@cc51de91
09/17/96 21:38:59 |
Joel Sherrill |
extended Task_id and Task_name arrays to avoid indexing past end of array.
4.104.114.84.95
@1d9d044
09/17/96 21:33:07 |
Joel Sherrill |
Reversed logic in conditional to correctly distinguish between
FIFO …
4.104.114.84.95
@41be2e8
09/17/96 21:31:30 |
Joel Sherrill |
added routine _POSIX_Timespec_subtract
4.104.114.84.95
@aa48536
09/17/96 21:31:10 |
Joel Sherrill |
Added code to insure that the post switch extension was executed and …
4.104.114.84.95
@9093c3c
09/17/96 21:29:51 |
Joel Sherrill |
Corrected implementation of timed wait on condition variables. First …
4.104.114.84.95
@ded66f8
09/17/96 21:26:25 |
Joel Sherrill |
added prototype for _POSIX_Timespec_subtract
4.104.114.84.95
@09093ee
09/12/96 20:41:27 |
Mark.Johannes |
Fixed test to match change to pthread_cond_timedwait which now takes a …
4.104.114.84.95
@cda277f
09/11/96 19:16:07 |
Joel Sherrill |
added $Id$ to file headers
cpu.h: added prototype for _CPU_ISR_Get_level()
4.104.114.84.95
@0971cd5
09/11/96 19:15:09 |
Joel Sherrill |
added $ string to file header
4.104.114.84.95
@5bb00a8
09/11/96 19:13:44 |
Joel Sherrill |
added $Id$ string to file header
4.104.114.84.95
@9c0d032
09/11/96 19:12:43 |
Joel Sherrill |
new files
4.104.114.84.95
@b944007b
09/08/96 16:24:43 |
Joel Sherrill |
added definition of EXT_INT5
4.104.114.84.95
@3d07c8b
09/08/96 16:24:13 |
Joel Sherrill |
added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE
4.104.114.84.95
@bdef2d8
09/08/96 16:23:35 |
Joel Sherrill |
idtmem.S: changed reference to include files to correct location
4.104.114.84.95
@eaa34e7
09/08/96 16:22:29 |
Joel Sherrill |
4.104.114.84.95
@3335420
09/08/96 16:22:05 |
Joel Sherrill |
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it …
4.104.114.84.95
@e7a36a9
09/08/96 16:21:48 |
Joel Sherrill |
Ada task stack size minimize is twice that for regular pthreads.
4.104.114.84.95
@ed5a518
09/08/96 16:21:16 |
Joel Sherrill |
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be …
4.104.114.84.95
@8445e57
09/06/96 19:57:21 |
Joel Sherrill |
removed need for exceptbdr.h file
4.104.114.84.95
@f198c63
09/06/96 18:11:41 |
Joel Sherrill |
new file for MIPS port by Craig Lebakken (lebakken@…) and …
4.104.114.84.95
@2ffcc2ed
09/06/96 15:17:39 |
Joel Sherrill |
modified test to take into account change in default value of …
4.104.114.84.95
@7fea679b
09/06/96 15:16:19 |
Joel Sherrill |
changed _TOD_Is_set from a function to a boolean variable
4.104.114.84.95
@65c421f
09/05/96 20:45:05 |
Joel Sherrill |
default thread attributes: default value for inheritsched changed from …
4.104.114.84.95
@297be5c
09/05/96 20:41:10 |
Joel Sherrill |
pthread_mutex_setprioceiling: fixed bug where returned priority was
4.104.114.84.95
@7e230f10
09/05/96 20:31:32 |
Joel Sherrill |
added printf of status when not successful
4.104.114.84.95
@9a5cbef0
09/05/96 20:29:07 |
Joel Sherrill |
nanosleep: negative value for tv_sec is no longer an error. It now
is …
4.104.114.84.95
@f254b93f
09/05/96 20:03:19 |
Joel Sherrill |
nanosleep no longer consider a negative value of tv_sec to be an …
4.104.114.84.95
@62bf651f
08/29/96 16:39:01 |
Joel Sherrill |
new file to support GNU Ada.
