@c539a865
11/14/16 10:34:54 |
Sebastian Huber |
sparc: Move CPU_Interrupt_frame related defines
Move …
5
@427dcee
11/11/16 10:17:02 |
Sebastian Huber |
sparc: Rename CPU_Minimum_stack_frame
Rename SPARC-specific …
5
@d18560a
11/11/16 10:16:33 |
Sebastian Huber |
sparc64: Rename CPU_Minimum_stack_frame
Rename SPARC64-specific …
5
@8ef8a32
11/11/16 09:48:14 |
Sebastian Huber |
bsps/mips: Use <libcpu/isr_entries.h>
Avoid duplicate …
5
@04bd261
11/13/16 14:18:58 |
Sebastian Huber |
arm: Use TPIDRPRW for current per-CPU control
Use the previously …
5
@bb5d97f3
11/17/16 13:56:53 |
Christian.Mauderer |
bsp/atsamv: Make size of nocache-memory configurable.
5
@38a1449
11/09/16 13:59:33 |
Sebastian Huber |
powerpc: Add _CPU_Get_current_per_CPU_control()
Add …
5
@1f5bee3
11/07/16 15:54:40 |
Sebastian Huber |
score: Add and use Thread_Control::is_idle
Update #2797.
5
@6cb234f
11/07/16 08:30:17 |
Sebastian Huber |
bsp/qoriq: Remove duplicate qoriq_gpio definition
Close #2800.
5
@11ae6f9
11/03/16 17:49:12 |
Tim Cussins |
virtex4, virtex5 bsp.h: Use BSP_INTERRUPT_STACK_SIZE not user space …
5
@0df50a6c
10/03/16 15:59:47 |
joel |
m68k/mrm332/make/custom/mrm332-testsuite.tcfg: Add dl05
5
@c2798633
10/03/16 15:59:31 |
joel |
m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg: Add dl05
5
@fbf4543
10/03/16 15:59:05 |
joel |
m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add dl05
5
@710302ae
10/03/16 15:58:45 |
joel |
mcf5206elite/make/custom/mcf5206elite-testsuite.tcfg: Add dl05
5
@c7589640
08/08/16 16:33:21 |
joel |
moxiesim/bsp_specs: Add crtbegin/end to fix link issues
5
@fac8a3a
11/02/16 09:01:36 |
Sebastian Huber |
bsps/sparc: Fix copy of initialized data
The text and data sections …
5
@fc718cb8
10/22/16 15:46:56 |
jcmarsh |
Updated xilinx_zynq_a9_qemu bsp README instructions.
5
@f94155b
10/18/16 22:22:57 |
Sebastian Huber |
bsps/sparc: Add interrupt controller registers
5
@9361412
10/18/16 22:21:21 |
Sebastian Huber |
bsp/leon3: Avoid implicit integer conversions
5
@24fe213
10/17/16 12:36:49 |
alexander.krutwig |
atsam: multiple messages on one cs low level
5
@dfcec559
10/12/16 08:15:29 |
pisa |
libchip/network/if_fxp.c: do not use rtems_interrupt_disable.
The …
5
@20625a5
10/12/16 07:47:00 |
pisa |
bsps/i386: use Pentimum instructions for pc586 and pc686 builds.
When …
5
@6b54dcb
10/12/16 07:40:41 |
pisa |
bsps/i386: replace global interrupt disable by SMP build supporting …
5
@f45ddeea
10/13/16 05:51:55 |
Sebastian Huber |
bsp/atsamv: Fix typo
5
@facebbb
10/02/16 10:19:12 |
pisa |
bsps/i386: Separate variable for i8259 IRQs disable due to in progress …
5
@282de10
10/11/16 08:42:15 |
Sebastian Huber |
bsp/qoriq: Add GPIO register map
5
@00bac95
10/11/16 06:25:39 |
Sebastian Huber |
bsps/sparc: Support GR740 GPIO
5
@a899549e
10/05/16 12:04:23 |
Sebastian Huber |
bsp/atsam: Provide default buffer counts
5
@10eedb9f
10/05/16 12:04:07 |
Sebastian Huber |
bsp/atsam: Fix PHY detection
5
@8ace7ee4
09/23/16 06:17:00 |
Sebastian Huber |
bsp/mvme147*: Fix linker issue
The GNU linker does not allow a …
5
@bbe8833
09/23/16 06:03:41 |
Sebastian Huber |
bsps/m68k: Add libatomic support to some bsp_specs
Update #2695.
5
@d6e58a0
09/23/16 04:44:08 |
Sebastian Huber |
bsps/m68k: Fix linker command file
Prevent garbage collection of …
5
@425f6cfa
09/22/16 07:56:06 |
pisa |
arm/tms570: document BSP setup with included hardware initialization.
