@c2ea0ea
05/06/14 12:44:17 |
Sebastian Huber |
bsp/gen83xx: Add BSP_USB_EHCI_MPC83XX_HAS_ULPI
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@b0e83e12
04/30/14 08:13:07 |
ralf.kirchner |
libchip: Add asserts to dwmac driver
4.115
@64bc102
04/30/14 08:07:20 |
ralf.kirchner |
libchip: Correct netstats message for dwmac driver
4.115
@bc9a71b
04/30/14 08:06:11 |
ralf.kirchner |
bsp/altera-cyclone-v: Move mbufs and network clusters to uncached RAM
4.115
@ff13e0b
04/30/14 08:06:10 |
ralf.kirchner |
bsp/altera-cyclone-v: Increase size of nocache region and nocache heap …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@a16af0b3
04/29/14 07:39:08 |
Sebastian Huber |
bsps/mips: Delete unused files
The MIPS port defines …
4.115
@0b344f34
04/29/14 06:53:35 |
Sebastian Huber |
bsps/m32r: Fix bsp_specs
4.115
@ef26454
04/29/14 06:43:04 |
Sebastian Huber |
bsps/bfin: Fix bsp_specs
4.115
@6741427a
04/28/14 14:55:38 |
Sebastian Huber |
bsp/h8sim: Fix linker command file
4.115
@7c0bd74
04/22/14 08:15:39 |
Sebastian Huber |
sparc: Add _CPU_Get_current_per_CPU_control()
Use register g6 for the …
4.115
@b2ec2d15
04/22/14 05:46:56 |
Sebastian Huber |
sparc: Optimize context switch
The registers g2 through g4 are …
4.115
@f412e12
04/24/14 13:21:00 |
Joel Sherrill |
mcf52235/configure.ac: Delete junk line
4.115
@b74c9cf
04/23/14 04:31:55 |
Chris Johns |
bootstrap: Sort the contents of the prinstall.am files.
Sorting …
4.115
@1450de0
04/22/14 18:10:47 |
Joel Sherrill |
shsim: Correct linking for C++
4.115
@25c3208a
04/22/14 18:08:14 |
Joel Sherrill |
gensh4: Correct linking for C++
4.115
@851e643
04/22/14 18:07:56 |
Joel Sherrill |
gensh2: Correct linking for C++
4.115
@3191b42
04/22/14 18:07:44 |
Joel Sherrill |
gensh1: Correct linking for C++
4.115
@b6a2e57b
04/22/14 18:07:01 |
Joel Sherrill |
score603e: Add rtems_crti
4.115
@77737ad
04/22/14 18:06:08 |
Joel Sherrill |
ss555: Add rtems_crti/n
4.115
@812c9d6
04/22/14 15:44:20 |
Joel Sherrill |
sim68000/bsp_specs: Add crtbegin/end, crt[in]
4.115
@2f36f5a5
04/22/14 15:36:44 |
Joel Sherrill |
mpc8260ads: Add rtems_crti/n
4.115
@8c18adde
04/22/14 14:45:55 |
Joel Sherrill |
h8sim/bsp_specs: Add crtbegin/end, crt[in]
4.115
@d47904f
04/21/14 18:08:00 |
Joel Sherrill |
niagara/Makefile.am: Fix rule for start.o
4.115
@90bc4d03
04/21/14 14:07:51 |
Joel Sherrill |
libcpu/sh: Build cache stubs so apps usign cache API link
4.115
@614fefe
04/18/14 16:05:18 |
Joel Sherrill |
dummy_printk_support.c: Comment clean up
4.115
@a531683
04/18/14 15:52:21 |
Joel Sherrill |
shsim: Add printk() support and move all code to console subdirectory
4.115
@d60e760
04/22/14 07:45:39 |
Sebastian Huber |
bsps: Fix TLS support in linker command files
The TLS section symbols …
4.115
@e2782684
04/22/14 07:32:16 |
Sebastian Huber |
bsp/mbx8xx: Fix Makefile.am and bsp_specs
4.115
@e10574a
04/22/14 06:32:27 |
Sebastian Huber |
bsps/powerpc: Fix linker command files
4.115
@d98eea0
04/17/14 09:27:23 |
ralf.kirchner |
bsp/arm: Cleanup L2 cache handling
4.115
@127634c
04/17/14 09:22:53 |
ralf.kirchner |
bsp/arm: Correct L2 cache enable method
4.115
@62fa1ea
04/17/14 09:19:48 |
ralf.kirchner |
bsp/arm: Add cache size methods
Add new methods which deliver the …
4.115
@1c62f74d
04/17/14 09:11:58 |
ralf.kirchner |
bsp/arm: Add L2 cache locking
This level 2 cache is a shared data and …
4.115
@bebcfa57
04/17/14 09:03:50 |
ralf.kirchner |
bsp/arm: Remove unused cache store methods
4.115
@db5a84d
04/17/14 08:59:47 |
ralf.kirchner |
bsp/arm: Correct cache misalignment handling