currently the only routine in this file …
4.104.114.84.95
@b5c04b6
08/27/96 15:19:51 |
Joel Sherrill |
fixed typo .. changed == to !=
4.104.114.84.95
@5a234809
08/27/96 15:19:33 |
Joel Sherrill |
check that we were passed a valid mutex and ignore errors from the …
4.104.114.84.95
@e4cc4176
08/23/96 15:58:24 |
Mark.Johannes |
Changed all EFAULTS to EINVALs
4.104.114.84.95
@3adf786
08/23/96 15:56:50 |
Mark.Johannes |
filled in screen
4.104.114.84.95
@237088c
08/23/96 15:56:22 |
Mark.Johannes |
Filled in screen
4.104.114.84.95
@78f5dae
08/23/96 15:55:02 |
Mark.Johannes |
Filled in the screen
4.104.114.84.95
@e2ceeca7
08/23/96 15:50:53 |
Mark.Johannes |
Added build_time statement to provide a tm for the test
4.104.114.84.95
@257adba
08/23/96 15:17:16 |
Mark.Johannes |
Changed test 5 to test 10 at bottom
4.104.114.84.95
@0b710dbb
08/23/96 14:47:58 |
Mark.Johannes |
pthread_create: changed EINVAL for no more threads back to EAGAIN
4.104.114.84.95
@df70c6b
08/22/96 20:18:44 |
Mark.Johannes |
Commented out the EINVAL for mutex not acquired befor cond_wait call
4.104.114.84.95
@6702bffc
08/21/96 15:49:21 |
Mark.Johannes |
updated to support ENOTSUP
4.104.114.84.95
@256a462
08/20/96 21:41:08 |
Mark.Johannes |
Added Einval case for mutex not initialized
4.104.114.84.95
@c5c5f8c
08/19/96 15:30:25 |
Mark.Johannes |
Changed all EFAULTs to EINVALs
4.104.114.84.95
@02f041e
08/19/96 15:27:37 |
Mark.Johannes |
pthread_mutex_init: added error messages for NULL mutex and EBUSY
4.104.114.84.95
@cd3868cd
08/15/96 21:09:02 |
Joel Sherrill |
updates from Tony Bennett (tbennett@…)
4.104.114.84.95
@0600e86f
08/15/96 21:05:21 |
Joel Sherrill |
_Thread_Start_multitasking: added code to initialize the floating …
4.104.114.84.95
@9ac3e76
08/15/96 19:38:46 |
Mark.Johannes |
changed ENOMEM error message
4.104.114.84.95
@7fb19bb
08/15/96 19:27:08 |
Mark.Johannes |
init: added tests for pthread_kill and kill errors.
4.104.114.84.95
@851b18d
08/15/96 18:59:34 |
Joel Sherrill |
changed error code
4.104.114.84.95
@fdf6917
08/15/96 18:59:00 |
Joel Sherrill |
changed error for too many threads to EAGAIN
4.104.114.84.95
@f3e19146
08/15/96 18:58:09 |
Joel Sherrill |
clock_gettime: changed assert condition to a standard error code
4.104.114.84.95
@b03ab630
08/15/96 18:57:07 |
Joel Sherrill |
sched_rr_get_interval: converted assert condition into a standard …
4.104.114.84.95
@57dae56
08/15/96 18:56:09 |
Joel Sherrill |
added constant to indicate there is no mutex associated with this …
4.104.114.84.95
@de45ddc
08/15/96 16:29:00 |
Mark.Johannes |
pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO
4.104.114.84.95
@948721c
08/15/96 16:24:44 |
Mark.Johannes |
pthread_kill: moved check for SA_SIGINFO to allow for validation of …
4.104.114.84.95
@48e685c
08/15/96 16:22:59 |
Mark.Johannes |
fixed typo for NOTSUP -> ENOTSUP
4.104.114.84.95
@fb7d080
08/14/96 20:25:57 |
Joel Sherrill |
pthread_mutex_init returns EAGAIN not ENOMEM when there are too many …
4.104.114.84.95
@ac81b6ca
08/14/96 19:41:47 |
Joel Sherrill |
added test cases for NULL being passed to pthread attribute get routines
4.104.114.84.95
@ff53a6d4
08/14/96 19:30:49 |
Joel Sherrill |
added test case for pthread_attr_getscope being passed a NULL …
4.104.114.84.95
@4e63ae5
08/14/96 17:20:45 |
Mark.Johannes |
commented of ENOTSUP until fixed in newlib
4.104.114.84.95
@aae1c932
08/14/96 17:20:03 |
Mark.Johannes |
pthread_cond_timedwait: added error cases for abstime
4.104.114.84.95
@87c8fd09
08/14/96 17:19:03 |
Mark.Johannes |
system.h: added task3 and changed condition variable config to 1
4.104.114.84.95
@b0c483ed
08/14/96 17:18:02 |
Mark.Johannes |
task3: added to test error case in Wait_support for lock on mutex
4.104.114.84.95
@520949bf
08/14/96 17:16:14 |
Mark.Johannes |
init: added error case for wait timedwait, and wait support
4.104.114.84.95
@645fc954
08/14/96 15:27:14 |
Joel Sherrill |
pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope
4.104.114.84.95
@dce801d
08/13/96 21:32:49 |
Mark.Johannes |
pthread_cond_destroy: added enable dispatch to EBUSY case
4.104.114.84.95
@95b76bc
08/13/96 21:10:06 |
Mark.Johannes |
pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First
4.104.114.84.95
@456b3769
08/13/96 20:50:54 |
Mark.Johannes |
pthread_cond_destroy: EBUSY case now uses Thread_queue_First
4.104.114.84.95
@c53eb2c3
08/13/96 20:46:10 |
Mark.Johannes |
removed count from Thread_queue_Control
4.104.114.84.95
@a66fcc5
08/13/96 20:43:51 |
Mark.Johannes |
removed Thread_queue_Get_number_waiting
4.104.114.84.95
@392b35e
08/13/96 20:38:30 |
Joel Sherrill |
deleted a line for spacing correction
4.104.114.84.95
@48b40d8
08/13/96 19:53:51 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: changed status of lock and …
4.104.114.84.95
@c8a4ed6
08/13/96 19:06:45 |
Mark.Johannes |
task_2: added comments and print statement for task exit
4.104.114.84.95
@1d428a3c
08/13/96 19:06:12 |
Mark.Johannes |
task_1: added comments and print statement for task exit
4.104.114.84.95
@c9c94387
08/13/96 19:05:27 |
Mark.Johannes |
Init.c: added timewait case, added broadcast case
4.104.114.84.95
@76f03c6
08/13/96 19:03:29 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: fixed the timeout sequence.