5
@aae17bf3
09/22/16 07:48:26 |
pisa |
arm/tms570: update bootstrap generated preinstall.am
5
@98b6874
09/22/16 07:23:17 |
pisa |
arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare …
5
@29430a3
09/22/16 07:50:59 |
pisa |
arm/tms570: include hardware initialization and selftest based on Ti …
5
@5746f10
09/12/16 08:46:58 |
pisa |
arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces.
5
@a396ed4
09/17/16 15:09:11 |
pisa |
bsps/arm: Export bsp_start_hook_0_done symbol from ARM start.S.
The …
5
@4d3c866
09/20/16 22:14:45 |
pisa |
classic networking: adapt FXP driver to work with actual PCI and IRQ …
5
@8c83cbc
08/04/16 21:32:06 |
pisa |
classic networking: do not reference BSP_irq_enabled_at_i8259s which …
5
@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@0ab86d09
09/13/16 14:32:51 |
alexander.krutwig |
bsp/atsam: Add SPI bus driver
5
@c186de5c
09/14/16 12:46:03 |
alexander.krutwig |
bsp/atsam: Use normal memory for QSPI flash area
This is a …
5
@5eb769ca
09/08/16 21:40:21 |
pisa |
arm/raspberrypi: define bsp_reset to restart board by watchdog.
5
@275032b
09/08/16 07:31:47 |
Sebastian Huber |
powerpc: Fix SMP context switch
We need the unmodified r4 for …
5
@d4160618
09/07/16 03:59:16 |
Chris Johns |
testsuite: Add libdl/dl05 reloc test.
5
@531924d
09/08/16 05:24:29 |
Sebastian Huber |
bsp/raspberrypi: Rename file
5
@5d369c85
09/03/16 12:10:52 |
pisa |
arm/raspberrypi: use GPU/system timer as clock source.
It has …
5
@40f49d1
09/03/16 12:04:16 |
pisa |
arm/raspberrypi: correct and extend definitions for GPU timer.
5
@df2ee9d
09/07/16 18:28:33 |
pisa |
arm/raspberrypi: basic BCM2836 SMP implementation.
The BSP support is …
5
@38a5385
09/01/16 19:55:51 |
pisa |
arm/raspberrypi: propagate number of configured CPUs into linker script.
5
@dfbedf3
09/01/16 19:40:09 |
pisa |
arm/raspberrypi: rename linkcmds to linkcmds.in to allow their …
5
@4c53be1
09/03/16 01:37:36 |
pisa |
arm/raspberrypi: more definitions of BCM2836 core local peripherals.
5
@bf62c39
09/03/16 00:26:10 |
krohini1593 |
arm/raspberrypi: include definitions of BCM2836 SMP mailboxes.
5
@6e6a77a6
09/02/16 23:59:21 |
pisa |
bsps/arm: reorganize CP15 code to allow clean and invalidate ARMv7 …
5
@5c494641
09/02/16 23:30:47 |
pisa |
bsps/arm: remove lock in arm_cp15_set_translation_table_entries().
5
@7ec689ad
09/02/16 23:30:20 |
pisa |
bsps/arm: use defines for cache type register format field.
The …
5
@b9cc5aa
08/22/16 08:41:33 |
bsp/atsam: Add SDRAM IS42S16320F-7BL.
5
@beb289e
08/19/16 09:59:12 |
bsp/atsam: Move ram init values to structure.
5
@cac586e6
09/06/16 08:55:09 |
Sebastian Huber |
bsp/xilinx-zynq: Avoid duplicate declaration
5
@caf2cbd
08/16/16 05:49:41 |
Chris Johns |
arm/xilinx_zynq: Start the second core when an SMP build.
5
@13c985c
08/31/16 14:49:15 |
pisa |
arm/xilinx_zynq: ensure that cache is cleaned and MMU disabled when …
5
@6deb4190
08/25/16 06:18:21 |
Chris Johns |
libdl: The dl04 is too big for some BSPs. Do not built it.
5
@3c74f4aa
08/27/16 06:15:04 |
muditjain18011995 |
arm/raspberrypi: Mailbox : Extending functionality
Adding …
5
@8099e0a
08/24/16 14:26:07 |
alexander.krutwig |
bsp/atsam: Add missing break statement
5
@8cf102dd
08/24/16 13:30:06 |
alexander.krutwig |
bsp/atsam: Fix data cache flush
5
@89a319a0
08/23/16 01:11:53 |
Chris Johns |
libbsp/arm: Fix ARM BSPs missing the bsp_translation_table_end symbol. …
5
@fea392a
08/10/16 08:32:39 |
alexander.krutwig |
bsp/atsam: Add timeout to QSPI send command
5
@01aa1ba
08/09/16 07:05:27 |
Chris Johns |
libbsp/arm: Add the TTB table to the default MMU set up as read/write. …
5
@03c1038
08/10/16 03:28:50 |
Chris Johns |
librtems++: Remove from RTEMS.