Correct misalignment …
4.115
@92e2757
04/17/14 08:37:10 |
ralf.kirchner |
bsp/arm: Correct L2 cache flushing
Correct misalignment handling and …
4.115
@cbd9e63
04/17/14 08:30:54 |
ralf.kirchner |
bsp/arm: Remove arm erratum 764369 from L2 cache
Arm erratum 764369 …
4.115
@9ee2ec5
04/17/14 07:43:30 |
ralf.kirchner |
bsp/arm: Consistenly same handling for flushing
It is importeant to …
4.115
@e331e69
04/16/14 14:07:13 |
ralf.kirchner |
bsp/arm: RTEMS_SMP to arm erratum 764369 detection
Move the RTEMS_SMP …
4.115
@707b6172
04/16/14 14:04:56 |
ralf.kirchner |
bsp/arm: Erratum 764369 after enabling SCU
Execute the SCU part of …
4.115
@d9e7d1e
04/16/14 12:27:36 |
ralf.kirchner |
bsp/arm: Correct detection of arm erratum 764368
4.115
@924b47a
04/17/14 07:21:36 |
ralf.kirchner |
bsp/arm: Cleanup L1 cache
4.115
@a38d4a37
04/16/14 12:22:42 |
ralf.kirchner |
libchip: Correct error handling in dwmac driver
By fault an …
4.115
@1613a01b
04/10/14 15:06:14 |
ralf.kirchner |
libchip: Reduce tx interrupts
Reduce number of packet transmitted …
4.115
@f28b8d45
04/10/14 15:03:54 |
ralf.kirchner |
libchip: Cleanup
4.115
@18fe64a2
04/10/14 15:02:40 |
ralf.kirchner |
libchip: Improve handling of DMA suspends
Reset the corresponding DMA …
4.115
@6ac3969
04/10/14 14:57:02 |
ralf.kirchner |
bsp/altera-cyclone-v: Cleanup
4.115
@782182eb
04/10/14 14:54:39 |
ralf.kirchner |
bsp/altera-cyclone-v: Change console baud rate
The baud rate of the …
4.115
@320faf8e
04/17/14 05:57:09 |
Sebastian Huber |
score: Clarify TLS support
4.115
@b80f920
04/15/14 11:36:35 |
Sebastian Huber |
bsp/qoriq: SMP support for IRQ support
4.115
@487b94e7
04/15/14 11:34:24 |
Sebastian Huber |
bsps/powerpc: SMP support for SPR functions
These registers are local …
4.115
@598f39cd
04/15/14 11:33:42 |
Sebastian Huber |
libchip: SMP support for NS16550
4.115
@509040f0
04/14/14 15:11:12 |
Sebastian Huber |
bsps/powerpc: SMP support for one TSEC driver
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@53e008b
04/10/14 13:48:05 |
Sebastian Huber |
score: SMP initialization changes
Add and use …
4.115
@67a7a2c
04/14/14 06:09:54 |
Sebastian Huber |
sparc: Use leon multilib define
4.115
@73b9af2d
03/14/14 18:22:30 |
Gedare Bloom |
sparc64/niagara: add bsp_fatal_handler to terminate execution
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@95cb09e
04/02/14 16:39:20 |
Joel Sherrill |
sparc/shared/.../linkcmds.base: Correct C++ support
Add KEEP() for …
4.115
@aa7ff5d3
04/03/14 20:14:47 |
Joel Sherrill |
leon2 ckinit.c, console.c: Comment clean up
4.115
@fcc10761
04/03/14 20:13:58 |
Joel Sherrill |
leon2/Makefile.am: Change to one file per line
4.115
@68a6470
04/03/14 20:13:45 |
Joel Sherrill |
erc32/Makefile.am: Change to one file per line
4.115
@6c0b7b8
04/03/14 20:13:25 |
Joel Sherrill |
psim/console/console-io.c: Comment clean up
4.115
@d4db719
04/03/14 20:13:08 |
Joel Sherrill |
sim68000/console/conscfg.c: Comment clean up
4.115
@3a422f7d
04/03/14 20:11:50 |
Joel Sherrill |
h8sim/console/console-io.c: Comment clean up
4.115
@8e980e61
04/01/14 07:48:40 |
Sebastian Huber |
4.115
@10b0c3f
03/31/14 14:11:30 |
Sebastian Huber |
bsps/powerpc: PR757: Fix PPC_IRQ_TRACE for ppc601
We could probably …
4.115
@8118b670
03/31/14 16:30:44 |
Sebastian Huber |
libchip: Avoid DEVOLATILE()
4.115
@1d9818d
03/31/14 11:06:20 |
cederman |
LEON3: UT699 and GR712 sleep-mode d-cache fix
See errata of …
4.115
@3c21ad7
03/31/14 06:39:59 |
ppisa4lists |
SPI SD-Card: adapt common driver code to block devices core API changes.
