23:56 Joel Sherrill Added 68360 support submitted by W. Eric Norum … 4.104.114.84.95
(edit) @457b6ae   03/06/96 22:01:11 Joel Sherrill Generic 68360 BSP (gen360) submitted by: W. Eric Norum … 4.104.114.84.95
(edit) @e6424462   03/06/96 21:37:43 Joel Sherrill As part of reducing visibility into rtems and hiding the .inl files … 4.104.114.84.95
(edit) @1a8fde6c   03/06/96 21:34:57 Joel Sherrill Removed prototyes for static inline routines and moved the comments … 4.104.114.84.95
(edit) @8e76546   03/06/96 21:26:28 Joel Sherrill Removed prototyes for static inline rgutines and moved the comments … 4.104.114.84.95
(edit) @ba39113   02/22/96 20:14:36 Joel Sherrill The name of the test support routine pause was changed to … 4.104.114.84.95
(edit) @66d9e3ad   02/21/96 22:37:55 Joel Sherrill Changed io manager initialization routine to not be static and added … 4.104.114.84.95
(edit) @10017a72   02/21/96 22:37:47 Joel Sherrill Changed io manager initialization routine to not be static. 4.104.114.84.95
(edit) @4ff1920   02/21/96 22:37:18 Joel Sherrill changed io manager initialization routine to not be static 4.104.114.84.95
(edit) @0e0d88b   02/21/96 14:47:58 Joel Sherrill Dispersal of internal thread handler resulted in removal of some … 4.104.114.84.95
(edit) @8cbbe312   02/21/96 14:47:03 Joel Sherrill Dispersal of internal thread handler resulted in the SYSI task being … 4.104.114.84.95
(edit) @adf98bd   02/21/96 14:44:11 Joel Sherrill Removed the internal thread objects and dispersed its contents to the … 4.104.114.84.95
(edit) @75f09e5   02/21/96 14:43:34 Joel Sherrill Dispersal of internal thread handler resulted in IDLE thread becoming … 4.104.114.84.95
(edit) @c4b8161d   02/21/96 14:37:32 Joel Sherrill MPCI Receive became a thread and the prototype changed. 4.104.114.84.95
(edit) @56d34e6   02/21/96 14:32:02 Joel Sherrill Removed the internal thread objects and dispersed its contents to the … 4.104.114.84.95
(edit) @b2b52cbc   02/14/96 19:00:00 Joel Sherrill Removed arguments from _Thread_Start_multitasking. 4.104.114.84.95
(edit) @f972294d   02/14/96 18:59:37 Joel Sherrill idle thread now created before system initialization thread. Also … 4.104.114.84.95
(edit) @744d2878   02/14/96 18:48:39 Joel Sherrill removed arguments from _Thread_Start_multitasking 4.104.114.84.95
(edit) @df26b788   02/14/96 17:06:57 Joel Sherrill white space problem 4.104.114.84.95
(edit) @389fa850   02/14/96 17:06:40 Joel Sherrill Moved some initialization from the system initialization thread to … 4.104.114.84.95
(edit) @8bde6ea9   02/13/96 22:16:36 Joel Sherrill removed post switch extension 4.104.114.84.95
(edit) @da646dd   02/13/96 22:15:52 Joel Sherrill fixed bug when outbyte had argument in wrong order relative to those … 4.104.114.84.95
(edit) @94b3ec59   02/13/96 22:14:48 Joel Sherrill changed post task extension from user set to api set and added flag in … 4.104.114.84.95
(edit) @6ca1184   02/13/96 22:14:25 Joel Sherrill added clear of _ISR_Signals_to_thread_executing 4.104.114.84.95
(edit) @391f6628   02/13/96 15:38:37 Joel Sherrill more comments added and existing ones cleaned up in synchronization paths 4.104.114.84.95
(edit) @b38955b   02/13/96 15:38:03 Joel Sherrill comma removed from end of last enumerated element 4.104.114.84.95
(edit) @18269cef   02/13/96 15:37:33 Joel Sherrill comment added to describe synchronization logic in timeout routine 4.104.114.84.95
(edit) @a31ddf7   02/12/96 14:36:09 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @8c8a924   02/09/96 14:31:39 Joel Sherrill As part of implementing the new isr synchronization algorithm using a … 4.104.114.84.95
(edit) @107ce47b   02/09/96 14:30:42 Joel Sherrill new isr synchronization algorithm using a single enumerated set of states. 4.104.114.84.95
(edit) @6dae1c2d   02/09/96 14:25:33 Joel Sherrill added rtems_interrupt_is_in_progress 4.104.114.84.95
(edit) @8a38f3b   02/09/96 14:21:37 Joel Sherrill added clear of _ISR_Signals_to_thread_executing 4.104.114.84.95
(edit) @f3dabb04   02/08/96 22:16:35 Joel Sherrill changed synchronization algorithm to be a single list of enumerated states 4.104.114.84.95
(edit) @d57392d   02/08/96 16:18:38 Joel Sherrill alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT 4.104.114.84.95
(edit) @4f60309b   02/01/96 22:09:07 Joel Sherrill Swapped order of nested acquisition check and check for returning … 4.104.114.84.95
(edit) @f00a0522   02/01/96 21:54:40 Joel Sherrill synchronization state bugs address 4.104.114.84.95
(edit) @665356af   02/01/96 19:39:21 Joel Sherrill invalid use of tcb field resource count 4.104.114.84.95
(edit) @4f7c546e   01/22/96 21:12:12 Joel Sherrill new times for 3.5.1 4.104.114.84.95
(edit) @c3dcd6e   01/19/96 22:22:12 Joel Sherrill Added RTEMS API control structure to per task memory usage macro. 4.104.114.84.95
(edit) @709b93d   01/19/96 22:21:46 Joel Sherrill Increased stack size. 4.104.114.84.95