This is old and there are better …
5
@9a4eca5
08/10/16 03:07:29 |
Chris Johns |
build-system: Always enable C++ if the compiler is present.
We always …
5
@5d0f0de4
07/28/16 11:33:50 |
alexander.krutwig |
bsp/atsam: Add power support
5
@e5fd901
07/28/16 10:01:58 |
alexander.krutwig |
atsam: Add atsam_rtc_get_time()
5
@912a1a90
07/31/16 11:10:28 |
pisa |
arm/raspberrypi: framebuffer driver checks for initialization and …
5
@3d3ad4dc
07/31/16 09:33:06 |
pisa |
arm/raspberrypi: VideoCore? access corrections in cache operation and …
5
@f383f4bf
07/27/16 09:39:56 |
Sebastian Huber |
bsp/qoriq: Remove legacy U-Boot support
5
@cecc109
07/28/16 08:48:02 |
Sebastian Huber |
bsp/qoriq: Fix start stack setup
5
@6446773
07/28/16 08:35:24 |
Sebastian Huber |
bsp/qoriq: Fix tlbwe synchronization
5
@b1ef3674
07/27/16 09:30:09 |
Sebastian Huber |
bsp/qoriq: Add QORIQ_HAS_WRITE_BACK_L1_CACHE
Fixes start via U-Boot …
5
@f6fdf2e
07/25/16 13:11:07 |
alexander.krutwig |
atsam: Add user defined RX/TX descriptor counts
5
@c51e6d91
07/18/16 11:20:18 |
alexander.krutwig |
atsam: Use normal memory for DTCM
Avoids problems with unaligned data …
5
@84008f9e
07/25/16 12:51:06 |
alexander.krutwig |
bsps/arm: Clear pending exceptions for ARMv7-M
5
@ba5de753
07/25/16 11:57:52 |
Sebastian Huber |
bsps: Fix shared polled console fatal error
Fatal errors must …
5
@ba0471d
07/23/16 13:15:17 |
pisa |
arm/raspberrypi: add Secure Digital (SD) controller interrupt source …
5
@d216c5d6
07/23/16 10:10:34 |
pisa |
arm/raspberrypi: change interrupt dispatch and enable to generic …
5
@d548318
07/23/16 10:07:10 |
pisa |
arm/raspberrypi: remove duplicate setup of IRQ handler in the main ARM …
5
@1c62f7ee
07/22/16 08:27:11 |
deval.maker |
Added USB interrupt handler. And defined some macros regarding USB.
5
@0055b65
07/22/16 19:15:55 |
pisa |
bsp/tms570: ensure that change of SCI baudrate is not applied in the …
5
@dcf806e
07/17/16 16:50:18 |
pisa |
arm/raspberrypi: reorder and update MMU config table to nor force RW …
5
@bef2b73
07/17/16 16:45:46 |
pisa |
arm/raspberrypi: use cache manager operations to flush/invalidate all …
5
@577e7fb
07/17/16 17:31:33 |
pisa |
arm/bsps: CP15 and basic cache support entire cache clean for more …
5
@33381218
07/17/16 16:21:48 |
pisa |
bsps/arm: do not disable MMU during translation table management …
5
@a48c052
07/15/16 14:21:12 |
pisa |
arm/raspberrypi: cache manager can be used for mailbox synchronization …
5
@c2a4b8bf
07/19/16 07:42:26 |
Sebastian Huber |
bsps/powerpc: Fix shared console driver
The Termios modes are now an …
5
@8d785f7
07/19/16 04:43:10 |
Sebastian Huber |
bsps/powerpc: Fix AtliVec? context switch
Properly pass the stack …
5
@55bde66
07/17/16 13:40:30 |
punitvara |
beagle: pwm polishing
. added a README to pwm
. added …
5
@612297e8
07/12/16 10:44:17 |
joel |
Misc: Spell length correctly
5
@814bd6e3
07/12/16 08:02:40 |
Sebastian Huber |
bsps/powerpc: Fix AltiVec? enable
There must be an isync after the …
5
@116370c6
07/05/16 15:10:31 |
joel |
shared/console-polled.c: Use standard fatal error codes
5
@c3058473
07/04/16 18:34:39 |
Sebastian Huber |
bsps/arm: Fix basic cache support for SMP
5