4.115
@89aa1ec8
03/24/14 09:32:10 |
james.fitzsimons |
m68k/mrm332: changes required to get the mrm332 bsp working again.
4.115
@67a4842
03/24/14 07:54:15 |
cederman |
bsps/sparc: Make local functions for amba plug&play static.
4.115
@52f6502
03/13/14 13:13:55 |
cederman |
bsps/sparc: Add common gnat handler function prototype.
Moved …
4.115
@e4b50853
03/13/14 13:35:43 |
cederman |
greth: Make local functions static, remove overflow and correct printf …
4.115
@3240325
03/13/14 13:26:00 |
cederman |
bsps/sparc: Change asm to asm to compile with -pedantic.
4.115
@f23bd591
03/13/14 13:21:27 |
cederman |
bsps/sparc: Make spurious trap handler function static.
4.115
@a46e02c7
03/13/14 13:33:00 |
cederman |
bsps/sparc: Make local functions static.
The PCI and RASTA versions …
4.115
@5130248e
03/13/14 13:28:46 |
cederman |
smc91111: Move driver attach prototype to header file.
Also signal to …
4.115
@82e507e
03/17/14 18:25:48 |
Joel Sherrill |
no_bsp/shmsupp/lock.c: Remove rtems_bsp_delay()
4.115
@8d687914
03/17/14 18:25:48 |
Joel Sherrill |
no_bsp/include/bsp.h: Remove rtems_bsp_delay()
4.115
@bd7dd3b0
03/17/14 18:25:48 |
Joel Sherrill |
nios2_iss/include/bsp.h: Remove rtems_bsp_delay()
4.115
@b51e44ad
03/17/14 18:25:48 |
Joel Sherrill |
moxiesim/include/bsp.h: Remove rtems_bsp_delay()
4.115
@43e5a3c
03/17/14 18:25:48 |
Joel Sherrill |
sim68000/include/bsp.h: Remove rtems_bsp_delay()
4.115
@2e9efbf
03/17/14 18:25:48 |
Joel Sherrill |
ods68302/include/bsp.h: Remove rtems_bsp_delay()
4.115
@a4ee9f5
03/17/14 18:25:48 |
Joel Sherrill |
mvme136/include/bsp.h: Remove rtems_bsp_delay()
4.115
@3420b6b
03/17/14 18:25:48 |
Joel Sherrill |
mrm332/include/bsp.h: Remove rtems_bsp_delay()
4.115
@65e0fece
03/17/14 18:25:47 |
Joel Sherrill |
gen68360/include/bsp.h: Remove rtems_bsp_delay()
4.115
@99a1a2c5
03/17/14 18:25:47 |
Joel Sherrill |
gen68340/include/bsp.h: Remove rtems_bsp_delay()
4.115
@3139c1d0
03/17/14 18:25:47 |
Joel Sherrill |
gen68302/include/bsp.h: Remove rtems_bsp_delay()
4.115
@130f01b
03/17/14 18:25:47 |
Joel Sherrill |
m32rsim/include/bsp.h: Remove rtems_bsp_delay()
4.115
@0758923
03/17/14 18:25:47 |
Joel Sherrill |
m32cbsp/include/bsp.h: Remove rtems_bsp_delay()
4.115
@0e363f4
03/17/14 18:25:47 |
Joel Sherrill |
lm32_evr/include/bsp.h: Remove rtems_bsp_delay()
4.115
@31f1ef9d
03/17/14 18:25:47 |
Joel Sherrill |
pc386/include/bsp.h: Remove rtems_bsp_delay()
4.115
@43af31d
03/17/14 18:25:47 |
Joel Sherrill |
h8sim/include/bsp.h: Remove rtems_bsp_delay()
4.115
@8fd544d5
03/17/14 18:23:59 |
Joel Sherrill |
gensh1/include/bsp.h: Remove rtems_bsp_delay()
4.115
@5830f5a
03/17/14 18:23:59 |
Joel Sherrill |
gensh2/include/bsp.h: Remove rtems_bsp_delay()
4.115
@770ad77
03/17/14 18:23:59 |
Joel Sherrill |
gensh4/include/bsp.h: Remove rtems_bsp_delay()
4.115