4.104.114.84.95
@b2e8026
08/13/96 15:43:12 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@9b67f170
08/13/96 15:36:28 |
Joel Sherrill |
corrected problem in which sigtimedwait() was being invoked with
the …
4.104.114.84.95
@fc960ab
08/13/96 15:35:36 |
Joel Sherrill |
chenaged format of output
4.104.114.84.95
@0d59c7a
08/13/96 14:47:52 |
Joel Sherrill |
added include of errno.h so the test can check for EINTR.
4.104.114.84.95
@85f5b4ab
08/13/96 14:47:31 |
Joel Sherrill |
nanosleep now returns -1 and EINTR when a signal interrupts EINTR.
4.104.114.84.95
@f48c9068
08/13/96 14:24:00 |
Joel Sherrill |
removed errors for TOD not set yet.
made nanosleep return -1/EINTR …
4.104.114.84.95
@aac34f7b
08/13/96 14:23:16 |
Joel Sherrill |
added page break before sysconf()
4.104.114.84.95
@e9624663
08/12/96 21:52:37 |
Mark.Johannes |
task_1: added to handle cases of waiting tasks on condition variables
4.104.114.84.95
@a7f4c5a
08/12/96 21:51:44 |
Mark.Johannes |
system.h: added protoypes for task and task2, added mutex id, and task ids
4.104.114.84.95
@aad3fe6
08/12/96 21:49:54 |
Mark.Johannes |
Init.c: added cases for signal, wait and broadcast
4.104.114.84.95
@08515de
08/12/96 21:49:14 |
Mark.Johannes |
Task2: new task for broadcast case
4.104.114.84.95
@5da2ae8
08/12/96 21:15:15 |
Joel Sherrill |
added test cases for clock_getres
4.104.114.84.95
@1087564
08/12/96 20:59:41 |
Joel Sherrill |
clock_getres: added error check for NULL pointer being passed in.
4.104.114.84.95
@3fbfbcd
08/12/96 20:48:13 |
Joel Sherrill |
sleep: wrong page number
4.104.114.84.95
@702a31c
08/12/96 20:08:36 |
Joel Sherrill |
removed comment about NO_UNINITIALIZED_WARNINGS since that macro
no …
4.104.114.84.95
@221bd65
08/12/96 20:00:02 |
Joel Sherrill |
added test case for stack too large
4.104.114.84.95
@5f08fd6
08/12/96 19:55:09 |
Joel Sherrill |
nanosleep: verify rqtp parameter is non-NULL.
nanosleep: return 0 …
4.104.114.84.95
@c4f5e752
08/12/96 19:54:12 |
Joel Sherrill |
added test cases for clock_gettime (invalid id), clock_settime …
4.104.114.84.95
@d60d9505
08/12/96 19:20:18 |
Joel Sherrill |
added test case for non-NULL parameter to time()
4.104.114.84.95
@40cfab47
08/12/96 19:19:03 |
Joel Sherrill |
time: It is not an error if the TOD is not set.
4.104.114.84.95
@9b77fee
08/12/96 19:00:12 |
Mark.Johannes |
Wait_support: removed the calls to mutex core to posix status codes
4.104.114.84.95
@3b97b7a0
08/12/96 18:58:12 |
Mark.Johannes |
mutex.h: removes the promotion of core status code to POSXI status codes
4.104.114.84.95
@1402ee25
08/12/96 18:56:04 |
Joel Sherrill |
fixed spacing ; moved a dummy MP support routine to clean up printout.
4.104.114.84.95
@c7a9c66
08/12/96 18:06:27 |
Joel Sherrill |
_POSIX_Mutex_Get: made null id an error
4.104.114.84.95
@ccdf4c57
08/12/96 18:05:47 |
Joel Sherrill |
pthread_mutex_getprioceiling: added error check for null old_ceiling
4.104.114.84.95
@d06e9ca
08/12/96 18:04:38 |
Joel Sherrill |
added numerous error test cases.
4.104.114.84.95
